[PATCH v3 19/38] bsp/leon3: Use new L2CACHE register block API
Wed Jul 12 13:49:58 UTC 2023
 bsps/sparc/leon3/start/cache.c | 38 ++++++++++++++++++++--------------
 1 file changed, 23 insertions(+), 15 deletions(-)
diff --git a/bsps/sparc/leon3/start/cache.c b/bsps/sparc/leon3/start/cache.c
index 676f591857..ed6fb5733d 100644
--- a/bsps/sparc/leon3/start/cache.c
+++ b/bsps/sparc/leon3/start/cache.c
@@ -6,9 +6,13 @@
  * http://www.rtems.org/license/LICENSE.
-#include <amba.h>
+#include <grlib/l2cache-regs.h>
+#include <grlib/io.h>
 #include <bsp/leon3.h>
+#include <grlib/ambapp.h>
 #define CPU_CACHE_SUPPORT_PROVIDES_RANGE_FUNCTIONS
 #define CPU_CACHE_SUPPORT_PROVIDES_CACHE_SIZE_FUNCTIONS
@@ -19,12 +23,11 @@
 #define CPU_DATA_CACHE_ALIGNMENT 64
-static inline volatile struct l2c_regs *get_l2c_regs(void)
+static inline l2cache *get_l2c_regs(void)
-  volatile struct l2c_regs *l2c = NULL;
   struct ambapp_dev *adev;
-  adev = (void *) ambapp_for_each(
+  adev = (struct ambapp_dev *) ambapp_for_each(
     ambapp_plb(),
     OPTIONS_ALL | OPTIONS_AHB_SLVS,
     VENDOR_GAISLER,
@@ -32,27 +35,32 @@ static inline volatile struct l2c_regs *get_l2c_regs(void)
     ambapp_find_by_idx,
     NULL
-  if (adev != NULL) {
-    l2c = (volatile struct l2c_regs *) DEV_TO_AHB(adev)->start[1];
+  if (adev == NULL) {
+    return NULL;
-  return l2c;
+  return (l2cache *) DEV_TO_AHB(adev)->start[1];
 static inline size_t get_l2_size(void)
-  size_t size = 0;
-  volatile struct l2c_regs *l2c = get_l2c_regs();
+  l2cache *regs;
+  unsigned status;
+  unsigned ways;
+  unsigned set_size;
-  if (l2c != NULL) {
-    unsigned status = l2c->status;
-    unsigned ways = (status & 0x3) + 1;
-    unsigned set_size = ((status & 0x7ff) >> 2) * 1024;
+  regs = get_l2c_regs();
-    size = ways * set_size;
+  if (regs == NULL) {
+    return 0;
-  return size;
+  status = grlib_load_32(&regs->l2cs);
+  ways = L2CACHE_L2CS_WAY_GET(status) + 1;
+  set_size = L2CACHE_L2CS_WAY_SIZE_GET(status) * 1024;
+  return ways * set_size;
 static inline size_t get_l1_size(uint32_t l1_cfg)
2.35.3
