[PATCH 1/2] score/arm: improve printed exception information for Cortex-Mx CPUs
Karel Gardas karel at functional.vision
Thu Jul 6 19:24:00 UTC 2023
Sponsored-By:	Precidata
 .../score/cpu/arm/arm-exception-frame-print.c | 101 ++++++++++++++++++
 .../cpu/arm/include/rtems/score/armv7m.h      |  11 ++
 2 files changed, 112 insertions(+)
diff --git a/cpukit/score/cpu/arm/arm-exception-frame-print.c b/cpukit/score/cpu/arm/arm-exception-frame-print.c
index 7bc6795ea5..32e9c723d9 100644
--- a/cpukit/score/cpu/arm/arm-exception-frame-print.c
+++ b/cpukit/score/cpu/arm/arm-exception-frame-print.c
@@ -41,6 +41,9 @@
 #include <inttypes.h>
 #include <rtems/score/cpu.h>
+#if defined(ARM_MULTILIB_ARCH_V7M)
+#include <rtems/score/armv7m.h>
+#endif
 #include <rtems/bspIo.h>
 static void _ARM_VFP_context_print( const ARM_VFP_context *vfp_context )
@@ -66,6 +69,103 @@ static void _ARM_VFP_context_print( const ARM_VFP_context *vfp_context )
 #endif
+static void _ARM_Cortex_M_fault_info_print(void)
+    /* prints content of additional debugging registers
+     * available on Cortex-Mx where x > 0 cores.
+    uint32_t cfsr = _ARMV7M_SCB->cfsr;
+    uint8_t mmfsr = ARMV7M_SCB_CFSR_MMFSR_GET(cfsr);
+    uint8_t bfsr = (ARMV7M_SCB_CFSR_BFSR_GET(cfsr) >> 8);
+    uint16_t ufsr = (ARMV7M_SCB_CFSR_UFSR_GET(cfsr) >> 16);
+    uint32_t hfsr = _ARMV7M_SCB->hfsr;
+    if (mmfsr > 0) {
+        printk("MMFSR= 0x%08" PRIx32 " (memory fault)\n", mmfsr);
+        if ((mmfsr & 0x1) != 0) {
+            printk("  IACCVIOL   : 1  (instruction access violation)\n");
+        if ((mmfsr & 0x2) != 0) {
+            printk("  DACCVIOL   : 1  (data access violation)\n");
+        if ((mmfsr & 0x8) != 0) {
+            printk("  MUNSTKERR  : 1  (fault on unstacking on exception return)\n");
+        if ((mmfsr & 0x10) != 0) {
+            printk("  MSTKERR    : 1  (fault on stacking on exception entry)\n");
+        if ((mmfsr & 0x20) != 0) {
+            printk("  MLSPERR    : 1  (fault during lazy FP stack preservation)\n");
+        if ((mmfsr & 0x80) != 0) {
+            printk("  MMFARVALID : 1 -> 0x%08" PRIx32 " (error address)\n", _ARMV7M_SCB->mmfar);
+        else {
+            printk("  MMFARVALID : 0  (undetermined error address)\n");
+    if (bfsr > 0) {
+        printk("BFSR = 0x%08" PRIx32 " (bus fault)\n", bfsr);
+        if ((bfsr & 0x1) != 0) {
+            printk("  IBUSERR    : 1  (instruction fetch error)\n");
+        if ((bfsr & 0x2) != 0) {
+            printk("  PRECISERR  : 1  (data bus error with known exact location)\n");
+        if ((bfsr & 0x4) != 0) {
+            printk("  IMPRECISERR: 1  (data bus error without known exact location)\n");
+        if ((bfsr & 0x8) != 0) {
+            printk("  UNSTKERR   : 1  (fault on unstacking on exception return)\n");
+        if ((bfsr & 0x10) != 0) {
+            printk("  STKERR     : 1  (fault on stacking on exception entry)\n");
+        if ((bfsr & 0x20) != 0) {
+            printk("  LSPERR     : 1  (fault during lazy FP stack preservation)\n");
+        if ((bfsr & 0x80) != 0) {
+            printk("  BFARVALID  : 1 -> 0x%08" PRIx32 "  (error address)\n", _ARMV7M_SCB->bfar);
+        else {
+            printk("  BFARVALID  : 0  (undetermined error address)\n");
+    if (ufsr > 0) {
+        printk("UFSR = 0x%08" PRIx32 " (usage fault)\n", ufsr);
+        if ((ufsr & 0x1) != 0) {
+            printk("  UNDEFINSTR : 1  (undefined instruction issued)\n");
+        if ((ufsr & 0x2) != 0) {
+            printk("  INVSTATE   : 1  (invalid instruction state (Thumb not set in EPSR or invalid IT state in EPSR))\n");
+        if ((ufsr & 0x4) != 0) {
+            printk("  INVPC      : 1  (integrity check failure on EXC_RETURN)\n");
+        if ((ufsr & 0x8) != 0) {
+            printk("  NOCP       : 1  (coprocessor instruction issued but coprocessor disabled or non existent)\n");
+        if ((ufsr & 0x100) != 0) {
+            printk("  UNALIGNED  : 1  (unaligned access operation occurred)\n");
+        if ((ufsr & 0x200) != 0) {
+            printk("  DIVBYZERO  : 1  (division by zero)");
+    if ((hfsr & (ARMV7M_SCB_HFSR_VECTTBL_MASK | ARMV7M_SCB_HFSR_DEBUGEVT_MASK | ARMV7M_SCB_HFSR_FORCED_MASK)) != 0) {
+        printk("HFSR = 0x%08" PRIx32 " (hard fault)\n", hfsr);
+        if ((hfsr & ARMV7M_SCB_HFSR_VECTTBL_MASK) != 0) {
+            printk("  VECTTBL    : 1  (error in address located in vector table)\n");
+        if ((hfsr & ARMV7M_SCB_HFSR_FORCED_MASK) != 0) {
+            printk("  FORCED     : 1  (configurable fault escalated to hard fault)\n");
+        if ((hfsr & ARMV7M_SCB_HFSR_DEBUGEVT_MASK) != 0) {
+            printk("  DEBUGEVT   : 1  (debug event occurred with debug system disabled)\n");
+#endif
 void _CPU_Exception_frame_print( const CPU_Exception_frame *frame )
   printk(
@@ -109,4 +209,5 @@ void _CPU_Exception_frame_print( const CPU_Exception_frame *frame )
   _ARM_VFP_context_print( frame->vfp_context );
+  _ARM_Cortex_M_fault_info_print();
diff --git a/cpukit/score/cpu/arm/include/rtems/score/armv7m.h b/cpukit/score/cpu/arm/include/rtems/score/armv7m.h
index 0f129f1d2e..7fa48b3aa5 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/armv7m.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/armv7m.h
@@ -159,8 +159,19 @@ typedef struct {
 #define ARMV7M_SCB_SHCSR_MEMFAULTENA (1U << 16)
   uint32_t shcsr;
+#define ARMV7M_SCB_CFSR_MMFSR_MASK 0xff
+#define ARMV7M_SCB_CFSR_MMFSR_GET(n) (n & ARMV7M_SCB_CFSR_MMFSR_MASK)
+#define ARMV7M_SCB_CFSR_BFSR_MASK 0xff00
+#define ARMV7M_SCB_CFSR_BFSR_GET(n) (n & ARMV7M_SCB_CFSR_BFSR_MASK)
+#define ARMV7M_SCB_CFSR_UFSR_MASK 0xffff0000
+#define ARMV7M_SCB_CFSR_UFSR_GET(n) (n & ARMV7M_SCB_CFSR_UFSR_MASK)
   uint32_t cfsr;
+#define ARMV7M_SCB_HFSR_VECTTBL_MASK 0x2
+#define ARMV7M_SCB_HFSR_FORCED_MASK (1U << 30)
+#define ARMV7M_SCB_HFSR_DEBUGEVT_MASK (1U << 31)
   uint32_t hfsr;
   uint32_t dfsr;
   uint32_t mmfar;
   uint32_t bfar;
2.25.1
