[PATCH rtems-examples v1] Add regulator example
Fri Jul 7 20:55:45 UTC 2023
Updates #4924.
 misc/Makefile                      |   6 +
 misc/regulator/Makefile            |  20 ++++
 misc/regulator/regulator_example.c | 179 +++++++++++++++++++++++++++++
 misc/regulator/rtems_config.c      |  59 ++++++++++
 misc/regulator/wscript             |  15 +++
 misc/wscript                       |   1 +
 6 files changed, 280 insertions(+)
 create mode 100644 misc/regulator/Makefile
 create mode 100644 misc/regulator/regulator_example.c
 create mode 100644 misc/regulator/rtems_config.c
 create mode 100644 misc/regulator/wscript
diff --git a/misc/Makefile b/misc/Makefile
index ed31598..a75ea58 100644
--- a/misc/Makefile
+++ b/misc/Makefile
@@ -8,3 +8,9 @@ SUBDIRS=minimum bspcmdline extract_example nanosecond_tick_wrap userdrv
 ifeq ($(RTEMS_HAS_POSIX_API),yes)
 # SUBDIRS += adamain
 endif
+# If regulator.h is not present, do not build that example
+ifneq (,$(RTEMS_MAKEFILE_PATH).lib/include/rtems/regulator.h)
+  SUBDIRS += regulator
+endif
diff --git a/misc/regulator/Makefile b/misc/regulator/Makefile
new file mode 100644
index 0000000..7446839
--- /dev/null
+++ b/misc/regulator/Makefile
@@ -0,0 +1,20 @@
+#  RTEMS_MAKEFILE_PATH is typically set in an environment variable
+PGM=${ARCH}/regulator_example.exe
+# C source names
+CSRCS = rtems_config.c regulator_example.c
+COBJS = $(CSRCS:%.c=${ARCH}/%.o)
+include $(RTEMS_MAKEFILE_PATH)/Makefile.inc
+include $(RTEMS_CUSTOM)
+include $(PROJECT_ROOT)/make/leaf.cfg
+OBJS= $(COBJS) $(CXXOBJS) $(ASOBJS)
+all:    ${ARCH} $(PGM)
+$(PGM): $(OBJS)
+	$(make-exe)
diff --git a/misc/regulator/regulator_example.c b/misc/regulator/regulator_example.c
index 0000000..d507d8d
--- /dev/null
+++ b/misc/regulator/regulator_example.c
@@ -0,0 +1,179 @@
+ * @defgroup RegulatorExamples Regulator Use Examples
+ * @brief User Examples for the Regulator
+ * This is a set of user examples for the regulator.
+ * @ingroup RegulatorExamples
+ * @file
+ * @brief Example 1 for Regulator Library
+ * Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
+ * are met:
+#include <assert.h>
+#include <stdio.h>
+#include <string.h>
+#include <unistd.h>
+#include <rtems.h>
+#include <rtems/inttypes.h>
+#include <rtems/regulator.h>
+ * @brief Count of Delivered Messages
+static int delivered = 1;
+ * @brief Deliver Method Which Prints
+ * This deliverer method implementation prints the message with the
+ * receipt time. The following behavioral warnings should be noted
+ * as this is not necessarily representative of whata real application
+ * may do:
+ * - The printing may skew the delivery time.
+ * - The message must be in ASCII and NUL terminated.
+static void example_deliverer(
+  void     *context,
+  void     *message,
+  size_t    length
+  (void) context;
+  (void) length;
+  int              rc;
+  struct timespec current;
+  rc = clock_gettime(CLOCK_REALTIME, &current);
+  assert(rc == 0);
+  fprintf(
+    stderr,
+    "%" PRIdtime_t ":%8ld %s\n",
+    current.tv_sec,
+    current.tv_nsec,
+    (char *)message
+  delivered += 1;
+ * @ingroup RegulatorTests
+ * @brief Verify rtems_regulator_send and output thread delivers message
+ * This example shows that when the regulator is successfully initialized
+ * and used as expected, a message sent via rtems_regulator_send() is delivered as
+ * expected.
+static void example_send_messages(void)
+  #define MAXIMUM_MESSAGE_LENGTH 32
+  rtems_status_code         sc;
+  rtems_regulator_instance *regulator;
+  char                      message[MAXIMUM_MESSAGE_LENGTH];
+  void                     *buffer;
+  size_t                    length;
+  int                       msg;
+  int                       i;
+  int                       burst;
+  rtems_regulator_attributes  attributes = {
+    .deliverer = example_deliverer,
+    .deliverer_context = NULL,
+    .maximum_message_size = MAXIMUM_MESSAGE_LENGTH,
+    .maximum_messages = 10,
+    .output_thread_priority = 16,
+    .output_thread_stack_size = 0,
+    .output_thread_period = RTEMS_MILLISECONDS_TO_TICKS(1000),
+    .maximum_to_dequeue_per_period = 3
+  sc = rtems_regulator_create(&attributes, &regulator);
+  assert(sc == RTEMS_SUCCESSFUL);
+  assert(regulator != NULL);
+   * Send messages as a burst which will need to be smoothly sent at
+   * the configured rate.
+  msg = 0;
+  for (burst=0 ; burst < 2 ; burst++ ) {
+    fprintf(stderr, "Send Burst %d of 7 messages\n", burst);
+    for (i=1; i <= 7 ; i++, msg++) {
+      sc = rtems_regulator_obtain_buffer(regulator, &buffer);
+      assert(buffer != NULL);
+      length = snprintf(message, MAXIMUM_MESSAGE_LENGTH, "message %d", msg);
+      strcpy(buffer, message);
+      sc = rtems_regulator_send(regulator, buffer, length);
+    sleep(5);
+    if (delivered == 14) {
+      fprintf(stderr, "*** END OF REGULATOR EXAMPLE 01 ***");
+      exit(0);
+  /* Will not exit above loop */
+  #undef MAXIMUM_MESSAGE_LENGTH
+/* Necessary prototype */
+rtems_task test_regulator(rtems_task_argument);
+ * @brief Entry task which invokes the example helper
+rtems_task test_regulator(rtems_task_argument arg)
+  (void) arg;
+  puts("*** START OF REGULATOR EXAMPLE 01 ***");
+  example_send_messages();
+  puts("*** END OF EXAMPLE REGULATOR 01 ***");
+  exit(0);
diff --git a/misc/regulator/rtems_config.c b/misc/regulator/rtems_config.c
index 0000000..ca96e1b
--- /dev/null
+++ b/misc/regulator/rtems_config.c
@@ -0,0 +1,59 @@
+ * @file
+ * @brief RTEMS Configuration for regulator tests
+ *  COPYRIGHT (c) 2022.  *  On-Line Applications Research Corporation (OAR).
+ * are met:
+#include <rtems.h>
+#include <bsp.h> /* for device driver prototypes */
+/* NOTICE: the clock driver is explicitly disabled */
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INIT_TASK_ENTRY_POINT test_regulator
+#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
+/* Use hard limits to make it easier to trip object creation errors */
+#define CONFIGURE_MAXIMUM_TASKS 2
+#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 1
+#define CONFIGURE_MAXIMUM_PARTITIONS 1
+#define CONFIGURE_MAXIMUM_PERIODS 1
+#define CONFIGURE_UNIFIED_WORK_AREAS
+#define CONFIGURE_MINIMUM_TASK_STACK_SIZE (8 * 1024)
+#include <rtems/confdefs.h>
diff --git a/misc/regulator/wscript b/misc/regulator/wscript
index 0000000..4a4f8de
--- /dev/null
+++ b/misc/regulator/wscript
@@ -0,0 +1,15 @@
+# Copyright 2023 Joel Sherrill (joel at rtems.org)
+# This file's license is 2-clause BSD as in this distribution's LICENSE.2 file.
+# Waf build script for an RTEMS Hello
+import rtems_waf.rtems as rtems
+def build(bld):
+    rtems.build(bld)
+    #if rtems.check_inc(bld, ['rtems/regulator.h']):
+    if bld.check(header_name='rtems/regulator.h', features='c', mandatory = False):
+        bld(features = 'c cprogram',
+            target = 'regulator_example.exe',
+            source = ['regulator_example.c','rtems_config.c'])
diff --git a/misc/wscript b/misc/wscript
index 8689080..4b8aa38 100644
--- a/misc/wscript
+++ b/misc/wscript
@@ -14,6 +14,7 @@ def build(bld):
     bld.recurse('bspcmdline')
     bld.recurse('nanosecond_tick_wrap')
     bld.recurse('qemu_vfat')
+    bld.recurse('regulator')
     bld.recurse('applib')
     bld.recurse('userdrv')
     #if rtems.check_posix(bld):
2.24.4
