[PATCH 22/47] bsp/tms570: Enable hardware init for some variants
Thu Dec 21 14:37:55 UTC 2023
 spec/build/bsps/arm/tms570/optlowinit.yml | 7 ++++++-
 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/spec/build/bsps/arm/tms570/optlowinit.yml b/spec/build/bsps/arm/tms570/optlowinit.yml
index e9aa3557b3..32b84aa08c 100644
--- a/spec/build/bsps/arm/tms570/optlowinit.yml
+++ b/spec/build/bsps/arm/tms570/optlowinit.yml
@@ -7,10 +7,15 @@ build-type: option
 copyrights:
 - Copyright (C) 2020 embedded brains GmbH & Co. KG
 default:
+- enabled-by:
+  - arm/tms570ls3137_hdk
+  - arm/tms570lc4357_hdk
+  value: true
 - enabled-by: true
   value: false
 description: |
-  Include BSP startup code for TMS570LS3137 which allows to start RTEMS application directly after reset
+  Include BSP startup code for TMS570LS3137 or TMS57LC4357 which allows to
+  start RTEMS application directly after reset.
 enabled-by: true
 links: []
2.35.3
