[PATCH rtems-source-builder] bare/config: add renode rsb installation config
Tue Jul 11 18:01:16 UTC 2023
This probably requires some documentation, as it requires several
packages that are not going to be typically installed already by RTEMS
users/developers. Chris, is there any place to document required
dependencies/packages for a build set?
The patch has a whitespace problem
+# Renode source
 It might be a non-ASCII character, as it gets eaten by email but is
in the patch file.
Gedare
On Mon, Jul 10, 2023 at 5:13 AM Muhammad Sulthan Mazaya
<msulthanmazaya at gmail.com> wrote:
> An implementation of renode rsb installation config. It uses renode's
> github release as source and build the package using their build script.
>  bare/config/devel/renode-git-1.cfg | 47 ++++++++++++++++++++++++++++++
>  bare/config/devel/renode.bset      |  9 ++++++
>  2 files changed, 56 insertions(+)
>  create mode 100644 bare/config/devel/renode-git-1.cfg
>  create mode 100644 bare/config/devel/renode.bset
> diff --git a/bare/config/devel/renode-git-1.cfg b/bare/config/devel/renode-git-1.cfg
> new file mode 100644
> index 0000000..df424a6
> --- /dev/null
> +++ b/bare/config/devel/renode-git-1.cfg
> @@ -0,0 +1,47 @@
> +# Renode from github
> +%if %{release} == %{nil}
> + %define release 1
> +%endif
> +%define renode_version 1.13.3
> +Name:      renode-%{renode_version}-%{_host}-%{release}
> +Summary:   Renode v%{renode_version}
> +Version:   %{renode_version}
> +Release:   %{release}
> +URL:      http://www.renode.io
> +# Renode source
> +%source set renode https://github.com/renode/renode/releases/download/v%{renode_version}/renode_%{renode_version}_source.tar.xz
> +# Prepare the source code.
> +%prep
> +  build_top=$(pwd)
> +  source_dir_renode="renode_%{renode_version}_source"
> +  %source setup renode -q -n renode_%{renode_version}_source
> +  cd ${build_top}
> +%build
> +  build_top=$(pwd)
> +  cd ${source_dir_renode}
> +  ./build.sh
> +  cd ${build_top}
> +%install
> +  build_top=$(pwd)
> +  mkdir -p %{_bindir}
> +  cp -r ./${source_dir_renode}/* %{_bindir}
> +  cd ${build_top}
> diff --git a/bare/config/devel/renode.bset b/bare/config/devel/renode.bset
> index 0000000..d64a2a2
> --- /dev/null
> +++ b/bare/config/devel/renode.bset
> @@ -0,0 +1,9 @@
> +# Build set for Renode
> +    %define release 1
> +%endif
> +devel/renode-git-1
> 2.34.1
> devel mailing list
> devel at rtems.org
