[PATCH v3 12/38] bsps/grlib: Use GRLIB definition of GRSPWROUTER
Wed Jul 12 13:49:51 UTC 2023
Rename parts to match with GRLIB naming.
Update #4842.
 bsps/include/grlib/grspwrouter-regs.h | 1925 +++++++++++++++++++++++++
 bsps/include/grlib/spwrmap-regs.h     | 1443 ------------------
 2 files changed, 1925 insertions(+), 1443 deletions(-)
 create mode 100644 bsps/include/grlib/grspwrouter-regs.h
 delete mode 100644 bsps/include/grlib/spwrmap-regs.h
diff --git a/bsps/include/grlib/grspwrouter-regs.h b/bsps/include/grlib/grspwrouter-regs.h
new file mode 100644
index 0000000000..e688f34434
--- /dev/null
+++ b/bsps/include/grlib/grspwrouter-regs.h
@@ -0,0 +1,1925 @@
+ * @file
+ * @ingroup RTEMSDeviceGRSPWROUTER
+ * @brief This header file defines the GRSPWROUTER register block interface.
+ * Copyright (C) 2021, 2023 embedded brains GmbH & Co. KG
+ * are met:
+ * This file is part of the RTEMS quality process and was automatically
+ * generated.  If you find something that needs to be fixed or
+ * worded better please post a report or patch to an RTEMS mailing list
+ * or raise a bug report:
+ * https://www.rtems.org/bugs.html
+ * For information on updating and regenerating please refer to the How-To
+ * section in the Software Requirements Engineering chapter of the
+ * RTEMS Software Engineering manual.  The manual is provided as a part of
+ * a release.  For development sources please refer to the online
+ * documentation at:
+ * https://docs.rtems.org
+/* Generated from spec:/dev/grlib/if/grspwrouter-header */
+#ifndef _GRLIB_GRSPWROUTER_REGS_H
+#define _GRLIB_GRSPWROUTER_REGS_H
+#include <stdint.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+/* Generated from spec:/dev/grlib/if/grspwrouter-portstats */
+ * @defgroup RTEMSDeviceGRSPWRouterPortStats SpaceWire Router Port Statistics
+ * @brief This group contains the SpaceWire Router Port Statistics interfaces.
+ * @defgroup RTEMSDeviceGRSPWRouterPortStatsOCHARCNT \
+ *   Outgoing character counter, ports > 0 (OCHARCNT)
+ * @brief This group contains register bit definitions.
+#define GRSPWROUTER_OCHARCNT_OR 0x80000000U
+#define GRSPWROUTER_OCHARCNT_CC_SHIFT 0
+#define GRSPWROUTER_OCHARCNT_CC_MASK 0x7fffffffU
+#define GRSPWROUTER_OCHARCNT_CC_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_OCHARCNT_CC_MASK ) >> \
+    GRSPWROUTER_OCHARCNT_CC_SHIFT )
+#define GRSPWROUTER_OCHARCNT_CC_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_OCHARCNT_CC_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_OCHARCNT_CC_SHIFT ) & \
+      GRSPWROUTER_OCHARCNT_CC_MASK ) )
+#define GRSPWROUTER_OCHARCNT_CC( _val ) \
+ * @defgroup RTEMSDeviceGRSPWRouterPortStatsICHARCNT \
+ *   Incoming character counter, ports > 0 (ICHARCNT)
+#define GRSPWROUTER_ICHARCNT_OR 0x80000000U
+#define GRSPWROUTER_ICHARCNT_CC_SHIFT 0
+#define GRSPWROUTER_ICHARCNT_CC_MASK 0x7fffffffU
+#define GRSPWROUTER_ICHARCNT_CC_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_ICHARCNT_CC_MASK ) >> \
+    GRSPWROUTER_ICHARCNT_CC_SHIFT )
+#define GRSPWROUTER_ICHARCNT_CC_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_ICHARCNT_CC_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_ICHARCNT_CC_SHIFT ) & \
+      GRSPWROUTER_ICHARCNT_CC_MASK ) )
+#define GRSPWROUTER_ICHARCNT_CC( _val ) \
+ * @defgroup RTEMSDeviceGRSPWRouterPortStatsOPKTCNT \
+ *   Outgoing packet counter, ports > 0 (OPKTCNT)
+#define GRSPWROUTER_OPKTCNT_OR 0x80000000U
+#define GRSPWROUTER_OPKTCNT_PC_SHIFT 0
+#define GRSPWROUTER_OPKTCNT_PC_MASK 0x7fffffffU
+#define GRSPWROUTER_OPKTCNT_PC_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_OPKTCNT_PC_MASK ) >> \
+    GRSPWROUTER_OPKTCNT_PC_SHIFT )
+#define GRSPWROUTER_OPKTCNT_PC_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_OPKTCNT_PC_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_OPKTCNT_PC_SHIFT ) & \
+      GRSPWROUTER_OPKTCNT_PC_MASK ) )
+#define GRSPWROUTER_OPKTCNT_PC( _val ) \
+ * @defgroup RTEMSDeviceGRSPWRouterPortStatsIPKTCNT \
+ *   Incoming packet counter, ports > 0 (IPKTCNT)
+#define GRSPWROUTER_IPKTCNT_OR 0x80000000U
+#define GRSPWROUTER_IPKTCNT_PC_SHIFT 0
+#define GRSPWROUTER_IPKTCNT_PC_MASK 0x7fffffffU
+#define GRSPWROUTER_IPKTCNT_PC_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_IPKTCNT_PC_MASK ) >> \
+    GRSPWROUTER_IPKTCNT_PC_SHIFT )
+#define GRSPWROUTER_IPKTCNT_PC_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_IPKTCNT_PC_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_IPKTCNT_PC_SHIFT ) & \
+      GRSPWROUTER_IPKTCNT_PC_MASK ) )
+#define GRSPWROUTER_IPKTCNT_PC( _val ) \
+ * @brief This structure defines the SpaceWire Router Port Statistics register
+ *   block memory map.
+typedef struct grspwrouter_portstats {
+   * @brief See @ref RTEMSDeviceGRSPWRouterPortStatsOCHARCNT.
+  uint32_t ocharcnt;
+   * @brief See @ref RTEMSDeviceGRSPWRouterPortStatsICHARCNT.
+  uint32_t icharcnt;
+   * @brief See @ref RTEMSDeviceGRSPWRouterPortStatsOPKTCNT.
+  uint32_t opktcnt;
+   * @brief See @ref RTEMSDeviceGRSPWRouterPortStatsIPKTCNT.
+  uint32_t ipktcnt;
+} grspwrouter_portstats;
+/* Generated from spec:/dev/grlib/if/grspwrouter */
+ * @defgroup RTEMSDeviceGRSPWROUTER SpaceWire Router
+ * @ingroup RTEMSDeviceGRLIB
+ * @brief This group contains the SpaceWire Router interfaces.
+ * @defgroup RTEMSDeviceGRSPWROUTERRTPMAP \
+ *   Routing table port mapping, addresses 1-31 and 32-255 (RTPMAP)
+#define GRSPWROUTER_RTPMAP_PE_SHIFT 1
+#define GRSPWROUTER_RTPMAP_PE_MASK 0xfffffffeU
+#define GRSPWROUTER_RTPMAP_PE_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_RTPMAP_PE_MASK ) >> \
+    GRSPWROUTER_RTPMAP_PE_SHIFT )
+#define GRSPWROUTER_RTPMAP_PE_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_RTPMAP_PE_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_RTPMAP_PE_SHIFT ) & \
+      GRSPWROUTER_RTPMAP_PE_MASK ) )
+#define GRSPWROUTER_RTPMAP_PE( _val ) \
+#define GRSPWROUTER_RTPMAP_PD 0x1U
+ * @defgroup RTEMSDeviceGRSPWROUTERRTACTRL \
+ *   Routing table address control, addresses 1-31 and 32-255 (RTACTRL)
+#define GRSPWROUTER_RTACTRL_SR 0x8U
+#define GRSPWROUTER_RTACTRL_EN 0x4U
+#define GRSPWROUTER_RTACTRL_PR 0x2U
+#define GRSPWROUTER_RTACTRL_HD 0x1U
+ * @defgroup RTEMSDeviceGRSPWROUTERPCTRLCFG \
+ *   Port control, port 0 (configuration port) (PCTRLCFG)
+#define GRSPWROUTER_PCTRLCFG_PL 0x20000U
+#define GRSPWROUTER_PCTRLCFG_TS 0x10000U
+#define GRSPWROUTER_PCTRLCFG_TR 0x200U
+ * @defgroup RTEMSDeviceGRSPWROUTERPCTRL Port control, ports > 0 (PCTRL)
+#define GRSPWROUTER_PCTRL_RD_SHIFT 24
+#define GRSPWROUTER_PCTRL_RD_MASK 0xff000000U
+#define GRSPWROUTER_PCTRL_RD_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_PCTRL_RD_MASK ) >> \
+    GRSPWROUTER_PCTRL_RD_SHIFT )
+#define GRSPWROUTER_PCTRL_RD_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_PCTRL_RD_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_PCTRL_RD_SHIFT ) & \
+      GRSPWROUTER_PCTRL_RD_MASK ) )
+#define GRSPWROUTER_PCTRL_RD( _val ) \
+#define GRSPWROUTER_PCTRL_RES_SHIFT 22
+#define GRSPWROUTER_PCTRL_RES_MASK 0xc00000U
+#define GRSPWROUTER_PCTRL_RES_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_PCTRL_RES_MASK ) >> \
+    GRSPWROUTER_PCTRL_RES_SHIFT )
+#define GRSPWROUTER_PCTRL_RES_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_PCTRL_RES_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_PCTRL_RES_SHIFT ) & \
+      GRSPWROUTER_PCTRL_RES_MASK ) )
+#define GRSPWROUTER_PCTRL_RES( _val ) \
+#define GRSPWROUTER_PCTRL_ST 0x200000U
+#define GRSPWROUTER_PCTRL_SR 0x100000U
+#define GRSPWROUTER_PCTRL_AD 0x80000U
+#define GRSPWROUTER_PCTRL_LR 0x40000U
+#define GRSPWROUTER_PCTRL_PL 0x20000U
+#define GRSPWROUTER_PCTRL_TS 0x10000U
+#define GRSPWROUTER_PCTRL_IC 0x8000U
+#define GRSPWROUTER_PCTRL_ET 0x4000U
+#define GRSPWROUTER_PCTRL_NF 0x2000U
+#define GRSPWROUTER_PCTRL_PS 0x1000U
+#define GRSPWROUTER_PCTRL_BE 0x800U
+#define GRSPWROUTER_PCTRL_DI 0x400U
+#define GRSPWROUTER_PCTRL_TR 0x200U
+#define GRSPWROUTER_PCTRL_PR 0x100U
+#define GRSPWROUTER_PCTRL_TF 0x80U
+#define GRSPWROUTER_PCTRL_RS 0x40U
+#define GRSPWROUTER_PCTRL_TE 0x20U
+#define GRSPWROUTER_PCTRL_R 0x10U
+#define GRSPWROUTER_PCTRL_CE 0x8U
+#define GRSPWROUTER_PCTRL_AS 0x4U
+#define GRSPWROUTER_PCTRL_LS 0x2U
+#define GRSPWROUTER_PCTRL_LD 0x1U
+ * @defgroup RTEMSDeviceGRSPWROUTERPSTSCFG \
+ *   Port status, port 0 (configuration port) (PSTSCFG)
+#define GRSPWROUTER_PSTSCFG_EO 0x80000000U
+#define GRSPWROUTER_PSTSCFG_EE 0x40000000U
+#define GRSPWROUTER_PSTSCFG_PL 0x20000000U
+#define GRSPWROUTER_PSTSCFG_TT 0x10000000U
+#define GRSPWROUTER_PSTSCFG_PT 0x8000000U
+#define GRSPWROUTER_PSTSCFG_HC 0x4000000U
+#define GRSPWROUTER_PSTSCFG_PI 0x2000000U
+#define GRSPWROUTER_PSTSCFG_CE 0x1000000U
+#define GRSPWROUTER_PSTSCFG_EC_SHIFT 20
+#define GRSPWROUTER_PSTSCFG_EC_MASK 0xf00000U
+#define GRSPWROUTER_PSTSCFG_EC_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_PSTSCFG_EC_MASK ) >> \
+    GRSPWROUTER_PSTSCFG_EC_SHIFT )
+#define GRSPWROUTER_PSTSCFG_EC_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_PSTSCFG_EC_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_PSTSCFG_EC_SHIFT ) & \
+      GRSPWROUTER_PSTSCFG_EC_MASK ) )
+#define GRSPWROUTER_PSTSCFG_EC( _val ) \
+#define GRSPWROUTER_PSTSCFG_R 0x80000U
+#define GRSPWROUTER_PSTSCFG_TS 0x40000U
+#define GRSPWROUTER_PSTSCFG_ME 0x20000U
+#define GRSPWROUTER_PSTSCFG_IP_SHIFT 7
+#define GRSPWROUTER_PSTSCFG_IP_MASK 0xf80U
+#define GRSPWROUTER_PSTSCFG_IP_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_PSTSCFG_IP_MASK ) >> \
+    GRSPWROUTER_PSTSCFG_IP_SHIFT )
+#define GRSPWROUTER_PSTSCFG_IP_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_PSTSCFG_IP_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_PSTSCFG_IP_SHIFT ) & \
+      GRSPWROUTER_PSTSCFG_IP_MASK ) )
+#define GRSPWROUTER_PSTSCFG_IP( _val ) \
+#define GRSPWROUTER_PSTSCFG_RES_SHIFT 5
+#define GRSPWROUTER_PSTSCFG_RES_MASK 0x60U
+#define GRSPWROUTER_PSTSCFG_RES_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_PSTSCFG_RES_MASK ) >> \
+    GRSPWROUTER_PSTSCFG_RES_SHIFT )
+#define GRSPWROUTER_PSTSCFG_RES_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_PSTSCFG_RES_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_PSTSCFG_RES_SHIFT ) & \
+      GRSPWROUTER_PSTSCFG_RES_MASK ) )
+#define GRSPWROUTER_PSTSCFG_RES( _val ) \
+#define GRSPWROUTER_PSTSCFG_CP 0x10U
+#define GRSPWROUTER_PSTSCFG_PC_SHIFT 0
+#define GRSPWROUTER_PSTSCFG_PC_MASK 0xfU
+#define GRSPWROUTER_PSTSCFG_PC_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_PSTSCFG_PC_MASK ) >> \
+    GRSPWROUTER_PSTSCFG_PC_SHIFT )
+#define GRSPWROUTER_PSTSCFG_PC_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_PSTSCFG_PC_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_PSTSCFG_PC_SHIFT ) & \
+      GRSPWROUTER_PSTSCFG_PC_MASK ) )
+#define GRSPWROUTER_PSTSCFG_PC( _val ) \
+ * @defgroup RTEMSDeviceGRSPWROUTERPSTS Port status, ports > 0 (PSTS)
+#define GRSPWROUTER_PSTS_PT_SHIFT 30
+#define GRSPWROUTER_PSTS_PT_MASK 0xc0000000U
+#define GRSPWROUTER_PSTS_PT_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_PSTS_PT_MASK ) >> \
+    GRSPWROUTER_PSTS_PT_SHIFT )
+#define GRSPWROUTER_PSTS_PT_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_PSTS_PT_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_PSTS_PT_SHIFT ) & \
+      GRSPWROUTER_PSTS_PT_MASK ) )
+#define GRSPWROUTER_PSTS_PT( _val ) \
+#define GRSPWROUTER_PSTS_PL 0x20000000U
+#define GRSPWROUTER_PSTS_TT 0x10000000U
+#define GRSPWROUTER_PSTS_RS 0x8000000U
+#define GRSPWROUTER_PSTS_SR 0x4000000U
+#define GRSPWROUTER_PSTS_LR 0x400000U
+#define GRSPWROUTER_PSTS_SP 0x200000U
+#define GRSPWROUTER_PSTS_AC 0x100000U
+#define GRSPWROUTER_PSTS_AP 0x80000U
+#define GRSPWROUTER_PSTS_TS 0x40000U
+#define GRSPWROUTER_PSTS_ME 0x20000U
+#define GRSPWROUTER_PSTS_TF 0x10000U
+#define GRSPWROUTER_PSTS_RE 0x8000U
+#define GRSPWROUTER_PSTS_LS_SHIFT 12
+#define GRSPWROUTER_PSTS_LS_MASK 0x7000U
+#define GRSPWROUTER_PSTS_LS_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_PSTS_LS_MASK ) >> \
+    GRSPWROUTER_PSTS_LS_SHIFT )
+#define GRSPWROUTER_PSTS_LS_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_PSTS_LS_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_PSTS_LS_SHIFT ) & \
+      GRSPWROUTER_PSTS_LS_MASK ) )
+#define GRSPWROUTER_PSTS_LS( _val ) \
+#define GRSPWROUTER_PSTS_IP_SHIFT 7
+#define GRSPWROUTER_PSTS_IP_MASK 0xf80U
+#define GRSPWROUTER_PSTS_IP_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_PSTS_IP_MASK ) >> \
+    GRSPWROUTER_PSTS_IP_SHIFT )
+#define GRSPWROUTER_PSTS_IP_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_PSTS_IP_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_PSTS_IP_SHIFT ) & \
+      GRSPWROUTER_PSTS_IP_MASK ) )
+#define GRSPWROUTER_PSTS_IP( _val ) \
+#define GRSPWROUTER_PSTS_PR 0x40U
+#define GRSPWROUTER_PSTS_PB 0x20U
+#define GRSPWROUTER_PSTS_IA 0x10U
+#define GRSPWROUTER_PSTS_CE 0x8U
+#define GRSPWROUTER_PSTS_ER 0x4U
+#define GRSPWROUTER_PSTS_DE 0x2U
+#define GRSPWROUTER_PSTS_PE 0x1U
+ * @defgroup RTEMSDeviceGRSPWROUTERPTIMER Port timer reload (PTIMER)
+#define GRSPWROUTER_PTIMER_RL_SHIFT 0
+#define GRSPWROUTER_PTIMER_RL_MASK 0x3ffU
+#define GRSPWROUTER_PTIMER_RL_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_PTIMER_RL_MASK ) >> \
+    GRSPWROUTER_PTIMER_RL_SHIFT )
+#define GRSPWROUTER_PTIMER_RL_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_PTIMER_RL_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_PTIMER_RL_SHIFT ) & \
+      GRSPWROUTER_PTIMER_RL_MASK ) )
+#define GRSPWROUTER_PTIMER_RL( _val ) \
+ * @defgroup RTEMSDeviceGRSPWROUTERPCTRL2CFG \
+ *   Port control 2, port 0 (configuration port) (PCTRL2CFG)
+#define GRSPWROUTER_PCTRL2CFG_SM_SHIFT 24
+#define GRSPWROUTER_PCTRL2CFG_SM_MASK 0xff000000U
+#define GRSPWROUTER_PCTRL2CFG_SM_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_PCTRL2CFG_SM_MASK ) >> \
+    GRSPWROUTER_PCTRL2CFG_SM_SHIFT )
+#define GRSPWROUTER_PCTRL2CFG_SM_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_PCTRL2CFG_SM_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_PCTRL2CFG_SM_SHIFT ) & \
+      GRSPWROUTER_PCTRL2CFG_SM_MASK ) )
+#define GRSPWROUTER_PCTRL2CFG_SM( _val ) \
+#define GRSPWROUTER_PCTRL2CFG_SV_SHIFT 16
+#define GRSPWROUTER_PCTRL2CFG_SV_MASK 0xff0000U
+#define GRSPWROUTER_PCTRL2CFG_SV_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_PCTRL2CFG_SV_MASK ) >> \
+    GRSPWROUTER_PCTRL2CFG_SV_SHIFT )
+#define GRSPWROUTER_PCTRL2CFG_SV_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_PCTRL2CFG_SV_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_PCTRL2CFG_SV_SHIFT ) & \
+      GRSPWROUTER_PCTRL2CFG_SV_MASK ) )
+#define GRSPWROUTER_PCTRL2CFG_SV( _val ) \
+#define GRSPWROUTER_PCTRL2CFG_OR 0x8000U
+ * @defgroup RTEMSDeviceGRSPWROUTERPCTRL2 Port control 2, ports > 0 (PCTRL2)
+#define GRSPWROUTER_PCTRL2_SM_SHIFT 24
+#define GRSPWROUTER_PCTRL2_SM_MASK 0xff000000U
+#define GRSPWROUTER_PCTRL2_SM_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_PCTRL2_SM_MASK ) >> \
+    GRSPWROUTER_PCTRL2_SM_SHIFT )
+#define GRSPWROUTER_PCTRL2_SM_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_PCTRL2_SM_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_PCTRL2_SM_SHIFT ) & \
+      GRSPWROUTER_PCTRL2_SM_MASK ) )
+#define GRSPWROUTER_PCTRL2_SM( _val ) \
+#define GRSPWROUTER_PCTRL2_SV_SHIFT 16
+#define GRSPWROUTER_PCTRL2_SV_MASK 0xff0000U
+#define GRSPWROUTER_PCTRL2_SV_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_PCTRL2_SV_MASK ) >> \
+    GRSPWROUTER_PCTRL2_SV_SHIFT )
+#define GRSPWROUTER_PCTRL2_SV_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_PCTRL2_SV_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_PCTRL2_SV_SHIFT ) & \
+      GRSPWROUTER_PCTRL2_SV_MASK ) )
+#define GRSPWROUTER_PCTRL2_SV( _val ) \
+#define GRSPWROUTER_PCTRL2_OR 0x8000U
+#define GRSPWROUTER_PCTRL2_UR 0x4000U
+#define GRSPWROUTER_PCTRL2_R 0x2000U
+#define GRSPWROUTER_PCTRL2_AT 0x1000U
+#define GRSPWROUTER_PCTRL2_AR 0x800U
+#define GRSPWROUTER_PCTRL2_IT 0x400U
+#define GRSPWROUTER_PCTRL2_IR 0x200U
+#define GRSPWROUTER_PCTRL2_SD_SHIFT 1
+#define GRSPWROUTER_PCTRL2_SD_MASK 0x3eU
+#define GRSPWROUTER_PCTRL2_SD_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_PCTRL2_SD_MASK ) >> \
+    GRSPWROUTER_PCTRL2_SD_SHIFT )
+#define GRSPWROUTER_PCTRL2_SD_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_PCTRL2_SD_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_PCTRL2_SD_SHIFT ) & \
+      GRSPWROUTER_PCTRL2_SD_MASK ) )
+#define GRSPWROUTER_PCTRL2_SD( _val ) \
+#define GRSPWROUTER_PCTRL2_SC 0x1U
+ * @defgroup RTEMSDeviceGRSPWROUTERRTRCFG \
+ *   Router configuration / status (RTRCFG)
+#define GRSPWROUTER_RTRCFG_SP_SHIFT 27
+#define GRSPWROUTER_RTRCFG_SP_MASK 0xf8000000U
+#define GRSPWROUTER_RTRCFG_SP_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_RTRCFG_SP_MASK ) >> \
+    GRSPWROUTER_RTRCFG_SP_SHIFT )
+#define GRSPWROUTER_RTRCFG_SP_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_RTRCFG_SP_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_RTRCFG_SP_SHIFT ) & \
+      GRSPWROUTER_RTRCFG_SP_MASK ) )
+#define GRSPWROUTER_RTRCFG_SP( _val ) \
+#define GRSPWROUTER_RTRCFG_AP_SHIFT 22
+#define GRSPWROUTER_RTRCFG_AP_MASK 0x7c00000U
+#define GRSPWROUTER_RTRCFG_AP_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_RTRCFG_AP_MASK ) >> \
+    GRSPWROUTER_RTRCFG_AP_SHIFT )
+#define GRSPWROUTER_RTRCFG_AP_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_RTRCFG_AP_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_RTRCFG_AP_SHIFT ) & \
+      GRSPWROUTER_RTRCFG_AP_MASK ) )
+#define GRSPWROUTER_RTRCFG_AP( _val ) \
+#define GRSPWROUTER_RTRCFG_FP_SHIFT 17
+#define GRSPWROUTER_RTRCFG_FP_MASK 0x3e0000U
+#define GRSPWROUTER_RTRCFG_FP_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_RTRCFG_FP_MASK ) >> \
+    GRSPWROUTER_RTRCFG_FP_SHIFT )
+#define GRSPWROUTER_RTRCFG_FP_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_RTRCFG_FP_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_RTRCFG_FP_SHIFT ) & \
+      GRSPWROUTER_RTRCFG_FP_MASK ) )
+#define GRSPWROUTER_RTRCFG_FP( _val ) \
+#define GRSPWROUTER_RTRCFG_R 0x10000U
+#define GRSPWROUTER_RTRCFG_SR 0x8000U
+#define GRSPWROUTER_RTRCFG_PE 0x4000U
+#define GRSPWROUTER_RTRCFG_IC 0x2000U
+#define GRSPWROUTER_RTRCFG_IS 0x1000U
+#define GRSPWROUTER_RTRCFG_IP 0x800U
+#define GRSPWROUTER_RTRCFG_AI 0x400U
+#define GRSPWROUTER_RTRCFG_AT 0x200U
+#define GRSPWROUTER_RTRCFG_IE 0x100U
+#define GRSPWROUTER_RTRCFG_RE 0x80U
+#define GRSPWROUTER_RTRCFG_EE 0x40U
+#define GRSPWROUTER_RTRCFG_R 0x20U
+#define GRSPWROUTER_RTRCFG_SA 0x10U
+#define GRSPWROUTER_RTRCFG_TF 0x8U
+#define GRSPWROUTER_RTRCFG_RM 0x4U
+#define GRSPWROUTER_RTRCFG_TA 0x2U
+#define GRSPWROUTER_RTRCFG_PP 0x1U
+ * @defgroup RTEMSDeviceGRSPWROUTERTC Time-code (TC)
+#define GRSPWROUTER_TC_RE 0x200U
+#define GRSPWROUTER_TC_EN 0x100U
+#define GRSPWROUTER_TC_CF_SHIFT 6
+#define GRSPWROUTER_TC_CF_MASK 0xc0U
+#define GRSPWROUTER_TC_CF_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_TC_CF_MASK ) >> \
+    GRSPWROUTER_TC_CF_SHIFT )
+#define GRSPWROUTER_TC_CF_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_TC_CF_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_TC_CF_SHIFT ) & \
+      GRSPWROUTER_TC_CF_MASK ) )
+#define GRSPWROUTER_TC_CF( _val ) \
+#define GRSPWROUTER_TC_TC_SHIFT 0
+#define GRSPWROUTER_TC_TC_MASK 0x3fU
+#define GRSPWROUTER_TC_TC_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_TC_TC_MASK ) >> \
+    GRSPWROUTER_TC_TC_SHIFT )
+#define GRSPWROUTER_TC_TC_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_TC_TC_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_TC_TC_SHIFT ) & \
+      GRSPWROUTER_TC_TC_MASK ) )
+#define GRSPWROUTER_TC_TC( _val ) \
+ * @defgroup RTEMSDeviceGRSPWROUTERVER Version / instance ID (VER)
+#define GRSPWROUTER_VER_MA_SHIFT 24
+#define GRSPWROUTER_VER_MA_MASK 0xff000000U
+#define GRSPWROUTER_VER_MA_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_VER_MA_MASK ) >> \
+    GRSPWROUTER_VER_MA_SHIFT )
+#define GRSPWROUTER_VER_MA_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_VER_MA_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_VER_MA_SHIFT ) & \
+      GRSPWROUTER_VER_MA_MASK ) )
+#define GRSPWROUTER_VER_MA( _val ) \
+#define GRSPWROUTER_VER_MI_SHIFT 16
+#define GRSPWROUTER_VER_MI_MASK 0xff0000U
+#define GRSPWROUTER_VER_MI_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_VER_MI_MASK ) >> \
+    GRSPWROUTER_VER_MI_SHIFT )
+#define GRSPWROUTER_VER_MI_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_VER_MI_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_VER_MI_SHIFT ) & \
+      GRSPWROUTER_VER_MI_MASK ) )
+#define GRSPWROUTER_VER_MI( _val ) \
+#define GRSPWROUTER_VER_PA_SHIFT 8
+#define GRSPWROUTER_VER_PA_MASK 0xff00U
+#define GRSPWROUTER_VER_PA_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_VER_PA_MASK ) >> \
+    GRSPWROUTER_VER_PA_SHIFT )
+#define GRSPWROUTER_VER_PA_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_VER_PA_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_VER_PA_SHIFT ) & \
+      GRSPWROUTER_VER_PA_MASK ) )
+#define GRSPWROUTER_VER_PA( _val ) \
+#define GRSPWROUTER_VER_ID_SHIFT 0
+#define GRSPWROUTER_VER_ID_MASK 0xffU
+#define GRSPWROUTER_VER_ID_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_VER_ID_MASK ) >> \
+    GRSPWROUTER_VER_ID_SHIFT )
+#define GRSPWROUTER_VER_ID_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_VER_ID_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_VER_ID_SHIFT ) & \
+      GRSPWROUTER_VER_ID_MASK ) )
+#define GRSPWROUTER_VER_ID( _val ) \
+ * @defgroup RTEMSDeviceGRSPWROUTERIDIV Initialization divisor (IDIV)
+#define GRSPWROUTER_IDIV_ID_SHIFT 0
+#define GRSPWROUTER_IDIV_ID_MASK 0xffU
+#define GRSPWROUTER_IDIV_ID_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_IDIV_ID_MASK ) >> \
+    GRSPWROUTER_IDIV_ID_SHIFT )
+#define GRSPWROUTER_IDIV_ID_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_IDIV_ID_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_IDIV_ID_SHIFT ) & \
+      GRSPWROUTER_IDIV_ID_MASK ) )
+#define GRSPWROUTER_IDIV_ID( _val ) \
+ * @defgroup RTEMSDeviceGRSPWROUTERCFGWE \
+ *   Configuration port write enable (CFGWE)
+#define GRSPWROUTER_CFGWE_WE 0x1U
+ * @defgroup RTEMSDeviceGRSPWROUTERPRESCALER Timer prescaler reload (PRESCALER)
+#define GRSPWROUTER_PRESCALER_RL_SHIFT 0
+#define GRSPWROUTER_PRESCALER_RL_MASK 0xffffffffU
+#define GRSPWROUTER_PRESCALER_RL_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_PRESCALER_RL_MASK ) >> \
+    GRSPWROUTER_PRESCALER_RL_SHIFT )
+#define GRSPWROUTER_PRESCALER_RL_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_PRESCALER_RL_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_PRESCALER_RL_SHIFT ) & \
+      GRSPWROUTER_PRESCALER_RL_MASK ) )
+#define GRSPWROUTER_PRESCALER_RL( _val ) \
+ * @defgroup RTEMSDeviceGRSPWROUTERIMASK Interrupt mask (IMASK)
+#define GRSPWROUTER_IMASK_PE 0x400U
+#define GRSPWROUTER_IMASK_SR 0x200U
+#define GRSPWROUTER_IMASK_RS 0x100U
+#define GRSPWROUTER_IMASK_TT 0x80U
+#define GRSPWROUTER_IMASK_PL 0x40U
+#define GRSPWROUTER_IMASK_TS 0x20U
+#define GRSPWROUTER_IMASK_AC 0x10U
+#define GRSPWROUTER_IMASK_RE 0x8U
+#define GRSPWROUTER_IMASK_IA 0x4U
+#define GRSPWROUTER_IMASK_LE 0x2U
+#define GRSPWROUTER_IMASK_ME 0x1U
+ * @defgroup RTEMSDeviceGRSPWROUTERIPMASK Interrupt port mask (IPMASK)
+#define GRSPWROUTER_IPMASK_IE_SHIFT 0
+#define GRSPWROUTER_IPMASK_IE_MASK 0xffffffffU
+#define GRSPWROUTER_IPMASK_IE_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_IPMASK_IE_MASK ) >> \
+    GRSPWROUTER_IPMASK_IE_SHIFT )
+#define GRSPWROUTER_IPMASK_IE_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_IPMASK_IE_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_IPMASK_IE_SHIFT ) & \
+      GRSPWROUTER_IPMASK_IE_MASK ) )
+#define GRSPWROUTER_IPMASK_IE( _val ) \
+ * @defgroup RTEMSDeviceGRSPWROUTERPIP Port interrupt pending (PIP)
+#define GRSPWROUTER_PIP_IP_SHIFT 0
+#define GRSPWROUTER_PIP_IP_MASK 0xffffffffU
+#define GRSPWROUTER_PIP_IP_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_PIP_IP_MASK ) >> \
+    GRSPWROUTER_PIP_IP_SHIFT )
+#define GRSPWROUTER_PIP_IP_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_PIP_IP_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_PIP_IP_SHIFT ) & \
+      GRSPWROUTER_PIP_IP_MASK ) )
+#define GRSPWROUTER_PIP_IP( _val ) \
+ * @defgroup RTEMSDeviceGRSPWROUTERICODEGEN \
+ *   Interrupt code generation (ICODEGEN)
+#define GRSPWROUTER_ICODEGEN_HI 0x200000U
+#define GRSPWROUTER_ICODEGEN_UA 0x100000U
+#define GRSPWROUTER_ICODEGEN_AH 0x80000U
+#define GRSPWROUTER_ICODEGEN_IT 0x40000U
+#define GRSPWROUTER_ICODEGEN_TE 0x1U
+#define GRSPWROUTER_ICODEGEN_EN 0x20000U
+#define GRSPWROUTER_ICODEGEN_IN_SHIFT 6
+#define GRSPWROUTER_ICODEGEN_IN_MASK 0xffc0U
+#define GRSPWROUTER_ICODEGEN_IN_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_ICODEGEN_IN_MASK ) >> \
+    GRSPWROUTER_ICODEGEN_IN_SHIFT )
+#define GRSPWROUTER_ICODEGEN_IN_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_ICODEGEN_IN_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_ICODEGEN_IN_SHIFT ) & \
+      GRSPWROUTER_ICODEGEN_IN_MASK ) )
+#define GRSPWROUTER_ICODEGEN_IN( _val ) \
+ * @defgroup RTEMSDeviceGRSPWROUTERISR0 \
+ *   Interrupt code distribution ISR register, interrupt 0-31 (ISR0)
+#define GRSPWROUTER_ISR0_IB_SHIFT 0
+#define GRSPWROUTER_ISR0_IB_MASK 0xffffffffU
+#define GRSPWROUTER_ISR0_IB_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_ISR0_IB_MASK ) >> \
+    GRSPWROUTER_ISR0_IB_SHIFT )
+#define GRSPWROUTER_ISR0_IB_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_ISR0_IB_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_ISR0_IB_SHIFT ) & \
+      GRSPWROUTER_ISR0_IB_MASK ) )
+#define GRSPWROUTER_ISR0_IB( _val ) \
+ * @defgroup RTEMSDeviceGRSPWROUTERISR1 \
+ *   Interrupt code distribution ISR register, interrupt 32-63 (ISR1)
+#define GRSPWROUTER_ISR1_IB_SHIFT 0
+#define GRSPWROUTER_ISR1_IB_MASK 0xffffffffU
+#define GRSPWROUTER_ISR1_IB_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_ISR1_IB_MASK ) >> \
+    GRSPWROUTER_ISR1_IB_SHIFT )
+#define GRSPWROUTER_ISR1_IB_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_ISR1_IB_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_ISR1_IB_SHIFT ) & \
+      GRSPWROUTER_ISR1_IB_MASK ) )
+#define GRSPWROUTER_ISR1_IB( _val ) \
+ * @defgroup RTEMSDeviceGRSPWROUTERISRTIMER \
+ *   Interrupt code distribution ISR timer reload (ISRTIMER)
+#define GRSPWROUTER_ISRTIMER_RL_SHIFT 0
+#define GRSPWROUTER_ISRTIMER_RL_MASK 0xffffffffU
+#define GRSPWROUTER_ISRTIMER_RL_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_ISRTIMER_RL_MASK ) >> \
+    GRSPWROUTER_ISRTIMER_RL_SHIFT )
+#define GRSPWROUTER_ISRTIMER_RL_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_ISRTIMER_RL_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_ISRTIMER_RL_SHIFT ) & \
+      GRSPWROUTER_ISRTIMER_RL_MASK ) )
+#define GRSPWROUTER_ISRTIMER_RL( _val ) \
+ * @defgroup RTEMSDeviceGRSPWROUTERAITIMER \
+ *   Interrupt code distribution ACK-to-INT timer reload (AITIMER)
+#define GRSPWROUTER_AITIMER_RL_SHIFT 0
+#define GRSPWROUTER_AITIMER_RL_MASK 0xffffffffU
+#define GRSPWROUTER_AITIMER_RL_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_AITIMER_RL_MASK ) >> \
+    GRSPWROUTER_AITIMER_RL_SHIFT )
+#define GRSPWROUTER_AITIMER_RL_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_AITIMER_RL_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_AITIMER_RL_SHIFT ) & \
+      GRSPWROUTER_AITIMER_RL_MASK ) )
+#define GRSPWROUTER_AITIMER_RL( _val ) \
+ * @defgroup RTEMSDeviceGRSPWROUTERISRCTIMER \
+ *   Interrupt code distribution ISR change timer reload (ISRCTIMER)
+#define GRSPWROUTER_ISRCTIMER_RL_SHIFT 0
+#define GRSPWROUTER_ISRCTIMER_RL_MASK 0x1fU
+#define GRSPWROUTER_ISRCTIMER_RL_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_ISRCTIMER_RL_MASK ) >> \
+    GRSPWROUTER_ISRCTIMER_RL_SHIFT )
+#define GRSPWROUTER_ISRCTIMER_RL_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_ISRCTIMER_RL_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_ISRCTIMER_RL_SHIFT ) & \
+      GRSPWROUTER_ISRCTIMER_RL_MASK ) )
+#define GRSPWROUTER_ISRCTIMER_RL( _val ) \
+ * @defgroup RTEMSDeviceGRSPWROUTERLRUNSTAT Link running status (LRUNSTAT)
+#define GRSPWROUTER_LRUNSTAT_LR_SHIFT 1
+#define GRSPWROUTER_LRUNSTAT_LR_MASK 0xfffffffeU
+#define GRSPWROUTER_LRUNSTAT_LR_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_LRUNSTAT_LR_MASK ) >> \
+    GRSPWROUTER_LRUNSTAT_LR_SHIFT )
+#define GRSPWROUTER_LRUNSTAT_LR_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_LRUNSTAT_LR_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_LRUNSTAT_LR_SHIFT ) & \
+      GRSPWROUTER_LRUNSTAT_LR_MASK ) )
+#define GRSPWROUTER_LRUNSTAT_LR( _val ) \
+#define GRSPWROUTER_LRUNSTAT_R 0x1U
+ * @defgroup RTEMSDeviceGRSPWROUTERCAP Capability (CAP)
+#define GRSPWROUTER_CAP_AF_SHIFT 24
+#define GRSPWROUTER_CAP_AF_MASK 0x3000000U
+#define GRSPWROUTER_CAP_AF_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_CAP_AF_MASK ) >> \
+    GRSPWROUTER_CAP_AF_SHIFT )
+#define GRSPWROUTER_CAP_AF_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_CAP_AF_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_CAP_AF_SHIFT ) & \
+      GRSPWROUTER_CAP_AF_MASK ) )
+#define GRSPWROUTER_CAP_AF( _val ) \
+#define GRSPWROUTER_CAP_R 0x800000U
+#define GRSPWROUTER_CAP_PF_SHIFT 20
+#define GRSPWROUTER_CAP_PF_MASK 0x700000U
+#define GRSPWROUTER_CAP_PF_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_CAP_PF_MASK ) >> \
+    GRSPWROUTER_CAP_PF_SHIFT )
+#define GRSPWROUTER_CAP_PF_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_CAP_PF_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_CAP_PF_SHIFT ) & \
+      GRSPWROUTER_CAP_PF_MASK ) )
+#define GRSPWROUTER_CAP_PF( _val ) \
+#define GRSPWROUTER_CAP_R 0x80000U
+#define GRSPWROUTER_CAP_RM_SHIFT 16
+#define GRSPWROUTER_CAP_RM_MASK 0x70000U
+#define GRSPWROUTER_CAP_RM_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_CAP_RM_MASK ) >> \
+    GRSPWROUTER_CAP_RM_SHIFT )
+#define GRSPWROUTER_CAP_RM_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_CAP_RM_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_CAP_RM_SHIFT ) & \
+      GRSPWROUTER_CAP_RM_MASK ) )
+#define GRSPWROUTER_CAP_RM( _val ) \
+#define GRSPWROUTER_CAP_R 0x8000U
+#define GRSPWROUTER_CAP_AA 0x4000U
+#define GRSPWROUTER_CAP_AX 0x2000U
+#define GRSPWROUTER_CAP_DP 0x1000U
+#define GRSPWROUTER_CAP_ID 0x800U
+#define GRSPWROUTER_CAP_SD 0x400U
+#define GRSPWROUTER_CAP_PC_SHIFT 5
+#define GRSPWROUTER_CAP_PC_MASK 0x3e0U
+#define GRSPWROUTER_CAP_PC_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_CAP_PC_MASK ) >> \
+    GRSPWROUTER_CAP_PC_SHIFT )
+#define GRSPWROUTER_CAP_PC_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_CAP_PC_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_CAP_PC_SHIFT ) & \
+      GRSPWROUTER_CAP_PC_MASK ) )
+#define GRSPWROUTER_CAP_PC( _val ) \
+#define GRSPWROUTER_CAP_CC_SHIFT 0
+#define GRSPWROUTER_CAP_CC_MASK 0x1fU
+#define GRSPWROUTER_CAP_CC_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_CAP_CC_MASK ) >> \
+    GRSPWROUTER_CAP_CC_SHIFT )
+#define GRSPWROUTER_CAP_CC_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_CAP_CC_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_CAP_CC_SHIFT ) & \
+      GRSPWROUTER_CAP_CC_MASK ) )
+#define GRSPWROUTER_CAP_CC( _val ) \
+ * @defgroup RTEMSDeviceGRSPWROUTERPNPVEND \
+ *   SpaceWire Plug-and-Play - Device Vendor and Product ID (PNPVEND)
+#define GRSPWROUTER_PNPVEND_VI_SHIFT 16
+#define GRSPWROUTER_PNPVEND_VI_MASK 0xffff0000U
+#define GRSPWROUTER_PNPVEND_VI_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_PNPVEND_VI_MASK ) >> \
+    GRSPWROUTER_PNPVEND_VI_SHIFT )
+#define GRSPWROUTER_PNPVEND_VI_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_PNPVEND_VI_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_PNPVEND_VI_SHIFT ) & \
+      GRSPWROUTER_PNPVEND_VI_MASK ) )
+#define GRSPWROUTER_PNPVEND_VI( _val ) \
+#define GRSPWROUTER_PNPVEND_PI_SHIFT 0
+#define GRSPWROUTER_PNPVEND_PI_MASK 0x3ffffffU
+#define GRSPWROUTER_PNPVEND_PI_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_PNPVEND_PI_MASK ) >> \
+    GRSPWROUTER_PNPVEND_PI_SHIFT )
+#define GRSPWROUTER_PNPVEND_PI_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_PNPVEND_PI_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_PNPVEND_PI_SHIFT ) & \
+      GRSPWROUTER_PNPVEND_PI_MASK ) )
+#define GRSPWROUTER_PNPVEND_PI( _val ) \
+ * @defgroup RTEMSDeviceGRSPWROUTERPNPUVEND \
+ *   SpaceWire Plug-and-Play - Unit Vendor and Product ID (PNPUVEND)
+#define GRSPWROUTER_PNPUVEND_VI_SHIFT 16
+#define GRSPWROUTER_PNPUVEND_VI_MASK 0xffff0000U
+#define GRSPWROUTER_PNPUVEND_VI_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_PNPUVEND_VI_MASK ) >> \
+    GRSPWROUTER_PNPUVEND_VI_SHIFT )
+#define GRSPWROUTER_PNPUVEND_VI_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_PNPUVEND_VI_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_PNPUVEND_VI_SHIFT ) & \
+      GRSPWROUTER_PNPUVEND_VI_MASK ) )
+#define GRSPWROUTER_PNPUVEND_VI( _val ) \
+#define GRSPWROUTER_PNPUVEND_PI_SHIFT 0
+#define GRSPWROUTER_PNPUVEND_PI_MASK 0x3ffffffU
+#define GRSPWROUTER_PNPUVEND_PI_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_PNPUVEND_PI_MASK ) >> \
+    GRSPWROUTER_PNPUVEND_PI_SHIFT )
+#define GRSPWROUTER_PNPUVEND_PI_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_PNPUVEND_PI_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_PNPUVEND_PI_SHIFT ) & \
+      GRSPWROUTER_PNPUVEND_PI_MASK ) )
+#define GRSPWROUTER_PNPUVEND_PI( _val ) \
+ * @defgroup RTEMSDeviceGRSPWROUTERPNPUSN \
+ *   SpaceWire Plug-and-Play - Unit Serial Number (PNPUSN)
+#define GRSPWROUTER_PNPUSN_SN_SHIFT 0
+#define GRSPWROUTER_PNPUSN_SN_MASK 0xffffffffU
+#define GRSPWROUTER_PNPUSN_SN_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_PNPUSN_SN_MASK ) >> \
+    GRSPWROUTER_PNPUSN_SN_SHIFT )
+#define GRSPWROUTER_PNPUSN_SN_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_PNPUSN_SN_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_PNPUSN_SN_SHIFT ) & \
+      GRSPWROUTER_PNPUSN_SN_MASK ) )
+#define GRSPWROUTER_PNPUSN_SN( _val ) \
+ * @defgroup RTEMSDeviceGRSPWROUTERPNPNETDISC \
+ *   SpaceWire Plug-and-Play - Port network discovery enable (PNPNETDISC)
+#define GRSPWROUTER_PNPNETDISC_ND_SHIFT 0
+#define GRSPWROUTER_PNPNETDISC_ND_MASK 0xffffffffU
+#define GRSPWROUTER_PNPNETDISC_ND_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_PNPNETDISC_ND_MASK ) >> \
+    GRSPWROUTER_PNPNETDISC_ND_SHIFT )
+#define GRSPWROUTER_PNPNETDISC_ND_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_PNPNETDISC_ND_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_PNPNETDISC_ND_SHIFT ) & \
+      GRSPWROUTER_PNPNETDISC_ND_MASK ) )
+#define GRSPWROUTER_PNPNETDISC_ND( _val ) \
+ * @defgroup RTEMSDeviceGRSPWROUTERMAXPLEN \
+ *   Maximum packet length, ports > 0 (MAXPLEN)
+#define GRSPWROUTER_MAXPLEN_ML_SHIFT 0
+#define GRSPWROUTER_MAXPLEN_ML_MASK 0x1ffffffU
+#define GRSPWROUTER_MAXPLEN_ML_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_MAXPLEN_ML_MASK ) >> \
+    GRSPWROUTER_MAXPLEN_ML_SHIFT )
+#define GRSPWROUTER_MAXPLEN_ML_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_MAXPLEN_ML_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_MAXPLEN_ML_SHIFT ) & \
+      GRSPWROUTER_MAXPLEN_ML_MASK ) )
+#define GRSPWROUTER_MAXPLEN_ML( _val ) \
+ * @defgroup RTEMSDeviceGRSPWROUTERCREDCNT \
+ *   Credit counter, SpaceWire ports (CREDCNT)
+#define GRSPWROUTER_CREDCNT_OC_SHIFT 6
+#define GRSPWROUTER_CREDCNT_OC_MASK 0xfc0U
+#define GRSPWROUTER_CREDCNT_OC_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_CREDCNT_OC_MASK ) >> \
+    GRSPWROUTER_CREDCNT_OC_SHIFT )
+#define GRSPWROUTER_CREDCNT_OC_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_CREDCNT_OC_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_CREDCNT_OC_SHIFT ) & \
+      GRSPWROUTER_CREDCNT_OC_MASK ) )
+#define GRSPWROUTER_CREDCNT_OC( _val ) \
+#define GRSPWROUTER_CREDCNT_IC_SHIFT 0
+#define GRSPWROUTER_CREDCNT_IC_MASK 0x3fU
+#define GRSPWROUTER_CREDCNT_IC_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_CREDCNT_IC_MASK ) >> \
+    GRSPWROUTER_CREDCNT_IC_SHIFT )
+#define GRSPWROUTER_CREDCNT_IC_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_CREDCNT_IC_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_CREDCNT_IC_SHIFT ) & \
+      GRSPWROUTER_CREDCNT_IC_MASK ) )
+#define GRSPWROUTER_CREDCNT_IC( _val ) \
+ * @defgroup RTEMSDeviceGRSPWROUTERGPO0 General purpose out, bits 0-31 (GPO0)
+#define GRSPWROUTER_GPO0_GPO_SHIFT 0
+#define GRSPWROUTER_GPO0_GPO_MASK 0xffffffffU
+#define GRSPWROUTER_GPO0_GPO_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_GPO0_GPO_MASK ) >> \
+    GRSPWROUTER_GPO0_GPO_SHIFT )
+#define GRSPWROUTER_GPO0_GPO_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_GPO0_GPO_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_GPO0_GPO_SHIFT ) & \
+      GRSPWROUTER_GPO0_GPO_MASK ) )
+#define GRSPWROUTER_GPO0_GPO( _val ) \
+ * @defgroup RTEMSDeviceGRSPWROUTERGPO1 General purpose out, bits 32-63 (GPO1)
+#define GRSPWROUTER_GPO1_GPO_SHIFT 0
+#define GRSPWROUTER_GPO1_GPO_MASK 0xffffffffU
+#define GRSPWROUTER_GPO1_GPO_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_GPO1_GPO_MASK ) >> \
+    GRSPWROUTER_GPO1_GPO_SHIFT )
+#define GRSPWROUTER_GPO1_GPO_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_GPO1_GPO_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_GPO1_GPO_SHIFT ) & \
+      GRSPWROUTER_GPO1_GPO_MASK ) )
+#define GRSPWROUTER_GPO1_GPO( _val ) \
+ * @defgroup RTEMSDeviceGRSPWROUTERGPO2 General purpose out, bits 64-95 (GPO2)
+#define GRSPWROUTER_GPO2_GPO_SHIFT 0
+#define GRSPWROUTER_GPO2_GPO_MASK 0xffffffffU
+#define GRSPWROUTER_GPO2_GPO_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_GPO2_GPO_MASK ) >> \
+    GRSPWROUTER_GPO2_GPO_SHIFT )
+#define GRSPWROUTER_GPO2_GPO_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_GPO2_GPO_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_GPO2_GPO_SHIFT ) & \
+      GRSPWROUTER_GPO2_GPO_MASK ) )
+#define GRSPWROUTER_GPO2_GPO( _val ) \
+ * @defgroup RTEMSDeviceGRSPWROUTERGPO3 General purpose out, bits 96-127 (GPO3)
+#define GRSPWROUTER_GPO3_GPO_SHIFT 0
+#define GRSPWROUTER_GPO3_GPO_MASK 0xffffffffU
+#define GRSPWROUTER_GPO3_GPO_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_GPO3_GPO_MASK ) >> \
+    GRSPWROUTER_GPO3_GPO_SHIFT )
+#define GRSPWROUTER_GPO3_GPO_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_GPO3_GPO_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_GPO3_GPO_SHIFT ) & \
+      GRSPWROUTER_GPO3_GPO_MASK ) )
+#define GRSPWROUTER_GPO3_GPO( _val ) \
+ * @defgroup RTEMSDeviceGRSPWROUTERGPI0 General purpose in, bits 0-31 (GPI0)
+#define GRSPWROUTER_GPI0_GPI_SHIFT 0
+#define GRSPWROUTER_GPI0_GPI_MASK 0xffffffffU
+#define GRSPWROUTER_GPI0_GPI_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_GPI0_GPI_MASK ) >> \
+    GRSPWROUTER_GPI0_GPI_SHIFT )
+#define GRSPWROUTER_GPI0_GPI_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_GPI0_GPI_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_GPI0_GPI_SHIFT ) & \
+      GRSPWROUTER_GPI0_GPI_MASK ) )
+#define GRSPWROUTER_GPI0_GPI( _val ) \
+ * @defgroup RTEMSDeviceGRSPWROUTERGPI1 General purpose in, bits 32-63 (GPI1)
+#define GRSPWROUTER_GPI1_GPI_SHIFT 0
+#define GRSPWROUTER_GPI1_GPI_MASK 0xffffffffU
+#define GRSPWROUTER_GPI1_GPI_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_GPI1_GPI_MASK ) >> \
+    GRSPWROUTER_GPI1_GPI_SHIFT )
+#define GRSPWROUTER_GPI1_GPI_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_GPI1_GPI_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_GPI1_GPI_SHIFT ) & \
+      GRSPWROUTER_GPI1_GPI_MASK ) )
+#define GRSPWROUTER_GPI1_GPI( _val ) \
+ * @defgroup RTEMSDeviceGRSPWROUTERGPI2 General purpose in, bits 64-95 (GPI2)
+#define GRSPWROUTER_GPI2_GPI_SHIFT 0
+#define GRSPWROUTER_GPI2_GPI_MASK 0xffffffffU
+#define GRSPWROUTER_GPI2_GPI_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_GPI2_GPI_MASK ) >> \
+    GRSPWROUTER_GPI2_GPI_SHIFT )
+#define GRSPWROUTER_GPI2_GPI_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_GPI2_GPI_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_GPI2_GPI_SHIFT ) & \
+      GRSPWROUTER_GPI2_GPI_MASK ) )
+#define GRSPWROUTER_GPI2_GPI( _val ) \
+ * @defgroup RTEMSDeviceGRSPWROUTERGPI3 General purpose in, bits 64-127 (GPI3)
+#define GRSPWROUTER_GPI3_GPI_SHIFT 0
+#define GRSPWROUTER_GPI3_GPI_MASK 0xffffffffU
+#define GRSPWROUTER_GPI3_GPI_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_GPI3_GPI_MASK ) >> \
+    GRSPWROUTER_GPI3_GPI_SHIFT )
+#define GRSPWROUTER_GPI3_GPI_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_GPI3_GPI_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_GPI3_GPI_SHIFT ) & \
+      GRSPWROUTER_GPI3_GPI_MASK ) )
+#define GRSPWROUTER_GPI3_GPI( _val ) \
+ * @defgroup RTEMSDeviceGRSPWROUTERRTCOMB \
+ *   Routing table, combined port mapping and address control, addresses 1-255 (RTCOMB)
+#define GRSPWROUTER_RTCOMB_SR 0x80000000U
+#define GRSPWROUTER_RTCOMB_EN 0x40000000U
+#define GRSPWROUTER_RTCOMB_PR 0x20000000U
+#define GRSPWROUTER_RTCOMB_HD 0x10000000U
+#define GRSPWROUTER_RTCOMB_PE_SHIFT 1
+#define GRSPWROUTER_RTCOMB_PE_MASK 0xffffffeU
+#define GRSPWROUTER_RTCOMB_PE_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_RTCOMB_PE_MASK ) >> \
+    GRSPWROUTER_RTCOMB_PE_SHIFT )
+#define GRSPWROUTER_RTCOMB_PE_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_RTCOMB_PE_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_RTCOMB_PE_SHIFT ) & \
+      GRSPWROUTER_RTCOMB_PE_MASK ) )
+#define GRSPWROUTER_RTCOMB_PE( _val ) \
+#define GRSPWROUTER_RTCOMB_PD 0x1U
+ * @defgroup RTEMSDeviceGRSPWROUTERAPBAREA APB address area (APBAREA)
+#define GRSPWROUTER_APBAREA_APB_SHIFT 0
+#define GRSPWROUTER_APBAREA_APB_MASK 0xffffffffU
+#define GRSPWROUTER_APBAREA_APB_GET( _reg ) \
+  ( ( ( _reg ) & GRSPWROUTER_APBAREA_APB_MASK ) >> \
+    GRSPWROUTER_APBAREA_APB_SHIFT )
+#define GRSPWROUTER_APBAREA_APB_SET( _reg, _val ) \
+  ( ( ( _reg ) & ~GRSPWROUTER_APBAREA_APB_MASK ) | \
+    ( ( ( _val ) << GRSPWROUTER_APBAREA_APB_SHIFT ) & \
+      GRSPWROUTER_APBAREA_APB_MASK ) )
+#define GRSPWROUTER_APBAREA_APB( _val ) \
+ * @brief This structure defines the SpaceWire Router register block memory
+ *   map.
+typedef struct grspwrouter {
+  uint32_t reserved_0_4;
+   * @brief See @ref RTEMSDeviceGRSPWROUTERRTPMAP.
+  uint32_t rtpmap[ 255 ];
+  uint32_t reserved_400_404;
+   * @brief See @ref RTEMSDeviceGRSPWROUTERRTACTRL.
+  uint32_t rtactrl[ 255 ];
+   * @brief See @ref RTEMSDeviceGRSPWROUTERPCTRLCFG.
+  uint32_t pctrlcfg;
+   * @brief See @ref RTEMSDeviceGRSPWROUTERPCTRL.
+  uint32_t pctrl[ 31 ];
+   * @brief See @ref RTEMSDeviceGRSPWROUTERPSTSCFG.
+  uint32_t pstscfg;
+   * @brief See @ref RTEMSDeviceGRSPWROUTERPSTS.
+  uint32_t psts[ 31 ];
+   * @brief See @ref RTEMSDeviceGRSPWROUTERPTIMER.
+  uint32_t ptimer[ 32 ];
+   * @brief See @ref RTEMSDeviceGRSPWROUTERPCTRL2CFG.
+  uint32_t pctrl2cfg;
+   * @brief See @ref RTEMSDeviceGRSPWROUTERPCTRL2.
+  uint32_t pctrl2[ 31 ];
+   * @brief See @ref RTEMSDeviceGRSPWROUTERRTRCFG.
+  uint32_t rtrcfg;
+   * @brief See @ref RTEMSDeviceGRSPWROUTERTC.
+  uint32_t tc;
+   * @brief See @ref RTEMSDeviceGRSPWROUTERVER.
+  uint32_t ver;
+   * @brief See @ref RTEMSDeviceGRSPWROUTERIDIV.
+  uint32_t idiv;
+   * @brief See @ref RTEMSDeviceGRSPWROUTERCFGWE.
+  uint32_t cfgwe;
+   * @brief See @ref RTEMSDeviceGRSPWROUTERPRESCALER.
+  uint32_t prescaler;
+   * @brief See @ref RTEMSDeviceGRSPWROUTERIMASK.
+  uint32_t imask;
+   * @brief See @ref RTEMSDeviceGRSPWROUTERIPMASK.
+  uint32_t ipmask;
+   * @brief See @ref RTEMSDeviceGRSPWROUTERPIP.
+  uint32_t pip;
+   * @brief See @ref RTEMSDeviceGRSPWROUTERICODEGEN.
+  uint32_t icodegen;
+   * @brief See @ref RTEMSDeviceGRSPWROUTERISR0.
+  uint32_t isr0;
+   * @brief See @ref RTEMSDeviceGRSPWROUTERISR1.
+  uint32_t isr1;
+   * @brief See @ref RTEMSDeviceGRSPWROUTERISRTIMER.
+  uint32_t isrtimer;
+   * @brief See @ref RTEMSDeviceGRSPWROUTERAITIMER.
+  uint32_t aitimer;
+   * @brief See @ref RTEMSDeviceGRSPWROUTERISRCTIMER.
+  uint32_t isrctimer;
+  uint32_t reserved_a3c_a40;
+   * @brief See @ref RTEMSDeviceGRSPWROUTERLRUNSTAT.
+  uint32_t lrunstat;
+   * @brief See @ref RTEMSDeviceGRSPWROUTERCAP.
+  uint32_t cap;
+  uint32_t reserved_a48_a50[ 2 ];
+   * @brief See @ref RTEMSDeviceGRSPWROUTERPNPVEND.
+  uint32_t pnpvend;
+   * @brief See @ref RTEMSDeviceGRSPWROUTERPNPUVEND.
+  uint32_t pnpuvend;
+   * @brief See @ref RTEMSDeviceGRSPWROUTERPNPUSN.
+  uint32_t pnpusn;
+   * @brief See @ref RTEMSDeviceGRSPWROUTERPNPNETDISC.
+  uint32_t pnpnetdisc;
+  uint32_t reserved_a60_c10[ 108 ];
+   * @brief See @ref RTEMSDeviceGRSPWRouterPortStats.
+  grspwrouter_portstats portstats[ 31 ];
+   * @brief See @ref RTEMSDeviceGRSPWROUTERMAXPLEN.
+  uint32_t maxplen[ 32 ];
+  uint32_t reserved_e80_e84;
+   * @brief See @ref RTEMSDeviceGRSPWROUTERCREDCNT.
+  uint32_t credcnt[ 31 ];
+   * @brief See @ref RTEMSDeviceGRSPWROUTERGPO0.
+  uint32_t gpo0;
+   * @brief See @ref RTEMSDeviceGRSPWROUTERGPO1.
+  uint32_t gpo1;
+   * @brief See @ref RTEMSDeviceGRSPWROUTERGPO2.
+  uint32_t gpo2;
+   * @brief See @ref RTEMSDeviceGRSPWROUTERGPO3.
+  uint32_t gpo3;
+   * @brief See @ref RTEMSDeviceGRSPWROUTERGPI0.
+  uint32_t gpi0;
+   * @brief See @ref RTEMSDeviceGRSPWROUTERGPI1.
+  uint32_t gpi1;
+   * @brief See @ref RTEMSDeviceGRSPWROUTERGPI2.
+  uint32_t gpi2;
+   * @brief See @ref RTEMSDeviceGRSPWROUTERGPI3.
+  uint32_t gpi3;
+  uint32_t reserved_f20_1004[ 57 ];
+   * @brief See @ref RTEMSDeviceGRSPWROUTERRTCOMB.
+  uint32_t rtcomb[ 255 ];
+  uint32_t reserved_1400_2000[ 768 ];
+   * @brief See @ref RTEMSDeviceGRSPWROUTERAPBAREA.
+  uint32_t apbarea[ 1024 ];
+} grspwrouter;
+#ifdef __cplusplus
+#endif
+#endif /* _GRLIB_GRSPWROUTER_REGS_H */
diff --git a/bsps/include/grlib/spwrmap-regs.h b/bsps/include/grlib/spwrmap-regs.h
deleted file mode 100644
index 9a0ed203f3..0000000000
--- a/bsps/include/grlib/spwrmap-regs.h
+++ /dev/null
@@ -1,1443 +0,0 @@
-/* SPDX-License-Identifier: BSD-2-Clause */
- * @file
- * @ingroup RTEMSDeviceGRLIBSPWMAP
- * @brief This header file defines the SPWRMAP register block interface.
- * Copyright (C) 2021 embedded brains GmbH & Co. KG
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- *    notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- *    notice, this list of conditions and the following disclaimer in the
- *    documentation and/or other materials provided with the distribution.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
- * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
- * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
- * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
- * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
- * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
- * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
- * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
- * POSSIBILITY OF SUCH DAMAGE.
- * This file is part of the RTEMS quality process and was automatically
- * generated.  If you find something that needs to be fixed or
- * worded better please post a report or patch to an RTEMS mailing list
- * or raise a bug report:
- * https://www.rtems.org/bugs.html
- * For information on updating and regenerating please refer to the How-To
- * section in the Software Requirements Engineering chapter of the
- * RTEMS Software Engineering manual.  The manual is provided as a part of
- * a release.  For development sources please refer to the online
- * documentation at:
- * https://docs.rtems.org
-/* Generated from spec:/dev/grlib/if/spwrmap-header */
-#ifndef _GRLIB_SPWRMAP_REGS_H
-#define _GRLIB_SPWRMAP_REGS_H
-#include <stdint.h>
-#ifdef __cplusplus
-extern "C" {
-#endif
-/* Generated from spec:/dev/grlib/if/spwrmap */
- * @defgroup RTEMSDeviceGRLIBSPWMAP \
- *   SpaceWire Remote Memory Access Protocol (RMAP)
- * @brief This group contains the SpaceWire Remote Memory Access Protocol
- *   (RMAP) interfaces.
- * @defgroup RTEMSDeviceGRLIBSPWMAPRTPMAP \
- *   Routing table port mapping, addresses 1-12 and 32-255 (RTPMAP)
- * @brief This group contains register bit definitions.
-#define SPWRMAP_RTPMAP_PE_SHIFT 1
-#define SPWRMAP_RTPMAP_PE_MASK 0x1ffeU
-#define SPWRMAP_RTPMAP_PE_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_RTPMAP_PE_MASK ) >> \
-    SPWRMAP_RTPMAP_PE_SHIFT )
-#define SPWRMAP_RTPMAP_PE_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_RTPMAP_PE_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_RTPMAP_PE_SHIFT ) & \
-      SPWRMAP_RTPMAP_PE_MASK ) )
-#define SPWRMAP_RTPMAP_PE( _val ) \
-#define SPWRMAP_RTPMAP_PD 0x1U
- * @defgroup RTEMSDeviceGRLIBSPWMAPRTACTRL \
- *   Routing table address control, addresses 1-12 and 32-255 (RTACTRL)
-#define SPWRMAP_RTACTRL_SR 0x8U
-#define SPWRMAP_RTACTRL_EN 0x4U
-#define SPWRMAP_RTACTRL_PR 0x2U
-#define SPWRMAP_RTACTRL_HD 0x1U
- * @defgroup RTEMSDeviceGRLIBSPWMAPPCTRLCFG \
- *   Port control, port 0 (configuration port) (PCTRLCFG)
-#define SPWRMAP_PCTRLCFG_PL 0x20000U
-#define SPWRMAP_PCTRLCFG_TS 0x10000U
-#define SPWRMAP_PCTRLCFG_TR 0x200U
- * @defgroup RTEMSDeviceGRLIBSPWMAPPCTRL \
- *   Port control, ports 1-12 (SpaceWire ports and AMBA ports) (PCTRL)
-#define SPWRMAP_PCTRL_RD_SHIFT 24
-#define SPWRMAP_PCTRL_RD_MASK 0xff000000U
-#define SPWRMAP_PCTRL_RD_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_PCTRL_RD_MASK ) >> \
-    SPWRMAP_PCTRL_RD_SHIFT )
-#define SPWRMAP_PCTRL_RD_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_PCTRL_RD_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_PCTRL_RD_SHIFT ) & \
-      SPWRMAP_PCTRL_RD_MASK ) )
-#define SPWRMAP_PCTRL_RD( _val ) \
-#define SPWRMAP_PCTRL_ST 0x200000U
-#define SPWRMAP_PCTRL_SR 0x100000U
-#define SPWRMAP_PCTRL_AD 0x80000U
-#define SPWRMAP_PCTRL_LR 0x40000U
-#define SPWRMAP_PCTRL_PL 0x20000U
-#define SPWRMAP_PCTRL_TS 0x10000U
-#define SPWRMAP_PCTRL_IC 0x8000U
-#define SPWRMAP_PCTRL_ET 0x4000U
-#define SPWRMAP_PCTRL_DI 0x400U
-#define SPWRMAP_PCTRL_TR 0x200U
-#define SPWRMAP_PCTRL_PR 0x100U
-#define SPWRMAP_PCTRL_TF 0x80U
-#define SPWRMAP_PCTRL_RS 0x40U
-#define SPWRMAP_PCTRL_TE 0x20U
-#define SPWRMAP_PCTRL_CE 0x8U
-#define SPWRMAP_PCTRL_AS 0x4U
-#define SPWRMAP_PCTRL_LS 0x2U
-#define SPWRMAP_PCTRL_LD 0x1U
- * @defgroup RTEMSDeviceGRLIBSPWMAPPSTSCFG \
- *   Port status, port 0 (configuration port) (PSTSCFG)
-#define SPWRMAP_PSTSCFG_EO 0x80000000U
-#define SPWRMAP_PSTSCFG_EE 0x40000000U
-#define SPWRMAP_PSTSCFG_PL 0x20000000U
-#define SPWRMAP_PSTSCFG_TT 0x10000000U
-#define SPWRMAP_PSTSCFG_PT 0x8000000U
-#define SPWRMAP_PSTSCFG_HC 0x4000000U
-#define SPWRMAP_PSTSCFG_PI 0x2000000U
-#define SPWRMAP_PSTSCFG_CE 0x1000000U
-#define SPWRMAP_PSTSCFG_EC_SHIFT 20
-#define SPWRMAP_PSTSCFG_EC_MASK 0xf00000U
-#define SPWRMAP_PSTSCFG_EC_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_PSTSCFG_EC_MASK ) >> \
-    SPWRMAP_PSTSCFG_EC_SHIFT )
-#define SPWRMAP_PSTSCFG_EC_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_PSTSCFG_EC_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_PSTSCFG_EC_SHIFT ) & \
-      SPWRMAP_PSTSCFG_EC_MASK ) )
-#define SPWRMAP_PSTSCFG_EC( _val ) \
-#define SPWRMAP_PSTSCFG_TS 0x40000U
-#define SPWRMAP_PSTSCFG_ME 0x20000U
-#define SPWRMAP_PSTSCFG_IP_SHIFT 7
-#define SPWRMAP_PSTSCFG_IP_MASK 0xf80U
-#define SPWRMAP_PSTSCFG_IP_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_PSTSCFG_IP_MASK ) >> \
-    SPWRMAP_PSTSCFG_IP_SHIFT )
-#define SPWRMAP_PSTSCFG_IP_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_PSTSCFG_IP_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_PSTSCFG_IP_SHIFT ) & \
-      SPWRMAP_PSTSCFG_IP_MASK ) )
-#define SPWRMAP_PSTSCFG_IP( _val ) \
-#define SPWRMAP_PSTSCFG_CP 0x10U
-#define SPWRMAP_PSTSCFG_PC_SHIFT 0
-#define SPWRMAP_PSTSCFG_PC_MASK 0xfU
-#define SPWRMAP_PSTSCFG_PC_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_PSTSCFG_PC_MASK ) >> \
-    SPWRMAP_PSTSCFG_PC_SHIFT )
-#define SPWRMAP_PSTSCFG_PC_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_PSTSCFG_PC_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_PSTSCFG_PC_SHIFT ) & \
-      SPWRMAP_PSTSCFG_PC_MASK ) )
-#define SPWRMAP_PSTSCFG_PC( _val ) \
- * @defgroup RTEMSDeviceGRLIBSPWMAPPSTS \
- *   Port status, ports 1-12 (SpaceWire ports and AMBA ports) (PSTS)
-#define SPWRMAP_PSTS_PT_SHIFT 30
-#define SPWRMAP_PSTS_PT_MASK 0xc0000000U
-#define SPWRMAP_PSTS_PT_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_PSTS_PT_MASK ) >> \
-    SPWRMAP_PSTS_PT_SHIFT )
-#define SPWRMAP_PSTS_PT_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_PSTS_PT_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_PSTS_PT_SHIFT ) & \
-      SPWRMAP_PSTS_PT_MASK ) )
-#define SPWRMAP_PSTS_PT( _val ) \
-#define SPWRMAP_PSTS_PL 0x20000000U
-#define SPWRMAP_PSTS_TT 0x10000000U
-#define SPWRMAP_PSTS_RS 0x8000000U
-#define SPWRMAP_PSTS_SR 0x4000000U
-#define SPWRMAP_PSTS_LR 0x400000U
-#define SPWRMAP_PSTS_SP 0x200000U
-#define SPWRMAP_PSTS_AC 0x100000U
-#define SPWRMAP_PSTS_TS 0x40000U
-#define SPWRMAP_PSTS_ME 0x20000U
-#define SPWRMAP_PSTS_TF 0x10000U
-#define SPWRMAP_PSTS_RE 0x8000U
-#define SPWRMAP_PSTS_LS_SHIFT 12
-#define SPWRMAP_PSTS_LS_MASK 0x7000U
-#define SPWRMAP_PSTS_LS_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_PSTS_LS_MASK ) >> \
-    SPWRMAP_PSTS_LS_SHIFT )
-#define SPWRMAP_PSTS_LS_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_PSTS_LS_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_PSTS_LS_SHIFT ) & \
-      SPWRMAP_PSTS_LS_MASK ) )
-#define SPWRMAP_PSTS_LS( _val ) \
-#define SPWRMAP_PSTS_IP_SHIFT 7
-#define SPWRMAP_PSTS_IP_MASK 0xf80U
-#define SPWRMAP_PSTS_IP_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_PSTS_IP_MASK ) >> \
-    SPWRMAP_PSTS_IP_SHIFT )
-#define SPWRMAP_PSTS_IP_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_PSTS_IP_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_PSTS_IP_SHIFT ) & \
-      SPWRMAP_PSTS_IP_MASK ) )
-#define SPWRMAP_PSTS_IP( _val ) \
-#define SPWRMAP_PSTS_PR 0x40U
-#define SPWRMAP_PSTS_PB 0x20U
-#define SPWRMAP_PSTS_IA 0x10U
-#define SPWRMAP_PSTS_CE 0x8U
-#define SPWRMAP_PSTS_ER 0x4U
-#define SPWRMAP_PSTS_DE 0x2U
-#define SPWRMAP_PSTS_PE 0x1U
- * @defgroup RTEMSDeviceGRLIBSPWMAPPTIMER \
- *   Port timer reload, ports 0-12 (PTIMER)
-#define SPWRMAP_PTIMER_RL_SHIFT 0
-#define SPWRMAP_PTIMER_RL_MASK 0xffffU
-#define SPWRMAP_PTIMER_RL_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_PTIMER_RL_MASK ) >> \
-    SPWRMAP_PTIMER_RL_SHIFT )
-#define SPWRMAP_PTIMER_RL_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_PTIMER_RL_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_PTIMER_RL_SHIFT ) & \
-      SPWRMAP_PTIMER_RL_MASK ) )
-#define SPWRMAP_PTIMER_RL( _val ) \
- * @defgroup RTEMSDeviceGRLIBSPWMAPPCTRL2CFG \
- *   Port control 2, port 0 (configuration port) (PCTRL2CFG)
-#define SPWRMAP_PCTRL2CFG_SM_SHIFT 24
-#define SPWRMAP_PCTRL2CFG_SM_MASK 0xff000000U
-#define SPWRMAP_PCTRL2CFG_SM_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_PCTRL2CFG_SM_MASK ) >> \
-    SPWRMAP_PCTRL2CFG_SM_SHIFT )
-#define SPWRMAP_PCTRL2CFG_SM_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_PCTRL2CFG_SM_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_PCTRL2CFG_SM_SHIFT ) & \
-      SPWRMAP_PCTRL2CFG_SM_MASK ) )
-#define SPWRMAP_PCTRL2CFG_SM( _val ) \
-#define SPWRMAP_PCTRL2CFG_SV_SHIFT 16
-#define SPWRMAP_PCTRL2CFG_SV_MASK 0xff0000U
-#define SPWRMAP_PCTRL2CFG_SV_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_PCTRL2CFG_SV_MASK ) >> \
-    SPWRMAP_PCTRL2CFG_SV_SHIFT )
-#define SPWRMAP_PCTRL2CFG_SV_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_PCTRL2CFG_SV_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_PCTRL2CFG_SV_SHIFT ) & \
-      SPWRMAP_PCTRL2CFG_SV_MASK ) )
-#define SPWRMAP_PCTRL2CFG_SV( _val ) \
-#define SPWRMAP_PCTRL2CFG_OR 0x8000U
- * @defgroup RTEMSDeviceGRLIBSPWMAPPCTRL2 \
- *   Port control 2, ports 1-12 (SpaceWire ports and AMBA ports) (PCTRL2)
-#define SPWRMAP_PCTRL2_SM_SHIFT 24
-#define SPWRMAP_PCTRL2_SM_MASK 0xff000000U
-#define SPWRMAP_PCTRL2_SM_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_PCTRL2_SM_MASK ) >> \
-    SPWRMAP_PCTRL2_SM_SHIFT )
-#define SPWRMAP_PCTRL2_SM_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_PCTRL2_SM_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_PCTRL2_SM_SHIFT ) & \
-      SPWRMAP_PCTRL2_SM_MASK ) )
-#define SPWRMAP_PCTRL2_SM( _val ) \
-#define SPWRMAP_PCTRL2_SV_SHIFT 16
-#define SPWRMAP_PCTRL2_SV_MASK 0xff0000U
-#define SPWRMAP_PCTRL2_SV_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_PCTRL2_SV_MASK ) >> \
-    SPWRMAP_PCTRL2_SV_SHIFT )
-#define SPWRMAP_PCTRL2_SV_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_PCTRL2_SV_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_PCTRL2_SV_SHIFT ) & \
-      SPWRMAP_PCTRL2_SV_MASK ) )
-#define SPWRMAP_PCTRL2_SV( _val ) \
-#define SPWRMAP_PCTRL2_OR 0x8000U
-#define SPWRMAP_PCTRL2_UR 0x4000U
-#define SPWRMAP_PCTRL2_AT 0x1000U
-#define SPWRMAP_PCTRL2_AR 0x800U
-#define SPWRMAP_PCTRL2_IT 0x400U
-#define SPWRMAP_PCTRL2_IR 0x200U
-#define SPWRMAP_PCTRL2_SD_SHIFT 1
-#define SPWRMAP_PCTRL2_SD_MASK 0x3eU
-#define SPWRMAP_PCTRL2_SD_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_PCTRL2_SD_MASK ) >> \
-    SPWRMAP_PCTRL2_SD_SHIFT )
-#define SPWRMAP_PCTRL2_SD_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_PCTRL2_SD_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_PCTRL2_SD_SHIFT ) & \
-      SPWRMAP_PCTRL2_SD_MASK ) )
-#define SPWRMAP_PCTRL2_SD( _val ) \
-#define SPWRMAP_PCTRL2_SC 0x1U
- * @defgroup RTEMSDeviceGRLIBSPWMAPRTRCFG \
- *   Router configuration / status (RTRCFG)
-#define SPWRMAP_RTRCFG_SP_SHIFT 27
-#define SPWRMAP_RTRCFG_SP_MASK 0xf8000000U
-#define SPWRMAP_RTRCFG_SP_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_RTRCFG_SP_MASK ) >> \
-    SPWRMAP_RTRCFG_SP_SHIFT )
-#define SPWRMAP_RTRCFG_SP_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_RTRCFG_SP_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_RTRCFG_SP_SHIFT ) & \
-      SPWRMAP_RTRCFG_SP_MASK ) )
-#define SPWRMAP_RTRCFG_SP( _val ) \
-#define SPWRMAP_RTRCFG_AP_SHIFT 22
-#define SPWRMAP_RTRCFG_AP_MASK 0x7c00000U
-#define SPWRMAP_RTRCFG_AP_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_RTRCFG_AP_MASK ) >> \
-    SPWRMAP_RTRCFG_AP_SHIFT )
-#define SPWRMAP_RTRCFG_AP_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_RTRCFG_AP_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_RTRCFG_AP_SHIFT ) & \
-      SPWRMAP_RTRCFG_AP_MASK ) )
-#define SPWRMAP_RTRCFG_AP( _val ) \
-#define SPWRMAP_RTRCFG_SR 0x8000U
-#define SPWRMAP_RTRCFG_PE 0x4000U
-#define SPWRMAP_RTRCFG_IC 0x2000U
-#define SPWRMAP_RTRCFG_IS 0x1000U
-#define SPWRMAP_RTRCFG_IP 0x800U
-#define SPWRMAP_RTRCFG_AI 0x400U
-#define SPWRMAP_RTRCFG_AT 0x200U
-#define SPWRMAP_RTRCFG_IE 0x100U
-#define SPWRMAP_RTRCFG_RE 0x80U
-#define SPWRMAP_RTRCFG_EE 0x40U
-#define SPWRMAP_RTRCFG_SA 0x10U
-#define SPWRMAP_RTRCFG_TF 0x8U
-#define SPWRMAP_RTRCFG_ME 0x4U
-#define SPWRMAP_RTRCFG_TA 0x2U
-#define SPWRMAP_RTRCFG_PP 0x1U
- * @defgroup RTEMSDeviceGRLIBSPWMAPTC Time-code (TC)
-#define SPWRMAP_TC_RE 0x200U
-#define SPWRMAP_TC_EN 0x100U
-#define SPWRMAP_TC_CF_SHIFT 6
-#define SPWRMAP_TC_CF_MASK 0xc0U
-#define SPWRMAP_TC_CF_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_TC_CF_MASK ) >> \
-    SPWRMAP_TC_CF_SHIFT )
-#define SPWRMAP_TC_CF_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_TC_CF_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_TC_CF_SHIFT ) & \
-      SPWRMAP_TC_CF_MASK ) )
-#define SPWRMAP_TC_CF( _val ) \
-#define SPWRMAP_TC_TC_SHIFT 0
-#define SPWRMAP_TC_TC_MASK 0x3fU
-#define SPWRMAP_TC_TC_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_TC_TC_MASK ) >> \
-    SPWRMAP_TC_TC_SHIFT )
-#define SPWRMAP_TC_TC_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_TC_TC_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_TC_TC_SHIFT ) & \
-      SPWRMAP_TC_TC_MASK ) )
-#define SPWRMAP_TC_TC( _val ) \
- * @defgroup RTEMSDeviceGRLIBSPWMAPVER Version / instance ID (VER)
-#define SPWRMAP_VER_MA_SHIFT 24
-#define SPWRMAP_VER_MA_MASK 0xff000000U
-#define SPWRMAP_VER_MA_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_VER_MA_MASK ) >> \
-    SPWRMAP_VER_MA_SHIFT )
-#define SPWRMAP_VER_MA_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_VER_MA_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_VER_MA_SHIFT ) & \
-      SPWRMAP_VER_MA_MASK ) )
-#define SPWRMAP_VER_MA( _val ) \
-#define SPWRMAP_VER_MI_SHIFT 16
-#define SPWRMAP_VER_MI_MASK 0xff0000U
-#define SPWRMAP_VER_MI_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_VER_MI_MASK ) >> \
-    SPWRMAP_VER_MI_SHIFT )
-#define SPWRMAP_VER_MI_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_VER_MI_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_VER_MI_SHIFT ) & \
-      SPWRMAP_VER_MI_MASK ) )
-#define SPWRMAP_VER_MI( _val ) \
-#define SPWRMAP_VER_PA_SHIFT 8
-#define SPWRMAP_VER_PA_MASK 0xff00U
-#define SPWRMAP_VER_PA_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_VER_PA_MASK ) >> \
-    SPWRMAP_VER_PA_SHIFT )
-#define SPWRMAP_VER_PA_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_VER_PA_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_VER_PA_SHIFT ) & \
-      SPWRMAP_VER_PA_MASK ) )
-#define SPWRMAP_VER_PA( _val ) \
-#define SPWRMAP_VER_ID_SHIFT 0
-#define SPWRMAP_VER_ID_MASK 0xffU
-#define SPWRMAP_VER_ID_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_VER_ID_MASK ) >> \
-    SPWRMAP_VER_ID_SHIFT )
-#define SPWRMAP_VER_ID_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_VER_ID_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_VER_ID_SHIFT ) & \
-      SPWRMAP_VER_ID_MASK ) )
-#define SPWRMAP_VER_ID( _val ) \
- * @defgroup RTEMSDeviceGRLIBSPWMAPIDIV Initialization divisor (IDIV)
-#define SPWRMAP_IDIV_ID_SHIFT 0
-#define SPWRMAP_IDIV_ID_MASK 0xffU
-#define SPWRMAP_IDIV_ID_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_IDIV_ID_MASK ) >> \
-    SPWRMAP_IDIV_ID_SHIFT )
-#define SPWRMAP_IDIV_ID_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_IDIV_ID_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_IDIV_ID_SHIFT ) & \
-      SPWRMAP_IDIV_ID_MASK ) )
-#define SPWRMAP_IDIV_ID( _val ) \
- * @defgroup RTEMSDeviceGRLIBSPWMAPCFGWE \
- *   Configuration port write enable (CFGWE)
-#define SPWRMAP_CFGWE_WE 0x1U
- * @defgroup RTEMSDeviceGRLIBSPWMAPPRESCALER Timer prescaler reload (PRESCALER)
-#define SPWRMAP_PRESCALER_RL_SHIFT 0
-#define SPWRMAP_PRESCALER_RL_MASK 0xffffU
-#define SPWRMAP_PRESCALER_RL_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_PRESCALER_RL_MASK ) >> \
-    SPWRMAP_PRESCALER_RL_SHIFT )
-#define SPWRMAP_PRESCALER_RL_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_PRESCALER_RL_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_PRESCALER_RL_SHIFT ) & \
-      SPWRMAP_PRESCALER_RL_MASK ) )
-#define SPWRMAP_PRESCALER_RL( _val ) \
- * @defgroup RTEMSDeviceGRLIBSPWMAPIMASK Interrupt mask (IMASK)
-#define SPWRMAP_IMASK_PE 0x400U
-#define SPWRMAP_IMASK_SR 0x200U
-#define SPWRMAP_IMASK_RS 0x100U
-#define SPWRMAP_IMASK_TT 0x80U
-#define SPWRMAP_IMASK_PL 0x40U
-#define SPWRMAP_IMASK_TS 0x20U
-#define SPWRMAP_IMASK_AC 0x10U
-#define SPWRMAP_IMASK_RE 0x8U
-#define SPWRMAP_IMASK_IA 0x4U
-#define SPWRMAP_IMASK_LE 0x2U
-#define SPWRMAP_IMASK_ME 0x1U
- * @defgroup RTEMSDeviceGRLIBSPWMAPIPMASK Interrupt port mask (IPMASK)
-#define SPWRMAP_IPMASK_IE_SHIFT 0
-#define SPWRMAP_IPMASK_IE_MASK 0xffffffffU
-#define SPWRMAP_IPMASK_IE_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_IPMASK_IE_MASK ) >> \
-    SPWRMAP_IPMASK_IE_SHIFT )
-#define SPWRMAP_IPMASK_IE_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_IPMASK_IE_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_IPMASK_IE_SHIFT ) & \
-      SPWRMAP_IPMASK_IE_MASK ) )
-#define SPWRMAP_IPMASK_IE( _val ) \
- * @defgroup RTEMSDeviceGRLIBSPWMAPPIP Port interrupt pending (PIP)
-#define SPWRMAP_PIP_IP_SHIFT 0
-#define SPWRMAP_PIP_IP_MASK 0xffffffffU
-#define SPWRMAP_PIP_IP_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_PIP_IP_MASK ) >> \
-    SPWRMAP_PIP_IP_SHIFT )
-#define SPWRMAP_PIP_IP_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_PIP_IP_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_PIP_IP_SHIFT ) & \
-      SPWRMAP_PIP_IP_MASK ) )
-#define SPWRMAP_PIP_IP( _val ) \
- * @defgroup RTEMSDeviceGRLIBSPWMAPICODEGEN \
- *   Interrupt code generation (ICODEGEN)
-#define SPWRMAP_ICODEGEN_HI 0x200000U
-#define SPWRMAP_ICODEGEN_UA 0x100000U
-#define SPWRMAP_ICODEGEN_AH 0x80000U
-#define SPWRMAP_ICODEGEN_IT 0x40000U
-#define SPWRMAP_ICODEGEN_TE 0x20000U
-#define SPWRMAP_ICODEGEN_EN 0x10000U
-#define SPWRMAP_ICODEGEN_IN_SHIFT 0
-#define SPWRMAP_ICODEGEN_IN_MASK 0x3fU
-#define SPWRMAP_ICODEGEN_IN_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_ICODEGEN_IN_MASK ) >> \
-    SPWRMAP_ICODEGEN_IN_SHIFT )
-#define SPWRMAP_ICODEGEN_IN_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_ICODEGEN_IN_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_ICODEGEN_IN_SHIFT ) & \
-      SPWRMAP_ICODEGEN_IN_MASK ) )
-#define SPWRMAP_ICODEGEN_IN( _val ) \
- * @defgroup RTEMSDeviceGRLIBSPWMAPISR0 \
- *   Interrupt code distribution ISR register, interrupt 0-31 (ISR0)
-#define SPWRMAP_ISR0_IB_SHIFT 0
-#define SPWRMAP_ISR0_IB_MASK 0xffffffffU
-#define SPWRMAP_ISR0_IB_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_ISR0_IB_MASK ) >> \
-    SPWRMAP_ISR0_IB_SHIFT )
-#define SPWRMAP_ISR0_IB_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_ISR0_IB_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_ISR0_IB_SHIFT ) & \
-      SPWRMAP_ISR0_IB_MASK ) )
-#define SPWRMAP_ISR0_IB( _val ) \
- * @defgroup RTEMSDeviceGRLIBSPWMAPISR1 \
- *   Interrupt code distribution ISR register, interrupt 32-63 (ISR1)
-#define SPWRMAP_ISR1_IB_SHIFT 0
-#define SPWRMAP_ISR1_IB_MASK 0xffffffffU
-#define SPWRMAP_ISR1_IB_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_ISR1_IB_MASK ) >> \
-    SPWRMAP_ISR1_IB_SHIFT )
-#define SPWRMAP_ISR1_IB_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_ISR1_IB_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_ISR1_IB_SHIFT ) & \
-      SPWRMAP_ISR1_IB_MASK ) )
-#define SPWRMAP_ISR1_IB( _val ) \
- * @defgroup RTEMSDeviceGRLIBSPWMAPISRTIMER \
- *   Interrupt code distribution ISR timer reload (ISRTIMER)
-#define SPWRMAP_ISRTIMER_RL_SHIFT 0
-#define SPWRMAP_ISRTIMER_RL_MASK 0xffffU
-#define SPWRMAP_ISRTIMER_RL_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_ISRTIMER_RL_MASK ) >> \
-    SPWRMAP_ISRTIMER_RL_SHIFT )
-#define SPWRMAP_ISRTIMER_RL_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_ISRTIMER_RL_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_ISRTIMER_RL_SHIFT ) & \
-      SPWRMAP_ISRTIMER_RL_MASK ) )
-#define SPWRMAP_ISRTIMER_RL( _val ) \
- * @defgroup RTEMSDeviceGRLIBSPWMAPAITIMER \
- *   Interrupt code distribution ACK-to-INT timer reload (AITIMER)
-#define SPWRMAP_AITIMER_RL_SHIFT 0
-#define SPWRMAP_AITIMER_RL_MASK 0xffffU
-#define SPWRMAP_AITIMER_RL_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_AITIMER_RL_MASK ) >> \
-    SPWRMAP_AITIMER_RL_SHIFT )
-#define SPWRMAP_AITIMER_RL_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_AITIMER_RL_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_AITIMER_RL_SHIFT ) & \
-      SPWRMAP_AITIMER_RL_MASK ) )
-#define SPWRMAP_AITIMER_RL( _val ) \
- * @defgroup RTEMSDeviceGRLIBSPWMAPISRCTIMER \
- *   Interrupt code distribution ISR change timer reload (ISRCTIMER)
-#define SPWRMAP_ISRCTIMER_RL_SHIFT 0
-#define SPWRMAP_ISRCTIMER_RL_MASK 0x1fU
-#define SPWRMAP_ISRCTIMER_RL_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_ISRCTIMER_RL_MASK ) >> \
-    SPWRMAP_ISRCTIMER_RL_SHIFT )
-#define SPWRMAP_ISRCTIMER_RL_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_ISRCTIMER_RL_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_ISRCTIMER_RL_SHIFT ) & \
-      SPWRMAP_ISRCTIMER_RL_MASK ) )
-#define SPWRMAP_ISRCTIMER_RL( _val ) \
- * @defgroup RTEMSDeviceGRLIBSPWMAPLRUNSTAT Link running status (LRUNSTAT)
-#define SPWRMAP_LRUNSTAT_LR_SHIFT 1
-#define SPWRMAP_LRUNSTAT_LR_MASK 0xfffffffeU
-#define SPWRMAP_LRUNSTAT_LR_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_LRUNSTAT_LR_MASK ) >> \
-    SPWRMAP_LRUNSTAT_LR_SHIFT )
-#define SPWRMAP_LRUNSTAT_LR_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_LRUNSTAT_LR_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_LRUNSTAT_LR_SHIFT ) & \
-      SPWRMAP_LRUNSTAT_LR_MASK ) )
-#define SPWRMAP_LRUNSTAT_LR( _val ) \
- * @defgroup RTEMSDeviceGRLIBSPWMAPCAP Capability (CAP)
-#define SPWRMAP_CAP_AF_SHIFT 24
-#define SPWRMAP_CAP_AF_MASK 0x3000000U
-#define SPWRMAP_CAP_AF_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_CAP_AF_MASK ) >> \
-    SPWRMAP_CAP_AF_SHIFT )
-#define SPWRMAP_CAP_AF_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_CAP_AF_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_CAP_AF_SHIFT ) & \
-      SPWRMAP_CAP_AF_MASK ) )
-#define SPWRMAP_CAP_AF( _val ) \
-#define SPWRMAP_CAP_PF_SHIFT 20
-#define SPWRMAP_CAP_PF_MASK 0x700000U
-#define SPWRMAP_CAP_PF_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_CAP_PF_MASK ) >> \
-    SPWRMAP_CAP_PF_SHIFT )
-#define SPWRMAP_CAP_PF_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_CAP_PF_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_CAP_PF_SHIFT ) & \
-      SPWRMAP_CAP_PF_MASK ) )
-#define SPWRMAP_CAP_PF( _val ) \
-#define SPWRMAP_CAP_RM_SHIFT 16
-#define SPWRMAP_CAP_RM_MASK 0x70000U
-#define SPWRMAP_CAP_RM_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_CAP_RM_MASK ) >> \
-    SPWRMAP_CAP_RM_SHIFT )
-#define SPWRMAP_CAP_RM_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_CAP_RM_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_CAP_RM_SHIFT ) & \
-      SPWRMAP_CAP_RM_MASK ) )
-#define SPWRMAP_CAP_RM( _val ) \
-#define SPWRMAP_CAP_AS 0x4000U
-#define SPWRMAP_CAP_AX 0x2000U
-#define SPWRMAP_CAP_DP 0x1000U
-#define SPWRMAP_CAP_ID 0x800U
-#define SPWRMAP_CAP_SD 0x400U
-#define SPWRMAP_CAP_PC_SHIFT 5
-#define SPWRMAP_CAP_PC_MASK 0x3e0U
-#define SPWRMAP_CAP_PC_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_CAP_PC_MASK ) >> \
-    SPWRMAP_CAP_PC_SHIFT )
-#define SPWRMAP_CAP_PC_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_CAP_PC_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_CAP_PC_SHIFT ) & \
-      SPWRMAP_CAP_PC_MASK ) )
-#define SPWRMAP_CAP_PC( _val ) \
-#define SPWRMAP_CAP_CC_SHIFT 0
-#define SPWRMAP_CAP_CC_MASK 0x1fU
-#define SPWRMAP_CAP_CC_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_CAP_CC_MASK ) >> \
-    SPWRMAP_CAP_CC_SHIFT )
-#define SPWRMAP_CAP_CC_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_CAP_CC_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_CAP_CC_SHIFT ) & \
-      SPWRMAP_CAP_CC_MASK ) )
-#define SPWRMAP_CAP_CC( _val ) \
- * @defgroup RTEMSDeviceGRLIBSPWMAPPNPVEND \
- *   SpaceWire Plug-and-Play - Device Vendor and Product ID (PNPVEND)
-#define SPWRMAP_PNPVEND_VI_SHIFT 16
-#define SPWRMAP_PNPVEND_VI_MASK 0xffff0000U
-#define SPWRMAP_PNPVEND_VI_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_PNPVEND_VI_MASK ) >> \
-    SPWRMAP_PNPVEND_VI_SHIFT )
-#define SPWRMAP_PNPVEND_VI_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_PNPVEND_VI_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_PNPVEND_VI_SHIFT ) & \
-      SPWRMAP_PNPVEND_VI_MASK ) )
-#define SPWRMAP_PNPVEND_VI( _val ) \
-#define SPWRMAP_PNPVEND_PI_SHIFT 0
-#define SPWRMAP_PNPVEND_PI_MASK 0xffffU
-#define SPWRMAP_PNPVEND_PI_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_PNPVEND_PI_MASK ) >> \
-    SPWRMAP_PNPVEND_PI_SHIFT )
-#define SPWRMAP_PNPVEND_PI_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_PNPVEND_PI_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_PNPVEND_PI_SHIFT ) & \
-      SPWRMAP_PNPVEND_PI_MASK ) )
-#define SPWRMAP_PNPVEND_PI( _val ) \
- * @defgroup RTEMSDeviceGRLIBSPWMAPPNPUVEND \
- *   SpaceWire Plug-and-Play - Unit Vendor and Product ID (PNPUVEND)
-#define SPWRMAP_PNPUVEND_VI_SHIFT 16
-#define SPWRMAP_PNPUVEND_VI_MASK 0xffff0000U
-#define SPWRMAP_PNPUVEND_VI_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_PNPUVEND_VI_MASK ) >> \
-    SPWRMAP_PNPUVEND_VI_SHIFT )
-#define SPWRMAP_PNPUVEND_VI_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_PNPUVEND_VI_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_PNPUVEND_VI_SHIFT ) & \
-      SPWRMAP_PNPUVEND_VI_MASK ) )
-#define SPWRMAP_PNPUVEND_VI( _val ) \
-#define SPWRMAP_PNPUVEND_PI_SHIFT 0
-#define SPWRMAP_PNPUVEND_PI_MASK 0xffffU
-#define SPWRMAP_PNPUVEND_PI_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_PNPUVEND_PI_MASK ) >> \
-    SPWRMAP_PNPUVEND_PI_SHIFT )
-#define SPWRMAP_PNPUVEND_PI_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_PNPUVEND_PI_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_PNPUVEND_PI_SHIFT ) & \
-      SPWRMAP_PNPUVEND_PI_MASK ) )
-#define SPWRMAP_PNPUVEND_PI( _val ) \
- * @defgroup RTEMSDeviceGRLIBSPWMAPPNPUSN \
- *   SpaceWire Plug-and-Play - Unit Serial Number (PNPUSN)
-#define SPWRMAP_PNPUSN_SN_SHIFT 0
-#define SPWRMAP_PNPUSN_SN_MASK 0xffffffffU
-#define SPWRMAP_PNPUSN_SN_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_PNPUSN_SN_MASK ) >> \
-    SPWRMAP_PNPUSN_SN_SHIFT )
-#define SPWRMAP_PNPUSN_SN_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_PNPUSN_SN_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_PNPUSN_SN_SHIFT ) & \
-      SPWRMAP_PNPUSN_SN_MASK ) )
-#define SPWRMAP_PNPUSN_SN( _val ) \
- * @defgroup RTEMSDeviceGRLIBSPWMAPMAXPLEN \
- *   Maximum packet length, ports 0-12 (MAXPLEN)
-#define SPWRMAP_MAXPLEN_ML_SHIFT 0
-#define SPWRMAP_MAXPLEN_ML_MASK 0x1ffffffU
-#define SPWRMAP_MAXPLEN_ML_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_MAXPLEN_ML_MASK ) >> \
-    SPWRMAP_MAXPLEN_ML_SHIFT )
-#define SPWRMAP_MAXPLEN_ML_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_MAXPLEN_ML_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_MAXPLEN_ML_SHIFT ) & \
-      SPWRMAP_MAXPLEN_ML_MASK ) )
-#define SPWRMAP_MAXPLEN_ML( _val ) \
- * @defgroup RTEMSDeviceGRLIBSPWMAPCREDCNT Credit counter, ports 1-8 (CREDCNT)
-#define SPWRMAP_CREDCNT_OC_SHIFT 6
-#define SPWRMAP_CREDCNT_OC_MASK 0xfc0U
-#define SPWRMAP_CREDCNT_OC_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_CREDCNT_OC_MASK ) >> \
-    SPWRMAP_CREDCNT_OC_SHIFT )
-#define SPWRMAP_CREDCNT_OC_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_CREDCNT_OC_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_CREDCNT_OC_SHIFT ) & \
-      SPWRMAP_CREDCNT_OC_MASK ) )
-#define SPWRMAP_CREDCNT_OC( _val ) \
-#define SPWRMAP_CREDCNT_IC_SHIFT 0
-#define SPWRMAP_CREDCNT_IC_MASK 0x3fU
-#define SPWRMAP_CREDCNT_IC_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_CREDCNT_IC_MASK ) >> \
-    SPWRMAP_CREDCNT_IC_SHIFT )
-#define SPWRMAP_CREDCNT_IC_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_CREDCNT_IC_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_CREDCNT_IC_SHIFT ) & \
-      SPWRMAP_CREDCNT_IC_MASK ) )
-#define SPWRMAP_CREDCNT_IC( _val ) \
- * @defgroup RTEMSDeviceGRLIBSPWMAPRTCOMB \
- *   Routing table, combined port mapping and address control, addresses 1-255 (RTCOMB)
-#define SPWRMAP_RTCOMB_SR 0x80000000U
-#define SPWRMAP_RTCOMB_EN 0x40000000U
-#define SPWRMAP_RTCOMB_PR 0x20000000U
-#define SPWRMAP_RTCOMB_HD 0x10000000U
-#define SPWRMAP_RTCOMB_PE_SHIFT 1
-#define SPWRMAP_RTCOMB_PE_MASK 0xffffeU
-#define SPWRMAP_RTCOMB_PE_GET( _reg ) \
-  ( ( ( _reg ) & SPWRMAP_RTCOMB_PE_MASK ) >> \
-    SPWRMAP_RTCOMB_PE_SHIFT )
-#define SPWRMAP_RTCOMB_PE_SET( _reg, _val ) \
-  ( ( ( _reg ) & ~SPWRMAP_RTCOMB_PE_MASK ) | \
-    ( ( ( _val ) << SPWRMAP_RTCOMB_PE_SHIFT ) & \
-      SPWRMAP_RTCOMB_PE_MASK ) )
-#define SPWRMAP_RTCOMB_PE( _val ) \
-#define SPWRMAP_RTCOMB_PD 0x1U
- * @brief This set of defines the SpaceWire Remote Memory Access Protocol
- *   (RMAP) address map.
-typedef struct spwrmap {
-  uint32_t reserved_0_4;
-   * @brief See @ref RTEMSDeviceGRLIBSPWMAPRTPMAP.
-  uint32_t rtpmap;
-  uint32_t reserved_8_404[ 255 ];
-   * @brief See @ref RTEMSDeviceGRLIBSPWMAPRTACTRL.
-  uint32_t rtactrl;
-  uint32_t reserved_408_800[ 254 ];
-   * @brief See @ref RTEMSDeviceGRLIBSPWMAPPCTRLCFG.
-  uint32_t pctrlcfg;
-   * @brief See @ref RTEMSDeviceGRLIBSPWMAPPCTRL.
-  uint32_t pctrl;
-  uint32_t reserved_808_880[ 30 ];
-   * @brief See @ref RTEMSDeviceGRLIBSPWMAPPSTSCFG.
-  uint32_t pstscfg;
-   * @brief See @ref RTEMSDeviceGRLIBSPWMAPPSTS.
-  uint32_t psts;
-  uint32_t reserved_888_900[ 30 ];
-   * @brief See @ref RTEMSDeviceGRLIBSPWMAPPTIMER.
-  uint32_t ptimer;
-  uint32_t reserved_904_980[ 31 ];
-   * @brief See @ref RTEMSDeviceGRLIBSPWMAPPCTRL2CFG.
-  uint32_t pctrl2cfg;
-   * @brief See @ref RTEMSDeviceGRLIBSPWMAPPCTRL2.
-  uint32_t pctrl2;
-  uint32_t reserved_988_a00[ 30 ];
-   * @brief See @ref RTEMSDeviceGRLIBSPWMAPRTRCFG.
-  uint32_t rtrcfg;
-   * @brief See @ref RTEMSDeviceGRLIBSPWMAPTC.
-  uint32_t tc;
-   * @brief See @ref RTEMSDeviceGRLIBSPWMAPVER.
-  uint32_t ver;
-   * @brief See @ref RTEMSDeviceGRLIBSPWMAPIDIV.
-  uint32_t idiv;
-   * @brief See @ref RTEMSDeviceGRLIBSPWMAPCFGWE.
-  uint32_t cfgwe;
-   * @brief See @ref RTEMSDeviceGRLIBSPWMAPPRESCALER.
-  uint32_t prescaler;
-   * @brief See @ref RTEMSDeviceGRLIBSPWMAPIMASK.
-  uint32_t imask;
-   * @brief See @ref RTEMSDeviceGRLIBSPWMAPIPMASK.
-  uint32_t ipmask;
-   * @brief See @ref RTEMSDeviceGRLIBSPWMAPPIP.
-  uint32_t pip;
-   * @brief See @ref RTEMSDeviceGRLIBSPWMAPICODEGEN.
-  uint32_t icodegen;
-   * @brief See @ref RTEMSDeviceGRLIBSPWMAPISR0.
-  uint32_t isr0;
-   * @brief See @ref RTEMSDeviceGRLIBSPWMAPISR1.
-  uint32_t isr1;
-   * @brief See @ref RTEMSDeviceGRLIBSPWMAPISRTIMER.
-  uint32_t isrtimer;
-   * @brief See @ref RTEMSDeviceGRLIBSPWMAPAITIMER.
-  uint32_t aitimer;
-   * @brief See @ref RTEMSDeviceGRLIBSPWMAPISRCTIMER.
-  uint32_t isrctimer;
-  uint32_t reserved_a3c_a40;
-   * @brief See @ref RTEMSDeviceGRLIBSPWMAPLRUNSTAT.
-  uint32_t lrunstat;
-   * @brief See @ref RTEMSDeviceGRLIBSPWMAPCAP.
-  uint32_t cap;
-  uint32_t reserved_a48_a50[ 2 ];
-   * @brief See @ref RTEMSDeviceGRLIBSPWMAPPNPVEND.
-  uint32_t pnpvend;
-   * @brief See @ref RTEMSDeviceGRLIBSPWMAPPNPUVEND.
-  uint32_t pnpuvend;
-   * @brief See @ref RTEMSDeviceGRLIBSPWMAPPNPUSN.
-  uint32_t pnpusn;
-  uint32_t reserved_a5c_e00[ 233 ];
-   * @brief See @ref RTEMSDeviceGRLIBSPWMAPMAXPLEN.
-  uint32_t maxplen;
-  uint32_t reserved_e04_e84[ 32 ];
-   * @brief See @ref RTEMSDeviceGRLIBSPWMAPCREDCNT.
-  uint32_t credcnt;
-  uint32_t reserved_e88_1004[ 95 ];
-   * @brief See @ref RTEMSDeviceGRLIBSPWMAPRTCOMB.
-  uint32_t rtcomb;
-} spwrmap;
-#ifdef __cplusplus
-#endif
-#endif /* _GRLIB_SPWRMAP_REGS_H */
2.35.3
