[PATCH v3 10/38] bsps/grlib: Use GRLIB definition of GRSPW2
Wed Jul 12 13:49:49 UTC 2023
Update #4842.
 bsps/include/grlib/grspw2-regs.h | 1122 ++++++++++++++++++++++++++----
 1 file changed, 982 insertions(+), 140 deletions(-)
diff --git a/bsps/include/grlib/grspw2-regs.h b/bsps/include/grlib/grspw2-regs.h
index 8e9661edc2..6293230cfe 100644
--- a/bsps/include/grlib/grspw2-regs.h
+++ b/bsps/include/grlib/grspw2-regs.h
@@ -9,7 +9,7 @@
- * Copyright (C) 2021 embedded brains GmbH & Co. KG
+ * Copyright (C) 2021, 2023 embedded brains GmbH & Co. KG
  * modification, are permitted provided that the following conditions
@@ -61,6 +61,282 @@
 extern "C" {
 #endif
+/* Generated from spec:/dev/grlib/if/grspw2-dma */
+ * @defgroup RTEMSDeviceGRSPW2DMA GRSPW2 DMA
+ * @ingroup RTEMSDeviceGRSPW2
+ * @brief This group contains the GRSPW2 DMA interfaces.
+ * @defgroup RTEMSDeviceGRSPW2DMADMACTRL DMA control/status (DMACTRL)
+ * @brief This group contains register bit definitions.
+#define GRSPW2_DMACTRL_INTNUM_SHIFT 26
+#define GRSPW2_DMACTRL_INTNUM_MASK 0xfc000000U
+#define GRSPW2_DMACTRL_INTNUM_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_DMACTRL_INTNUM_MASK ) >> \
+    GRSPW2_DMACTRL_INTNUM_SHIFT )
+#define GRSPW2_DMACTRL_INTNUM_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_DMACTRL_INTNUM_MASK ) | \
+    ( ( ( _val ) << GRSPW2_DMACTRL_INTNUM_SHIFT ) & \
+      GRSPW2_DMACTRL_INTNUM_MASK ) )
+#define GRSPW2_DMACTRL_INTNUM( _val ) \
+#define GRSPW2_DMACTRL_RES_SHIFT 24
+#define GRSPW2_DMACTRL_RES_MASK 0x3000000U
+#define GRSPW2_DMACTRL_RES_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_DMACTRL_RES_MASK ) >> \
+    GRSPW2_DMACTRL_RES_SHIFT )
+#define GRSPW2_DMACTRL_RES_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_DMACTRL_RES_MASK ) | \
+    ( ( ( _val ) << GRSPW2_DMACTRL_RES_SHIFT ) & \
+      GRSPW2_DMACTRL_RES_MASK ) )
+#define GRSPW2_DMACTRL_RES( _val ) \
+#define GRSPW2_DMACTRL_EP 0x800000U
+#define GRSPW2_DMACTRL_TR 0x400000U
+#define GRSPW2_DMACTRL_IE 0x200000U
+#define GRSPW2_DMACTRL_IT 0x100000U
+#define GRSPW2_DMACTRL_RP 0x80000U
+#define GRSPW2_DMACTRL_TP 0x40000U
+#define GRSPW2_DMACTRL_TL 0x20000U
+#define GRSPW2_DMACTRL_LE 0x10000U
+#define GRSPW2_DMACTRL_SP 0x8000U
+#define GRSPW2_DMACTRL_SA 0x4000U
+#define GRSPW2_DMACTRL_EN 0x2000U
+#define GRSPW2_DMACTRL_NS 0x1000U
+#define GRSPW2_DMACTRL_RD 0x800U
+#define GRSPW2_DMACTRL_RX 0x400U
+#define GRSPW2_DMACTRL_AT 0x200U
+#define GRSPW2_DMACTRL_RA 0x100U
+#define GRSPW2_DMACTRL_TA 0x80U
+#define GRSPW2_DMACTRL_PR 0x40U
+#define GRSPW2_DMACTRL_PS 0x20U
+#define GRSPW2_DMACTRL_AI 0x10U
+#define GRSPW2_DMACTRL_RI 0x8U
+#define GRSPW2_DMACTRL_TI 0x4U
+#define GRSPW2_DMACTRL_RE 0x2U
+#define GRSPW2_DMACTRL_TE 0x1U
+ * @defgroup RTEMSDeviceGRSPW2DMADMAMAXLEN DMA RX maximum length (DMAMAXLEN)
+#define GRSPW2_DMAMAXLEN_RXMAXLEN_SHIFT 2
+#define GRSPW2_DMAMAXLEN_RXMAXLEN_MASK 0x1fffffcU
+#define GRSPW2_DMAMAXLEN_RXMAXLEN_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_DMAMAXLEN_RXMAXLEN_MASK ) >> \
+    GRSPW2_DMAMAXLEN_RXMAXLEN_SHIFT )
+#define GRSPW2_DMAMAXLEN_RXMAXLEN_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_DMAMAXLEN_RXMAXLEN_MASK ) | \
+    ( ( ( _val ) << GRSPW2_DMAMAXLEN_RXMAXLEN_SHIFT ) & \
+      GRSPW2_DMAMAXLEN_RXMAXLEN_MASK ) )
+#define GRSPW2_DMAMAXLEN_RXMAXLEN( _val ) \
+#define GRSPW2_DMAMAXLEN_RES_SHIFT 0
+#define GRSPW2_DMAMAXLEN_RES_MASK 0x3U
+#define GRSPW2_DMAMAXLEN_RES_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_DMAMAXLEN_RES_MASK ) >> \
+    GRSPW2_DMAMAXLEN_RES_SHIFT )
+#define GRSPW2_DMAMAXLEN_RES_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_DMAMAXLEN_RES_MASK ) | \
+    ( ( ( _val ) << GRSPW2_DMAMAXLEN_RES_SHIFT ) & \
+      GRSPW2_DMAMAXLEN_RES_MASK ) )
+#define GRSPW2_DMAMAXLEN_RES( _val ) \
+ * @defgroup RTEMSDeviceGRSPW2DMADMATXDESC \
+ *   DMA transmit descriptor table address (DMATXDESC)
+#define GRSPW2_DMATXDESC_DESCBASEADDR_SHIFT 0
+#define GRSPW2_DMATXDESC_DESCBASEADDR_MASK 0xffffffffU
+#define GRSPW2_DMATXDESC_DESCBASEADDR_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_DMATXDESC_DESCBASEADDR_MASK ) >> \
+    GRSPW2_DMATXDESC_DESCBASEADDR_SHIFT )
+#define GRSPW2_DMATXDESC_DESCBASEADDR_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_DMATXDESC_DESCBASEADDR_MASK ) | \
+    ( ( ( _val ) << GRSPW2_DMATXDESC_DESCBASEADDR_SHIFT ) & \
+      GRSPW2_DMATXDESC_DESCBASEADDR_MASK ) )
+#define GRSPW2_DMATXDESC_DESCBASEADDR( _val ) \
+#define GRSPW2_DMATXDESC_DESCSEL_SHIFT 4
+#define GRSPW2_DMATXDESC_DESCSEL_MASK 0xfffffff0U
+#define GRSPW2_DMATXDESC_DESCSEL_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_DMATXDESC_DESCSEL_MASK ) >> \
+    GRSPW2_DMATXDESC_DESCSEL_SHIFT )
+#define GRSPW2_DMATXDESC_DESCSEL_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_DMATXDESC_DESCSEL_MASK ) | \
+    ( ( ( _val ) << GRSPW2_DMATXDESC_DESCSEL_SHIFT ) & \
+      GRSPW2_DMATXDESC_DESCSEL_MASK ) )
+#define GRSPW2_DMATXDESC_DESCSEL( _val ) \
+ * @defgroup RTEMSDeviceGRSPW2DMADMARXDESC \
+ *   DMA receive descriptor table address (DMARXDESC)
+#define GRSPW2_DMARXDESC_DESCBASEADDR_SHIFT 10
+#define GRSPW2_DMARXDESC_DESCBASEADDR_MASK 0xfffffc00U
+#define GRSPW2_DMARXDESC_DESCBASEADDR_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_DMARXDESC_DESCBASEADDR_MASK ) >> \
+    GRSPW2_DMARXDESC_DESCBASEADDR_SHIFT )
+#define GRSPW2_DMARXDESC_DESCBASEADDR_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_DMARXDESC_DESCBASEADDR_MASK ) | \
+    ( ( ( _val ) << GRSPW2_DMARXDESC_DESCBASEADDR_SHIFT ) & \
+      GRSPW2_DMARXDESC_DESCBASEADDR_MASK ) )
+#define GRSPW2_DMARXDESC_DESCBASEADDR( _val ) \
+#define GRSPW2_DMARXDESC_DESCSEL_SHIFT 3
+#define GRSPW2_DMARXDESC_DESCSEL_MASK 0x3f8U
+#define GRSPW2_DMARXDESC_DESCSEL_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_DMARXDESC_DESCSEL_MASK ) >> \
+    GRSPW2_DMARXDESC_DESCSEL_SHIFT )
+#define GRSPW2_DMARXDESC_DESCSEL_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_DMARXDESC_DESCSEL_MASK ) | \
+    ( ( ( _val ) << GRSPW2_DMARXDESC_DESCSEL_SHIFT ) & \
+      GRSPW2_DMARXDESC_DESCSEL_MASK ) )
+#define GRSPW2_DMARXDESC_DESCSEL( _val ) \
+ * @defgroup RTEMSDeviceGRSPW2DMADMAADDR DMA address (DMAADDR)
+#define GRSPW2_DMAADDR_MASK_SHIFT 8
+#define GRSPW2_DMAADDR_MASK_MASK 0xff00U
+#define GRSPW2_DMAADDR_MASK_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_DMAADDR_MASK_MASK ) >> \
+    GRSPW2_DMAADDR_MASK_SHIFT )
+#define GRSPW2_DMAADDR_MASK_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_DMAADDR_MASK_MASK ) | \
+    ( ( ( _val ) << GRSPW2_DMAADDR_MASK_SHIFT ) & \
+      GRSPW2_DMAADDR_MASK_MASK ) )
+#define GRSPW2_DMAADDR_MASK( _val ) \
+#define GRSPW2_DMAADDR_ADDR_SHIFT 0
+#define GRSPW2_DMAADDR_ADDR_MASK 0xffU
+#define GRSPW2_DMAADDR_ADDR_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_DMAADDR_ADDR_MASK ) >> \
+    GRSPW2_DMAADDR_ADDR_SHIFT )
+#define GRSPW2_DMAADDR_ADDR_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_DMAADDR_ADDR_MASK ) | \
+    ( ( ( _val ) << GRSPW2_DMAADDR_ADDR_SHIFT ) & \
+      GRSPW2_DMAADDR_ADDR_MASK ) )
+#define GRSPW2_DMAADDR_ADDR( _val ) \
+ * @brief This structure defines the GRSPW2 DMA register block memory map.
+typedef struct grspw2_dma {
+   * @brief See @ref RTEMSDeviceGRSPW2DMADMACTRL.
+  uint32_t dmactrl;
+   * @brief See @ref RTEMSDeviceGRSPW2DMADMAMAXLEN.
+  uint32_t dmamaxlen;
+   * @brief See @ref RTEMSDeviceGRSPW2DMADMATXDESC.
+  uint32_t dmatxdesc;
+   * @brief See @ref RTEMSDeviceGRSPW2DMADMARXDESC.
+  uint32_t dmarxdesc;
+   * @brief See @ref RTEMSDeviceGRSPW2DMADMAADDR.
+  uint32_t dmaaddr;
+  uint32_t reserved_14_20[ 3 ];
+} grspw2_dma;
 /* Generated from spec:/dev/grlib/if/grspw2 */
@@ -102,10 +378,39 @@ extern "C" {
 #define GRSPW2_CTRL_PO 0x4000000U
+#define GRSPW2_CTRL_CC 0x2000000U
+#define GRSPW2_CTRL_ID 0x1000000U
+#define GRSPW2_CTRL_R 0x800000U
+#define GRSPW2_CTRL_LE 0x400000U
+#define GRSPW2_CTRL_PS 0x200000U
+#define GRSPW2_CTRL_NP 0x100000U
+#define GRSPW2_CTRL_PNPA_SHIFT 18
+#define GRSPW2_CTRL_PNPA_MASK 0xc0000U
+#define GRSPW2_CTRL_PNPA_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_CTRL_PNPA_MASK ) >> \
+    GRSPW2_CTRL_PNPA_SHIFT )
+#define GRSPW2_CTRL_PNPA_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_CTRL_PNPA_MASK ) | \
+    ( ( ( _val ) << GRSPW2_CTRL_PNPA_SHIFT ) & \
+      GRSPW2_CTRL_PNPA_MASK ) )
+#define GRSPW2_CTRL_PNPA( _val ) \
 #define GRSPW2_CTRL_RD 0x20000U
 #define GRSPW2_CTRL_RE 0x10000U
+#define GRSPW2_CTRL_PE 0x8000U
+#define GRSPW2_CTRL_R 0x4000U
 #define GRSPW2_CTRL_TL 0x2000U
 #define GRSPW2_CTRL_TF 0x1000U
@@ -118,6 +423,8 @@ extern "C" {
 #define GRSPW2_CTRL_TQ 0x100U
+#define GRSPW2_CTRL_R 0x80U
 #define GRSPW2_CTRL_RS 0x40U
 #define GRSPW2_CTRL_PM 0x20U
@@ -155,18 +462,7 @@ extern "C" {
   ( ( ( _val ) << GRSPW2_STS_NRXD_SHIFT ) & \
     GRSPW2_STS_NRXD_MASK )
-#define GRSPW2_STS_NTXD_SHIFT 24
-#define GRSPW2_STS_NTXD_MASK 0x3000000U
-#define GRSPW2_STS_NTXD_GET( _reg ) \
-  ( ( ( _reg ) & GRSPW2_STS_NTXD_MASK ) >> \
-    GRSPW2_STS_NTXD_SHIFT )
-#define GRSPW2_STS_NTXD_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~GRSPW2_STS_NTXD_MASK ) | \
-    ( ( ( _val ) << GRSPW2_STS_NTXD_SHIFT ) & \
-      GRSPW2_STS_NTXD_MASK ) )
-#define GRSPW2_STS_NTXD( _val ) \
+#define GRSPW2_STS_NTXD 0x2000000U
 #define GRSPW2_STS_LS_SHIFT 21
 #define GRSPW2_STS_LS_MASK 0xe00000U
@@ -181,10 +477,25 @@ extern "C" {
   ( ( ( _val ) << GRSPW2_STS_LS_SHIFT ) & \
     GRSPW2_STS_LS_MASK )
+#define GRSPW2_STS_AP 0x200U
 #define GRSPW2_STS_EE 0x100U
 #define GRSPW2_STS_IA 0x80U
+#define GRSPW2_STS_RES_SHIFT 5
+#define GRSPW2_STS_RES_MASK 0x60U
+#define GRSPW2_STS_RES_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_STS_RES_MASK ) >> \
+    GRSPW2_STS_RES_SHIFT )
+#define GRSPW2_STS_RES_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_STS_RES_MASK ) | \
+    ( ( ( _val ) << GRSPW2_STS_RES_SHIFT ) & \
+      GRSPW2_STS_RES_MASK ) )
+#define GRSPW2_STS_RES( _val ) \
 #define GRSPW2_STS_PE 0x10U
 #define GRSPW2_STS_DE 0x8U
@@ -329,190 +640,633 @@ extern "C" {
- * @defgroup RTEMSDeviceGRSPW2DMACTRL DMA control/status, channel 1 (DMACTRL)
+ * @defgroup RTEMSDeviceGRSPW2INTCTRL Interrupt distribution control (INTCTRL)
-#define GRSPW2_DMACTRL_EP 0x800000U
-#define GRSPW2_DMACTRL_TR 0x400000U
-#define GRSPW2_DMACTRL_RP 0x80000U
-#define GRSPW2_DMACTRL_TP 0x40000U
+#define GRSPW2_INTCTRL_INTNUM_SHIFT 26
+#define GRSPW2_INTCTRL_INTNUM_MASK 0xfc000000U
+#define GRSPW2_INTCTRL_INTNUM_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_INTCTRL_INTNUM_MASK ) >> \
+    GRSPW2_INTCTRL_INTNUM_SHIFT )
+#define GRSPW2_INTCTRL_INTNUM_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_INTCTRL_INTNUM_MASK ) | \
+    ( ( ( _val ) << GRSPW2_INTCTRL_INTNUM_SHIFT ) & \
+      GRSPW2_INTCTRL_INTNUM_MASK ) )
+#define GRSPW2_INTCTRL_INTNUM( _val ) \
+#define GRSPW2_INTCTRL_RS 0x2000000U
+#define GRSPW2_INTCTRL_EE 0x1000000U
+#define GRSPW2_INTCTRL_IA 0x800000U
+#define GRSPW2_INTCTRL_RES 0x2U
+#define GRSPW2_INTCTRL_TQ_SHIFT 21
+#define GRSPW2_INTCTRL_TQ_MASK 0x600000U
+#define GRSPW2_INTCTRL_TQ_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_INTCTRL_TQ_MASK ) >> \
+    GRSPW2_INTCTRL_TQ_SHIFT )
+#define GRSPW2_INTCTRL_TQ_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_INTCTRL_TQ_MASK ) | \
+    ( ( ( _val ) << GRSPW2_INTCTRL_TQ_SHIFT ) & \
+      GRSPW2_INTCTRL_TQ_MASK ) )
+#define GRSPW2_INTCTRL_TQ( _val ) \
+#define GRSPW2_INTCTRL_AQ 0x100000U
+#define GRSPW2_INTCTRL_IQ 0x80000U
+#define GRSPW2_INTCTRL_RES 0x40000U
+#define GRSPW2_INTCTRL_AA_SHIFT 16
+#define GRSPW2_INTCTRL_AA_MASK 0x30000U
+#define GRSPW2_INTCTRL_AA_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_INTCTRL_AA_MASK ) >> \
+    GRSPW2_INTCTRL_AA_SHIFT )
+#define GRSPW2_INTCTRL_AA_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_INTCTRL_AA_MASK ) | \
+    ( ( ( _val ) << GRSPW2_INTCTRL_AA_SHIFT ) & \
+      GRSPW2_INTCTRL_AA_MASK ) )
+#define GRSPW2_INTCTRL_AA( _val ) \
+#define GRSPW2_INTCTRL_AT 0x8000U
+#define GRSPW2_INTCTRL_IT 0x4000U
+#define GRSPW2_INTCTRL_RES 0x2000U
+#define GRSPW2_INTCTRL_ID_SHIFT 8
+#define GRSPW2_INTCTRL_ID_MASK 0x1f00U
+#define GRSPW2_INTCTRL_ID_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_INTCTRL_ID_MASK ) >> \
+    GRSPW2_INTCTRL_ID_SHIFT )
+#define GRSPW2_INTCTRL_ID_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_INTCTRL_ID_MASK ) | \
+    ( ( ( _val ) << GRSPW2_INTCTRL_ID_SHIFT ) & \
+      GRSPW2_INTCTRL_ID_MASK ) )
+#define GRSPW2_INTCTRL_ID( _val ) \
+#define GRSPW2_INTCTRL_II 0x80U
+#define GRSPW2_INTCTRL_TXINT 0x40U
-#define GRSPW2_DMACTRL_TL 0x20000U
-#define GRSPW2_DMACTRL_LE 0x10000U
+ * @defgroup RTEMSDeviceGRSPW2INTRX Interrupt-code receive (INTRX)
-#define GRSPW2_DMACTRL_SP 0x8000U
+#define GRSPW2_INTRX_RXIRQ_SHIFT 0
+#define GRSPW2_INTRX_RXIRQ_MASK 0xffffffffU
+#define GRSPW2_INTRX_RXIRQ_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_INTRX_RXIRQ_MASK ) >> \
+    GRSPW2_INTRX_RXIRQ_SHIFT )
+#define GRSPW2_INTRX_RXIRQ_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_INTRX_RXIRQ_MASK ) | \
+    ( ( ( _val ) << GRSPW2_INTRX_RXIRQ_SHIFT ) & \
+      GRSPW2_INTRX_RXIRQ_MASK ) )
+#define GRSPW2_INTRX_RXIRQ( _val ) \
-#define GRSPW2_DMACTRL_SA 0x4000U
-#define GRSPW2_DMACTRL_EN 0x2000U
+ * @defgroup RTEMSDeviceGRSPW2INTTO Interrupt timeout (INTTO)
-#define GRSPW2_DMACTRL_NS 0x1000U
+#define GRSPW2_INTTO_INTTO_SHIFT 0
+#define GRSPW2_INTTO_INTTO_MASK 0xffffffffU
+#define GRSPW2_INTTO_INTTO_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_INTTO_INTTO_MASK ) >> \
+    GRSPW2_INTTO_INTTO_SHIFT )
+#define GRSPW2_INTTO_INTTO_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_INTTO_INTTO_MASK ) | \
+    ( ( ( _val ) << GRSPW2_INTTO_INTTO_SHIFT ) & \
+      GRSPW2_INTTO_INTTO_MASK ) )
+#define GRSPW2_INTTO_INTTO( _val ) \
-#define GRSPW2_DMACTRL_RD 0x800U
-#define GRSPW2_DMACTRL_RX 0x400U
+ * @defgroup RTEMSDeviceGRSPW2INTTOEXT Interrupt timeout extended (INTTOEXT)
-#define GRSPW2_DMACTRL_AT 0x200U
+#define GRSPW2_INTTOEXT_INTTOEXT_SHIFT 0
+#define GRSPW2_INTTOEXT_INTTOEXT_MASK 0xffffffffU
+#define GRSPW2_INTTOEXT_INTTOEXT_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_INTTOEXT_INTTOEXT_MASK ) >> \
+    GRSPW2_INTTOEXT_INTTOEXT_SHIFT )
+#define GRSPW2_INTTOEXT_INTTOEXT_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_INTTOEXT_INTTOEXT_MASK ) | \
+    ( ( ( _val ) << GRSPW2_INTTOEXT_INTTOEXT_SHIFT ) & \
+      GRSPW2_INTTOEXT_INTTOEXT_MASK ) )
+#define GRSPW2_INTTOEXT_INTTOEXT( _val ) \
-#define GRSPW2_DMACTRL_RA 0x100U
-#define GRSPW2_DMACTRL_TA 0x80U
+ * @defgroup RTEMSDeviceGRSPW2TICKMASK Interrupt tick-out mask (TICKMASK)
-#define GRSPW2_DMACTRL_PR 0x40U
+#define GRSPW2_TICKMASK_MASK_SHIFT 0
+#define GRSPW2_TICKMASK_MASK_MASK 0xffffffffU
+#define GRSPW2_TICKMASK_MASK_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_TICKMASK_MASK_MASK ) >> \
+    GRSPW2_TICKMASK_MASK_SHIFT )
+#define GRSPW2_TICKMASK_MASK_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_TICKMASK_MASK_MASK ) | \
+    ( ( ( _val ) << GRSPW2_TICKMASK_MASK_SHIFT ) & \
+      GRSPW2_TICKMASK_MASK_MASK ) )
+#define GRSPW2_TICKMASK_MASK( _val ) \
-#define GRSPW2_DMACTRL_PS 0x20U
-#define GRSPW2_DMACTRL_AI 0x10U
+ * @defgroup RTEMSDeviceGRSPW2AUTOACKTICKMASKEXT \
+ *   Interrupt-code auto acknowledge mask / interrupt tick-out mask extended (AUTOACK_TICKMASKEXT)
-#define GRSPW2_DMACTRL_RI 0x8U
+#define GRSPW2_AUTOACK_TICKMASKEXT_AAMASK_SHIFT 0
+#define GRSPW2_AUTOACK_TICKMASKEXT_AAMASK_MASK 0xffffffffU
+#define GRSPW2_AUTOACK_TICKMASKEXT_AAMASK_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_AUTOACK_TICKMASKEXT_AAMASK_MASK ) >> \
+    GRSPW2_AUTOACK_TICKMASKEXT_AAMASK_SHIFT )
+#define GRSPW2_AUTOACK_TICKMASKEXT_AAMASK_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_AUTOACK_TICKMASKEXT_AAMASK_MASK ) | \
+    ( ( ( _val ) << GRSPW2_AUTOACK_TICKMASKEXT_AAMASK_SHIFT ) & \
+      GRSPW2_AUTOACK_TICKMASKEXT_AAMASK_MASK ) )
+#define GRSPW2_AUTOACK_TICKMASKEXT_AAMASK( _val ) \
-#define GRSPW2_DMACTRL_TI 0x4U
-#define GRSPW2_DMACTRL_RE 0x2U
+ * @defgroup RTEMSDeviceGRSPW2INTCFG \
+ *   Interrupt distribution configuration (INTCFG)
-#define GRSPW2_DMACTRL_TE 0x1U
+#define GRSPW2_INTCFG_INTNUM3_SHIFT 26
+#define GRSPW2_INTCFG_INTNUM3_MASK 0xfc000000U
+#define GRSPW2_INTCFG_INTNUM3_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_INTCFG_INTNUM3_MASK ) >> \
+    GRSPW2_INTCFG_INTNUM3_SHIFT )
+#define GRSPW2_INTCFG_INTNUM3_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_INTCFG_INTNUM3_MASK ) | \
+    ( ( ( _val ) << GRSPW2_INTCFG_INTNUM3_SHIFT ) & \
+      GRSPW2_INTCFG_INTNUM3_MASK ) )
+#define GRSPW2_INTCFG_INTNUM3( _val ) \
+#define GRSPW2_INTCFG_INTNUM2_SHIFT 20
+#define GRSPW2_INTCFG_INTNUM2_MASK 0x3f00000U
+#define GRSPW2_INTCFG_INTNUM2_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_INTCFG_INTNUM2_MASK ) >> \
+    GRSPW2_INTCFG_INTNUM2_SHIFT )
+#define GRSPW2_INTCFG_INTNUM2_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_INTCFG_INTNUM2_MASK ) | \
+    ( ( ( _val ) << GRSPW2_INTCFG_INTNUM2_SHIFT ) & \
+      GRSPW2_INTCFG_INTNUM2_MASK ) )
+#define GRSPW2_INTCFG_INTNUM2( _val ) \
+#define GRSPW2_INTCFG_INTNUM1_SHIFT 14
+#define GRSPW2_INTCFG_INTNUM1_MASK 0xfc000U
+#define GRSPW2_INTCFG_INTNUM1_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_INTCFG_INTNUM1_MASK ) >> \
+    GRSPW2_INTCFG_INTNUM1_SHIFT )
+#define GRSPW2_INTCFG_INTNUM1_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_INTCFG_INTNUM1_MASK ) | \
+    ( ( ( _val ) << GRSPW2_INTCFG_INTNUM1_SHIFT ) & \
+      GRSPW2_INTCFG_INTNUM1_MASK ) )
+#define GRSPW2_INTCFG_INTNUM1( _val ) \
+#define GRSPW2_INTCFG_INTNUM0_SHIFT 8
+#define GRSPW2_INTCFG_INTNUM0_MASK 0x3f00U
+#define GRSPW2_INTCFG_INTNUM0_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_INTCFG_INTNUM0_MASK ) >> \
+    GRSPW2_INTCFG_INTNUM0_SHIFT )
+#define GRSPW2_INTCFG_INTNUM0_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_INTCFG_INTNUM0_MASK ) | \
+    ( ( ( _val ) << GRSPW2_INTCFG_INTNUM0_SHIFT ) & \
+      GRSPW2_INTCFG_INTNUM0_MASK ) )
+#define GRSPW2_INTCFG_INTNUM0( _val ) \
+#define GRSPW2_INTCFG_NUMINT_SHIFT 4
+#define GRSPW2_INTCFG_NUMINT_MASK 0xf0U
+#define GRSPW2_INTCFG_NUMINT_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_INTCFG_NUMINT_MASK ) >> \
+    GRSPW2_INTCFG_NUMINT_SHIFT )
+#define GRSPW2_INTCFG_NUMINT_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_INTCFG_NUMINT_MASK ) | \
+    ( ( ( _val ) << GRSPW2_INTCFG_NUMINT_SHIFT ) & \
+      GRSPW2_INTCFG_NUMINT_MASK ) )
+#define GRSPW2_INTCFG_NUMINT( _val ) \
+#define GRSPW2_INTCFG_PR 0x8U
+#define GRSPW2_INTCFG_IR 0x4U
+#define GRSPW2_INTCFG_IT 0x2U
+#define GRSPW2_INTCFG_EE 0x1U
- * @defgroup RTEMSDeviceGRSPW2DMAMAXLEN \
- *   DMA RX maximum length, channel 1 (DMAMAXLEN)
+ * @defgroup RTEMSDeviceGRSPW2ISR Interrupt distribution ISR (ISR)
-#define GRSPW2_DMAMAXLEN_RXMAXLEN_SHIFT 2
-#define GRSPW2_DMAMAXLEN_RXMAXLEN_MASK 0x1fffffcU
-#define GRSPW2_DMAMAXLEN_RXMAXLEN_GET( _reg ) \
-  ( ( ( _reg ) & GRSPW2_DMAMAXLEN_RXMAXLEN_MASK ) >> \
-    GRSPW2_DMAMAXLEN_RXMAXLEN_SHIFT )
-#define GRSPW2_DMAMAXLEN_RXMAXLEN_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~GRSPW2_DMAMAXLEN_RXMAXLEN_MASK ) | \
-    ( ( ( _val ) << GRSPW2_DMAMAXLEN_RXMAXLEN_SHIFT ) & \
-      GRSPW2_DMAMAXLEN_RXMAXLEN_MASK ) )
-#define GRSPW2_DMAMAXLEN_RXMAXLEN( _val ) \
+#define GRSPW2_ISR_ISR_SHIFT 0
+#define GRSPW2_ISR_ISR_MASK 0xffffffffU
+#define GRSPW2_ISR_ISR_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_ISR_ISR_MASK ) >> \
+    GRSPW2_ISR_ISR_SHIFT )
+#define GRSPW2_ISR_ISR_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_ISR_ISR_MASK ) | \
+    ( ( ( _val ) << GRSPW2_ISR_ISR_SHIFT ) & \
+      GRSPW2_ISR_ISR_MASK ) )
+#define GRSPW2_ISR_ISR( _val ) \
- * @defgroup RTEMSDeviceGRSPW2DMATXDESC \
- *   DMA transmitter descriptor table address, channel 1 (DMATXDESC)
+ * @defgroup RTEMSDeviceGRSPW2ISREXT \
+ *   Interrupt distribution ISR extended (ISREXT)
-#define GRSPW2_DMATXDESC_DESCBASEADDR_SHIFT 10
-#define GRSPW2_DMATXDESC_DESCBASEADDR_MASK 0xfffffc00U
-#define GRSPW2_DMATXDESC_DESCBASEADDR_GET( _reg ) \
-  ( ( ( _reg ) & GRSPW2_DMATXDESC_DESCBASEADDR_MASK ) >> \
-    GRSPW2_DMATXDESC_DESCBASEADDR_SHIFT )
-#define GRSPW2_DMATXDESC_DESCBASEADDR_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~GRSPW2_DMATXDESC_DESCBASEADDR_MASK ) | \
-    ( ( ( _val ) << GRSPW2_DMATXDESC_DESCBASEADDR_SHIFT ) & \
-      GRSPW2_DMATXDESC_DESCBASEADDR_MASK ) )
-#define GRSPW2_DMATXDESC_DESCBASEADDR( _val ) \
+#define GRSPW2_ISREXT_ISR_SHIFT 0
+#define GRSPW2_ISREXT_ISR_MASK 0xffffffffU
+#define GRSPW2_ISREXT_ISR_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_ISREXT_ISR_MASK ) >> \
+    GRSPW2_ISREXT_ISR_SHIFT )
+#define GRSPW2_ISREXT_ISR_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_ISREXT_ISR_MASK ) | \
+    ( ( ( _val ) << GRSPW2_ISREXT_ISR_SHIFT ) & \
+      GRSPW2_ISREXT_ISR_MASK ) )
+#define GRSPW2_ISREXT_ISR( _val ) \
-#define GRSPW2_DMATXDESC_DESCSEL_SHIFT 4
-#define GRSPW2_DMATXDESC_DESCSEL_MASK 0x3f0U
-#define GRSPW2_DMATXDESC_DESCSEL_GET( _reg ) \
-  ( ( ( _reg ) & GRSPW2_DMATXDESC_DESCSEL_MASK ) >> \
-    GRSPW2_DMATXDESC_DESCSEL_SHIFT )
-#define GRSPW2_DMATXDESC_DESCSEL_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~GRSPW2_DMATXDESC_DESCSEL_MASK ) | \
-    ( ( ( _val ) << GRSPW2_DMATXDESC_DESCSEL_SHIFT ) & \
-      GRSPW2_DMATXDESC_DESCSEL_MASK ) )
-#define GRSPW2_DMATXDESC_DESCSEL( _val ) \
+ * @defgroup RTEMSDeviceGRSPW2PRESCALER \
+ *   Interrupt distribution prescaler reload (PRESCALER)
+#define GRSPW2_PRESCALER_R 0x80000000U
+#define GRSPW2_PRESCALER_RL_SHIFT 0
+#define GRSPW2_PRESCALER_RL_MASK 0x7fffffffU
+#define GRSPW2_PRESCALER_RL_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_PRESCALER_RL_MASK ) >> \
+    GRSPW2_PRESCALER_RL_SHIFT )
+#define GRSPW2_PRESCALER_RL_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_PRESCALER_RL_MASK ) | \
+    ( ( ( _val ) << GRSPW2_PRESCALER_RL_SHIFT ) & \
+      GRSPW2_PRESCALER_RL_MASK ) )
+#define GRSPW2_PRESCALER_RL( _val ) \
- * @defgroup RTEMSDeviceGRSPW2DMARXDESC \
- *   DMA receiver descriptor table address, channel 1 (DMARXDESC)
+ * @defgroup RTEMSDeviceGRSPW2ISRTIMER \
+ *   Interrupt distribution ISR timer reload (ISRTIMER)
-#define GRSPW2_DMARXDESC_DESCBASEADDR_SHIFT 10
-#define GRSPW2_DMARXDESC_DESCBASEADDR_MASK 0xfffffc00U
-#define GRSPW2_DMARXDESC_DESCBASEADDR_GET( _reg ) \
-  ( ( ( _reg ) & GRSPW2_DMARXDESC_DESCBASEADDR_MASK ) >> \
-    GRSPW2_DMARXDESC_DESCBASEADDR_SHIFT )
-#define GRSPW2_DMARXDESC_DESCBASEADDR_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~GRSPW2_DMARXDESC_DESCBASEADDR_MASK ) | \
-    ( ( ( _val ) << GRSPW2_DMARXDESC_DESCBASEADDR_SHIFT ) & \
-      GRSPW2_DMARXDESC_DESCBASEADDR_MASK ) )
-#define GRSPW2_DMARXDESC_DESCBASEADDR( _val ) \
+#define GRSPW2_ISRTIMER_EN 0x80000000U
+#define GRSPW2_ISRTIMER_RL_SHIFT 0
+#define GRSPW2_ISRTIMER_RL_MASK 0x7fffffffU
+#define GRSPW2_ISRTIMER_RL_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_ISRTIMER_RL_MASK ) >> \
+    GRSPW2_ISRTIMER_RL_SHIFT )
+#define GRSPW2_ISRTIMER_RL_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_ISRTIMER_RL_MASK ) | \
+    ( ( ( _val ) << GRSPW2_ISRTIMER_RL_SHIFT ) & \
+      GRSPW2_ISRTIMER_RL_MASK ) )
+#define GRSPW2_ISRTIMER_RL( _val ) \
-#define GRSPW2_DMARXDESC_DESCSEL_SHIFT 3
-#define GRSPW2_DMARXDESC_DESCSEL_MASK 0x3f8U
-#define GRSPW2_DMARXDESC_DESCSEL_GET( _reg ) \
-  ( ( ( _reg ) & GRSPW2_DMARXDESC_DESCSEL_MASK ) >> \
-    GRSPW2_DMARXDESC_DESCSEL_SHIFT )
-#define GRSPW2_DMARXDESC_DESCSEL_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~GRSPW2_DMARXDESC_DESCSEL_MASK ) | \
-    ( ( ( _val ) << GRSPW2_DMARXDESC_DESCSEL_SHIFT ) & \
-      GRSPW2_DMARXDESC_DESCSEL_MASK ) )
-#define GRSPW2_DMARXDESC_DESCSEL( _val ) \
+ * @defgroup RTEMSDeviceGRSPW2IATIMER \
+ *   Interrupt distribution INT / ACK timer reload (IATIMER)
+#define GRSPW2_IATIMER_EN 0x80000000U
+#define GRSPW2_IATIMER_RL_SHIFT 0
+#define GRSPW2_IATIMER_RL_MASK 0x7fffffffU
+#define GRSPW2_IATIMER_RL_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_IATIMER_RL_MASK ) >> \
+    GRSPW2_IATIMER_RL_SHIFT )
+#define GRSPW2_IATIMER_RL_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_IATIMER_RL_MASK ) | \
+    ( ( ( _val ) << GRSPW2_IATIMER_RL_SHIFT ) & \
+      GRSPW2_IATIMER_RL_MASK ) )
+#define GRSPW2_IATIMER_RL( _val ) \
- * @defgroup RTEMSDeviceGRSPW2DMAADDR DMA address, channel 1 (DMAADDR)
+ * @defgroup RTEMSDeviceGRSPW2ICTIMER \
+ *   Interrupt distribution change timer reload (ICTIMER)
-#define GRSPW2_DMAADDR_MASK_SHIFT 8
-#define GRSPW2_DMAADDR_MASK_MASK 0xff00U
-#define GRSPW2_DMAADDR_MASK_GET( _reg ) \
-  ( ( ( _reg ) & GRSPW2_DMAADDR_MASK_MASK ) >> \
-    GRSPW2_DMAADDR_MASK_SHIFT )
-#define GRSPW2_DMAADDR_MASK_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~GRSPW2_DMAADDR_MASK_MASK ) | \
-    ( ( ( _val ) << GRSPW2_DMAADDR_MASK_SHIFT ) & \
-      GRSPW2_DMAADDR_MASK_MASK ) )
-#define GRSPW2_DMAADDR_MASK( _val ) \
+#define GRSPW2_ICTIMER_EN 0x80000000U
+#define GRSPW2_ICTIMER_RL_SHIFT 0
+#define GRSPW2_ICTIMER_RL_MASK 0x7fffffffU
+#define GRSPW2_ICTIMER_RL_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_ICTIMER_RL_MASK ) >> \
+    GRSPW2_ICTIMER_RL_SHIFT )
+#define GRSPW2_ICTIMER_RL_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_ICTIMER_RL_MASK ) | \
+    ( ( ( _val ) << GRSPW2_ICTIMER_RL_SHIFT ) & \
+      GRSPW2_ICTIMER_RL_MASK ) )
+#define GRSPW2_ICTIMER_RL( _val ) \
-#define GRSPW2_DMAADDR_ADDR_SHIFT 0
-#define GRSPW2_DMAADDR_ADDR_MASK 0xffU
-#define GRSPW2_DMAADDR_ADDR_GET( _reg ) \
-  ( ( ( _reg ) & GRSPW2_DMAADDR_ADDR_MASK ) >> \
-    GRSPW2_DMAADDR_ADDR_SHIFT )
-#define GRSPW2_DMAADDR_ADDR_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~GRSPW2_DMAADDR_ADDR_MASK ) | \
-    ( ( ( _val ) << GRSPW2_DMAADDR_ADDR_SHIFT ) & \
-      GRSPW2_DMAADDR_ADDR_MASK ) )
-#define GRSPW2_DMAADDR_ADDR( _val ) \
+ * @defgroup RTEMSDeviceGRSPW2PNPVEND \
+ *   SpaceWire Plug-and-Play - Device Vendor and Product ID (PNPVEND)
+#define GRSPW2_PNPVEND_VEND_SHIFT 16
+#define GRSPW2_PNPVEND_VEND_MASK 0xffff0000U
+#define GRSPW2_PNPVEND_VEND_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_PNPVEND_VEND_MASK ) >> \
+    GRSPW2_PNPVEND_VEND_SHIFT )
+#define GRSPW2_PNPVEND_VEND_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_PNPVEND_VEND_MASK ) | \
+    ( ( ( _val ) << GRSPW2_PNPVEND_VEND_SHIFT ) & \
+      GRSPW2_PNPVEND_VEND_MASK ) )
+#define GRSPW2_PNPVEND_VEND( _val ) \
+#define GRSPW2_PNPVEND_PROD_SHIFT 0
+#define GRSPW2_PNPVEND_PROD_MASK 0xffffU
+#define GRSPW2_PNPVEND_PROD_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_PNPVEND_PROD_MASK ) >> \
+    GRSPW2_PNPVEND_PROD_SHIFT )
+#define GRSPW2_PNPVEND_PROD_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_PNPVEND_PROD_MASK ) | \
+    ( ( ( _val ) << GRSPW2_PNPVEND_PROD_SHIFT ) & \
+      GRSPW2_PNPVEND_PROD_MASK ) )
+#define GRSPW2_PNPVEND_PROD( _val ) \
+ * @defgroup RTEMSDeviceGRSPW2PNPOA0 \
+ *   SpaceWire Plug-and-Play - Owner Address 0 (PNPOA0)
+#define GRSPW2_PNPOA0_RA_SHIFT 0
+#define GRSPW2_PNPOA0_RA_MASK 0xffffffffU
+#define GRSPW2_PNPOA0_RA_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_PNPOA0_RA_MASK ) >> \
+    GRSPW2_PNPOA0_RA_SHIFT )
+#define GRSPW2_PNPOA0_RA_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_PNPOA0_RA_MASK ) | \
+    ( ( ( _val ) << GRSPW2_PNPOA0_RA_SHIFT ) & \
+      GRSPW2_PNPOA0_RA_MASK ) )
+#define GRSPW2_PNPOA0_RA( _val ) \
+ * @defgroup RTEMSDeviceGRSPW2PNPOA1 \
+ *   SpaceWire Plug-and-Play - Owner Address 1 (PNPOA1)
+#define GRSPW2_PNPOA1_RA_SHIFT 0
+#define GRSPW2_PNPOA1_RA_MASK 0xffffffffU
+#define GRSPW2_PNPOA1_RA_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_PNPOA1_RA_MASK ) >> \
+    GRSPW2_PNPOA1_RA_SHIFT )
+#define GRSPW2_PNPOA1_RA_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_PNPOA1_RA_MASK ) | \
+    ( ( ( _val ) << GRSPW2_PNPOA1_RA_SHIFT ) & \
+      GRSPW2_PNPOA1_RA_MASK ) )
+#define GRSPW2_PNPOA1_RA( _val ) \
+ * @defgroup RTEMSDeviceGRSPW2PNPOA2 \
+ *   SpaceWire Plug-and-Play - Owner Address 2 (PNPOA2)
+#define GRSPW2_PNPOA2_RA_SHIFT 0
+#define GRSPW2_PNPOA2_RA_MASK 0xffffffffU
+#define GRSPW2_PNPOA2_RA_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_PNPOA2_RA_MASK ) >> \
+    GRSPW2_PNPOA2_RA_SHIFT )
+#define GRSPW2_PNPOA2_RA_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_PNPOA2_RA_MASK ) | \
+    ( ( ( _val ) << GRSPW2_PNPOA2_RA_SHIFT ) & \
+      GRSPW2_PNPOA2_RA_MASK ) )
+#define GRSPW2_PNPOA2_RA( _val ) \
+ * @defgroup RTEMSDeviceGRSPW2PNPDEVID \
+ *   SpaceWire Plug-and-Play - Device ID (PNPDEVID)
+#define GRSPW2_PNPDEVID_DID_SHIFT 0
+#define GRSPW2_PNPDEVID_DID_MASK 0xffffffffU
+#define GRSPW2_PNPDEVID_DID_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_PNPDEVID_DID_MASK ) >> \
+    GRSPW2_PNPDEVID_DID_SHIFT )
+#define GRSPW2_PNPDEVID_DID_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_PNPDEVID_DID_MASK ) | \
+    ( ( ( _val ) << GRSPW2_PNPDEVID_DID_SHIFT ) & \
+      GRSPW2_PNPDEVID_DID_MASK ) )
+#define GRSPW2_PNPDEVID_DID( _val ) \
+ * @defgroup RTEMSDeviceGRSPW2PNPUVEND \
+ *   SpaceWire Plug-and-Play - Unit Vendor and Product ID (PNPUVEND)
+#define GRSPW2_PNPUVEND_VEND_SHIFT 16
+#define GRSPW2_PNPUVEND_VEND_MASK 0xffff0000U
+#define GRSPW2_PNPUVEND_VEND_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_PNPUVEND_VEND_MASK ) >> \
+    GRSPW2_PNPUVEND_VEND_SHIFT )
+#define GRSPW2_PNPUVEND_VEND_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_PNPUVEND_VEND_MASK ) | \
+    ( ( ( _val ) << GRSPW2_PNPUVEND_VEND_SHIFT ) & \
+      GRSPW2_PNPUVEND_VEND_MASK ) )
+#define GRSPW2_PNPUVEND_VEND( _val ) \
+#define GRSPW2_PNPUVEND_PROD_SHIFT 0
+#define GRSPW2_PNPUVEND_PROD_MASK 0xffffU
+#define GRSPW2_PNPUVEND_PROD_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_PNPUVEND_PROD_MASK ) >> \
+    GRSPW2_PNPUVEND_PROD_SHIFT )
+#define GRSPW2_PNPUVEND_PROD_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_PNPUVEND_PROD_MASK ) | \
+    ( ( ( _val ) << GRSPW2_PNPUVEND_PROD_SHIFT ) & \
+      GRSPW2_PNPUVEND_PROD_MASK ) )
+#define GRSPW2_PNPUVEND_PROD( _val ) \
+ * @defgroup RTEMSDeviceGRSPW2PNPUSN \
+ *   SpaceWire Plug-and-Play - Unit Serial Number (PNPUSN)
+#define GRSPW2_PNPUSN_USN_SHIFT 0
+#define GRSPW2_PNPUSN_USN_MASK 0xffffffffU
+#define GRSPW2_PNPUSN_USN_GET( _reg ) \
+  ( ( ( _reg ) & GRSPW2_PNPUSN_USN_MASK ) >> \
+    GRSPW2_PNPUSN_USN_SHIFT )
+#define GRSPW2_PNPUSN_USN_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPW2_PNPUSN_USN_MASK ) | \
+    ( ( ( _val ) << GRSPW2_PNPUSN_USN_SHIFT ) & \
+      GRSPW2_PNPUSN_USN_MASK ) )
+#define GRSPW2_PNPUSN_USN( _val ) \
@@ -553,29 +1307,117 @@ typedef struct grspw2 {
   uint32_t reserved_18_20[ 2 ];
-   * @brief See @ref RTEMSDeviceGRSPW2DMACTRL.
+   * @brief See @ref RTEMSDeviceGRSPW2DMA.
-  uint32_t dmactrl;
+  grspw2_dma dma[ 4 ];
-   * @brief See @ref RTEMSDeviceGRSPW2DMAMAXLEN.
+   * @brief See @ref RTEMSDeviceGRSPW2INTCTRL.
-  uint32_t dmamaxlen;
+  uint32_t intctrl;
-   * @brief See @ref RTEMSDeviceGRSPW2DMATXDESC.
+   * @brief See @ref RTEMSDeviceGRSPW2INTRX.
-  uint32_t dmatxdesc;
+  uint32_t intrx;
+  uint32_t reserved_a8_ac;
-   * @brief See @ref RTEMSDeviceGRSPW2DMARXDESC.
+   * @brief See @ref RTEMSDeviceGRSPW2INTTO.
-  uint32_t dmarxdesc;
+  uint32_t intto;
-   * @brief See @ref RTEMSDeviceGRSPW2DMAADDR.
+   * @brief See @ref RTEMSDeviceGRSPW2INTTOEXT.
-  uint32_t dmaaddr;
+  uint32_t inttoext;
+   * @brief See @ref RTEMSDeviceGRSPW2TICKMASK.
+  uint32_t tickmask;
+   * @brief See @ref RTEMSDeviceGRSPW2AUTOACKTICKMASKEXT.
+  uint32_t autoack_tickmaskext;
+   * @brief See @ref RTEMSDeviceGRSPW2INTCFG.
+  uint32_t intcfg;
+  uint32_t reserved_c0_c4;
+   * @brief See @ref RTEMSDeviceGRSPW2ISR.
+  uint32_t isr;
+   * @brief See @ref RTEMSDeviceGRSPW2ISREXT.
+  uint32_t isrext;
+  uint32_t reserved_cc_d0;
+   * @brief See @ref RTEMSDeviceGRSPW2PRESCALER.
+  uint32_t prescaler;
+   * @brief See @ref RTEMSDeviceGRSPW2ISRTIMER.
+  uint32_t isrtimer;
+   * @brief See @ref RTEMSDeviceGRSPW2IATIMER.
+  uint32_t iatimer;
+   * @brief See @ref RTEMSDeviceGRSPW2ICTIMER.
+  uint32_t ictimer;
+   * @brief See @ref RTEMSDeviceGRSPW2PNPVEND.
+  uint32_t pnpvend;
+  uint32_t reserved_e4_e8;
+   * @brief See @ref RTEMSDeviceGRSPW2PNPOA0.
+  uint32_t pnpoa0;
+   * @brief See @ref RTEMSDeviceGRSPW2PNPOA1.
+  uint32_t pnpoa1;
+   * @brief See @ref RTEMSDeviceGRSPW2PNPOA2.
+  uint32_t pnpoa2;
+   * @brief See @ref RTEMSDeviceGRSPW2PNPDEVID.
+  uint32_t pnpdevid;
+   * @brief See @ref RTEMSDeviceGRSPW2PNPUVEND.
+  uint32_t pnpuvend;
+   * @brief See @ref RTEMSDeviceGRSPW2PNPUSN.
+  uint32_t pnpusn;
 } grspw2;
2.35.3
