[RSB 2/4] 6: Update GCC 10 and 12
Sun Jul 2 23:14:17 UTC 2023
On 30/6/2023 4:20 pm, Sebastian Huber wrote:
> On 29.06.23 02:20, Chris Johns wrote:
>> On 28/6/2023 3:33 pm, Sebastian Huber wrote:
>>> On 28.06.23 04:37, Chris Johns wrote:
>>>> Can you please provide something other than update in the commit message?
>>>> If it is to pick up patches on these gcc release branches then please say so.
>>> This update has no particular reason. I just had a bit of time to run my update
>>> script. Ideally there would be an automatic update process in place. If you
>>> don't want to follow the upstream release branches, then please say so. However,
>>> this work helps to identify RTEMS related issues in the upstream development.
>>> Working tools for RTEMS need maintenance. It is not that release versions of GCC
>>> magically work on RTEMS.
>> This sounds great. Would it be possible to add a simple comment in the commit
>> message this is a housekeeping update to the latest? It makes it easier
>> reviewing the commit log to understand changes of interest verses such as things
>> we need or make in newlib verses housekeeping.
> Ok, makes sense. I added this sentence:
> Keep RTEMS up to date with the upstream development.
Perfect and appreciated. It is now easier to review and accept a change like this.
>>>> Are these versions of the compiler tracking tarfile packages?
>>> No, the configurations track the release branches.
>> For newlib this makes sense during development and releases because of newlib's
>> long release period. It also works for binutils, gcc and gdb when we are in
>> development however I am not sure it does with releases. Should we look to
>> tarfiles for releases for the binutils, gcc and gdb tools?
> For RTEMS releases it makes sense to use upstream releases for the tools with as
> few patches as possible.
Great. How do we make the move? I am happy to update the RSB if I am given the
details or instructions. I feel you are the best person to know when so if you
think it is OK to change does it work if you create a ticket with the links to
the sources then assign it to me?
Thanks
