[RSB PATCH] 6: Merge the MacOS M silicon patch from gcc-12 to gcc-13
Karel Gardas karel at functional.vision
Mon Dec 18 09:50:39 UTC 2023
On 12/18/23 07:05, Chris Johns wrote:
>> Mac with M1/M2/M3 work fine with the latest tooling.
> I think there is a middle ground here and that means some investigation is
> needed to determine what works and what is at issue then deciding how much
> further work is done. I have done some of this. The results are based on what I
> have working:
> Builds:
>    Sonoma
>    Montery
>    Big Sur
> Fails:
>    Ventura
> The failure on Ventura is in GMP called from MPFR. Running the GMP tests a
> number fail and removing --disable-shared improves the test results but GCC does
> not build. I have not looked any further.
Just a rant.
IIRC when Ventura cames it was a disaster for RSB since on Monterey this
worked and on Ventura it stopped. IIRC less RAM on system shows more
sensibility to Ventura problems. And IIRC you were the person who solved
this somehow.
Does this mean we're back to the original state with Ventura making
troubles again? I'm not sure if this is even technically possible
(partly due to how Apple supports OS reverts) to test every version of
Ventura released by Apple to see reliably if whole family is sick or
there are some versions which may be recommended for use. E.g. Ventura
spans from 13.0 to 13.5 already...
Perhaps doable on VM...
Karel
