[PATCH 1/5] bsps/microblaze: Add device tree getter
Alex White alex.white at oarcorp.com
Fri Jan 13 04:33:33 UTC 2023
This allows drivers to read configuration data from the device tree if
the BSP is built with device tree support.
 .../include/bsp/microblaze-fdt-support.h      | 65 +++++++++++++++++
 bsps/microblaze/microblaze_fpga/fdt/bsp_fdt.c | 23 ------
 bsps/microblaze/microblaze_fpga/include/bsp.h |  3 +
 .../shared/fdt/microblaze-fdt-support.c       | 72 +++++++++++++++++++
 .../bsps/microblaze/microblaze_fpga/grp.yml   |  2 +
 .../bsps/microblaze/microblaze_fpga/obj.yml   |  3 +-
 .../microblaze/microblaze_fpga/optusefdt.yml  | 15 ++++
 7 files changed, 159 insertions(+), 24 deletions(-)
 create mode 100644 bsps/microblaze/include/bsp/microblaze-fdt-support.h
 delete mode 100644 bsps/microblaze/microblaze_fpga/fdt/bsp_fdt.c
 create mode 100644 bsps/microblaze/shared/fdt/microblaze-fdt-support.c
 create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optusefdt.yml
diff --git a/bsps/microblaze/include/bsp/microblaze-fdt-support.h b/bsps/microblaze/include/bsp/microblaze-fdt-support.h
new file mode 100644
index 0000000000..ede8153c81
--- /dev/null
+++ b/bsps/microblaze/include/bsp/microblaze-fdt-support.h
@@ -0,0 +1,65 @@
+ * @file
+ * @ingroup RTEMSBSPsMicroblaze
+ * @brief This header file provides support for the device tree.
+ * Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
+ * are met:
+#ifndef LIBBSP_MICROBLAZE_MICROBLAZE_FDT_SUPPORT_H
+#define LIBBSP_MICROBLAZE_MICROBLAZE_FDT_SUPPORT_H
+#ifdef __cplusplus
+extern "C" {
+#endif
+#include <stdint.h>
+ * @brief Get the value of a property from a compatible node in the device tree.
+ * @param[in] compatible The 'compatible' string to match against.
+ * @param[in] prop_name The property name.
+ * @param[in] default_value The default value to return if no compatible node
+ *                          was found or the property was not found.
+ * @return The value of the property or the default value.
+uint32_t try_get_prop_from_device_tree(
+  const char *compatible,
+  const char *prop_name,
+  uint32_t default_value
+#ifdef __cplusplus
+#endif
+#endif /* LIBBSP_MICROBLAZE_MICROBLAZE_FDT_SUPPORT_H */
diff --git a/bsps/microblaze/microblaze_fpga/fdt/bsp_fdt.c b/bsps/microblaze/microblaze_fpga/fdt/bsp_fdt.c
deleted file mode 100644
index 9eb92c5dc6..0000000000
--- a/bsps/microblaze/microblaze_fpga/fdt/bsp_fdt.c
+++ /dev/null
@@ -1,23 +0,0 @@
- *  COPYRIGHT (c) 2021.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#include <bsp.h>
-#include <bsp/fdt.h>
-#include BSP_MICROBLAZE_FPGA_DTB_HEADER_PATH
-const void *bsp_fdt_get(void)
-  return system_dtb;
-uint32_t bsp_fdt_map_intr(const uint32_t *intr, size_t icells)
-  return intr[0];
diff --git a/bsps/microblaze/microblaze_fpga/include/bsp.h b/bsps/microblaze/microblaze_fpga/include/bsp.h
index 93cf0e4b34..410d4483c6 100644
--- a/bsps/microblaze/microblaze_fpga/include/bsp.h
+++ b/bsps/microblaze/microblaze_fpga/include/bsp.h
@@ -43,12 +43,15 @@ extern "C" {
 #include <bspopts.h>
 #include <bsp/default-initial-extension.h>
+#include <bsp/microblaze-fdt-support.h>
+#ifdef BSP_MICROBLAZE_FPGA_USE_FDT
 #define BSP_FDT_IS_SUPPORTED
 extern const unsigned char system_dtb[];
 extern const size_t system_dtb_size;
+#endif /* BSP_MICROBLAZE_FPGA_USE_FDT */
 void microblaze_enable_icache(void);
 void microblaze_enable_dcache(void);
diff --git a/bsps/microblaze/shared/fdt/microblaze-fdt-support.c b/bsps/microblaze/shared/fdt/microblaze-fdt-support.c
index 0000000000..ec4e039946
--- /dev/null
+++ b/bsps/microblaze/shared/fdt/microblaze-fdt-support.c
@@ -0,0 +1,72 @@
+ * are met:
+#include <bspopts.h>
+#include <bsp/fdt.h>
+#include <libfdt.h>
+#include BSP_MICROBLAZE_FPGA_DTB_HEADER_PATH
+const void *bsp_fdt_get(void)
+  return system_dtb;
+uint32_t bsp_fdt_map_intr(const uint32_t *intr, size_t icells)
+  return intr[0];
+  uint32_t value = default_value;
+  const void *fdt = bsp_fdt_get();
+  int node = fdt_node_offset_by_compatible( fdt, -1, compatible );
+  if ( node < 0 ) {
+    return default_value;
+  const uint32_t *prop = fdt_getprop( fdt, node, prop_name, NULL );
+  if ( prop == NULL ) {
+  value = fdt32_to_cpu( prop[0] );
+   return value;
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/grp.yml b/spec/build/bsps/microblaze/microblaze_fpga/grp.yml
index c196a74e43..f3088a68a3 100644
--- a/spec/build/bsps/microblaze/microblaze_fpga/grp.yml
+++ b/spec/build/bsps/microblaze/microblaze_fpga/grp.yml
@@ -48,6 +48,8 @@ links:
   uid: opttimerfrequency
 - role: build-dependency
   uid: optuartlitebaseaddress
+- role: build-dependency
+  uid: optusefdt
   uid: ../../obj
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/obj.yml b/spec/build/bsps/microblaze/microblaze_fpga/obj.yml
index 0c7085292a..2bbe50d3d9 100644
--- a/spec/build/bsps/microblaze/microblaze_fpga/obj.yml
+++ b/spec/build/bsps/microblaze/microblaze_fpga/obj.yml
@@ -15,6 +15,7 @@ install:
   source:
   - bsps/microblaze/microblaze_fpga/include/bsp/irq.h
   - bsps/microblaze/microblaze_fpga/include/bsp/jffs2_qspi.h
+  - bsps/microblaze/include/bsp/microblaze-fdt-support.h
   - bsps/microblaze/include/common/xil_types.h
   - bsps/microblaze/include/dev/serial/uartlite.h
   - bsps/microblaze/include/dev/serial/uartlite_l.h
@@ -23,7 +24,6 @@ source:
 - bsps/microblaze/microblaze_fpga/clock/clock.c
 - bsps/microblaze/microblaze_fpga/console/console-io.c
 - bsps/microblaze/microblaze_fpga/console/debug-io.c
-- bsps/microblaze/microblaze_fpga/fdt/bsp_fdt.c
 - bsps/microblaze/microblaze_fpga/fs/jffs2_qspi.c
 - bsps/microblaze/microblaze_fpga/irq/irq.c
 - bsps/microblaze/microblaze_fpga/start/_debug_sw_break_handler.S
@@ -38,6 +38,7 @@ source:
 - bsps/microblaze/microblaze_fpga/start/microblaze_invalidate_icache.S
 - bsps/microblaze/shared/dev/serial/uartlite.c
 - bsps/microblaze/shared/dev/serial/uartlite_l.c
+- bsps/microblaze/shared/fdt/microblaze-fdt-support.c
 - bsps/shared/cache/nocache.c
 - bsps/shared/dev/btimer/btimer-cpucounter.c
 - bsps/shared/dev/cpucounter/cpucounterfrequency.c
diff --git a/spec/build/bsps/microblaze/microblaze_fpga/optusefdt.yml b/spec/build/bsps/microblaze/microblaze_fpga/optusefdt.yml
index 0000000000..4b7bc309e2
--- /dev/null
+++ b/spec/build/bsps/microblaze/microblaze_fpga/optusefdt.yml
@@ -0,0 +1,15 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+actions:
+- get-boolean: null
+- define-condition: null
+build-type: option
+copyrights:
+- Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
+default: true
+default-by-variant: []
+description: |
+  define if FDT is used
+enabled-by: true
+links: []
+name: BSP_MICROBLAZE_FPGA_USE_FDT
+type: build
2.34.1
