[PATCH 07/47] bsp/tms570: Add bsp_restart()
Thu Dec 21 14:37:40 UTC 2023
 bsps/arm/tms570/include/bsp.h      |  2 ++
 bsps/arm/tms570/start/bsprestart.c | 42 ++++++++++++++++++++++++++++++
 spec/build/bsps/arm/tms570/obj.yml |  1 +
 3 files changed, 45 insertions(+)
 create mode 100644 bsps/arm/tms570/start/bsprestart.c
diff --git a/bsps/arm/tms570/include/bsp.h b/bsps/arm/tms570/include/bsp.h
index adb0a2769a..9d26309e07 100644
--- a/bsps/arm/tms570/include/bsp.h
+++ b/bsps/arm/tms570/include/bsp.h
@@ -69,6 +69,8 @@
 #define BSP_PLL_OUT_CLOCK 160000000
 #endif
+RTEMS_NO_RETURN void bsp_restart(const void *addr);
 #endif /* ASM */
diff --git a/bsps/arm/tms570/start/bsprestart.c b/bsps/arm/tms570/start/bsprestart.c
new file mode 100644
index 0000000000..c989d8fc77
--- /dev/null
+++ b/bsps/arm/tms570/start/bsprestart.c
@@ -0,0 +1,42 @@
+ * Copyright (c) 2017 embedded brains GmbH & Co. KG
+ * are met:
+#include <bsp.h>
+void bsp_restart( const void *addr )
+  rtems_interrupt_level level;
+  void(*start)(void) = (void(*)(void))(addr);
+  rtems_interrupt_disable(level);
+  (void)level;
+  rtems_cache_disable_instruction();
+  rtems_cache_disable_data();
+  start();
+  RTEMS_UNREACHABLE();
diff --git a/spec/build/bsps/arm/tms570/obj.yml b/spec/build/bsps/arm/tms570/obj.yml
index 35a2b9ce6a..46e4eea116 100644
--- a/spec/build/bsps/arm/tms570/obj.yml
+++ b/spec/build/bsps/arm/tms570/obj.yml
@@ -80,6 +80,7 @@ source:
 - bsps/arm/tms570/cpucounter/cpucounterread.c
 - bsps/arm/tms570/irq/irq.c
 - bsps/arm/tms570/start/bspreset.c
+- bsps/arm/tms570/start/bsprestart.c
 - bsps/arm/tms570/start/bspstart.c
 - bsps/arm/tms570/start/pinmux.c
 - bsps/arm/tms570/start/tms570-pom.c
2.35.3
