[PATCH rtems-central v2] spec: Add JFFS2 delayed write task priority
Kinsey Moore kinsey.moore at oarcorp.com
Mon Dec 18 15:53:13 UTC 2023
On Mon, Dec 18, 2023 at 9:21 AM Sebastian Huber <
> On 18.12.23 15:59, Kinsey Moore wrote:
> > This adds the configuration option used to select the JFFS2 delayed
> > write task priority to be used when operating on NAND flash.
> Thanks, looks good. Should I check it in and update the generated
> documentation?
That sounds great, thanks!
Kinsey
URL: <http://lists.rtems.org/pipermail/devel/attachments/20231218/8816f9fd/attachment.htm>
