[PATCH 46/47] bsp/tms570: Board-specific tms570_emif_sdram_init()
Thu Dec 21 14:38:19 UTC 2023
 bsps/arm/tms570/include/bsp/tms570_hwinit.h |  6 +-
 bsps/arm/tms570/start/hwinit-lc4357-hdk.c   | 58 +++++++++++++
 bsps/arm/tms570/start/hwinit-ls3137-hdk.c   | 52 +++++++++++
 bsps/arm/tms570/start/init_emif_sdram.c     | 96 ---------------------
 spec/build/bsps/arm/tms570/objhwinit.yml    |  1 -
 5 files changed, 115 insertions(+), 98 deletions(-)
 delete mode 100644 bsps/arm/tms570/start/init_emif_sdram.c
diff --git a/bsps/arm/tms570/include/bsp/tms570_hwinit.h b/bsps/arm/tms570/include/bsp/tms570_hwinit.h
index f88463bb43..2af2f3d48a 100644
--- a/bsps/arm/tms570/include/bsp/tms570_hwinit.h
+++ b/bsps/arm/tms570/include/bsp/tms570_hwinit.h
@@ -69,7 +69,6 @@ void _coreEnableRamEcc_( void );
 void _coreDisableRamEcc_( void );
 void _mpuInit_( void );
-void tms570_emif_sdram_init( void );
 void tms570_memory_init( uint32_t ram );
 void tms570_trim_lpo_init( void );
 void tms570_flash_init( void );
@@ -83,6 +82,11 @@ void tms570_esm_init( void );
  * peripherals that are specific to a particular board.
+ * @brief Initialize the External Memory InterFace (EMIF) peripheral.
+void tms570_emif_sdram_init(void);
  * @brief Initialize PLLs source divider/multipliers.
diff --git a/bsps/arm/tms570/start/hwinit-lc4357-hdk.c b/bsps/arm/tms570/start/hwinit-lc4357-hdk.c
index 0c5a471748..1a5386d81b 100644
--- a/bsps/arm/tms570/start/hwinit-lc4357-hdk.c
+++ b/bsps/arm/tms570/start/hwinit-lc4357-hdk.c
@@ -129,6 +129,64 @@ void tms570_pinmux_init( void )
     tms570_pin_config_complete();
+void tms570_emif_sdram_init( void )
+    uint32_t dummy;
+    /* Do not run attempt to initialize SDRAM when code is running from it */
+    if ( tms570_running_from_sdram() )
+        return;
+    // Following the initialization procedure as described in EMIF-errata #5 for the tms570lc43
+    // at EMIF clock rates >= 40Mhz
+    // Note step one of this procedure is running this EMIF initialization sequence before PLL
+    // and clocks are mapped/enabled
+    // For additional details on startup procedure see tms570lc43 TRM s21.2.5.5.B
+    // Set SDRAM timings. These are dependent on the EMIF CLK rate, which = VCLK3
+    // Set these based on the final EMIF clock rate once PLL & VCLK is enabled
+    TMS570_EMIF.SDTIMR  = (uint32_t)1U << 27U|
+                (uint32_t)0U << 24U|
+                (uint32_t)0U << 20U|
+                (uint32_t)0U << 19U|
+                (uint32_t)1U << 16U|
+                (uint32_t)1U << 12U|
+                (uint32_t)1U << 8U|
+                (uint32_t)0U << 4U;
+    /* Minimum number of ECLKOUT cycles from Self-Refresh exit to any command */
+    // Also set this based on the final EMIF clk
+    TMS570_EMIF.SDSRETR = 2;
+    // Program the RR Field of SDRCR to provide 200us of initialization time
+    // Per Errata#5, for EMIF startup, set this based on the non-VLCK3 clk rate.
+    // The Errata is this register must be calculated as `SDRCR = 200us * EMIF_CLK`
+    //  (typically this would be `SDRCR = (200us * EMIF_CLK) / 8` )
+    //  Since the PLL's arent enabled yet, EMIF_CLK would be EXT_OSCIN / 2
+    TMS570_EMIF.SDRCR = 1600;
+    TMS570_EMIF.SDCR   = ((uint32_t)0U << 31U)|
+            ((uint32_t)1U << 14U)|
+            ((uint32_t)2U << 9U)|
+            ((uint32_t)1U << 8U)|
+            ((uint32_t)2U << 4U)|
+            ((uint32_t)0); // pagesize = 256
+    // Read of SDRAM memory location causes processor to wait until SDRAM Initialization completes
+    dummy = *(volatile uint32_t*)TMS570_MEMORY_SDRAM_ORIGIN;
+    (void) dummy;
+    // Program the RR field to the default Refresh Interval of the SDRAM
+    // Program this to the correct interval for the VCLK3/EMIF_CLK rate
+    // Do this in the typical way per TRM: SDRCR = ((200us * EMIF_CLK) / 8) + 1
+    TMS570_EMIF.SDRCR = 1251;
+    /* Place the EMIF in Self Refresh Mode For Clock Change          */
+    /* Must only write to the upper byte of the SDCR to avoid        */
+    /* a second initialization sequence                              */
+    /* The byte address depends on endian (0x3U in LE, 0x00 in BE32) */
+    *((volatile unsigned char *)(&TMS570_EMIF.SDCR) + 0x0U) = 0x80;
  * @brief Setup all system PLLs (HCG:setupPLL)
diff --git a/bsps/arm/tms570/start/hwinit-ls3137-hdk.c b/bsps/arm/tms570/start/hwinit-ls3137-hdk.c
index 610d20ecc3..1f2bbd96f2 100644
--- a/bsps/arm/tms570/start/hwinit-ls3137-hdk.c
+++ b/bsps/arm/tms570/start/hwinit-ls3137-hdk.c
@@ -240,6 +240,58 @@ void tms570_pinmux_init( void )
     RTEMS_ARRAY_SIZE( tms570_pinmmr_init_data ) );
+  uint32_t dummy;
+  uint32_t sdtimr = 0;
+  uint32_t sdcr = 0;
+    return;
+  sdtimr = TMS570_EMIF_SDTIMR_T_RFC_SET( sdtimr, 6 - 1 );
+  sdtimr = TMS570_EMIF_SDTIMR_T_RP_SET( sdtimr, 2 - 1 );
+  sdtimr = TMS570_EMIF_SDTIMR_T_RCD_SET( sdtimr, 2 - 1 );
+  sdtimr = TMS570_EMIF_SDTIMR_T_WR_SET( sdtimr, 2 - 1 );
+  sdtimr = TMS570_EMIF_SDTIMR_T_RAS_SET( sdtimr, 4 - 1 );
+  sdtimr = TMS570_EMIF_SDTIMR_T_RC_SET( sdtimr, 6 - 1 );
+  sdtimr = TMS570_EMIF_SDTIMR_T_RRD_SET( sdtimr, 2 - 1 );
+  TMS570_EMIF.SDTIMR = sdtimr;
+  TMS570_EMIF.SDSRETR = 5;
+  /* Define the SDRAM refresh period in terms of EMIF_CLK cycles. */
+  TMS570_EMIF.SDRCR = 2000;
+  /* SR - Self-Refresh mode bit. */
+  sdcr |= TMS570_EMIF_SDCR_SR * 0;
+  /* field: PD - Power Down bit controls entering and exiting of the power-down mode. */
+  sdcr |= TMS570_EMIF_SDCR_PD * 0;
+  /* PDWR - Perform refreshes during power down. */
+  sdcr |= TMS570_EMIF_SDCR_PDWR * 0;
+  /* NM - Narrow mode bit defines whether SDRAM is 16- or 32-bit-wide */
+  sdcr |= TMS570_EMIF_SDCR_NM * 1;
+  /* CL - CAS Latency. */
+  sdcr = TMS570_EMIF_SDCR_CL_SET( sdcr, 2 );
+  /* CL can only be written if BIT11_9LOCK is simultaneously written with a 1. */
+  sdcr |= TMS570_EMIF_SDCR_BIT11_9LOCK * 1;
+  /* IBANK - Internal SDRAM Bank size. */
+  sdcr = TMS570_EMIF_SDCR_IBANK_SET( sdcr, 2 ); /* 4-banks device */
+  /* Page Size. This field defines the internal page size of connected SDRAM devices. */
+  sdcr = TMS570_EMIF_SDCR_PAGESIZE_SET( sdcr, 0 ); /* elements_256 */
+  TMS570_EMIF.SDCR = sdcr;
+  (void) dummy;
+  TMS570_EMIF.SDRCR = 31;
+  TMS570_EMIF.SDRCR = 312;
diff --git a/bsps/arm/tms570/start/init_emif_sdram.c b/bsps/arm/tms570/start/init_emif_sdram.c
deleted file mode 100644
index 0b190da321..0000000000
--- a/bsps/arm/tms570/start/init_emif_sdram.c
+++ /dev/null
@@ -1,96 +0,0 @@
-/* SPDX-License-Identifier: BSD-2-Clause */
- * @file
- * @ingroup RTEMSBSPsARMTMS570
- * @brief This source file contains the initialization of
- *   external memory/SDRAM interface.
- * Copyright (C) 2016 Pavel Pisa <pisa at cmp.felk.cvut.cz>
- * Czech Technical University in Prague
- * Zikova 1903/4
- * 166 36 Praha 6
- * Czech Republic
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- *    notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- *    notice, this list of conditions and the following disclaimer in the
- *    documentation and/or other materials provided with the distribution.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
- * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
- * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
- * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
- * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
- * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
- * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
- * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
- * POSSIBILITY OF SUCH DAMAGE.
-#include <stdint.h>
-#include <bsp/tms570.h>
-#include <bsp/tms570_hwinit.h>
-  uint32_t dummy;
-  uint32_t sdtimr = 0;
-  uint32_t sdcr = 0;
-  /* Do not run attempt to initialize SDRAM when code is running from it */
-  if ( tms570_running_from_sdram() )
-    return;
-  sdtimr = TMS570_EMIF_SDTIMR_T_RFC_SET( sdtimr, 6 - 1 );
-  sdtimr = TMS570_EMIF_SDTIMR_T_RP_SET( sdtimr, 2 - 1 );
-  sdtimr = TMS570_EMIF_SDTIMR_T_RCD_SET( sdtimr, 2 - 1 );
-  sdtimr = TMS570_EMIF_SDTIMR_T_WR_SET( sdtimr, 2 - 1 );
-  sdtimr = TMS570_EMIF_SDTIMR_T_RAS_SET( sdtimr, 4 - 1 );
-  sdtimr = TMS570_EMIF_SDTIMR_T_RC_SET( sdtimr, 6 - 1 );
-  sdtimr = TMS570_EMIF_SDTIMR_T_RRD_SET( sdtimr, 2 - 1 );
-  TMS570_EMIF.SDTIMR = sdtimr;
-  /* Minimum number of ECLKOUT cycles from Self-Refresh exit to any command */
-  TMS570_EMIF.SDSRETR = 5;
-  /* Define the SDRAM refresh period in terms of EMIF_CLK cycles. */
-  TMS570_EMIF.SDRCR = 2000;
-  /* SR - Self-Refresh mode bit. */
-  sdcr |= TMS570_EMIF_SDCR_SR * 0;
-  /* field: PD - Power Down bit controls entering and exiting of the power-down mode. */
-  sdcr |= TMS570_EMIF_SDCR_PD * 0;
-  /* PDWR - Perform refreshes during power down. */
-  sdcr |= TMS570_EMIF_SDCR_PDWR * 0;
-  /* NM - Narrow mode bit defines whether SDRAM is 16- or 32-bit-wide */
-  sdcr |= TMS570_EMIF_SDCR_NM * 1;
-  /* CL - CAS Latency. */
-  sdcr = TMS570_EMIF_SDCR_CL_SET( sdcr, 2 );
-  /* CL can only be written if BIT11_9LOCK is simultaneously written with a 1. */
-  sdcr |= TMS570_EMIF_SDCR_BIT11_9LOCK * 1;
-  /* IBANK - Internal SDRAM Bank size. */
-  sdcr = TMS570_EMIF_SDCR_IBANK_SET( sdcr, 2 ); /* 4-banks device */
-  /* Page Size. This field defines the internal page size of connected SDRAM devices. */
-  sdcr = TMS570_EMIF_SDCR_PAGESIZE_SET( sdcr, 0 ); /* elements_256 */
-  TMS570_EMIF.SDCR = sdcr;
-  dummy = *(volatile uint32_t*)TMS570_MEMORY_SDRAM_ORIGIN;
-  (void) dummy;
-  TMS570_EMIF.SDRCR = 31;
-  TMS570_EMIF.SDRCR = 312;
diff --git a/spec/build/bsps/arm/tms570/objhwinit.yml b/spec/build/bsps/arm/tms570/objhwinit.yml
index db4b8fdedd..01b1502280 100644
--- a/spec/build/bsps/arm/tms570/objhwinit.yml
+++ b/spec/build/bsps/arm/tms570/objhwinit.yml
@@ -21,7 +21,6 @@ source:
 - bsps/arm/tms570/start/bspstarthooks-hwinit.c
 - bsps/arm/tms570/start/errata_SSWF021_45.c
 - bsps/arm/tms570/start/fail_notification.c
-- bsps/arm/tms570/start/init_emif_sdram.c
 - bsps/arm/tms570/start/init_esm.c
 - bsps/arm/tms570/start/init_system.c
 - bsps/arm/tms570/start/tms570_selftest.c
2.35.3
