[PATCH v3 00/38] Integrate pre-qualified LEON3 BSP
Martin Åberg maberg at gaisler.com
Thu Jul 13 08:43:49 UTC 2023
On 2023-07-12 15:49, Sebastian Huber wrote:
> v3:
> * Restore previous behaviour of gptimer_tlib_reset().
> * Use new IRQ(A)MP register block API also for
>    LEON_Enable_interrupt_broadcast() and
>    LEON_Disable_interrupt_broadcast().
> * Add GRCAN - CanTxIRQ.
> * Expand GRCLKGATE register bit fields.
> * Move GR740-specific register blocks.
OK
> * Use GRLIB definition of GRSPW2
> * Remove obsolete register block.  This register block was an incomplete
>    duplicate of spec:/dev/grlib/if/grspw2.
> * Use GRLIB definition of GRSPWROUTER.  Rename item to match with GRLIB
>    naming.
This looks great. Thanks!
All commits in the patch set are OK now.
Best regards,
Martin Åberg
Software Engineer
Frontgrade Gaisler
martin.aberg at gaisler.com
Frontgrade Gaisler AB, Kungsgatan 12, SE-411 19 GÖTEBORG, Sweden.
+46 (0) 31 775 8650, www.gaisler.com
