What Happened to _Thread_Close?
Fri Jul 7 19:50:42 UTC 2023
Hi
Building the rtems-examples, the test fat_ramdisk gets a failure from
rtems-tld because _Thread_Close is still listed in the ini files it uses.
What symbols should be in the sections that currently have _Thread_Close?
Small patch below my signature which just removes _Thread_Close references.
I am assuming something may need to be added but I don't know what changed
removed _Thread_Close.
Thanks.
---joel
diff --git a/linkers/rtems-score-thread.ini b/linkers/rtems-score-thread.ini
index 974bcfd..a759f72 100644
--- a/linkers/rtems-score-thread.ini
+++ b/linkers/rtems-score-thread.ini
@@ -5,7 +5,7 @@
 trace = _Thread_Handler_initialization, _Thread_Create_idle,
_Thread_Start_multitasking
 trace = _Stack_Allocate, _Stack_Free, _Thread_Start
 trace = _Thread_Yield, _Thread_Set_life_protection
-trace = _Thread_Kill_zombies, _Thread_Close
+trace = _Thread_Kill_zombies
 trace = _Thread_Clear_state, _Thread_Set_state, _Thread_Load_environment
 trace = _Thread_Get
@@ -19,7 +19,7 @@ trace = _Stack_Allocate, _Thread_Start
 trace = _Thread_Restart, _Thread_Handler
 [rtems-score-thread-destroy]
 [rtems-score-thread-activity]
@@ -38,7 +38,6 @@ _Thread_Start = Status_Control, Thread_Control*, const
Thread_Entry_information*
 _Thread_Yield = void, Thread_Control*
 _Thread_Set_life_protection = Thread_Life_state, Thread_Life_state
 _Thread_Kill_zombies = void, void
-_Thread_Close = void, Thread_Control*, Thread_Control*,
Thread_Close_context*
 _Thread_Clear_state = States_Control, Thread_Control*, States_Control
 _Thread_Set_state = States_Control, Thread_Control*, States_Control
 _Thread_Load_environment = void, Thread_Control*
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230707/f94e8312/attachment.htm>
