[PATCH 14/47] bsp/tms570: Add TM27 support
Thu Dec 21 14:37:47 UTC 2023
 bsps/arm/tms570/include/tm27.h | 129 ++++++++++++++++++++++++++++++++-
 1 file changed, 128 insertions(+), 1 deletion(-)
diff --git a/bsps/arm/tms570/include/tm27.h b/bsps/arm/tms570/include/tm27.h
index 0dfa7bf628..a8ca08a0dd 100644
--- a/bsps/arm/tms570/include/tm27.h
+++ b/bsps/arm/tms570/include/tm27.h
@@ -1 +1,128 @@
-#include <rtems/tm27-default.h>
+ * @file
+ * @ingroup RTEMSBSPsARMTMS570
+ * @brief This header file provides a TM27 support implementation.
+ * Copyright (c) 2023 embedded brains GmbH & Co. KG
+ * are met:
+#ifndef _RTEMS_TMTEST27
+#error "This is an RTEMS internal file you must not include directly."
+#endif
+#ifndef __tm27_h
+#define __tm27_h
+#include <rtems.h>
+#include <bsp/irq.h>
+#include <bsp/tms570.h>
+#include <rtems/score/armv4.h>
+#define MUST_WAIT_FOR_INTERRUPT 1
+#define TM27_INTERRUPT_VECTOR_DEFAULT TMS570_IRQ_TIMER_3
+#define TM27_INTERRUPT_VECTOR_ALTERNATIVE TMS570_IRQ_TIMER_1
+static inline void Install_tm27_vector( rtems_interrupt_handler handler )
+  static rtems_interrupt_entry entry_2;
+  static rtems_interrupt_entry entry_3;
+  TMS570_RTI.CNT[1].CPUCx = 1;
+  TMS570_RTI.CNT[1].UCx = 0;
+  TMS570_RTI.CNT[1].FRCx = 0;
+  TMS570_RTI.CMP[1].COMPx = 1;
+  TMS570_RTI.CMP[1].UDCPx = 1;
+  TMS570_RTI.CMP[2].COMPx = 1;
+  TMS570_RTI.CMP[2].UDCPx = 1;
+  TMS570_RTI.CMP[3].COMPx = 1;
+  TMS570_RTI.CMP[3].UDCPx = 1;
+  TMS570_RTI.COMPCTRL |= TMS570_RTI_COMPCTRL_COMPSEL1 |
+    TMS570_RTI_COMPCTRL_COMPSEL2 |
+    TMS570_RTI_COMPCTRL_COMPSEL3;
+  TMS570_RTI.GCTRL |= TMS570_RTI_GCTRL_CNT1EN;
+  rtems_interrupt_entry_initialize(
+    &entry_2,
+    handler,
+    NULL,
+    "tm27"
+  (void) rtems_interrupt_entry_install(
+    TMS570_IRQ_TIMER_2,
+    RTEMS_INTERRUPT_SHARED,
+    &entry_2
+    &entry_3,
+    handler,
+    NULL,
+    "tm27"
+    TMS570_IRQ_TIMER_3,
+    &entry_3
+static inline void Cause_tm27_intr(void)
+  TMS570_RTI.SETINTENA = TMS570_RTI_SETINTENA_SETINT3;
+static inline void Clear_tm27_intr(void)
+  TMS570_RTI.CLEARINTENA = TMS570_RTI_CLEARINTENA_CLEARINT2 |
+    TMS570_RTI_CLEARINTENA_CLEARINT3;
+static inline void Lower_tm27_intr(void)
+  TMS570_RTI.SETINTENA = TMS570_RTI_SETINTENA_SETINT2;
+  (void) _ARMV4_Status_irq_enable();
+static inline rtems_status_code _TM27_Raise_alternative(void)
+  TMS570_RTI.SETINTENA = TMS570_RTI_SETINTENA_SETINT1;
+  return RTEMS_SUCCESSFUL;
+static inline rtems_status_code _TM27_Clear_alternative(void)
+  TMS570_RTI.CLEARINTENA = TMS570_RTI_CLEARINTENA_CLEARINT1;
+#endif /* __tm27_h */
2.35.3
