[PATCH] arm/stm32h7: Add support for STM32H750B-DK
Kinsey Moore kinsey.moore at oarcorp.com
Tue Jul 11 21:26:15 UTC 2023
On Tue, Jul 11, 2023 at 4:04 PM Karel Gardas <karel at functional.vision>
wrote:
> On 7/11/23 15:50, Kinsey Moore wrote:
> > This adds support for the STM32H750B-DK discovery kit. This kit includes
> > a built-in STLINKv3 debugger which provides a USB serial bridge for
> > USART3. USART1 is routed to the Arduino header and USART2 is routed to
> > the STMOD connector. This BSP reuses what would otherwise be duplicated
> > files from the stm32h747i-disco BSP. Note that system_stm32h7xx.c has
> > been imported from the STM repository with two minor changes wrapped
> > with #if __rtems__. This hardware has been tested with hello and ticker.
> Nice! So with a just little bit of tweak I may get my stm32h745-disco
> up&running as your 750 is on the same disco kit. Sweet! :-)
> > diff --git a/spec/build/bsps/arm/stm32h7/optmemsdram1sz.yml
> b/spec/build/bsps/arm/stm32h7/optmemsdram1sz.yml
> > index bd1053db38..56ec66a64f 100644
> > --- a/spec/build/bsps/arm/stm32h7/optmemsdram1sz.yml
> > +++ b/spec/build/bsps/arm/stm32h7/optmemsdram1sz.yml
> > @@ -14,6 +14,9 @@ default:
> >     - arm/stm32h757i-eval-m4
> >     - arm/stm32h7b3i-dk
> >     value: 0x00000000
> > +- enabled-by:
> > +  - arm/stm32h750b-dk
> > +  value: 0x01000000
> >   - enabled-by: true
> >     value: 0x02000000
> >   description: |
> Have you actually tested writing to the SDRAM 1 memory region? Asking
> since IIRC several of STMicro data sheets were wrong about specifying
> RAM to be SDRAM 1 while in fact it was in SDRAM 2 region by default. And
> your system*.c does not contain (if I've not overlooked it) any
> remapping from SDRAM 2 to SDRAM 1 -- so just asking for to be sure, you
> actually tested putting some data into it.
> E.g. "An 8M x 32-bit SDRAM is connected to the SDRAM bank1 of the FMC
> interface of the STM32H7x7XI microcontroller." -- this comes from um2525
> for stm32h757i-eval and no, by default SDRAM is mapped to bank2.
I'm not sure that anything I've done for testing would have verified that
the SDRAM is operating properly. I'll have to pull it back out and give it
a shot.
Kinsey
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230711/a1cdb845/attachment-0001.htm>
