[PATCH 35/47] bsp/tms570: Initialize SRAM on demand
Thu Dec 21 14:38:08 UTC 2023
 bsps/arm/tms570/start/bspstarthooks-hwinit.c | 37 ++++++++++++++------
 1 file changed, 27 insertions(+), 10 deletions(-)
diff --git a/bsps/arm/tms570/start/bspstarthooks-hwinit.c b/bsps/arm/tms570/start/bspstarthooks-hwinit.c
index 4b3fe2fbbf..c42200d80a 100644
--- a/bsps/arm/tms570/start/bspstarthooks-hwinit.c
+++ b/bsps/arm/tms570/start/bspstarthooks-hwinit.c
@@ -9,6 +9,7 @@
+ * Copyright (C) 2023 embedded brains GmbH & Co. KG
  * Copyright (C) 2016 Pavel Pisa <pisa at cmp.felk.cvut.cz>
  * Czech Technical University in Prague
@@ -50,7 +51,32 @@
 #define PBIST_March13N_SP        0x00000008U  /**< March13 N Algo for 1 Port mem */
-BSP_START_TEXT_SECTION void bsp_start_hook_0( void )
+/* Use assembly code to avoid using the stack */
+__attribute__((__naked__)) void bsp_start_hook_0( void )
+  __asm__ volatile (
+    /* Check if we run in SRAM */
+    "ldr r0, =#" RTEMS_XSTRING( TMS570_MEMORY_SRAM_ORIGIN ) "\n"
+    "ldr r1, =#" RTEMS_XSTRING( TMS570_MEMORY_SRAM_SIZE ) "\n"
+    "sub r0, lr, r0\n"
+    "cmp r1, r0\n"
+    "blt 1f\n"
+     * Initialize the SRAM if we are not running in SRAM.  While we are called,
+     * non-volatile register r7 is not used by start.S.
+    "movs r0, #0x1\n"
+    "mov r7, lr\n"
+    "bl tms570_memory_init\n"
+    "mov lr, r7\n"
+    /* Jump to the high level start hook */
+    "1: b tms570_start_hook_0\n"
+static RTEMS_USED void tms570_start_hook_0( void )
 #if TMS570_VARIANT == 3137
@@ -170,15 +196,6 @@ BSP_START_TEXT_SECTION void bsp_start_hook_0( void )
     tms570_pbist_run_and_check( 0x08300020U,   /* ESRAM Single Port PBIST */
       (uint32_t) PBIST_March13N_SP );
-     * Initialize CPU RAM.
-     * This function uses the system module's hardware for auto-initialization of memories and their
-     * associated protection schemes. The CPU RAM is initialized by setting bit 0 of the MSIENA register.
-     * Hence the value 0x1 passed to the function.
-     * This function will initialize the entire CPU RAM and the corresponding ECC locations.
-    tms570_memory_init( 0x1U );
      * Enable ECC checking for TCRAM accesses.
      * This function enables the CPU's ECC logic for accesses to B0TCM and B1TCM.
2.35.3
