[PATCH v3 14/38] bsp/leon3: Untangle interrupt controller support
Wed Jul 12 13:49:53 UTC 2023
Separate the probing of the interrupt controller from the
initialization.
 bsps/sparc/leon3/include/bsp/irqimpl.h | 83 ++++++++++++++++++++++++++
 bsps/sparc/leon3/include/leon.h        | 10 +---
 bsps/sparc/leon3/start/amba.c          |  9 ---
 bsps/sparc/leon3/start/eirq.c          | 15 ++++-
 spec/build/bsps/sparc/leon3/obj.yml    |  1 +
 5 files changed, 97 insertions(+), 21 deletions(-)
 create mode 100644 bsps/sparc/leon3/include/bsp/irqimpl.h
diff --git a/bsps/sparc/leon3/include/bsp/irqimpl.h b/bsps/sparc/leon3/include/bsp/irqimpl.h
new file mode 100644
index 0000000000..77619c99b9
--- /dev/null
+++ b/bsps/sparc/leon3/include/bsp/irqimpl.h
@@ -0,0 +1,83 @@
+ * @file
+ * @ingroup RTEMSBSPsSPARCLEON3
+ * @brief This header file provides interfaces used by the interrupt support
+ *   implementation.
+ * Copyright (C) 2021 embedded brains GmbH & Co. KG
+ * are met:
+#ifndef LIBBSP_SPARC_LEON3_BSP_IRQIMPL_H
+#define LIBBSP_SPARC_LEON3_BSP_IRQIMPL_H
+#include <rtems.h>
+#include <grlib/grlib.h>
+struct ambapp_dev;
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @addtogroup RTEMSBSPsSPARCLEON3
+ * @brief This lock serializes the interrupt controller access.
+extern rtems_interrupt_lock LEON3_IrqCtrl_Lock;
+ * @brief This pointer provides the IRQ(A)MP register block address.
+extern volatile struct irqmp_regs *LEON3_IrqCtrl_Regs;
+ * @brief This pointer provides the IRQ(A)MP device information block.
+extern struct ambapp_dev *LEON3_IrqCtrl_Adev;
+ * @brief Initializes the interrupt controller for the boot processor.
+ * @param[in, out] regs is the IRQ(A)MP register block address.
+void leon3_ext_irq_init( volatile struct irqmp_regs *regs );
+#ifdef __cplusplus
+#endif
+#endif /* LIBBSP_SPARC_LEON3_BSP_IRQIMPL_H */
diff --git a/bsps/sparc/leon3/include/leon.h b/bsps/sparc/leon3/include/leon.h
index 6294feb8a7..0382e1b7e3 100644
--- a/bsps/sparc/leon3/include/leon.h
+++ b/bsps/sparc/leon3/include/leon.h
@@ -44,6 +44,7 @@
 #include <amba.h>
+#include <bsp/irqimpl.h>
 #ifdef __cplusplus
 extern "C" {
@@ -146,10 +147,6 @@ extern "C" {
 #define LEON3_REG_CACHE_CTRL_FI      0x00200000 /* Flush instruction cache */
 #define LEON3_REG_CACHE_CTRL_DS      0x00800000 /* Data cache snooping */
-/* LEON3 Interrupt Controller */
-extern volatile struct irqmp_regs *LEON3_IrqCtrl_Regs;
-extern struct ambapp_dev *LEON3_IrqCtrl_Adev;
 /* LEON3 GP Timer */
 extern volatile struct gptimer_regs *LEON3_Timer_Regs;
 extern struct ambapp_dev *LEON3_Timer_Adev;
@@ -193,8 +190,6 @@ static __inline__ int bsp_irq_fixup(int irq)
  *        store the result back are vulnerable.
-extern rtems_interrupt_lock LEON3_IrqCtrl_Lock;
 #define LEON3_IRQCTRL_ACQUIRE( _lock_context ) \
   rtems_interrupt_lock_acquire( &LEON3_IrqCtrl_Lock, _lock_context )
@@ -410,9 +405,6 @@ extern int leon3_timer_core_index;
 extern unsigned int leon3_timer_prescaler;
-/* GRLIB extended IRQ controller register */
-void leon3_ext_irq_init(void);
 RTEMS_NO_RETURN void leon3_power_down_loop(void);
 static inline uint32_t leon3_get_cpu_count(
diff --git a/bsps/sparc/leon3/start/amba.c b/bsps/sparc/leon3/start/amba.c
index 15b72dcbe8..5ce3de6bdd 100644
--- a/bsps/sparc/leon3/start/amba.c
+++ b/bsps/sparc/leon3/start/amba.c
@@ -115,9 +115,6 @@ RTEMS_SYSINIT_ITEM(
 #endif
-rtems_interrupt_lock LEON3_IrqCtrl_Lock =
-  RTEMS_INTERRUPT_LOCK_INITIALIZER("LEON3 IrqCtrl");
 /* Pointers to Interrupt Controller configuration registers */
@@ -166,12 +163,6 @@ static void amba_initialize(void)
     icsel = (icsel >> ((7 - (LEON3_Cpu_Index & 0x7)) * 4)) & 0xf;
     LEON3_IrqCtrl_Regs += icsel;
-  LEON3_IrqCtrl_Regs->mask[LEON3_Cpu_Index] = 0;
-  LEON3_IrqCtrl_Regs->force[LEON3_Cpu_Index] = 0;
-  LEON3_IrqCtrl_Regs->iclear = 0xffffffff;
-  /* Init Extended IRQ controller if available */
-  leon3_ext_irq_init();
   /* find GP Timer */
   adev = (void *)ambapp_for_each(plb, (OPTIONS_ALL|OPTIONS_APB_SLVS),
diff --git a/bsps/sparc/leon3/start/eirq.c b/bsps/sparc/leon3/start/eirq.c
index d8ff6d2a82..0371cfe98f 100644
--- a/bsps/sparc/leon3/start/eirq.c
+++ b/bsps/sparc/leon3/start/eirq.c
@@ -38,12 +38,19 @@
 /* GRLIB extended IRQ controller IRQ number */
 int LEON3_IrqCtrl_EIrq = -1;
+rtems_interrupt_lock LEON3_IrqCtrl_Lock =
+  RTEMS_INTERRUPT_LOCK_INITIALIZER("LEON3 IrqCtrl");
 /* Initialize Extended Interrupt controller */
+void leon3_ext_irq_init(volatile struct irqmp_regs *regs)
-  if ( (LEON3_IrqCtrl_Regs->mpstat >> 16) & 0xf ) {
+  regs->mask[LEON3_Cpu_Index] = 0;
+  regs->force[LEON3_Cpu_Index] = 0;
+  regs->iclear = 0xffffffff;
+  if ( (regs->mpstat >> 16) & 0xf ) {
     /* Extended IRQ controller available */
-    LEON3_IrqCtrl_EIrq = (LEON3_IrqCtrl_Regs->mpstat >> 16) & 0xf;
+    LEON3_IrqCtrl_EIrq = (regs->mpstat >> 16) & 0xf;
@@ -76,6 +83,8 @@ void bsp_interrupt_facility_initialize(void)
     leon3_interrupt_affinities[i] = affinity;
 #endif
+  leon3_ext_irq_init(LEON3_IrqCtrl_Regs);
 rtems_status_code bsp_interrupt_get_attributes(
diff --git a/spec/build/bsps/sparc/leon3/obj.yml b/spec/build/bsps/sparc/leon3/obj.yml
index 4d8394e111..2a793d21e7 100644
--- a/spec/build/bsps/sparc/leon3/obj.yml
+++ b/spec/build/bsps/sparc/leon3/obj.yml
@@ -16,6 +16,7 @@ install:
 - destination: ${BSP_INCLUDEDIR}/bsp
   source:
   - bsps/sparc/leon3/include/bsp/irq.h
+  - bsps/sparc/leon3/include/bsp/irqimpl.h
   - bsps/sparc/leon3/include/bsp/watchdog.h
 - destination: ${BSP_LIBDIR}
   source:
2.35.3
