[PATCH 2/2] bsps/xil: Import full xil_exception.h
Kinsey Moore kinsey.moore at oarcorp.com
Thu Feb 2 21:40:34 UTC 2023
This imports the full xil_exception.h instead of an empty stub. This is
required for some Xilinx drivers. The imported files adhere to the
current VERSION file.
 .../xil/arm/ARMv8/32bit/xil_exception.h       | 408 ++++++++++++++++++
 .../xil/arm/ARMv8/64bit/xil_exception.h       | 408 ++++++++++++++++++
 bsps/include/xil/arm/cortexa9/xil_exception.h | 408 ++++++++++++++++++
 bsps/include/xil/arm/cortexr5/xil_exception.h | 408 ++++++++++++++++++
 bsps/include/xil/microblaze/xil_exception.h   | 112 +++++
 bsps/include/xil/xil_exception.h              |   1 -
 spec/build/bsps/objxilinxsupport.yml          |   1 -
 spec/build/bsps/objxilinxsupporta9.yml        |   1 +
 spec/build/bsps/objxilinxsupportilp32.yml     |   1 +
 spec/build/bsps/objxilinxsupportlp64.yml      |   1 +
 spec/build/bsps/objxilinxsupportmb.yml        |   1 +
 spec/build/bsps/objxilinxsupportr5.yml        |   1 +
 12 files changed, 1749 insertions(+), 2 deletions(-)
 create mode 100644 bsps/include/xil/arm/ARMv8/32bit/xil_exception.h
 create mode 100644 bsps/include/xil/arm/ARMv8/64bit/xil_exception.h
 create mode 100644 bsps/include/xil/arm/cortexa9/xil_exception.h
 create mode 100644 bsps/include/xil/arm/cortexr5/xil_exception.h
 create mode 100644 bsps/include/xil/microblaze/xil_exception.h
 delete mode 100644 bsps/include/xil/xil_exception.h
diff --git a/bsps/include/xil/arm/ARMv8/32bit/xil_exception.h b/bsps/include/xil/arm/ARMv8/32bit/xil_exception.h
new file mode 100644
index 0000000000..144d8423df
--- /dev/null
+++ b/bsps/include/xil/arm/ARMv8/32bit/xil_exception.h
@@ -0,0 +1,408 @@
+* Copyright (c) 2015 - 2022 Xilinx, Inc.  All rights reserved.
+* SPDX-License-Identifier: MIT
+* @file xil_exception.h
+* This header file contains ARM Cortex A53,A9,R5 specific exception related APIs.
+* For exception related functions that can be used across all Xilinx supported
+* processors, please use xil_exception.h.
+* @addtogroup arm_exception_apis ARM Processor Exception Handling
+* ARM processors specific exception related APIs for cortex A53,A9 and R5 can
+* utilized for enabling/disabling IRQ, registering/removing handler for
+* exceptions or initializing exception vector table with null handler.
+* <pre>
+* MODIFICATION HISTORY:
+* Ver   Who      Date     Changes
+* 5.2	pkp  	 28/05/15 First release
+* 6.0   mus      27/07/16 Consolidated file for a53,a9 and r5 processors
+* 6.7   mna      26/04/18 Add API Xil_GetExceptionRegisterHandler.
+* 6.7   asa      18/05/18 Update signature of API Xil_GetExceptionRegisterHandler.
+* 7.0   mus      01/03/19 Tweak Xil_ExceptionEnableMask and
+*                         Xil_ExceptionDisableMask macros to support legacy
+*                         examples for Cortexa72 EL3 exception level.
+* 7.3   mus      04/15/20 Added Xil_EnableNestedInterrupts and
+*                         Xil_DisableNestedInterrupts macros for ARMv8.
+*                         For Cortexa72, these macro's would not be supported
+*                         at EL3, as Cortexa72 is using GIC-500(GICv3),  which
+*                         triggeres only FIQ at EL3. Fix for CR#1062506
+* 7.6   mus      09/17/21 Updated flag checking to fix warning reported with
+*                         -Wundef compiler option CR#1110261
+* 7.7   mus      01/31/22 Few of the #defines in xil_exception.h in are treated
+*                         in different way based on "versal" flag. In existing
+*                         flow, this flag is defined only in xparameters.h and
+*                         BSP compiler flags, it is not defined in application
+*                         compiler flags. So, including xil_exception.h in
+*                         application source file, without including
+*                         xparameters.h results  in incorrect behavior.
+*                         Including xparameters.h in xil_exception.h to avoid
+*                         such issues. It fixes CR#1120498.
+* 7.7	sk	 03/02/22 Define XExc_VectorTableEntry structure to fix
+* 			  misra_c_2012_rule_5_6 violation.
+* 7.7	sk	 03/02/22 Add XExc_VectorTable as extern to fix misra_c_2012_
+* 			  rule_8_4 violation.
+* </pre>
+ *@cond nocomments
+#ifndef XIL_EXCEPTION_H /* prevent circular inclusions */
+#define XIL_EXCEPTION_H /* by using protection macros */
+/***************************** Include Files ********************************/
+#include "xil_types.h"
+#include "xpseudo_asm.h"
+#include "bspconfig.h"
+#include "xparameters.h"
+#ifdef __cplusplus
+extern "C" {
+#endif
+/************************** Constant Definitions ****************************/
+#define XIL_EXCEPTION_FIQ	XREG_CPSR_FIQ_ENABLE
+#define XIL_EXCEPTION_IRQ	XREG_CPSR_IRQ_ENABLE
+#define XIL_EXCEPTION_ALL	(XREG_CPSR_FIQ_ENABLE | XREG_CPSR_IRQ_ENABLE)
+#define XIL_EXCEPTION_ID_FIRST			0U
+#if defined (__aarch64__)
+#define XIL_EXCEPTION_ID_SYNC_INT		1U
+#define XIL_EXCEPTION_ID_IRQ_INT		2U
+#define XIL_EXCEPTION_ID_FIQ_INT		3U
+#define XIL_EXCEPTION_ID_SERROR_ABORT_INT		4U
+#define XIL_EXCEPTION_ID_LAST			5U
+#else
+#define XIL_EXCEPTION_ID_RESET			0U
+#define XIL_EXCEPTION_ID_UNDEFINED_INT		1U
+#define XIL_EXCEPTION_ID_SWI_INT		2U
+#define XIL_EXCEPTION_ID_PREFETCH_ABORT_INT	3U
+#define XIL_EXCEPTION_ID_DATA_ABORT_INT		4U
+#define XIL_EXCEPTION_ID_IRQ_INT		5U
+#define XIL_EXCEPTION_ID_FIQ_INT		6U
+#define XIL_EXCEPTION_ID_LAST			6U
+#endif
+ * XIL_EXCEPTION_ID_INT is defined for all Xilinx processors.
+#if defined (versal) && !defined(ARMR5) && EL3
+#define XIL_EXCEPTION_ID_INT    XIL_EXCEPTION_ID_FIQ_INT
+#else
+#define XIL_EXCEPTION_ID_INT	XIL_EXCEPTION_ID_IRQ_INT
+#endif
+/**************************** Type Definitions ******************************/
+ * This typedef is the exception handler function.
+typedef void (*Xil_ExceptionHandler)(void *data);
+typedef void (*Xil_InterruptHandler)(void *data);
+typedef struct {
+        Xil_ExceptionHandler Handler;
+        void *Data;
+} XExc_VectorTableEntry;
+extern XExc_VectorTableEntry XExc_VectorTable[];
+*@endcond
+/***************** Macros (Inline Functions) Definitions ********************/
+* @brief	Enable Exceptions.
+* @param	Mask: Value for enabling the exceptions.
+* @return	None.
+* @note		If bit is 0, exception is enabled.
+*			C-Style signature: void Xil_ExceptionEnableMask(Mask)
+ * Cortexa72 processor in versal is coupled with GIC-500, and GIC-500 supports
+ * only FIQ at EL3. Hence, tweaking this macro to always enable FIQ
+ * ignoring argument passed by user.
+#define Xil_ExceptionEnableMask(Mask)	\
+		mtcpsr(mfcpsr() & ~ ((XIL_EXCEPTION_FIQ) & XIL_EXCEPTION_ALL))
+#elif defined (__GNUC__) || defined (__ICCARM__)
+		mtcpsr(mfcpsr() & ~ ((Mask) & XIL_EXCEPTION_ALL))
+#else
+		  register u32 Reg __asm("cpsr"); \
+		  mtcpsr((Reg) & (~((Mask) & XIL_EXCEPTION_ALL))); \
+#endif
+* @brief	Enable the IRQ exception.
+* @return   None.
+* @note     None.
+#define Xil_ExceptionEnable() \
+                Xil_ExceptionEnableMask(XIL_EXCEPTION_FIQ)
+#else
+		Xil_ExceptionEnableMask(XIL_EXCEPTION_IRQ)
+#endif
+* @brief	Disable Exceptions.
+* @param	Mask: Value for disabling the exceptions.
+* @return	None.
+* @note		If bit is 1, exception is disabled.
+*			C-Style signature: Xil_ExceptionDisableMask(Mask)
+ * only FIQ at EL3. Hence, tweaking this macro to always disable FIQ
+#define Xil_ExceptionDisableMask(Mask)	\
+		mtcpsr(mfcpsr() | ((XIL_EXCEPTION_FIQ) & XIL_EXCEPTION_ALL))
+		mtcpsr(mfcpsr() | ((Mask) & XIL_EXCEPTION_ALL))
+#else
+		  mtcpsr((Reg) | ((Mask) & XIL_EXCEPTION_ALL)); \
+#endif
+* Disable the IRQ exception.
+* @return   None.
+* @note     None.
+#define Xil_ExceptionDisable() \
+		Xil_ExceptionDisableMask(XIL_EXCEPTION_IRQ)
+#if ( defined (PLATFORM_ZYNQMP) && defined (EL3) && (EL3==1) )
+* @brief	Enable nested interrupts by clearing the I bit in DAIF.This
+*			macro is defined for Cortex-A53 64 bit mode BSP configured to run
+*			at EL3.. However,it is not defined for Versal Cortex-A72 BSP
+*			configured to run at EL3. Reason is, Cortex-A72 is coupled
+*			with GIC-500(GICv3 specifications) and it triggers only FIQ at EL3.
+* @return   None.
+* @note     This macro is supposed to be used from interrupt handlers. In the
+*			interrupt handler the interrupts are disabled by default (I bit
+*			is set as 1). To allow nesting of interrupts, this macro should be
+*			used. It clears the I bit. Once that bit is cleared and provided the
+*			preemption of interrupt conditions are met in the GIC, nesting of
+*			interrupts will start happening.
+*			Caution: This macro must be used with caution. Before calling this
+*			macro, the user must ensure that the source of the current IRQ
+*			is appropriately cleared. Otherwise, as soon as we clear the I
+*			bit, there can be an infinite loop of interrupts with an
+*			eventual crash (all the stack space getting consumed).
+#define Xil_EnableNestedInterrupts() \
+                __asm__ __volatile__ ("mrs    X1, ELR_EL3"); \
+                __asm__ __volatile__ ("mrs    X2, SPSR_EL3");  \
+                __asm__ __volatile__ ("stp    X1,X2, [sp,#-0x10]!"); \
+                __asm__ __volatile__ ("mrs    X1, DAIF");  \
+                __asm__ __volatile__ ("bic    X1,X1,#(0x1<<7)");  \
+                __asm__ __volatile__ ("msr    DAIF, X1");  \
+* @brief	Disable the nested interrupts by setting the I bit in DAIF. This
+*			at EL3.
+* @return   None.
+* @note     This macro is meant to be called in the interrupt service routines.
+*			This macro cannot be used independently. It can only be used when
+*			nesting of interrupts have been enabled by using the macro
+*			Xil_EnableNestedInterrupts(). In a typical flow, the user first
+*			calls the Xil_EnableNestedInterrupts in the ISR at the appropriate
+*			point. The user then must call this macro before exiting the interrupt
+*			service routine. This macro puts the ARM back in IRQ mode and
+*			hence sets back the I bit.
+#define Xil_DisableNestedInterrupts() \
+                __asm__ __volatile__ ("ldp    X1,X2, [sp,#0x10]!"); \
+                __asm__ __volatile__ ("msr    ELR_EL3, X1"); \
+                __asm__ __volatile__ ("msr    SPSR_EL3, X2"); \
+                __asm__ __volatile__ ("orr    X1, X1, #(0x1<<7)"); \
+#elif (defined (EL1_NONSECURE) && (EL1_NONSECURE==1))
+*			macro is defined for Cortex-A53 64 bit mode and Cortex-A72 64 bit
+*			BSP configured to run at EL1 NON SECURE
+* @return   None.
+                __asm__ __volatile__ ("mrs    X1, ELR_EL1"); \
+                __asm__ __volatile__ ("mrs    X2, SPSR_EL1");  \
+* @return   None.
+                __asm__ __volatile__ ("msr    ELR_EL1, X1"); \
+                __asm__ __volatile__ ("msr    SPSR_EL1, X2"); \
+#elif (!defined (__aarch64__) && !defined (ARMA53_32))
+* @brief	Enable nested interrupts by clearing the I and F bits in CPSR. This
+* 			API is defined for cortex-a9 and cortex-r5.
+* @return   None.
+*			interrupt handler the interrupts are disabled by default (I and F
+*			are 1). To allow nesting of interrupts, this macro should be
+*			used. It clears the I and F bits by changing the ARM mode to
+*			system mode. Once these bits are cleared and provided the
+*			is appropriately cleared. Otherwise, as soon as we clear the I and
+*			F bits, there can be an infinite loop of interrupts with an
+		__asm__ __volatile__ ("stmfd   sp!, {lr}"); \
+		__asm__ __volatile__ ("mrs     lr, spsr");  \
+		__asm__ __volatile__ ("msr     cpsr_c, #0x1F"); \
+* @brief	Disable the nested interrupts by setting the I and F bits. This API
+*			is defined for cortex-a9 and cortex-r5.
+* @return   None.
+*			service routine. This macro puts the ARM back in IRQ/FIQ mode and
+*			hence sets back the I and F bits.
+		__asm__ __volatile__ ("ldmfd   sp!, {lr}");   \
+		__asm__ __volatile__ ("msr     cpsr_c, #0x92"); \
+		__asm__ __volatile__ ("msr     spsr_cxsf, lr"); \
+#endif
+/************************** Variable Definitions ****************************/
+/************************** Function Prototypes *****************************/
+extern void Xil_ExceptionRegisterHandler(u32 Exception_id,
+					 Xil_ExceptionHandler Handler,
+					 void *Data);
+extern void Xil_ExceptionRemoveHandler(u32 Exception_id);
+extern void Xil_GetExceptionRegisterHandler(u32 Exception_id,
+					Xil_ExceptionHandler *Handler, void **Data);
+extern void Xil_ExceptionInit(void);
+void Xil_SyncAbortHandler(void *CallBackRef);
+void Xil_SErrorAbortHandler(void *CallBackRef);
+#else
+extern void Xil_DataAbortHandler(void *CallBackRef);
+extern void Xil_PrefetchAbortHandler(void *CallBackRef);
+extern void Xil_UndefinedExceptionHandler(void *CallBackRef);
+#endif
+#ifdef __cplusplus
+#endif /* __cplusplus */
+#endif /* XIL_EXCEPTION_H */
+* @} End of "addtogroup arm_exception_apis".
diff --git a/bsps/include/xil/arm/ARMv8/64bit/xil_exception.h b/bsps/include/xil/arm/ARMv8/64bit/xil_exception.h
--- /dev/null
+++ b/bsps/include/xil/arm/ARMv8/64bit/xil_exception.h
@@ -0,0 +1,408 @@
+* <pre>
+* </pre>
+ *@cond nocomments
+#ifdef __cplusplus
+extern "C" {
+#endif
+#else
+#endif
+#else
+#endif
+typedef struct {
+        void *Data;
+*@endcond
+* @return	None.
+#else
+#endif
+* @return   None.
+* @note     None.
+#else
+#endif
+* @return	None.
+#else
+#endif
+* @return   None.
+* @note     None.
+* @return   None.
+*			at EL3.
+* @return   None.
+* @return   None.
+* @return   None.
+* @return   None.
+* @return   None.
+#endif
+					 void *Data);
+#else
+#endif
+#ifdef __cplusplus
diff --git a/bsps/include/xil/arm/cortexa9/xil_exception.h b/bsps/include/xil/arm/cortexa9/xil_exception.h
--- /dev/null
+++ b/bsps/include/xil/arm/cortexa9/xil_exception.h
@@ -0,0 +1,408 @@
+* <pre>
+* </pre>
+ *@cond nocomments
+#ifdef __cplusplus
+extern "C" {
+#endif
+#else
+#endif
+#else
+#endif
+typedef struct {
+        void *Data;
+*@endcond
+* @return	None.
+#else
+#endif
+* @return   None.
+* @note     None.
+#else
+#endif
+* @return	None.
+#else
+#endif
+* @return   None.
+* @note     None.
+* @return   None.
+*			at EL3.
+* @return   None.
+* @return   None.
+* @return   None.
+* @return   None.
+* @return   None.
+#endif
+					 void *Data);
+#else
+#endif
+#ifdef __cplusplus
diff --git a/bsps/include/xil/arm/cortexr5/xil_exception.h b/bsps/include/xil/arm/cortexr5/xil_exception.h
--- /dev/null
+++ b/bsps/include/xil/arm/cortexr5/xil_exception.h
@@ -0,0 +1,408 @@
+* <pre>
+* </pre>
+ *@cond nocomments
+#ifdef __cplusplus
+extern "C" {
+#endif
+#else
+#endif
+#else
+#endif
+typedef struct {
+        void *Data;
+*@endcond
+* @return	None.
+#else
+#endif
+* @return   None.
+* @note     None.
+#else
+#endif
+* @return	None.
+#else
+#endif
+* @return   None.
+* @note     None.
+* @return   None.
+*			at EL3.
+* @return   None.
+* @return   None.
+* @return   None.
+* @return   None.
+* @return   None.
+#endif
+					 void *Data);
+#else
+#endif
+#ifdef __cplusplus
diff --git a/bsps/include/xil/microblaze/xil_exception.h b/bsps/include/xil/microblaze/xil_exception.h
index 0000000000..571acd9624
--- /dev/null
+++ b/bsps/include/xil/microblaze/xil_exception.h
@@ -0,0 +1,112 @@
+* Copyright (c) 2009 - 2021 Xilinx, Inc.  All rights reserved.
+* @addtogroup microblaze_exception_apis Microblaze Exception APIs
+* The xil_exception.h file, available in the <install-directory>/src/microblaze folder,
+* contains Microblaze specific exception related APIs and macros. Application programs
+* can use these APIs for various exception related operations. For example, enable exception,
+* disable exception, register exception hander.
+* @note To use exception related functions, xil_exception.h must be added in source code
+* <pre>
+* 1.00  hbm  07/28/09 Initial release
+* </pre>
+ *@cond nocomments
+#ifdef __cplusplus
+extern "C" {
+#endif
+/************************** Constant Definitions *****************************/
+ * These constants are specific to Microblaze processor.
+#define XIL_EXCEPTION_ID_FSL                  0U
+#define XIL_EXCEPTION_ID_UNALIGNED_ACCESS     1U
+#define XIL_EXCEPTION_ID_ILLEGAL_OPCODE       2U
+#define XIL_EXCEPTION_ID_M_AXI_I_EXCEPTION    3U
+#define XIL_EXCEPTION_ID_IPLB_EXCEPTION       3U
+#define XIL_EXCEPTION_ID_M_AXI_D_EXCEPTION    4U
+#define XIL_EXCEPTION_ID_DPLB_EXCEPTION       4U
+#define XIL_EXCEPTION_ID_DIV_BY_ZERO          5U
+#define XIL_EXCEPTION_ID_FPU                  6U
+#define XIL_EXCEPTION_ID_STACK_VIOLATION      7U
+#define XIL_EXCEPTION_ID_MMU                  7U
+#define XIL_EXCEPTION_ID_LAST		      XIL_EXCEPTION_ID_MMU
+ * XIL_EXCEPTION_ID_INT is defined for all processors, but with different value.
+#define XIL_EXCEPTION_ID_INT		      16U /**
+						  * exception ID for interrupt
+/**************************** Type Definitions *******************************/
+typedef void (*Xil_ExceptionHandler)(void *Data);
+ * This data type defines an interrupt handler for a device.
+ * The argument points to the instance of the component
+typedef void (*XInterruptHandler) (void *InstancePtr);
+/***************** Macros (Inline Functions) Definitions *********************/
+/************************** Function Prototypes ******************************/
+extern void Xil_ExceptionRegisterHandler(u32 Id,
+					 void *Data);
+extern void Xil_ExceptionRemoveHandler(u32 Id);
+extern void Xil_ExceptionEnable(void);
+extern void Xil_ExceptionDisable(void);
+#ifdef __cplusplus
+#endif
+#endif
+ *@endcond
+* @} End of "addtogroup microblaze_exception_apis".
diff --git a/bsps/include/xil/xil_exception.h b/bsps/include/xil/xil_exception.h
deleted file mode 100644
index 55a8df3add..0000000000
--- a/bsps/include/xil/xil_exception.h
+++ /dev/null
@@ -1 +0,0 @@
-/* Intentional blank stub file for Xilinx driver compatibility. */
diff --git a/spec/build/bsps/objxilinxsupport.yml b/spec/build/bsps/objxilinxsupport.yml
index 6632fe0ce9..d686ae9cfd 100644
--- a/spec/build/bsps/objxilinxsupport.yml
+++ b/spec/build/bsps/objxilinxsupport.yml
@@ -16,7 +16,6 @@ install:
   - bsps/include/xil/sleep.h
   - bsps/include/xil/xbasic_types.h
   - bsps/include/xil/xil_assert.h
-  - bsps/include/xil/xil_exception.h
   - bsps/include/xil/xil_io.h
   - bsps/include/xil/xil_mem.h
   - bsps/include/xil/xil_printf.h
diff --git a/spec/build/bsps/objxilinxsupporta9.yml b/spec/build/bsps/objxilinxsupporta9.yml
index 39894897c5..5b29011b47 100644
--- a/spec/build/bsps/objxilinxsupporta9.yml
+++ b/spec/build/bsps/objxilinxsupporta9.yml
@@ -13,6 +13,7 @@ install:
 - destination: ${BSP_INCLUDEDIR}
   source:
   - bsps/include/xil/arm/cortexa9/xil_cache.h
+  - bsps/include/xil/arm/cortexa9/xil_exception.h
   - bsps/include/xil/arm/cortexa9/xpseudo_asm.h
   - bsps/include/xil/arm/cortexa9/xreg_cortexa9.h
 links: []
diff --git a/spec/build/bsps/objxilinxsupportilp32.yml b/spec/build/bsps/objxilinxsupportilp32.yml
index 4f2726577a..2db5d12bef 100644
--- a/spec/build/bsps/objxilinxsupportilp32.yml
+++ b/spec/build/bsps/objxilinxsupportilp32.yml
   source:
   - bsps/include/xil/arm/ARMv8/32bit/xil_cache.h
+  - bsps/include/xil/arm/ARMv8/32bit/xil_exception.h
   - bsps/include/xil/arm/ARMv8/32bit/xpseudo_asm.h
   - bsps/include/xil/arm/ARMv8/32bit/xreg_cortexa53.h
 links: []
diff --git a/spec/build/bsps/objxilinxsupportlp64.yml b/spec/build/bsps/objxilinxsupportlp64.yml
index dd4b19bcc2..efb2e8d58a 100644
--- a/spec/build/bsps/objxilinxsupportlp64.yml
+++ b/spec/build/bsps/objxilinxsupportlp64.yml
@@ -15,6 +15,7 @@ install:
   source:
   - bsps/include/xil/arm/ARMv8/64bit/xil_cache.h
+  - bsps/include/xil/arm/ARMv8/64bit/xil_exception.h
   - bsps/include/xil/arm/ARMv8/64bit/xpseudo_asm.h
   - bsps/include/xil/arm/ARMv8/64bit/xreg_cortexa53.h
 links: []
diff --git a/spec/build/bsps/objxilinxsupportmb.yml b/spec/build/bsps/objxilinxsupportmb.yml
index e8abc48e04..d5f401182e 100644
--- a/spec/build/bsps/objxilinxsupportmb.yml
+++ b/spec/build/bsps/objxilinxsupportmb.yml
@@ -12,6 +12,7 @@ install:
   source:
   - bsps/include/xil/microblaze/xil_cache.h
+  - bsps/include/xil/microblaze/xil_exception.h
 links: []
 source: []
 type: build
diff --git a/spec/build/bsps/objxilinxsupportr5.yml b/spec/build/bsps/objxilinxsupportr5.yml
index 5b4c97803f..4f7fe33606 100644
--- a/spec/build/bsps/objxilinxsupportr5.yml
+++ b/spec/build/bsps/objxilinxsupportr5.yml
@@ -11,6 +11,7 @@ install:
   source:
   - bsps/include/xil/arm/cortexr5/xil_cache.h
+  - bsps/include/xil/arm/cortexr5/xil_exception.h
   - bsps/include/xil/arm/cortexr5/xpseudo_asm.h
   - bsps/include/xil/arm/cortexr5/xreg_cortexr5.h
 links: []
2.30.2
