[PATCH v2 27/32] bsps/sparc: Remove BSP_POWER_DOWN_AT_FATAL_HALT
Martin Åberg maberg at gaisler.com
Fri Jul 7 16:29:41 UTC 2023
OK
On 2023-07-05 13:18, Sebastian Huber wrote:
> Remove the BSP_POWER_DOWN_AT_FATAL_HALT BSP option.  Applications should
> do the customization of the system termination with an initial fatal
> extension.
>   bsps/sparc/leon3/start/bsp_fatal_halt.c      | 50 -------------------
>   bsps/sparc/shared/start/bsp_fatal_halt.c     | 52 --------------------
>   cpukit/score/cpu/sparc/syscall.S             |  2 +
>   spec/build/bsps/sparc/erc32/bsperc32.yml     |  3 --
>   spec/build/bsps/sparc/erc32/optpwrdwnhlt.yml | 16 ------
>   spec/build/bsps/sparc/leon2/grp.yml          |  2 -
>   spec/build/bsps/sparc/leon2/obj.yml          |  1 -
>   spec/build/bsps/sparc/leon2/optpwrdwnhlt.yml | 16 ------
>   spec/build/bsps/sparc/leon3/grp.yml          |  2 -
>   spec/build/bsps/sparc/leon3/obj.yml          |  1 -
>   spec/build/bsps/sparc/leon3/optpwrdwnhlt.yml | 16 ------
>   11 files changed, 2 insertions(+), 159 deletions(-)
>   delete mode 100644 bsps/sparc/leon3/start/bsp_fatal_halt.c
>   delete mode 100644 bsps/sparc/shared/start/bsp_fatal_halt.c
>   delete mode 100644 spec/build/bsps/sparc/erc32/optpwrdwnhlt.yml
>   delete mode 100644 spec/build/bsps/sparc/leon2/optpwrdwnhlt.yml
>   delete mode 100644 spec/build/bsps/sparc/leon3/optpwrdwnhlt.yml
Best regards,
Martin Åberg
Software Engineer
Frontgrade Gaisler
martin.aberg at gaisler.com
Frontgrade Gaisler AB, Kungsgatan 12, SE-411 19 GÖTEBORG, Sweden.
+46 (0) 31 775 8650, www.gaisler.com
