[PATCH v2 10/32] bsp/leon3: Use new IRQ(A)MP register block API
Martin Åberg maberg at gaisler.com
Fri Jul 7 16:19:35 UTC 2023
Great to see the new register names being used.
OK. But a minor note below about LEON_Enable_interrupt_broadcast() below.
On 2023-07-05 13:18, Sebastian Huber wrote:
>   #define LEON_Force_interrupt( _source ) \
> -  do { \
> -    LEON3_IrqCtrl_Regs->iforce = (1U << (_source)); \
> -  } while (0)
> +  grlib_store_32(&LEON3_IrqCtrl_Regs->iforce0, 1U << (_source))
>   #define LEON_Enable_interrupt_broadcast( _source ) \
>     do { \
> @@ -207,24 +195,30 @@ extern uint32_t LEON3_Cpu_Index;
>     } while (0)
It looks like LEON_Enable_interrupt_broadcast() and
LEON_Disable_interrupt_broadcast are still accessing the
register by dereferencing LEON3_IrqCtrl_Regs->bcast directly,
in contrast to the other changes in the file. (These two macros
are not used anywhere at the moment.)
Best regards,
Martin Åberg
Software Engineer
Frontgrade Gaisler
martin.aberg at gaisler.com
Frontgrade Gaisler AB, Kungsgatan 12, SE-411 19 GÖTEBORG, Sweden.
+46 (0) 31 775 8650, www.gaisler.com
