[PATCH] bsps/arm: replace CMSIS v4 with CMSIS v5 files
Karel Gardas karel at functional.vision
Thu Jul 13 21:05:46 UTC 2023
CAVEAT: license change from BSD to Apache2 license!
Explanation:
The imported files come from CMSIS v5 project available on:
https://github.com/ARM-software/CMSIS_5/tree/develop
The files imported are located inside the CMSIS/Core/Include
project sub-directory.
The project does not provide any NOTICE file in its root directory nor
in the directory of the imported files.
The NOTICE file and its usage in the Apache 2 license was/is
so far the only issue mentioned in discussion of RTEMS developers/users
when considering inclusion of the code under Apache 2 license
into the RTEMS project.
Since the CMSIS v5 project is free from this legal hinder, we may freely
use it and update files to the latest version.
Technical: the patch replaces code from 2015 with the latest version
which brings quite a lot of bug fixes and most importantly opens
possibilities to support MCUs based on new ARM cores.
 bsps/arm/include/cachel1_armv7.h  |  441 +++
 bsps/arm/include/cmsis_compiler.h |  303 ++
 bsps/arm/include/cmsis_gcc.h      | 3592 +++++++++++++--------
 bsps/arm/include/cmsis_version.h  |   39 +
 bsps/arm/include/core_cm4.h       |  629 ++--
 bsps/arm/include/core_cm7.h       | 4922 ++++++++++++++---------------
 bsps/arm/include/core_cmFunc.h    |   87 -
 bsps/arm/include/core_cmInstr.h   |   88 -
 bsps/arm/include/core_cmSimd.h    |   97 -
 bsps/arm/include/mpu_armv7.h      |  275 ++
 10 files changed, 6113 insertions(+), 4360 deletions(-)
 create mode 100644 bsps/arm/include/cachel1_armv7.h
 create mode 100644 bsps/arm/include/cmsis_compiler.h
 create mode 100644 bsps/arm/include/cmsis_version.h
 delete mode 100644 bsps/arm/include/core_cmFunc.h
 delete mode 100644 bsps/arm/include/core_cmInstr.h
 delete mode 100644 bsps/arm/include/core_cmSimd.h
 create mode 100644 bsps/arm/include/mpu_armv7.h
diff --git a/bsps/arm/include/cachel1_armv7.h b/bsps/arm/include/cachel1_armv7.h
new file mode 100644
index 0000000000..13215e223b
--- /dev/null
+++ b/bsps/arm/include/cachel1_armv7.h
@@ -0,0 +1,441 @@
+ * @file     cachel1_armv7.h
+ * @brief    CMSIS Level 1 Cache API for Armv7-M and later
+ * @version  V1.0.3
+ * @date     17. March 2023
+ * Copyright (c) 2020-2021 Arm Limited. All rights reserved.
+ * SPDX-License-Identifier: Apache-2.0
+ * Licensed under the Apache License, Version 2.0 (the License); you may
+ * not use this file except in compliance with the License.
+ * You may obtain a copy of the License at
+ * www.apache.org/licenses/LICENSE-2.0
+ * Unless required by applicable law or agreed to in writing, software
+ * distributed under the License is distributed on an AS IS BASIS, WITHOUT
+ * WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+ * See the License for the specific language governing permissions and
+ * limitations under the License.
+#if   defined ( __ICCARM__ )
+  #pragma system_include         /* treat file as system include file for MISRA check */
+#elif defined (__clang__)
+  #pragma clang system_header    /* treat file as system include file */
+#endif
+#ifndef ARM_CACHEL1_ARMV7_H
+#define ARM_CACHEL1_ARMV7_H
+  \ingroup  CMSIS_Core_FunctionInterface
+  \defgroup CMSIS_Core_CacheFunctions Cache Functions
+  \brief    Functions that configure Instruction and Data cache.
+/* Cache Size ID Register Macros */
+#define CCSIDR_WAYS(x)         (((x) & SCB_CCSIDR_ASSOCIATIVITY_Msk) >> SCB_CCSIDR_ASSOCIATIVITY_Pos)
+#define CCSIDR_SETS(x)         (((x) & SCB_CCSIDR_NUMSETS_Msk      ) >> SCB_CCSIDR_NUMSETS_Pos      )
+#ifndef __SCB_DCACHE_LINE_SIZE
+#define __SCB_DCACHE_LINE_SIZE  32U /*!< Cortex-M7 cache line size is fixed to 32 bytes (8 words). See also register SCB_CCSIDR */
+#endif
+#ifndef __SCB_ICACHE_LINE_SIZE
+#define __SCB_ICACHE_LINE_SIZE  32U /*!< Cortex-M7 cache line size is fixed to 32 bytes (8 words). See also register SCB_CCSIDR */
+#endif
+  \brief   Enable I-Cache
+  \details Turns on I-Cache
+__STATIC_FORCEINLINE void SCB_EnableICache (void)
+  #if defined (__ICACHE_PRESENT) && (__ICACHE_PRESENT == 1U)
+    if (SCB->CCR & SCB_CCR_IC_Msk) return;  /* return if ICache is already enabled */
+    __DSB();
+    __ISB();
+    SCB->ICIALLU = 0UL;                     /* invalidate I-Cache */
+    __DSB();
+    __ISB();
+    SCB->CCR |=  (uint32_t)SCB_CCR_IC_Msk;  /* enable I-Cache */
+    __DSB();
+    __ISB();
+  #endif
+  \brief   Disable I-Cache
+  \details Turns off I-Cache
+__STATIC_FORCEINLINE void SCB_DisableICache (void)
+    __DSB();
+    __ISB();
+    SCB->CCR &= ~(uint32_t)SCB_CCR_IC_Msk;  /* disable I-Cache */
+    __DSB();
+    __ISB();
+  #endif
+  \brief   Invalidate I-Cache
+  \details Invalidates I-Cache
+__STATIC_FORCEINLINE void SCB_InvalidateICache (void)
+    __DSB();
+    __ISB();
+    __DSB();
+    __ISB();
+  #endif
+  \brief   I-Cache Invalidate by address
+  \details Invalidates I-Cache for the given address.
+           I-Cache is invalidated starting from a 32 byte aligned address in 32 byte granularity.
+           I-Cache memory blocks which are part of given address + given size are invalidated.
+  \param[in]   addr    address
+  \param[in]   isize   size of memory block (in number of bytes)
+__STATIC_FORCEINLINE void SCB_InvalidateICache_by_Addr (volatile void *addr, int32_t isize)
+    if ( isize > 0 ) {
+       int32_t op_size = isize + (((uint32_t)addr) & (__SCB_ICACHE_LINE_SIZE - 1U));
+      uint32_t op_addr = (uint32_t)addr /* & ~(__SCB_ICACHE_LINE_SIZE - 1U) */;
+      __DSB();
+      do {
+        SCB->ICIMVAU = op_addr;             /* register accepts only 32byte aligned values, only bits 31..5 are valid */
+        op_addr += __SCB_ICACHE_LINE_SIZE;
+        op_size -= __SCB_ICACHE_LINE_SIZE;
+      } while ( op_size > 0 );
+      __DSB();
+      __ISB();
+  #endif
+  \brief   Enable D-Cache
+  \details Turns on D-Cache
+__STATIC_FORCEINLINE void SCB_EnableDCache (void)
+  #if defined (__DCACHE_PRESENT) && (__DCACHE_PRESENT == 1U)
+    uint32_t ccsidr;
+    uint32_t sets;
+    uint32_t ways;
+    if (SCB->CCR & SCB_CCR_DC_Msk) return;  /* return if DCache is already enabled */
+    SCB->CSSELR = 0U;                       /* select Level 1 data cache */
+    __DSB();
+    ccsidr = SCB->CCSIDR;
+                                            /* invalidate D-Cache */
+    sets = (uint32_t)(CCSIDR_SETS(ccsidr));
+    do {
+      ways = (uint32_t)(CCSIDR_WAYS(ccsidr));
+      do {
+        SCB->DCISW = (((sets << SCB_DCISW_SET_Pos) & SCB_DCISW_SET_Msk) |
+                      ((ways << SCB_DCISW_WAY_Pos) & SCB_DCISW_WAY_Msk)  );
+        #if defined ( __CC_ARM )
+          __schedule_barrier();
+        #endif
+      } while (ways-- != 0U);
+    } while(sets-- != 0U);
+    __DSB();
+    SCB->CCR |=  (uint32_t)SCB_CCR_DC_Msk;  /* enable D-Cache */
+    __DSB();
+    __ISB();
+  #endif
+  \brief   Disable D-Cache
+  \details Turns off D-Cache
+__STATIC_FORCEINLINE void SCB_DisableDCache (void)
+    struct {
+      uint32_t ccsidr;
+      uint32_t sets;
+      uint32_t ways;
+    } locals
+    #if ((defined(__GNUC__) || defined(__clang__)) && !defined(__OPTIMIZE__))
+       __ALIGNED(__SCB_DCACHE_LINE_SIZE)
+    #endif
+    __DSB();
+    SCB->CCR &= ~(uint32_t)SCB_CCR_DC_Msk;  /* disable D-Cache */
+    __DSB();
+    #if !defined(__OPTIMIZE__)
+       * For the endless loop issue with no optimization builds.
+       * More details, see https://github.com/ARM-software/CMSIS_5/issues/620
+       * The issue only happens when local variables are in stack. If
+       * local variables are saved in general purpose register, then the function
+       * is OK.
+       * When local variables are in stack, after disabling the cache, flush the
+       * local variables cache line for data consistency.
+      /* Clean and invalidate the local variable cache. */
+    #if defined(__ICCARM__)
+    /* As we can't align the stack to the cache line size, invalidate each of the variables */
+      SCB->DCCIMVAC = (uint32_t)&locals.sets;
+      SCB->DCCIMVAC = (uint32_t)&locals.ways;
+      SCB->DCCIMVAC = (uint32_t)&locals.ccsidr;
+    #else
+      SCB->DCCIMVAC = (uint32_t)&locals;
+    #endif
+      __DSB();
+      __ISB();
+    #endif
+    locals.ccsidr = SCB->CCSIDR;
+                                            /* clean & invalidate D-Cache */
+    locals.sets = (uint32_t)(CCSIDR_SETS(locals.ccsidr));
+    do {
+      locals.ways = (uint32_t)(CCSIDR_WAYS(locals.ccsidr));
+      do {
+        SCB->DCCISW = (((locals.sets << SCB_DCCISW_SET_Pos) & SCB_DCCISW_SET_Msk) |
+                       ((locals.ways << SCB_DCCISW_WAY_Pos) & SCB_DCCISW_WAY_Msk)  );
+        #endif
+      } while (locals.ways-- != 0U);
+    } while(locals.sets-- != 0U);
+    __DSB();
+    __ISB();
+  #endif
+  \brief   Invalidate D-Cache
+  \details Invalidates D-Cache
+__STATIC_FORCEINLINE void SCB_InvalidateDCache (void)
+    uint32_t ccsidr;
+    uint32_t sets;
+    uint32_t ways;
+    __DSB();
+    do {
+      do {
+        #endif
+    __DSB();
+    __ISB();
+  #endif
+  \brief   Clean D-Cache
+  \details Cleans D-Cache
+__STATIC_FORCEINLINE void SCB_CleanDCache (void)
+    uint32_t ccsidr;
+    uint32_t sets;
+    uint32_t ways;
+    __DSB();
+                                            /* clean D-Cache */
+    do {
+      do {
+        SCB->DCCSW = (((sets << SCB_DCCSW_SET_Pos) & SCB_DCCSW_SET_Msk) |
+                      ((ways << SCB_DCCSW_WAY_Pos) & SCB_DCCSW_WAY_Msk)  );
+        #endif
+    __DSB();
+    __ISB();
+  #endif
+  \brief   Clean & Invalidate D-Cache
+  \details Cleans and Invalidates D-Cache
+__STATIC_FORCEINLINE void SCB_CleanInvalidateDCache (void)
+    uint32_t ccsidr;
+    uint32_t sets;
+    uint32_t ways;
+    __DSB();
+    do {
+      do {
+        SCB->DCCISW = (((sets << SCB_DCCISW_SET_Pos) & SCB_DCCISW_SET_Msk) |
+                       ((ways << SCB_DCCISW_WAY_Pos) & SCB_DCCISW_WAY_Msk)  );
+        #endif
+    __DSB();
+    __ISB();
+  #endif
+  \brief   D-Cache Invalidate by address
+  \details Invalidates D-Cache for the given address.
+           D-Cache is invalidated starting from a 32 byte aligned address in 32 byte granularity.
+           D-Cache memory blocks which are part of given address + given size are invalidated.
+  \param[in]   dsize   size of memory block (in number of bytes)
+__STATIC_FORCEINLINE void SCB_InvalidateDCache_by_Addr (volatile void *addr, int32_t dsize)
+    if ( dsize > 0 ) {
+       int32_t op_size = dsize + (((uint32_t)addr) & (__SCB_DCACHE_LINE_SIZE - 1U));
+      uint32_t op_addr = (uint32_t)addr /* & ~(__SCB_DCACHE_LINE_SIZE - 1U) */;
+      __DSB();
+      do {
+        SCB->DCIMVAC = op_addr;             /* register accepts only 32byte aligned values, only bits 31..5 are valid */
+        op_addr += __SCB_DCACHE_LINE_SIZE;
+        op_size -= __SCB_DCACHE_LINE_SIZE;
+      __DSB();
+      __ISB();
+  #endif
+  \brief   D-Cache Clean by address
+  \details Cleans D-Cache for the given address
+           D-Cache is cleaned starting from a 32 byte aligned address in 32 byte granularity.
+           D-Cache memory blocks which are part of given address + given size are cleaned.
+__STATIC_FORCEINLINE void SCB_CleanDCache_by_Addr (volatile void *addr, int32_t dsize)
+      __DSB();
+      do {
+        SCB->DCCMVAC = op_addr;             /* register accepts only 32byte aligned values, only bits 31..5 are valid */
+      __DSB();
+      __ISB();
+  #endif
+  \brief   D-Cache Clean and Invalidate by address
+  \details Cleans and invalidates D_Cache for the given address
+           D-Cache is cleaned and invalidated starting from a 32 byte aligned address in 32 byte granularity.
+           D-Cache memory blocks which are part of given address + given size are cleaned and invalidated.
+  \param[in]   addr    address (aligned to 32-byte boundary)
+__STATIC_FORCEINLINE void SCB_CleanInvalidateDCache_by_Addr (volatile void *addr, int32_t dsize)
+      __DSB();
+      do {
+        SCB->DCCIMVAC = op_addr;            /* register accepts only 32byte aligned values, only bits 31..5 are valid */
+      __DSB();
+      __ISB();
+  #endif
+/*@} end of CMSIS_Core_CacheFunctions */
+#endif /* ARM_CACHEL1_ARMV7_H */
diff --git a/bsps/arm/include/cmsis_compiler.h b/bsps/arm/include/cmsis_compiler.h
index 0000000000..192f9b7c93
--- /dev/null
+++ b/bsps/arm/include/cmsis_compiler.h
@@ -0,0 +1,303 @@
+ * @file     cmsis_compiler.h
+ * @brief    CMSIS compiler generic header file
+ * @version  V5.3.0
+ * @date     04. April 2023
+ * Copyright (c) 2009-2023 Arm Limited. All rights reserved.
+#ifndef __CMSIS_COMPILER_H
+#define __CMSIS_COMPILER_H
+#include <stdint.h>
+ * Arm Compiler 4/5
+#if   defined ( __CC_ARM )
+  #include "cmsis_armcc.h"
+ * Arm Compiler 6.6 LTM (armclang)
+#elif defined (__ARMCC_VERSION) && (__ARMCC_VERSION >= 6010050) && (__ARMCC_VERSION < 6100100)
+  #include "cmsis_armclang_ltm.h"
+ * Arm Compiler above 6.10.1 (armclang)
+#elif defined (__ARMCC_VERSION) && (__ARMCC_VERSION >= 6100100)
+  #include "cmsis_armclang.h"
+ * TI Arm Clang Compiler (tiarmclang)
+#elif defined (__ti__)
+  #include "cmsis_tiarmclang.h"
+ * GNU Compiler
+#elif defined ( __GNUC__ )
+  #include "cmsis_gcc.h"
+ * IAR Compiler
+#elif defined ( __ICCARM__ )
+  #include <cmsis_iccarm.h>
+ * TI Arm Compiler (armcl)
+#elif defined ( __TI_ARM__ )
+  #include <cmsis_ccs.h>
+  #ifndef   __ASM
+    #define __ASM                                  __asm
+  #endif
+  #ifndef   __INLINE
+    #define __INLINE                               inline
+  #endif
+  #ifndef   __STATIC_INLINE
+    #define __STATIC_INLINE                        static inline
+  #endif
+  #ifndef   __STATIC_FORCEINLINE
+    #define __STATIC_FORCEINLINE                   __STATIC_INLINE
+  #endif
+  #ifndef   __NO_RETURN
+    #define __NO_RETURN                            __attribute__((noreturn))
+  #endif
+  #ifndef   __USED
+    #define __USED                                 __attribute__((used))
+  #endif
+  #ifndef   __WEAK
+    #define __WEAK                                 __attribute__((weak))
+  #endif
+  #ifndef   __PACKED
+    #define __PACKED                               __attribute__((packed))
+  #endif
+  #ifndef   __PACKED_STRUCT
+    #define __PACKED_STRUCT                        struct __attribute__((packed))
+  #endif
+  #ifndef   __PACKED_UNION
+    #define __PACKED_UNION                         union __attribute__((packed))
+  #endif
+  #ifndef   __UNALIGNED_UINT32        /* deprecated */
+    struct __attribute__((packed)) T_UINT32 { uint32_t v; };
+    #define __UNALIGNED_UINT32(x)                  (((struct T_UINT32 *)(x))->v)
+  #endif
+  #ifndef   __UNALIGNED_UINT16_WRITE
+    __PACKED_STRUCT T_UINT16_WRITE { uint16_t v; };
+    #define __UNALIGNED_UINT16_WRITE(addr, val)    (void)((((struct T_UINT16_WRITE *)(void*)(addr))->v) = (val))
+  #endif
+  #ifndef   __UNALIGNED_UINT16_READ
+    __PACKED_STRUCT T_UINT16_READ { uint16_t v; };
+    #define __UNALIGNED_UINT16_READ(addr)          (((const struct T_UINT16_READ *)(const void *)(addr))->v)
+  #endif
+  #ifndef   __UNALIGNED_UINT32_WRITE
+    __PACKED_STRUCT T_UINT32_WRITE { uint32_t v; };
+    #define __UNALIGNED_UINT32_WRITE(addr, val)    (void)((((struct T_UINT32_WRITE *)(void *)(addr))->v) = (val))
+  #endif
+  #ifndef   __UNALIGNED_UINT32_READ
+    __PACKED_STRUCT T_UINT32_READ { uint32_t v; };
+    #define __UNALIGNED_UINT32_READ(addr)          (((const struct T_UINT32_READ *)(const void *)(addr))->v)
+  #endif
+  #ifndef   __ALIGNED
+    #define __ALIGNED(x)                           __attribute__((aligned(x)))
+  #endif
+  #ifndef   __RESTRICT
+    #define __RESTRICT                             __restrict
+  #endif
+  #ifndef   __COMPILER_BARRIER
+    #warning No compiler specific solution for __COMPILER_BARRIER. __COMPILER_BARRIER is ignored.
+    #define __COMPILER_BARRIER()                   (void)0
+  #endif
+  #ifndef __NO_INIT
+    #define __NO_INIT                              __attribute__ ((section (".bss.noinit")))
+  #endif
+  #ifndef __ALIAS
+    #define __ALIAS(x)                             __attribute__ ((alias(x)))
+  #endif
+ * TASKING Compiler
+#elif defined ( __TASKING__ )
+   * The CMSIS functions have been implemented as intrinsics in the compiler.
+   * Please use "carm -?i" to get an up to date list of all intrinsics,
+   * Including the CMSIS ones.
+  #ifndef   __ASM
+  #endif
+  #ifndef   __INLINE
+  #endif
+  #endif
+  #endif
+  #endif
+  #ifndef   __USED
+  #endif
+  #ifndef   __WEAK
+  #endif
+  #ifndef   __PACKED
+    #define __PACKED                               __packed__
+  #endif
+    #define __PACKED_STRUCT                        struct __packed__
+  #endif
+    #define __PACKED_UNION                         union __packed__
+  #endif
+    struct __packed__ T_UINT32 { uint32_t v; };
+  #endif
+    #define __UNALIGNED_UINT16_WRITE(addr, val)    (void)((((struct T_UINT16_WRITE *)(void *)(addr))->v) = (val))
+  #endif
+  #endif
+  #endif
+  #endif
+  #ifndef   __ALIGNED
+    #define __ALIGNED(x)              __align(x)
+  #endif
+    #warning No compiler specific solution for __RESTRICT. __RESTRICT is ignored.
+  #endif
+  #endif
+  #ifndef __NO_INIT
+  #endif
+  #ifndef __ALIAS
+  #endif
+ * COSMIC Compiler
+#elif defined ( __CSMC__ )
+   #include <cmsis_csm.h>
+ #ifndef   __ASM
+    #define __ASM                                  _asm
+  #endif
+  #ifndef   __INLINE
+  #endif
+  #endif
+  #endif
+    // NO RETURN is automatically detected hence no warning here
+  #endif
+  #ifndef   __USED
+    #warning No compiler specific solution for __USED. __USED is ignored.
+    #define __USED
+  #endif
+  #ifndef   __WEAK
+    #define __WEAK                                 __weak
+  #endif
+  #ifndef   __PACKED
+    #define __PACKED                               @packed
+  #endif
+    #define __PACKED_STRUCT                        @packed struct
+  #endif
+    #define __PACKED_UNION                         @packed union
+  #endif
+    @packed struct T_UINT32 { uint32_t v; };
+  #endif
+  #endif
+  #endif
+  #endif
+  #endif
+  #ifndef   __ALIGNED
+    #warning No compiler specific solution for __ALIGNED. __ALIGNED is ignored.
+  #endif
+  #endif
+  #endif
+  #ifndef __NO_INIT
+  #endif
+  #ifndef __ALIAS
+  #endif
+#else
+  #error Unknown compiler.
+#endif
+#endif /* __CMSIS_COMPILER_H */
diff --git a/bsps/arm/include/cmsis_gcc.h b/bsps/arm/include/cmsis_gcc.h
index ea32ae7b4a..4f0762d6dc 100644
--- a/bsps/arm/include/cmsis_gcc.h
+++ b/bsps/arm/include/cmsis_gcc.h
@@ -1,1375 +1,2217 @@
- * @file
- * @brief    CMSIS Cortex-M Core Function/Instruction Header File
- * @version  V4.30
- * @date     20. October 2015
-/* Copyright (c) 2009 - 2015 ARM LIMITED
-   All rights reserved.
-   Redistribution and use in source and binary forms, with or without
-   modification, are permitted provided that the following conditions are met:
-   - Redistributions of source code must retain the above copyright
-     notice, this list of conditions and the following disclaimer.
-   - Redistributions in binary form must reproduce the above copyright
-     notice, this list of conditions and the following disclaimer in the
-     documentation and/or other materials provided with the distribution.
-   - Neither the name of ARM nor the names of its contributors may be used
-     to endorse or promote products derived from this software without
-     specific prior written permission.
-   THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
-   AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
-   IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
-   ARE DISCLAIMED. IN NO EVENT SHALL COPYRIGHT HOLDERS AND CONTRIBUTORS BE
-   LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
-   CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
-   SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
-   INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
-   CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
-   ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
-   POSSIBILITY OF SUCH DAMAGE.
-#ifndef __CMSIS_GCC_H
-#define __CMSIS_GCC_H
-/* ignore some GCC warnings */
-#if defined ( __GNUC__ )
-#pragma GCC diagnostic push
-#pragma GCC diagnostic ignored "-Wsign-conversion"
-#pragma GCC diagnostic ignored "-Wconversion"
-#pragma GCC diagnostic ignored "-Wunused-parameter"
-#endif
-/* ###########################  Core Function Access  ########################### */
-/** \ingroup  CMSIS_Core_FunctionInterface
-    \defgroup CMSIS_Core_RegAccFunctions CMSIS Core Register Access Functions
-  \brief   Enable IRQ Interrupts
-  \details Enables IRQ interrupts by clearing the I-bit in the CPSR.
-           Can only be executed in Privileged modes.
-__attribute__( ( always_inline ) ) __STATIC_INLINE void __enable_irq(void)
-  __ASM volatile ("cpsie i" : : : "memory");
-  \brief   Disable IRQ Interrupts
-  \details Disables IRQ interrupts by setting the I-bit in the CPSR.
-__attribute__( ( always_inline ) ) __STATIC_INLINE void __disable_irq(void)
-  __ASM volatile ("cpsid i" : : : "memory");
-  \brief   Get Control Register
-  \details Returns the content of the Control Register.
-  \return               Control Register value
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_CONTROL(void)
-  uint32_t result;
-  __ASM volatile ("MRS %0, control" : "=r" (result) );
-  return(result);
-  \brief   Set Control Register
-  \details Writes the given value to the Control Register.
-  \param [in]    control  Control Register value to set
-__attribute__( ( always_inline ) ) __STATIC_INLINE void __set_CONTROL(uint32_t control)
-  __ASM volatile ("MSR control, %0" : : "r" (control) : "memory");
-  \brief   Get IPSR Register
-  \details Returns the content of the IPSR Register.
-  \return               IPSR Register value
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_IPSR(void)
-  uint32_t result;
-  __ASM volatile ("MRS %0, ipsr" : "=r" (result) );
-  return(result);
-  \brief   Get APSR Register
-  \details Returns the content of the APSR Register.
-  \return               APSR Register value
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_APSR(void)
-  uint32_t result;
-  __ASM volatile ("MRS %0, apsr" : "=r" (result) );
-  return(result);
-  \brief   Get xPSR Register
-  \details Returns the content of the xPSR Register.
-    \return               xPSR Register value
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_xPSR(void)
-  uint32_t result;
-  __ASM volatile ("MRS %0, xpsr" : "=r" (result) );
-  return(result);
-  \brief   Get Process Stack Pointer
-  \details Returns the current value of the Process Stack Pointer (PSP).
-  \return               PSP Register value
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_PSP(void)
-  register uint32_t result;
-  __ASM volatile ("MRS %0, psp\n"  : "=r" (result) );
-  return(result);
-  \brief   Set Process Stack Pointer
-  \details Assigns the given value to the Process Stack Pointer (PSP).
-  \param [in]    topOfProcStack  Process Stack Pointer value to set
-__attribute__( ( always_inline ) ) __STATIC_INLINE void __set_PSP(uint32_t topOfProcStack)
-  __ASM volatile ("MSR psp, %0\n" : : "r" (topOfProcStack) : "sp");
-  \brief   Get Main Stack Pointer
-  \details Returns the current value of the Main Stack Pointer (MSP).
-  \return               MSP Register value
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_MSP(void)
-  __ASM volatile ("MRS %0, msp\n" : "=r" (result) );
-  return(result);
-  \brief   Set Main Stack Pointer
-  \details Assigns the given value to the Main Stack Pointer (MSP).
-    \param [in]    topOfMainStack  Main Stack Pointer value to set
-__attribute__( ( always_inline ) ) __STATIC_INLINE void __set_MSP(uint32_t topOfMainStack)
-  __ASM volatile ("MSR msp, %0\n" : : "r" (topOfMainStack) : "sp");
-  \brief   Get Priority Mask
-  \details Returns the current state of the priority mask bit from the Priority Mask Register.
-  \return               Priority Mask value
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_PRIMASK(void)
-  uint32_t result;
-  __ASM volatile ("MRS %0, primask" : "=r" (result) );
-  return(result);
-  \brief   Set Priority Mask
-  \details Assigns the given value to the Priority Mask Register.
-  \param [in]    priMask  Priority Mask
-__attribute__( ( always_inline ) ) __STATIC_INLINE void __set_PRIMASK(uint32_t priMask)
-  __ASM volatile ("MSR primask, %0" : : "r" (priMask) : "memory");
-#if       (__CORTEX_M >= 0x03U)
-  \brief   Enable FIQ
-  \details Enables FIQ interrupts by clearing the F-bit in the CPSR.
-__attribute__( ( always_inline ) ) __STATIC_INLINE void __enable_fault_irq(void)
-  __ASM volatile ("cpsie f" : : : "memory");
-  \brief   Disable FIQ
-  \details Disables FIQ interrupts by setting the F-bit in the CPSR.
-__attribute__( ( always_inline ) ) __STATIC_INLINE void __disable_fault_irq(void)
-  __ASM volatile ("cpsid f" : : : "memory");
-  \brief   Get Base Priority
-  \details Returns the current value of the Base Priority register.
-  \return               Base Priority register value
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_BASEPRI(void)
-  uint32_t result;
-  __ASM volatile ("MRS %0, basepri" : "=r" (result) );
-  return(result);
-  \brief   Set Base Priority
-  \details Assigns the given value to the Base Priority register.
-  \param [in]    basePri  Base Priority value to set
-__attribute__( ( always_inline ) ) __STATIC_INLINE void __set_BASEPRI(uint32_t value)
-  __ASM volatile ("MSR basepri, %0" : : "r" (value) : "memory");
-  \brief   Set Base Priority with condition
-  \details Assigns the given value to the Base Priority register only if BASEPRI masking is disabled,
-           or the new value increases the BASEPRI priority level.
-__attribute__( ( always_inline ) ) __STATIC_INLINE void __set_BASEPRI_MAX(uint32_t value)
-  __ASM volatile ("MSR basepri_max, %0" : : "r" (value) : "memory");
-  \brief   Get Fault Mask
-  \details Returns the current value of the Fault Mask register.
-  \return               Fault Mask register value
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_FAULTMASK(void)
-  uint32_t result;
-  __ASM volatile ("MRS %0, faultmask" : "=r" (result) );
-  return(result);
-  \brief   Set Fault Mask
-  \details Assigns the given value to the Fault Mask register.
-  \param [in]    faultMask  Fault Mask value to set
-__attribute__( ( always_inline ) ) __STATIC_INLINE void __set_FAULTMASK(uint32_t faultMask)
-  __ASM volatile ("MSR faultmask, %0" : : "r" (faultMask) : "memory");
-#endif /* (__CORTEX_M >= 0x03U) */
-#if       (__CORTEX_M == 0x04U) || (__CORTEX_M == 0x07U)
-  \brief   Get FPSCR
-  \details Returns the current value of the Floating Point Status/Control register.
-  \return               Floating Point Status/Control register value
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __get_FPSCR(void)
-#if (__FPU_PRESENT == 1U) && (__FPU_USED == 1U)
-  uint32_t result;
-  /* Empty asm statement works as a scheduling barrier */
-  __ASM volatile ("");
-  __ASM volatile ("VMRS %0, fpscr" : "=r" (result) );
-  return(result);
-#else
-   return(0);
-#endif
-  \brief   Set FPSCR
-  \details Assigns the given value to the Floating Point Status/Control register.
-  \param [in]    fpscr  Floating Point Status/Control value to set
-__attribute__( ( always_inline ) ) __STATIC_INLINE void __set_FPSCR(uint32_t fpscr)
-  __ASM volatile ("VMSR fpscr, %0" : : "r" (fpscr) : "vfpcc");
-#endif
-#endif /* (__CORTEX_M == 0x04U) || (__CORTEX_M == 0x07U) */
-/*@} end of CMSIS_Core_RegAccFunctions */
-/* ##########################  Core Instruction Access  ######################### */
-/** \defgroup CMSIS_Core_InstructionInterface CMSIS Core Instruction Interface
-  \ingroup CMSIS
-  Access to dedicated instructions
-/* Define macros for porting to both thumb1 and thumb2.
- * For thumb1, use low register (r0-r7), specified by constraint "l"
- * Otherwise, use general registers, specified by constraint "r" */
-#if defined (__thumb__) && !defined (__thumb2__)
-#define __CMSIS_GCC_OUT_REG(r) "=l" (r)
-#define __CMSIS_GCC_USE_REG(r) "l" (r)
-#else
-#define __CMSIS_GCC_OUT_REG(r) "=r" (r)
-#define __CMSIS_GCC_USE_REG(r) "r" (r)
-#endif
-  \brief   No Operation
-  \details No Operation does nothing. This instruction can be used for code alignment purposes.
-__attribute__((always_inline)) __STATIC_INLINE void __NOP(void)
-  __ASM volatile ("nop");
-  \brief   Wait For Interrupt
-  \details Wait For Interrupt is a hint instruction that suspends execution until one of a number of events occurs.
-__attribute__((always_inline)) __STATIC_INLINE void __WFI(void)
-  __ASM volatile ("wfi");
-  \brief   Wait For Event
-  \details Wait For Event is a hint instruction that permits the processor to enter
-    a low-power state until one of a number of events occurs.
-__attribute__((always_inline)) __STATIC_INLINE void __WFE(void)
-  __ASM volatile ("wfe");
-  \brief   Send Event
-  \details Send Event is a hint instruction. It causes an event to be signaled to the CPU.
-__attribute__((always_inline)) __STATIC_INLINE void __SEV(void)
-  __ASM volatile ("sev");
-  \brief   Instruction Synchronization Barrier
-  \details Instruction Synchronization Barrier flushes the pipeline in the processor,
-           so that all instructions following the ISB are fetched from cache or memory,
-           after the instruction has been completed.
-__attribute__((always_inline)) __STATIC_INLINE void __ISB(void)
-  __ASM volatile ("isb 0xF":::"memory");
-  \brief   Data Synchronization Barrier
-  \details Acts as a special kind of Data Memory Barrier.
-           It completes when all explicit memory accesses before this instruction complete.
-__attribute__((always_inline)) __STATIC_INLINE void __DSB(void)
-  __ASM volatile ("dsb 0xF":::"memory");
-  \brief   Data Memory Barrier
-  \details Ensures the apparent order of the explicit memory operations before
-           and after the instruction, without ensuring their completion.
-__attribute__((always_inline)) __STATIC_INLINE void __DMB(void)
-  __ASM volatile ("dmb 0xF":::"memory");
-  \brief   Reverse byte order (32 bit)
-  \details Reverses the byte order in integer value.
-  \param [in]    value  Value to reverse
-  \return               Reversed value
-__attribute__((always_inline)) __STATIC_INLINE uint32_t __REV(uint32_t value)
-#if (__GNUC__ > 4) || (__GNUC__ == 4 && __GNUC_MINOR__ >= 5)
-  return __builtin_bswap32(value);
-#else
-  uint32_t result;
-  __ASM volatile ("rev %0, %1" : __CMSIS_GCC_OUT_REG (result) : __CMSIS_GCC_USE_REG (value) );
-  return(result);
-#endif
-  \brief   Reverse byte order (16 bit)
-  \details Reverses the byte order in two unsigned short values.
-__attribute__((always_inline)) __STATIC_INLINE uint32_t __REV16(uint32_t value)
-  uint32_t result;
-  __ASM volatile ("rev16 %0, %1" : __CMSIS_GCC_OUT_REG (result) : __CMSIS_GCC_USE_REG (value) );
-  return(result);
-  \brief   Reverse byte order in signed short value
-  \details Reverses the byte order in a signed short value with sign extension to integer.
-__attribute__((always_inline)) __STATIC_INLINE int32_t __REVSH(int32_t value)
-#if (__GNUC__ > 4) || (__GNUC__ == 4 && __GNUC_MINOR__ >= 8)
-  return (short)__builtin_bswap16(value);
-#else
-  int32_t result;
-  __ASM volatile ("revsh %0, %1" : __CMSIS_GCC_OUT_REG (result) : __CMSIS_GCC_USE_REG (value) );
-  return(result);
-#endif
-  \brief   Rotate Right in unsigned value (32 bit)
-  \details Rotate Right (immediate) provides the value of the contents of a register rotated by a variable number of bits.
-  \param [in]    value  Value to rotate
-  \param [in]    value  Number of Bits to rotate
-  \return               Rotated value
-__attribute__((always_inline)) __STATIC_INLINE uint32_t __ROR(uint32_t op1, uint32_t op2)
-  return (op1 >> op2) | (op1 << (32U - op2));
-  \brief   Breakpoint
-  \details Causes the processor to enter Debug state.
-           Debug tools can use this to investigate system state when the instruction at a particular address is reached.
-  \param [in]    value  is ignored by the processor.
-                 If required, a debugger can use it to store additional information about the breakpoint.
-#define __BKPT(value)                       __ASM volatile ("bkpt "#value)
-  \brief   Reverse bit order of value
-  \details Reverses the bit order of the given value.
-__attribute__((always_inline)) __STATIC_INLINE uint32_t __RBIT(uint32_t value)
-  uint32_t result;
-#if       (__CORTEX_M >= 0x03U) || (__CORTEX_SC >= 300U)
-   __ASM volatile ("rbit %0, %1" : "=r" (result) : "r" (value) );
-#else
-  int32_t s = 4 /*sizeof(v)*/ * 8 - 1; /* extra shift needed at end */
-  result = value;                      /* r will be reversed bits of v; first get LSB of v */
-  for (value >>= 1U; value; value >>= 1U)
-    result <<= 1U;
-    result |= value & 1U;
-    s--;
-  result <<= s;                        /* shift when v's highest bits are zero */
-#endif
-  return(result);
-  \brief   Count leading zeros
-  \details Counts the number of leading zeros of a data value.
-  \param [in]  value  Value to count the leading zeros
-  \return             number of leading zeros in value
-#define __CLZ             __builtin_clz
-  \brief   LDR Exclusive (8 bit)
-  \details Executes a exclusive LDR instruction for 8 bit value.
-  \param [in]    ptr  Pointer to data
-  \return             value of type uint8_t at (*ptr)
-__attribute__((always_inline)) __STATIC_INLINE uint8_t __LDREXB(volatile uint8_t *addr)
-    uint32_t result;
-   __ASM volatile ("ldrexb %0, %1" : "=r" (result) : "Q" (*addr) );
-#else
-    /* Prior to GCC 4.8, "Q" will be expanded to [rx, #0] which is not
-       accepted by assembler. So has to use following less efficient pattern.
-   __ASM volatile ("ldrexb %0, [%1]" : "=r" (result) : "r" (addr) : "memory" );
-#endif
-   return ((uint8_t) result);    /* Add explicit type cast here */
-  \brief   LDR Exclusive (16 bit)
-  \details Executes a exclusive LDR instruction for 16 bit values.
-  \return        value of type uint16_t at (*ptr)
-__attribute__((always_inline)) __STATIC_INLINE uint16_t __LDREXH(volatile uint16_t *addr)
-    uint32_t result;
-   __ASM volatile ("ldrexh %0, %1" : "=r" (result) : "Q" (*addr) );
-#else
-   __ASM volatile ("ldrexh %0, [%1]" : "=r" (result) : "r" (addr) : "memory" );
-#endif
-   return ((uint16_t) result);    /* Add explicit type cast here */
-  \brief   LDR Exclusive (32 bit)
-  \details Executes a exclusive LDR instruction for 32 bit values.
-  \return        value of type uint32_t at (*ptr)
-__attribute__((always_inline)) __STATIC_INLINE uint32_t __LDREXW(volatile uint32_t *addr)
-    uint32_t result;
-   __ASM volatile ("ldrex %0, %1" : "=r" (result) : "Q" (*addr) );
-   return(result);
-  \brief   STR Exclusive (8 bit)
-  \details Executes a exclusive STR instruction for 8 bit values.
-  \param [in]  value  Value to store
-  \param [in]    ptr  Pointer to location
-  \return          0  Function succeeded
-  \return          1  Function failed
-__attribute__((always_inline)) __STATIC_INLINE uint32_t __STREXB(uint8_t value, volatile uint8_t *addr)
-   uint32_t result;
-   __ASM volatile ("strexb %0, %2, %1" : "=&r" (result), "=Q" (*addr) : "r" ((uint32_t)value) );
-   return(result);
-  \brief   STR Exclusive (16 bit)
-  \details Executes a exclusive STR instruction for 16 bit values.
-__attribute__((always_inline)) __STATIC_INLINE uint32_t __STREXH(uint16_t value, volatile uint16_t *addr)
-   uint32_t result;
-   __ASM volatile ("strexh %0, %2, %1" : "=&r" (result), "=Q" (*addr) : "r" ((uint32_t)value) );
-   return(result);
-  \brief   STR Exclusive (32 bit)
-  \details Executes a exclusive STR instruction for 32 bit values.
-__attribute__((always_inline)) __STATIC_INLINE uint32_t __STREXW(uint32_t value, volatile uint32_t *addr)
-   uint32_t result;
-   __ASM volatile ("strex %0, %2, %1" : "=&r" (result), "=Q" (*addr) : "r" (value) );
-   return(result);
-  \brief   Remove the exclusive lock
-  \details Removes the exclusive lock which is created by LDREX.
-__attribute__((always_inline)) __STATIC_INLINE void __CLREX(void)
-  __ASM volatile ("clrex" ::: "memory");
-  \brief   Signed Saturate
-  \details Saturates a signed value.
-  \param [in]  value  Value to be saturated
-  \param [in]    sat  Bit position to saturate to (1..32)
-  \return             Saturated value
-#define __SSAT(ARG1,ARG2) \
-  uint32_t __RES, __ARG1 = (ARG1); \
-  __ASM ("ssat %0, %1, %2" : "=r" (__RES) :  "I" (ARG2), "r" (__ARG1) ); \
-  __RES; \
-  \brief   Unsigned Saturate
-  \details Saturates an unsigned value.
-  \param [in]    sat  Bit position to saturate to (0..31)
-#define __USAT(ARG1,ARG2) \
-  __ASM ("usat %0, %1, %2" : "=r" (__RES) :  "I" (ARG2), "r" (__ARG1) ); \
-  __RES; \
-  \brief   Rotate Right with Extend (32 bit)
-  \details Moves each bit of a bitstring right by one bit.
-           The carry input is shifted in at the left end of the bitstring.
-__attribute__((always_inline)) __STATIC_INLINE uint32_t __RRX(uint32_t value)
-  uint32_t result;
-  __ASM volatile ("rrx %0, %1" : __CMSIS_GCC_OUT_REG (result) : __CMSIS_GCC_USE_REG (value) );
-  return(result);
-  \brief   LDRT Unprivileged (8 bit)
-  \details Executes a Unprivileged LDRT instruction for 8 bit value.
-__attribute__((always_inline)) __STATIC_INLINE uint8_t __LDRBT(volatile uint8_t *addr)
-    uint32_t result;
-   __ASM volatile ("ldrbt %0, %1" : "=r" (result) : "Q" (*addr) );
-#else
-   __ASM volatile ("ldrbt %0, [%1]" : "=r" (result) : "r" (addr) : "memory" );
-#endif
-  \brief   LDRT Unprivileged (16 bit)
-  \details Executes a Unprivileged LDRT instruction for 16 bit values.
-__attribute__((always_inline)) __STATIC_INLINE uint16_t __LDRHT(volatile uint16_t *addr)
-    uint32_t result;
-   __ASM volatile ("ldrht %0, %1" : "=r" (result) : "Q" (*addr) );
-#else
-   __ASM volatile ("ldrht %0, [%1]" : "=r" (result) : "r" (addr) : "memory" );
-#endif
-  \brief   LDRT Unprivileged (32 bit)
-  \details Executes a Unprivileged LDRT instruction for 32 bit values.
-__attribute__((always_inline)) __STATIC_INLINE uint32_t __LDRT(volatile uint32_t *addr)
-    uint32_t result;
-   __ASM volatile ("ldrt %0, %1" : "=r" (result) : "Q" (*addr) );
-   return(result);
-  \brief   STRT Unprivileged (8 bit)
-  \details Executes a Unprivileged STRT instruction for 8 bit values.
-__attribute__((always_inline)) __STATIC_INLINE void __STRBT(uint8_t value, volatile uint8_t *addr)
-   __ASM volatile ("strbt %1, %0" : "=Q" (*addr) : "r" ((uint32_t)value) );
-  \brief   STRT Unprivileged (16 bit)
-  \details Executes a Unprivileged STRT instruction for 16 bit values.
-__attribute__((always_inline)) __STATIC_INLINE void __STRHT(uint16_t value, volatile uint16_t *addr)
-   __ASM volatile ("strht %1, %0" : "=Q" (*addr) : "r" ((uint32_t)value) );
-  \brief   STRT Unprivileged (32 bit)
-  \details Executes a Unprivileged STRT instruction for 32 bit values.
-__attribute__((always_inline)) __STATIC_INLINE void __STRT(uint32_t value, volatile uint32_t *addr)
-   __ASM volatile ("strt %1, %0" : "=Q" (*addr) : "r" (value) );
-#endif /* (__CORTEX_M >= 0x03U) || (__CORTEX_SC >= 300U) */
-/*@}*/ /* end of group CMSIS_Core_InstructionInterface */
-/* ###################  Compiler specific Intrinsics  ########################### */
-/** \defgroup CMSIS_SIMD_intrinsics CMSIS SIMD Intrinsics
-  \ingroup CMSIS
-  Access to dedicated SIMD instructions
-#if (__CORTEX_M >= 0x04U)  /* only for Cortex-M4 and above */
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SADD8(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("sadd8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __QADD8(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("qadd8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SHADD8(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("shadd8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UADD8(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("uadd8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UQADD8(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("uqadd8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UHADD8(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("uhadd8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SSUB8(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("ssub8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __QSUB8(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("qsub8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SHSUB8(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("shsub8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __USUB8(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("usub8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UQSUB8(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("uqsub8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UHSUB8(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("uhsub8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SADD16(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("sadd16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __QADD16(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("qadd16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SHADD16(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("shadd16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UADD16(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("uadd16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UQADD16(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("uqadd16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UHADD16(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("uhadd16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SSUB16(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("ssub16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __QSUB16(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("qsub16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SHSUB16(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("shsub16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __USUB16(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("usub16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UQSUB16(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("uqsub16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UHSUB16(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("uhsub16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SASX(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("sasx %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __QASX(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("qasx %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SHASX(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("shasx %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UASX(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("uasx %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UQASX(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("uqasx %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UHASX(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("uhasx %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SSAX(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("ssax %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __QSAX(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("qsax %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SHSAX(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("shsax %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __USAX(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("usax %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UQSAX(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("uqsax %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UHSAX(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("uhsax %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __USAD8(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("usad8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __USADA8(uint32_t op1, uint32_t op2, uint32_t op3)
-  uint32_t result;
-  __ASM volatile ("usada8 %0, %1, %2, %3" : "=r" (result) : "r" (op1), "r" (op2), "r" (op3) );
-  return(result);
-#define __SSAT16(ARG1,ARG2) \
-  int32_t __RES, __ARG1 = (ARG1); \
-  __ASM ("ssat16 %0, %1, %2" : "=r" (__RES) :  "I" (ARG2), "r" (__ARG1) ); \
-  __RES; \
-#define __USAT16(ARG1,ARG2) \
-  __ASM ("usat16 %0, %1, %2" : "=r" (__RES) :  "I" (ARG2), "r" (__ARG1) ); \
-  __RES; \
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UXTB16(uint32_t op1)
-  uint32_t result;
-  __ASM volatile ("uxtb16 %0, %1" : "=r" (result) : "r" (op1));
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __UXTAB16(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("uxtab16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SXTB16(uint32_t op1)
-  uint32_t result;
-  __ASM volatile ("sxtb16 %0, %1" : "=r" (result) : "r" (op1));
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SXTAB16(uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("sxtab16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMUAD  (uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("smuad %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMUADX (uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("smuadx %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMLAD (uint32_t op1, uint32_t op2, uint32_t op3)
-  uint32_t result;
-  __ASM volatile ("smlad %0, %1, %2, %3" : "=r" (result) : "r" (op1), "r" (op2), "r" (op3) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMLADX (uint32_t op1, uint32_t op2, uint32_t op3)
-  uint32_t result;
-  __ASM volatile ("smladx %0, %1, %2, %3" : "=r" (result) : "r" (op1), "r" (op2), "r" (op3) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint64_t __SMLALD (uint32_t op1, uint32_t op2, uint64_t acc)
-  union llreg_u{
-    uint32_t w32[2];
-    uint64_t w64;
-  } llr;
-  llr.w64 = acc;
-#ifndef __ARMEB__   /* Little endian */
-  __ASM volatile ("smlald %0, %1, %2, %3" : "=r" (llr.w32[0]), "=r" (llr.w32[1]): "r" (op1), "r" (op2) , "0" (llr.w32[0]), "1" (llr.w32[1]) );
-#else               /* Big endian */
-  __ASM volatile ("smlald %0, %1, %2, %3" : "=r" (llr.w32[1]), "=r" (llr.w32[0]): "r" (op1), "r" (op2) , "0" (llr.w32[1]), "1" (llr.w32[0]) );
-#endif
-  return(llr.w64);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint64_t __SMLALDX (uint32_t op1, uint32_t op2, uint64_t acc)
-  union llreg_u{
-    uint32_t w32[2];
-    uint64_t w64;
-  } llr;
-  llr.w64 = acc;
-  __ASM volatile ("smlaldx %0, %1, %2, %3" : "=r" (llr.w32[0]), "=r" (llr.w32[1]): "r" (op1), "r" (op2) , "0" (llr.w32[0]), "1" (llr.w32[1]) );
-  __ASM volatile ("smlaldx %0, %1, %2, %3" : "=r" (llr.w32[1]), "=r" (llr.w32[0]): "r" (op1), "r" (op2) , "0" (llr.w32[1]), "1" (llr.w32[0]) );
-#endif
-  return(llr.w64);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMUSD  (uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("smusd %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMUSDX (uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("smusdx %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMLSD (uint32_t op1, uint32_t op2, uint32_t op3)
-  uint32_t result;
-  __ASM volatile ("smlsd %0, %1, %2, %3" : "=r" (result) : "r" (op1), "r" (op2), "r" (op3) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMLSDX (uint32_t op1, uint32_t op2, uint32_t op3)
-  uint32_t result;
-  __ASM volatile ("smlsdx %0, %1, %2, %3" : "=r" (result) : "r" (op1), "r" (op2), "r" (op3) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint64_t __SMLSLD (uint32_t op1, uint32_t op2, uint64_t acc)
-  union llreg_u{
-    uint32_t w32[2];
-    uint64_t w64;
-  } llr;
-  llr.w64 = acc;
-  __ASM volatile ("smlsld %0, %1, %2, %3" : "=r" (llr.w32[0]), "=r" (llr.w32[1]): "r" (op1), "r" (op2) , "0" (llr.w32[0]), "1" (llr.w32[1]) );
-  __ASM volatile ("smlsld %0, %1, %2, %3" : "=r" (llr.w32[1]), "=r" (llr.w32[0]): "r" (op1), "r" (op2) , "0" (llr.w32[1]), "1" (llr.w32[0]) );
-#endif
-  return(llr.w64);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint64_t __SMLSLDX (uint32_t op1, uint32_t op2, uint64_t acc)
-  union llreg_u{
-    uint32_t w32[2];
-    uint64_t w64;
-  } llr;
-  llr.w64 = acc;
-  __ASM volatile ("smlsldx %0, %1, %2, %3" : "=r" (llr.w32[0]), "=r" (llr.w32[1]): "r" (op1), "r" (op2) , "0" (llr.w32[0]), "1" (llr.w32[1]) );
-  __ASM volatile ("smlsldx %0, %1, %2, %3" : "=r" (llr.w32[1]), "=r" (llr.w32[0]): "r" (op1), "r" (op2) , "0" (llr.w32[1]), "1" (llr.w32[0]) );
-#endif
-  return(llr.w64);
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SEL  (uint32_t op1, uint32_t op2)
-  uint32_t result;
-  __ASM volatile ("sel %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE  int32_t __QADD( int32_t op1,  int32_t op2)
-  int32_t result;
-  __ASM volatile ("qadd %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-__attribute__( ( always_inline ) ) __STATIC_INLINE  int32_t __QSUB( int32_t op1,  int32_t op2)
-  int32_t result;
-  __ASM volatile ("qsub %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
-  return(result);
-#define __PKHBT(ARG1,ARG2,ARG3) \
-  uint32_t __RES, __ARG1 = (ARG1), __ARG2 = (ARG2); \
-  __ASM ("pkhbt %0, %1, %2, lsl %3" : "=r" (__RES) :  "r" (__ARG1), "r" (__ARG2), "I" (ARG3)  ); \
-  __RES; \
-#define __PKHTB(ARG1,ARG2,ARG3) \
-  if (ARG3 == 0) \
-    __ASM ("pkhtb %0, %1, %2" : "=r" (__RES) :  "r" (__ARG1), "r" (__ARG2)  ); \
-  else \
-    __ASM ("pkhtb %0, %1, %2, asr %3" : "=r" (__RES) :  "r" (__ARG1), "r" (__ARG2), "I" (ARG3)  ); \
-  __RES; \
-__attribute__( ( always_inline ) ) __STATIC_INLINE uint32_t __SMMLA (int32_t op1, int32_t op2, int32_t op3)
- int32_t result;
- __ASM volatile ("smmla %0, %1, %2, %3" : "=r" (result): "r"  (op1), "r" (op2), "r" (op3) );
- return(result);
-#endif /* (__CORTEX_M >= 0x04) */
-/*@} end of group CMSIS_SIMD_intrinsics */
-#pragma GCC diagnostic pop
-#endif
-#endif /* __CMSIS_GCC_H */
+ * @file     cmsis_gcc.h
+ * @brief    CMSIS compiler GCC header file
+ * @version  V5.4.2
+ * @date     17. December 2022
+ * Copyright (c) 2009-2021 Arm Limited. All rights reserved.
+#ifndef __CMSIS_GCC_H
+#define __CMSIS_GCC_H
+/* ignore some GCC warnings */
+#pragma GCC diagnostic push
+#pragma GCC diagnostic ignored "-Wsign-conversion"
+#pragma GCC diagnostic ignored "-Wconversion"
+#pragma GCC diagnostic ignored "-Wunused-parameter"
+/* Fallback for __has_builtin */
+#ifndef __has_builtin
+  #define __has_builtin(x) (0)
+#endif
+/* CMSIS compiler specific defines */
+#ifndef   __ASM
+#endif
+#ifndef   __INLINE
+#endif
+#ifndef   __STATIC_INLINE
+#endif
+#ifndef   __STATIC_FORCEINLINE
+  #define __STATIC_FORCEINLINE                   __attribute__((always_inline)) static inline
+#endif
+#ifndef   __NO_RETURN
+  #define __NO_RETURN                            __attribute__((__noreturn__))
+#endif
+#ifndef   __USED
+#endif
+#ifndef   __WEAK
+#endif
+#ifndef   __PACKED
+  #define __PACKED                               __attribute__((packed, aligned(1)))
+#endif
+#ifndef   __PACKED_STRUCT
+  #define __PACKED_STRUCT                        struct __attribute__((packed, aligned(1)))
+#endif
+#ifndef   __PACKED_UNION
+  #define __PACKED_UNION                         union __attribute__((packed, aligned(1)))
+#endif
+#ifndef   __UNALIGNED_UINT32        /* deprecated */
+  #pragma GCC diagnostic push
+  #pragma GCC diagnostic ignored "-Wpacked"
+  #pragma GCC diagnostic ignored "-Wattributes"
+  #pragma GCC diagnostic pop
+#endif
+#ifndef   __UNALIGNED_UINT16_WRITE
+#endif
+#ifndef   __UNALIGNED_UINT16_READ
+#endif
+#ifndef   __UNALIGNED_UINT32_WRITE
+#endif
+#ifndef   __UNALIGNED_UINT32_READ
+#endif
+#ifndef   __ALIGNED
+#endif
+#ifndef   __RESTRICT
+#endif
+#ifndef   __COMPILER_BARRIER
+  #define __COMPILER_BARRIER()                   __ASM volatile("":::"memory")
+#endif
+#ifndef __NO_INIT
+#endif
+#ifndef __ALIAS
+#endif
+/* #########################  Startup and Lowlevel Init  ######################## */
+#ifndef __PROGRAM_START
+  \brief   Initializes data and bss sections
+  \details This default implementations initialized all data and additional bss
+           sections relying on .copy.table and .zero.table specified properly
+           in the used linker script.
+__STATIC_FORCEINLINE __NO_RETURN void __cmsis_start(void)
+  extern void _start(void) __NO_RETURN;
+  typedef struct __copy_table {
+    uint32_t const* src;
+    uint32_t* dest;
+    uint32_t  wlen;
+  } __copy_table_t;
+  typedef struct __zero_table {
+    uint32_t* dest;
+    uint32_t  wlen;
+  } __zero_table_t;
+  extern const __copy_table_t __copy_table_start__;
+  extern const __copy_table_t __copy_table_end__;
+  extern const __zero_table_t __zero_table_start__;
+  extern const __zero_table_t __zero_table_end__;
+  for (__copy_table_t const* pTable = &__copy_table_start__; pTable < &__copy_table_end__; ++pTable) {
+    for(uint32_t i=0u; i<pTable->wlen; ++i) {
+      pTable->dest[i] = pTable->src[i];
+  for (__zero_table_t const* pTable = &__zero_table_start__; pTable < &__zero_table_end__; ++pTable) {
+      pTable->dest[i] = 0u;
+  _start();
+#define __PROGRAM_START           __cmsis_start
+#endif
+#ifndef __INITIAL_SP
+#define __INITIAL_SP              __StackTop
+#endif
+#ifndef __STACK_LIMIT
+#define __STACK_LIMIT             __StackLimit
+#endif
+#ifndef __VECTOR_TABLE
+#define __VECTOR_TABLE            __Vectors
+#endif
+#ifndef __VECTOR_TABLE_ATTRIBUTE
+#define __VECTOR_TABLE_ATTRIBUTE  __attribute__((used, section(".vectors")))
+#endif
+#if defined (__ARM_FEATURE_CMSE) && (__ARM_FEATURE_CMSE == 3U)
+#ifndef __STACK_SEAL
+#define __STACK_SEAL              __StackSeal
+#endif
+#ifndef __TZ_STACK_SEAL_SIZE
+#define __TZ_STACK_SEAL_SIZE      8U
+#endif
+#ifndef __TZ_STACK_SEAL_VALUE
+#define __TZ_STACK_SEAL_VALUE     0xFEF5EDA5FEF5EDA5ULL
+#endif
+__STATIC_FORCEINLINE void __TZ_set_STACKSEAL_S (uint32_t* stackTop) {
+  *((uint64_t *)stackTop) = __TZ_STACK_SEAL_VALUE;
+#endif
+/* ##########################  Core Instruction Access  ######################### */
+/** \defgroup CMSIS_Core_InstructionInterface CMSIS Core Instruction Interface
+  Access to dedicated instructions
+/* Define macros for porting to both thumb1 and thumb2.
+ * For thumb1, use low register (r0-r7), specified by constraint "l"
+ * Otherwise, use general registers, specified by constraint "r" */
+#if defined (__thumb__) && !defined (__thumb2__)
+#define __CMSIS_GCC_OUT_REG(r) "=l" (r)
+#define __CMSIS_GCC_RW_REG(r) "+l" (r)
+#define __CMSIS_GCC_USE_REG(r) "l" (r)
+#else
+#define __CMSIS_GCC_OUT_REG(r) "=r" (r)
+#define __CMSIS_GCC_RW_REG(r) "+r" (r)
+#define __CMSIS_GCC_USE_REG(r) "r" (r)
+#endif
+  \brief   No Operation
+  \details No Operation does nothing. This instruction can be used for code alignment purposes.
+#define __NOP()                             __ASM volatile ("nop")
+  \brief   Wait For Interrupt
+  \details Wait For Interrupt is a hint instruction that suspends execution until one of a number of events occurs.
+#define __WFI()                             __ASM volatile ("wfi":::"memory")
+  \brief   Wait For Event
+  \details Wait For Event is a hint instruction that permits the processor to enter
+           a low-power state until one of a number of events occurs.
+#define __WFE()                             __ASM volatile ("wfe":::"memory")
+  \brief   Send Event
+  \details Send Event is a hint instruction. It causes an event to be signaled to the CPU.
+#define __SEV()                             __ASM volatile ("sev")
+  \brief   Instruction Synchronization Barrier
+  \details Instruction Synchronization Barrier flushes the pipeline in the processor,
+           so that all instructions following the ISB are fetched from cache or memory,
+           after the instruction has been completed.
+__STATIC_FORCEINLINE void __ISB(void)
+  __ASM volatile ("isb 0xF":::"memory");
+  \brief   Data Synchronization Barrier
+  \details Acts as a special kind of Data Memory Barrier.
+           It completes when all explicit memory accesses before this instruction complete.
+__STATIC_FORCEINLINE void __DSB(void)
+  __ASM volatile ("dsb 0xF":::"memory");
+  \brief   Data Memory Barrier
+  \details Ensures the apparent order of the explicit memory operations before
+           and after the instruction, without ensuring their completion.
+__STATIC_FORCEINLINE void __DMB(void)
+  __ASM volatile ("dmb 0xF":::"memory");
+  \brief   Reverse byte order (32 bit)
+  \details Reverses the byte order in unsigned integer value. For example, 0x12345678 becomes 0x78563412.
+  \param [in]    value  Value to reverse
+  \return               Reversed value
+__STATIC_FORCEINLINE uint32_t __REV(uint32_t value)
+#if (__GNUC__ > 4) || (__GNUC__ == 4 && __GNUC_MINOR__ >= 5)
+  return __builtin_bswap32(value);
+#else
+  uint32_t result;
+  __ASM ("rev %0, %1" : __CMSIS_GCC_OUT_REG (result) : __CMSIS_GCC_USE_REG (value) );
+  return result;
+#endif
+  \brief   Reverse byte order (16 bit)
+  \details Reverses the byte order within each halfword of a word. For example, 0x12345678 becomes 0x34127856.
+__STATIC_FORCEINLINE uint32_t __REV16(uint32_t value)
+  uint32_t result;
+  __ASM ("rev16 %0, %1" : __CMSIS_GCC_OUT_REG (result) : __CMSIS_GCC_USE_REG (value) );
+  return result;
+  \details Reverses the byte order in a 16-bit value and returns the signed 16-bit result. For example, 0x0080 becomes 0x8000.
+__STATIC_FORCEINLINE int16_t __REVSH(int16_t value)
+#if (__GNUC__ > 4) || (__GNUC__ == 4 && __GNUC_MINOR__ >= 8)
+  return (int16_t)__builtin_bswap16(value);
+#else
+  int16_t result;
+  __ASM ("revsh %0, %1" : __CMSIS_GCC_OUT_REG (result) : __CMSIS_GCC_USE_REG (value) );
+  return result;
+#endif
+  \brief   Rotate Right in unsigned value (32 bit)
+  \details Rotate Right (immediate) provides the value of the contents of a register rotated by a variable number of bits.
+  \param [in]    op1  Value to rotate
+  \param [in]    op2  Number of Bits to rotate
+  \return               Rotated value
+__STATIC_FORCEINLINE uint32_t __ROR(uint32_t op1, uint32_t op2)
+  op2 %= 32U;
+  if (op2 == 0U)
+    return op1;
+  return (op1 >> op2) | (op1 << (32U - op2));
+  \brief   Breakpoint
+  \details Causes the processor to enter Debug state.
+           Debug tools can use this to investigate system state when the instruction at a particular address is reached.
+  \param [in]    value  is ignored by the processor.
+                 If required, a debugger can use it to store additional information about the breakpoint.
+#define __BKPT(value)                       __ASM volatile ("bkpt "#value)
+  \brief   Reverse bit order of value
+  \details Reverses the bit order of the given value.
+__STATIC_FORCEINLINE uint32_t __RBIT(uint32_t value)
+  uint32_t result;
+#if ((defined (__ARM_ARCH_7M__      ) && (__ARM_ARCH_7M__      == 1)) || \
+     (defined (__ARM_ARCH_7EM__     ) && (__ARM_ARCH_7EM__     == 1)) || \
+     (defined (__ARM_ARCH_8M_MAIN__ ) && (__ARM_ARCH_8M_MAIN__ == 1))    )
+   __ASM ("rbit %0, %1" : "=r" (result) : "r" (value) );
+#else
+  uint32_t s = (4U /*sizeof(v)*/ * 8U) - 1U; /* extra shift needed at end */
+  result = value;                      /* r will be reversed bits of v; first get LSB of v */
+  for (value >>= 1U; value != 0U; value >>= 1U)
+    result <<= 1U;
+    result |= value & 1U;
+    s--;
+  result <<= s;                        /* shift when v's highest bits are zero */
+#endif
+  return result;
+  \brief   Count leading zeros
+  \details Counts the number of leading zeros of a data value.
+  \param [in]  value  Value to count the leading zeros
+  \return             number of leading zeros in value
+__STATIC_FORCEINLINE uint8_t __CLZ(uint32_t value)
+  /* Even though __builtin_clz produces a CLZ instruction on ARM, formally
+     __builtin_clz(0) is undefined behaviour, so handle this case specially.
+     This guarantees ARM-compatible results if happening to compile on a non-ARM
+     target, and ensures the compiler doesn't decide to activate any
+     optimisations using the logic "value was passed to __builtin_clz, so it
+     is non-zero".
+     ARM GCC 7.3 and possibly earlier will optimise this test away, leaving a
+     single CLZ instruction.
+  if (value == 0U)
+    return 32U;
+  return __builtin_clz(value);
+     (defined (__ARM_ARCH_8M_MAIN__ ) && (__ARM_ARCH_8M_MAIN__ == 1)) || \
+     (defined (__ARM_ARCH_8M_BASE__ ) && (__ARM_ARCH_8M_BASE__ == 1))    )
+  \brief   LDR Exclusive (8 bit)
+  \details Executes a exclusive LDR instruction for 8 bit value.
+  \param [in]    ptr  Pointer to data
+  \return             value of type uint8_t at (*ptr)
+__STATIC_FORCEINLINE uint8_t __LDREXB(volatile uint8_t *addr)
+    uint32_t result;
+   __ASM volatile ("ldrexb %0, %1" : "=r" (result) : "Q" (*addr) );
+#else
+    /* Prior to GCC 4.8, "Q" will be expanded to [rx, #0] which is not
+       accepted by assembler. So has to use following less efficient pattern.
+   __ASM volatile ("ldrexb %0, [%1]" : "=r" (result) : "r" (addr) : "memory" );
+#endif
+   return ((uint8_t) result);    /* Add explicit type cast here */
+  \brief   LDR Exclusive (16 bit)
+  \details Executes a exclusive LDR instruction for 16 bit values.
+  \return        value of type uint16_t at (*ptr)
+__STATIC_FORCEINLINE uint16_t __LDREXH(volatile uint16_t *addr)
+    uint32_t result;
+   __ASM volatile ("ldrexh %0, %1" : "=r" (result) : "Q" (*addr) );
+#else
+   __ASM volatile ("ldrexh %0, [%1]" : "=r" (result) : "r" (addr) : "memory" );
+#endif
+   return ((uint16_t) result);    /* Add explicit type cast here */
+  \brief   LDR Exclusive (32 bit)
+  \details Executes a exclusive LDR instruction for 32 bit values.
+  \return        value of type uint32_t at (*ptr)
+__STATIC_FORCEINLINE uint32_t __LDREXW(volatile uint32_t *addr)
+    uint32_t result;
+   __ASM volatile ("ldrex %0, %1" : "=r" (result) : "Q" (*addr) );
+   return(result);
+  \brief   STR Exclusive (8 bit)
+  \details Executes a exclusive STR instruction for 8 bit values.
+  \param [in]  value  Value to store
+  \param [in]    ptr  Pointer to location
+  \return          0  Function succeeded
+  \return          1  Function failed
+__STATIC_FORCEINLINE uint32_t __STREXB(uint8_t value, volatile uint8_t *addr)
+   uint32_t result;
+   __ASM volatile ("strexb %0, %2, %1" : "=&r" (result), "=Q" (*addr) : "r" ((uint32_t)value) );
+   return(result);
+  \brief   STR Exclusive (16 bit)
+  \details Executes a exclusive STR instruction for 16 bit values.
+__STATIC_FORCEINLINE uint32_t __STREXH(uint16_t value, volatile uint16_t *addr)
+   uint32_t result;
+   __ASM volatile ("strexh %0, %2, %1" : "=&r" (result), "=Q" (*addr) : "r" ((uint32_t)value) );
+   return(result);
+  \brief   STR Exclusive (32 bit)
+  \details Executes a exclusive STR instruction for 32 bit values.
+__STATIC_FORCEINLINE uint32_t __STREXW(uint32_t value, volatile uint32_t *addr)
+   uint32_t result;
+   __ASM volatile ("strex %0, %2, %1" : "=&r" (result), "=Q" (*addr) : "r" (value) );
+   return(result);
+  \brief   Remove the exclusive lock
+  \details Removes the exclusive lock which is created by LDREX.
+__STATIC_FORCEINLINE void __CLREX(void)
+  __ASM volatile ("clrex" ::: "memory");
+#endif /* ((defined (__ARM_ARCH_7M__      ) && (__ARM_ARCH_7M__      == 1)) || \
+           (defined (__ARM_ARCH_8M_BASE__ ) && (__ARM_ARCH_8M_BASE__ == 1))    ) */
+  \brief   Signed Saturate
+  \details Saturates a signed value.
+  \param [in]  ARG1  Value to be saturated
+  \param [in]  ARG2  Bit position to saturate to (1..32)
+  \return             Saturated value
+#define __SSAT(ARG1, ARG2) \
+__extension__ \
+  int32_t __RES, __ARG1 = (ARG1); \
+  __ASM volatile ("ssat %0, %1, %2" : "=r" (__RES) :  "I" (ARG2), "r" (__ARG1) : "cc" ); \
+  __RES; \
+  \brief   Unsigned Saturate
+  \details Saturates an unsigned value.
+  \param [in]  ARG2  Bit position to saturate to (0..31)
+#define __USAT(ARG1, ARG2) \
+__extension__ \
+  uint32_t __RES, __ARG1 = (ARG1); \
+  __ASM volatile ("usat %0, %1, %2" : "=r" (__RES) :  "I" (ARG2), "r" (__ARG1) : "cc" ); \
+  __RES; \
+  \brief   Rotate Right with Extend (32 bit)
+  \details Moves each bit of a bitstring right by one bit.
+           The carry input is shifted in at the left end of the bitstring.
+  \param [in]    value  Value to rotate
+__STATIC_FORCEINLINE uint32_t __RRX(uint32_t value)
+  uint32_t result;
+  __ASM volatile ("rrx %0, %1" : __CMSIS_GCC_OUT_REG (result) : __CMSIS_GCC_USE_REG (value) );
+  return(result);
+  \brief   LDRT Unprivileged (8 bit)
+  \details Executes a Unprivileged LDRT instruction for 8 bit value.
+__STATIC_FORCEINLINE uint8_t __LDRBT(volatile uint8_t *ptr)
+    uint32_t result;
+   __ASM volatile ("ldrbt %0, %1" : "=r" (result) : "Q" (*ptr) );
+#else
+   __ASM volatile ("ldrbt %0, [%1]" : "=r" (result) : "r" (ptr) : "memory" );
+#endif
+  \brief   LDRT Unprivileged (16 bit)
+  \details Executes a Unprivileged LDRT instruction for 16 bit values.
+__STATIC_FORCEINLINE uint16_t __LDRHT(volatile uint16_t *ptr)
+    uint32_t result;
+   __ASM volatile ("ldrht %0, %1" : "=r" (result) : "Q" (*ptr) );
+#else
+   __ASM volatile ("ldrht %0, [%1]" : "=r" (result) : "r" (ptr) : "memory" );
+#endif
+  \brief   LDRT Unprivileged (32 bit)
+  \details Executes a Unprivileged LDRT instruction for 32 bit values.
+__STATIC_FORCEINLINE uint32_t __LDRT(volatile uint32_t *ptr)
+    uint32_t result;
+   __ASM volatile ("ldrt %0, %1" : "=r" (result) : "Q" (*ptr) );
+   return(result);
+  \brief   STRT Unprivileged (8 bit)
+  \details Executes a Unprivileged STRT instruction for 8 bit values.
+__STATIC_FORCEINLINE void __STRBT(uint8_t value, volatile uint8_t *ptr)
+   __ASM volatile ("strbt %1, %0" : "=Q" (*ptr) : "r" ((uint32_t)value) );
+  \brief   STRT Unprivileged (16 bit)
+  \details Executes a Unprivileged STRT instruction for 16 bit values.
+__STATIC_FORCEINLINE void __STRHT(uint16_t value, volatile uint16_t *ptr)
+   __ASM volatile ("strht %1, %0" : "=Q" (*ptr) : "r" ((uint32_t)value) );
+  \brief   STRT Unprivileged (32 bit)
+  \details Executes a Unprivileged STRT instruction for 32 bit values.
+__STATIC_FORCEINLINE void __STRT(uint32_t value, volatile uint32_t *ptr)
+   __ASM volatile ("strt %1, %0" : "=Q" (*ptr) : "r" (value) );
+#else  /* ((defined (__ARM_ARCH_7M__      ) && (__ARM_ARCH_7M__      == 1)) || \
+           (defined (__ARM_ARCH_8M_MAIN__ ) && (__ARM_ARCH_8M_MAIN__ == 1))    ) */
+  \param [in]  value  Value to be saturated
+  \param [in]    sat  Bit position to saturate to (1..32)
+__STATIC_FORCEINLINE int32_t __SSAT(int32_t val, uint32_t sat)
+  if ((sat >= 1U) && (sat <= 32U))
+    const int32_t max = (int32_t)((1U << (sat - 1U)) - 1U);
+    const int32_t min = -1 - max ;
+    if (val > max)
+      return max;
+    else if (val < min)
+      return min;
+  return val;
+  \param [in]    sat  Bit position to saturate to (0..31)
+__STATIC_FORCEINLINE uint32_t __USAT(int32_t val, uint32_t sat)
+  if (sat <= 31U)
+    const uint32_t max = ((1U << sat) - 1U);
+    if (val > (int32_t)max)
+      return max;
+    else if (val < 0)
+      return 0U;
+  return (uint32_t)val;
+#if ((defined (__ARM_ARCH_8M_MAIN__ ) && (__ARM_ARCH_8M_MAIN__ == 1)) || \
+  \brief   Load-Acquire (8 bit)
+  \details Executes a LDAB instruction for 8 bit value.
+__STATIC_FORCEINLINE uint8_t __LDAB(volatile uint8_t *ptr)
+    uint32_t result;
+   __ASM volatile ("ldab %0, %1" : "=r" (result) : "Q" (*ptr) : "memory" );
+  \brief   Load-Acquire (16 bit)
+  \details Executes a LDAH instruction for 16 bit values.
+__STATIC_FORCEINLINE uint16_t __LDAH(volatile uint16_t *ptr)
+    uint32_t result;
+   __ASM volatile ("ldah %0, %1" : "=r" (result) : "Q" (*ptr) : "memory" );
+  \brief   Load-Acquire (32 bit)
+  \details Executes a LDA instruction for 32 bit values.
+__STATIC_FORCEINLINE uint32_t __LDA(volatile uint32_t *ptr)
+    uint32_t result;
+   __ASM volatile ("lda %0, %1" : "=r" (result) : "Q" (*ptr) : "memory" );
+   return(result);
+  \brief   Store-Release (8 bit)
+  \details Executes a STLB instruction for 8 bit values.
+__STATIC_FORCEINLINE void __STLB(uint8_t value, volatile uint8_t *ptr)
+   __ASM volatile ("stlb %1, %0" : "=Q" (*ptr) : "r" ((uint32_t)value) : "memory" );
+  \brief   Store-Release (16 bit)
+  \details Executes a STLH instruction for 16 bit values.
+__STATIC_FORCEINLINE void __STLH(uint16_t value, volatile uint16_t *ptr)
+   __ASM volatile ("stlh %1, %0" : "=Q" (*ptr) : "r" ((uint32_t)value) : "memory" );
+  \brief   Store-Release (32 bit)
+  \details Executes a STL instruction for 32 bit values.
+__STATIC_FORCEINLINE void __STL(uint32_t value, volatile uint32_t *ptr)
+   __ASM volatile ("stl %1, %0" : "=Q" (*ptr) : "r" ((uint32_t)value) : "memory" );
+  \brief   Load-Acquire Exclusive (8 bit)
+  \details Executes a LDAB exclusive instruction for 8 bit value.
+__STATIC_FORCEINLINE uint8_t __LDAEXB(volatile uint8_t *ptr)
+    uint32_t result;
+   __ASM volatile ("ldaexb %0, %1" : "=r" (result) : "Q" (*ptr) : "memory" );
+  \brief   Load-Acquire Exclusive (16 bit)
+  \details Executes a LDAH exclusive instruction for 16 bit values.
+__STATIC_FORCEINLINE uint16_t __LDAEXH(volatile uint16_t *ptr)
+    uint32_t result;
+   __ASM volatile ("ldaexh %0, %1" : "=r" (result) : "Q" (*ptr) : "memory" );
+  \brief   Load-Acquire Exclusive (32 bit)
+  \details Executes a LDA exclusive instruction for 32 bit values.
+__STATIC_FORCEINLINE uint32_t __LDAEX(volatile uint32_t *ptr)
+    uint32_t result;
+   __ASM volatile ("ldaex %0, %1" : "=r" (result) : "Q" (*ptr) : "memory" );
+   return(result);
+  \brief   Store-Release Exclusive (8 bit)
+  \details Executes a STLB exclusive instruction for 8 bit values.
+__STATIC_FORCEINLINE uint32_t __STLEXB(uint8_t value, volatile uint8_t *ptr)
+   uint32_t result;
+   __ASM volatile ("stlexb %0, %2, %1" : "=&r" (result), "=Q" (*ptr) : "r" ((uint32_t)value) : "memory" );
+   return(result);
+  \brief   Store-Release Exclusive (16 bit)
+  \details Executes a STLH exclusive instruction for 16 bit values.
+__STATIC_FORCEINLINE uint32_t __STLEXH(uint16_t value, volatile uint16_t *ptr)
+   uint32_t result;
+   __ASM volatile ("stlexh %0, %2, %1" : "=&r" (result), "=Q" (*ptr) : "r" ((uint32_t)value) : "memory" );
+   return(result);
+  \brief   Store-Release Exclusive (32 bit)
+  \details Executes a STL exclusive instruction for 32 bit values.
+__STATIC_FORCEINLINE uint32_t __STLEX(uint32_t value, volatile uint32_t *ptr)
+   uint32_t result;
+   __ASM volatile ("stlex %0, %2, %1" : "=&r" (result), "=Q" (*ptr) : "r" ((uint32_t)value) : "memory" );
+   return(result);
+#endif /* ((defined (__ARM_ARCH_8M_MAIN__ ) && (__ARM_ARCH_8M_MAIN__ == 1)) || \
+/*@}*/ /* end of group CMSIS_Core_InstructionInterface */
+/* ###########################  Core Function Access  ########################### */
+/** \ingroup  CMSIS_Core_FunctionInterface
+    \defgroup CMSIS_Core_RegAccFunctions CMSIS Core Register Access Functions
+  \brief   Enable IRQ Interrupts
+  \details Enables IRQ interrupts by clearing special-purpose register PRIMASK.
+           Can only be executed in Privileged modes.
+__STATIC_FORCEINLINE void __enable_irq(void)
+  __ASM volatile ("cpsie i" : : : "memory");
+  \brief   Disable IRQ Interrupts
+  \details Disables IRQ interrupts by setting special-purpose register PRIMASK.
+__STATIC_FORCEINLINE void __disable_irq(void)
+  __ASM volatile ("cpsid i" : : : "memory");
+  \brief   Get Control Register
+  \details Returns the content of the Control Register.
+  \return               Control Register value
+__STATIC_FORCEINLINE uint32_t __get_CONTROL(void)
+  uint32_t result;
+  __ASM volatile ("MRS %0, control" : "=r" (result) );
+  return(result);
+#if (defined (__ARM_FEATURE_CMSE ) && (__ARM_FEATURE_CMSE == 3))
+  \brief   Get Control Register (non-secure)
+  \details Returns the content of the non-secure Control Register when in secure mode.
+  \return               non-secure Control Register value
+__STATIC_FORCEINLINE uint32_t __TZ_get_CONTROL_NS(void)
+  uint32_t result;
+  __ASM volatile ("MRS %0, control_ns" : "=r" (result) );
+  return(result);
+#endif
+  \brief   Set Control Register
+  \details Writes the given value to the Control Register.
+  \param [in]    control  Control Register value to set
+__STATIC_FORCEINLINE void __set_CONTROL(uint32_t control)
+  __ASM volatile ("MSR control, %0" : : "r" (control) : "memory");
+  __ISB();
+  \brief   Set Control Register (non-secure)
+  \details Writes the given value to the non-secure Control Register when in secure state.
+__STATIC_FORCEINLINE void __TZ_set_CONTROL_NS(uint32_t control)
+  __ASM volatile ("MSR control_ns, %0" : : "r" (control) : "memory");
+  __ISB();
+#endif
+  \brief   Get IPSR Register
+  \details Returns the content of the IPSR Register.
+  \return               IPSR Register value
+__STATIC_FORCEINLINE uint32_t __get_IPSR(void)
+  uint32_t result;
+  __ASM volatile ("MRS %0, ipsr" : "=r" (result) );
+  return(result);
+  \brief   Get APSR Register
+  \details Returns the content of the APSR Register.
+  \return               APSR Register value
+__STATIC_FORCEINLINE uint32_t __get_APSR(void)
+  uint32_t result;
+  __ASM volatile ("MRS %0, apsr" : "=r" (result) );
+  return(result);
+  \brief   Get xPSR Register
+  \details Returns the content of the xPSR Register.
+  \return               xPSR Register value
+__STATIC_FORCEINLINE uint32_t __get_xPSR(void)
+  uint32_t result;
+  __ASM volatile ("MRS %0, xpsr" : "=r" (result) );
+  return(result);
+  \brief   Get Process Stack Pointer
+  \details Returns the current value of the Process Stack Pointer (PSP).
+  \return               PSP Register value
+__STATIC_FORCEINLINE uint32_t __get_PSP(void)
+  uint32_t result;
+  __ASM volatile ("MRS %0, psp"  : "=r" (result) );
+  return(result);
+  \brief   Get Process Stack Pointer (non-secure)
+  \details Returns the current value of the non-secure Process Stack Pointer (PSP) when in secure state.
+__STATIC_FORCEINLINE uint32_t __TZ_get_PSP_NS(void)
+  uint32_t result;
+  __ASM volatile ("MRS %0, psp_ns"  : "=r" (result) );
+  return(result);
+#endif
+  \brief   Set Process Stack Pointer
+  \details Assigns the given value to the Process Stack Pointer (PSP).
+  \param [in]    topOfProcStack  Process Stack Pointer value to set
+__STATIC_FORCEINLINE void __set_PSP(uint32_t topOfProcStack)
+  __ASM volatile ("MSR psp, %0" : : "r" (topOfProcStack) : );
+  \brief   Set Process Stack Pointer (non-secure)
+  \details Assigns the given value to the non-secure Process Stack Pointer (PSP) when in secure state.
+__STATIC_FORCEINLINE void __TZ_set_PSP_NS(uint32_t topOfProcStack)
+  __ASM volatile ("MSR psp_ns, %0" : : "r" (topOfProcStack) : );
+#endif
+  \brief   Get Main Stack Pointer
+  \details Returns the current value of the Main Stack Pointer (MSP).
+  \return               MSP Register value
+__STATIC_FORCEINLINE uint32_t __get_MSP(void)
+  uint32_t result;
+  __ASM volatile ("MRS %0, msp" : "=r" (result) );
+  return(result);
+  \brief   Get Main Stack Pointer (non-secure)
+  \details Returns the current value of the non-secure Main Stack Pointer (MSP) when in secure state.
+__STATIC_FORCEINLINE uint32_t __TZ_get_MSP_NS(void)
+  uint32_t result;
+  __ASM volatile ("MRS %0, msp_ns" : "=r" (result) );
+  return(result);
+#endif
+  \brief   Set Main Stack Pointer
+  \details Assigns the given value to the Main Stack Pointer (MSP).
+  \param [in]    topOfMainStack  Main Stack Pointer value to set
+__STATIC_FORCEINLINE void __set_MSP(uint32_t topOfMainStack)
+  __ASM volatile ("MSR msp, %0" : : "r" (topOfMainStack) : );
+  \brief   Set Main Stack Pointer (non-secure)
+  \details Assigns the given value to the non-secure Main Stack Pointer (MSP) when in secure state.
+__STATIC_FORCEINLINE void __TZ_set_MSP_NS(uint32_t topOfMainStack)
+  __ASM volatile ("MSR msp_ns, %0" : : "r" (topOfMainStack) : );
+#endif
+  \brief   Get Stack Pointer (non-secure)
+  \details Returns the current value of the non-secure Stack Pointer (SP) when in secure state.
+  \return               SP Register value
+__STATIC_FORCEINLINE uint32_t __TZ_get_SP_NS(void)
+  uint32_t result;
+  __ASM volatile ("MRS %0, sp_ns" : "=r" (result) );
+  return(result);
+  \brief   Set Stack Pointer (non-secure)
+  \details Assigns the given value to the non-secure Stack Pointer (SP) when in secure state.
+  \param [in]    topOfStack  Stack Pointer value to set
+__STATIC_FORCEINLINE void __TZ_set_SP_NS(uint32_t topOfStack)
+  __ASM volatile ("MSR sp_ns, %0" : : "r" (topOfStack) : );
+#endif
+  \brief   Get Priority Mask
+  \details Returns the current state of the priority mask bit from the Priority Mask Register.
+  \return               Priority Mask value
+__STATIC_FORCEINLINE uint32_t __get_PRIMASK(void)
+  uint32_t result;
+  __ASM volatile ("MRS %0, primask" : "=r" (result) );
+  return(result);
+  \brief   Get Priority Mask (non-secure)
+  \details Returns the current state of the non-secure priority mask bit from the Priority Mask Register when in secure state.
+__STATIC_FORCEINLINE uint32_t __TZ_get_PRIMASK_NS(void)
+  uint32_t result;
+  __ASM volatile ("MRS %0, primask_ns" : "=r" (result) );
+  return(result);
+#endif
+  \brief   Set Priority Mask
+  \details Assigns the given value to the Priority Mask Register.
+  \param [in]    priMask  Priority Mask
+__STATIC_FORCEINLINE void __set_PRIMASK(uint32_t priMask)
+  __ASM volatile ("MSR primask, %0" : : "r" (priMask) : "memory");
+  \brief   Set Priority Mask (non-secure)
+  \details Assigns the given value to the non-secure Priority Mask Register when in secure state.
+__STATIC_FORCEINLINE void __TZ_set_PRIMASK_NS(uint32_t priMask)
+  __ASM volatile ("MSR primask_ns, %0" : : "r" (priMask) : "memory");
+#endif
+  \brief   Enable FIQ
+  \details Enables FIQ interrupts by clearing special-purpose register FAULTMASK.
+__STATIC_FORCEINLINE void __enable_fault_irq(void)
+  __ASM volatile ("cpsie f" : : : "memory");
+  \brief   Disable FIQ
+  \details Disables FIQ interrupts by setting special-purpose register FAULTMASK.
+__STATIC_FORCEINLINE void __disable_fault_irq(void)
+  __ASM volatile ("cpsid f" : : : "memory");
+  \brief   Get Base Priority
+  \details Returns the current value of the Base Priority register.
+  \return               Base Priority register value
+__STATIC_FORCEINLINE uint32_t __get_BASEPRI(void)
+  uint32_t result;
+  __ASM volatile ("MRS %0, basepri" : "=r" (result) );
+  return(result);
+  \brief   Get Base Priority (non-secure)
+  \details Returns the current value of the non-secure Base Priority register when in secure state.
+__STATIC_FORCEINLINE uint32_t __TZ_get_BASEPRI_NS(void)
+  uint32_t result;
+  __ASM volatile ("MRS %0, basepri_ns" : "=r" (result) );
+  return(result);
+#endif
+  \brief   Set Base Priority
+  \details Assigns the given value to the Base Priority register.
+  \param [in]    basePri  Base Priority value to set
+__STATIC_FORCEINLINE void __set_BASEPRI(uint32_t basePri)
+  __ASM volatile ("MSR basepri, %0" : : "r" (basePri) : "memory");
+  \brief   Set Base Priority (non-secure)
+  \details Assigns the given value to the non-secure Base Priority register when in secure state.
+__STATIC_FORCEINLINE void __TZ_set_BASEPRI_NS(uint32_t basePri)
+  __ASM volatile ("MSR basepri_ns, %0" : : "r" (basePri) : "memory");
+#endif
+  \brief   Set Base Priority with condition
+  \details Assigns the given value to the Base Priority register only if BASEPRI masking is disabled,
+           or the new value increases the BASEPRI priority level.
+__STATIC_FORCEINLINE void __set_BASEPRI_MAX(uint32_t basePri)
+  __ASM volatile ("MSR basepri_max, %0" : : "r" (basePri) : "memory");
+  \brief   Get Fault Mask
+  \details Returns the current value of the Fault Mask register.
+  \return               Fault Mask register value
+__STATIC_FORCEINLINE uint32_t __get_FAULTMASK(void)
+  uint32_t result;
+  __ASM volatile ("MRS %0, faultmask" : "=r" (result) );
+  return(result);
+  \brief   Get Fault Mask (non-secure)
+  \details Returns the current value of the non-secure Fault Mask register when in secure state.
+__STATIC_FORCEINLINE uint32_t __TZ_get_FAULTMASK_NS(void)
+  uint32_t result;
+  __ASM volatile ("MRS %0, faultmask_ns" : "=r" (result) );
+  return(result);
+#endif
+  \brief   Set Fault Mask
+  \details Assigns the given value to the Fault Mask register.
+  \param [in]    faultMask  Fault Mask value to set
+__STATIC_FORCEINLINE void __set_FAULTMASK(uint32_t faultMask)
+  __ASM volatile ("MSR faultmask, %0" : : "r" (faultMask) : "memory");
+  \brief   Set Fault Mask (non-secure)
+  \details Assigns the given value to the non-secure Fault Mask register when in secure state.
+__STATIC_FORCEINLINE void __TZ_set_FAULTMASK_NS(uint32_t faultMask)
+  __ASM volatile ("MSR faultmask_ns, %0" : : "r" (faultMask) : "memory");
+#endif
+  \brief   Get Process Stack Pointer Limit
+  Devices without ARMv8-M Main Extensions (i.e. Cortex-M23) lack the non-secure
+  Stack Pointer Limit register hence zero is returned always in non-secure
+  mode.
+  \details Returns the current value of the Process Stack Pointer Limit (PSPLIM).
+  \return               PSPLIM Register value
+__STATIC_FORCEINLINE uint32_t __get_PSPLIM(void)
+#if (!(defined (__ARM_ARCH_8M_MAIN__ ) && (__ARM_ARCH_8M_MAIN__ == 1)) && \
+    (!defined (__ARM_FEATURE_CMSE) || (__ARM_FEATURE_CMSE < 3)))
+    // without main extensions, the non-secure PSPLIM is RAZ/WI
+  return 0U;
+#else
+  uint32_t result;
+  __ASM volatile ("MRS %0, psplim"  : "=r" (result) );
+  return result;
+#endif
+#if (defined (__ARM_FEATURE_CMSE) && (__ARM_FEATURE_CMSE == 3))
+  \brief   Get Process Stack Pointer Limit (non-secure)
+  Stack Pointer Limit register hence zero is returned always.
+  \details Returns the current value of the non-secure Process Stack Pointer Limit (PSPLIM) when in secure state.
+__STATIC_FORCEINLINE uint32_t __TZ_get_PSPLIM_NS(void)
+#if (!(defined (__ARM_ARCH_8M_MAIN__ ) && (__ARM_ARCH_8M_MAIN__ == 1)))
+  return 0U;
+#else
+  uint32_t result;
+  __ASM volatile ("MRS %0, psplim_ns"  : "=r" (result) );
+  return result;
+#endif
+#endif
+  \brief   Set Process Stack Pointer Limit
+  Stack Pointer Limit register hence the write is silently ignored in non-secure
+  mode.
+  \details Assigns the given value to the Process Stack Pointer Limit (PSPLIM).
+  \param [in]    ProcStackPtrLimit  Process Stack Pointer Limit value to set
+__STATIC_FORCEINLINE void __set_PSPLIM(uint32_t ProcStackPtrLimit)
+  (void)ProcStackPtrLimit;
+#else
+  __ASM volatile ("MSR psplim, %0" : : "r" (ProcStackPtrLimit));
+#endif
+  Stack Pointer Limit register hence the write is silently ignored.
+  \details Assigns the given value to the non-secure Process Stack Pointer Limit (PSPLIM) when in secure state.
+__STATIC_FORCEINLINE void __TZ_set_PSPLIM_NS(uint32_t ProcStackPtrLimit)
+#else
+  __ASM volatile ("MSR psplim_ns, %0\n" : : "r" (ProcStackPtrLimit));
+#endif
+#endif
+  \brief   Get Main Stack Pointer Limit
+  mode.
+  \details Returns the current value of the Main Stack Pointer Limit (MSPLIM).
+  \return               MSPLIM Register value
+__STATIC_FORCEINLINE uint32_t __get_MSPLIM(void)
+  // without main extensions, the non-secure MSPLIM is RAZ/WI
+  return 0U;
+#else
+  uint32_t result;
+  __ASM volatile ("MRS %0, msplim" : "=r" (result) );
+  return result;
+#endif
+  \brief   Get Main Stack Pointer Limit (non-secure)
+  \details Returns the current value of the non-secure Main Stack Pointer Limit(MSPLIM) when in secure state.
+__STATIC_FORCEINLINE uint32_t __TZ_get_MSPLIM_NS(void)
+  return 0U;
+#else
+  uint32_t result;
+  __ASM volatile ("MRS %0, msplim_ns" : "=r" (result) );
+  return result;
+#endif
+#endif
+  \brief   Set Main Stack Pointer Limit
+  mode.
+  \details Assigns the given value to the Main Stack Pointer Limit (MSPLIM).
+  \param [in]    MainStackPtrLimit  Main Stack Pointer Limit value to set
+__STATIC_FORCEINLINE void __set_MSPLIM(uint32_t MainStackPtrLimit)
+  (void)MainStackPtrLimit;
+#else
+  __ASM volatile ("MSR msplim, %0" : : "r" (MainStackPtrLimit));
+#endif
+  \brief   Set Main Stack Pointer Limit (non-secure)
+  \details Assigns the given value to the non-secure Main Stack Pointer Limit (MSPLIM) when in secure state.
+  \param [in]    MainStackPtrLimit  Main Stack Pointer value to set
+__STATIC_FORCEINLINE void __TZ_set_MSPLIM_NS(uint32_t MainStackPtrLimit)
+#else
+  __ASM volatile ("MSR msplim_ns, %0" : : "r" (MainStackPtrLimit));
+#endif
+#endif
+  \brief   Get FPSCR
+  \details Returns the current value of the Floating Point Status/Control register.
+  \return               Floating Point Status/Control register value
+__STATIC_FORCEINLINE uint32_t __get_FPSCR(void)
+#if ((defined (__FPU_PRESENT) && (__FPU_PRESENT == 1U)) && \
+     (defined (__FPU_USED   ) && (__FPU_USED    == 1U))     )
+#if __has_builtin(__builtin_arm_get_fpscr)
+// Re-enable using built-in when GCC has been fixed
+// || (__GNUC__ > 7) || (__GNUC__ == 7 && __GNUC_MINOR__ >= 2)
+  /* see https://gcc.gnu.org/ml/gcc-patches/2017-04/msg00443.html */
+  return __builtin_arm_get_fpscr();
+#else
+  uint32_t result;
+  __ASM volatile ("VMRS %0, fpscr" : "=r" (result) );
+  return(result);
+#endif
+#else
+  return(0U);
+#endif
+  \brief   Set FPSCR
+  \details Assigns the given value to the Floating Point Status/Control register.
+  \param [in]    fpscr  Floating Point Status/Control value to set
+__STATIC_FORCEINLINE void __set_FPSCR(uint32_t fpscr)
+#if __has_builtin(__builtin_arm_set_fpscr)
+  __builtin_arm_set_fpscr(fpscr);
+#else
+  __ASM volatile ("VMSR fpscr, %0" : : "r" (fpscr) : "vfpcc", "memory");
+#endif
+#else
+  (void)fpscr;
+#endif
+/*@} end of CMSIS_Core_RegAccFunctions */
+/* ###################  Compiler specific Intrinsics  ########################### */
+/** \defgroup CMSIS_SIMD_intrinsics CMSIS SIMD Intrinsics
+  Access to dedicated SIMD instructions
+#if (defined (__ARM_FEATURE_DSP) && (__ARM_FEATURE_DSP == 1))
+__STATIC_FORCEINLINE uint32_t __SADD8(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM volatile ("sadd8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __QADD8(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM ("qadd8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __SHADD8(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM ("shadd8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __UADD8(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM volatile ("uadd8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __UQADD8(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM ("uqadd8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __UHADD8(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM ("uhadd8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __SSUB8(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM volatile ("ssub8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __QSUB8(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM ("qsub8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __SHSUB8(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM ("shsub8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __USUB8(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM volatile ("usub8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __UQSUB8(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM ("uqsub8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __UHSUB8(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM ("uhsub8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __SADD16(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM volatile ("sadd16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __QADD16(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM ("qadd16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __SHADD16(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM ("shadd16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __UADD16(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM volatile ("uadd16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __UQADD16(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM ("uqadd16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __UHADD16(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM ("uhadd16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __SSUB16(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM volatile ("ssub16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __QSUB16(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM ("qsub16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __SHSUB16(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM ("shsub16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __USUB16(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM volatile ("usub16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __UQSUB16(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM ("uqsub16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __UHSUB16(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM ("uhsub16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __SASX(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM volatile ("sasx %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __QASX(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM ("qasx %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __SHASX(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM ("shasx %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __UASX(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM volatile ("uasx %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __UQASX(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM ("uqasx %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __UHASX(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM ("uhasx %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __SSAX(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM volatile ("ssax %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __QSAX(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM ("qsax %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __SHSAX(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM ("shsax %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __USAX(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM volatile ("usax %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __UQSAX(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM ("uqsax %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __UHSAX(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM ("uhsax %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __USAD8(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM ("usad8 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __USADA8(uint32_t op1, uint32_t op2, uint32_t op3)
+  uint32_t result;
+  __ASM ("usada8 %0, %1, %2, %3" : "=r" (result) : "r" (op1), "r" (op2), "r" (op3) );
+  return(result);
+#define __SSAT16(ARG1, ARG2) \
+__extension__ \
+  __ASM volatile ("ssat16 %0, %1, %2" : "=r" (__RES) :  "I" (ARG2), "r" (__ARG1) : "cc" ); \
+  __RES; \
+#define __USAT16(ARG1, ARG2) \
+__extension__ \
+  __ASM volatile ("usat16 %0, %1, %2" : "=r" (__RES) :  "I" (ARG2), "r" (__ARG1) : "cc" ); \
+  __RES; \
+__STATIC_FORCEINLINE uint32_t __UXTB16(uint32_t op1)
+  uint32_t result;
+  __ASM ("uxtb16 %0, %1" : "=r" (result) : "r" (op1));
+  return(result);
+__STATIC_FORCEINLINE uint32_t __UXTAB16(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM ("uxtab16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __SXTB16(uint32_t op1)
+  uint32_t result;
+  __ASM ("sxtb16 %0, %1" : "=r" (result) : "r" (op1));
+  return(result);
+__STATIC_FORCEINLINE uint32_t __SXTB16_RORn(uint32_t op1, uint32_t rotate)
+  uint32_t result;
+  if (__builtin_constant_p(rotate) && ((rotate == 8U) || (rotate == 16U) || (rotate == 24U))) {
+    __ASM volatile ("sxtb16 %0, %1, ROR %2" : "=r" (result) : "r" (op1), "i" (rotate) );
+  } else {
+    result = __SXTB16(__ROR(op1, rotate)) ;
+  return result;
+__STATIC_FORCEINLINE uint32_t __SXTAB16(uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM ("sxtab16 %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __SXTAB16_RORn(uint32_t op1, uint32_t op2, uint32_t rotate)
+  uint32_t result;
+    __ASM volatile ("sxtab16 %0, %1, %2, ROR %3" : "=r" (result) : "r" (op1) , "r" (op2) , "i" (rotate));
+  } else {
+    result = __SXTAB16(op1, __ROR(op2, rotate));
+  return result;
+__STATIC_FORCEINLINE uint32_t __SMUAD  (uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM volatile ("smuad %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __SMUADX (uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM volatile ("smuadx %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __SMLAD (uint32_t op1, uint32_t op2, uint32_t op3)
+  uint32_t result;
+  __ASM volatile ("smlad %0, %1, %2, %3" : "=r" (result) : "r" (op1), "r" (op2), "r" (op3) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __SMLADX (uint32_t op1, uint32_t op2, uint32_t op3)
+  uint32_t result;
+  __ASM volatile ("smladx %0, %1, %2, %3" : "=r" (result) : "r" (op1), "r" (op2), "r" (op3) );
+  return(result);
+__STATIC_FORCEINLINE uint64_t __SMLALD (uint32_t op1, uint32_t op2, uint64_t acc)
+  union llreg_u{
+    uint32_t w32[2];
+    uint64_t w64;
+  } llr;
+  llr.w64 = acc;
+#ifndef __ARMEB__   /* Little endian */
+  __ASM volatile ("smlald %0, %1, %2, %3" : "=r" (llr.w32[0]), "=r" (llr.w32[1]): "r" (op1), "r" (op2) , "0" (llr.w32[0]), "1" (llr.w32[1]) );
+#else               /* Big endian */
+  __ASM volatile ("smlald %0, %1, %2, %3" : "=r" (llr.w32[1]), "=r" (llr.w32[0]): "r" (op1), "r" (op2) , "0" (llr.w32[1]), "1" (llr.w32[0]) );
+#endif
+  return(llr.w64);
+__STATIC_FORCEINLINE uint64_t __SMLALDX (uint32_t op1, uint32_t op2, uint64_t acc)
+  union llreg_u{
+    uint32_t w32[2];
+    uint64_t w64;
+  } llr;
+  llr.w64 = acc;
+  __ASM volatile ("smlaldx %0, %1, %2, %3" : "=r" (llr.w32[0]), "=r" (llr.w32[1]): "r" (op1), "r" (op2) , "0" (llr.w32[0]), "1" (llr.w32[1]) );
+  __ASM volatile ("smlaldx %0, %1, %2, %3" : "=r" (llr.w32[1]), "=r" (llr.w32[0]): "r" (op1), "r" (op2) , "0" (llr.w32[1]), "1" (llr.w32[0]) );
+#endif
+  return(llr.w64);
+__STATIC_FORCEINLINE uint32_t __SMUSD  (uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM volatile ("smusd %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __SMUSDX (uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM volatile ("smusdx %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __SMLSD (uint32_t op1, uint32_t op2, uint32_t op3)
+  uint32_t result;
+  __ASM volatile ("smlsd %0, %1, %2, %3" : "=r" (result) : "r" (op1), "r" (op2), "r" (op3) );
+  return(result);
+__STATIC_FORCEINLINE uint32_t __SMLSDX (uint32_t op1, uint32_t op2, uint32_t op3)
+  uint32_t result;
+  __ASM volatile ("smlsdx %0, %1, %2, %3" : "=r" (result) : "r" (op1), "r" (op2), "r" (op3) );
+  return(result);
+__STATIC_FORCEINLINE uint64_t __SMLSLD (uint32_t op1, uint32_t op2, uint64_t acc)
+  union llreg_u{
+    uint32_t w32[2];
+    uint64_t w64;
+  } llr;
+  llr.w64 = acc;
+  __ASM volatile ("smlsld %0, %1, %2, %3" : "=r" (llr.w32[0]), "=r" (llr.w32[1]): "r" (op1), "r" (op2) , "0" (llr.w32[0]), "1" (llr.w32[1]) );
+  __ASM volatile ("smlsld %0, %1, %2, %3" : "=r" (llr.w32[1]), "=r" (llr.w32[0]): "r" (op1), "r" (op2) , "0" (llr.w32[1]), "1" (llr.w32[0]) );
+#endif
+  return(llr.w64);
+__STATIC_FORCEINLINE uint64_t __SMLSLDX (uint32_t op1, uint32_t op2, uint64_t acc)
+  union llreg_u{
+    uint32_t w32[2];
+    uint64_t w64;
+  } llr;
+  llr.w64 = acc;
+  __ASM volatile ("smlsldx %0, %1, %2, %3" : "=r" (llr.w32[0]), "=r" (llr.w32[1]): "r" (op1), "r" (op2) , "0" (llr.w32[0]), "1" (llr.w32[1]) );
+  __ASM volatile ("smlsldx %0, %1, %2, %3" : "=r" (llr.w32[1]), "=r" (llr.w32[0]): "r" (op1), "r" (op2) , "0" (llr.w32[1]), "1" (llr.w32[0]) );
+#endif
+  return(llr.w64);
+__STATIC_FORCEINLINE uint32_t __SEL  (uint32_t op1, uint32_t op2)
+  uint32_t result;
+  __ASM volatile ("sel %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE  int32_t __QADD( int32_t op1,  int32_t op2)
+  int32_t result;
+  __ASM volatile ("qadd %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+__STATIC_FORCEINLINE  int32_t __QSUB( int32_t op1,  int32_t op2)
+  int32_t result;
+  __ASM volatile ("qsub %0, %1, %2" : "=r" (result) : "r" (op1), "r" (op2) );
+  return(result);
+#define __PKHBT(ARG1,ARG2,ARG3) \
+__extension__ \
+  uint32_t __RES, __ARG1 = (ARG1), __ARG2 = (ARG2); \
+  __ASM ("pkhbt %0, %1, %2, lsl %3" : "=r" (__RES) :  "r" (__ARG1), "r" (__ARG2), "I" (ARG3)  ); \
+  __RES; \
+#define __PKHTB(ARG1,ARG2,ARG3) \
+__extension__ \
+  if (ARG3 == 0) \
+    __ASM ("pkhtb %0, %1, %2" : "=r" (__RES) :  "r" (__ARG1), "r" (__ARG2)  ); \
+  else \
+    __ASM ("pkhtb %0, %1, %2, asr %3" : "=r" (__RES) :  "r" (__ARG1), "r" (__ARG2), "I" (ARG3)  ); \
+  __RES; \
+__STATIC_FORCEINLINE int32_t __SMMLA (int32_t op1, int32_t op2, int32_t op3)
+ int32_t result;
+ __ASM ("smmla %0, %1, %2, %3" : "=r" (result): "r"  (op1), "r" (op2), "r" (op3) );
+ return(result);
+#endif /* (__ARM_FEATURE_DSP == 1) */
+/*@} end of group CMSIS_SIMD_intrinsics */
+#pragma GCC diagnostic pop
+#endif /* __CMSIS_GCC_H */
diff --git a/bsps/arm/include/cmsis_version.h b/bsps/arm/include/cmsis_version.h
new file mode 100644
index 0000000000..8b4765f186
--- /dev/null
+++ b/bsps/arm/include/cmsis_version.h
@@ -0,0 +1,39 @@
+ * @file     cmsis_version.h
+ * @brief    CMSIS Core(M) Version definitions
+ * @version  V5.0.5
+ * @date     02. February 2022
+ * Copyright (c) 2009-2022 ARM Limited. All rights reserved.
+ * SPDX-License-Identifier: Apache-2.0
+ * Licensed under the Apache License, Version 2.0 (the License); you may
+ * not use this file except in compliance with the License.
+ * You may obtain a copy of the License at
+ * www.apache.org/licenses/LICENSE-2.0
+ * Unless required by applicable law or agreed to in writing, software
+ * distributed under the License is distributed on an AS IS BASIS, WITHOUT
+ * WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+ * See the License for the specific language governing permissions and
+ * limitations under the License.
+#if   defined ( __ICCARM__ )
+  #pragma system_include         /* treat file as system include file for MISRA check */
+#elif defined (__clang__)
+  #pragma clang system_header   /* treat file as system include file */
+#endif
+#ifndef __CMSIS_VERSION_H
+#define __CMSIS_VERSION_H
+/*  CMSIS Version definitions */
+#define __CM_CMSIS_VERSION_MAIN  ( 5U)                                      /*!< [31:16] CMSIS Core(M) main version */
+#define __CM_CMSIS_VERSION_SUB   ( 6U)                                      /*!< [15:0]  CMSIS Core(M) sub version */
+#define __CM_CMSIS_VERSION       ((__CM_CMSIS_VERSION_MAIN << 16U) | \
+                                   __CM_CMSIS_VERSION_SUB           )       /*!< CMSIS Core(M) version number */
+#endif
diff --git a/bsps/arm/include/core_cm4.h b/bsps/arm/include/core_cm4.h
index dc840ebf22..711c11326c 100644
--- a/bsps/arm/include/core_cm4.h
+++ b/bsps/arm/include/core_cm4.h
@@ -1,40 +1,30 @@
  * @file     core_cm4.h
  * @brief    CMSIS Cortex-M4 Core Peripheral Access Layer Header File
- * @version  V4.30
- * @date     20. October 2015
+ * @version  V5.2.0
+ * @date     04. April 2023
-/* Copyright (c) 2009 - 2015 ARM LIMITED
-   All rights reserved.
-   Redistribution and use in source and binary forms, with or without
-   modification, are permitted provided that the following conditions are met:
-   - Redistributions of source code must retain the above copyright
-     notice, this list of conditions and the following disclaimer.
-   - Redistributions in binary form must reproduce the above copyright
-     notice, this list of conditions and the following disclaimer in the
-     documentation and/or other materials provided with the distribution.
-   - Neither the name of ARM nor the names of its contributors may be used
-     to endorse or promote products derived from this software without
-     specific prior written permission.
-   THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
-   AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
-   IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
-   ARE DISCLAIMED. IN NO EVENT SHALL COPYRIGHT HOLDERS AND CONTRIBUTORS BE
-   LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
-   CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
-   SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
-   INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
-   CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
-   ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
-   POSSIBILITY OF SUCH DAMAGE.
+ * Copyright (c) 2009-2023 Arm Limited. All rights reserved.
- #pragma system_include         /* treat file as system include file for MISRA check */
-#elif defined(__ARMCC_VERSION) && (__ARMCC_VERSION >= 6010050)
 #endif
@@ -70,60 +60,22 @@
-/*  CMSIS CM4 definitions */
-#define __CM4_CMSIS_VERSION_MAIN  (0x04U)                                      /*!< [31:16] CMSIS HAL main version */
-#define __CM4_CMSIS_VERSION_SUB   (0x1EU)                                      /*!< [15:0]  CMSIS HAL sub version */
-#define __CM4_CMSIS_VERSION       ((__CM4_CMSIS_VERSION_MAIN << 16U) | \
-                                    __CM4_CMSIS_VERSION_SUB           )        /*!< CMSIS HAL version number */
-#define __CORTEX_M                (0x04U)                                      /*!< Cortex-M Core */
-#if   defined ( __CC_ARM )
-  #define __ASM            __asm                                      /*!< asm keyword for ARM Compiler */
-  #define __INLINE         __inline                                   /*!< inline keyword for ARM Compiler */
-  #define __STATIC_INLINE  static __inline
-#elif defined ( __GNUC__ )
-  #define __ASM            __asm                                      /*!< asm keyword for GNU Compiler */
-  #define __INLINE         inline                                     /*!< inline keyword for GNU Compiler */
-  #define __STATIC_INLINE  static inline
-#elif defined ( __ICCARM__ )
-  #define __ASM            __asm                                      /*!< asm keyword for IAR Compiler */
-  #define __INLINE         inline                                     /*!< inline keyword for IAR Compiler. Only available in High optimization mode! */
-#elif defined ( __TMS470__ )
-  #define __ASM            __asm                                      /*!< asm keyword for TI CCS Compiler */
+#include "cmsis_version.h"
-#elif defined ( __TASKING__ )
-  #define __ASM            __asm                                      /*!< asm keyword for TASKING Compiler */
-  #define __INLINE         inline                                     /*!< inline keyword for TASKING Compiler */
-#elif defined ( __CSMC__ )
-  #define __packed
-  #define __ASM            _asm                                      /*!< asm keyword for COSMIC Compiler */
-  #define __INLINE         inline                                    /*!< inline keyword for COSMIC Compiler. Use -pc99 on compile line */
+/* CMSIS CM4 definitions */
+#define __CM4_CMSIS_VERSION_MAIN  (__CM_CMSIS_VERSION_MAIN)              /*!< \deprecated [31:16] CMSIS HAL main version */
+#define __CM4_CMSIS_VERSION_SUB   (__CM_CMSIS_VERSION_SUB)               /*!< \deprecated [15:0]  CMSIS HAL sub version */
+#define __CM4_CMSIS_VERSION       ((__CM4_CMSIS_VERSION_MAIN << 16U) | \
+                                    __CM4_CMSIS_VERSION_SUB           )  /*!< \deprecated CMSIS HAL version number */
-#else
-  #error Unknown compiler
-#endif
+#define __CORTEX_M                (4U)                                   /*!< Cortex-M Core */
 /** __FPU_USED indicates whether an FPU is used or not.
     For this, __FPU_PRESENT has to be checked prior to making use of FPU specific registers and functions.
   #if defined __TARGET_FPU_VFP
-    #if (__FPU_PRESENT == 1U)
+    #if defined (__FPU_PRESENT) && (__FPU_PRESENT == 1U)
       #define __FPU_USED       1U
     #else
       #error "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)"
@@ -133,9 +85,21 @@
     #define __FPU_USED         0U
   #endif
-  #if defined __ARM_PCS_VFP
-    #if (__FPU_PRESENT == 1)
+#elif defined (__ARMCC_VERSION) && (__ARMCC_VERSION >= 6010050)
+  #if defined __ARM_FP
+      #define __FPU_USED       1U
+    #else
+      #warning "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)"
+      #define __FPU_USED       0U
+    #endif
+  #else
+  #endif
+#elif defined (__ti__)
+  #if defined (__ARM_FP)
     #else
@@ -147,7 +111,7 @@
   #if defined (__VFP_FP__) && !defined(__SOFTFP__)
     #else
@@ -159,7 +123,7 @@
   #if defined __ARMVFP__
     #else
@@ -169,9 +133,9 @@
   #endif
+#elif defined ( __TI_ARM__ )
   #if defined __TI_VFP_SUPPORT__
     #else
@@ -183,7 +147,7 @@
   #if defined __FPU_VFP__
     #else
@@ -195,7 +159,7 @@
   #if ( __CSMC__ & 0x400U)
     #else
@@ -207,9 +171,8 @@
 #endif
-#include "core_cmInstr.h"                /* Core Instruction Access */
-#include "core_cmFunc.h"                 /* Core Function Access */
-#include "core_cmSimd.h"                 /* Compiler specific SIMD Intrinsics */
+#include "cmsis_compiler.h"               /* CMSIS compiler specific defines */
 #ifdef __cplusplus
@@ -243,8 +206,13 @@
     #warning "__MPU_PRESENT not defined in device header file; using default!"
   #endif
+  #ifndef __VTOR_PRESENT
+    #define __VTOR_PRESENT             1U
+    #warning "__VTOR_PRESENT not defined in device header file; using default!"
+  #endif
   #ifndef __NVIC_PRIO_BITS
-    #define __NVIC_PRIO_BITS          4U
+    #define __NVIC_PRIO_BITS          3U
     #warning "__NVIC_PRIO_BITS not defined in device header file; using default!"
   #endif
@@ -367,11 +335,12 @@ typedef union
   struct
     uint32_t ISR:9;                      /*!< bit:  0.. 8  Exception number */
-    uint32_t _reserved0:7;               /*!< bit:  9..15  Reserved */
+    uint32_t _reserved0:1;               /*!< bit:      9  Reserved */
+    uint32_t ICI_IT_1:6;                 /*!< bit: 10..15  ICI/IT part 1 */
     uint32_t GE:4;                       /*!< bit: 16..19  Greater than or Equal flags */
     uint32_t _reserved1:4;               /*!< bit: 20..23  Reserved */
-    uint32_t T:1;                        /*!< bit:     24  Thumb bit        (read 0) */
-    uint32_t IT:2;                       /*!< bit: 25..26  saved IT state   (read 0) */
+    uint32_t T:1;                        /*!< bit:     24  Thumb bit */
+    uint32_t ICI_IT_2:2;                 /*!< bit: 25..26  ICI/IT part 2 */
     uint32_t Q:1;                        /*!< bit:     27  Saturation condition flag */
     uint32_t V:1;                        /*!< bit:     28  Overflow condition code flag */
     uint32_t C:1;                        /*!< bit:     29  Carry condition code flag */
@@ -397,8 +366,8 @@ typedef union
 #define xPSR_Q_Pos                         27U                                            /*!< xPSR: Q Position */
 #define xPSR_Q_Msk                         (1UL << xPSR_Q_Pos)                            /*!< xPSR: Q Mask */
-#define xPSR_IT_Pos                        25U                                            /*!< xPSR: IT Position */
-#define xPSR_IT_Msk                        (3UL << xPSR_IT_Pos)                           /*!< xPSR: IT Mask */
+#define xPSR_ICI_IT_2_Pos                  25U                                            /*!< xPSR: ICI/IT part 2 Position */
+#define xPSR_ICI_IT_2_Msk                  (3UL << xPSR_ICI_IT_2_Pos)                     /*!< xPSR: ICI/IT part 2 Mask */
 #define xPSR_T_Pos                         24U                                            /*!< xPSR: T Position */
 #define xPSR_T_Msk                         (1UL << xPSR_T_Pos)                            /*!< xPSR: T Mask */
@@ -406,6 +375,9 @@ typedef union
 #define xPSR_GE_Pos                        16U                                            /*!< xPSR: GE Position */
 #define xPSR_GE_Msk                        (0xFUL << xPSR_GE_Pos)                         /*!< xPSR: GE Mask */
+#define xPSR_ICI_IT_1_Pos                  10U                                            /*!< xPSR: ICI/IT part 1 Position */
+#define xPSR_ICI_IT_1_Msk                  (0x3FUL << xPSR_ICI_IT_1_Pos)                  /*!< xPSR: ICI/IT part 1 Mask */
 #define xPSR_ISR_Pos                        0U                                            /*!< xPSR: ISR Position */
 #define xPSR_ISR_Msk                       (0x1FFUL /*<< xPSR_ISR_Pos*/)                  /*!< xPSR: ISR Mask */
@@ -453,7 +425,7 @@ typedef struct
   __IOM uint32_t ISER[8U];               /*!< Offset: 0x000 (R/W)  Interrupt Set Enable Register */
         uint32_t RESERVED0[24U];
   __IOM uint32_t ICER[8U];               /*!< Offset: 0x080 (R/W)  Interrupt Clear Enable Register */
-        uint32_t RSERVED1[24U];
+        uint32_t RESERVED1[24U];
   __IOM uint32_t ISPR[8U];               /*!< Offset: 0x100 (R/W)  Interrupt Set Pending Register */
         uint32_t RESERVED2[24U];
   __IOM uint32_t ICPR[8U];               /*!< Offset: 0x180 (R/W)  Interrupt Clear Pending Register */
@@ -662,6 +634,66 @@ typedef struct
 #define SCB_CFSR_MEMFAULTSR_Pos             0U                                            /*!< SCB CFSR: Memory Manage Fault Status Register Position */
 #define SCB_CFSR_MEMFAULTSR_Msk            (0xFFUL /*<< SCB_CFSR_MEMFAULTSR_Pos*/)        /*!< SCB CFSR: Memory Manage Fault Status Register Mask */
+/* MemManage Fault Status Register (part of SCB Configurable Fault Status Register) */
+#define SCB_CFSR_MMARVALID_Pos             (SCB_CFSR_MEMFAULTSR_Pos + 7U)                 /*!< SCB CFSR (MMFSR): MMARVALID Position */
+#define SCB_CFSR_MMARVALID_Msk             (1UL << SCB_CFSR_MMARVALID_Pos)                /*!< SCB CFSR (MMFSR): MMARVALID Mask */
+#define SCB_CFSR_MLSPERR_Pos               (SCB_CFSR_MEMFAULTSR_Pos + 5U)                 /*!< SCB CFSR (MMFSR): MLSPERR Position */
+#define SCB_CFSR_MLSPERR_Msk               (1UL << SCB_CFSR_MLSPERR_Pos)                  /*!< SCB CFSR (MMFSR): MLSPERR Mask */
+#define SCB_CFSR_MSTKERR_Pos               (SCB_CFSR_MEMFAULTSR_Pos + 4U)                 /*!< SCB CFSR (MMFSR): MSTKERR Position */
+#define SCB_CFSR_MSTKERR_Msk               (1UL << SCB_CFSR_MSTKERR_Pos)                  /*!< SCB CFSR (MMFSR): MSTKERR Mask */
+#define SCB_CFSR_MUNSTKERR_Pos             (SCB_CFSR_MEMFAULTSR_Pos + 3U)                 /*!< SCB CFSR (MMFSR): MUNSTKERR Position */
+#define SCB_CFSR_MUNSTKERR_Msk             (1UL << SCB_CFSR_MUNSTKERR_Pos)                /*!< SCB CFSR (MMFSR): MUNSTKERR Mask */
+#define SCB_CFSR_DACCVIOL_Pos              (SCB_CFSR_MEMFAULTSR_Pos + 1U)                 /*!< SCB CFSR (MMFSR): DACCVIOL Position */
+#define SCB_CFSR_DACCVIOL_Msk              (1UL << SCB_CFSR_DACCVIOL_Pos)                 /*!< SCB CFSR (MMFSR): DACCVIOL Mask */
+#define SCB_CFSR_IACCVIOL_Pos              (SCB_CFSR_MEMFAULTSR_Pos + 0U)                 /*!< SCB CFSR (MMFSR): IACCVIOL Position */
+#define SCB_CFSR_IACCVIOL_Msk              (1UL /*<< SCB_CFSR_IACCVIOL_Pos*/)             /*!< SCB CFSR (MMFSR): IACCVIOL Mask */
+/* BusFault Status Register (part of SCB Configurable Fault Status Register) */
+#define SCB_CFSR_BFARVALID_Pos            (SCB_CFSR_BUSFAULTSR_Pos + 7U)                  /*!< SCB CFSR (BFSR): BFARVALID Position */
+#define SCB_CFSR_BFARVALID_Msk            (1UL << SCB_CFSR_BFARVALID_Pos)                 /*!< SCB CFSR (BFSR): BFARVALID Mask */
+#define SCB_CFSR_LSPERR_Pos               (SCB_CFSR_BUSFAULTSR_Pos + 5U)                  /*!< SCB CFSR (BFSR): LSPERR Position */
+#define SCB_CFSR_LSPERR_Msk               (1UL << SCB_CFSR_LSPERR_Pos)                    /*!< SCB CFSR (BFSR): LSPERR Mask */
+#define SCB_CFSR_STKERR_Pos               (SCB_CFSR_BUSFAULTSR_Pos + 4U)                  /*!< SCB CFSR (BFSR): STKERR Position */
+#define SCB_CFSR_STKERR_Msk               (1UL << SCB_CFSR_STKERR_Pos)                    /*!< SCB CFSR (BFSR): STKERR Mask */
+#define SCB_CFSR_UNSTKERR_Pos             (SCB_CFSR_BUSFAULTSR_Pos + 3U)                  /*!< SCB CFSR (BFSR): UNSTKERR Position */
+#define SCB_CFSR_UNSTKERR_Msk             (1UL << SCB_CFSR_UNSTKERR_Pos)                  /*!< SCB CFSR (BFSR): UNSTKERR Mask */
+#define SCB_CFSR_IMPRECISERR_Pos          (SCB_CFSR_BUSFAULTSR_Pos + 2U)                  /*!< SCB CFSR (BFSR): IMPRECISERR Position */
+#define SCB_CFSR_IMPRECISERR_Msk          (1UL << SCB_CFSR_IMPRECISERR_Pos)               /*!< SCB CFSR (BFSR): IMPRECISERR Mask */
+#define SCB_CFSR_PRECISERR_Pos            (SCB_CFSR_BUSFAULTSR_Pos + 1U)                  /*!< SCB CFSR (BFSR): PRECISERR Position */
+#define SCB_CFSR_PRECISERR_Msk            (1UL << SCB_CFSR_PRECISERR_Pos)                 /*!< SCB CFSR (BFSR): PRECISERR Mask */
+#define SCB_CFSR_IBUSERR_Pos              (SCB_CFSR_BUSFAULTSR_Pos + 0U)                  /*!< SCB CFSR (BFSR): IBUSERR Position */
+#define SCB_CFSR_IBUSERR_Msk              (1UL << SCB_CFSR_IBUSERR_Pos)                   /*!< SCB CFSR (BFSR): IBUSERR Mask */
+/* UsageFault Status Register (part of SCB Configurable Fault Status Register) */
+#define SCB_CFSR_DIVBYZERO_Pos            (SCB_CFSR_USGFAULTSR_Pos + 9U)                  /*!< SCB CFSR (UFSR): DIVBYZERO Position */
+#define SCB_CFSR_DIVBYZERO_Msk            (1UL << SCB_CFSR_DIVBYZERO_Pos)                 /*!< SCB CFSR (UFSR): DIVBYZERO Mask */
+#define SCB_CFSR_UNALIGNED_Pos            (SCB_CFSR_USGFAULTSR_Pos + 8U)                  /*!< SCB CFSR (UFSR): UNALIGNED Position */
+#define SCB_CFSR_UNALIGNED_Msk            (1UL << SCB_CFSR_UNALIGNED_Pos)                 /*!< SCB CFSR (UFSR): UNALIGNED Mask */
+#define SCB_CFSR_NOCP_Pos                 (SCB_CFSR_USGFAULTSR_Pos + 3U)                  /*!< SCB CFSR (UFSR): NOCP Position */
+#define SCB_CFSR_NOCP_Msk                 (1UL << SCB_CFSR_NOCP_Pos)                      /*!< SCB CFSR (UFSR): NOCP Mask */
+#define SCB_CFSR_INVPC_Pos                (SCB_CFSR_USGFAULTSR_Pos + 2U)                  /*!< SCB CFSR (UFSR): INVPC Position */
+#define SCB_CFSR_INVPC_Msk                (1UL << SCB_CFSR_INVPC_Pos)                     /*!< SCB CFSR (UFSR): INVPC Mask */
+#define SCB_CFSR_INVSTATE_Pos             (SCB_CFSR_USGFAULTSR_Pos + 1U)                  /*!< SCB CFSR (UFSR): INVSTATE Position */
+#define SCB_CFSR_INVSTATE_Msk             (1UL << SCB_CFSR_INVSTATE_Pos)                  /*!< SCB CFSR (UFSR): INVSTATE Mask */
+#define SCB_CFSR_UNDEFINSTR_Pos           (SCB_CFSR_USGFAULTSR_Pos + 0U)                  /*!< SCB CFSR (UFSR): UNDEFINSTR Position */
+#define SCB_CFSR_UNDEFINSTR_Msk           (1UL << SCB_CFSR_UNDEFINSTR_Pos)                /*!< SCB CFSR (UFSR): UNDEFINSTR Mask */
 /* SCB Hard Fault Status Register Definitions */
 #define SCB_HFSR_DEBUGEVT_Pos              31U                                            /*!< SCB HFSR: DEBUGEVT Position */
 #define SCB_HFSR_DEBUGEVT_Msk              (1UL << SCB_HFSR_DEBUGEVT_Pos)                 /*!< SCB HFSR: DEBUGEVT Mask */
@@ -807,10 +839,7 @@ typedef struct
   __IOM uint32_t TPR;                    /*!< Offset: 0xE40 (R/W)  ITM Trace Privilege Register */
         uint32_t RESERVED2[15U];
   __IOM uint32_t TCR;                    /*!< Offset: 0xE80 (R/W)  ITM Trace Control Register */
-        uint32_t RESERVED3[29U];
-  __OM  uint32_t IWR;                    /*!< Offset: 0xEF8 ( /W)  ITM Integration Write Register */
-  __IM  uint32_t IRR;                    /*!< Offset: 0xEFC (R/ )  ITM Integration Read Register */
-  __IOM uint32_t IMCR;                   /*!< Offset: 0xF00 (R/W)  ITM Integration Mode Control Register */
+        uint32_t RESERVED3[32U];
         uint32_t RESERVED4[43U];
   __OM  uint32_t LAR;                    /*!< Offset: 0xFB0 ( /W)  ITM Lock Access Register */
   __IM  uint32_t LSR;                    /*!< Offset: 0xFB4 (R/ )  ITM Lock Status Register */
@@ -831,20 +860,20 @@ typedef struct
 /* ITM Trace Privilege Register Definitions */
 #define ITM_TPR_PRIVMASK_Pos                0U                                            /*!< ITM TPR: PRIVMASK Position */
-#define ITM_TPR_PRIVMASK_Msk               (0xFUL /*<< ITM_TPR_PRIVMASK_Pos*/)            /*!< ITM TPR: PRIVMASK Mask */
+#define ITM_TPR_PRIVMASK_Msk               (0xFFFFFFFFUL /*<< ITM_TPR_PRIVMASK_Pos*/)     /*!< ITM TPR: PRIVMASK Mask */
 /* ITM Trace Control Register Definitions */
 #define ITM_TCR_BUSY_Pos                   23U                                            /*!< ITM TCR: BUSY Position */
 #define ITM_TCR_BUSY_Msk                   (1UL << ITM_TCR_BUSY_Pos)                      /*!< ITM TCR: BUSY Mask */
-#define ITM_TCR_TraceBusID_Pos             16U                                            /*!< ITM TCR: ATBID Position */
-#define ITM_TCR_TraceBusID_Msk             (0x7FUL << ITM_TCR_TraceBusID_Pos)             /*!< ITM TCR: ATBID Mask */
+#define ITM_TCR_TRACEBUSID_Pos             16U                                            /*!< ITM TCR: ATBID Position */
+#define ITM_TCR_TRACEBUSID_Msk             (0x7FUL << ITM_TCR_TRACEBUSID_Pos)             /*!< ITM TCR: ATBID Mask */
 #define ITM_TCR_GTSFREQ_Pos                10U                                            /*!< ITM TCR: Global timestamp frequency Position */
 #define ITM_TCR_GTSFREQ_Msk                (3UL << ITM_TCR_GTSFREQ_Pos)                   /*!< ITM TCR: Global timestamp frequency Mask */
-#define ITM_TCR_TSPrescale_Pos              8U                                            /*!< ITM TCR: TSPrescale Position */
-#define ITM_TCR_TSPrescale_Msk             (3UL << ITM_TCR_TSPrescale_Pos)                /*!< ITM TCR: TSPrescale Mask */
+#define ITM_TCR_TSPRESCALE_Pos              8U                                            /*!< ITM TCR: TSPrescale Position */
+#define ITM_TCR_TSPRESCALE_Msk             (3UL << ITM_TCR_TSPRESCALE_Pos)                /*!< ITM TCR: TSPrescale Mask */
 #define ITM_TCR_SWOENA_Pos                  4U                                            /*!< ITM TCR: SWOENA Position */
 #define ITM_TCR_SWOENA_Msk                 (1UL << ITM_TCR_SWOENA_Pos)                    /*!< ITM TCR: SWOENA Mask */
@@ -861,27 +890,15 @@ typedef struct
 #define ITM_TCR_ITMENA_Pos                  0U                                            /*!< ITM TCR: ITM Enable bit Position */
 #define ITM_TCR_ITMENA_Msk                 (1UL /*<< ITM_TCR_ITMENA_Pos*/)                /*!< ITM TCR: ITM Enable bit Mask */
-/* ITM Integration Write Register Definitions */
-#define ITM_IWR_ATVALIDM_Pos                0U                                            /*!< ITM IWR: ATVALIDM Position */
-#define ITM_IWR_ATVALIDM_Msk               (1UL /*<< ITM_IWR_ATVALIDM_Pos*/)              /*!< ITM IWR: ATVALIDM Mask */
-/* ITM Integration Read Register Definitions */
-#define ITM_IRR_ATREADYM_Pos                0U                                            /*!< ITM IRR: ATREADYM Position */
-#define ITM_IRR_ATREADYM_Msk               (1UL /*<< ITM_IRR_ATREADYM_Pos*/)              /*!< ITM IRR: ATREADYM Mask */
-/* ITM Integration Mode Control Register Definitions */
-#define ITM_IMCR_INTEGRATION_Pos            0U                                            /*!< ITM IMCR: INTEGRATION Position */
-#define ITM_IMCR_INTEGRATION_Msk           (1UL /*<< ITM_IMCR_INTEGRATION_Pos*/)          /*!< ITM IMCR: INTEGRATION Mask */
 /* ITM Lock Status Register Definitions */
-#define ITM_LSR_ByteAcc_Pos                 2U                                            /*!< ITM LSR: ByteAcc Position */
-#define ITM_LSR_ByteAcc_Msk                (1UL << ITM_LSR_ByteAcc_Pos)                   /*!< ITM LSR: ByteAcc Mask */
+#define ITM_LSR_BYTEACC_Pos                 2U                                            /*!< ITM LSR: ByteAcc Position */
+#define ITM_LSR_BYTEACC_Msk                (1UL << ITM_LSR_BYTEACC_Pos)                   /*!< ITM LSR: ByteAcc Mask */
-#define ITM_LSR_Access_Pos                  1U                                            /*!< ITM LSR: Access Position */
-#define ITM_LSR_Access_Msk                 (1UL << ITM_LSR_Access_Pos)                    /*!< ITM LSR: Access Mask */
+#define ITM_LSR_ACCESS_Pos                  1U                                            /*!< ITM LSR: Access Position */
+#define ITM_LSR_ACCESS_Msk                 (1UL << ITM_LSR_ACCESS_Pos)                    /*!< ITM LSR: Access Mask */
-#define ITM_LSR_Present_Pos                 0U                                            /*!< ITM LSR: Present Position */
-#define ITM_LSR_Present_Msk                (1UL /*<< ITM_LSR_Present_Pos*/)               /*!< ITM LSR: Present Mask */
+#define ITM_LSR_PRESENT_Pos                 0U                                            /*!< ITM LSR: Present Position */
+#define ITM_LSR_PRESENT_Msk                (1UL /*<< ITM_LSR_PRESENT_Pos*/)               /*!< ITM LSR: Present Mask */
 /*@}*/ /* end of group CMSIS_ITM */
@@ -1045,7 +1062,7 @@ typedef struct
 typedef struct
-  __IOM uint32_t SSPSR;                  /*!< Offset: 0x000 (R/ )  Supported Parallel Port Size Register */
+  __IM  uint32_t SSPSR;                  /*!< Offset: 0x000 (R/ )  Supported Parallel Port Size Register */
   __IOM uint32_t CSPSR;                  /*!< Offset: 0x004 (R/W)  Current Parallel Port Size Register */
         uint32_t RESERVED0[2U];
   __IOM uint32_t ACPR;                   /*!< Offset: 0x010 (R/W)  Asynchronous Clock Prescaler Register */
@@ -1056,7 +1073,7 @@ typedef struct
   __IOM uint32_t FFCR;                   /*!< Offset: 0x304 (R/W)  Formatter and Flush Control Register */
   __IM  uint32_t FSCR;                   /*!< Offset: 0x308 (R/ )  Formatter Synchronization Counter Register */
         uint32_t RESERVED3[759U];
-  __IM  uint32_t TRIGGER;                /*!< Offset: 0xEE8 (R/ )  TRIGGER */
+  __IM  uint32_t TRIGGER;                /*!< Offset: 0xEE8 (R/ )  TRIGGER Register */
   __IM  uint32_t FIFO0;                  /*!< Offset: 0xEEC (R/ )  Integration ETM Data */
   __IM  uint32_t ITATBCTR2;              /*!< Offset: 0xEF0 (R/ )  ITATBCTR2 */
         uint32_t RESERVED4[1U];
@@ -1105,13 +1122,13 @@ typedef struct
 /* TPI Integration ETM Data Register Definitions (FIFO0) */
 #define TPI_FIFO0_ITM_ATVALID_Pos          29U                                         /*!< TPI FIFO0: ITM_ATVALID Position */
-#define TPI_FIFO0_ITM_ATVALID_Msk          (0x3UL << TPI_FIFO0_ITM_ATVALID_Pos)        /*!< TPI FIFO0: ITM_ATVALID Mask */
+#define TPI_FIFO0_ITM_ATVALID_Msk          (0x1UL << TPI_FIFO0_ITM_ATVALID_Pos)        /*!< TPI FIFO0: ITM_ATVALID Mask */
 #define TPI_FIFO0_ITM_bytecount_Pos        27U                                         /*!< TPI FIFO0: ITM_bytecount Position */
 #define TPI_FIFO0_ITM_bytecount_Msk        (0x3UL << TPI_FIFO0_ITM_bytecount_Pos)      /*!< TPI FIFO0: ITM_bytecount Mask */
 #define TPI_FIFO0_ETM_ATVALID_Pos          26U                                         /*!< TPI FIFO0: ETM_ATVALID Position */
-#define TPI_FIFO0_ETM_ATVALID_Msk          (0x3UL << TPI_FIFO0_ETM_ATVALID_Pos)        /*!< TPI FIFO0: ETM_ATVALID Mask */
+#define TPI_FIFO0_ETM_ATVALID_Msk          (0x1UL << TPI_FIFO0_ETM_ATVALID_Pos)        /*!< TPI FIFO0: ETM_ATVALID Mask */
 #define TPI_FIFO0_ETM_bytecount_Pos        24U                                         /*!< TPI FIFO0: ETM_bytecount Position */
 #define TPI_FIFO0_ETM_bytecount_Msk        (0x3UL << TPI_FIFO0_ETM_bytecount_Pos)      /*!< TPI FIFO0: ETM_bytecount Mask */
@@ -1126,18 +1143,21 @@ typedef struct
 #define TPI_FIFO0_ETM0_Msk                 (0xFFUL /*<< TPI_FIFO0_ETM0_Pos*/)          /*!< TPI FIFO0: ETM0 Mask */
 /* TPI ITATBCTR2 Register Definitions */
-#define TPI_ITATBCTR2_ATREADY_Pos           0U                                         /*!< TPI ITATBCTR2: ATREADY Position */
-#define TPI_ITATBCTR2_ATREADY_Msk          (0x1UL /*<< TPI_ITATBCTR2_ATREADY_Pos*/)    /*!< TPI ITATBCTR2: ATREADY Mask */
+#define TPI_ITATBCTR2_ATREADY2_Pos          0U                                         /*!< TPI ITATBCTR2: ATREADY2 Position */
+#define TPI_ITATBCTR2_ATREADY2_Msk         (0x1UL /*<< TPI_ITATBCTR2_ATREADY2_Pos*/)   /*!< TPI ITATBCTR2: ATREADY2 Mask */
+#define TPI_ITATBCTR2_ATREADY1_Pos          0U                                         /*!< TPI ITATBCTR2: ATREADY1 Position */
+#define TPI_ITATBCTR2_ATREADY1_Msk         (0x1UL /*<< TPI_ITATBCTR2_ATREADY1_Pos*/)   /*!< TPI ITATBCTR2: ATREADY1 Mask */
 /* TPI Integration ITM Data Register Definitions (FIFO1) */
 #define TPI_FIFO1_ITM_ATVALID_Pos          29U                                         /*!< TPI FIFO1: ITM_ATVALID Position */
-#define TPI_FIFO1_ITM_ATVALID_Msk          (0x3UL << TPI_FIFO1_ITM_ATVALID_Pos)        /*!< TPI FIFO1: ITM_ATVALID Mask */
+#define TPI_FIFO1_ITM_ATVALID_Msk          (0x1UL << TPI_FIFO1_ITM_ATVALID_Pos)        /*!< TPI FIFO1: ITM_ATVALID Mask */
 #define TPI_FIFO1_ITM_bytecount_Pos        27U                                         /*!< TPI FIFO1: ITM_bytecount Position */
 #define TPI_FIFO1_ITM_bytecount_Msk        (0x3UL << TPI_FIFO1_ITM_bytecount_Pos)      /*!< TPI FIFO1: ITM_bytecount Mask */
 #define TPI_FIFO1_ETM_ATVALID_Pos          26U                                         /*!< TPI FIFO1: ETM_ATVALID Position */
-#define TPI_FIFO1_ETM_ATVALID_Msk          (0x3UL << TPI_FIFO1_ETM_ATVALID_Pos)        /*!< TPI FIFO1: ETM_ATVALID Mask */
+#define TPI_FIFO1_ETM_ATVALID_Msk          (0x1UL << TPI_FIFO1_ETM_ATVALID_Pos)        /*!< TPI FIFO1: ETM_ATVALID Mask */
 #define TPI_FIFO1_ETM_bytecount_Pos        24U                                         /*!< TPI FIFO1: ETM_bytecount Position */
 #define TPI_FIFO1_ETM_bytecount_Msk        (0x3UL << TPI_FIFO1_ETM_bytecount_Pos)      /*!< TPI FIFO1: ETM_bytecount Mask */
@@ -1152,12 +1172,15 @@ typedef struct
 #define TPI_FIFO1_ITM0_Msk                 (0xFFUL /*<< TPI_FIFO1_ITM0_Pos*/)          /*!< TPI FIFO1: ITM0 Mask */
 /* TPI ITATBCTR0 Register Definitions */
-#define TPI_ITATBCTR0_ATREADY_Pos           0U                                         /*!< TPI ITATBCTR0: ATREADY Position */
-#define TPI_ITATBCTR0_ATREADY_Msk          (0x1UL /*<< TPI_ITATBCTR0_ATREADY_Pos*/)    /*!< TPI ITATBCTR0: ATREADY Mask */
+#define TPI_ITATBCTR0_ATREADY2_Pos          0U                                         /*!< TPI ITATBCTR0: ATREADY2 Position */
+#define TPI_ITATBCTR0_ATREADY2_Msk         (0x1UL /*<< TPI_ITATBCTR0_ATREADY2_Pos*/)   /*!< TPI ITATBCTR0: ATREADY2 Mask */
+#define TPI_ITATBCTR0_ATREADY1_Pos          0U                                         /*!< TPI ITATBCTR0: ATREADY1 Position */
+#define TPI_ITATBCTR0_ATREADY1_Msk         (0x1UL /*<< TPI_ITATBCTR0_ATREADY1_Pos*/)   /*!< TPI ITATBCTR0: ATREADY1 Mask */
 /* TPI Integration Mode Control Register Definitions */
 #define TPI_ITCTRL_Mode_Pos                 0U                                         /*!< TPI ITCTRL: Mode Position */
-#define TPI_ITCTRL_Mode_Msk                (0x1UL /*<< TPI_ITCTRL_Mode_Pos*/)          /*!< TPI ITCTRL: Mode Mask */
+#define TPI_ITCTRL_Mode_Msk                (0x3UL /*<< TPI_ITCTRL_Mode_Pos*/)          /*!< TPI ITCTRL: Mode Mask */
 /* TPI DEVID Register Definitions */
 #define TPI_DEVID_NRZVALID_Pos             11U                                         /*!< TPI DEVID: NRZVALID Position */
@@ -1179,16 +1202,16 @@ typedef struct
 #define TPI_DEVID_NrTraceInput_Msk         (0x1FUL /*<< TPI_DEVID_NrTraceInput_Pos*/)  /*!< TPI DEVID: NrTraceInput Mask */
 /* TPI DEVTYPE Register Definitions */
-#define TPI_DEVTYPE_MajorType_Pos           4U                                         /*!< TPI DEVTYPE: MajorType Position */
-#define TPI_DEVTYPE_MajorType_Msk          (0xFUL << TPI_DEVTYPE_MajorType_Pos)        /*!< TPI DEVTYPE: MajorType Mask */
-#define TPI_DEVTYPE_SubType_Pos             0U                                         /*!< TPI DEVTYPE: SubType Position */
+#define TPI_DEVTYPE_SubType_Pos             4U                                         /*!< TPI DEVTYPE: SubType Position */
 #define TPI_DEVTYPE_SubType_Msk            (0xFUL /*<< TPI_DEVTYPE_SubType_Pos*/)      /*!< TPI DEVTYPE: SubType Mask */
+#define TPI_DEVTYPE_MajorType_Pos           0U                                         /*!< TPI DEVTYPE: MajorType Position */
+#define TPI_DEVTYPE_MajorType_Msk          (0xFUL << TPI_DEVTYPE_MajorType_Pos)        /*!< TPI DEVTYPE: MajorType Mask */
 /*@}*/ /* end of group CMSIS_TPI */
-#if (__MPU_PRESENT == 1U)
+#if defined (__MPU_PRESENT) && (__MPU_PRESENT == 1U)
   \ingroup  CMSIS_core_register
   \defgroup CMSIS_MPU     Memory Protection Unit (MPU)
@@ -1214,6 +1237,8 @@ typedef struct
   __IOM uint32_t RASR_A3;                /*!< Offset: 0x028 (R/W)  MPU Alias 3 Region Attribute and Size Register */
 } MPU_Type;
+#define MPU_TYPE_RALIASES                  4U
 /* MPU Type Register Definitions */
 #define MPU_TYPE_IREGION_Pos               16U                                            /*!< MPU TYPE: IREGION Position */
 #define MPU_TYPE_IREGION_Msk               (0xFFUL << MPU_TYPE_IREGION_Pos)               /*!< MPU TYPE: IREGION Mask */
@@ -1280,10 +1305,9 @@ typedef struct
 #define MPU_RASR_ENABLE_Msk                (1UL /*<< MPU_RASR_ENABLE_Pos*/)               /*!< MPU RASR: Region enable bit Disable Mask */
 /*@} end of group CMSIS_MPU */
-#endif
+#endif /* defined (__MPU_PRESENT) && (__MPU_PRESENT == 1U) */
-#if (__FPU_PRESENT == 1U)
   \defgroup CMSIS_FPU     Floating Point Unit (FPU)
@@ -1302,6 +1326,7 @@ typedef struct
   __IOM uint32_t FPDSCR;                 /*!< Offset: 0x00C (R/W)  Floating-Point Default Status Control Register */
   __IM  uint32_t MVFR0;                  /*!< Offset: 0x010 (R/ )  Media and FP Feature Register 0 */
   __IM  uint32_t MVFR1;                  /*!< Offset: 0x014 (R/ )  Media and FP Feature Register 1 */
+  __IM  uint32_t MVFR2;                  /*!< Offset: 0x018 (R/ )  Media and FP Feature Register 2 */
 } FPU_Type;
 /* Floating-Point Context Control Register Definitions */
@@ -1387,8 +1412,12 @@ typedef struct
 #define FPU_MVFR1_FtZ_mode_Pos              0U                                            /*!< MVFR1: FtZ mode bits Position */
 #define FPU_MVFR1_FtZ_mode_Msk             (0xFUL /*<< FPU_MVFR1_FtZ_mode_Pos*/)          /*!< MVFR1: FtZ mode bits Mask */
+/* Media and FP Feature Register 2 Definitions */
+#define FPU_MVFR2_VFP_Misc_Pos              4U                                            /*!< MVFR2: VFP Misc bits Position */
+#define FPU_MVFR2_VFP_Misc_Msk             (0xFUL << FPU_MVFR2_VFP_Misc_Pos)              /*!< MVFR2: VFP Misc bits Mask */
 /*@} end of group CMSIS_FPU */
-#endif
@@ -1506,18 +1535,18 @@ typedef struct
   \brief   Mask and shift a bit field value for use in a register bit range.
   \param[in] field  Name of the register bit field.
-  \param[in] value  Value of the bit field.
+  \param[in] value  Value of the bit field. This parameter is interpreted as an uint32_t type.
   \return           Masked and shifted value.
-#define _VAL2FLD(field, value)    ((value << field ## _Pos) & field ## _Msk)
+#define _VAL2FLD(field, value)    (((uint32_t)(value) << field ## _Pos) & field ## _Msk)
   \brief     Mask and shift a register value to extract a bit filed value.
-  \param[in] value  Value of register.
+  \param[in] value  Value of register. This parameter is interpreted as an uint32_t type.
   \return           Masked and shifted bit field value.
-#define _FLD2VAL(field, value)    ((value & field ## _Msk) >> field ## _Pos)
+#define _FLD2VAL(field, value)    (((uint32_t)(value) & field ## _Msk) >> field ## _Pos)
 /*@} end of group CMSIS_core_bitfield */
@@ -1529,7 +1558,7 @@ typedef struct
-/* Memory mapping of Cortex-M4 Hardware */
+/* Memory mapping of Core Hardware */
 #define SCS_BASE            (0xE000E000UL)                            /*!< System Control Space Base Address */
 #define ITM_BASE            (0xE0000000UL)                            /*!< ITM Base Address */
 #define DWT_BASE            (0xE0001000UL)                            /*!< DWT Base Address */
@@ -1548,15 +1577,42 @@ typedef struct
 #define TPI                 ((TPI_Type       *)     TPI_BASE      )   /*!< TPI configuration struct */
 #define CoreDebug           ((CoreDebug_Type *)     CoreDebug_BASE)   /*!< Core Debug configuration struct */
   #define MPU_BASE          (SCS_BASE +  0x0D90UL)                    /*!< Memory Protection Unit */
   #define MPU               ((MPU_Type       *)     MPU_BASE      )   /*!< Memory Protection Unit */
 #endif
-  #define FPU_BASE          (SCS_BASE +  0x0F30UL)                    /*!< Floating Point Unit */
-  #define FPU               ((FPU_Type       *)     FPU_BASE      )   /*!< Floating Point Unit */
-#endif
+#define FPU_BASE            (SCS_BASE +  0x0F30UL)                    /*!< Floating Point Unit */
+#define FPU                 ((FPU_Type       *)     FPU_BASE      )   /*!< Floating Point Unit */
+  \ingroup    CMSIS_core_register
+  \defgroup   CMSIS_register_aliases     Backwards Compatibility Aliases
+  \brief      Register alias definitions for backwards compatibility.
+/* Capitalize ITM_TCR Register Definitions */
+/* ITM Trace Control Register Definitions */
+#define ITM_TCR_TraceBusID_Pos           (ITM_TCR_TRACEBUSID_Pos)     /*!< \deprecated ITM_TCR_TraceBusID_Pos */
+#define ITM_TCR_TraceBusID_Msk           (ITM_TCR_TRACEBUSID_Msk)     /*!< \deprecated ITM_TCR_TraceBusID_Msk */
+#define ITM_TCR_TSPrescale_Pos           (ITM_TCR_TSPRESCALE_Pos)     /*!< \deprecated ITM_TCR_TSPrescale_Pos */
+#define ITM_TCR_TSPrescale_Msk           (ITM_TCR_TSPRESCALE_Msk)     /*!< \deprecated ITM_TCR_TSPrescale_Msk */
+/* ITM Lock Status Register Definitions */
+#define ITM_LSR_ByteAcc_Pos              (ITM_LSR_BYTEACC_Pos)        /*!< \deprecated ITM_LSR_ByteAcc_Pos */
+#define ITM_LSR_ByteAcc_Msk              (ITM_LSR_BYTEACC_Msk)        /*!< \deprecated ITM_LSR_ByteAcc_Msk */
+#define ITM_LSR_Access_Pos               (ITM_LSR_ACCESS_Pos)         /*!< \deprecated ITM_LSR_Access_Pos */
+#define ITM_LSR_Access_Msk               (ITM_LSR_ACCESS_Msk)         /*!< \deprecated ITM_LSR_Access_Msk */
+#define ITM_LSR_Present_Pos              (ITM_LSR_PRESENT_Pos)        /*!< \deprecated ITM_LSR_Present_Pos */
+#define ITM_LSR_Present_Msk              (ITM_LSR_PRESENT_Msk)        /*!< \deprecated ITM_LSR_Present_Msk */
@@ -1584,6 +1640,48 @@ typedef struct
+#ifdef CMSIS_NVIC_VIRTUAL
+  #ifndef CMSIS_NVIC_VIRTUAL_HEADER_FILE
+    #define CMSIS_NVIC_VIRTUAL_HEADER_FILE "cmsis_nvic_virtual.h"
+  #endif
+  #include CMSIS_NVIC_VIRTUAL_HEADER_FILE
+#else
+  #define NVIC_SetPriorityGrouping    __NVIC_SetPriorityGrouping
+  #define NVIC_GetPriorityGrouping    __NVIC_GetPriorityGrouping
+  #define NVIC_EnableIRQ              __NVIC_EnableIRQ
+  #define NVIC_GetEnableIRQ           __NVIC_GetEnableIRQ
+  #define NVIC_DisableIRQ             __NVIC_DisableIRQ
+  #define NVIC_GetPendingIRQ          __NVIC_GetPendingIRQ
+  #define NVIC_SetPendingIRQ          __NVIC_SetPendingIRQ
+  #define NVIC_ClearPendingIRQ        __NVIC_ClearPendingIRQ
+  #define NVIC_GetActive              __NVIC_GetActive
+  #define NVIC_SetPriority            __NVIC_SetPriority
+  #define NVIC_GetPriority            __NVIC_GetPriority
+  #define NVIC_SystemReset            __NVIC_SystemReset
+#endif /* CMSIS_NVIC_VIRTUAL */
+#ifdef CMSIS_VECTAB_VIRTUAL
+  #ifndef CMSIS_VECTAB_VIRTUAL_HEADER_FILE
+    #define CMSIS_VECTAB_VIRTUAL_HEADER_FILE "cmsis_vectab_virtual.h"
+  #endif
+  #include CMSIS_VECTAB_VIRTUAL_HEADER_FILE
+#else
+  #define NVIC_SetVector              __NVIC_SetVector
+  #define NVIC_GetVector              __NVIC_GetVector
+#endif  /* (CMSIS_VECTAB_VIRTUAL) */
+#define NVIC_USER_IRQ_OFFSET          16
+/* The following EXC_RETURN values are saved the LR on exception entry */
+#define EXC_RETURN_HANDLER         (0xFFFFFFF1UL)     /* return to Handler mode, uses MSP after return                               */
+#define EXC_RETURN_THREAD_MSP      (0xFFFFFFF9UL)     /* return to Thread mode, uses MSP after return                                */
+#define EXC_RETURN_THREAD_PSP      (0xFFFFFFFDUL)     /* return to Thread mode, uses PSP after return                                */
+#define EXC_RETURN_HANDLER_FPU     (0xFFFFFFE1UL)     /* return to Handler mode, uses MSP after return, restore floating-point state */
+#define EXC_RETURN_THREAD_MSP_FPU  (0xFFFFFFE9UL)     /* return to Thread mode, uses MSP after return, restore floating-point state  */
+#define EXC_RETURN_THREAD_PSP_FPU  (0xFFFFFFEDUL)     /* return to Thread mode, uses PSP after return, restore floating-point state  */
   \brief   Set Priority Grouping
   \details Sets the priority grouping field using the required unlock sequence.
@@ -1593,7 +1691,7 @@ typedef struct
            priority bits (__NVIC_PRIO_BITS), the smallest possible priority group is set.
   \param [in]      PriorityGroup  Priority grouping field.
-__STATIC_INLINE void NVIC_SetPriorityGrouping(uint32_t PriorityGroup)
+__STATIC_INLINE void __NVIC_SetPriorityGrouping(uint32_t PriorityGroup)
   uint32_t reg_value;
   uint32_t PriorityGroupTmp = (PriorityGroup & (uint32_t)0x07UL);             /* only values 0..7 are used          */
@@ -1602,7 +1700,7 @@ __STATIC_INLINE void NVIC_SetPriorityGrouping(uint32_t PriorityGroup)
   reg_value &= ~((uint32_t)(SCB_AIRCR_VECTKEY_Msk | SCB_AIRCR_PRIGROUP_Msk)); /* clear bits to change               */
   reg_value  =  (reg_value                                   |
                 ((uint32_t)0x5FAUL << SCB_AIRCR_VECTKEY_Pos) |
-                (PriorityGroupTmp << 8U)                      );              /* Insert write key and priorty group */
+                (PriorityGroupTmp << SCB_AIRCR_PRIGROUP_Pos)  );              /* Insert write key and priority group */
   SCB->AIRCR =  reg_value;
@@ -1612,121 +1710,180 @@ __STATIC_INLINE void NVIC_SetPriorityGrouping(uint32_t PriorityGroup)
   \details Reads the priority grouping field from the NVIC Interrupt Controller.
   \return                Priority grouping field (SCB->AIRCR [10:8] PRIGROUP field).
-__STATIC_INLINE uint32_t NVIC_GetPriorityGrouping(void)
+__STATIC_INLINE uint32_t __NVIC_GetPriorityGrouping(void)
   return ((uint32_t)((SCB->AIRCR & SCB_AIRCR_PRIGROUP_Msk) >> SCB_AIRCR_PRIGROUP_Pos));
-  \brief   Enable External Interrupt
-  \details Enables a device-specific interrupt in the NVIC interrupt controller.
-  \param [in]      IRQn  External interrupt number. Value cannot be negative.
+  \brief   Enable Interrupt
+  \details Enables a device specific interrupt in the NVIC interrupt controller.
+  \param [in]      IRQn  Device specific interrupt number.
+  \note    IRQn must not be negative.
+__STATIC_INLINE void __NVIC_EnableIRQ(IRQn_Type IRQn)
+  if ((int32_t)(IRQn) >= 0)
+    __COMPILER_BARRIER();
+    NVIC->ISER[(((uint32_t)IRQn) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)IRQn) & 0x1FUL));
+  \brief   Get Interrupt Enable status
+  \details Returns a device specific interrupt enable status from the NVIC interrupt controller.
+  \return             0  Interrupt is not enabled.
+  \return             1  Interrupt is enabled.
-__STATIC_INLINE void NVIC_EnableIRQ(IRQn_Type IRQn)
+__STATIC_INLINE uint32_t __NVIC_GetEnableIRQ(IRQn_Type IRQn)
-  NVIC->ISER[(((uint32_t)(int32_t)IRQn) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)(int32_t)IRQn) & 0x1FUL));
+    return((uint32_t)(((NVIC->ISER[(((uint32_t)IRQn) >> 5UL)] & (1UL << (((uint32_t)IRQn) & 0x1FUL))) != 0UL) ? 1UL : 0UL));
+  else
+    return(0U);
-  \brief   Disable External Interrupt
-  \details Disables a device-specific interrupt in the NVIC interrupt controller.
+  \brief   Disable Interrupt
+  \details Disables a device specific interrupt in the NVIC interrupt controller.
-__STATIC_INLINE void NVIC_DisableIRQ(IRQn_Type IRQn)
+__STATIC_INLINE void __NVIC_DisableIRQ(IRQn_Type IRQn)
-  NVIC->ICER[(((uint32_t)(int32_t)IRQn) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)(int32_t)IRQn) & 0x1FUL));
+    NVIC->ICER[(((uint32_t)IRQn) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)IRQn) & 0x1FUL));
+    __DSB();
+    __ISB();
   \brief   Get Pending Interrupt
-  \details Reads the pending register in the NVIC and returns the pending bit for the specified interrupt.
-  \param [in]      IRQn  Interrupt number.
+  \details Reads the NVIC pending register and returns the pending bit for the specified device specific interrupt.
   \return             0  Interrupt status is not pending.
   \return             1  Interrupt status is pending.
-__STATIC_INLINE uint32_t NVIC_GetPendingIRQ(IRQn_Type IRQn)
+__STATIC_INLINE uint32_t __NVIC_GetPendingIRQ(IRQn_Type IRQn)
-  return((uint32_t)(((NVIC->ISPR[(((uint32_t)(int32_t)IRQn) >> 5UL)] & (1UL << (((uint32_t)(int32_t)IRQn) & 0x1FUL))) != 0UL) ? 1UL : 0UL));
+    return((uint32_t)(((NVIC->ISPR[(((uint32_t)IRQn) >> 5UL)] & (1UL << (((uint32_t)IRQn) & 0x1FUL))) != 0UL) ? 1UL : 0UL));
+  else
+    return(0U);
   \brief   Set Pending Interrupt
-  \details Sets the pending bit of an external interrupt.
-  \param [in]      IRQn  Interrupt number. Value cannot be negative.
+  \details Sets the pending bit of a device specific interrupt in the NVIC pending register.
-__STATIC_INLINE void NVIC_SetPendingIRQ(IRQn_Type IRQn)
+__STATIC_INLINE void __NVIC_SetPendingIRQ(IRQn_Type IRQn)
-  NVIC->ISPR[(((uint32_t)(int32_t)IRQn) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)(int32_t)IRQn) & 0x1FUL));
+    NVIC->ISPR[(((uint32_t)IRQn) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)IRQn) & 0x1FUL));
   \brief   Clear Pending Interrupt
-  \details Clears the pending bit of an external interrupt.
+  \details Clears the pending bit of a device specific interrupt in the NVIC pending register.
-__STATIC_INLINE void NVIC_ClearPendingIRQ(IRQn_Type IRQn)
+__STATIC_INLINE void __NVIC_ClearPendingIRQ(IRQn_Type IRQn)
-  NVIC->ICPR[(((uint32_t)(int32_t)IRQn) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)(int32_t)IRQn) & 0x1FUL));
+    NVIC->ICPR[(((uint32_t)IRQn) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)IRQn) & 0x1FUL));
   \brief   Get Active Interrupt
-  \details Reads the active register in NVIC and returns the active bit.
+  \details Reads the active register in the NVIC and returns the active bit for the device specific interrupt.
   \return             0  Interrupt status is not active.
   \return             1  Interrupt status is active.
-__STATIC_INLINE uint32_t NVIC_GetActive(IRQn_Type IRQn)
+__STATIC_INLINE uint32_t __NVIC_GetActive(IRQn_Type IRQn)
-  return((uint32_t)(((NVIC->IABR[(((uint32_t)(int32_t)IRQn) >> 5UL)] & (1UL << (((uint32_t)(int32_t)IRQn) & 0x1FUL))) != 0UL) ? 1UL : 0UL));
+    return((uint32_t)(((NVIC->IABR[(((uint32_t)IRQn) >> 5UL)] & (1UL << (((uint32_t)IRQn) & 0x1FUL))) != 0UL) ? 1UL : 0UL));
+  else
+    return(0U);
   \brief   Set Interrupt Priority
-  \details Sets the priority of an interrupt.
-  \note    The priority cannot be set for every core interrupt.
+  \details Sets the priority of a device specific interrupt or a processor exception.
+           The interrupt number can be positive to specify a device specific interrupt,
+           or negative to specify a processor exception.
   \param [in]  priority  Priority to set.
+  \note    The priority cannot be set for every processor exception.
-__STATIC_INLINE void NVIC_SetPriority(IRQn_Type IRQn, uint32_t priority)
+__STATIC_INLINE void __NVIC_SetPriority(IRQn_Type IRQn, uint32_t priority)
-  if ((int32_t)(IRQn) < 0)
-    SCB->SHP[(((uint32_t)(int32_t)IRQn) & 0xFUL)-4UL] = (uint8_t)((priority << (8U - __NVIC_PRIO_BITS)) & (uint32_t)0xFFUL);
+    NVIC->IP[((uint32_t)IRQn)]               = (uint8_t)((priority << (8U - __NVIC_PRIO_BITS)) & (uint32_t)0xFFUL);
   else
-    NVIC->IP[((uint32_t)(int32_t)IRQn)]               = (uint8_t)((priority << (8U - __NVIC_PRIO_BITS)) & (uint32_t)0xFFUL);
+    SCB->SHP[(((uint32_t)IRQn) & 0xFUL)-4UL] = (uint8_t)((priority << (8U - __NVIC_PRIO_BITS)) & (uint32_t)0xFFUL);
   \brief   Get Interrupt Priority
-  \details Reads the priority of an interrupt.
-           The interrupt number can be positive to specify an external (device specific) interrupt,
-           or negative to specify an internal (core) interrupt.
+  \details Reads the priority of a device specific interrupt or a processor exception.
   \return             Interrupt Priority.
                       Value is aligned automatically to the implemented priority bits of the microcontroller.
-__STATIC_INLINE uint32_t NVIC_GetPriority(IRQn_Type IRQn)
+__STATIC_INLINE uint32_t __NVIC_GetPriority(IRQn_Type IRQn)
-    return(((uint32_t)SCB->SHP[(((uint32_t)(int32_t)IRQn) & 0xFUL)-4UL] >> (8U - __NVIC_PRIO_BITS)));
+    return(((uint32_t)NVIC->IP[((uint32_t)IRQn)]               >> (8U - __NVIC_PRIO_BITS)));
   else
-    return(((uint32_t)NVIC->IP[((uint32_t)(int32_t)IRQn)]               >> (8U - __NVIC_PRIO_BITS)));
+    return(((uint32_t)SCB->SHP[(((uint32_t)IRQn) & 0xFUL)-4UL] >> (8U - __NVIC_PRIO_BITS)));
@@ -1783,11 +1940,43 @@ __STATIC_INLINE void NVIC_DecodePriority (uint32_t Priority, uint32_t PriorityGr
+  \brief   Set Interrupt Vector
+  \details Sets an interrupt vector in SRAM based interrupt vector table.
+           VTOR must been relocated to SRAM before.
+  \param [in]   IRQn      Interrupt number
+  \param [in]   vector    Address of interrupt handler function
+__STATIC_INLINE void __NVIC_SetVector(IRQn_Type IRQn, uint32_t vector)
+  uint32_t *vectors = (uint32_t *)SCB->VTOR;
+  vectors[(int32_t)IRQn + NVIC_USER_IRQ_OFFSET] = vector;
+  /* ARM Application Note 321 states that the M4 does not require the architectural barrier */
+  \brief   Get Interrupt Vector
+  \details Reads an interrupt vector from interrupt vector table.
+  \param [in]   IRQn      Interrupt number.
+  \return                 Address of interrupt handler function
+__STATIC_INLINE uint32_t __NVIC_GetVector(IRQn_Type IRQn)
+  return vectors[(int32_t)IRQn + NVIC_USER_IRQ_OFFSET];
   \brief   System Reset
   \details Initiates a system reset request to reset the MCU.
-__STATIC_INLINE void NVIC_SystemReset(void)
+__NO_RETURN __STATIC_INLINE void __NVIC_SystemReset(void)
   __DSB();                                                          /* Ensure all outstanding memory accesses included
        buffered write are completed before reset */
@@ -1805,6 +1994,50 @@ __STATIC_INLINE void NVIC_SystemReset(void)
 /*@} end of CMSIS_Core_NVICFunctions */
+/* ##########################  MPU functions  #################################### */
+#include "mpu_armv7.h"
+#endif
+/* ##########################  FPU functions  #################################### */
+  \ingroup  CMSIS_Core_FunctionInterface
+  \defgroup CMSIS_Core_FpuFunctions FPU Functions
+  \brief    Function that provides FPU type.
+  \brief   get FPU type
+  \details returns the FPU type
+  \returns
+   - \b  0: No FPU
+   - \b  1: Single precision FPU
+   - \b  2: Double + Single precision FPU
+__STATIC_INLINE uint32_t SCB_GetFPUType(void)
+  uint32_t mvfr0;
+  mvfr0 = FPU->MVFR0;
+  if      ((mvfr0 & (FPU_MVFR0_Single_precision_Msk | FPU_MVFR0_Double_precision_Msk)) == 0x020U)
+    return 1U;           /* Single precision FPU */
+  else
+    return 0U;           /* No FPU */
+/*@} end of CMSIS_Core_FpuFunctions */
 /* ##################################    SysTick function  ############################################ */
@@ -1814,7 +2047,7 @@ __STATIC_INLINE void NVIC_SystemReset(void)
-#if (__Vendor_SysTickConfig == 0U)
+#if defined (__Vendor_SysTickConfig) && (__Vendor_SysTickConfig == 0U)
   \brief   System Tick Configuration
@@ -1857,8 +2090,8 @@ __STATIC_INLINE uint32_t SysTick_Config(uint32_t ticks)
-extern volatile int32_t ITM_RxBuffer;                    /*!< External variable to receive characters. */
-#define                 ITM_RXBUFFER_EMPTY   0x5AA55AA5U /*!< Value identifying \ref ITM_RxBuffer is ready for next character. */
+extern volatile int32_t ITM_RxBuffer;                              /*!< External variable to receive characters. */
+#define                 ITM_RXBUFFER_EMPTY  ((int32_t)0x5AA55AA5U) /*!< Value identifying \ref ITM_RxBuffer is ready for next character. */
diff --git a/bsps/arm/include/core_cm7.h b/bsps/arm/include/core_cm7.h
index 3ffef85495..7ba4daa2ab 100644
--- a/bsps/arm/include/core_cm7.h
+++ b/bsps/arm/include/core_cm7.h
@@ -1,2515 +1,2407 @@
- * @file
- * @brief    CMSIS Cortex-M7 Core Peripheral Access Layer Header File
- * @version  V4.30
-#if   defined ( __ICCARM__ )
-  #pragma clang system_header   /* treat file as system include file */
-#endif
-#ifndef __CORE_CM7_H_GENERIC
-#define __CORE_CM7_H_GENERIC
-#include <stdint.h>
-#ifdef __cplusplus
- extern "C" {
-#endif
-  \page CMSIS_MISRA_Exceptions  MISRA-C:2004 Compliance Exceptions
-  CMSIS violates the following MISRA-C:2004 rules:
-   \li Required Rule 8.5, object/function definition in header file.<br>
-     Function definitions in header files are used to allow 'inlining'.
-   \li Required Rule 18.4, declaration of union type or object of union type: '{...}'.<br>
-     Unions are used for effective representation of core registers.
-   \li Advisory Rule 19.7, Function-like macro defined.<br>
-     Function-like macros are used to allow more efficient code.
- *                 CMSIS definitions
-  \ingroup Cortex_M7
-/*  CMSIS CM7 definitions */
-#define __CM7_CMSIS_VERSION_MAIN  (0x04U)                                      /*!< [31:16] CMSIS HAL main version */
-#define __CM7_CMSIS_VERSION_SUB   (0x1EU)                                      /*!< [15:0]  CMSIS HAL sub version */
-#define __CM7_CMSIS_VERSION       ((__CM7_CMSIS_VERSION_MAIN << 16U) | \
-                                    __CM7_CMSIS_VERSION_SUB           )        /*!< CMSIS HAL version number */
-#define __CORTEX_M                (0x07U)                                      /*!< Cortex-M Core */
-  #define __packed
-#else
-#endif
-/** __FPU_USED indicates whether an FPU is used or not.
-    For this, __FPU_PRESENT has to be checked prior to making use of FPU specific registers and functions.
-  #if defined __TARGET_FPU_VFP
-      #define __FPU_USED       1U
-    #else
-      #error "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)"
-      #define __FPU_USED       0U
-    #endif
-  #else
-  #endif
-    #else
-      #warning "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)"
-    #endif
-  #else
-  #endif
-  #if defined (__VFP_FP__) && !defined(__SOFTFP__)
-    #else
-    #endif
-  #else
-  #endif
-  #if defined __ARMVFP__
-    #else
-    #endif
-  #else
-  #endif
-  #if defined __TI_VFP_SUPPORT__
-    #else
-    #endif
-  #else
-  #endif
-  #if defined __FPU_VFP__
-    #else
-    #endif
-  #else
-  #endif
-  #if ( __CSMC__ & 0x400U)
-    #else
-    #endif
-  #else
-  #endif
-#endif
-#ifdef __cplusplus
-#endif
-#endif /* __CORE_CM7_H_GENERIC */
-#ifndef __CMSIS_GENERIC
-#ifndef __CORE_CM7_H_DEPENDANT
-#define __CORE_CM7_H_DEPENDANT
-#ifdef __cplusplus
- extern "C" {
-#endif
-/* check device defines and use defaults */
-#if defined __CHECK_DEVICE_DEFINES
-  #ifndef __CM7_REV
-    #define __CM7_REV               0x0000U
-    #warning "__CM7_REV not defined in device header file; using default!"
-  #endif
-  #ifndef __FPU_PRESENT
-    #define __FPU_PRESENT             0U
-    #warning "__FPU_PRESENT not defined in device header file; using default!"
-  #endif
-  #ifndef __MPU_PRESENT
-    #define __MPU_PRESENT             0U
-    #warning "__MPU_PRESENT not defined in device header file; using default!"
-  #endif
-  #ifndef __ICACHE_PRESENT
-    #define __ICACHE_PRESENT          0U
-    #warning "__ICACHE_PRESENT not defined in device header file; using default!"
-  #endif
-  #ifndef __DCACHE_PRESENT
-    #define __DCACHE_PRESENT          0U
-    #warning "__DCACHE_PRESENT not defined in device header file; using default!"
-  #endif
-  #ifndef __DTCM_PRESENT
-    #define __DTCM_PRESENT            0U
-    #warning "__DTCM_PRESENT        not defined in device header file; using default!"
-  #endif
-  #ifndef __NVIC_PRIO_BITS
-    #define __NVIC_PRIO_BITS          3U
-    #warning "__NVIC_PRIO_BITS not defined in device header file; using default!"
-  #endif
-  #ifndef __Vendor_SysTickConfig
-    #define __Vendor_SysTickConfig    0U
-    #warning "__Vendor_SysTickConfig not defined in device header file; using default!"
-  #endif
-#endif
-/* IO definitions (access restrictions to peripheral registers) */
-    \defgroup CMSIS_glob_defs CMSIS Global Defines
-    \ingroup CMSIS
-    <strong>IO Type Qualifiers</strong> are used
-    \li to specify the access to peripheral variables.
-    \li for automatic generation of peripheral register debug information.
-#ifdef __cplusplus
-  #define   __I     volatile             /*!< Defines 'read only' permissions */
-#else
-  #define   __I     volatile const       /*!< Defines 'read only' permissions */
-#endif
-#define     __O     volatile             /*!< Defines 'write only' permissions */
-#define     __IO    volatile             /*!< Defines 'read / write' permissions */
-/* following defines should be used for structure members */
-#define     __IM     volatile const      /*! Defines 'read only' structure member permissions */
-#define     __OM     volatile            /*! Defines 'write only' structure member permissions */
-#define     __IOM    volatile            /*! Defines 'read / write' structure member permissions */
-/*@} end of group Cortex_M7 */
- *                 Register Abstraction
-  Core Register contain:
-  - Core Register
-  - Core NVIC Register
-  - Core SCB Register
-  - Core SysTick Register
-  - Core Debug Register
-  - Core MPU Register
-  - Core FPU Register
-  \defgroup CMSIS_core_register Defines and Type Definitions
-  \ingroup CMSIS
-  \brief Type definitions and defines for Cortex-M processor based devices.
-  \ingroup    CMSIS_core_register
-  \defgroup   CMSIS_CORE  Status and Control Registers
-  \brief      Core Register type definitions.
-  \brief  Union type to access the Application Program Status Register (APSR).
-typedef union
-  struct
-    uint32_t _reserved0:16;              /*!< bit:  0..15  Reserved */
-    uint32_t GE:4;                       /*!< bit: 16..19  Greater than or Equal flags */
-    uint32_t _reserved1:7;               /*!< bit: 20..26  Reserved */
-    uint32_t Q:1;                        /*!< bit:     27  Saturation condition flag */
-    uint32_t V:1;                        /*!< bit:     28  Overflow condition code flag */
-    uint32_t C:1;                        /*!< bit:     29  Carry condition code flag */
-    uint32_t Z:1;                        /*!< bit:     30  Zero condition code flag */
-    uint32_t N:1;                        /*!< bit:     31  Negative condition code flag */
-  } b;                                   /*!< Structure used for bit  access */
-  uint32_t w;                            /*!< Type      used for word access */
-} APSR_Type;
-/* APSR Register Definitions */
-#define APSR_N_Pos                         31U                                            /*!< APSR: N Position */
-#define APSR_N_Msk                         (1UL << APSR_N_Pos)                            /*!< APSR: N Mask */
-#define APSR_Z_Pos                         30U                                            /*!< APSR: Z Position */
-#define APSR_Z_Msk                         (1UL << APSR_Z_Pos)                            /*!< APSR: Z Mask */
-#define APSR_C_Pos                         29U                                            /*!< APSR: C Position */
-#define APSR_C_Msk                         (1UL << APSR_C_Pos)                            /*!< APSR: C Mask */
-#define APSR_V_Pos                         28U                                            /*!< APSR: V Position */
-#define APSR_V_Msk                         (1UL << APSR_V_Pos)                            /*!< APSR: V Mask */
-#define APSR_Q_Pos                         27U                                            /*!< APSR: Q Position */
-#define APSR_Q_Msk                         (1UL << APSR_Q_Pos)                            /*!< APSR: Q Mask */
-#define APSR_GE_Pos                        16U                                            /*!< APSR: GE Position */
-#define APSR_GE_Msk                        (0xFUL << APSR_GE_Pos)                         /*!< APSR: GE Mask */
-  \brief  Union type to access the Interrupt Program Status Register (IPSR).
-typedef union
-  struct
-    uint32_t ISR:9;                      /*!< bit:  0.. 8  Exception number */
-    uint32_t _reserved0:23;              /*!< bit:  9..31  Reserved */
-} IPSR_Type;
-/* IPSR Register Definitions */
-#define IPSR_ISR_Pos                        0U                                            /*!< IPSR: ISR Position */
-#define IPSR_ISR_Msk                       (0x1FFUL /*<< IPSR_ISR_Pos*/)                  /*!< IPSR: ISR Mask */
-  \brief  Union type to access the Special-Purpose Program Status Registers (xPSR).
-typedef union
-  struct
-    uint32_t _reserved1:4;               /*!< bit: 20..23  Reserved */
-} xPSR_Type;
-/* xPSR Register Definitions */
-#define xPSR_N_Pos                         31U                                            /*!< xPSR: N Position */
-#define xPSR_N_Msk                         (1UL << xPSR_N_Pos)                            /*!< xPSR: N Mask */
-#define xPSR_Z_Pos                         30U                                            /*!< xPSR: Z Position */
-#define xPSR_Z_Msk                         (1UL << xPSR_Z_Pos)                            /*!< xPSR: Z Mask */
-#define xPSR_C_Pos                         29U                                            /*!< xPSR: C Position */
-#define xPSR_C_Msk                         (1UL << xPSR_C_Pos)                            /*!< xPSR: C Mask */
-#define xPSR_V_Pos                         28U                                            /*!< xPSR: V Position */
-#define xPSR_V_Msk                         (1UL << xPSR_V_Pos)                            /*!< xPSR: V Mask */
-#define xPSR_Q_Pos                         27U                                            /*!< xPSR: Q Position */
-#define xPSR_Q_Msk                         (1UL << xPSR_Q_Pos)                            /*!< xPSR: Q Mask */
-#define xPSR_T_Pos                         24U                                            /*!< xPSR: T Position */
-#define xPSR_T_Msk                         (1UL << xPSR_T_Pos)                            /*!< xPSR: T Mask */
-#define xPSR_GE_Pos                        16U                                            /*!< xPSR: GE Position */
-#define xPSR_GE_Msk                        (0xFUL << xPSR_GE_Pos)                         /*!< xPSR: GE Mask */
-#define xPSR_ISR_Pos                        0U                                            /*!< xPSR: ISR Position */
-#define xPSR_ISR_Msk                       (0x1FFUL /*<< xPSR_ISR_Pos*/)                  /*!< xPSR: ISR Mask */
-  \brief  Union type to access the Control Registers (CONTROL).
-typedef union
-  struct
-    uint32_t nPRIV:1;                    /*!< bit:      0  Execution privilege in Thread mode */
-    uint32_t SPSEL:1;                    /*!< bit:      1  Stack to be used */
-    uint32_t FPCA:1;                     /*!< bit:      2  FP extension active flag */
-    uint32_t _reserved0:29;              /*!< bit:  3..31  Reserved */
-} CONTROL_Type;
-/* CONTROL Register Definitions */
-#define CONTROL_FPCA_Pos                    2U                                            /*!< CONTROL: FPCA Position */
-#define CONTROL_FPCA_Msk                   (1UL << CONTROL_FPCA_Pos)                      /*!< CONTROL: FPCA Mask */
-#define CONTROL_SPSEL_Pos                   1U                                            /*!< CONTROL: SPSEL Position */
-#define CONTROL_SPSEL_Msk                  (1UL << CONTROL_SPSEL_Pos)                     /*!< CONTROL: SPSEL Mask */
-#define CONTROL_nPRIV_Pos                   0U                                            /*!< CONTROL: nPRIV Position */
-#define CONTROL_nPRIV_Msk                  (1UL /*<< CONTROL_nPRIV_Pos*/)                 /*!< CONTROL: nPRIV Mask */
-/*@} end of group CMSIS_CORE */
-  \defgroup   CMSIS_NVIC  Nested Vectored Interrupt Controller (NVIC)
-  \brief      Type definitions for the NVIC Registers
-  \brief  Structure type to access the Nested Vectored Interrupt Controller (NVIC).
-typedef struct
-  __IOM uint32_t ISER[8U];               /*!< Offset: 0x000 (R/W)  Interrupt Set Enable Register */
-        uint32_t RESERVED0[24U];
-  __IOM uint32_t ICER[8U];               /*!< Offset: 0x080 (R/W)  Interrupt Clear Enable Register */
-  __IOM uint32_t ISPR[8U];               /*!< Offset: 0x100 (R/W)  Interrupt Set Pending Register */
-        uint32_t RESERVED2[24U];
-  __IOM uint32_t ICPR[8U];               /*!< Offset: 0x180 (R/W)  Interrupt Clear Pending Register */
-        uint32_t RESERVED3[24U];
-  __IOM uint32_t IABR[8U];               /*!< Offset: 0x200 (R/W)  Interrupt Active bit Register */
-        uint32_t RESERVED4[56U];
-  __IOM uint8_t  IP[240U];               /*!< Offset: 0x300 (R/W)  Interrupt Priority Register (8Bit wide) */
-        uint32_t RESERVED5[644U];
-  __OM  uint32_t STIR;                   /*!< Offset: 0xE00 ( /W)  Software Trigger Interrupt Register */
-}  NVIC_Type;
-/* Software Triggered Interrupt Register Definitions */
-#define NVIC_STIR_INTID_Pos                 0U                                         /*!< STIR: INTLINESNUM Position */
-#define NVIC_STIR_INTID_Msk                (0x1FFUL /*<< NVIC_STIR_INTID_Pos*/)        /*!< STIR: INTLINESNUM Mask */
-/*@} end of group CMSIS_NVIC */
-  \defgroup CMSIS_SCB     System Control Block (SCB)
-  \brief    Type definitions for the System Control Block Registers
-  \brief  Structure type to access the System Control Block (SCB).
-typedef struct
-  __IM  uint32_t CPUID;                  /*!< Offset: 0x000 (R/ )  CPUID Base Register */
-  __IOM uint32_t ICSR;                   /*!< Offset: 0x004 (R/W)  Interrupt Control and State Register */
-  __IOM uint32_t VTOR;                   /*!< Offset: 0x008 (R/W)  Vector Table Offset Register */
-  __IOM uint32_t AIRCR;                  /*!< Offset: 0x00C (R/W)  Application Interrupt and Reset Control Register */
-  __IOM uint32_t SCR;                    /*!< Offset: 0x010 (R/W)  System Control Register */
-  __IOM uint32_t CCR;                    /*!< Offset: 0x014 (R/W)  Configuration Control Register */
-  __IOM uint8_t  SHPR[12U];              /*!< Offset: 0x018 (R/W)  System Handlers Priority Registers (4-7, 8-11, 12-15) */
-  __IOM uint32_t SHCSR;                  /*!< Offset: 0x024 (R/W)  System Handler Control and State Register */
-  __IOM uint32_t CFSR;                   /*!< Offset: 0x028 (R/W)  Configurable Fault Status Register */
-  __IOM uint32_t HFSR;                   /*!< Offset: 0x02C (R/W)  HardFault Status Register */
-  __IOM uint32_t DFSR;                   /*!< Offset: 0x030 (R/W)  Debug Fault Status Register */
-  __IOM uint32_t MMFAR;                  /*!< Offset: 0x034 (R/W)  MemManage Fault Address Register */
-  __IOM uint32_t BFAR;                   /*!< Offset: 0x038 (R/W)  BusFault Address Register */
-  __IOM uint32_t AFSR;                   /*!< Offset: 0x03C (R/W)  Auxiliary Fault Status Register */
-  __IM  uint32_t ID_PFR[2U];             /*!< Offset: 0x040 (R/ )  Processor Feature Register */
-  __IM  uint32_t ID_DFR;                 /*!< Offset: 0x048 (R/ )  Debug Feature Register */
-  __IM  uint32_t ID_AFR;                 /*!< Offset: 0x04C (R/ )  Auxiliary Feature Register */
-  __IM  uint32_t ID_MFR[4U];             /*!< Offset: 0x050 (R/ )  Memory Model Feature Register */
-  __IM  uint32_t ID_ISAR[5U];            /*!< Offset: 0x060 (R/ )  Instruction Set Attributes Register */
-        uint32_t RESERVED0[1U];
-  __IM  uint32_t CLIDR;                  /*!< Offset: 0x078 (R/ )  Cache Level ID register */
-  __IM  uint32_t CTR;                    /*!< Offset: 0x07C (R/ )  Cache Type register */
-  __IM  uint32_t CCSIDR;                 /*!< Offset: 0x080 (R/ )  Cache Size ID Register */
-  __IOM uint32_t CSSELR;                 /*!< Offset: 0x084 (R/W)  Cache Size Selection Register */
-  __IOM uint32_t CPACR;                  /*!< Offset: 0x088 (R/W)  Coprocessor Access Control Register */
-        uint32_t RESERVED3[93U];
-  __OM  uint32_t STIR;                   /*!< Offset: 0x200 ( /W)  Software Triggered Interrupt Register */
-        uint32_t RESERVED4[15U];
-  __IM  uint32_t MVFR0;                  /*!< Offset: 0x240 (R/ )  Media and VFP Feature Register 0 */
-  __IM  uint32_t MVFR1;                  /*!< Offset: 0x244 (R/ )  Media and VFP Feature Register 1 */
-  __IM  uint32_t MVFR2;                  /*!< Offset: 0x248 (R/ )  Media and VFP Feature Register 1 */
-        uint32_t RESERVED5[1U];
-  __OM  uint32_t ICIALLU;                /*!< Offset: 0x250 ( /W)  I-Cache Invalidate All to PoU */
-        uint32_t RESERVED6[1U];
-  __OM  uint32_t ICIMVAU;                /*!< Offset: 0x258 ( /W)  I-Cache Invalidate by MVA to PoU */
-  __OM  uint32_t DCIMVAC;                /*!< Offset: 0x25C ( /W)  D-Cache Invalidate by MVA to PoC */
-  __OM  uint32_t DCISW;                  /*!< Offset: 0x260 ( /W)  D-Cache Invalidate by Set-way */
-  __OM  uint32_t DCCMVAU;                /*!< Offset: 0x264 ( /W)  D-Cache Clean by MVA to PoU */
-  __OM  uint32_t DCCMVAC;                /*!< Offset: 0x268 ( /W)  D-Cache Clean by MVA to PoC */
-  __OM  uint32_t DCCSW;                  /*!< Offset: 0x26C ( /W)  D-Cache Clean by Set-way */
-  __OM  uint32_t DCCIMVAC;               /*!< Offset: 0x270 ( /W)  D-Cache Clean and Invalidate by MVA to PoC */
-  __OM  uint32_t DCCISW;                 /*!< Offset: 0x274 ( /W)  D-Cache Clean and Invalidate by Set-way */
-        uint32_t RESERVED7[6U];
-  __IOM uint32_t ITCMCR;                 /*!< Offset: 0x290 (R/W)  Instruction Tightly-Coupled Memory Control Register */
-  __IOM uint32_t DTCMCR;                 /*!< Offset: 0x294 (R/W)  Data Tightly-Coupled Memory Control Registers */
-  __IOM uint32_t AHBPCR;                 /*!< Offset: 0x298 (R/W)  AHBP Control Register */
-  __IOM uint32_t CACR;                   /*!< Offset: 0x29C (R/W)  L1 Cache Control Register */
-  __IOM uint32_t AHBSCR;                 /*!< Offset: 0x2A0 (R/W)  AHB Slave Control Register */
-        uint32_t RESERVED8[1U];
-  __IOM uint32_t ABFSR;                  /*!< Offset: 0x2A8 (R/W)  Auxiliary Bus Fault Status Register */
-} SCB_Type;
-/* SCB CPUID Register Definitions */
-#define SCB_CPUID_IMPLEMENTER_Pos          24U                                            /*!< SCB CPUID: IMPLEMENTER Position */
-#define SCB_CPUID_IMPLEMENTER_Msk          (0xFFUL << SCB_CPUID_IMPLEMENTER_Pos)          /*!< SCB CPUID: IMPLEMENTER Mask */
-#define SCB_CPUID_VARIANT_Pos              20U                                            /*!< SCB CPUID: VARIANT Position */
-#define SCB_CPUID_VARIANT_Msk              (0xFUL << SCB_CPUID_VARIANT_Pos)               /*!< SCB CPUID: VARIANT Mask */
-#define SCB_CPUID_ARCHITECTURE_Pos         16U                                            /*!< SCB CPUID: ARCHITECTURE Position */
-#define SCB_CPUID_ARCHITECTURE_Msk         (0xFUL << SCB_CPUID_ARCHITECTURE_Pos)          /*!< SCB CPUID: ARCHITECTURE Mask */
-#define SCB_CPUID_PARTNO_Pos                4U                                            /*!< SCB CPUID: PARTNO Position */
-#define SCB_CPUID_PARTNO_Msk               (0xFFFUL << SCB_CPUID_PARTNO_Pos)              /*!< SCB CPUID: PARTNO Mask */
-#define SCB_CPUID_REVISION_Pos              0U                                            /*!< SCB CPUID: REVISION Position */
-#define SCB_CPUID_REVISION_Msk             (0xFUL /*<< SCB_CPUID_REVISION_Pos*/)          /*!< SCB CPUID: REVISION Mask */
-/* SCB Interrupt Control State Register Definitions */
-#define SCB_ICSR_NMIPENDSET_Pos            31U                                            /*!< SCB ICSR: NMIPENDSET Position */
-#define SCB_ICSR_NMIPENDSET_Msk            (1UL << SCB_ICSR_NMIPENDSET_Pos)               /*!< SCB ICSR: NMIPENDSET Mask */
-#define SCB_ICSR_PENDSVSET_Pos             28U                                            /*!< SCB ICSR: PENDSVSET Position */
-#define SCB_ICSR_PENDSVSET_Msk             (1UL << SCB_ICSR_PENDSVSET_Pos)                /*!< SCB ICSR: PENDSVSET Mask */
-#define SCB_ICSR_PENDSVCLR_Pos             27U                                            /*!< SCB ICSR: PENDSVCLR Position */
-#define SCB_ICSR_PENDSVCLR_Msk             (1UL << SCB_ICSR_PENDSVCLR_Pos)                /*!< SCB ICSR: PENDSVCLR Mask */
-#define SCB_ICSR_PENDSTSET_Pos             26U                                            /*!< SCB ICSR: PENDSTSET Position */
-#define SCB_ICSR_PENDSTSET_Msk             (1UL << SCB_ICSR_PENDSTSET_Pos)                /*!< SCB ICSR: PENDSTSET Mask */
-#define SCB_ICSR_PENDSTCLR_Pos             25U                                            /*!< SCB ICSR: PENDSTCLR Position */
-#define SCB_ICSR_PENDSTCLR_Msk             (1UL << SCB_ICSR_PENDSTCLR_Pos)                /*!< SCB ICSR: PENDSTCLR Mask */
-#define SCB_ICSR_ISRPREEMPT_Pos            23U                                            /*!< SCB ICSR: ISRPREEMPT Position */
-#define SCB_ICSR_ISRPREEMPT_Msk            (1UL << SCB_ICSR_ISRPREEMPT_Pos)               /*!< SCB ICSR: ISRPREEMPT Mask */
-#define SCB_ICSR_ISRPENDING_Pos            22U                                            /*!< SCB ICSR: ISRPENDING Position */
-#define SCB_ICSR_ISRPENDING_Msk            (1UL << SCB_ICSR_ISRPENDING_Pos)               /*!< SCB ICSR: ISRPENDING Mask */
-#define SCB_ICSR_VECTPENDING_Pos           12U                                            /*!< SCB ICSR: VECTPENDING Position */
-#define SCB_ICSR_VECTPENDING_Msk           (0x1FFUL << SCB_ICSR_VECTPENDING_Pos)          /*!< SCB ICSR: VECTPENDING Mask */
-#define SCB_ICSR_RETTOBASE_Pos             11U                                            /*!< SCB ICSR: RETTOBASE Position */
-#define SCB_ICSR_RETTOBASE_Msk             (1UL << SCB_ICSR_RETTOBASE_Pos)                /*!< SCB ICSR: RETTOBASE Mask */
-#define SCB_ICSR_VECTACTIVE_Pos             0U                                            /*!< SCB ICSR: VECTACTIVE Position */
-#define SCB_ICSR_VECTACTIVE_Msk            (0x1FFUL /*<< SCB_ICSR_VECTACTIVE_Pos*/)       /*!< SCB ICSR: VECTACTIVE Mask */
-/* SCB Vector Table Offset Register Definitions */
-#define SCB_VTOR_TBLOFF_Pos                 7U                                            /*!< SCB VTOR: TBLOFF Position */
-#define SCB_VTOR_TBLOFF_Msk                (0x1FFFFFFUL << SCB_VTOR_TBLOFF_Pos)           /*!< SCB VTOR: TBLOFF Mask */
-/* SCB Application Interrupt and Reset Control Register Definitions */
-#define SCB_AIRCR_VECTKEY_Pos              16U                                            /*!< SCB AIRCR: VECTKEY Position */
-#define SCB_AIRCR_VECTKEY_Msk              (0xFFFFUL << SCB_AIRCR_VECTKEY_Pos)            /*!< SCB AIRCR: VECTKEY Mask */
-#define SCB_AIRCR_VECTKEYSTAT_Pos          16U                                            /*!< SCB AIRCR: VECTKEYSTAT Position */
-#define SCB_AIRCR_VECTKEYSTAT_Msk          (0xFFFFUL << SCB_AIRCR_VECTKEYSTAT_Pos)        /*!< SCB AIRCR: VECTKEYSTAT Mask */
-#define SCB_AIRCR_ENDIANESS_Pos            15U                                            /*!< SCB AIRCR: ENDIANESS Position */
-#define SCB_AIRCR_ENDIANESS_Msk            (1UL << SCB_AIRCR_ENDIANESS_Pos)               /*!< SCB AIRCR: ENDIANESS Mask */
-#define SCB_AIRCR_PRIGROUP_Pos              8U                                            /*!< SCB AIRCR: PRIGROUP Position */
-#define SCB_AIRCR_PRIGROUP_Msk             (7UL << SCB_AIRCR_PRIGROUP_Pos)                /*!< SCB AIRCR: PRIGROUP Mask */
-#define SCB_AIRCR_SYSRESETREQ_Pos           2U                                            /*!< SCB AIRCR: SYSRESETREQ Position */
-#define SCB_AIRCR_SYSRESETREQ_Msk          (1UL << SCB_AIRCR_SYSRESETREQ_Pos)             /*!< SCB AIRCR: SYSRESETREQ Mask */
-#define SCB_AIRCR_VECTCLRACTIVE_Pos         1U                                            /*!< SCB AIRCR: VECTCLRACTIVE Position */
-#define SCB_AIRCR_VECTCLRACTIVE_Msk        (1UL << SCB_AIRCR_VECTCLRACTIVE_Pos)           /*!< SCB AIRCR: VECTCLRACTIVE Mask */
-#define SCB_AIRCR_VECTRESET_Pos             0U                                            /*!< SCB AIRCR: VECTRESET Position */
-#define SCB_AIRCR_VECTRESET_Msk            (1UL /*<< SCB_AIRCR_VECTRESET_Pos*/)           /*!< SCB AIRCR: VECTRESET Mask */
-/* SCB System Control Register Definitions */
-#define SCB_SCR_SEVONPEND_Pos               4U                                            /*!< SCB SCR: SEVONPEND Position */
-#define SCB_SCR_SEVONPEND_Msk              (1UL << SCB_SCR_SEVONPEND_Pos)                 /*!< SCB SCR: SEVONPEND Mask */
-#define SCB_SCR_SLEEPDEEP_Pos               2U                                            /*!< SCB SCR: SLEEPDEEP Position */
-#define SCB_SCR_SLEEPDEEP_Msk              (1UL << SCB_SCR_SLEEPDEEP_Pos)                 /*!< SCB SCR: SLEEPDEEP Mask */
-#define SCB_SCR_SLEEPONEXIT_Pos             1U                                            /*!< SCB SCR: SLEEPONEXIT Position */
-#define SCB_SCR_SLEEPONEXIT_Msk            (1UL << SCB_SCR_SLEEPONEXIT_Pos)               /*!< SCB SCR: SLEEPONEXIT Mask */
-/* SCB Configuration Control Register Definitions */
-#define SCB_CCR_BP_Pos                      18U                                           /*!< SCB CCR: Branch prediction enable bit Position */
-#define SCB_CCR_BP_Msk                     (1UL << SCB_CCR_BP_Pos)                        /*!< SCB CCR: Branch prediction enable bit Mask */
-#define SCB_CCR_IC_Pos                      17U                                           /*!< SCB CCR: Instruction cache enable bit Position */
-#define SCB_CCR_IC_Msk                     (1UL << SCB_CCR_IC_Pos)                        /*!< SCB CCR: Instruction cache enable bit Mask */
-#define SCB_CCR_DC_Pos                      16U                                           /*!< SCB CCR: Cache enable bit Position */
-#define SCB_CCR_DC_Msk                     (1UL << SCB_CCR_DC_Pos)                        /*!< SCB CCR: Cache enable bit Mask */
-#define SCB_CCR_STKALIGN_Pos                9U                                            /*!< SCB CCR: STKALIGN Position */
-#define SCB_CCR_STKALIGN_Msk               (1UL << SCB_CCR_STKALIGN_Pos)                  /*!< SCB CCR: STKALIGN Mask */
-#define SCB_CCR_BFHFNMIGN_Pos               8U                                            /*!< SCB CCR: BFHFNMIGN Position */
-#define SCB_CCR_BFHFNMIGN_Msk              (1UL << SCB_CCR_BFHFNMIGN_Pos)                 /*!< SCB CCR: BFHFNMIGN Mask */
-#define SCB_CCR_DIV_0_TRP_Pos               4U                                            /*!< SCB CCR: DIV_0_TRP Position */
-#define SCB_CCR_DIV_0_TRP_Msk              (1UL << SCB_CCR_DIV_0_TRP_Pos)                 /*!< SCB CCR: DIV_0_TRP Mask */
-#define SCB_CCR_UNALIGN_TRP_Pos             3U                                            /*!< SCB CCR: UNALIGN_TRP Position */
-#define SCB_CCR_UNALIGN_TRP_Msk            (1UL << SCB_CCR_UNALIGN_TRP_Pos)               /*!< SCB CCR: UNALIGN_TRP Mask */
-#define SCB_CCR_USERSETMPEND_Pos            1U                                            /*!< SCB CCR: USERSETMPEND Position */
-#define SCB_CCR_USERSETMPEND_Msk           (1UL << SCB_CCR_USERSETMPEND_Pos)              /*!< SCB CCR: USERSETMPEND Mask */
-#define SCB_CCR_NONBASETHRDENA_Pos          0U                                            /*!< SCB CCR: NONBASETHRDENA Position */
-#define SCB_CCR_NONBASETHRDENA_Msk         (1UL /*<< SCB_CCR_NONBASETHRDENA_Pos*/)        /*!< SCB CCR: NONBASETHRDENA Mask */
-/* SCB System Handler Control and State Register Definitions */
-#define SCB_SHCSR_USGFAULTENA_Pos          18U                                            /*!< SCB SHCSR: USGFAULTENA Position */
-#define SCB_SHCSR_USGFAULTENA_Msk          (1UL << SCB_SHCSR_USGFAULTENA_Pos)             /*!< SCB SHCSR: USGFAULTENA Mask */
-#define SCB_SHCSR_BUSFAULTENA_Pos          17U                                            /*!< SCB SHCSR: BUSFAULTENA Position */
-#define SCB_SHCSR_BUSFAULTENA_Msk          (1UL << SCB_SHCSR_BUSFAULTENA_Pos)             /*!< SCB SHCSR: BUSFAULTENA Mask */
-#define SCB_SHCSR_MEMFAULTENA_Pos          16U                                            /*!< SCB SHCSR: MEMFAULTENA Position */
-#define SCB_SHCSR_MEMFAULTENA_Msk          (1UL << SCB_SHCSR_MEMFAULTENA_Pos)             /*!< SCB SHCSR: MEMFAULTENA Mask */
-#define SCB_SHCSR_SVCALLPENDED_Pos         15U                                            /*!< SCB SHCSR: SVCALLPENDED Position */
-#define SCB_SHCSR_SVCALLPENDED_Msk         (1UL << SCB_SHCSR_SVCALLPENDED_Pos)            /*!< SCB SHCSR: SVCALLPENDED Mask */
-#define SCB_SHCSR_BUSFAULTPENDED_Pos       14U                                            /*!< SCB SHCSR: BUSFAULTPENDED Position */
-#define SCB_SHCSR_BUSFAULTPENDED_Msk       (1UL << SCB_SHCSR_BUSFAULTPENDED_Pos)          /*!< SCB SHCSR: BUSFAULTPENDED Mask */
-#define SCB_SHCSR_MEMFAULTPENDED_Pos       13U                                            /*!< SCB SHCSR: MEMFAULTPENDED Position */
-#define SCB_SHCSR_MEMFAULTPENDED_Msk       (1UL << SCB_SHCSR_MEMFAULTPENDED_Pos)          /*!< SCB SHCSR: MEMFAULTPENDED Mask */
-#define SCB_SHCSR_USGFAULTPENDED_Pos       12U                                            /*!< SCB SHCSR: USGFAULTPENDED Position */
-#define SCB_SHCSR_USGFAULTPENDED_Msk       (1UL << SCB_SHCSR_USGFAULTPENDED_Pos)          /*!< SCB SHCSR: USGFAULTPENDED Mask */
-#define SCB_SHCSR_SYSTICKACT_Pos           11U                                            /*!< SCB SHCSR: SYSTICKACT Position */
-#define SCB_SHCSR_SYSTICKACT_Msk           (1UL << SCB_SHCSR_SYSTICKACT_Pos)              /*!< SCB SHCSR: SYSTICKACT Mask */
-#define SCB_SHCSR_PENDSVACT_Pos            10U                                            /*!< SCB SHCSR: PENDSVACT Position */
-#define SCB_SHCSR_PENDSVACT_Msk            (1UL << SCB_SHCSR_PENDSVACT_Pos)               /*!< SCB SHCSR: PENDSVACT Mask */
-#define SCB_SHCSR_MONITORACT_Pos            8U                                            /*!< SCB SHCSR: MONITORACT Position */
-#define SCB_SHCSR_MONITORACT_Msk           (1UL << SCB_SHCSR_MONITORACT_Pos)              /*!< SCB SHCSR: MONITORACT Mask */
-#define SCB_SHCSR_SVCALLACT_Pos             7U                                            /*!< SCB SHCSR: SVCALLACT Position */
-#define SCB_SHCSR_SVCALLACT_Msk            (1UL << SCB_SHCSR_SVCALLACT_Pos)               /*!< SCB SHCSR: SVCALLACT Mask */
-#define SCB_SHCSR_USGFAULTACT_Pos           3U                                            /*!< SCB SHCSR: USGFAULTACT Position */
-#define SCB_SHCSR_USGFAULTACT_Msk          (1UL << SCB_SHCSR_USGFAULTACT_Pos)             /*!< SCB SHCSR: USGFAULTACT Mask */
-#define SCB_SHCSR_BUSFAULTACT_Pos           1U                                            /*!< SCB SHCSR: BUSFAULTACT Position */
-#define SCB_SHCSR_BUSFAULTACT_Msk          (1UL << SCB_SHCSR_BUSFAULTACT_Pos)             /*!< SCB SHCSR: BUSFAULTACT Mask */
-#define SCB_SHCSR_MEMFAULTACT_Pos           0U                                            /*!< SCB SHCSR: MEMFAULTACT Position */
-#define SCB_SHCSR_MEMFAULTACT_Msk          (1UL /*<< SCB_SHCSR_MEMFAULTACT_Pos*/)         /*!< SCB SHCSR: MEMFAULTACT Mask */
-/* SCB Configurable Fault Status Register Definitions */
-#define SCB_CFSR_USGFAULTSR_Pos            16U                                            /*!< SCB CFSR: Usage Fault Status Register Position */
-#define SCB_CFSR_USGFAULTSR_Msk            (0xFFFFUL << SCB_CFSR_USGFAULTSR_Pos)          /*!< SCB CFSR: Usage Fault Status Register Mask */
-#define SCB_CFSR_BUSFAULTSR_Pos             8U                                            /*!< SCB CFSR: Bus Fault Status Register Position */
-#define SCB_CFSR_BUSFAULTSR_Msk            (0xFFUL << SCB_CFSR_BUSFAULTSR_Pos)            /*!< SCB CFSR: Bus Fault Status Register Mask */
-#define SCB_CFSR_MEMFAULTSR_Pos             0U                                            /*!< SCB CFSR: Memory Manage Fault Status Register Position */
-#define SCB_CFSR_MEMFAULTSR_Msk            (0xFFUL /*<< SCB_CFSR_MEMFAULTSR_Pos*/)        /*!< SCB CFSR: Memory Manage Fault Status Register Mask */
-/* SCB Hard Fault Status Register Definitions */
-#define SCB_HFSR_DEBUGEVT_Pos              31U                                            /*!< SCB HFSR: DEBUGEVT Position */
-#define SCB_HFSR_DEBUGEVT_Msk              (1UL << SCB_HFSR_DEBUGEVT_Pos)                 /*!< SCB HFSR: DEBUGEVT Mask */
-#define SCB_HFSR_FORCED_Pos                30U                                            /*!< SCB HFSR: FORCED Position */
-#define SCB_HFSR_FORCED_Msk                (1UL << SCB_HFSR_FORCED_Pos)                   /*!< SCB HFSR: FORCED Mask */
-#define SCB_HFSR_VECTTBL_Pos                1U                                            /*!< SCB HFSR: VECTTBL Position */
-#define SCB_HFSR_VECTTBL_Msk               (1UL << SCB_HFSR_VECTTBL_Pos)                  /*!< SCB HFSR: VECTTBL Mask */
-/* SCB Debug Fault Status Register Definitions */
-#define SCB_DFSR_EXTERNAL_Pos               4U                                            /*!< SCB DFSR: EXTERNAL Position */
-#define SCB_DFSR_EXTERNAL_Msk              (1UL << SCB_DFSR_EXTERNAL_Pos)                 /*!< SCB DFSR: EXTERNAL Mask */
-#define SCB_DFSR_VCATCH_Pos                 3U                                            /*!< SCB DFSR: VCATCH Position */
-#define SCB_DFSR_VCATCH_Msk                (1UL << SCB_DFSR_VCATCH_Pos)                   /*!< SCB DFSR: VCATCH Mask */
-#define SCB_DFSR_DWTTRAP_Pos                2U                                            /*!< SCB DFSR: DWTTRAP Position */
-#define SCB_DFSR_DWTTRAP_Msk               (1UL << SCB_DFSR_DWTTRAP_Pos)                  /*!< SCB DFSR: DWTTRAP Mask */
-#define SCB_DFSR_BKPT_Pos                   1U                                            /*!< SCB DFSR: BKPT Position */
-#define SCB_DFSR_BKPT_Msk                  (1UL << SCB_DFSR_BKPT_Pos)                     /*!< SCB DFSR: BKPT Mask */
-#define SCB_DFSR_HALTED_Pos                 0U                                            /*!< SCB DFSR: HALTED Position */
-#define SCB_DFSR_HALTED_Msk                (1UL /*<< SCB_DFSR_HALTED_Pos*/)               /*!< SCB DFSR: HALTED Mask */
-/* SCB Cache Level ID Register Definitions */
-#define SCB_CLIDR_LOUU_Pos                 27U                                            /*!< SCB CLIDR: LoUU Position */
-#define SCB_CLIDR_LOUU_Msk                 (7UL << SCB_CLIDR_LOUU_Pos)                    /*!< SCB CLIDR: LoUU Mask */
-#define SCB_CLIDR_LOC_Pos                  24U                                            /*!< SCB CLIDR: LoC Position */
-#define SCB_CLIDR_LOC_Msk                  (7UL << SCB_CLIDR_LOC_Pos)                     /*!< SCB CLIDR: LoC Mask */
-/* SCB Cache Type Register Definitions */
-#define SCB_CTR_FORMAT_Pos                 29U                                            /*!< SCB CTR: Format Position */
-#define SCB_CTR_FORMAT_Msk                 (7UL << SCB_CTR_FORMAT_Pos)                    /*!< SCB CTR: Format Mask */
-#define SCB_CTR_CWG_Pos                    24U                                            /*!< SCB CTR: CWG Position */
-#define SCB_CTR_CWG_Msk                    (0xFUL << SCB_CTR_CWG_Pos)                     /*!< SCB CTR: CWG Mask */
-#define SCB_CTR_ERG_Pos                    20U                                            /*!< SCB CTR: ERG Position */
-#define SCB_CTR_ERG_Msk                    (0xFUL << SCB_CTR_ERG_Pos)                     /*!< SCB CTR: ERG Mask */
-#define SCB_CTR_DMINLINE_Pos               16U                                            /*!< SCB CTR: DminLine Position */
-#define SCB_CTR_DMINLINE_Msk               (0xFUL << SCB_CTR_DMINLINE_Pos)                /*!< SCB CTR: DminLine Mask */
-#define SCB_CTR_IMINLINE_Pos                0U                                            /*!< SCB CTR: ImInLine Position */
-#define SCB_CTR_IMINLINE_Msk               (0xFUL /*<< SCB_CTR_IMINLINE_Pos*/)            /*!< SCB CTR: ImInLine Mask */
-/* SCB Cache Size ID Register Definitions */
-#define SCB_CCSIDR_WT_Pos                  31U                                            /*!< SCB CCSIDR: WT Position */
-#define SCB_CCSIDR_WT_Msk                  (1UL << SCB_CCSIDR_WT_Pos)                     /*!< SCB CCSIDR: WT Mask */
-#define SCB_CCSIDR_WB_Pos                  30U                                            /*!< SCB CCSIDR: WB Position */
-#define SCB_CCSIDR_WB_Msk                  (1UL << SCB_CCSIDR_WB_Pos)                     /*!< SCB CCSIDR: WB Mask */
-#define SCB_CCSIDR_RA_Pos                  29U                                            /*!< SCB CCSIDR: RA Position */
-#define SCB_CCSIDR_RA_Msk                  (1UL << SCB_CCSIDR_RA_Pos)                     /*!< SCB CCSIDR: RA Mask */
-#define SCB_CCSIDR_WA_Pos                  28U                                            /*!< SCB CCSIDR: WA Position */
-#define SCB_CCSIDR_WA_Msk                  (1UL << SCB_CCSIDR_WA_Pos)                     /*!< SCB CCSIDR: WA Mask */
-#define SCB_CCSIDR_NUMSETS_Pos             13U                                            /*!< SCB CCSIDR: NumSets Position */
-#define SCB_CCSIDR_NUMSETS_Msk             (0x7FFFUL << SCB_CCSIDR_NUMSETS_Pos)           /*!< SCB CCSIDR: NumSets Mask */
-#define SCB_CCSIDR_ASSOCIATIVITY_Pos        3U                                            /*!< SCB CCSIDR: Associativity Position */
-#define SCB_CCSIDR_ASSOCIATIVITY_Msk       (0x3FFUL << SCB_CCSIDR_ASSOCIATIVITY_Pos)      /*!< SCB CCSIDR: Associativity Mask */
-#define SCB_CCSIDR_LINESIZE_Pos             0U                                            /*!< SCB CCSIDR: LineSize Position */
-#define SCB_CCSIDR_LINESIZE_Msk            (7UL /*<< SCB_CCSIDR_LINESIZE_Pos*/)           /*!< SCB CCSIDR: LineSize Mask */
-/* SCB Cache Size Selection Register Definitions */
-#define SCB_CSSELR_LEVEL_Pos                1U                                            /*!< SCB CSSELR: Level Position */
-#define SCB_CSSELR_LEVEL_Msk               (7UL << SCB_CSSELR_LEVEL_Pos)                  /*!< SCB CSSELR: Level Mask */
-#define SCB_CSSELR_IND_Pos                  0U                                            /*!< SCB CSSELR: InD Position */
-#define SCB_CSSELR_IND_Msk                 (1UL /*<< SCB_CSSELR_IND_Pos*/)                /*!< SCB CSSELR: InD Mask */
-/* SCB Software Triggered Interrupt Register Definitions */
-#define SCB_STIR_INTID_Pos                  0U                                            /*!< SCB STIR: INTID Position */
-#define SCB_STIR_INTID_Msk                 (0x1FFUL /*<< SCB_STIR_INTID_Pos*/)            /*!< SCB STIR: INTID Mask */
-/* SCB D-Cache Invalidate by Set-way Register Definitions */
-#define SCB_DCISW_WAY_Pos                  30U                                            /*!< SCB DCISW: Way Position */
-#define SCB_DCISW_WAY_Msk                  (3UL << SCB_DCISW_WAY_Pos)                     /*!< SCB DCISW: Way Mask */
-#define SCB_DCISW_SET_Pos                   5U                                            /*!< SCB DCISW: Set Position */
-#define SCB_DCISW_SET_Msk                  (0x1FFUL << SCB_DCISW_SET_Pos)                 /*!< SCB DCISW: Set Mask */
-/* SCB D-Cache Clean by Set-way Register Definitions */
-#define SCB_DCCSW_WAY_Pos                  30U                                            /*!< SCB DCCSW: Way Position */
-#define SCB_DCCSW_WAY_Msk                  (3UL << SCB_DCCSW_WAY_Pos)                     /*!< SCB DCCSW: Way Mask */
-#define SCB_DCCSW_SET_Pos                   5U                                            /*!< SCB DCCSW: Set Position */
-#define SCB_DCCSW_SET_Msk                  (0x1FFUL << SCB_DCCSW_SET_Pos)                 /*!< SCB DCCSW: Set Mask */
-/* SCB D-Cache Clean and Invalidate by Set-way Register Definitions */
-#define SCB_DCCISW_WAY_Pos                 30U                                            /*!< SCB DCCISW: Way Position */
-#define SCB_DCCISW_WAY_Msk                 (3UL << SCB_DCCISW_WAY_Pos)                    /*!< SCB DCCISW: Way Mask */
-#define SCB_DCCISW_SET_Pos                  5U                                            /*!< SCB DCCISW: Set Position */
-#define SCB_DCCISW_SET_Msk                 (0x1FFUL << SCB_DCCISW_SET_Pos)                /*!< SCB DCCISW: Set Mask */
-/* Instruction Tightly-Coupled Memory Control Register Definitions */
-#define SCB_ITCMCR_SZ_Pos                   3U                                            /*!< SCB ITCMCR: SZ Position */
-#define SCB_ITCMCR_SZ_Msk                  (0xFUL << SCB_ITCMCR_SZ_Pos)                   /*!< SCB ITCMCR: SZ Mask */
-#define SCB_ITCMCR_RETEN_Pos                2U                                            /*!< SCB ITCMCR: RETEN Position */
-#define SCB_ITCMCR_RETEN_Msk               (1UL << SCB_ITCMCR_RETEN_Pos)                  /*!< SCB ITCMCR: RETEN Mask */
-#define SCB_ITCMCR_RMW_Pos                  1U                                            /*!< SCB ITCMCR: RMW Position */
-#define SCB_ITCMCR_RMW_Msk                 (1UL << SCB_ITCMCR_RMW_Pos)                    /*!< SCB ITCMCR: RMW Mask */
-#define SCB_ITCMCR_EN_Pos                   0U                                            /*!< SCB ITCMCR: EN Position */
-#define SCB_ITCMCR_EN_Msk                  (1UL /*<< SCB_ITCMCR_EN_Pos*/)                 /*!< SCB ITCMCR: EN Mask */
-/* Data Tightly-Coupled Memory Control Register Definitions */
-#define SCB_DTCMCR_SZ_Pos                   3U                                            /*!< SCB DTCMCR: SZ Position */
-#define SCB_DTCMCR_SZ_Msk                  (0xFUL << SCB_DTCMCR_SZ_Pos)                   /*!< SCB DTCMCR: SZ Mask */
-#define SCB_DTCMCR_RETEN_Pos                2U                                            /*!< SCB DTCMCR: RETEN Position */
-#define SCB_DTCMCR_RETEN_Msk               (1UL << SCB_DTCMCR_RETEN_Pos)                   /*!< SCB DTCMCR: RETEN Mask */
-#define SCB_DTCMCR_RMW_Pos                  1U                                            /*!< SCB DTCMCR: RMW Position */
-#define SCB_DTCMCR_RMW_Msk                 (1UL << SCB_DTCMCR_RMW_Pos)                    /*!< SCB DTCMCR: RMW Mask */
-#define SCB_DTCMCR_EN_Pos                   0U                                            /*!< SCB DTCMCR: EN Position */
-#define SCB_DTCMCR_EN_Msk                  (1UL /*<< SCB_DTCMCR_EN_Pos*/)                 /*!< SCB DTCMCR: EN Mask */
-/* AHBP Control Register Definitions */
-#define SCB_AHBPCR_SZ_Pos                   1U                                            /*!< SCB AHBPCR: SZ Position */
-#define SCB_AHBPCR_SZ_Msk                  (7UL << SCB_AHBPCR_SZ_Pos)                     /*!< SCB AHBPCR: SZ Mask */
-#define SCB_AHBPCR_EN_Pos                   0U                                            /*!< SCB AHBPCR: EN Position */
-#define SCB_AHBPCR_EN_Msk                  (1UL /*<< SCB_AHBPCR_EN_Pos*/)                 /*!< SCB AHBPCR: EN Mask */
-/* L1 Cache Control Register Definitions */
-#define SCB_CACR_FORCEWT_Pos                2U                                            /*!< SCB CACR: FORCEWT Position */
-#define SCB_CACR_FORCEWT_Msk               (1UL << SCB_CACR_FORCEWT_Pos)                  /*!< SCB CACR: FORCEWT Mask */
-#define SCB_CACR_ECCEN_Pos                  1U                                            /*!< SCB CACR: ECCEN Position */
-#define SCB_CACR_ECCEN_Msk                 (1UL << SCB_CACR_ECCEN_Pos)                    /*!< SCB CACR: ECCEN Mask */
-#define SCB_CACR_SIWT_Pos                   0U                                            /*!< SCB CACR: SIWT Position */
-#define SCB_CACR_SIWT_Msk                  (1UL /*<< SCB_CACR_SIWT_Pos*/)                 /*!< SCB CACR: SIWT Mask */
-/* AHBS Control Register Definitions */
-#define SCB_AHBSCR_INITCOUNT_Pos           11U                                            /*!< SCB AHBSCR: INITCOUNT Position */
-#define SCB_AHBSCR_INITCOUNT_Msk           (0x1FUL << SCB_AHBPCR_INITCOUNT_Pos)           /*!< SCB AHBSCR: INITCOUNT Mask */
-#define SCB_AHBSCR_TPRI_Pos                 2U                                            /*!< SCB AHBSCR: TPRI Position */
-#define SCB_AHBSCR_TPRI_Msk                (0x1FFUL << SCB_AHBPCR_TPRI_Pos)               /*!< SCB AHBSCR: TPRI Mask */
-#define SCB_AHBSCR_CTL_Pos                  0U                                            /*!< SCB AHBSCR: CTL Position*/
-#define SCB_AHBSCR_CTL_Msk                 (3UL /*<< SCB_AHBPCR_CTL_Pos*/)                /*!< SCB AHBSCR: CTL Mask */
-/* Auxiliary Bus Fault Status Register Definitions */
-#define SCB_ABFSR_AXIMTYPE_Pos              8U                                            /*!< SCB ABFSR: AXIMTYPE Position*/
-#define SCB_ABFSR_AXIMTYPE_Msk             (3UL << SCB_ABFSR_AXIMTYPE_Pos)                /*!< SCB ABFSR: AXIMTYPE Mask */
-#define SCB_ABFSR_EPPB_Pos                  4U                                            /*!< SCB ABFSR: EPPB Position*/
-#define SCB_ABFSR_EPPB_Msk                 (1UL << SCB_ABFSR_EPPB_Pos)                    /*!< SCB ABFSR: EPPB Mask */
-#define SCB_ABFSR_AXIM_Pos                  3U                                            /*!< SCB ABFSR: AXIM Position*/
-#define SCB_ABFSR_AXIM_Msk                 (1UL << SCB_ABFSR_AXIM_Pos)                    /*!< SCB ABFSR: AXIM Mask */
-#define SCB_ABFSR_AHBP_Pos                  2U                                            /*!< SCB ABFSR: AHBP Position*/
-#define SCB_ABFSR_AHBP_Msk                 (1UL << SCB_ABFSR_AHBP_Pos)                    /*!< SCB ABFSR: AHBP Mask */
-#define SCB_ABFSR_DTCM_Pos                  1U                                            /*!< SCB ABFSR: DTCM Position*/
-#define SCB_ABFSR_DTCM_Msk                 (1UL << SCB_ABFSR_DTCM_Pos)                    /*!< SCB ABFSR: DTCM Mask */
-#define SCB_ABFSR_ITCM_Pos                  0U                                            /*!< SCB ABFSR: ITCM Position*/
-#define SCB_ABFSR_ITCM_Msk                 (1UL /*<< SCB_ABFSR_ITCM_Pos*/)                /*!< SCB ABFSR: ITCM Mask */
-/*@} end of group CMSIS_SCB */
-  \defgroup CMSIS_SCnSCB System Controls not in SCB (SCnSCB)
-  \brief    Type definitions for the System Control and ID Register not in the SCB
-  \brief  Structure type to access the System Control and ID Register not in the SCB.
-typedef struct
-  __IM  uint32_t ICTR;                   /*!< Offset: 0x004 (R/ )  Interrupt Controller Type Register */
-  __IOM uint32_t ACTLR;                  /*!< Offset: 0x008 (R/W)  Auxiliary Control Register */
-} SCnSCB_Type;
-/* Interrupt Controller Type Register Definitions */
-#define SCnSCB_ICTR_INTLINESNUM_Pos         0U                                         /*!< ICTR: INTLINESNUM Position */
-#define SCnSCB_ICTR_INTLINESNUM_Msk        (0xFUL /*<< SCnSCB_ICTR_INTLINESNUM_Pos*/)  /*!< ICTR: INTLINESNUM Mask */
-/* Auxiliary Control Register Definitions */
-#define SCnSCB_ACTLR_DISITMATBFLUSH_Pos    12U                                         /*!< ACTLR: DISITMATBFLUSH Position */
-#define SCnSCB_ACTLR_DISITMATBFLUSH_Msk    (1UL << SCnSCB_ACTLR_DISITMATBFLUSH_Pos)    /*!< ACTLR: DISITMATBFLUSH Mask */
-#define SCnSCB_ACTLR_DISRAMODE_Pos         11U                                         /*!< ACTLR: DISRAMODE Position */
-#define SCnSCB_ACTLR_DISRAMODE_Msk         (1UL << SCnSCB_ACTLR_DISRAMODE_Pos)         /*!< ACTLR: DISRAMODE Mask */
-#define SCnSCB_ACTLR_FPEXCODIS_Pos         10U                                         /*!< ACTLR: FPEXCODIS Position */
-#define SCnSCB_ACTLR_FPEXCODIS_Msk         (1UL << SCnSCB_ACTLR_FPEXCODIS_Pos)         /*!< ACTLR: FPEXCODIS Mask */
-#define SCnSCB_ACTLR_DISFOLD_Pos            2U                                         /*!< ACTLR: DISFOLD Position */
-#define SCnSCB_ACTLR_DISFOLD_Msk           (1UL << SCnSCB_ACTLR_DISFOLD_Pos)           /*!< ACTLR: DISFOLD Mask */
-#define SCnSCB_ACTLR_DISMCYCINT_Pos         0U                                         /*!< ACTLR: DISMCYCINT Position */
-#define SCnSCB_ACTLR_DISMCYCINT_Msk        (1UL /*<< SCnSCB_ACTLR_DISMCYCINT_Pos*/)    /*!< ACTLR: DISMCYCINT Mask */
-/*@} end of group CMSIS_SCnotSCB */
-  \defgroup CMSIS_SysTick     System Tick Timer (SysTick)
-  \brief    Type definitions for the System Timer Registers.
-  \brief  Structure type to access the System Timer (SysTick).
-typedef struct
-  __IOM uint32_t CTRL;                   /*!< Offset: 0x000 (R/W)  SysTick Control and Status Register */
-  __IOM uint32_t LOAD;                   /*!< Offset: 0x004 (R/W)  SysTick Reload Value Register */
-  __IOM uint32_t VAL;                    /*!< Offset: 0x008 (R/W)  SysTick Current Value Register */
-  __IM  uint32_t CALIB;                  /*!< Offset: 0x00C (R/ )  SysTick Calibration Register */
-} SysTick_Type;
-/* SysTick Control / Status Register Definitions */
-#define SysTick_CTRL_COUNTFLAG_Pos         16U                                            /*!< SysTick CTRL: COUNTFLAG Position */
-#define SysTick_CTRL_COUNTFLAG_Msk         (1UL << SysTick_CTRL_COUNTFLAG_Pos)            /*!< SysTick CTRL: COUNTFLAG Mask */
-#define SysTick_CTRL_CLKSOURCE_Pos          2U                                            /*!< SysTick CTRL: CLKSOURCE Position */
-#define SysTick_CTRL_CLKSOURCE_Msk         (1UL << SysTick_CTRL_CLKSOURCE_Pos)            /*!< SysTick CTRL: CLKSOURCE Mask */
-#define SysTick_CTRL_TICKINT_Pos            1U                                            /*!< SysTick CTRL: TICKINT Position */
-#define SysTick_CTRL_TICKINT_Msk           (1UL << SysTick_CTRL_TICKINT_Pos)              /*!< SysTick CTRL: TICKINT Mask */
-#define SysTick_CTRL_ENABLE_Pos             0U                                            /*!< SysTick CTRL: ENABLE Position */
-#define SysTick_CTRL_ENABLE_Msk            (1UL /*<< SysTick_CTRL_ENABLE_Pos*/)           /*!< SysTick CTRL: ENABLE Mask */
-/* SysTick Reload Register Definitions */
-#define SysTick_LOAD_RELOAD_Pos             0U                                            /*!< SysTick LOAD: RELOAD Position */
-#define SysTick_LOAD_RELOAD_Msk            (0xFFFFFFUL /*<< SysTick_LOAD_RELOAD_Pos*/)    /*!< SysTick LOAD: RELOAD Mask */
-/* SysTick Current Register Definitions */
-#define SysTick_VAL_CURRENT_Pos             0U                                            /*!< SysTick VAL: CURRENT Position */
-#define SysTick_VAL_CURRENT_Msk            (0xFFFFFFUL /*<< SysTick_VAL_CURRENT_Pos*/)    /*!< SysTick VAL: CURRENT Mask */
-/* SysTick Calibration Register Definitions */
-#define SysTick_CALIB_NOREF_Pos            31U                                            /*!< SysTick CALIB: NOREF Position */
-#define SysTick_CALIB_NOREF_Msk            (1UL << SysTick_CALIB_NOREF_Pos)               /*!< SysTick CALIB: NOREF Mask */
-#define SysTick_CALIB_SKEW_Pos             30U                                            /*!< SysTick CALIB: SKEW Position */
-#define SysTick_CALIB_SKEW_Msk             (1UL << SysTick_CALIB_SKEW_Pos)                /*!< SysTick CALIB: SKEW Mask */
-#define SysTick_CALIB_TENMS_Pos             0U                                            /*!< SysTick CALIB: TENMS Position */
-#define SysTick_CALIB_TENMS_Msk            (0xFFFFFFUL /*<< SysTick_CALIB_TENMS_Pos*/)    /*!< SysTick CALIB: TENMS Mask */
-/*@} end of group CMSIS_SysTick */
-  \defgroup CMSIS_ITM     Instrumentation Trace Macrocell (ITM)
-  \brief    Type definitions for the Instrumentation Trace Macrocell (ITM)
-  \brief  Structure type to access the Instrumentation Trace Macrocell Register (ITM).
-typedef struct
-  __OM  union
-    __OM  uint8_t    u8;                 /*!< Offset: 0x000 ( /W)  ITM Stimulus Port 8-bit */
-    __OM  uint16_t   u16;                /*!< Offset: 0x000 ( /W)  ITM Stimulus Port 16-bit */
-    __OM  uint32_t   u32;                /*!< Offset: 0x000 ( /W)  ITM Stimulus Port 32-bit */
-  }  PORT [32U];                         /*!< Offset: 0x000 ( /W)  ITM Stimulus Port Registers */
-        uint32_t RESERVED0[864U];
-  __IOM uint32_t TER;                    /*!< Offset: 0xE00 (R/W)  ITM Trace Enable Register */
-        uint32_t RESERVED1[15U];
-  __IOM uint32_t TPR;                    /*!< Offset: 0xE40 (R/W)  ITM Trace Privilege Register */
-        uint32_t RESERVED2[15U];
-  __IOM uint32_t TCR;                    /*!< Offset: 0xE80 (R/W)  ITM Trace Control Register */
-        uint32_t RESERVED3[29U];
-  __OM  uint32_t IWR;                    /*!< Offset: 0xEF8 ( /W)  ITM Integration Write Register */
-  __IM  uint32_t IRR;                    /*!< Offset: 0xEFC (R/ )  ITM Integration Read Register */
-  __IOM uint32_t IMCR;                   /*!< Offset: 0xF00 (R/W)  ITM Integration Mode Control Register */
-        uint32_t RESERVED4[43U];
-  __OM  uint32_t LAR;                    /*!< Offset: 0xFB0 ( /W)  ITM Lock Access Register */
-  __IM  uint32_t LSR;                    /*!< Offset: 0xFB4 (R/ )  ITM Lock Status Register */
-        uint32_t RESERVED5[6U];
-  __IM  uint32_t PID4;                   /*!< Offset: 0xFD0 (R/ )  ITM Peripheral Identification Register #4 */
-  __IM  uint32_t PID5;                   /*!< Offset: 0xFD4 (R/ )  ITM Peripheral Identification Register #5 */
-  __IM  uint32_t PID6;                   /*!< Offset: 0xFD8 (R/ )  ITM Peripheral Identification Register #6 */
-  __IM  uint32_t PID7;                   /*!< Offset: 0xFDC (R/ )  ITM Peripheral Identification Register #7 */
-  __IM  uint32_t PID0;                   /*!< Offset: 0xFE0 (R/ )  ITM Peripheral Identification Register #0 */
-  __IM  uint32_t PID1;                   /*!< Offset: 0xFE4 (R/ )  ITM Peripheral Identification Register #1 */
-  __IM  uint32_t PID2;                   /*!< Offset: 0xFE8 (R/ )  ITM Peripheral Identification Register #2 */
-  __IM  uint32_t PID3;                   /*!< Offset: 0xFEC (R/ )  ITM Peripheral Identification Register #3 */
-  __IM  uint32_t CID0;                   /*!< Offset: 0xFF0 (R/ )  ITM Component  Identification Register #0 */
-  __IM  uint32_t CID1;                   /*!< Offset: 0xFF4 (R/ )  ITM Component  Identification Register #1 */
-  __IM  uint32_t CID2;                   /*!< Offset: 0xFF8 (R/ )  ITM Component  Identification Register #2 */
-  __IM  uint32_t CID3;                   /*!< Offset: 0xFFC (R/ )  ITM Component  Identification Register #3 */
-} ITM_Type;
-/* ITM Trace Privilege Register Definitions */
-#define ITM_TPR_PRIVMASK_Pos                0U                                            /*!< ITM TPR: PRIVMASK Position */
-#define ITM_TPR_PRIVMASK_Msk               (0xFUL /*<< ITM_TPR_PRIVMASK_Pos*/)            /*!< ITM TPR: PRIVMASK Mask */
-/* ITM Trace Control Register Definitions */
-#define ITM_TCR_BUSY_Pos                   23U                                            /*!< ITM TCR: BUSY Position */
-#define ITM_TCR_BUSY_Msk                   (1UL << ITM_TCR_BUSY_Pos)                      /*!< ITM TCR: BUSY Mask */
-#define ITM_TCR_TraceBusID_Pos             16U                                            /*!< ITM TCR: ATBID Position */
-#define ITM_TCR_TraceBusID_Msk             (0x7FUL << ITM_TCR_TraceBusID_Pos)             /*!< ITM TCR: ATBID Mask */
-#define ITM_TCR_GTSFREQ_Pos                10U                                            /*!< ITM TCR: Global timestamp frequency Position */
-#define ITM_TCR_GTSFREQ_Msk                (3UL << ITM_TCR_GTSFREQ_Pos)                   /*!< ITM TCR: Global timestamp frequency Mask */
-#define ITM_TCR_TSPrescale_Pos              8U                                            /*!< ITM TCR: TSPrescale Position */
-#define ITM_TCR_TSPrescale_Msk             (3UL << ITM_TCR_TSPrescale_Pos)                /*!< ITM TCR: TSPrescale Mask */
-#define ITM_TCR_SWOENA_Pos                  4U                                            /*!< ITM TCR: SWOENA Position */
-#define ITM_TCR_SWOENA_Msk                 (1UL << ITM_TCR_SWOENA_Pos)                    /*!< ITM TCR: SWOENA Mask */
-#define ITM_TCR_DWTENA_Pos                  3U                                            /*!< ITM TCR: DWTENA Position */
-#define ITM_TCR_DWTENA_Msk                 (1UL << ITM_TCR_DWTENA_Pos)                    /*!< ITM TCR: DWTENA Mask */
-#define ITM_TCR_SYNCENA_Pos                 2U                                            /*!< ITM TCR: SYNCENA Position */
-#define ITM_TCR_SYNCENA_Msk                (1UL << ITM_TCR_SYNCENA_Pos)                   /*!< ITM TCR: SYNCENA Mask */
-#define ITM_TCR_TSENA_Pos                   1U                                            /*!< ITM TCR: TSENA Position */
-#define ITM_TCR_TSENA_Msk                  (1UL << ITM_TCR_TSENA_Pos)                     /*!< ITM TCR: TSENA Mask */
-#define ITM_TCR_ITMENA_Pos                  0U                                            /*!< ITM TCR: ITM Enable bit Position */
-#define ITM_TCR_ITMENA_Msk                 (1UL /*<< ITM_TCR_ITMENA_Pos*/)                /*!< ITM TCR: ITM Enable bit Mask */
-/* ITM Integration Write Register Definitions */
-#define ITM_IWR_ATVALIDM_Pos                0U                                            /*!< ITM IWR: ATVALIDM Position */
-#define ITM_IWR_ATVALIDM_Msk               (1UL /*<< ITM_IWR_ATVALIDM_Pos*/)              /*!< ITM IWR: ATVALIDM Mask */
-/* ITM Integration Read Register Definitions */
-#define ITM_IRR_ATREADYM_Pos                0U                                            /*!< ITM IRR: ATREADYM Position */
-#define ITM_IRR_ATREADYM_Msk               (1UL /*<< ITM_IRR_ATREADYM_Pos*/)              /*!< ITM IRR: ATREADYM Mask */
-/* ITM Integration Mode Control Register Definitions */
-#define ITM_IMCR_INTEGRATION_Pos            0U                                            /*!< ITM IMCR: INTEGRATION Position */
-#define ITM_IMCR_INTEGRATION_Msk           (1UL /*<< ITM_IMCR_INTEGRATION_Pos*/)          /*!< ITM IMCR: INTEGRATION Mask */
-/* ITM Lock Status Register Definitions */
-#define ITM_LSR_ByteAcc_Pos                 2U                                            /*!< ITM LSR: ByteAcc Position */
-#define ITM_LSR_ByteAcc_Msk                (1UL << ITM_LSR_ByteAcc_Pos)                   /*!< ITM LSR: ByteAcc Mask */
-#define ITM_LSR_Access_Pos                  1U                                            /*!< ITM LSR: Access Position */
-#define ITM_LSR_Access_Msk                 (1UL << ITM_LSR_Access_Pos)                    /*!< ITM LSR: Access Mask */
-#define ITM_LSR_Present_Pos                 0U                                            /*!< ITM LSR: Present Position */
-#define ITM_LSR_Present_Msk                (1UL /*<< ITM_LSR_Present_Pos*/)               /*!< ITM LSR: Present Mask */
-/*@}*/ /* end of group CMSIS_ITM */
-  \defgroup CMSIS_DWT     Data Watchpoint and Trace (DWT)
-  \brief    Type definitions for the Data Watchpoint and Trace (DWT)
-  \brief  Structure type to access the Data Watchpoint and Trace Register (DWT).
-typedef struct
-  __IOM uint32_t CTRL;                   /*!< Offset: 0x000 (R/W)  Control Register */
-  __IOM uint32_t CYCCNT;                 /*!< Offset: 0x004 (R/W)  Cycle Count Register */
-  __IOM uint32_t CPICNT;                 /*!< Offset: 0x008 (R/W)  CPI Count Register */
-  __IOM uint32_t EXCCNT;                 /*!< Offset: 0x00C (R/W)  Exception Overhead Count Register */
-  __IOM uint32_t SLEEPCNT;               /*!< Offset: 0x010 (R/W)  Sleep Count Register */
-  __IOM uint32_t LSUCNT;                 /*!< Offset: 0x014 (R/W)  LSU Count Register */
-  __IOM uint32_t FOLDCNT;                /*!< Offset: 0x018 (R/W)  Folded-instruction Count Register */
-  __IM  uint32_t PCSR;                   /*!< Offset: 0x01C (R/ )  Program Counter Sample Register */
-  __IOM uint32_t COMP0;                  /*!< Offset: 0x020 (R/W)  Comparator Register 0 */
-  __IOM uint32_t MASK0;                  /*!< Offset: 0x024 (R/W)  Mask Register 0 */
-  __IOM uint32_t FUNCTION0;              /*!< Offset: 0x028 (R/W)  Function Register 0 */
-  __IOM uint32_t COMP1;                  /*!< Offset: 0x030 (R/W)  Comparator Register 1 */
-  __IOM uint32_t MASK1;                  /*!< Offset: 0x034 (R/W)  Mask Register 1 */
-  __IOM uint32_t FUNCTION1;              /*!< Offset: 0x038 (R/W)  Function Register 1 */
-        uint32_t RESERVED1[1U];
-  __IOM uint32_t COMP2;                  /*!< Offset: 0x040 (R/W)  Comparator Register 2 */
-  __IOM uint32_t MASK2;                  /*!< Offset: 0x044 (R/W)  Mask Register 2 */
-  __IOM uint32_t FUNCTION2;              /*!< Offset: 0x048 (R/W)  Function Register 2 */
-        uint32_t RESERVED2[1U];
-  __IOM uint32_t COMP3;                  /*!< Offset: 0x050 (R/W)  Comparator Register 3 */
-  __IOM uint32_t MASK3;                  /*!< Offset: 0x054 (R/W)  Mask Register 3 */
-  __IOM uint32_t FUNCTION3;              /*!< Offset: 0x058 (R/W)  Function Register 3 */
-        uint32_t RESERVED3[981U];
-  __OM  uint32_t LAR;                    /*!< Offset: 0xFB0 (  W)  Lock Access Register */
-  __IM  uint32_t LSR;                    /*!< Offset: 0xFB4 (R  )  Lock Status Register */
-} DWT_Type;
-/* DWT Control Register Definitions */
-#define DWT_CTRL_NUMCOMP_Pos               28U                                         /*!< DWT CTRL: NUMCOMP Position */
-#define DWT_CTRL_NUMCOMP_Msk               (0xFUL << DWT_CTRL_NUMCOMP_Pos)             /*!< DWT CTRL: NUMCOMP Mask */
-#define DWT_CTRL_NOTRCPKT_Pos              27U                                         /*!< DWT CTRL: NOTRCPKT Position */
-#define DWT_CTRL_NOTRCPKT_Msk              (0x1UL << DWT_CTRL_NOTRCPKT_Pos)            /*!< DWT CTRL: NOTRCPKT Mask */
-#define DWT_CTRL_NOEXTTRIG_Pos             26U                                         /*!< DWT CTRL: NOEXTTRIG Position */
-#define DWT_CTRL_NOEXTTRIG_Msk             (0x1UL << DWT_CTRL_NOEXTTRIG_Pos)           /*!< DWT CTRL: NOEXTTRIG Mask */
-#define DWT_CTRL_NOCYCCNT_Pos              25U                                         /*!< DWT CTRL: NOCYCCNT Position */
-#define DWT_CTRL_NOCYCCNT_Msk              (0x1UL << DWT_CTRL_NOCYCCNT_Pos)            /*!< DWT CTRL: NOCYCCNT Mask */
-#define DWT_CTRL_NOPRFCNT_Pos              24U                                         /*!< DWT CTRL: NOPRFCNT Position */
-#define DWT_CTRL_NOPRFCNT_Msk              (0x1UL << DWT_CTRL_NOPRFCNT_Pos)            /*!< DWT CTRL: NOPRFCNT Mask */
-#define DWT_CTRL_CYCEVTENA_Pos             22U                                         /*!< DWT CTRL: CYCEVTENA Position */
-#define DWT_CTRL_CYCEVTENA_Msk             (0x1UL << DWT_CTRL_CYCEVTENA_Pos)           /*!< DWT CTRL: CYCEVTENA Mask */
-#define DWT_CTRL_FOLDEVTENA_Pos            21U                                         /*!< DWT CTRL: FOLDEVTENA Position */
-#define DWT_CTRL_FOLDEVTENA_Msk            (0x1UL << DWT_CTRL_FOLDEVTENA_Pos)          /*!< DWT CTRL: FOLDEVTENA Mask */
-#define DWT_CTRL_LSUEVTENA_Pos             20U                                         /*!< DWT CTRL: LSUEVTENA Position */
-#define DWT_CTRL_LSUEVTENA_Msk             (0x1UL << DWT_CTRL_LSUEVTENA_Pos)           /*!< DWT CTRL: LSUEVTENA Mask */
-#define DWT_CTRL_SLEEPEVTENA_Pos           19U                                         /*!< DWT CTRL: SLEEPEVTENA Position */
-#define DWT_CTRL_SLEEPEVTENA_Msk           (0x1UL << DWT_CTRL_SLEEPEVTENA_Pos)         /*!< DWT CTRL: SLEEPEVTENA Mask */
-#define DWT_CTRL_EXCEVTENA_Pos             18U                                         /*!< DWT CTRL: EXCEVTENA Position */
-#define DWT_CTRL_EXCEVTENA_Msk             (0x1UL << DWT_CTRL_EXCEVTENA_Pos)           /*!< DWT CTRL: EXCEVTENA Mask */
-#define DWT_CTRL_CPIEVTENA_Pos             17U                                         /*!< DWT CTRL: CPIEVTENA Position */
-#define DWT_CTRL_CPIEVTENA_Msk             (0x1UL << DWT_CTRL_CPIEVTENA_Pos)           /*!< DWT CTRL: CPIEVTENA Mask */
-#define DWT_CTRL_EXCTRCENA_Pos             16U                                         /*!< DWT CTRL: EXCTRCENA Position */
-#define DWT_CTRL_EXCTRCENA_Msk             (0x1UL << DWT_CTRL_EXCTRCENA_Pos)           /*!< DWT CTRL: EXCTRCENA Mask */
-#define DWT_CTRL_PCSAMPLENA_Pos            12U                                         /*!< DWT CTRL: PCSAMPLENA Position */
-#define DWT_CTRL_PCSAMPLENA_Msk            (0x1UL << DWT_CTRL_PCSAMPLENA_Pos)          /*!< DWT CTRL: PCSAMPLENA Mask */
-#define DWT_CTRL_SYNCTAP_Pos               10U                                         /*!< DWT CTRL: SYNCTAP Position */
-#define DWT_CTRL_SYNCTAP_Msk               (0x3UL << DWT_CTRL_SYNCTAP_Pos)             /*!< DWT CTRL: SYNCTAP Mask */
-#define DWT_CTRL_CYCTAP_Pos                 9U                                         /*!< DWT CTRL: CYCTAP Position */
-#define DWT_CTRL_CYCTAP_Msk                (0x1UL << DWT_CTRL_CYCTAP_Pos)              /*!< DWT CTRL: CYCTAP Mask */
-#define DWT_CTRL_POSTINIT_Pos               5U                                         /*!< DWT CTRL: POSTINIT Position */
-#define DWT_CTRL_POSTINIT_Msk              (0xFUL << DWT_CTRL_POSTINIT_Pos)            /*!< DWT CTRL: POSTINIT Mask */
-#define DWT_CTRL_POSTPRESET_Pos             1U                                         /*!< DWT CTRL: POSTPRESET Position */
-#define DWT_CTRL_POSTPRESET_Msk            (0xFUL << DWT_CTRL_POSTPRESET_Pos)          /*!< DWT CTRL: POSTPRESET Mask */
-#define DWT_CTRL_CYCCNTENA_Pos              0U                                         /*!< DWT CTRL: CYCCNTENA Position */
-#define DWT_CTRL_CYCCNTENA_Msk             (0x1UL /*<< DWT_CTRL_CYCCNTENA_Pos*/)       /*!< DWT CTRL: CYCCNTENA Mask */
-/* DWT CPI Count Register Definitions */
-#define DWT_CPICNT_CPICNT_Pos               0U                                         /*!< DWT CPICNT: CPICNT Position */
-#define DWT_CPICNT_CPICNT_Msk              (0xFFUL /*<< DWT_CPICNT_CPICNT_Pos*/)       /*!< DWT CPICNT: CPICNT Mask */
-/* DWT Exception Overhead Count Register Definitions */
-#define DWT_EXCCNT_EXCCNT_Pos               0U                                         /*!< DWT EXCCNT: EXCCNT Position */
-#define DWT_EXCCNT_EXCCNT_Msk              (0xFFUL /*<< DWT_EXCCNT_EXCCNT_Pos*/)       /*!< DWT EXCCNT: EXCCNT Mask */
-/* DWT Sleep Count Register Definitions */
-#define DWT_SLEEPCNT_SLEEPCNT_Pos           0U                                         /*!< DWT SLEEPCNT: SLEEPCNT Position */
-#define DWT_SLEEPCNT_SLEEPCNT_Msk          (0xFFUL /*<< DWT_SLEEPCNT_SLEEPCNT_Pos*/)   /*!< DWT SLEEPCNT: SLEEPCNT Mask */
-/* DWT LSU Count Register Definitions */
-#define DWT_LSUCNT_LSUCNT_Pos               0U                                         /*!< DWT LSUCNT: LSUCNT Position */
-#define DWT_LSUCNT_LSUCNT_Msk              (0xFFUL /*<< DWT_LSUCNT_LSUCNT_Pos*/)       /*!< DWT LSUCNT: LSUCNT Mask */
-/* DWT Folded-instruction Count Register Definitions */
-#define DWT_FOLDCNT_FOLDCNT_Pos             0U                                         /*!< DWT FOLDCNT: FOLDCNT Position */
-#define DWT_FOLDCNT_FOLDCNT_Msk            (0xFFUL /*<< DWT_FOLDCNT_FOLDCNT_Pos*/)     /*!< DWT FOLDCNT: FOLDCNT Mask */
-/* DWT Comparator Mask Register Definitions */
-#define DWT_MASK_MASK_Pos                   0U                                         /*!< DWT MASK: MASK Position */
-#define DWT_MASK_MASK_Msk                  (0x1FUL /*<< DWT_MASK_MASK_Pos*/)           /*!< DWT MASK: MASK Mask */
-/* DWT Comparator Function Register Definitions */
-#define DWT_FUNCTION_MATCHED_Pos           24U                                         /*!< DWT FUNCTION: MATCHED Position */
-#define DWT_FUNCTION_MATCHED_Msk           (0x1UL << DWT_FUNCTION_MATCHED_Pos)         /*!< DWT FUNCTION: MATCHED Mask */
-#define DWT_FUNCTION_DATAVADDR1_Pos        16U                                         /*!< DWT FUNCTION: DATAVADDR1 Position */
-#define DWT_FUNCTION_DATAVADDR1_Msk        (0xFUL << DWT_FUNCTION_DATAVADDR1_Pos)      /*!< DWT FUNCTION: DATAVADDR1 Mask */
-#define DWT_FUNCTION_DATAVADDR0_Pos        12U                                         /*!< DWT FUNCTION: DATAVADDR0 Position */
-#define DWT_FUNCTION_DATAVADDR0_Msk        (0xFUL << DWT_FUNCTION_DATAVADDR0_Pos)      /*!< DWT FUNCTION: DATAVADDR0 Mask */
-#define DWT_FUNCTION_DATAVSIZE_Pos         10U                                         /*!< DWT FUNCTION: DATAVSIZE Position */
-#define DWT_FUNCTION_DATAVSIZE_Msk         (0x3UL << DWT_FUNCTION_DATAVSIZE_Pos)       /*!< DWT FUNCTION: DATAVSIZE Mask */
-#define DWT_FUNCTION_LNK1ENA_Pos            9U                                         /*!< DWT FUNCTION: LNK1ENA Position */
-#define DWT_FUNCTION_LNK1ENA_Msk           (0x1UL << DWT_FUNCTION_LNK1ENA_Pos)         /*!< DWT FUNCTION: LNK1ENA Mask */
-#define DWT_FUNCTION_DATAVMATCH_Pos         8U                                         /*!< DWT FUNCTION: DATAVMATCH Position */
-#define DWT_FUNCTION_DATAVMATCH_Msk        (0x1UL << DWT_FUNCTION_DATAVMATCH_Pos)      /*!< DWT FUNCTION: DATAVMATCH Mask */
-#define DWT_FUNCTION_CYCMATCH_Pos           7U                                         /*!< DWT FUNCTION: CYCMATCH Position */
-#define DWT_FUNCTION_CYCMATCH_Msk          (0x1UL << DWT_FUNCTION_CYCMATCH_Pos)        /*!< DWT FUNCTION: CYCMATCH Mask */
-#define DWT_FUNCTION_EMITRANGE_Pos          5U                                         /*!< DWT FUNCTION: EMITRANGE Position */
-#define DWT_FUNCTION_EMITRANGE_Msk         (0x1UL << DWT_FUNCTION_EMITRANGE_Pos)       /*!< DWT FUNCTION: EMITRANGE Mask */
-#define DWT_FUNCTION_FUNCTION_Pos           0U                                         /*!< DWT FUNCTION: FUNCTION Position */
-#define DWT_FUNCTION_FUNCTION_Msk          (0xFUL /*<< DWT_FUNCTION_FUNCTION_Pos*/)    /*!< DWT FUNCTION: FUNCTION Mask */
-/*@}*/ /* end of group CMSIS_DWT */
-  \defgroup CMSIS_TPI     Trace Port Interface (TPI)
-  \brief    Type definitions for the Trace Port Interface (TPI)
-  \brief  Structure type to access the Trace Port Interface Register (TPI).
-typedef struct
-  __IOM uint32_t SSPSR;                  /*!< Offset: 0x000 (R/ )  Supported Parallel Port Size Register */
-  __IOM uint32_t CSPSR;                  /*!< Offset: 0x004 (R/W)  Current Parallel Port Size Register */
-        uint32_t RESERVED0[2U];
-  __IOM uint32_t ACPR;                   /*!< Offset: 0x010 (R/W)  Asynchronous Clock Prescaler Register */
-        uint32_t RESERVED1[55U];
-  __IOM uint32_t SPPR;                   /*!< Offset: 0x0F0 (R/W)  Selected Pin Protocol Register */
-        uint32_t RESERVED2[131U];
-  __IM  uint32_t FFSR;                   /*!< Offset: 0x300 (R/ )  Formatter and Flush Status Register */
-  __IOM uint32_t FFCR;                   /*!< Offset: 0x304 (R/W)  Formatter and Flush Control Register */
-  __IM  uint32_t FSCR;                   /*!< Offset: 0x308 (R/ )  Formatter Synchronization Counter Register */
-        uint32_t RESERVED3[759U];
-  __IM  uint32_t TRIGGER;                /*!< Offset: 0xEE8 (R/ )  TRIGGER */
-  __IM  uint32_t FIFO0;                  /*!< Offset: 0xEEC (R/ )  Integration ETM Data */
-  __IM  uint32_t ITATBCTR2;              /*!< Offset: 0xEF0 (R/ )  ITATBCTR2 */
-        uint32_t RESERVED4[1U];
-  __IM  uint32_t ITATBCTR0;              /*!< Offset: 0xEF8 (R/ )  ITATBCTR0 */
-  __IM  uint32_t FIFO1;                  /*!< Offset: 0xEFC (R/ )  Integration ITM Data */
-  __IOM uint32_t ITCTRL;                 /*!< Offset: 0xF00 (R/W)  Integration Mode Control */
-        uint32_t RESERVED5[39U];
-  __IOM uint32_t CLAIMSET;               /*!< Offset: 0xFA0 (R/W)  Claim tag set */
-  __IOM uint32_t CLAIMCLR;               /*!< Offset: 0xFA4 (R/W)  Claim tag clear */
-        uint32_t RESERVED7[8U];
-  __IM  uint32_t DEVID;                  /*!< Offset: 0xFC8 (R/ )  TPIU_DEVID */
-  __IM  uint32_t DEVTYPE;                /*!< Offset: 0xFCC (R/ )  TPIU_DEVTYPE */
-} TPI_Type;
-/* TPI Asynchronous Clock Prescaler Register Definitions */
-#define TPI_ACPR_PRESCALER_Pos              0U                                         /*!< TPI ACPR: PRESCALER Position */
-#define TPI_ACPR_PRESCALER_Msk             (0x1FFFUL /*<< TPI_ACPR_PRESCALER_Pos*/)    /*!< TPI ACPR: PRESCALER Mask */
-/* TPI Selected Pin Protocol Register Definitions */
-#define TPI_SPPR_TXMODE_Pos                 0U                                         /*!< TPI SPPR: TXMODE Position */
-#define TPI_SPPR_TXMODE_Msk                (0x3UL /*<< TPI_SPPR_TXMODE_Pos*/)          /*!< TPI SPPR: TXMODE Mask */
-/* TPI Formatter and Flush Status Register Definitions */
-#define TPI_FFSR_FtNonStop_Pos              3U                                         /*!< TPI FFSR: FtNonStop Position */
-#define TPI_FFSR_FtNonStop_Msk             (0x1UL << TPI_FFSR_FtNonStop_Pos)           /*!< TPI FFSR: FtNonStop Mask */
-#define TPI_FFSR_TCPresent_Pos              2U                                         /*!< TPI FFSR: TCPresent Position */
-#define TPI_FFSR_TCPresent_Msk             (0x1UL << TPI_FFSR_TCPresent_Pos)           /*!< TPI FFSR: TCPresent Mask */
-#define TPI_FFSR_FtStopped_Pos              1U                                         /*!< TPI FFSR: FtStopped Position */
-#define TPI_FFSR_FtStopped_Msk             (0x1UL << TPI_FFSR_FtStopped_Pos)           /*!< TPI FFSR: FtStopped Mask */
-#define TPI_FFSR_FlInProg_Pos               0U                                         /*!< TPI FFSR: FlInProg Position */
-#define TPI_FFSR_FlInProg_Msk              (0x1UL /*<< TPI_FFSR_FlInProg_Pos*/)        /*!< TPI FFSR: FlInProg Mask */
-/* TPI Formatter and Flush Control Register Definitions */
-#define TPI_FFCR_TrigIn_Pos                 8U                                         /*!< TPI FFCR: TrigIn Position */
-#define TPI_FFCR_TrigIn_Msk                (0x1UL << TPI_FFCR_TrigIn_Pos)              /*!< TPI FFCR: TrigIn Mask */
-#define TPI_FFCR_EnFCont_Pos                1U                                         /*!< TPI FFCR: EnFCont Position */
-#define TPI_FFCR_EnFCont_Msk               (0x1UL << TPI_FFCR_EnFCont_Pos)             /*!< TPI FFCR: EnFCont Mask */
-/* TPI TRIGGER Register Definitions */
-#define TPI_TRIGGER_TRIGGER_Pos             0U                                         /*!< TPI TRIGGER: TRIGGER Position */
-#define TPI_TRIGGER_TRIGGER_Msk            (0x1UL /*<< TPI_TRIGGER_TRIGGER_Pos*/)      /*!< TPI TRIGGER: TRIGGER Mask */
-/* TPI Integration ETM Data Register Definitions (FIFO0) */
-#define TPI_FIFO0_ITM_ATVALID_Pos          29U                                         /*!< TPI FIFO0: ITM_ATVALID Position */
-#define TPI_FIFO0_ITM_ATVALID_Msk          (0x3UL << TPI_FIFO0_ITM_ATVALID_Pos)        /*!< TPI FIFO0: ITM_ATVALID Mask */
-#define TPI_FIFO0_ITM_bytecount_Pos        27U                                         /*!< TPI FIFO0: ITM_bytecount Position */
-#define TPI_FIFO0_ITM_bytecount_Msk        (0x3UL << TPI_FIFO0_ITM_bytecount_Pos)      /*!< TPI FIFO0: ITM_bytecount Mask */
-#define TPI_FIFO0_ETM_ATVALID_Pos          26U                                         /*!< TPI FIFO0: ETM_ATVALID Position */
-#define TPI_FIFO0_ETM_ATVALID_Msk          (0x3UL << TPI_FIFO0_ETM_ATVALID_Pos)        /*!< TPI FIFO0: ETM_ATVALID Mask */
-#define TPI_FIFO0_ETM_bytecount_Pos        24U                                         /*!< TPI FIFO0: ETM_bytecount Position */
-#define TPI_FIFO0_ETM_bytecount_Msk        (0x3UL << TPI_FIFO0_ETM_bytecount_Pos)      /*!< TPI FIFO0: ETM_bytecount Mask */
-#define TPI_FIFO0_ETM2_Pos                 16U                                         /*!< TPI FIFO0: ETM2 Position */
-#define TPI_FIFO0_ETM2_Msk                 (0xFFUL << TPI_FIFO0_ETM2_Pos)              /*!< TPI FIFO0: ETM2 Mask */
-#define TPI_FIFO0_ETM1_Pos                  8U                                         /*!< TPI FIFO0: ETM1 Position */
-#define TPI_FIFO0_ETM1_Msk                 (0xFFUL << TPI_FIFO0_ETM1_Pos)              /*!< TPI FIFO0: ETM1 Mask */
-#define TPI_FIFO0_ETM0_Pos                  0U                                         /*!< TPI FIFO0: ETM0 Position */
-#define TPI_FIFO0_ETM0_Msk                 (0xFFUL /*<< TPI_FIFO0_ETM0_Pos*/)          /*!< TPI FIFO0: ETM0 Mask */
-/* TPI ITATBCTR2 Register Definitions */
-#define TPI_ITATBCTR2_ATREADY_Pos           0U                                         /*!< TPI ITATBCTR2: ATREADY Position */
-#define TPI_ITATBCTR2_ATREADY_Msk          (0x1UL /*<< TPI_ITATBCTR2_ATREADY_Pos*/)    /*!< TPI ITATBCTR2: ATREADY Mask */
-/* TPI Integration ITM Data Register Definitions (FIFO1) */
-#define TPI_FIFO1_ITM_ATVALID_Pos          29U                                         /*!< TPI FIFO1: ITM_ATVALID Position */
-#define TPI_FIFO1_ITM_ATVALID_Msk          (0x3UL << TPI_FIFO1_ITM_ATVALID_Pos)        /*!< TPI FIFO1: ITM_ATVALID Mask */
-#define TPI_FIFO1_ITM_bytecount_Pos        27U                                         /*!< TPI FIFO1: ITM_bytecount Position */
-#define TPI_FIFO1_ITM_bytecount_Msk        (0x3UL << TPI_FIFO1_ITM_bytecount_Pos)      /*!< TPI FIFO1: ITM_bytecount Mask */
-#define TPI_FIFO1_ETM_ATVALID_Pos          26U                                         /*!< TPI FIFO1: ETM_ATVALID Position */
-#define TPI_FIFO1_ETM_ATVALID_Msk          (0x3UL << TPI_FIFO1_ETM_ATVALID_Pos)        /*!< TPI FIFO1: ETM_ATVALID Mask */
-#define TPI_FIFO1_ETM_bytecount_Pos        24U                                         /*!< TPI FIFO1: ETM_bytecount Position */
-#define TPI_FIFO1_ETM_bytecount_Msk        (0x3UL << TPI_FIFO1_ETM_bytecount_Pos)      /*!< TPI FIFO1: ETM_bytecount Mask */
-#define TPI_FIFO1_ITM2_Pos                 16U                                         /*!< TPI FIFO1: ITM2 Position */
-#define TPI_FIFO1_ITM2_Msk                 (0xFFUL << TPI_FIFO1_ITM2_Pos)              /*!< TPI FIFO1: ITM2 Mask */
-#define TPI_FIFO1_ITM1_Pos                  8U                                         /*!< TPI FIFO1: ITM1 Position */
-#define TPI_FIFO1_ITM1_Msk                 (0xFFUL << TPI_FIFO1_ITM1_Pos)              /*!< TPI FIFO1: ITM1 Mask */
-#define TPI_FIFO1_ITM0_Pos                  0U                                         /*!< TPI FIFO1: ITM0 Position */
-#define TPI_FIFO1_ITM0_Msk                 (0xFFUL /*<< TPI_FIFO1_ITM0_Pos*/)          /*!< TPI FIFO1: ITM0 Mask */
-/* TPI ITATBCTR0 Register Definitions */
-#define TPI_ITATBCTR0_ATREADY_Pos           0U                                         /*!< TPI ITATBCTR0: ATREADY Position */
-#define TPI_ITATBCTR0_ATREADY_Msk          (0x1UL /*<< TPI_ITATBCTR0_ATREADY_Pos*/)    /*!< TPI ITATBCTR0: ATREADY Mask */
-/* TPI Integration Mode Control Register Definitions */
-#define TPI_ITCTRL_Mode_Pos                 0U                                         /*!< TPI ITCTRL: Mode Position */
-#define TPI_ITCTRL_Mode_Msk                (0x1UL /*<< TPI_ITCTRL_Mode_Pos*/)          /*!< TPI ITCTRL: Mode Mask */
-/* TPI DEVID Register Definitions */
-#define TPI_DEVID_NRZVALID_Pos             11U                                         /*!< TPI DEVID: NRZVALID Position */
-#define TPI_DEVID_NRZVALID_Msk             (0x1UL << TPI_DEVID_NRZVALID_Pos)           /*!< TPI DEVID: NRZVALID Mask */
-#define TPI_DEVID_MANCVALID_Pos            10U                                         /*!< TPI DEVID: MANCVALID Position */
-#define TPI_DEVID_MANCVALID_Msk            (0x1UL << TPI_DEVID_MANCVALID_Pos)          /*!< TPI DEVID: MANCVALID Mask */
-#define TPI_DEVID_PTINVALID_Pos             9U                                         /*!< TPI DEVID: PTINVALID Position */
-#define TPI_DEVID_PTINVALID_Msk            (0x1UL << TPI_DEVID_PTINVALID_Pos)          /*!< TPI DEVID: PTINVALID Mask */
-#define TPI_DEVID_MinBufSz_Pos              6U                                         /*!< TPI DEVID: MinBufSz Position */
-#define TPI_DEVID_MinBufSz_Msk             (0x7UL << TPI_DEVID_MinBufSz_Pos)           /*!< TPI DEVID: MinBufSz Mask */
-#define TPI_DEVID_AsynClkIn_Pos             5U                                         /*!< TPI DEVID: AsynClkIn Position */
-#define TPI_DEVID_AsynClkIn_Msk            (0x1UL << TPI_DEVID_AsynClkIn_Pos)          /*!< TPI DEVID: AsynClkIn Mask */
-#define TPI_DEVID_NrTraceInput_Pos          0U                                         /*!< TPI DEVID: NrTraceInput Position */
-#define TPI_DEVID_NrTraceInput_Msk         (0x1FUL /*<< TPI_DEVID_NrTraceInput_Pos*/)  /*!< TPI DEVID: NrTraceInput Mask */
-/* TPI DEVTYPE Register Definitions */
-#define TPI_DEVTYPE_MajorType_Pos           4U                                         /*!< TPI DEVTYPE: MajorType Position */
-#define TPI_DEVTYPE_MajorType_Msk          (0xFUL << TPI_DEVTYPE_MajorType_Pos)        /*!< TPI DEVTYPE: MajorType Mask */
-#define TPI_DEVTYPE_SubType_Pos             0U                                         /*!< TPI DEVTYPE: SubType Position */
-#define TPI_DEVTYPE_SubType_Msk            (0xFUL /*<< TPI_DEVTYPE_SubType_Pos*/)      /*!< TPI DEVTYPE: SubType Mask */
-/*@}*/ /* end of group CMSIS_TPI */
-#if (__MPU_PRESENT == 1U)
-  \defgroup CMSIS_MPU     Memory Protection Unit (MPU)
-  \brief    Type definitions for the Memory Protection Unit (MPU)
-  \brief  Structure type to access the Memory Protection Unit (MPU).
-typedef struct
-  __IM  uint32_t TYPE;                   /*!< Offset: 0x000 (R/ )  MPU Type Register */
-  __IOM uint32_t CTRL;                   /*!< Offset: 0x004 (R/W)  MPU Control Register */
-  __IOM uint32_t RNR;                    /*!< Offset: 0x008 (R/W)  MPU Region RNRber Register */
-  __IOM uint32_t RBAR;                   /*!< Offset: 0x00C (R/W)  MPU Region Base Address Register */
-  __IOM uint32_t RASR;                   /*!< Offset: 0x010 (R/W)  MPU Region Attribute and Size Register */
-  __IOM uint32_t RBAR_A1;                /*!< Offset: 0x014 (R/W)  MPU Alias 1 Region Base Address Register */
-  __IOM uint32_t RASR_A1;                /*!< Offset: 0x018 (R/W)  MPU Alias 1 Region Attribute and Size Register */
-  __IOM uint32_t RBAR_A2;                /*!< Offset: 0x01C (R/W)  MPU Alias 2 Region Base Address Register */
-  __IOM uint32_t RASR_A2;                /*!< Offset: 0x020 (R/W)  MPU Alias 2 Region Attribute and Size Register */
-  __IOM uint32_t RBAR_A3;                /*!< Offset: 0x024 (R/W)  MPU Alias 3 Region Base Address Register */
-  __IOM uint32_t RASR_A3;                /*!< Offset: 0x028 (R/W)  MPU Alias 3 Region Attribute and Size Register */
-} MPU_Type;
-/* MPU Type Register Definitions */
-#define MPU_TYPE_IREGION_Pos               16U                                            /*!< MPU TYPE: IREGION Position */
-#define MPU_TYPE_IREGION_Msk               (0xFFUL << MPU_TYPE_IREGION_Pos)               /*!< MPU TYPE: IREGION Mask */
-#define MPU_TYPE_DREGION_Pos                8U                                            /*!< MPU TYPE: DREGION Position */
-#define MPU_TYPE_DREGION_Msk               (0xFFUL << MPU_TYPE_DREGION_Pos)               /*!< MPU TYPE: DREGION Mask */
-#define MPU_TYPE_SEPARATE_Pos               0U                                            /*!< MPU TYPE: SEPARATE Position */
-#define MPU_TYPE_SEPARATE_Msk              (1UL /*<< MPU_TYPE_SEPARATE_Pos*/)             /*!< MPU TYPE: SEPARATE Mask */
-/* MPU Control Register Definitions */
-#define MPU_CTRL_PRIVDEFENA_Pos             2U                                            /*!< MPU CTRL: PRIVDEFENA Position */
-#define MPU_CTRL_PRIVDEFENA_Msk            (1UL << MPU_CTRL_PRIVDEFENA_Pos)               /*!< MPU CTRL: PRIVDEFENA Mask */
-#define MPU_CTRL_HFNMIENA_Pos               1U                                            /*!< MPU CTRL: HFNMIENA Position */
-#define MPU_CTRL_HFNMIENA_Msk              (1UL << MPU_CTRL_HFNMIENA_Pos)                 /*!< MPU CTRL: HFNMIENA Mask */
-#define MPU_CTRL_ENABLE_Pos                 0U                                            /*!< MPU CTRL: ENABLE Position */
-#define MPU_CTRL_ENABLE_Msk                (1UL /*<< MPU_CTRL_ENABLE_Pos*/)               /*!< MPU CTRL: ENABLE Mask */
-/* MPU Region Number Register Definitions */
-#define MPU_RNR_REGION_Pos                  0U                                            /*!< MPU RNR: REGION Position */
-#define MPU_RNR_REGION_Msk                 (0xFFUL /*<< MPU_RNR_REGION_Pos*/)             /*!< MPU RNR: REGION Mask */
-/* MPU Region Base Address Register Definitions */
-#define MPU_RBAR_ADDR_Pos                   5U                                            /*!< MPU RBAR: ADDR Position */
-#define MPU_RBAR_ADDR_Msk                  (0x7FFFFFFUL << MPU_RBAR_ADDR_Pos)             /*!< MPU RBAR: ADDR Mask */
-#define MPU_RBAR_VALID_Pos                  4U                                            /*!< MPU RBAR: VALID Position */
-#define MPU_RBAR_VALID_Msk                 (1UL << MPU_RBAR_VALID_Pos)                    /*!< MPU RBAR: VALID Mask */
-#define MPU_RBAR_REGION_Pos                 0U                                            /*!< MPU RBAR: REGION Position */
-#define MPU_RBAR_REGION_Msk                (0xFUL /*<< MPU_RBAR_REGION_Pos*/)             /*!< MPU RBAR: REGION Mask */
-/* MPU Region Attribute and Size Register Definitions */
-#define MPU_RASR_ATTRS_Pos                 16U                                            /*!< MPU RASR: MPU Region Attribute field Position */
-#define MPU_RASR_ATTRS_Msk                 (0xFFFFUL << MPU_RASR_ATTRS_Pos)               /*!< MPU RASR: MPU Region Attribute field Mask */
-#define MPU_RASR_XN_Pos                    28U                                            /*!< MPU RASR: ATTRS.XN Position */
-#define MPU_RASR_XN_Msk                    (1UL << MPU_RASR_XN_Pos)                       /*!< MPU RASR: ATTRS.XN Mask */
-#define MPU_RASR_AP_Pos                    24U                                            /*!< MPU RASR: ATTRS.AP Position */
-#define MPU_RASR_AP_Msk                    (0x7UL << MPU_RASR_AP_Pos)                     /*!< MPU RASR: ATTRS.AP Mask */
-#define MPU_RASR_TEX_Pos                   19U                                            /*!< MPU RASR: ATTRS.TEX Position */
-#define MPU_RASR_TEX_Msk                   (0x7UL << MPU_RASR_TEX_Pos)                    /*!< MPU RASR: ATTRS.TEX Mask */
-#define MPU_RASR_S_Pos                     18U                                            /*!< MPU RASR: ATTRS.S Position */
-#define MPU_RASR_S_Msk                     (1UL << MPU_RASR_S_Pos)                        /*!< MPU RASR: ATTRS.S Mask */
-#define MPU_RASR_C_Pos                     17U                                            /*!< MPU RASR: ATTRS.C Position */
-#define MPU_RASR_C_Msk                     (1UL << MPU_RASR_C_Pos)                        /*!< MPU RASR: ATTRS.C Mask */
-#define MPU_RASR_B_Pos                     16U                                            /*!< MPU RASR: ATTRS.B Position */
-#define MPU_RASR_B_Msk                     (1UL << MPU_RASR_B_Pos)                        /*!< MPU RASR: ATTRS.B Mask */
-#define MPU_RASR_SRD_Pos                    8U                                            /*!< MPU RASR: Sub-Region Disable Position */
-#define MPU_RASR_SRD_Msk                   (0xFFUL << MPU_RASR_SRD_Pos)                   /*!< MPU RASR: Sub-Region Disable Mask */
-#define MPU_RASR_SIZE_Pos                   1U                                            /*!< MPU RASR: Region Size Field Position */
-#define MPU_RASR_SIZE_Msk                  (0x1FUL << MPU_RASR_SIZE_Pos)                  /*!< MPU RASR: Region Size Field Mask */
-#define MPU_RASR_ENABLE_Pos                 0U                                            /*!< MPU RASR: Region enable bit Position */
-#define MPU_RASR_ENABLE_Msk                (1UL /*<< MPU_RASR_ENABLE_Pos*/)               /*!< MPU RASR: Region enable bit Disable Mask */
-/*@} end of group CMSIS_MPU */
-#endif
-#if (__FPU_PRESENT == 1U)
-  \defgroup CMSIS_FPU     Floating Point Unit (FPU)
-  \brief    Type definitions for the Floating Point Unit (FPU)
-  \brief  Structure type to access the Floating Point Unit (FPU).
-typedef struct
-  __IOM uint32_t FPCCR;                  /*!< Offset: 0x004 (R/W)  Floating-Point Context Control Register */
-  __IOM uint32_t FPCAR;                  /*!< Offset: 0x008 (R/W)  Floating-Point Context Address Register */
-  __IOM uint32_t FPDSCR;                 /*!< Offset: 0x00C (R/W)  Floating-Point Default Status Control Register */
-  __IM  uint32_t MVFR0;                  /*!< Offset: 0x010 (R/ )  Media and FP Feature Register 0 */
-  __IM  uint32_t MVFR1;                  /*!< Offset: 0x014 (R/ )  Media and FP Feature Register 1 */
-  __IM  uint32_t MVFR2;                  /*!< Offset: 0x018 (R/ )  Media and FP Feature Register 2 */
-} FPU_Type;
-/* Floating-Point Context Control Register Definitions */
-#define FPU_FPCCR_ASPEN_Pos                31U                                            /*!< FPCCR: ASPEN bit Position */
-#define FPU_FPCCR_ASPEN_Msk                (1UL << FPU_FPCCR_ASPEN_Pos)                   /*!< FPCCR: ASPEN bit Mask */
-#define FPU_FPCCR_LSPEN_Pos                30U                                            /*!< FPCCR: LSPEN Position */
-#define FPU_FPCCR_LSPEN_Msk                (1UL << FPU_FPCCR_LSPEN_Pos)                   /*!< FPCCR: LSPEN bit Mask */
-#define FPU_FPCCR_MONRDY_Pos                8U                                            /*!< FPCCR: MONRDY Position */
-#define FPU_FPCCR_MONRDY_Msk               (1UL << FPU_FPCCR_MONRDY_Pos)                  /*!< FPCCR: MONRDY bit Mask */
-#define FPU_FPCCR_BFRDY_Pos                 6U                                            /*!< FPCCR: BFRDY Position */
-#define FPU_FPCCR_BFRDY_Msk                (1UL << FPU_FPCCR_BFRDY_Pos)                   /*!< FPCCR: BFRDY bit Mask */
-#define FPU_FPCCR_MMRDY_Pos                 5U                                            /*!< FPCCR: MMRDY Position */
-#define FPU_FPCCR_MMRDY_Msk                (1UL << FPU_FPCCR_MMRDY_Pos)                   /*!< FPCCR: MMRDY bit Mask */
-#define FPU_FPCCR_HFRDY_Pos                 4U                                            /*!< FPCCR: HFRDY Position */
-#define FPU_FPCCR_HFRDY_Msk                (1UL << FPU_FPCCR_HFRDY_Pos)                   /*!< FPCCR: HFRDY bit Mask */
-#define FPU_FPCCR_THREAD_Pos                3U                                            /*!< FPCCR: processor mode bit Position */
-#define FPU_FPCCR_THREAD_Msk               (1UL << FPU_FPCCR_THREAD_Pos)                  /*!< FPCCR: processor mode active bit Mask */
-#define FPU_FPCCR_USER_Pos                  1U                                            /*!< FPCCR: privilege level bit Position */
-#define FPU_FPCCR_USER_Msk                 (1UL << FPU_FPCCR_USER_Pos)                    /*!< FPCCR: privilege level bit Mask */
-#define FPU_FPCCR_LSPACT_Pos                0U                                            /*!< FPCCR: Lazy state preservation active bit Position */
-#define FPU_FPCCR_LSPACT_Msk               (1UL /*<< FPU_FPCCR_LSPACT_Pos*/)              /*!< FPCCR: Lazy state preservation active bit Mask */
-/* Floating-Point Context Address Register Definitions */
-#define FPU_FPCAR_ADDRESS_Pos               3U                                            /*!< FPCAR: ADDRESS bit Position */
-#define FPU_FPCAR_ADDRESS_Msk              (0x1FFFFFFFUL << FPU_FPCAR_ADDRESS_Pos)        /*!< FPCAR: ADDRESS bit Mask */
-/* Floating-Point Default Status Control Register Definitions */
-#define FPU_FPDSCR_AHP_Pos                 26U                                            /*!< FPDSCR: AHP bit Position */
-#define FPU_FPDSCR_AHP_Msk                 (1UL << FPU_FPDSCR_AHP_Pos)                    /*!< FPDSCR: AHP bit Mask */
-#define FPU_FPDSCR_DN_Pos                  25U                                            /*!< FPDSCR: DN bit Position */
-#define FPU_FPDSCR_DN_Msk                  (1UL << FPU_FPDSCR_DN_Pos)                     /*!< FPDSCR: DN bit Mask */
-#define FPU_FPDSCR_FZ_Pos                  24U                                            /*!< FPDSCR: FZ bit Position */
-#define FPU_FPDSCR_FZ_Msk                  (1UL << FPU_FPDSCR_FZ_Pos)                     /*!< FPDSCR: FZ bit Mask */
-#define FPU_FPDSCR_RMode_Pos               22U                                            /*!< FPDSCR: RMode bit Position */
-#define FPU_FPDSCR_RMode_Msk               (3UL << FPU_FPDSCR_RMode_Pos)                  /*!< FPDSCR: RMode bit Mask */
-/* Media and FP Feature Register 0 Definitions */
-#define FPU_MVFR0_FP_rounding_modes_Pos    28U                                            /*!< MVFR0: FP rounding modes bits Position */
-#define FPU_MVFR0_FP_rounding_modes_Msk    (0xFUL << FPU_MVFR0_FP_rounding_modes_Pos)     /*!< MVFR0: FP rounding modes bits Mask */
-#define FPU_MVFR0_Short_vectors_Pos        24U                                            /*!< MVFR0: Short vectors bits Position */
-#define FPU_MVFR0_Short_vectors_Msk        (0xFUL << FPU_MVFR0_Short_vectors_Pos)         /*!< MVFR0: Short vectors bits Mask */
-#define FPU_MVFR0_Square_root_Pos          20U                                            /*!< MVFR0: Square root bits Position */
-#define FPU_MVFR0_Square_root_Msk          (0xFUL << FPU_MVFR0_Square_root_Pos)           /*!< MVFR0: Square root bits Mask */
-#define FPU_MVFR0_Divide_Pos               16U                                            /*!< MVFR0: Divide bits Position */
-#define FPU_MVFR0_Divide_Msk               (0xFUL << FPU_MVFR0_Divide_Pos)                /*!< MVFR0: Divide bits Mask */
-#define FPU_MVFR0_FP_excep_trapping_Pos    12U                                            /*!< MVFR0: FP exception trapping bits Position */
-#define FPU_MVFR0_FP_excep_trapping_Msk    (0xFUL << FPU_MVFR0_FP_excep_trapping_Pos)     /*!< MVFR0: FP exception trapping bits Mask */
-#define FPU_MVFR0_Double_precision_Pos      8U                                            /*!< MVFR0: Double-precision bits Position */
-#define FPU_MVFR0_Double_precision_Msk     (0xFUL << FPU_MVFR0_Double_precision_Pos)      /*!< MVFR0: Double-precision bits Mask */
-#define FPU_MVFR0_Single_precision_Pos      4U                                            /*!< MVFR0: Single-precision bits Position */
-#define FPU_MVFR0_Single_precision_Msk     (0xFUL << FPU_MVFR0_Single_precision_Pos)      /*!< MVFR0: Single-precision bits Mask */
-#define FPU_MVFR0_A_SIMD_registers_Pos      0U                                            /*!< MVFR0: A_SIMD registers bits Position */
-#define FPU_MVFR0_A_SIMD_registers_Msk     (0xFUL /*<< FPU_MVFR0_A_SIMD_registers_Pos*/)  /*!< MVFR0: A_SIMD registers bits Mask */
-/* Media and FP Feature Register 1 Definitions */
-#define FPU_MVFR1_FP_fused_MAC_Pos         28U                                            /*!< MVFR1: FP fused MAC bits Position */
-#define FPU_MVFR1_FP_fused_MAC_Msk         (0xFUL << FPU_MVFR1_FP_fused_MAC_Pos)          /*!< MVFR1: FP fused MAC bits Mask */
-#define FPU_MVFR1_FP_HPFP_Pos              24U                                            /*!< MVFR1: FP HPFP bits Position */
-#define FPU_MVFR1_FP_HPFP_Msk              (0xFUL << FPU_MVFR1_FP_HPFP_Pos)               /*!< MVFR1: FP HPFP bits Mask */
-#define FPU_MVFR1_D_NaN_mode_Pos            4U                                            /*!< MVFR1: D_NaN mode bits Position */
-#define FPU_MVFR1_D_NaN_mode_Msk           (0xFUL << FPU_MVFR1_D_NaN_mode_Pos)            /*!< MVFR1: D_NaN mode bits Mask */
-#define FPU_MVFR1_FtZ_mode_Pos              0U                                            /*!< MVFR1: FtZ mode bits Position */
-#define FPU_MVFR1_FtZ_mode_Msk             (0xFUL /*<< FPU_MVFR1_FtZ_mode_Pos*/)          /*!< MVFR1: FtZ mode bits Mask */
-/* Media and FP Feature Register 2 Definitions */
-/*@} end of group CMSIS_FPU */
-#endif
-  \ingroup  CMSIS_core_register
-  \defgroup CMSIS_CoreDebug       Core Debug Registers (CoreDebug)
-  \brief    Type definitions for the Core Debug Registers
-  \brief  Structure type to access the Core Debug Register (CoreDebug).
-typedef struct
-  __IOM uint32_t DHCSR;                  /*!< Offset: 0x000 (R/W)  Debug Halting Control and Status Register */
-  __OM  uint32_t DCRSR;                  /*!< Offset: 0x004 ( /W)  Debug Core Register Selector Register */
-  __IOM uint32_t DCRDR;                  /*!< Offset: 0x008 (R/W)  Debug Core Register Data Register */
-  __IOM uint32_t DEMCR;                  /*!< Offset: 0x00C (R/W)  Debug Exception and Monitor Control Register */
-} CoreDebug_Type;
-/* Debug Halting Control and Status Register Definitions */
-#define CoreDebug_DHCSR_DBGKEY_Pos         16U                                            /*!< CoreDebug DHCSR: DBGKEY Position */
-#define CoreDebug_DHCSR_DBGKEY_Msk         (0xFFFFUL << CoreDebug_DHCSR_DBGKEY_Pos)       /*!< CoreDebug DHCSR: DBGKEY Mask */
-#define CoreDebug_DHCSR_S_RESET_ST_Pos     25U                                            /*!< CoreDebug DHCSR: S_RESET_ST Position */
-#define CoreDebug_DHCSR_S_RESET_ST_Msk     (1UL << CoreDebug_DHCSR_S_RESET_ST_Pos)        /*!< CoreDebug DHCSR: S_RESET_ST Mask */
-#define CoreDebug_DHCSR_S_RETIRE_ST_Pos    24U                                            /*!< CoreDebug DHCSR: S_RETIRE_ST Position */
-#define CoreDebug_DHCSR_S_RETIRE_ST_Msk    (1UL << CoreDebug_DHCSR_S_RETIRE_ST_Pos)       /*!< CoreDebug DHCSR: S_RETIRE_ST Mask */
-#define CoreDebug_DHCSR_S_LOCKUP_Pos       19U                                            /*!< CoreDebug DHCSR: S_LOCKUP Position */
-#define CoreDebug_DHCSR_S_LOCKUP_Msk       (1UL << CoreDebug_DHCSR_S_LOCKUP_Pos)          /*!< CoreDebug DHCSR: S_LOCKUP Mask */
-#define CoreDebug_DHCSR_S_SLEEP_Pos        18U                                            /*!< CoreDebug DHCSR: S_SLEEP Position */
-#define CoreDebug_DHCSR_S_SLEEP_Msk        (1UL << CoreDebug_DHCSR_S_SLEEP_Pos)           /*!< CoreDebug DHCSR: S_SLEEP Mask */
-#define CoreDebug_DHCSR_S_HALT_Pos         17U                                            /*!< CoreDebug DHCSR: S_HALT Position */
-#define CoreDebug_DHCSR_S_HALT_Msk         (1UL << CoreDebug_DHCSR_S_HALT_Pos)            /*!< CoreDebug DHCSR: S_HALT Mask */
-#define CoreDebug_DHCSR_S_REGRDY_Pos       16U                                            /*!< CoreDebug DHCSR: S_REGRDY Position */
-#define CoreDebug_DHCSR_S_REGRDY_Msk       (1UL << CoreDebug_DHCSR_S_REGRDY_Pos)          /*!< CoreDebug DHCSR: S_REGRDY Mask */
-#define CoreDebug_DHCSR_C_SNAPSTALL_Pos     5U                                            /*!< CoreDebug DHCSR: C_SNAPSTALL Position */
-#define CoreDebug_DHCSR_C_SNAPSTALL_Msk    (1UL << CoreDebug_DHCSR_C_SNAPSTALL_Pos)       /*!< CoreDebug DHCSR: C_SNAPSTALL Mask */
-#define CoreDebug_DHCSR_C_MASKINTS_Pos      3U                                            /*!< CoreDebug DHCSR: C_MASKINTS Position */
-#define CoreDebug_DHCSR_C_MASKINTS_Msk     (1UL << CoreDebug_DHCSR_C_MASKINTS_Pos)        /*!< CoreDebug DHCSR: C_MASKINTS Mask */
-#define CoreDebug_DHCSR_C_STEP_Pos          2U                                            /*!< CoreDebug DHCSR: C_STEP Position */
-#define CoreDebug_DHCSR_C_STEP_Msk         (1UL << CoreDebug_DHCSR_C_STEP_Pos)            /*!< CoreDebug DHCSR: C_STEP Mask */
-#define CoreDebug_DHCSR_C_HALT_Pos          1U                                            /*!< CoreDebug DHCSR: C_HALT Position */
-#define CoreDebug_DHCSR_C_HALT_Msk         (1UL << CoreDebug_DHCSR_C_HALT_Pos)            /*!< CoreDebug DHCSR: C_HALT Mask */
-#define CoreDebug_DHCSR_C_DEBUGEN_Pos       0U                                            /*!< CoreDebug DHCSR: C_DEBUGEN Position */
-#define CoreDebug_DHCSR_C_DEBUGEN_Msk      (1UL /*<< CoreDebug_DHCSR_C_DEBUGEN_Pos*/)     /*!< CoreDebug DHCSR: C_DEBUGEN Mask */
-/* Debug Core Register Selector Register Definitions */
-#define CoreDebug_DCRSR_REGWnR_Pos         16U                                            /*!< CoreDebug DCRSR: REGWnR Position */
-#define CoreDebug_DCRSR_REGWnR_Msk         (1UL << CoreDebug_DCRSR_REGWnR_Pos)            /*!< CoreDebug DCRSR: REGWnR Mask */
-#define CoreDebug_DCRSR_REGSEL_Pos          0U                                            /*!< CoreDebug DCRSR: REGSEL Position */
-#define CoreDebug_DCRSR_REGSEL_Msk         (0x1FUL /*<< CoreDebug_DCRSR_REGSEL_Pos*/)     /*!< CoreDebug DCRSR: REGSEL Mask */
-/* Debug Exception and Monitor Control Register Definitions */
-#define CoreDebug_DEMCR_TRCENA_Pos         24U                                            /*!< CoreDebug DEMCR: TRCENA Position */
-#define CoreDebug_DEMCR_TRCENA_Msk         (1UL << CoreDebug_DEMCR_TRCENA_Pos)            /*!< CoreDebug DEMCR: TRCENA Mask */
-#define CoreDebug_DEMCR_MON_REQ_Pos        19U                                            /*!< CoreDebug DEMCR: MON_REQ Position */
-#define CoreDebug_DEMCR_MON_REQ_Msk        (1UL << CoreDebug_DEMCR_MON_REQ_Pos)           /*!< CoreDebug DEMCR: MON_REQ Mask */
-#define CoreDebug_DEMCR_MON_STEP_Pos       18U                                            /*!< CoreDebug DEMCR: MON_STEP Position */
-#define CoreDebug_DEMCR_MON_STEP_Msk       (1UL << CoreDebug_DEMCR_MON_STEP_Pos)          /*!< CoreDebug DEMCR: MON_STEP Mask */
-#define CoreDebug_DEMCR_MON_PEND_Pos       17U                                            /*!< CoreDebug DEMCR: MON_PEND Position */
-#define CoreDebug_DEMCR_MON_PEND_Msk       (1UL << CoreDebug_DEMCR_MON_PEND_Pos)          /*!< CoreDebug DEMCR: MON_PEND Mask */
-#define CoreDebug_DEMCR_MON_EN_Pos         16U                                            /*!< CoreDebug DEMCR: MON_EN Position */
-#define CoreDebug_DEMCR_MON_EN_Msk         (1UL << CoreDebug_DEMCR_MON_EN_Pos)            /*!< CoreDebug DEMCR: MON_EN Mask */
-#define CoreDebug_DEMCR_VC_HARDERR_Pos     10U                                            /*!< CoreDebug DEMCR: VC_HARDERR Position */
-#define CoreDebug_DEMCR_VC_HARDERR_Msk     (1UL << CoreDebug_DEMCR_VC_HARDERR_Pos)        /*!< CoreDebug DEMCR: VC_HARDERR Mask */
-#define CoreDebug_DEMCR_VC_INTERR_Pos       9U                                            /*!< CoreDebug DEMCR: VC_INTERR Position */
-#define CoreDebug_DEMCR_VC_INTERR_Msk      (1UL << CoreDebug_DEMCR_VC_INTERR_Pos)         /*!< CoreDebug DEMCR: VC_INTERR Mask */
-#define CoreDebug_DEMCR_VC_BUSERR_Pos       8U                                            /*!< CoreDebug DEMCR: VC_BUSERR Position */
-#define CoreDebug_DEMCR_VC_BUSERR_Msk      (1UL << CoreDebug_DEMCR_VC_BUSERR_Pos)         /*!< CoreDebug DEMCR: VC_BUSERR Mask */
-#define CoreDebug_DEMCR_VC_STATERR_Pos      7U                                            /*!< CoreDebug DEMCR: VC_STATERR Position */
-#define CoreDebug_DEMCR_VC_STATERR_Msk     (1UL << CoreDebug_DEMCR_VC_STATERR_Pos)        /*!< CoreDebug DEMCR: VC_STATERR Mask */
-#define CoreDebug_DEMCR_VC_CHKERR_Pos       6U                                            /*!< CoreDebug DEMCR: VC_CHKERR Position */
-#define CoreDebug_DEMCR_VC_CHKERR_Msk      (1UL << CoreDebug_DEMCR_VC_CHKERR_Pos)         /*!< CoreDebug DEMCR: VC_CHKERR Mask */
-#define CoreDebug_DEMCR_VC_NOCPERR_Pos      5U                                            /*!< CoreDebug DEMCR: VC_NOCPERR Position */
-#define CoreDebug_DEMCR_VC_NOCPERR_Msk     (1UL << CoreDebug_DEMCR_VC_NOCPERR_Pos)        /*!< CoreDebug DEMCR: VC_NOCPERR Mask */
-#define CoreDebug_DEMCR_VC_MMERR_Pos        4U                                            /*!< CoreDebug DEMCR: VC_MMERR Position */
-#define CoreDebug_DEMCR_VC_MMERR_Msk       (1UL << CoreDebug_DEMCR_VC_MMERR_Pos)          /*!< CoreDebug DEMCR: VC_MMERR Mask */
-#define CoreDebug_DEMCR_VC_CORERESET_Pos    0U                                            /*!< CoreDebug DEMCR: VC_CORERESET Position */
-#define CoreDebug_DEMCR_VC_CORERESET_Msk   (1UL /*<< CoreDebug_DEMCR_VC_CORERESET_Pos*/)  /*!< CoreDebug DEMCR: VC_CORERESET Mask */
-/*@} end of group CMSIS_CoreDebug */
-  \defgroup   CMSIS_core_bitfield     Core register bit field macros
-  \brief      Macros for use with bit field definitions (xxx_Pos, xxx_Msk).
-  \brief   Mask and shift a bit field value for use in a register bit range.
-  \param[in] field  Name of the register bit field.
-  \param[in] value  Value of the bit field.
-  \return           Masked and shifted value.
-#define _VAL2FLD(field, value)    ((value << field ## _Pos) & field ## _Msk)
-  \brief     Mask and shift a register value to extract a bit filed value.
-  \param[in] value  Value of register.
-  \return           Masked and shifted bit field value.
-#define _FLD2VAL(field, value)    ((value & field ## _Msk) >> field ## _Pos)
-/*@} end of group CMSIS_core_bitfield */
-  \defgroup   CMSIS_core_base     Core Definitions
-  \brief      Definitions for base addresses, unions, and structures.
-/* Memory mapping of Cortex-M4 Hardware */
-#define SCS_BASE            (0xE000E000UL)                            /*!< System Control Space Base Address */
-#define ITM_BASE            (0xE0000000UL)                            /*!< ITM Base Address */
-#define DWT_BASE            (0xE0001000UL)                            /*!< DWT Base Address */
-#define TPI_BASE            (0xE0040000UL)                            /*!< TPI Base Address */
-#define CoreDebug_BASE      (0xE000EDF0UL)                            /*!< Core Debug Base Address */
-#define SysTick_BASE        (SCS_BASE +  0x0010UL)                    /*!< SysTick Base Address */
-#define NVIC_BASE           (SCS_BASE +  0x0100UL)                    /*!< NVIC Base Address */
-#define SCB_BASE            (SCS_BASE +  0x0D00UL)                    /*!< System Control Block Base Address */
-#define SCnSCB              ((SCnSCB_Type    *)     SCS_BASE      )   /*!< System control Register not in SCB */
-#define SCB                 ((SCB_Type       *)     SCB_BASE      )   /*!< SCB configuration struct */
-#define SysTick             ((SysTick_Type   *)     SysTick_BASE  )   /*!< SysTick configuration struct */
-#define NVIC                ((NVIC_Type      *)     NVIC_BASE     )   /*!< NVIC configuration struct */
-#define ITM                 ((ITM_Type       *)     ITM_BASE      )   /*!< ITM configuration struct */
-#define DWT                 ((DWT_Type       *)     DWT_BASE      )   /*!< DWT configuration struct */
-#define TPI                 ((TPI_Type       *)     TPI_BASE      )   /*!< TPI configuration struct */
-#define CoreDebug           ((CoreDebug_Type *)     CoreDebug_BASE)   /*!< Core Debug configuration struct */
-  #define MPU_BASE          (SCS_BASE +  0x0D90UL)                    /*!< Memory Protection Unit */
-  #define MPU               ((MPU_Type       *)     MPU_BASE      )   /*!< Memory Protection Unit */
-#endif
-  #define FPU_BASE          (SCS_BASE +  0x0F30UL)                    /*!< Floating Point Unit */
-  #define FPU               ((FPU_Type       *)     FPU_BASE      )   /*!< Floating Point Unit */
-#endif
- *                Hardware Abstraction Layer
-  Core Function Interface contains:
-  - Core NVIC Functions
-  - Core SysTick Functions
-  - Core Debug Functions
-  - Core Register Access Functions
-  \defgroup CMSIS_Core_FunctionInterface Functions and Instructions Reference
-  \ingroup CMSIS
-/* ##########################   NVIC functions  #################################### */
-  \ingroup  CMSIS_Core_FunctionInterface
-  \defgroup CMSIS_Core_NVICFunctions NVIC Functions
-  \brief    Functions that manage interrupts and exceptions via the NVIC.
-  \brief   Set Priority Grouping
-  \details Sets the priority grouping field using the required unlock sequence.
-           The parameter PriorityGroup is assigned to the field SCB->AIRCR [10:8] PRIGROUP field.
-           Only values from 0..7 are used.
-           In case of a conflict between priority grouping and available
-           priority bits (__NVIC_PRIO_BITS), the smallest possible priority group is set.
-  \param [in]      PriorityGroup  Priority grouping field.
-__STATIC_INLINE void NVIC_SetPriorityGrouping(uint32_t PriorityGroup)
-  uint32_t reg_value;
-  uint32_t PriorityGroupTmp = (PriorityGroup & (uint32_t)0x07UL);             /* only values 0..7 are used          */
-  reg_value  =  SCB->AIRCR;                                                   /* read old register configuration    */
-  reg_value &= ~((uint32_t)(SCB_AIRCR_VECTKEY_Msk | SCB_AIRCR_PRIGROUP_Msk)); /* clear bits to change               */
-  reg_value  =  (reg_value                                   |
-                ((uint32_t)0x5FAUL << SCB_AIRCR_VECTKEY_Pos) |
-                (PriorityGroupTmp << 8U)                      );              /* Insert write key and priorty group */
-  SCB->AIRCR =  reg_value;
-  \brief   Get Priority Grouping
-  \details Reads the priority grouping field from the NVIC Interrupt Controller.
-  \return                Priority grouping field (SCB->AIRCR [10:8] PRIGROUP field).
-__STATIC_INLINE uint32_t NVIC_GetPriorityGrouping(void)
-  return ((uint32_t)((SCB->AIRCR & SCB_AIRCR_PRIGROUP_Msk) >> SCB_AIRCR_PRIGROUP_Pos));
-  \brief   Enable External Interrupt
-  \details Enables a device-specific interrupt in the NVIC interrupt controller.
-  \param [in]      IRQn  External interrupt number. Value cannot be negative.
-__STATIC_INLINE void NVIC_EnableIRQ(IRQn_Type IRQn)
-  NVIC->ISER[(((uint32_t)(int32_t)IRQn) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)(int32_t)IRQn) & 0x1FUL));
-  \brief   Disable External Interrupt
-  \details Disables a device-specific interrupt in the NVIC interrupt controller.
-__STATIC_INLINE void NVIC_DisableIRQ(IRQn_Type IRQn)
-  NVIC->ICER[(((uint32_t)(int32_t)IRQn) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)(int32_t)IRQn) & 0x1FUL));
-  \brief   Get Pending Interrupt
-  \details Reads the pending register in the NVIC and returns the pending bit for the specified interrupt.
-  \param [in]      IRQn  Interrupt number.
-  \return             0  Interrupt status is not pending.
-  \return             1  Interrupt status is pending.
-__STATIC_INLINE uint32_t NVIC_GetPendingIRQ(IRQn_Type IRQn)
-  return((uint32_t)(((NVIC->ISPR[(((uint32_t)(int32_t)IRQn) >> 5UL)] & (1UL << (((uint32_t)(int32_t)IRQn) & 0x1FUL))) != 0UL) ? 1UL : 0UL));
-  \brief   Set Pending Interrupt
-  \details Sets the pending bit of an external interrupt.
-  \param [in]      IRQn  Interrupt number. Value cannot be negative.
-__STATIC_INLINE void NVIC_SetPendingIRQ(IRQn_Type IRQn)
-  NVIC->ISPR[(((uint32_t)(int32_t)IRQn) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)(int32_t)IRQn) & 0x1FUL));
-  \brief   Clear Pending Interrupt
-  \details Clears the pending bit of an external interrupt.
-__STATIC_INLINE void NVIC_ClearPendingIRQ(IRQn_Type IRQn)
-  NVIC->ICPR[(((uint32_t)(int32_t)IRQn) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)(int32_t)IRQn) & 0x1FUL));
-  \brief   Get Active Interrupt
-  \details Reads the active register in NVIC and returns the active bit.
-  \return             0  Interrupt status is not active.
-  \return             1  Interrupt status is active.
-__STATIC_INLINE uint32_t NVIC_GetActive(IRQn_Type IRQn)
-  return((uint32_t)(((NVIC->IABR[(((uint32_t)(int32_t)IRQn) >> 5UL)] & (1UL << (((uint32_t)(int32_t)IRQn) & 0x1FUL))) != 0UL) ? 1UL : 0UL));
-  \brief   Set Interrupt Priority
-  \details Sets the priority of an interrupt.
-  \note    The priority cannot be set for every core interrupt.
-  \param [in]  priority  Priority to set.
-__STATIC_INLINE void NVIC_SetPriority(IRQn_Type IRQn, uint32_t priority)
-  if ((int32_t)(IRQn) < 0)
-    SCB->SHPR[(((uint32_t)(int32_t)IRQn) & 0xFUL)-4UL] = (uint8_t)((priority << (8U - __NVIC_PRIO_BITS)) & (uint32_t)0xFFUL);
-  else
-    NVIC->IP[((uint32_t)(int32_t)IRQn)]                = (uint8_t)((priority << (8U - __NVIC_PRIO_BITS)) & (uint32_t)0xFFUL);
-  \brief   Get Interrupt Priority
-  \details Reads the priority of an interrupt.
-           The interrupt number can be positive to specify an external (device specific) interrupt,
-           or negative to specify an internal (core) interrupt.
-  \return             Interrupt Priority.
-                      Value is aligned automatically to the implemented priority bits of the microcontroller.
-__STATIC_INLINE uint32_t NVIC_GetPriority(IRQn_Type IRQn)
-    return(((uint32_t)SCB->SHPR[(((uint32_t)(int32_t)IRQn) & 0xFUL)-4UL] >> (8U - __NVIC_PRIO_BITS)));
-  else
-    return(((uint32_t)NVIC->IP[((uint32_t)(int32_t)IRQn)]                >> (8U - __NVIC_PRIO_BITS)));
-  \brief   Encode Priority
-  \details Encodes the priority for an interrupt with the given priority group,
-           preemptive priority value, and subpriority value.
-  \param [in]     PriorityGroup  Used priority group.
-  \param [in]   PreemptPriority  Preemptive priority value (starting from 0).
-  \param [in]       SubPriority  Subpriority value (starting from 0).
-  \return                        Encoded priority. Value can be used in the function \ref NVIC_SetPriority().
-__STATIC_INLINE uint32_t NVIC_EncodePriority (uint32_t PriorityGroup, uint32_t PreemptPriority, uint32_t SubPriority)
-  uint32_t PreemptPriorityBits;
-  uint32_t SubPriorityBits;
-  PreemptPriorityBits = ((7UL - PriorityGroupTmp) > (uint32_t)(__NVIC_PRIO_BITS)) ? (uint32_t)(__NVIC_PRIO_BITS) : (uint32_t)(7UL - PriorityGroupTmp);
-  SubPriorityBits     = ((PriorityGroupTmp + (uint32_t)(__NVIC_PRIO_BITS)) < (uint32_t)7UL) ? (uint32_t)0UL : (uint32_t)((PriorityGroupTmp - 7UL) + (uint32_t)(__NVIC_PRIO_BITS));
-  return (
-           ((PreemptPriority & (uint32_t)((1UL << (PreemptPriorityBits)) - 1UL)) << SubPriorityBits) |
-           ((SubPriority     & (uint32_t)((1UL << (SubPriorityBits    )) - 1UL)))
-  \brief   Decode Priority
-  \details Decodes an interrupt priority value with a given priority group to
-           preemptive priority value and subpriority value.
-           priority bits (__NVIC_PRIO_BITS) the smallest possible priority group is set.
-  \param [in]         Priority   Priority value, which can be retrieved with the function \ref NVIC_GetPriority().
-  \param [out] pPreemptPriority  Preemptive priority value (starting from 0).
-  \param [out]     pSubPriority  Subpriority value (starting from 0).
-__STATIC_INLINE void NVIC_DecodePriority (uint32_t Priority, uint32_t PriorityGroup, uint32_t* const pPreemptPriority, uint32_t* const pSubPriority)
-  *pPreemptPriority = (Priority >> SubPriorityBits) & (uint32_t)((1UL << (PreemptPriorityBits)) - 1UL);
-  *pSubPriority     = (Priority                   ) & (uint32_t)((1UL << (SubPriorityBits    )) - 1UL);
-  \brief   System Reset
-  \details Initiates a system reset request to reset the MCU.
-__STATIC_INLINE void NVIC_SystemReset(void)
-  __DSB();                                                          /* Ensure all outstanding memory accesses included
-        buffered write are completed before reset */
-  SCB->AIRCR  = (uint32_t)((0x5FAUL << SCB_AIRCR_VECTKEY_Pos)    |
-                           (SCB->AIRCR & SCB_AIRCR_PRIGROUP_Msk) |
-                            SCB_AIRCR_SYSRESETREQ_Msk    );         /* Keep priority group unchanged */
-  __DSB();                                                          /* Ensure completion of memory access */
-  for(;;)                                                           /* wait until reset */
-    __NOP();
-/*@} end of CMSIS_Core_NVICFunctions */
-/* ##########################  FPU functions  #################################### */
-  \defgroup CMSIS_Core_FpuFunctions FPU Functions
-  \brief    Function that provides FPU type.
-  \brief   get FPU type
-  \details returns the FPU type
-  \returns
-   - \b  0: No FPU
-   - \b  1: Single precision FPU
-   - \b  2: Double + Single precision FPU
-__STATIC_INLINE uint32_t SCB_GetFPUType(void)
-  uint32_t mvfr0;
-  mvfr0 = SCB->MVFR0;
-  if        ((mvfr0 & 0x00000FF0UL) == 0x220UL)
-    return 2UL;           /* Double + Single precision FPU */
-  else if ((mvfr0 & 0x00000FF0UL) == 0x020UL)
-    return 1UL;           /* Single precision FPU */
-  else
-    return 0UL;           /* No FPU */
-/*@} end of CMSIS_Core_FpuFunctions */
-/* ##########################  Cache functions  #################################### */
-  \defgroup CMSIS_Core_CacheFunctions Cache Functions
-  \brief    Functions that configure Instruction and Data cache.
-/* Cache Size ID Register Macros */
-#define CCSIDR_WAYS(x)         (((x) & SCB_CCSIDR_ASSOCIATIVITY_Msk) >> SCB_CCSIDR_ASSOCIATIVITY_Pos)
-#define CCSIDR_SETS(x)         (((x) & SCB_CCSIDR_NUMSETS_Msk      ) >> SCB_CCSIDR_NUMSETS_Pos      )
-  \brief   Enable I-Cache
-  \details Turns on I-Cache
-__STATIC_INLINE void SCB_EnableICache (void)
-  #if (__ICACHE_PRESENT == 1U)
-    __DSB();
-    __ISB();
-    SCB->ICIALLU = 0UL;                     /* invalidate I-Cache */
-    SCB->CCR |=  (uint32_t)SCB_CCR_IC_Msk;  /* enable I-Cache */
-    __DSB();
-    __ISB();
-  #endif
-  \brief   Disable I-Cache
-  \details Turns off I-Cache
-__STATIC_INLINE void SCB_DisableICache (void)
-    __DSB();
-    __ISB();
-    SCB->CCR &= ~(uint32_t)SCB_CCR_IC_Msk;  /* disable I-Cache */
-    __DSB();
-    __ISB();
-  #endif
-  \brief   Invalidate I-Cache
-  \details Invalidates I-Cache
-__STATIC_INLINE void SCB_InvalidateICache (void)
-    __DSB();
-    __ISB();
-    __DSB();
-    __ISB();
-  #endif
-  \brief   Enable D-Cache
-  \details Turns on D-Cache
-__STATIC_INLINE void SCB_EnableDCache (void)
-  #if (__DCACHE_PRESENT == 1U)
-    uint32_t ccsidr;
-    uint32_t sets;
-    uint32_t ways;
-    SCB->CSSELR = (0U << 1U) | 0U;          /* Level 1 data cache */
-    __DSB();
-    ccsidr = SCB->CCSIDR;
-                                            /* invalidate D-Cache */
-    sets = (uint32_t)(CCSIDR_SETS(ccsidr));
-    do {
-      ways = (uint32_t)(CCSIDR_WAYS(ccsidr));
-      do {
-        SCB->DCISW = (((sets << SCB_DCISW_SET_Pos) & SCB_DCISW_SET_Msk) |
-                      ((ways << SCB_DCISW_WAY_Pos) & SCB_DCISW_WAY_Msk)  );
-        #if defined ( __CC_ARM )
-          __schedule_barrier();
-        #endif
-      } while (ways--);
-    } while(sets--);
-    __DSB();
-    SCB->CCR |=  (uint32_t)SCB_CCR_DC_Msk;  /* enable D-Cache */
-    __DSB();
-    __ISB();
-  #endif
-  \brief   Disable D-Cache
-  \details Turns off D-Cache
-__STATIC_INLINE void SCB_DisableDCache (void)
-    uint32_t ccsidr;
-    uint32_t sets;
-    uint32_t ways;
-    __DSB();
-    SCB->CCR &= ~(uint32_t)SCB_CCR_DC_Msk;  /* disable D-Cache */
-                                            /* clean & invalidate D-Cache */
-    do {
-      do {
-        SCB->DCCISW = (((sets << SCB_DCCISW_SET_Pos) & SCB_DCCISW_SET_Msk) |
-                       ((ways << SCB_DCCISW_WAY_Pos) & SCB_DCCISW_WAY_Msk)  );
-        #endif
-      } while (ways--);
-    } while(sets--);
-    __DSB();
-    __ISB();
-  #endif
-  \brief   Invalidate D-Cache
-  \details Invalidates D-Cache
-__STATIC_INLINE void SCB_InvalidateDCache (void)
-    uint32_t ccsidr;
-    uint32_t sets;
-    uint32_t ways;
-    __DSB();
-    do {
-      do {
-        #endif
-      } while (ways--);
-    } while(sets--);
-    __DSB();
-    __ISB();
-  #endif
-  \brief   Clean D-Cache
-  \details Cleans D-Cache
-__STATIC_INLINE void SCB_CleanDCache (void)
-    uint32_t ccsidr;
-    uint32_t sets;
-    uint32_t ways;
-    __DSB();
-                                            /* clean D-Cache */
-    do {
-      do {
-        SCB->DCCSW = (((sets << SCB_DCCSW_SET_Pos) & SCB_DCCSW_SET_Msk) |
-                      ((ways << SCB_DCCSW_WAY_Pos) & SCB_DCCSW_WAY_Msk)  );
-        #endif
-      } while (ways--);
-    } while(sets--);
-    __DSB();
-    __ISB();
-  #endif
-  \brief   Clean & Invalidate D-Cache
-  \details Cleans and Invalidates D-Cache
-__STATIC_INLINE void SCB_CleanInvalidateDCache (void)
-    uint32_t ccsidr;
-    uint32_t sets;
-    uint32_t ways;
-    __DSB();
-    do {
-      do {
-        #endif
-      } while (ways--);
-    } while(sets--);
-    __DSB();
-    __ISB();
-  #endif
-  \brief   D-Cache Invalidate by address
-  \details Invalidates D-Cache for the given address
-  \param[in]   addr    address (aligned to 32-byte boundary)
-  \param[in]   dsize   size of memory block (in number of bytes)
-__STATIC_INLINE void SCB_InvalidateDCache_by_Addr (uint32_t *addr, int32_t dsize)
-     int32_t op_size = dsize;
-    uint32_t op_addr = (uint32_t)addr;
-     int32_t linesize = 32U;                /* in Cortex-M7 size of cache line is fixed to 8 words (32 bytes) */
-    __DSB();
-    while (op_size > 0) {
-      SCB->DCIMVAC = op_addr;
-      op_addr += linesize;
-      op_size -= linesize;
-    __DSB();
-    __ISB();
-  #endif
-  \brief   D-Cache Clean by address
-  \details Cleans D-Cache for the given address
-__STATIC_INLINE void SCB_CleanDCache_by_Addr (uint32_t *addr, int32_t dsize)
-  #if (__DCACHE_PRESENT == 1)
-    uint32_t op_addr = (uint32_t) addr;
-    __DSB();
-      SCB->DCCMVAC = op_addr;
-    __DSB();
-    __ISB();
-  #endif
-  \brief   D-Cache Clean and Invalidate by address
-  \details Cleans and invalidates D_Cache for the given address
-__STATIC_INLINE void SCB_CleanInvalidateDCache_by_Addr (uint32_t *addr, int32_t dsize)
-    __DSB();
-      SCB->DCCIMVAC = op_addr;
-    __DSB();
-    __ISB();
-  #endif
-/*@} end of CMSIS_Core_CacheFunctions */
-/* ##################################    SysTick function  ############################################ */
-  \defgroup CMSIS_Core_SysTickFunctions SysTick Functions
-  \brief    Functions that configure the System.
-#if (__Vendor_SysTickConfig == 0U)
-  \brief   System Tick Configuration
-  \details Initializes the System Timer and its interrupt, and starts the System Tick Timer.
-           Counter is in free running mode to generate periodic interrupts.
-  \param [in]  ticks  Number of ticks between two interrupts.
-  \return          0  Function succeeded.
-  \return          1  Function failed.
-  \note    When the variable <b>__Vendor_SysTickConfig</b> is set to 1, then the
-           function <b>SysTick_Config</b> is not included. In this case, the file <b><i>device</i>.h</b>
-           must contain a vendor-specific implementation of this function.
-__STATIC_INLINE uint32_t SysTick_Config(uint32_t ticks)
-  if ((ticks - 1UL) > SysTick_LOAD_RELOAD_Msk)
-    return (1UL);                                                   /* Reload value impossible */
-  SysTick->LOAD  = (uint32_t)(ticks - 1UL);                         /* set reload register */
-  NVIC_SetPriority (SysTick_IRQn, (1UL << __NVIC_PRIO_BITS) - 1UL); /* set Priority for Systick Interrupt */
-  SysTick->VAL   = 0UL;                                             /* Load the SysTick Counter Value */
-  SysTick->CTRL  = SysTick_CTRL_CLKSOURCE_Msk |
-                   SysTick_CTRL_TICKINT_Msk   |
-                   SysTick_CTRL_ENABLE_Msk;                         /* Enable SysTick IRQ and SysTick Timer */
-  return (0UL);                                                     /* Function successful */
-#endif
-/*@} end of CMSIS_Core_SysTickFunctions */
-/* ##################################### Debug In/Output function ########################################### */
-  \defgroup CMSIS_core_DebugFunctions ITM Functions
-  \brief    Functions that access the ITM debug interface.
-extern volatile int32_t ITM_RxBuffer;                    /*!< External variable to receive characters. */
-#define                 ITM_RXBUFFER_EMPTY   0x5AA55AA5U /*!< Value identifying \ref ITM_RxBuffer is ready for next character. */
-  \brief   ITM Send Character
-  \details Transmits a character via the ITM channel 0, and
-           \li Just returns when no debugger is connected that has booked the output.
-           \li Is blocking when a debugger is connected, but the previous character sent has not been transmitted.
-  \param [in]     ch  Character to transmit.
-  \returns            Character to transmit.
-__STATIC_INLINE uint32_t ITM_SendChar (uint32_t ch)
-  if (((ITM->TCR & ITM_TCR_ITMENA_Msk) != 0UL) &&      /* ITM enabled */
-      ((ITM->TER & 1UL               ) != 0UL)   )     /* ITM Port #0 enabled */
-    while (ITM->PORT[0U].u32 == 0UL)
-      __NOP();
-    ITM->PORT[0U].u8 = (uint8_t)ch;
-  return (ch);
-  \brief   ITM Receive Character
-  \details Inputs a character via the external variable \ref ITM_RxBuffer.
-  \return             Received character.
-  \return         -1  No character pending.
-__STATIC_INLINE int32_t ITM_ReceiveChar (void)
-  int32_t ch = -1;                           /* no character available */
-  if (ITM_RxBuffer != ITM_RXBUFFER_EMPTY)
-    ch = ITM_RxBuffer;
-    ITM_RxBuffer = ITM_RXBUFFER_EMPTY;       /* ready for next character */
-  return (ch);
-  \brief   ITM Check Character
-  \details Checks whether a character is pending for reading in the variable \ref ITM_RxBuffer.
-  \return          0  No character available.
-  \return          1  Character available.
-__STATIC_INLINE int32_t ITM_CheckChar (void)
-  if (ITM_RxBuffer == ITM_RXBUFFER_EMPTY)
-    return (0);                              /* no character available */
-  else
-    return (1);                              /*    character available */
-/*@} end of CMSIS_core_DebugFunctions */
-#ifdef __cplusplus
-#endif
-#endif /* __CORE_CM7_H_DEPENDANT */
-#endif /* __CMSIS_GENERIC */
+ * @file     core_cm7.h
+ * @brief    CMSIS Cortex-M7 Core Peripheral Access Layer Header File
+ * @version  V5.2.0
+ * @date     04. April 2023
+ * Copyright (c) 2009-2023 Arm Limited. All rights reserved.
+ * SPDX-License-Identifier: Apache-2.0
+ * Licensed under the Apache License, Version 2.0 (the License); you may
+ * not use this file except in compliance with the License.
+ * You may obtain a copy of the License at
+ * www.apache.org/licenses/LICENSE-2.0
+ * Unless required by applicable law or agreed to in writing, software
+ * distributed under the License is distributed on an AS IS BASIS, WITHOUT
+ * WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+ * See the License for the specific language governing permissions and
+ * limitations under the License.
+#if   defined ( __ICCARM__ )
+  #pragma system_include         /* treat file as system include file for MISRA check */
+#elif defined (__clang__)
+  #pragma clang system_header   /* treat file as system include file */
+#endif
+#ifndef __CORE_CM7_H_GENERIC
+#define __CORE_CM7_H_GENERIC
+#include <stdint.h>
+#ifdef __cplusplus
+ extern "C" {
+#endif
+  \page CMSIS_MISRA_Exceptions  MISRA-C:2004 Compliance Exceptions
+  CMSIS violates the following MISRA-C:2004 rules:
+   \li Required Rule 8.5, object/function definition in header file.<br>
+     Function definitions in header files are used to allow 'inlining'.
+   \li Required Rule 18.4, declaration of union type or object of union type: '{...}'.<br>
+     Unions are used for effective representation of core registers.
+   \li Advisory Rule 19.7, Function-like macro defined.<br>
+     Function-like macros are used to allow more efficient code.
+ *                 CMSIS definitions
+  \ingroup Cortex_M7
+#include "cmsis_version.h"
+/* CMSIS CM7 definitions */
+#define __CM7_CMSIS_VERSION_MAIN  (__CM_CMSIS_VERSION_MAIN)                  /*!< \deprecated [31:16] CMSIS HAL main version */
+#define __CM7_CMSIS_VERSION_SUB   ( __CM_CMSIS_VERSION_SUB)                  /*!< \deprecated [15:0]  CMSIS HAL sub version */
+#define __CM7_CMSIS_VERSION       ((__CM7_CMSIS_VERSION_MAIN << 16U) | \
+                                    __CM7_CMSIS_VERSION_SUB           )      /*!< \deprecated CMSIS HAL version number */
+#define __CORTEX_M                (7U)                                       /*!< Cortex-M Core */
+/** __FPU_USED indicates whether an FPU is used or not.
+    For this, __FPU_PRESENT has to be checked prior to making use of FPU specific registers and functions.
+#if defined ( __CC_ARM )
+  #if defined __TARGET_FPU_VFP
+    #if defined (__FPU_PRESENT) && (__FPU_PRESENT == 1U)
+      #define __FPU_USED       1U
+    #else
+      #error "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)"
+      #define __FPU_USED       0U
+    #endif
+  #else
+  #endif
+#elif defined (__ARMCC_VERSION) && (__ARMCC_VERSION >= 6010050)
+  #if defined __ARM_FP
+    #else
+      #warning "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)"
+    #endif
+  #else
+  #endif
+#elif defined (__ti__)
+  #if defined (__ARM_FP)
+    #else
+    #endif
+  #else
+  #endif
+#elif defined ( __GNUC__ )
+  #if defined (__VFP_FP__) && !defined(__SOFTFP__)
+    #else
+    #endif
+  #else
+  #endif
+#elif defined ( __ICCARM__ )
+  #if defined __ARMVFP__
+    #else
+    #endif
+  #else
+  #endif
+#elif defined ( __TI_ARM__ )
+  #if defined __TI_VFP_SUPPORT__
+    #else
+    #endif
+  #else
+  #endif
+#elif defined ( __TASKING__ )
+  #if defined __FPU_VFP__
+    #else
+    #endif
+  #else
+  #endif
+#elif defined ( __CSMC__ )
+  #if ( __CSMC__ & 0x400U)
+    #else
+    #endif
+  #else
+  #endif
+#endif
+#include "cmsis_compiler.h"               /* CMSIS compiler specific defines */
+#ifdef __cplusplus
+#endif
+#endif /* __CORE_CM7_H_GENERIC */
+#ifndef __CMSIS_GENERIC
+#ifndef __CORE_CM7_H_DEPENDANT
+#define __CORE_CM7_H_DEPENDANT
+#ifdef __cplusplus
+ extern "C" {
+#endif
+/* check device defines and use defaults */
+#if defined __CHECK_DEVICE_DEFINES
+  #ifndef __CM7_REV
+    #define __CM7_REV               0x0000U
+    #warning "__CM7_REV not defined in device header file; using default!"
+  #endif
+  #ifndef __FPU_PRESENT
+    #define __FPU_PRESENT             0U
+    #warning "__FPU_PRESENT not defined in device header file; using default!"
+  #endif
+  #ifndef __MPU_PRESENT
+    #define __MPU_PRESENT             0U
+    #warning "__MPU_PRESENT not defined in device header file; using default!"
+  #endif
+  #ifndef __ICACHE_PRESENT
+    #define __ICACHE_PRESENT          0U
+    #warning "__ICACHE_PRESENT not defined in device header file; using default!"
+  #endif
+  #ifndef __DCACHE_PRESENT
+    #define __DCACHE_PRESENT          0U
+    #warning "__DCACHE_PRESENT not defined in device header file; using default!"
+  #endif
+  #ifndef __DTCM_PRESENT
+    #define __DTCM_PRESENT            0U
+    #warning "__DTCM_PRESENT        not defined in device header file; using default!"
+  #endif
+  #ifndef __VTOR_PRESENT
+    #define __VTOR_PRESENT             1U
+    #warning "__VTOR_PRESENT not defined in device header file; using default!"
+  #endif
+  #ifndef __NVIC_PRIO_BITS
+    #define __NVIC_PRIO_BITS          3U
+    #warning "__NVIC_PRIO_BITS not defined in device header file; using default!"
+  #endif
+  #ifndef __Vendor_SysTickConfig
+    #define __Vendor_SysTickConfig    0U
+    #warning "__Vendor_SysTickConfig not defined in device header file; using default!"
+  #endif
+#endif
+/* IO definitions (access restrictions to peripheral registers) */
+    \defgroup CMSIS_glob_defs CMSIS Global Defines
+    <strong>IO Type Qualifiers</strong> are used
+    \li to specify the access to peripheral variables.
+    \li for automatic generation of peripheral register debug information.
+#ifdef __cplusplus
+  #define   __I     volatile             /*!< Defines 'read only' permissions */
+#else
+  #define   __I     volatile const       /*!< Defines 'read only' permissions */
+#endif
+#define     __O     volatile             /*!< Defines 'write only' permissions */
+#define     __IO    volatile             /*!< Defines 'read / write' permissions */
+/* following defines should be used for structure members */
+#define     __IM     volatile const      /*! Defines 'read only' structure member permissions */
+#define     __OM     volatile            /*! Defines 'write only' structure member permissions */
+#define     __IOM    volatile            /*! Defines 'read / write' structure member permissions */
+/*@} end of group Cortex_M7 */
+ *                 Register Abstraction
+  Core Register contain:
+  - Core Register
+  - Core NVIC Register
+  - Core SCB Register
+  - Core SysTick Register
+  - Core Debug Register
+  - Core MPU Register
+  - Core FPU Register
+  \defgroup CMSIS_core_register Defines and Type Definitions
+  \brief Type definitions and defines for Cortex-M processor based devices.
+  \ingroup    CMSIS_core_register
+  \defgroup   CMSIS_CORE  Status and Control Registers
+  \brief      Core Register type definitions.
+  \brief  Union type to access the Application Program Status Register (APSR).
+typedef union
+  struct
+    uint32_t _reserved0:16;              /*!< bit:  0..15  Reserved */
+    uint32_t GE:4;                       /*!< bit: 16..19  Greater than or Equal flags */
+    uint32_t _reserved1:7;               /*!< bit: 20..26  Reserved */
+    uint32_t Q:1;                        /*!< bit:     27  Saturation condition flag */
+    uint32_t V:1;                        /*!< bit:     28  Overflow condition code flag */
+    uint32_t C:1;                        /*!< bit:     29  Carry condition code flag */
+    uint32_t Z:1;                        /*!< bit:     30  Zero condition code flag */
+    uint32_t N:1;                        /*!< bit:     31  Negative condition code flag */
+  } b;                                   /*!< Structure used for bit  access */
+  uint32_t w;                            /*!< Type      used for word access */
+} APSR_Type;
+/* APSR Register Definitions */
+#define APSR_N_Pos                         31U                                            /*!< APSR: N Position */
+#define APSR_N_Msk                         (1UL << APSR_N_Pos)                            /*!< APSR: N Mask */
+#define APSR_Z_Pos                         30U                                            /*!< APSR: Z Position */
+#define APSR_Z_Msk                         (1UL << APSR_Z_Pos)                            /*!< APSR: Z Mask */
+#define APSR_C_Pos                         29U                                            /*!< APSR: C Position */
+#define APSR_C_Msk                         (1UL << APSR_C_Pos)                            /*!< APSR: C Mask */
+#define APSR_V_Pos                         28U                                            /*!< APSR: V Position */
+#define APSR_V_Msk                         (1UL << APSR_V_Pos)                            /*!< APSR: V Mask */
+#define APSR_Q_Pos                         27U                                            /*!< APSR: Q Position */
+#define APSR_Q_Msk                         (1UL << APSR_Q_Pos)                            /*!< APSR: Q Mask */
+#define APSR_GE_Pos                        16U                                            /*!< APSR: GE Position */
+#define APSR_GE_Msk                        (0xFUL << APSR_GE_Pos)                         /*!< APSR: GE Mask */
+  \brief  Union type to access the Interrupt Program Status Register (IPSR).
+typedef union
+  struct
+    uint32_t ISR:9;                      /*!< bit:  0.. 8  Exception number */
+    uint32_t _reserved0:23;              /*!< bit:  9..31  Reserved */
+} IPSR_Type;
+/* IPSR Register Definitions */
+#define IPSR_ISR_Pos                        0U                                            /*!< IPSR: ISR Position */
+#define IPSR_ISR_Msk                       (0x1FFUL /*<< IPSR_ISR_Pos*/)                  /*!< IPSR: ISR Mask */
+  \brief  Union type to access the Special-Purpose Program Status Registers (xPSR).
+typedef union
+  struct
+    uint32_t _reserved0:1;               /*!< bit:      9  Reserved */
+    uint32_t ICI_IT_1:6;                 /*!< bit: 10..15  ICI/IT part 1 */
+    uint32_t _reserved1:4;               /*!< bit: 20..23  Reserved */
+    uint32_t T:1;                        /*!< bit:     24  Thumb bit */
+    uint32_t ICI_IT_2:2;                 /*!< bit: 25..26  ICI/IT part 2 */
+} xPSR_Type;
+/* xPSR Register Definitions */
+#define xPSR_N_Pos                         31U                                            /*!< xPSR: N Position */
+#define xPSR_N_Msk                         (1UL << xPSR_N_Pos)                            /*!< xPSR: N Mask */
+#define xPSR_Z_Pos                         30U                                            /*!< xPSR: Z Position */
+#define xPSR_Z_Msk                         (1UL << xPSR_Z_Pos)                            /*!< xPSR: Z Mask */
+#define xPSR_C_Pos                         29U                                            /*!< xPSR: C Position */
+#define xPSR_C_Msk                         (1UL << xPSR_C_Pos)                            /*!< xPSR: C Mask */
+#define xPSR_V_Pos                         28U                                            /*!< xPSR: V Position */
+#define xPSR_V_Msk                         (1UL << xPSR_V_Pos)                            /*!< xPSR: V Mask */
+#define xPSR_Q_Pos                         27U                                            /*!< xPSR: Q Position */
+#define xPSR_Q_Msk                         (1UL << xPSR_Q_Pos)                            /*!< xPSR: Q Mask */
+#define xPSR_ICI_IT_2_Pos                  25U                                            /*!< xPSR: ICI/IT part 2 Position */
+#define xPSR_ICI_IT_2_Msk                  (3UL << xPSR_ICI_IT_2_Pos)                     /*!< xPSR: ICI/IT part 2 Mask */
+#define xPSR_T_Pos                         24U                                            /*!< xPSR: T Position */
+#define xPSR_T_Msk                         (1UL << xPSR_T_Pos)                            /*!< xPSR: T Mask */
+#define xPSR_GE_Pos                        16U                                            /*!< xPSR: GE Position */
+#define xPSR_GE_Msk                        (0xFUL << xPSR_GE_Pos)                         /*!< xPSR: GE Mask */
+#define xPSR_ICI_IT_1_Pos                  10U                                            /*!< xPSR: ICI/IT part 1 Position */
+#define xPSR_ICI_IT_1_Msk                  (0x3FUL << xPSR_ICI_IT_1_Pos)                  /*!< xPSR: ICI/IT part 1 Mask */
+#define xPSR_ISR_Pos                        0U                                            /*!< xPSR: ISR Position */
+#define xPSR_ISR_Msk                       (0x1FFUL /*<< xPSR_ISR_Pos*/)                  /*!< xPSR: ISR Mask */
+  \brief  Union type to access the Control Registers (CONTROL).
+typedef union
+  struct
+    uint32_t nPRIV:1;                    /*!< bit:      0  Execution privilege in Thread mode */
+    uint32_t SPSEL:1;                    /*!< bit:      1  Stack to be used */
+    uint32_t FPCA:1;                     /*!< bit:      2  FP extension active flag */
+    uint32_t _reserved0:29;              /*!< bit:  3..31  Reserved */
+} CONTROL_Type;
+/* CONTROL Register Definitions */
+#define CONTROL_FPCA_Pos                    2U                                            /*!< CONTROL: FPCA Position */
+#define CONTROL_FPCA_Msk                   (1UL << CONTROL_FPCA_Pos)                      /*!< CONTROL: FPCA Mask */
+#define CONTROL_SPSEL_Pos                   1U                                            /*!< CONTROL: SPSEL Position */
+#define CONTROL_SPSEL_Msk                  (1UL << CONTROL_SPSEL_Pos)                     /*!< CONTROL: SPSEL Mask */
+#define CONTROL_nPRIV_Pos                   0U                                            /*!< CONTROL: nPRIV Position */
+#define CONTROL_nPRIV_Msk                  (1UL /*<< CONTROL_nPRIV_Pos*/)                 /*!< CONTROL: nPRIV Mask */
+/*@} end of group CMSIS_CORE */
+  \defgroup   CMSIS_NVIC  Nested Vectored Interrupt Controller (NVIC)
+  \brief      Type definitions for the NVIC Registers
+  \brief  Structure type to access the Nested Vectored Interrupt Controller (NVIC).
+typedef struct
+  __IOM uint32_t ISER[8U];               /*!< Offset: 0x000 (R/W)  Interrupt Set Enable Register */
+        uint32_t RESERVED0[24U];
+  __IOM uint32_t ICER[8U];               /*!< Offset: 0x080 (R/W)  Interrupt Clear Enable Register */
+        uint32_t RESERVED1[24U];
+  __IOM uint32_t ISPR[8U];               /*!< Offset: 0x100 (R/W)  Interrupt Set Pending Register */
+        uint32_t RESERVED2[24U];
+  __IOM uint32_t ICPR[8U];               /*!< Offset: 0x180 (R/W)  Interrupt Clear Pending Register */
+        uint32_t RESERVED3[24U];
+  __IOM uint32_t IABR[8U];               /*!< Offset: 0x200 (R/W)  Interrupt Active bit Register */
+        uint32_t RESERVED4[56U];
+  __IOM uint8_t  IP[240U];               /*!< Offset: 0x300 (R/W)  Interrupt Priority Register (8Bit wide) */
+        uint32_t RESERVED5[644U];
+  __OM  uint32_t STIR;                   /*!< Offset: 0xE00 ( /W)  Software Trigger Interrupt Register */
+}  NVIC_Type;
+/* Software Triggered Interrupt Register Definitions */
+#define NVIC_STIR_INTID_Pos                 0U                                         /*!< STIR: INTLINESNUM Position */
+#define NVIC_STIR_INTID_Msk                (0x1FFUL /*<< NVIC_STIR_INTID_Pos*/)        /*!< STIR: INTLINESNUM Mask */
+/*@} end of group CMSIS_NVIC */
+  \defgroup CMSIS_SCB     System Control Block (SCB)
+  \brief    Type definitions for the System Control Block Registers
+  \brief  Structure type to access the System Control Block (SCB).
+typedef struct
+  __IM  uint32_t CPUID;                  /*!< Offset: 0x000 (R/ )  CPUID Base Register */
+  __IOM uint32_t ICSR;                   /*!< Offset: 0x004 (R/W)  Interrupt Control and State Register */
+  __IOM uint32_t VTOR;                   /*!< Offset: 0x008 (R/W)  Vector Table Offset Register */
+  __IOM uint32_t AIRCR;                  /*!< Offset: 0x00C (R/W)  Application Interrupt and Reset Control Register */
+  __IOM uint32_t SCR;                    /*!< Offset: 0x010 (R/W)  System Control Register */
+  __IOM uint32_t CCR;                    /*!< Offset: 0x014 (R/W)  Configuration Control Register */
+  __IOM uint8_t  SHPR[12U];              /*!< Offset: 0x018 (R/W)  System Handlers Priority Registers (4-7, 8-11, 12-15) */
+  __IOM uint32_t SHCSR;                  /*!< Offset: 0x024 (R/W)  System Handler Control and State Register */
+  __IOM uint32_t CFSR;                   /*!< Offset: 0x028 (R/W)  Configurable Fault Status Register */
+  __IOM uint32_t HFSR;                   /*!< Offset: 0x02C (R/W)  HardFault Status Register */
+  __IOM uint32_t DFSR;                   /*!< Offset: 0x030 (R/W)  Debug Fault Status Register */
+  __IOM uint32_t MMFAR;                  /*!< Offset: 0x034 (R/W)  MemManage Fault Address Register */
+  __IOM uint32_t BFAR;                   /*!< Offset: 0x038 (R/W)  BusFault Address Register */
+  __IOM uint32_t AFSR;                   /*!< Offset: 0x03C (R/W)  Auxiliary Fault Status Register */
+  __IM  uint32_t ID_PFR[2U];             /*!< Offset: 0x040 (R/ )  Processor Feature Register */
+  __IM  uint32_t ID_DFR;                 /*!< Offset: 0x048 (R/ )  Debug Feature Register */
+  __IM  uint32_t ID_AFR;                 /*!< Offset: 0x04C (R/ )  Auxiliary Feature Register */
+  __IM  uint32_t ID_MFR[4U];             /*!< Offset: 0x050 (R/ )  Memory Model Feature Register */
+  __IM  uint32_t ID_ISAR[5U];            /*!< Offset: 0x060 (R/ )  Instruction Set Attributes Register */
+        uint32_t RESERVED0[1U];
+  __IM  uint32_t CLIDR;                  /*!< Offset: 0x078 (R/ )  Cache Level ID register */
+  __IM  uint32_t CTR;                    /*!< Offset: 0x07C (R/ )  Cache Type register */
+  __IM  uint32_t CCSIDR;                 /*!< Offset: 0x080 (R/ )  Cache Size ID Register */
+  __IOM uint32_t CSSELR;                 /*!< Offset: 0x084 (R/W)  Cache Size Selection Register */
+  __IOM uint32_t CPACR;                  /*!< Offset: 0x088 (R/W)  Coprocessor Access Control Register */
+        uint32_t RESERVED3[93U];
+  __OM  uint32_t STIR;                   /*!< Offset: 0x200 ( /W)  Software Triggered Interrupt Register */
+        uint32_t RESERVED4[15U];
+  __IM  uint32_t MVFR0;                  /*!< Offset: 0x240 (R/ )  Media and VFP Feature Register 0 */
+  __IM  uint32_t MVFR1;                  /*!< Offset: 0x244 (R/ )  Media and VFP Feature Register 1 */
+  __IM  uint32_t MVFR2;                  /*!< Offset: 0x248 (R/ )  Media and VFP Feature Register 2 */
+        uint32_t RESERVED5[1U];
+  __OM  uint32_t ICIALLU;                /*!< Offset: 0x250 ( /W)  I-Cache Invalidate All to PoU */
+        uint32_t RESERVED6[1U];
+  __OM  uint32_t ICIMVAU;                /*!< Offset: 0x258 ( /W)  I-Cache Invalidate by MVA to PoU */
+  __OM  uint32_t DCIMVAC;                /*!< Offset: 0x25C ( /W)  D-Cache Invalidate by MVA to PoC */
+  __OM  uint32_t DCISW;                  /*!< Offset: 0x260 ( /W)  D-Cache Invalidate by Set-way */
+  __OM  uint32_t DCCMVAU;                /*!< Offset: 0x264 ( /W)  D-Cache Clean by MVA to PoU */
+  __OM  uint32_t DCCMVAC;                /*!< Offset: 0x268 ( /W)  D-Cache Clean by MVA to PoC */
+  __OM  uint32_t DCCSW;                  /*!< Offset: 0x26C ( /W)  D-Cache Clean by Set-way */
+  __OM  uint32_t DCCIMVAC;               /*!< Offset: 0x270 ( /W)  D-Cache Clean and Invalidate by MVA to PoC */
+  __OM  uint32_t DCCISW;                 /*!< Offset: 0x274 ( /W)  D-Cache Clean and Invalidate by Set-way */
+  __OM  uint32_t BPIALL;                 /*!< Offset: 0x278 ( /W)  Branch Predictor Invalidate All */
+        uint32_t RESERVED7[5U];
+  __IOM uint32_t ITCMCR;                 /*!< Offset: 0x290 (R/W)  Instruction Tightly-Coupled Memory Control Register */
+  __IOM uint32_t DTCMCR;                 /*!< Offset: 0x294 (R/W)  Data Tightly-Coupled Memory Control Registers */
+  __IOM uint32_t AHBPCR;                 /*!< Offset: 0x298 (R/W)  AHBP Control Register */
+  __IOM uint32_t CACR;                   /*!< Offset: 0x29C (R/W)  L1 Cache Control Register */
+  __IOM uint32_t AHBSCR;                 /*!< Offset: 0x2A0 (R/W)  AHB Slave Control Register */
+        uint32_t RESERVED8[1U];
+  __IOM uint32_t ABFSR;                  /*!< Offset: 0x2A8 (R/W)  Auxiliary Bus Fault Status Register */
+} SCB_Type;
+/* SCB CPUID Register Definitions */
+#define SCB_CPUID_IMPLEMENTER_Pos          24U                                            /*!< SCB CPUID: IMPLEMENTER Position */
+#define SCB_CPUID_IMPLEMENTER_Msk          (0xFFUL << SCB_CPUID_IMPLEMENTER_Pos)          /*!< SCB CPUID: IMPLEMENTER Mask */
+#define SCB_CPUID_VARIANT_Pos              20U                                            /*!< SCB CPUID: VARIANT Position */
+#define SCB_CPUID_VARIANT_Msk              (0xFUL << SCB_CPUID_VARIANT_Pos)               /*!< SCB CPUID: VARIANT Mask */
+#define SCB_CPUID_ARCHITECTURE_Pos         16U                                            /*!< SCB CPUID: ARCHITECTURE Position */
+#define SCB_CPUID_ARCHITECTURE_Msk         (0xFUL << SCB_CPUID_ARCHITECTURE_Pos)          /*!< SCB CPUID: ARCHITECTURE Mask */
+#define SCB_CPUID_PARTNO_Pos                4U                                            /*!< SCB CPUID: PARTNO Position */
+#define SCB_CPUID_PARTNO_Msk               (0xFFFUL << SCB_CPUID_PARTNO_Pos)              /*!< SCB CPUID: PARTNO Mask */
+#define SCB_CPUID_REVISION_Pos              0U                                            /*!< SCB CPUID: REVISION Position */
+#define SCB_CPUID_REVISION_Msk             (0xFUL /*<< SCB_CPUID_REVISION_Pos*/)          /*!< SCB CPUID: REVISION Mask */
+/* SCB Interrupt Control State Register Definitions */
+#define SCB_ICSR_NMIPENDSET_Pos            31U                                            /*!< SCB ICSR: NMIPENDSET Position */
+#define SCB_ICSR_NMIPENDSET_Msk            (1UL << SCB_ICSR_NMIPENDSET_Pos)               /*!< SCB ICSR: NMIPENDSET Mask */
+#define SCB_ICSR_PENDSVSET_Pos             28U                                            /*!< SCB ICSR: PENDSVSET Position */
+#define SCB_ICSR_PENDSVSET_Msk             (1UL << SCB_ICSR_PENDSVSET_Pos)                /*!< SCB ICSR: PENDSVSET Mask */
+#define SCB_ICSR_PENDSVCLR_Pos             27U                                            /*!< SCB ICSR: PENDSVCLR Position */
+#define SCB_ICSR_PENDSVCLR_Msk             (1UL << SCB_ICSR_PENDSVCLR_Pos)                /*!< SCB ICSR: PENDSVCLR Mask */
+#define SCB_ICSR_PENDSTSET_Pos             26U                                            /*!< SCB ICSR: PENDSTSET Position */
+#define SCB_ICSR_PENDSTSET_Msk             (1UL << SCB_ICSR_PENDSTSET_Pos)                /*!< SCB ICSR: PENDSTSET Mask */
+#define SCB_ICSR_PENDSTCLR_Pos             25U                                            /*!< SCB ICSR: PENDSTCLR Position */
+#define SCB_ICSR_PENDSTCLR_Msk             (1UL << SCB_ICSR_PENDSTCLR_Pos)                /*!< SCB ICSR: PENDSTCLR Mask */
+#define SCB_ICSR_ISRPREEMPT_Pos            23U                                            /*!< SCB ICSR: ISRPREEMPT Position */
+#define SCB_ICSR_ISRPREEMPT_Msk            (1UL << SCB_ICSR_ISRPREEMPT_Pos)               /*!< SCB ICSR: ISRPREEMPT Mask */
+#define SCB_ICSR_ISRPENDING_Pos            22U                                            /*!< SCB ICSR: ISRPENDING Position */
+#define SCB_ICSR_ISRPENDING_Msk            (1UL << SCB_ICSR_ISRPENDING_Pos)               /*!< SCB ICSR: ISRPENDING Mask */
+#define SCB_ICSR_VECTPENDING_Pos           12U                                            /*!< SCB ICSR: VECTPENDING Position */
+#define SCB_ICSR_VECTPENDING_Msk           (0x1FFUL << SCB_ICSR_VECTPENDING_Pos)          /*!< SCB ICSR: VECTPENDING Mask */
+#define SCB_ICSR_RETTOBASE_Pos             11U                                            /*!< SCB ICSR: RETTOBASE Position */
+#define SCB_ICSR_RETTOBASE_Msk             (1UL << SCB_ICSR_RETTOBASE_Pos)                /*!< SCB ICSR: RETTOBASE Mask */
+#define SCB_ICSR_VECTACTIVE_Pos             0U                                            /*!< SCB ICSR: VECTACTIVE Position */
+#define SCB_ICSR_VECTACTIVE_Msk            (0x1FFUL /*<< SCB_ICSR_VECTACTIVE_Pos*/)       /*!< SCB ICSR: VECTACTIVE Mask */
+/* SCB Vector Table Offset Register Definitions */
+#define SCB_VTOR_TBLOFF_Pos                 7U                                            /*!< SCB VTOR: TBLOFF Position */
+#define SCB_VTOR_TBLOFF_Msk                (0x1FFFFFFUL << SCB_VTOR_TBLOFF_Pos)           /*!< SCB VTOR: TBLOFF Mask */
+/* SCB Application Interrupt and Reset Control Register Definitions */
+#define SCB_AIRCR_VECTKEY_Pos              16U                                            /*!< SCB AIRCR: VECTKEY Position */
+#define SCB_AIRCR_VECTKEY_Msk              (0xFFFFUL << SCB_AIRCR_VECTKEY_Pos)            /*!< SCB AIRCR: VECTKEY Mask */
+#define SCB_AIRCR_VECTKEYSTAT_Pos          16U                                            /*!< SCB AIRCR: VECTKEYSTAT Position */
+#define SCB_AIRCR_VECTKEYSTAT_Msk          (0xFFFFUL << SCB_AIRCR_VECTKEYSTAT_Pos)        /*!< SCB AIRCR: VECTKEYSTAT Mask */
+#define SCB_AIRCR_ENDIANESS_Pos            15U                                            /*!< SCB AIRCR: ENDIANESS Position */
+#define SCB_AIRCR_ENDIANESS_Msk            (1UL << SCB_AIRCR_ENDIANESS_Pos)               /*!< SCB AIRCR: ENDIANESS Mask */
+#define SCB_AIRCR_PRIGROUP_Pos              8U                                            /*!< SCB AIRCR: PRIGROUP Position */
+#define SCB_AIRCR_PRIGROUP_Msk             (7UL << SCB_AIRCR_PRIGROUP_Pos)                /*!< SCB AIRCR: PRIGROUP Mask */
+#define SCB_AIRCR_SYSRESETREQ_Pos           2U                                            /*!< SCB AIRCR: SYSRESETREQ Position */
+#define SCB_AIRCR_SYSRESETREQ_Msk          (1UL << SCB_AIRCR_SYSRESETREQ_Pos)             /*!< SCB AIRCR: SYSRESETREQ Mask */
+#define SCB_AIRCR_VECTCLRACTIVE_Pos         1U                                            /*!< SCB AIRCR: VECTCLRACTIVE Position */
+#define SCB_AIRCR_VECTCLRACTIVE_Msk        (1UL << SCB_AIRCR_VECTCLRACTIVE_Pos)           /*!< SCB AIRCR: VECTCLRACTIVE Mask */
+#define SCB_AIRCR_VECTRESET_Pos             0U                                            /*!< SCB AIRCR: VECTRESET Position */
+#define SCB_AIRCR_VECTRESET_Msk            (1UL /*<< SCB_AIRCR_VECTRESET_Pos*/)           /*!< SCB AIRCR: VECTRESET Mask */
+/* SCB System Control Register Definitions */
+#define SCB_SCR_SEVONPEND_Pos               4U                                            /*!< SCB SCR: SEVONPEND Position */
+#define SCB_SCR_SEVONPEND_Msk              (1UL << SCB_SCR_SEVONPEND_Pos)                 /*!< SCB SCR: SEVONPEND Mask */
+#define SCB_SCR_SLEEPDEEP_Pos               2U                                            /*!< SCB SCR: SLEEPDEEP Position */
+#define SCB_SCR_SLEEPDEEP_Msk              (1UL << SCB_SCR_SLEEPDEEP_Pos)                 /*!< SCB SCR: SLEEPDEEP Mask */
+#define SCB_SCR_SLEEPONEXIT_Pos             1U                                            /*!< SCB SCR: SLEEPONEXIT Position */
+#define SCB_SCR_SLEEPONEXIT_Msk            (1UL << SCB_SCR_SLEEPONEXIT_Pos)               /*!< SCB SCR: SLEEPONEXIT Mask */
+/* SCB Configuration Control Register Definitions */
+#define SCB_CCR_BP_Pos                      18U                                           /*!< SCB CCR: Branch prediction enable bit Position */
+#define SCB_CCR_BP_Msk                     (1UL << SCB_CCR_BP_Pos)                        /*!< SCB CCR: Branch prediction enable bit Mask */
+#define SCB_CCR_IC_Pos                      17U                                           /*!< SCB CCR: Instruction cache enable bit Position */
+#define SCB_CCR_IC_Msk                     (1UL << SCB_CCR_IC_Pos)                        /*!< SCB CCR: Instruction cache enable bit Mask */
+#define SCB_CCR_DC_Pos                      16U                                           /*!< SCB CCR: Cache enable bit Position */
+#define SCB_CCR_DC_Msk                     (1UL << SCB_CCR_DC_Pos)                        /*!< SCB CCR: Cache enable bit Mask */
+#define SCB_CCR_STKALIGN_Pos                9U                                            /*!< SCB CCR: STKALIGN Position */
+#define SCB_CCR_STKALIGN_Msk               (1UL << SCB_CCR_STKALIGN_Pos)                  /*!< SCB CCR: STKALIGN Mask */
+#define SCB_CCR_BFHFNMIGN_Pos               8U                                            /*!< SCB CCR: BFHFNMIGN Position */
+#define SCB_CCR_BFHFNMIGN_Msk              (1UL << SCB_CCR_BFHFNMIGN_Pos)                 /*!< SCB CCR: BFHFNMIGN Mask */
+#define SCB_CCR_DIV_0_TRP_Pos               4U                                            /*!< SCB CCR: DIV_0_TRP Position */
+#define SCB_CCR_DIV_0_TRP_Msk              (1UL << SCB_CCR_DIV_0_TRP_Pos)                 /*!< SCB CCR: DIV_0_TRP Mask */
+#define SCB_CCR_UNALIGN_TRP_Pos             3U                                            /*!< SCB CCR: UNALIGN_TRP Position */
+#define SCB_CCR_UNALIGN_TRP_Msk            (1UL << SCB_CCR_UNALIGN_TRP_Pos)               /*!< SCB CCR: UNALIGN_TRP Mask */
+#define SCB_CCR_USERSETMPEND_Pos            1U                                            /*!< SCB CCR: USERSETMPEND Position */
+#define SCB_CCR_USERSETMPEND_Msk           (1UL << SCB_CCR_USERSETMPEND_Pos)              /*!< SCB CCR: USERSETMPEND Mask */
+#define SCB_CCR_NONBASETHRDENA_Pos          0U                                            /*!< SCB CCR: NONBASETHRDENA Position */
+#define SCB_CCR_NONBASETHRDENA_Msk         (1UL /*<< SCB_CCR_NONBASETHRDENA_Pos*/)        /*!< SCB CCR: NONBASETHRDENA Mask */
+/* SCB System Handler Control and State Register Definitions */
+#define SCB_SHCSR_USGFAULTENA_Pos          18U                                            /*!< SCB SHCSR: USGFAULTENA Position */
+#define SCB_SHCSR_USGFAULTENA_Msk          (1UL << SCB_SHCSR_USGFAULTENA_Pos)             /*!< SCB SHCSR: USGFAULTENA Mask */
+#define SCB_SHCSR_BUSFAULTENA_Pos          17U                                            /*!< SCB SHCSR: BUSFAULTENA Position */
+#define SCB_SHCSR_BUSFAULTENA_Msk          (1UL << SCB_SHCSR_BUSFAULTENA_Pos)             /*!< SCB SHCSR: BUSFAULTENA Mask */
+#define SCB_SHCSR_MEMFAULTENA_Pos          16U                                            /*!< SCB SHCSR: MEMFAULTENA Position */
+#define SCB_SHCSR_MEMFAULTENA_Msk          (1UL << SCB_SHCSR_MEMFAULTENA_Pos)             /*!< SCB SHCSR: MEMFAULTENA Mask */
+#define SCB_SHCSR_SVCALLPENDED_Pos         15U                                            /*!< SCB SHCSR: SVCALLPENDED Position */
+#define SCB_SHCSR_SVCALLPENDED_Msk         (1UL << SCB_SHCSR_SVCALLPENDED_Pos)            /*!< SCB SHCSR: SVCALLPENDED Mask */
+#define SCB_SHCSR_BUSFAULTPENDED_Pos       14U                                            /*!< SCB SHCSR: BUSFAULTPENDED Position */
+#define SCB_SHCSR_BUSFAULTPENDED_Msk       (1UL << SCB_SHCSR_BUSFAULTPENDED_Pos)          /*!< SCB SHCSR: BUSFAULTPENDED Mask */
+#define SCB_SHCSR_MEMFAULTPENDED_Pos       13U                                            /*!< SCB SHCSR: MEMFAULTPENDED Position */
+#define SCB_SHCSR_MEMFAULTPENDED_Msk       (1UL << SCB_SHCSR_MEMFAULTPENDED_Pos)          /*!< SCB SHCSR: MEMFAULTPENDED Mask */
+#define SCB_SHCSR_USGFAULTPENDED_Pos       12U                                            /*!< SCB SHCSR: USGFAULTPENDED Position */
+#define SCB_SHCSR_USGFAULTPENDED_Msk       (1UL << SCB_SHCSR_USGFAULTPENDED_Pos)          /*!< SCB SHCSR: USGFAULTPENDED Mask */
+#define SCB_SHCSR_SYSTICKACT_Pos           11U                                            /*!< SCB SHCSR: SYSTICKACT Position */
+#define SCB_SHCSR_SYSTICKACT_Msk           (1UL << SCB_SHCSR_SYSTICKACT_Pos)              /*!< SCB SHCSR: SYSTICKACT Mask */
+#define SCB_SHCSR_PENDSVACT_Pos            10U                                            /*!< SCB SHCSR: PENDSVACT Position */
+#define SCB_SHCSR_PENDSVACT_Msk            (1UL << SCB_SHCSR_PENDSVACT_Pos)               /*!< SCB SHCSR: PENDSVACT Mask */
+#define SCB_SHCSR_MONITORACT_Pos            8U                                            /*!< SCB SHCSR: MONITORACT Position */
+#define SCB_SHCSR_MONITORACT_Msk           (1UL << SCB_SHCSR_MONITORACT_Pos)              /*!< SCB SHCSR: MONITORACT Mask */
+#define SCB_SHCSR_SVCALLACT_Pos             7U                                            /*!< SCB SHCSR: SVCALLACT Position */
+#define SCB_SHCSR_SVCALLACT_Msk            (1UL << SCB_SHCSR_SVCALLACT_Pos)               /*!< SCB SHCSR: SVCALLACT Mask */
+#define SCB_SHCSR_USGFAULTACT_Pos           3U                                            /*!< SCB SHCSR: USGFAULTACT Position */
+#define SCB_SHCSR_USGFAULTACT_Msk          (1UL << SCB_SHCSR_USGFAULTACT_Pos)             /*!< SCB SHCSR: USGFAULTACT Mask */
+#define SCB_SHCSR_BUSFAULTACT_Pos           1U                                            /*!< SCB SHCSR: BUSFAULTACT Position */
+#define SCB_SHCSR_BUSFAULTACT_Msk          (1UL << SCB_SHCSR_BUSFAULTACT_Pos)             /*!< SCB SHCSR: BUSFAULTACT Mask */
+#define SCB_SHCSR_MEMFAULTACT_Pos           0U                                            /*!< SCB SHCSR: MEMFAULTACT Position */
+#define SCB_SHCSR_MEMFAULTACT_Msk          (1UL /*<< SCB_SHCSR_MEMFAULTACT_Pos*/)         /*!< SCB SHCSR: MEMFAULTACT Mask */
+/* SCB Configurable Fault Status Register Definitions */
+#define SCB_CFSR_USGFAULTSR_Pos            16U                                            /*!< SCB CFSR: Usage Fault Status Register Position */
+#define SCB_CFSR_USGFAULTSR_Msk            (0xFFFFUL << SCB_CFSR_USGFAULTSR_Pos)          /*!< SCB CFSR: Usage Fault Status Register Mask */
+#define SCB_CFSR_BUSFAULTSR_Pos             8U                                            /*!< SCB CFSR: Bus Fault Status Register Position */
+#define SCB_CFSR_BUSFAULTSR_Msk            (0xFFUL << SCB_CFSR_BUSFAULTSR_Pos)            /*!< SCB CFSR: Bus Fault Status Register Mask */
+#define SCB_CFSR_MEMFAULTSR_Pos             0U                                            /*!< SCB CFSR: Memory Manage Fault Status Register Position */
+#define SCB_CFSR_MEMFAULTSR_Msk            (0xFFUL /*<< SCB_CFSR_MEMFAULTSR_Pos*/)        /*!< SCB CFSR: Memory Manage Fault Status Register Mask */
+/* MemManage Fault Status Register (part of SCB Configurable Fault Status Register) */
+#define SCB_CFSR_MMARVALID_Pos             (SCB_CFSR_MEMFAULTSR_Pos + 7U)                 /*!< SCB CFSR (MMFSR): MMARVALID Position */
+#define SCB_CFSR_MMARVALID_Msk             (1UL << SCB_CFSR_MMARVALID_Pos)                /*!< SCB CFSR (MMFSR): MMARVALID Mask */
+#define SCB_CFSR_MLSPERR_Pos               (SCB_CFSR_MEMFAULTSR_Pos + 5U)                 /*!< SCB CFSR (MMFSR): MLSPERR Position */
+#define SCB_CFSR_MLSPERR_Msk               (1UL << SCB_CFSR_MLSPERR_Pos)                  /*!< SCB CFSR (MMFSR): MLSPERR Mask */
+#define SCB_CFSR_MSTKERR_Pos               (SCB_CFSR_MEMFAULTSR_Pos + 4U)                 /*!< SCB CFSR (MMFSR): MSTKERR Position */
+#define SCB_CFSR_MSTKERR_Msk               (1UL << SCB_CFSR_MSTKERR_Pos)                  /*!< SCB CFSR (MMFSR): MSTKERR Mask */
+#define SCB_CFSR_MUNSTKERR_Pos             (SCB_CFSR_MEMFAULTSR_Pos + 3U)                 /*!< SCB CFSR (MMFSR): MUNSTKERR Position */
+#define SCB_CFSR_MUNSTKERR_Msk             (1UL << SCB_CFSR_MUNSTKERR_Pos)                /*!< SCB CFSR (MMFSR): MUNSTKERR Mask */
+#define SCB_CFSR_DACCVIOL_Pos              (SCB_CFSR_MEMFAULTSR_Pos + 1U)                 /*!< SCB CFSR (MMFSR): DACCVIOL Position */
+#define SCB_CFSR_DACCVIOL_Msk              (1UL << SCB_CFSR_DACCVIOL_Pos)                 /*!< SCB CFSR (MMFSR): DACCVIOL Mask */
+#define SCB_CFSR_IACCVIOL_Pos              (SCB_CFSR_MEMFAULTSR_Pos + 0U)                 /*!< SCB CFSR (MMFSR): IACCVIOL Position */
+#define SCB_CFSR_IACCVIOL_Msk              (1UL /*<< SCB_CFSR_IACCVIOL_Pos*/)             /*!< SCB CFSR (MMFSR): IACCVIOL Mask */
+/* BusFault Status Register (part of SCB Configurable Fault Status Register) */
+#define SCB_CFSR_BFARVALID_Pos            (SCB_CFSR_BUSFAULTSR_Pos + 7U)                  /*!< SCB CFSR (BFSR): BFARVALID Position */
+#define SCB_CFSR_BFARVALID_Msk            (1UL << SCB_CFSR_BFARVALID_Pos)                 /*!< SCB CFSR (BFSR): BFARVALID Mask */
+#define SCB_CFSR_LSPERR_Pos               (SCB_CFSR_BUSFAULTSR_Pos + 5U)                  /*!< SCB CFSR (BFSR): LSPERR Position */
+#define SCB_CFSR_LSPERR_Msk               (1UL << SCB_CFSR_LSPERR_Pos)                    /*!< SCB CFSR (BFSR): LSPERR Mask */
+#define SCB_CFSR_STKERR_Pos               (SCB_CFSR_BUSFAULTSR_Pos + 4U)                  /*!< SCB CFSR (BFSR): STKERR Position */
+#define SCB_CFSR_STKERR_Msk               (1UL << SCB_CFSR_STKERR_Pos)                    /*!< SCB CFSR (BFSR): STKERR Mask */
+#define SCB_CFSR_UNSTKERR_Pos             (SCB_CFSR_BUSFAULTSR_Pos + 3U)                  /*!< SCB CFSR (BFSR): UNSTKERR Position */
+#define SCB_CFSR_UNSTKERR_Msk             (1UL << SCB_CFSR_UNSTKERR_Pos)                  /*!< SCB CFSR (BFSR): UNSTKERR Mask */
+#define SCB_CFSR_IMPRECISERR_Pos          (SCB_CFSR_BUSFAULTSR_Pos + 2U)                  /*!< SCB CFSR (BFSR): IMPRECISERR Position */
+#define SCB_CFSR_IMPRECISERR_Msk          (1UL << SCB_CFSR_IMPRECISERR_Pos)               /*!< SCB CFSR (BFSR): IMPRECISERR Mask */
+#define SCB_CFSR_PRECISERR_Pos            (SCB_CFSR_BUSFAULTSR_Pos + 1U)                  /*!< SCB CFSR (BFSR): PRECISERR Position */
+#define SCB_CFSR_PRECISERR_Msk            (1UL << SCB_CFSR_PRECISERR_Pos)                 /*!< SCB CFSR (BFSR): PRECISERR Mask */
+#define SCB_CFSR_IBUSERR_Pos              (SCB_CFSR_BUSFAULTSR_Pos + 0U)                  /*!< SCB CFSR (BFSR): IBUSERR Position */
+#define SCB_CFSR_IBUSERR_Msk              (1UL << SCB_CFSR_IBUSERR_Pos)                   /*!< SCB CFSR (BFSR): IBUSERR Mask */
+/* UsageFault Status Register (part of SCB Configurable Fault Status Register) */
+#define SCB_CFSR_DIVBYZERO_Pos            (SCB_CFSR_USGFAULTSR_Pos + 9U)                  /*!< SCB CFSR (UFSR): DIVBYZERO Position */
+#define SCB_CFSR_DIVBYZERO_Msk            (1UL << SCB_CFSR_DIVBYZERO_Pos)                 /*!< SCB CFSR (UFSR): DIVBYZERO Mask */
+#define SCB_CFSR_UNALIGNED_Pos            (SCB_CFSR_USGFAULTSR_Pos + 8U)                  /*!< SCB CFSR (UFSR): UNALIGNED Position */
+#define SCB_CFSR_UNALIGNED_Msk            (1UL << SCB_CFSR_UNALIGNED_Pos)                 /*!< SCB CFSR (UFSR): UNALIGNED Mask */
+#define SCB_CFSR_NOCP_Pos                 (SCB_CFSR_USGFAULTSR_Pos + 3U)                  /*!< SCB CFSR (UFSR): NOCP Position */
+#define SCB_CFSR_NOCP_Msk                 (1UL << SCB_CFSR_NOCP_Pos)                      /*!< SCB CFSR (UFSR): NOCP Mask */
+#define SCB_CFSR_INVPC_Pos                (SCB_CFSR_USGFAULTSR_Pos + 2U)                  /*!< SCB CFSR (UFSR): INVPC Position */
+#define SCB_CFSR_INVPC_Msk                (1UL << SCB_CFSR_INVPC_Pos)                     /*!< SCB CFSR (UFSR): INVPC Mask */
+#define SCB_CFSR_INVSTATE_Pos             (SCB_CFSR_USGFAULTSR_Pos + 1U)                  /*!< SCB CFSR (UFSR): INVSTATE Position */
+#define SCB_CFSR_INVSTATE_Msk             (1UL << SCB_CFSR_INVSTATE_Pos)                  /*!< SCB CFSR (UFSR): INVSTATE Mask */
+#define SCB_CFSR_UNDEFINSTR_Pos           (SCB_CFSR_USGFAULTSR_Pos + 0U)                  /*!< SCB CFSR (UFSR): UNDEFINSTR Position */
+#define SCB_CFSR_UNDEFINSTR_Msk           (1UL << SCB_CFSR_UNDEFINSTR_Pos)                /*!< SCB CFSR (UFSR): UNDEFINSTR Mask */
+/* SCB Hard Fault Status Register Definitions */
+#define SCB_HFSR_DEBUGEVT_Pos              31U                                            /*!< SCB HFSR: DEBUGEVT Position */
+#define SCB_HFSR_DEBUGEVT_Msk              (1UL << SCB_HFSR_DEBUGEVT_Pos)                 /*!< SCB HFSR: DEBUGEVT Mask */
+#define SCB_HFSR_FORCED_Pos                30U                                            /*!< SCB HFSR: FORCED Position */
+#define SCB_HFSR_FORCED_Msk                (1UL << SCB_HFSR_FORCED_Pos)                   /*!< SCB HFSR: FORCED Mask */
+#define SCB_HFSR_VECTTBL_Pos                1U                                            /*!< SCB HFSR: VECTTBL Position */
+#define SCB_HFSR_VECTTBL_Msk               (1UL << SCB_HFSR_VECTTBL_Pos)                  /*!< SCB HFSR: VECTTBL Mask */
+/* SCB Debug Fault Status Register Definitions */
+#define SCB_DFSR_EXTERNAL_Pos               4U                                            /*!< SCB DFSR: EXTERNAL Position */
+#define SCB_DFSR_EXTERNAL_Msk              (1UL << SCB_DFSR_EXTERNAL_Pos)                 /*!< SCB DFSR: EXTERNAL Mask */
+#define SCB_DFSR_VCATCH_Pos                 3U                                            /*!< SCB DFSR: VCATCH Position */
+#define SCB_DFSR_VCATCH_Msk                (1UL << SCB_DFSR_VCATCH_Pos)                   /*!< SCB DFSR: VCATCH Mask */
+#define SCB_DFSR_DWTTRAP_Pos                2U                                            /*!< SCB DFSR: DWTTRAP Position */
+#define SCB_DFSR_DWTTRAP_Msk               (1UL << SCB_DFSR_DWTTRAP_Pos)                  /*!< SCB DFSR: DWTTRAP Mask */
+#define SCB_DFSR_BKPT_Pos                   1U                                            /*!< SCB DFSR: BKPT Position */
+#define SCB_DFSR_BKPT_Msk                  (1UL << SCB_DFSR_BKPT_Pos)                     /*!< SCB DFSR: BKPT Mask */
+#define SCB_DFSR_HALTED_Pos                 0U                                            /*!< SCB DFSR: HALTED Position */
+#define SCB_DFSR_HALTED_Msk                (1UL /*<< SCB_DFSR_HALTED_Pos*/)               /*!< SCB DFSR: HALTED Mask */
+/* SCB Cache Level ID Register Definitions */
+#define SCB_CLIDR_LOUU_Pos                 27U                                            /*!< SCB CLIDR: LoUU Position */
+#define SCB_CLIDR_LOUU_Msk                 (7UL << SCB_CLIDR_LOUU_Pos)                    /*!< SCB CLIDR: LoUU Mask */
+#define SCB_CLIDR_LOC_Pos                  24U                                            /*!< SCB CLIDR: LoC Position */
+#define SCB_CLIDR_LOC_Msk                  (7UL << SCB_CLIDR_LOC_Pos)                     /*!< SCB CLIDR: LoC Mask */
+/* SCB Cache Type Register Definitions */
+#define SCB_CTR_FORMAT_Pos                 29U                                            /*!< SCB CTR: Format Position */
+#define SCB_CTR_FORMAT_Msk                 (7UL << SCB_CTR_FORMAT_Pos)                    /*!< SCB CTR: Format Mask */
+#define SCB_CTR_CWG_Pos                    24U                                            /*!< SCB CTR: CWG Position */
+#define SCB_CTR_CWG_Msk                    (0xFUL << SCB_CTR_CWG_Pos)                     /*!< SCB CTR: CWG Mask */
+#define SCB_CTR_ERG_Pos                    20U                                            /*!< SCB CTR: ERG Position */
+#define SCB_CTR_ERG_Msk                    (0xFUL << SCB_CTR_ERG_Pos)                     /*!< SCB CTR: ERG Mask */
+#define SCB_CTR_DMINLINE_Pos               16U                                            /*!< SCB CTR: DminLine Position */
+#define SCB_CTR_DMINLINE_Msk               (0xFUL << SCB_CTR_DMINLINE_Pos)                /*!< SCB CTR: DminLine Mask */
+#define SCB_CTR_IMINLINE_Pos                0U                                            /*!< SCB CTR: ImInLine Position */
+#define SCB_CTR_IMINLINE_Msk               (0xFUL /*<< SCB_CTR_IMINLINE_Pos*/)            /*!< SCB CTR: ImInLine Mask */
+/* SCB Cache Size ID Register Definitions */
+#define SCB_CCSIDR_WT_Pos                  31U                                            /*!< SCB CCSIDR: WT Position */
+#define SCB_CCSIDR_WT_Msk                  (1UL << SCB_CCSIDR_WT_Pos)                     /*!< SCB CCSIDR: WT Mask */
+#define SCB_CCSIDR_WB_Pos                  30U                                            /*!< SCB CCSIDR: WB Position */
+#define SCB_CCSIDR_WB_Msk                  (1UL << SCB_CCSIDR_WB_Pos)                     /*!< SCB CCSIDR: WB Mask */
+#define SCB_CCSIDR_RA_Pos                  29U                                            /*!< SCB CCSIDR: RA Position */
+#define SCB_CCSIDR_RA_Msk                  (1UL << SCB_CCSIDR_RA_Pos)                     /*!< SCB CCSIDR: RA Mask */
+#define SCB_CCSIDR_WA_Pos                  28U                                            /*!< SCB CCSIDR: WA Position */
+#define SCB_CCSIDR_WA_Msk                  (1UL << SCB_CCSIDR_WA_Pos)                     /*!< SCB CCSIDR: WA Mask */
+#define SCB_CCSIDR_NUMSETS_Pos             13U                                            /*!< SCB CCSIDR: NumSets Position */
+#define SCB_CCSIDR_NUMSETS_Msk             (0x7FFFUL << SCB_CCSIDR_NUMSETS_Pos)           /*!< SCB CCSIDR: NumSets Mask */
+#define SCB_CCSIDR_ASSOCIATIVITY_Pos        3U                                            /*!< SCB CCSIDR: Associativity Position */
+#define SCB_CCSIDR_ASSOCIATIVITY_Msk       (0x3FFUL << SCB_CCSIDR_ASSOCIATIVITY_Pos)      /*!< SCB CCSIDR: Associativity Mask */
+#define SCB_CCSIDR_LINESIZE_Pos             0U                                            /*!< SCB CCSIDR: LineSize Position */
+#define SCB_CCSIDR_LINESIZE_Msk            (7UL /*<< SCB_CCSIDR_LINESIZE_Pos*/)           /*!< SCB CCSIDR: LineSize Mask */
+/* SCB Cache Size Selection Register Definitions */
+#define SCB_CSSELR_LEVEL_Pos                1U                                            /*!< SCB CSSELR: Level Position */
+#define SCB_CSSELR_LEVEL_Msk               (7UL << SCB_CSSELR_LEVEL_Pos)                  /*!< SCB CSSELR: Level Mask */
+#define SCB_CSSELR_IND_Pos                  0U                                            /*!< SCB CSSELR: InD Position */
+#define SCB_CSSELR_IND_Msk                 (1UL /*<< SCB_CSSELR_IND_Pos*/)                /*!< SCB CSSELR: InD Mask */
+/* SCB Software Triggered Interrupt Register Definitions */
+#define SCB_STIR_INTID_Pos                  0U                                            /*!< SCB STIR: INTID Position */
+#define SCB_STIR_INTID_Msk                 (0x1FFUL /*<< SCB_STIR_INTID_Pos*/)            /*!< SCB STIR: INTID Mask */
+/* SCB D-Cache Invalidate by Set-way Register Definitions */
+#define SCB_DCISW_WAY_Pos                  30U                                            /*!< SCB DCISW: Way Position */
+#define SCB_DCISW_WAY_Msk                  (3UL << SCB_DCISW_WAY_Pos)                     /*!< SCB DCISW: Way Mask */
+#define SCB_DCISW_SET_Pos                   5U                                            /*!< SCB DCISW: Set Position */
+#define SCB_DCISW_SET_Msk                  (0x1FFUL << SCB_DCISW_SET_Pos)                 /*!< SCB DCISW: Set Mask */
+/* SCB D-Cache Clean by Set-way Register Definitions */
+#define SCB_DCCSW_WAY_Pos                  30U                                            /*!< SCB DCCSW: Way Position */
+#define SCB_DCCSW_WAY_Msk                  (3UL << SCB_DCCSW_WAY_Pos)                     /*!< SCB DCCSW: Way Mask */
+#define SCB_DCCSW_SET_Pos                   5U                                            /*!< SCB DCCSW: Set Position */
+#define SCB_DCCSW_SET_Msk                  (0x1FFUL << SCB_DCCSW_SET_Pos)                 /*!< SCB DCCSW: Set Mask */
+/* SCB D-Cache Clean and Invalidate by Set-way Register Definitions */
+#define SCB_DCCISW_WAY_Pos                 30U                                            /*!< SCB DCCISW: Way Position */
+#define SCB_DCCISW_WAY_Msk                 (3UL << SCB_DCCISW_WAY_Pos)                    /*!< SCB DCCISW: Way Mask */
+#define SCB_DCCISW_SET_Pos                  5U                                            /*!< SCB DCCISW: Set Position */
+#define SCB_DCCISW_SET_Msk                 (0x1FFUL << SCB_DCCISW_SET_Pos)                /*!< SCB DCCISW: Set Mask */
+/* Instruction Tightly-Coupled Memory Control Register Definitions */
+#define SCB_ITCMCR_SZ_Pos                   3U                                            /*!< SCB ITCMCR: SZ Position */
+#define SCB_ITCMCR_SZ_Msk                  (0xFUL << SCB_ITCMCR_SZ_Pos)                   /*!< SCB ITCMCR: SZ Mask */
+#define SCB_ITCMCR_RETEN_Pos                2U                                            /*!< SCB ITCMCR: RETEN Position */
+#define SCB_ITCMCR_RETEN_Msk               (1UL << SCB_ITCMCR_RETEN_Pos)                  /*!< SCB ITCMCR: RETEN Mask */
+#define SCB_ITCMCR_RMW_Pos                  1U                                            /*!< SCB ITCMCR: RMW Position */
+#define SCB_ITCMCR_RMW_Msk                 (1UL << SCB_ITCMCR_RMW_Pos)                    /*!< SCB ITCMCR: RMW Mask */
+#define SCB_ITCMCR_EN_Pos                   0U                                            /*!< SCB ITCMCR: EN Position */
+#define SCB_ITCMCR_EN_Msk                  (1UL /*<< SCB_ITCMCR_EN_Pos*/)                 /*!< SCB ITCMCR: EN Mask */
+/* Data Tightly-Coupled Memory Control Register Definitions */
+#define SCB_DTCMCR_SZ_Pos                   3U                                            /*!< SCB DTCMCR: SZ Position */
+#define SCB_DTCMCR_SZ_Msk                  (0xFUL << SCB_DTCMCR_SZ_Pos)                   /*!< SCB DTCMCR: SZ Mask */
+#define SCB_DTCMCR_RETEN_Pos                2U                                            /*!< SCB DTCMCR: RETEN Position */
+#define SCB_DTCMCR_RETEN_Msk               (1UL << SCB_DTCMCR_RETEN_Pos)                   /*!< SCB DTCMCR: RETEN Mask */
+#define SCB_DTCMCR_RMW_Pos                  1U                                            /*!< SCB DTCMCR: RMW Position */
+#define SCB_DTCMCR_RMW_Msk                 (1UL << SCB_DTCMCR_RMW_Pos)                    /*!< SCB DTCMCR: RMW Mask */
+#define SCB_DTCMCR_EN_Pos                   0U                                            /*!< SCB DTCMCR: EN Position */
+#define SCB_DTCMCR_EN_Msk                  (1UL /*<< SCB_DTCMCR_EN_Pos*/)                 /*!< SCB DTCMCR: EN Mask */
+/* AHBP Control Register Definitions */
+#define SCB_AHBPCR_SZ_Pos                   1U                                            /*!< SCB AHBPCR: SZ Position */
+#define SCB_AHBPCR_SZ_Msk                  (7UL << SCB_AHBPCR_SZ_Pos)                     /*!< SCB AHBPCR: SZ Mask */
+#define SCB_AHBPCR_EN_Pos                   0U                                            /*!< SCB AHBPCR: EN Position */
+#define SCB_AHBPCR_EN_Msk                  (1UL /*<< SCB_AHBPCR_EN_Pos*/)                 /*!< SCB AHBPCR: EN Mask */
+/* L1 Cache Control Register Definitions */
+#define SCB_CACR_FORCEWT_Pos                2U                                            /*!< SCB CACR: FORCEWT Position */
+#define SCB_CACR_FORCEWT_Msk               (1UL << SCB_CACR_FORCEWT_Pos)                  /*!< SCB CACR: FORCEWT Mask */
+#define SCB_CACR_ECCEN_Pos                  1U                                            /*!< \deprecated SCB CACR: ECCEN Position */
+#define SCB_CACR_ECCEN_Msk                 (1UL << SCB_CACR_ECCEN_Pos)                    /*!< \deprecated SCB CACR: ECCEN Mask */
+#define SCB_CACR_ECCDIS_Pos                 1U                                            /*!< SCB CACR: ECCDIS Position */
+#define SCB_CACR_ECCDIS_Msk                (1UL << SCB_CACR_ECCDIS_Pos)                   /*!< SCB CACR: ECCDIS Mask */
+#define SCB_CACR_SIWT_Pos                   0U                                            /*!< SCB CACR: SIWT Position */
+#define SCB_CACR_SIWT_Msk                  (1UL /*<< SCB_CACR_SIWT_Pos*/)                 /*!< SCB CACR: SIWT Mask */
+/* AHBS Control Register Definitions */
+#define SCB_AHBSCR_INITCOUNT_Pos           11U                                            /*!< SCB AHBSCR: INITCOUNT Position */
+#define SCB_AHBSCR_INITCOUNT_Msk           (0x1FUL << SCB_AHBSCR_INITCOUNT_Pos)           /*!< SCB AHBSCR: INITCOUNT Mask */
+#define SCB_AHBSCR_TPRI_Pos                 2U                                            /*!< SCB AHBSCR: TPRI Position */
+#define SCB_AHBSCR_TPRI_Msk                (0x1FFUL << SCB_AHBSCR_TPRI_Pos)               /*!< SCB AHBSCR: TPRI Mask */
+#define SCB_AHBSCR_CTL_Pos                  0U                                            /*!< SCB AHBSCR: CTL Position*/
+#define SCB_AHBSCR_CTL_Msk                 (3UL /*<< SCB_AHBSCR_CTL_Pos*/)                /*!< SCB AHBSCR: CTL Mask */
+/* Auxiliary Bus Fault Status Register Definitions */
+#define SCB_ABFSR_AXIMTYPE_Pos              8U                                            /*!< SCB ABFSR: AXIMTYPE Position*/
+#define SCB_ABFSR_AXIMTYPE_Msk             (3UL << SCB_ABFSR_AXIMTYPE_Pos)                /*!< SCB ABFSR: AXIMTYPE Mask */
+#define SCB_ABFSR_EPPB_Pos                  4U                                            /*!< SCB ABFSR: EPPB Position*/
+#define SCB_ABFSR_EPPB_Msk                 (1UL << SCB_ABFSR_EPPB_Pos)                    /*!< SCB ABFSR: EPPB Mask */
+#define SCB_ABFSR_AXIM_Pos                  3U                                            /*!< SCB ABFSR: AXIM Position*/
+#define SCB_ABFSR_AXIM_Msk                 (1UL << SCB_ABFSR_AXIM_Pos)                    /*!< SCB ABFSR: AXIM Mask */
+#define SCB_ABFSR_AHBP_Pos                  2U                                            /*!< SCB ABFSR: AHBP Position*/
+#define SCB_ABFSR_AHBP_Msk                 (1UL << SCB_ABFSR_AHBP_Pos)                    /*!< SCB ABFSR: AHBP Mask */
+#define SCB_ABFSR_DTCM_Pos                  1U                                            /*!< SCB ABFSR: DTCM Position*/
+#define SCB_ABFSR_DTCM_Msk                 (1UL << SCB_ABFSR_DTCM_Pos)                    /*!< SCB ABFSR: DTCM Mask */
+#define SCB_ABFSR_ITCM_Pos                  0U                                            /*!< SCB ABFSR: ITCM Position*/
+#define SCB_ABFSR_ITCM_Msk                 (1UL /*<< SCB_ABFSR_ITCM_Pos*/)                /*!< SCB ABFSR: ITCM Mask */
+/*@} end of group CMSIS_SCB */
+  \defgroup CMSIS_SCnSCB System Controls not in SCB (SCnSCB)
+  \brief    Type definitions for the System Control and ID Register not in the SCB
+  \brief  Structure type to access the System Control and ID Register not in the SCB.
+typedef struct
+  __IM  uint32_t ICTR;                   /*!< Offset: 0x004 (R/ )  Interrupt Controller Type Register */
+  __IOM uint32_t ACTLR;                  /*!< Offset: 0x008 (R/W)  Auxiliary Control Register */
+} SCnSCB_Type;
+/* Interrupt Controller Type Register Definitions */
+#define SCnSCB_ICTR_INTLINESNUM_Pos         0U                                         /*!< ICTR: INTLINESNUM Position */
+#define SCnSCB_ICTR_INTLINESNUM_Msk        (0xFUL /*<< SCnSCB_ICTR_INTLINESNUM_Pos*/)  /*!< ICTR: INTLINESNUM Mask */
+/* Auxiliary Control Register Definitions */
+#define SCnSCB_ACTLR_DISDYNADD_Pos         26U                                         /*!< ACTLR: DISDYNADD Position */
+#define SCnSCB_ACTLR_DISDYNADD_Msk         (1UL << SCnSCB_ACTLR_DISDYNADD_Pos)         /*!< ACTLR: DISDYNADD Mask */
+#define SCnSCB_ACTLR_DISISSCH1_Pos         21U                                         /*!< ACTLR: DISISSCH1 Position */
+#define SCnSCB_ACTLR_DISISSCH1_Msk         (0x1FUL << SCnSCB_ACTLR_DISISSCH1_Pos)      /*!< ACTLR: DISISSCH1 Mask */
+#define SCnSCB_ACTLR_DISDI_Pos             16U                                         /*!< ACTLR: DISDI Position */
+#define SCnSCB_ACTLR_DISDI_Msk             (0x1FUL << SCnSCB_ACTLR_DISDI_Pos)          /*!< ACTLR: DISDI Mask */
+#define SCnSCB_ACTLR_DISCRITAXIRUR_Pos     15U                                         /*!< ACTLR: DISCRITAXIRUR Position */
+#define SCnSCB_ACTLR_DISCRITAXIRUR_Msk     (1UL << SCnSCB_ACTLR_DISCRITAXIRUR_Pos)     /*!< ACTLR: DISCRITAXIRUR Mask */
+#define SCnSCB_ACTLR_DISBTACALLOC_Pos      14U                                         /*!< ACTLR: DISBTACALLOC Position */
+#define SCnSCB_ACTLR_DISBTACALLOC_Msk      (1UL << SCnSCB_ACTLR_DISBTACALLOC_Pos)      /*!< ACTLR: DISBTACALLOC Mask */
+#define SCnSCB_ACTLR_DISBTACREAD_Pos       13U                                         /*!< ACTLR: DISBTACREAD Position */
+#define SCnSCB_ACTLR_DISBTACREAD_Msk       (1UL << SCnSCB_ACTLR_DISBTACREAD_Pos)       /*!< ACTLR: DISBTACREAD Mask */
+#define SCnSCB_ACTLR_DISITMATBFLUSH_Pos    12U                                         /*!< ACTLR: DISITMATBFLUSH Position */
+#define SCnSCB_ACTLR_DISITMATBFLUSH_Msk    (1UL << SCnSCB_ACTLR_DISITMATBFLUSH_Pos)    /*!< ACTLR: DISITMATBFLUSH Mask */
+#define SCnSCB_ACTLR_DISRAMODE_Pos         11U                                         /*!< ACTLR: DISRAMODE Position */
+#define SCnSCB_ACTLR_DISRAMODE_Msk         (1UL << SCnSCB_ACTLR_DISRAMODE_Pos)         /*!< ACTLR: DISRAMODE Mask */
+#define SCnSCB_ACTLR_FPEXCODIS_Pos         10U                                         /*!< ACTLR: FPEXCODIS Position */
+#define SCnSCB_ACTLR_FPEXCODIS_Msk         (1UL << SCnSCB_ACTLR_FPEXCODIS_Pos)         /*!< ACTLR: FPEXCODIS Mask */
+#define SCnSCB_ACTLR_DISFOLD_Pos            2U                                         /*!< ACTLR: DISFOLD Position */
+#define SCnSCB_ACTLR_DISFOLD_Msk           (1UL << SCnSCB_ACTLR_DISFOLD_Pos)           /*!< ACTLR: DISFOLD Mask */
+#define SCnSCB_ACTLR_DISMCYCINT_Pos         0U                                         /*!< ACTLR: DISMCYCINT Position */
+#define SCnSCB_ACTLR_DISMCYCINT_Msk        (1UL /*<< SCnSCB_ACTLR_DISMCYCINT_Pos*/)    /*!< ACTLR: DISMCYCINT Mask */
+/*@} end of group CMSIS_SCnotSCB */
+  \defgroup CMSIS_SysTick     System Tick Timer (SysTick)
+  \brief    Type definitions for the System Timer Registers.
+  \brief  Structure type to access the System Timer (SysTick).
+typedef struct
+  __IOM uint32_t CTRL;                   /*!< Offset: 0x000 (R/W)  SysTick Control and Status Register */
+  __IOM uint32_t LOAD;                   /*!< Offset: 0x004 (R/W)  SysTick Reload Value Register */
+  __IOM uint32_t VAL;                    /*!< Offset: 0x008 (R/W)  SysTick Current Value Register */
+  __IM  uint32_t CALIB;                  /*!< Offset: 0x00C (R/ )  SysTick Calibration Register */
+} SysTick_Type;
+/* SysTick Control / Status Register Definitions */
+#define SysTick_CTRL_COUNTFLAG_Pos         16U                                            /*!< SysTick CTRL: COUNTFLAG Position */
+#define SysTick_CTRL_COUNTFLAG_Msk         (1UL << SysTick_CTRL_COUNTFLAG_Pos)            /*!< SysTick CTRL: COUNTFLAG Mask */
+#define SysTick_CTRL_CLKSOURCE_Pos          2U                                            /*!< SysTick CTRL: CLKSOURCE Position */
+#define SysTick_CTRL_CLKSOURCE_Msk         (1UL << SysTick_CTRL_CLKSOURCE_Pos)            /*!< SysTick CTRL: CLKSOURCE Mask */
+#define SysTick_CTRL_TICKINT_Pos            1U                                            /*!< SysTick CTRL: TICKINT Position */
+#define SysTick_CTRL_TICKINT_Msk           (1UL << SysTick_CTRL_TICKINT_Pos)              /*!< SysTick CTRL: TICKINT Mask */
+#define SysTick_CTRL_ENABLE_Pos             0U                                            /*!< SysTick CTRL: ENABLE Position */
+#define SysTick_CTRL_ENABLE_Msk            (1UL /*<< SysTick_CTRL_ENABLE_Pos*/)           /*!< SysTick CTRL: ENABLE Mask */
+/* SysTick Reload Register Definitions */
+#define SysTick_LOAD_RELOAD_Pos             0U                                            /*!< SysTick LOAD: RELOAD Position */
+#define SysTick_LOAD_RELOAD_Msk            (0xFFFFFFUL /*<< SysTick_LOAD_RELOAD_Pos*/)    /*!< SysTick LOAD: RELOAD Mask */
+/* SysTick Current Register Definitions */
+#define SysTick_VAL_CURRENT_Pos             0U                                            /*!< SysTick VAL: CURRENT Position */
+#define SysTick_VAL_CURRENT_Msk            (0xFFFFFFUL /*<< SysTick_VAL_CURRENT_Pos*/)    /*!< SysTick VAL: CURRENT Mask */
+/* SysTick Calibration Register Definitions */
+#define SysTick_CALIB_NOREF_Pos            31U                                            /*!< SysTick CALIB: NOREF Position */
+#define SysTick_CALIB_NOREF_Msk            (1UL << SysTick_CALIB_NOREF_Pos)               /*!< SysTick CALIB: NOREF Mask */
+#define SysTick_CALIB_SKEW_Pos             30U                                            /*!< SysTick CALIB: SKEW Position */
+#define SysTick_CALIB_SKEW_Msk             (1UL << SysTick_CALIB_SKEW_Pos)                /*!< SysTick CALIB: SKEW Mask */
+#define SysTick_CALIB_TENMS_Pos             0U                                            /*!< SysTick CALIB: TENMS Position */
+#define SysTick_CALIB_TENMS_Msk            (0xFFFFFFUL /*<< SysTick_CALIB_TENMS_Pos*/)    /*!< SysTick CALIB: TENMS Mask */
+/*@} end of group CMSIS_SysTick */
+  \defgroup CMSIS_ITM     Instrumentation Trace Macrocell (ITM)
+  \brief    Type definitions for the Instrumentation Trace Macrocell (ITM)
+  \brief  Structure type to access the Instrumentation Trace Macrocell Register (ITM).
+typedef struct
+  __OM  union
+    __OM  uint8_t    u8;                 /*!< Offset: 0x000 ( /W)  ITM Stimulus Port 8-bit */
+    __OM  uint16_t   u16;                /*!< Offset: 0x000 ( /W)  ITM Stimulus Port 16-bit */
+    __OM  uint32_t   u32;                /*!< Offset: 0x000 ( /W)  ITM Stimulus Port 32-bit */
+  }  PORT [32U];                         /*!< Offset: 0x000 ( /W)  ITM Stimulus Port Registers */
+        uint32_t RESERVED0[864U];
+  __IOM uint32_t TER;                    /*!< Offset: 0xE00 (R/W)  ITM Trace Enable Register */
+        uint32_t RESERVED1[15U];
+  __IOM uint32_t TPR;                    /*!< Offset: 0xE40 (R/W)  ITM Trace Privilege Register */
+        uint32_t RESERVED2[15U];
+  __IOM uint32_t TCR;                    /*!< Offset: 0xE80 (R/W)  ITM Trace Control Register */
+        uint32_t RESERVED3[32U];
+        uint32_t RESERVED4[43U];
+  __OM  uint32_t LAR;                    /*!< Offset: 0xFB0 ( /W)  ITM Lock Access Register */
+  __IM  uint32_t LSR;                    /*!< Offset: 0xFB4 (R/ )  ITM Lock Status Register */
+        uint32_t RESERVED5[6U];
+  __IM  uint32_t PID4;                   /*!< Offset: 0xFD0 (R/ )  ITM Peripheral Identification Register #4 */
+  __IM  uint32_t PID5;                   /*!< Offset: 0xFD4 (R/ )  ITM Peripheral Identification Register #5 */
+  __IM  uint32_t PID6;                   /*!< Offset: 0xFD8 (R/ )  ITM Peripheral Identification Register #6 */
+  __IM  uint32_t PID7;                   /*!< Offset: 0xFDC (R/ )  ITM Peripheral Identification Register #7 */
+  __IM  uint32_t PID0;                   /*!< Offset: 0xFE0 (R/ )  ITM Peripheral Identification Register #0 */
+  __IM  uint32_t PID1;                   /*!< Offset: 0xFE4 (R/ )  ITM Peripheral Identification Register #1 */
+  __IM  uint32_t PID2;                   /*!< Offset: 0xFE8 (R/ )  ITM Peripheral Identification Register #2 */
+  __IM  uint32_t PID3;                   /*!< Offset: 0xFEC (R/ )  ITM Peripheral Identification Register #3 */
+  __IM  uint32_t CID0;                   /*!< Offset: 0xFF0 (R/ )  ITM Component  Identification Register #0 */
+  __IM  uint32_t CID1;                   /*!< Offset: 0xFF4 (R/ )  ITM Component  Identification Register #1 */
+  __IM  uint32_t CID2;                   /*!< Offset: 0xFF8 (R/ )  ITM Component  Identification Register #2 */
+  __IM  uint32_t CID3;                   /*!< Offset: 0xFFC (R/ )  ITM Component  Identification Register #3 */
+} ITM_Type;
+/* ITM Trace Privilege Register Definitions */
+#define ITM_TPR_PRIVMASK_Pos                0U                                            /*!< ITM TPR: PRIVMASK Position */
+#define ITM_TPR_PRIVMASK_Msk               (0xFFFFFFFFUL /*<< ITM_TPR_PRIVMASK_Pos*/)     /*!< ITM TPR: PRIVMASK Mask */
+/* ITM Trace Control Register Definitions */
+#define ITM_TCR_BUSY_Pos                   23U                                            /*!< ITM TCR: BUSY Position */
+#define ITM_TCR_BUSY_Msk                   (1UL << ITM_TCR_BUSY_Pos)                      /*!< ITM TCR: BUSY Mask */
+#define ITM_TCR_TRACEBUSID_Pos             16U                                            /*!< ITM TCR: ATBID Position */
+#define ITM_TCR_TRACEBUSID_Msk             (0x7FUL << ITM_TCR_TRACEBUSID_Pos)             /*!< ITM TCR: ATBID Mask */
+#define ITM_TCR_GTSFREQ_Pos                10U                                            /*!< ITM TCR: Global timestamp frequency Position */
+#define ITM_TCR_GTSFREQ_Msk                (3UL << ITM_TCR_GTSFREQ_Pos)                   /*!< ITM TCR: Global timestamp frequency Mask */
+#define ITM_TCR_TSPRESCALE_Pos              8U                                            /*!< ITM TCR: TSPrescale Position */
+#define ITM_TCR_TSPRESCALE_Msk             (3UL << ITM_TCR_TSPRESCALE_Pos)                /*!< ITM TCR: TSPrescale Mask */
+#define ITM_TCR_SWOENA_Pos                  4U                                            /*!< ITM TCR: SWOENA Position */
+#define ITM_TCR_SWOENA_Msk                 (1UL << ITM_TCR_SWOENA_Pos)                    /*!< ITM TCR: SWOENA Mask */
+#define ITM_TCR_DWTENA_Pos                  3U                                            /*!< ITM TCR: DWTENA Position */
+#define ITM_TCR_DWTENA_Msk                 (1UL << ITM_TCR_DWTENA_Pos)                    /*!< ITM TCR: DWTENA Mask */
+#define ITM_TCR_SYNCENA_Pos                 2U                                            /*!< ITM TCR: SYNCENA Position */
+#define ITM_TCR_SYNCENA_Msk                (1UL << ITM_TCR_SYNCENA_Pos)                   /*!< ITM TCR: SYNCENA Mask */
+#define ITM_TCR_TSENA_Pos                   1U                                            /*!< ITM TCR: TSENA Position */
+#define ITM_TCR_TSENA_Msk                  (1UL << ITM_TCR_TSENA_Pos)                     /*!< ITM TCR: TSENA Mask */
+#define ITM_TCR_ITMENA_Pos                  0U                                            /*!< ITM TCR: ITM Enable bit Position */
+#define ITM_TCR_ITMENA_Msk                 (1UL /*<< ITM_TCR_ITMENA_Pos*/)                /*!< ITM TCR: ITM Enable bit Mask */
+/* ITM Lock Status Register Definitions */
+#define ITM_LSR_BYTEACC_Pos                 2U                                            /*!< ITM LSR: ByteAcc Position */
+#define ITM_LSR_BYTEACC_Msk                (1UL << ITM_LSR_BYTEACC_Pos)                   /*!< ITM LSR: ByteAcc Mask */
+#define ITM_LSR_ACCESS_Pos                  1U                                            /*!< ITM LSR: Access Position */
+#define ITM_LSR_ACCESS_Msk                 (1UL << ITM_LSR_ACCESS_Pos)                    /*!< ITM LSR: Access Mask */
+#define ITM_LSR_PRESENT_Pos                 0U                                            /*!< ITM LSR: Present Position */
+#define ITM_LSR_PRESENT_Msk                (1UL /*<< ITM_LSR_PRESENT_Pos*/)               /*!< ITM LSR: Present Mask */
+/*@}*/ /* end of group CMSIS_ITM */
+  \defgroup CMSIS_DWT     Data Watchpoint and Trace (DWT)
+  \brief    Type definitions for the Data Watchpoint and Trace (DWT)
+  \brief  Structure type to access the Data Watchpoint and Trace Register (DWT).
+typedef struct
+  __IOM uint32_t CTRL;                   /*!< Offset: 0x000 (R/W)  Control Register */
+  __IOM uint32_t CYCCNT;                 /*!< Offset: 0x004 (R/W)  Cycle Count Register */
+  __IOM uint32_t CPICNT;                 /*!< Offset: 0x008 (R/W)  CPI Count Register */
+  __IOM uint32_t EXCCNT;                 /*!< Offset: 0x00C (R/W)  Exception Overhead Count Register */
+  __IOM uint32_t SLEEPCNT;               /*!< Offset: 0x010 (R/W)  Sleep Count Register */
+  __IOM uint32_t LSUCNT;                 /*!< Offset: 0x014 (R/W)  LSU Count Register */
+  __IOM uint32_t FOLDCNT;                /*!< Offset: 0x018 (R/W)  Folded-instruction Count Register */
+  __IM  uint32_t PCSR;                   /*!< Offset: 0x01C (R/ )  Program Counter Sample Register */
+  __IOM uint32_t COMP0;                  /*!< Offset: 0x020 (R/W)  Comparator Register 0 */
+  __IOM uint32_t MASK0;                  /*!< Offset: 0x024 (R/W)  Mask Register 0 */
+  __IOM uint32_t FUNCTION0;              /*!< Offset: 0x028 (R/W)  Function Register 0 */
+  __IOM uint32_t COMP1;                  /*!< Offset: 0x030 (R/W)  Comparator Register 1 */
+  __IOM uint32_t MASK1;                  /*!< Offset: 0x034 (R/W)  Mask Register 1 */
+  __IOM uint32_t FUNCTION1;              /*!< Offset: 0x038 (R/W)  Function Register 1 */
+        uint32_t RESERVED1[1U];
+  __IOM uint32_t COMP2;                  /*!< Offset: 0x040 (R/W)  Comparator Register 2 */
+  __IOM uint32_t MASK2;                  /*!< Offset: 0x044 (R/W)  Mask Register 2 */
+  __IOM uint32_t FUNCTION2;              /*!< Offset: 0x048 (R/W)  Function Register 2 */
+        uint32_t RESERVED2[1U];
+  __IOM uint32_t COMP3;                  /*!< Offset: 0x050 (R/W)  Comparator Register 3 */
+  __IOM uint32_t MASK3;                  /*!< Offset: 0x054 (R/W)  Mask Register 3 */
+  __IOM uint32_t FUNCTION3;              /*!< Offset: 0x058 (R/W)  Function Register 3 */
+        uint32_t RESERVED3[981U];
+  __OM  uint32_t LAR;                    /*!< Offset: 0xFB0 (  W)  Lock Access Register */
+  __IM  uint32_t LSR;                    /*!< Offset: 0xFB4 (R  )  Lock Status Register */
+} DWT_Type;
+/* DWT Control Register Definitions */
+#define DWT_CTRL_NUMCOMP_Pos               28U                                         /*!< DWT CTRL: NUMCOMP Position */
+#define DWT_CTRL_NUMCOMP_Msk               (0xFUL << DWT_CTRL_NUMCOMP_Pos)             /*!< DWT CTRL: NUMCOMP Mask */
+#define DWT_CTRL_NOTRCPKT_Pos              27U                                         /*!< DWT CTRL: NOTRCPKT Position */
+#define DWT_CTRL_NOTRCPKT_Msk              (0x1UL << DWT_CTRL_NOTRCPKT_Pos)            /*!< DWT CTRL: NOTRCPKT Mask */
+#define DWT_CTRL_NOEXTTRIG_Pos             26U                                         /*!< DWT CTRL: NOEXTTRIG Position */
+#define DWT_CTRL_NOEXTTRIG_Msk             (0x1UL << DWT_CTRL_NOEXTTRIG_Pos)           /*!< DWT CTRL: NOEXTTRIG Mask */
+#define DWT_CTRL_NOCYCCNT_Pos              25U                                         /*!< DWT CTRL: NOCYCCNT Position */
+#define DWT_CTRL_NOCYCCNT_Msk              (0x1UL << DWT_CTRL_NOCYCCNT_Pos)            /*!< DWT CTRL: NOCYCCNT Mask */
+#define DWT_CTRL_NOPRFCNT_Pos              24U                                         /*!< DWT CTRL: NOPRFCNT Position */
+#define DWT_CTRL_NOPRFCNT_Msk              (0x1UL << DWT_CTRL_NOPRFCNT_Pos)            /*!< DWT CTRL: NOPRFCNT Mask */
+#define DWT_CTRL_CYCEVTENA_Pos             22U                                         /*!< DWT CTRL: CYCEVTENA Position */
+#define DWT_CTRL_CYCEVTENA_Msk             (0x1UL << DWT_CTRL_CYCEVTENA_Pos)           /*!< DWT CTRL: CYCEVTENA Mask */
+#define DWT_CTRL_FOLDEVTENA_Pos            21U                                         /*!< DWT CTRL: FOLDEVTENA Position */
+#define DWT_CTRL_FOLDEVTENA_Msk            (0x1UL << DWT_CTRL_FOLDEVTENA_Pos)          /*!< DWT CTRL: FOLDEVTENA Mask */
+#define DWT_CTRL_LSUEVTENA_Pos             20U                                         /*!< DWT CTRL: LSUEVTENA Position */
+#define DWT_CTRL_LSUEVTENA_Msk             (0x1UL << DWT_CTRL_LSUEVTENA_Pos)           /*!< DWT CTRL: LSUEVTENA Mask */
+#define DWT_CTRL_SLEEPEVTENA_Pos           19U                                         /*!< DWT CTRL: SLEEPEVTENA Position */
+#define DWT_CTRL_SLEEPEVTENA_Msk           (0x1UL << DWT_CTRL_SLEEPEVTENA_Pos)         /*!< DWT CTRL: SLEEPEVTENA Mask */
+#define DWT_CTRL_EXCEVTENA_Pos             18U                                         /*!< DWT CTRL: EXCEVTENA Position */
+#define DWT_CTRL_EXCEVTENA_Msk             (0x1UL << DWT_CTRL_EXCEVTENA_Pos)           /*!< DWT CTRL: EXCEVTENA Mask */
+#define DWT_CTRL_CPIEVTENA_Pos             17U                                         /*!< DWT CTRL: CPIEVTENA Position */
+#define DWT_CTRL_CPIEVTENA_Msk             (0x1UL << DWT_CTRL_CPIEVTENA_Pos)           /*!< DWT CTRL: CPIEVTENA Mask */
+#define DWT_CTRL_EXCTRCENA_Pos             16U                                         /*!< DWT CTRL: EXCTRCENA Position */
+#define DWT_CTRL_EXCTRCENA_Msk             (0x1UL << DWT_CTRL_EXCTRCENA_Pos)           /*!< DWT CTRL: EXCTRCENA Mask */
+#define DWT_CTRL_PCSAMPLENA_Pos            12U                                         /*!< DWT CTRL: PCSAMPLENA Position */
+#define DWT_CTRL_PCSAMPLENA_Msk            (0x1UL << DWT_CTRL_PCSAMPLENA_Pos)          /*!< DWT CTRL: PCSAMPLENA Mask */
+#define DWT_CTRL_SYNCTAP_Pos               10U                                         /*!< DWT CTRL: SYNCTAP Position */
+#define DWT_CTRL_SYNCTAP_Msk               (0x3UL << DWT_CTRL_SYNCTAP_Pos)             /*!< DWT CTRL: SYNCTAP Mask */
+#define DWT_CTRL_CYCTAP_Pos                 9U                                         /*!< DWT CTRL: CYCTAP Position */
+#define DWT_CTRL_CYCTAP_Msk                (0x1UL << DWT_CTRL_CYCTAP_Pos)              /*!< DWT CTRL: CYCTAP Mask */
+#define DWT_CTRL_POSTINIT_Pos               5U                                         /*!< DWT CTRL: POSTINIT Position */
+#define DWT_CTRL_POSTINIT_Msk              (0xFUL << DWT_CTRL_POSTINIT_Pos)            /*!< DWT CTRL: POSTINIT Mask */
+#define DWT_CTRL_POSTPRESET_Pos             1U                                         /*!< DWT CTRL: POSTPRESET Position */
+#define DWT_CTRL_POSTPRESET_Msk            (0xFUL << DWT_CTRL_POSTPRESET_Pos)          /*!< DWT CTRL: POSTPRESET Mask */
+#define DWT_CTRL_CYCCNTENA_Pos              0U                                         /*!< DWT CTRL: CYCCNTENA Position */
+#define DWT_CTRL_CYCCNTENA_Msk             (0x1UL /*<< DWT_CTRL_CYCCNTENA_Pos*/)       /*!< DWT CTRL: CYCCNTENA Mask */
+/* DWT CPI Count Register Definitions */
+#define DWT_CPICNT_CPICNT_Pos               0U                                         /*!< DWT CPICNT: CPICNT Position */
+#define DWT_CPICNT_CPICNT_Msk              (0xFFUL /*<< DWT_CPICNT_CPICNT_Pos*/)       /*!< DWT CPICNT: CPICNT Mask */
+/* DWT Exception Overhead Count Register Definitions */
+#define DWT_EXCCNT_EXCCNT_Pos               0U                                         /*!< DWT EXCCNT: EXCCNT Position */
+#define DWT_EXCCNT_EXCCNT_Msk              (0xFFUL /*<< DWT_EXCCNT_EXCCNT_Pos*/)       /*!< DWT EXCCNT: EXCCNT Mask */
+/* DWT Sleep Count Register Definitions */
+#define DWT_SLEEPCNT_SLEEPCNT_Pos           0U                                         /*!< DWT SLEEPCNT: SLEEPCNT Position */
+#define DWT_SLEEPCNT_SLEEPCNT_Msk          (0xFFUL /*<< DWT_SLEEPCNT_SLEEPCNT_Pos*/)   /*!< DWT SLEEPCNT: SLEEPCNT Mask */
+/* DWT LSU Count Register Definitions */
+#define DWT_LSUCNT_LSUCNT_Pos               0U                                         /*!< DWT LSUCNT: LSUCNT Position */
+#define DWT_LSUCNT_LSUCNT_Msk              (0xFFUL /*<< DWT_LSUCNT_LSUCNT_Pos*/)       /*!< DWT LSUCNT: LSUCNT Mask */
+/* DWT Folded-instruction Count Register Definitions */
+#define DWT_FOLDCNT_FOLDCNT_Pos             0U                                         /*!< DWT FOLDCNT: FOLDCNT Position */
+#define DWT_FOLDCNT_FOLDCNT_Msk            (0xFFUL /*<< DWT_FOLDCNT_FOLDCNT_Pos*/)     /*!< DWT FOLDCNT: FOLDCNT Mask */
+/* DWT Comparator Mask Register Definitions */
+#define DWT_MASK_MASK_Pos                   0U                                         /*!< DWT MASK: MASK Position */
+#define DWT_MASK_MASK_Msk                  (0x1FUL /*<< DWT_MASK_MASK_Pos*/)           /*!< DWT MASK: MASK Mask */
+/* DWT Comparator Function Register Definitions */
+#define DWT_FUNCTION_MATCHED_Pos           24U                                         /*!< DWT FUNCTION: MATCHED Position */
+#define DWT_FUNCTION_MATCHED_Msk           (0x1UL << DWT_FUNCTION_MATCHED_Pos)         /*!< DWT FUNCTION: MATCHED Mask */
+#define DWT_FUNCTION_DATAVADDR1_Pos        16U                                         /*!< DWT FUNCTION: DATAVADDR1 Position */
+#define DWT_FUNCTION_DATAVADDR1_Msk        (0xFUL << DWT_FUNCTION_DATAVADDR1_Pos)      /*!< DWT FUNCTION: DATAVADDR1 Mask */
+#define DWT_FUNCTION_DATAVADDR0_Pos        12U                                         /*!< DWT FUNCTION: DATAVADDR0 Position */
+#define DWT_FUNCTION_DATAVADDR0_Msk        (0xFUL << DWT_FUNCTION_DATAVADDR0_Pos)      /*!< DWT FUNCTION: DATAVADDR0 Mask */
+#define DWT_FUNCTION_DATAVSIZE_Pos         10U                                         /*!< DWT FUNCTION: DATAVSIZE Position */
+#define DWT_FUNCTION_DATAVSIZE_Msk         (0x3UL << DWT_FUNCTION_DATAVSIZE_Pos)       /*!< DWT FUNCTION: DATAVSIZE Mask */
+#define DWT_FUNCTION_LNK1ENA_Pos            9U                                         /*!< DWT FUNCTION: LNK1ENA Position */
+#define DWT_FUNCTION_LNK1ENA_Msk           (0x1UL << DWT_FUNCTION_LNK1ENA_Pos)         /*!< DWT FUNCTION: LNK1ENA Mask */
+#define DWT_FUNCTION_DATAVMATCH_Pos         8U                                         /*!< DWT FUNCTION: DATAVMATCH Position */
+#define DWT_FUNCTION_DATAVMATCH_Msk        (0x1UL << DWT_FUNCTION_DATAVMATCH_Pos)      /*!< DWT FUNCTION: DATAVMATCH Mask */
+#define DWT_FUNCTION_CYCMATCH_Pos           7U                                         /*!< DWT FUNCTION: CYCMATCH Position */
+#define DWT_FUNCTION_CYCMATCH_Msk          (0x1UL << DWT_FUNCTION_CYCMATCH_Pos)        /*!< DWT FUNCTION: CYCMATCH Mask */
+#define DWT_FUNCTION_EMITRANGE_Pos          5U                                         /*!< DWT FUNCTION: EMITRANGE Position */
+#define DWT_FUNCTION_EMITRANGE_Msk         (0x1UL << DWT_FUNCTION_EMITRANGE_Pos)       /*!< DWT FUNCTION: EMITRANGE Mask */
+#define DWT_FUNCTION_FUNCTION_Pos           0U                                         /*!< DWT FUNCTION: FUNCTION Position */
+#define DWT_FUNCTION_FUNCTION_Msk          (0xFUL /*<< DWT_FUNCTION_FUNCTION_Pos*/)    /*!< DWT FUNCTION: FUNCTION Mask */
+/*@}*/ /* end of group CMSIS_DWT */
+  \defgroup CMSIS_TPI     Trace Port Interface (TPI)
+  \brief    Type definitions for the Trace Port Interface (TPI)
+  \brief  Structure type to access the Trace Port Interface Register (TPI).
+typedef struct
+  __IM  uint32_t SSPSR;                  /*!< Offset: 0x000 (R/ )  Supported Parallel Port Size Register */
+  __IOM uint32_t CSPSR;                  /*!< Offset: 0x004 (R/W)  Current Parallel Port Size Register */
+        uint32_t RESERVED0[2U];
+  __IOM uint32_t ACPR;                   /*!< Offset: 0x010 (R/W)  Asynchronous Clock Prescaler Register */
+        uint32_t RESERVED1[55U];
+  __IOM uint32_t SPPR;                   /*!< Offset: 0x0F0 (R/W)  Selected Pin Protocol Register */
+        uint32_t RESERVED2[131U];
+  __IM  uint32_t FFSR;                   /*!< Offset: 0x300 (R/ )  Formatter and Flush Status Register */
+  __IOM uint32_t FFCR;                   /*!< Offset: 0x304 (R/W)  Formatter and Flush Control Register */
+  __IM  uint32_t FSCR;                   /*!< Offset: 0x308 (R/ )  Formatter Synchronization Counter Register */
+        uint32_t RESERVED3[759U];
+  __IM  uint32_t TRIGGER;                /*!< Offset: 0xEE8 (R/ )  TRIGGER Register */
+  __IM  uint32_t FIFO0;                  /*!< Offset: 0xEEC (R/ )  Integration ETM Data */
+  __IM  uint32_t ITATBCTR2;              /*!< Offset: 0xEF0 (R/ )  ITATBCTR2 */
+        uint32_t RESERVED4[1U];
+  __IM  uint32_t ITATBCTR0;              /*!< Offset: 0xEF8 (R/ )  ITATBCTR0 */
+  __IM  uint32_t FIFO1;                  /*!< Offset: 0xEFC (R/ )  Integration ITM Data */
+  __IOM uint32_t ITCTRL;                 /*!< Offset: 0xF00 (R/W)  Integration Mode Control */
+        uint32_t RESERVED5[39U];
+  __IOM uint32_t CLAIMSET;               /*!< Offset: 0xFA0 (R/W)  Claim tag set */
+  __IOM uint32_t CLAIMCLR;               /*!< Offset: 0xFA4 (R/W)  Claim tag clear */
+        uint32_t RESERVED7[8U];
+  __IM  uint32_t DEVID;                  /*!< Offset: 0xFC8 (R/ )  TPIU_DEVID */
+  __IM  uint32_t DEVTYPE;                /*!< Offset: 0xFCC (R/ )  TPIU_DEVTYPE */
+} TPI_Type;
+/* TPI Asynchronous Clock Prescaler Register Definitions */
+#define TPI_ACPR_PRESCALER_Pos              0U                                         /*!< TPI ACPR: PRESCALER Position */
+#define TPI_ACPR_PRESCALER_Msk             (0x1FFFUL /*<< TPI_ACPR_PRESCALER_Pos*/)    /*!< TPI ACPR: PRESCALER Mask */
+/* TPI Selected Pin Protocol Register Definitions */
+#define TPI_SPPR_TXMODE_Pos                 0U                                         /*!< TPI SPPR: TXMODE Position */
+#define TPI_SPPR_TXMODE_Msk                (0x3UL /*<< TPI_SPPR_TXMODE_Pos*/)          /*!< TPI SPPR: TXMODE Mask */
+/* TPI Formatter and Flush Status Register Definitions */
+#define TPI_FFSR_FtNonStop_Pos              3U                                         /*!< TPI FFSR: FtNonStop Position */
+#define TPI_FFSR_FtNonStop_Msk             (0x1UL << TPI_FFSR_FtNonStop_Pos)           /*!< TPI FFSR: FtNonStop Mask */
+#define TPI_FFSR_TCPresent_Pos              2U                                         /*!< TPI FFSR: TCPresent Position */
+#define TPI_FFSR_TCPresent_Msk             (0x1UL << TPI_FFSR_TCPresent_Pos)           /*!< TPI FFSR: TCPresent Mask */
+#define TPI_FFSR_FtStopped_Pos              1U                                         /*!< TPI FFSR: FtStopped Position */
+#define TPI_FFSR_FtStopped_Msk             (0x1UL << TPI_FFSR_FtStopped_Pos)           /*!< TPI FFSR: FtStopped Mask */
+#define TPI_FFSR_FlInProg_Pos               0U                                         /*!< TPI FFSR: FlInProg Position */
+#define TPI_FFSR_FlInProg_Msk              (0x1UL /*<< TPI_FFSR_FlInProg_Pos*/)        /*!< TPI FFSR: FlInProg Mask */
+/* TPI Formatter and Flush Control Register Definitions */
+#define TPI_FFCR_TrigIn_Pos                 8U                                         /*!< TPI FFCR: TrigIn Position */
+#define TPI_FFCR_TrigIn_Msk                (0x1UL << TPI_FFCR_TrigIn_Pos)              /*!< TPI FFCR: TrigIn Mask */
+#define TPI_FFCR_EnFCont_Pos                1U                                         /*!< TPI FFCR: EnFCont Position */
+#define TPI_FFCR_EnFCont_Msk               (0x1UL << TPI_FFCR_EnFCont_Pos)             /*!< TPI FFCR: EnFCont Mask */
+/* TPI TRIGGER Register Definitions */
+#define TPI_TRIGGER_TRIGGER_Pos             0U                                         /*!< TPI TRIGGER: TRIGGER Position */
+#define TPI_TRIGGER_TRIGGER_Msk            (0x1UL /*<< TPI_TRIGGER_TRIGGER_Pos*/)      /*!< TPI TRIGGER: TRIGGER Mask */
+/* TPI Integration ETM Data Register Definitions (FIFO0) */
+#define TPI_FIFO0_ITM_ATVALID_Pos          29U                                         /*!< TPI FIFO0: ITM_ATVALID Position */
+#define TPI_FIFO0_ITM_ATVALID_Msk          (0x1UL << TPI_FIFO0_ITM_ATVALID_Pos)        /*!< TPI FIFO0: ITM_ATVALID Mask */
+#define TPI_FIFO0_ITM_bytecount_Pos        27U                                         /*!< TPI FIFO0: ITM_bytecount Position */
+#define TPI_FIFO0_ITM_bytecount_Msk        (0x3UL << TPI_FIFO0_ITM_bytecount_Pos)      /*!< TPI FIFO0: ITM_bytecount Mask */
+#define TPI_FIFO0_ETM_ATVALID_Pos          26U                                         /*!< TPI FIFO0: ETM_ATVALID Position */
+#define TPI_FIFO0_ETM_ATVALID_Msk          (0x1UL << TPI_FIFO0_ETM_ATVALID_Pos)        /*!< TPI FIFO0: ETM_ATVALID Mask */
+#define TPI_FIFO0_ETM_bytecount_Pos        24U                                         /*!< TPI FIFO0: ETM_bytecount Position */
+#define TPI_FIFO0_ETM_bytecount_Msk        (0x3UL << TPI_FIFO0_ETM_bytecount_Pos)      /*!< TPI FIFO0: ETM_bytecount Mask */
+#define TPI_FIFO0_ETM2_Pos                 16U                                         /*!< TPI FIFO0: ETM2 Position */
+#define TPI_FIFO0_ETM2_Msk                 (0xFFUL << TPI_FIFO0_ETM2_Pos)              /*!< TPI FIFO0: ETM2 Mask */
+#define TPI_FIFO0_ETM1_Pos                  8U                                         /*!< TPI FIFO0: ETM1 Position */
+#define TPI_FIFO0_ETM1_Msk                 (0xFFUL << TPI_FIFO0_ETM1_Pos)              /*!< TPI FIFO0: ETM1 Mask */
+#define TPI_FIFO0_ETM0_Pos                  0U                                         /*!< TPI FIFO0: ETM0 Position */
+#define TPI_FIFO0_ETM0_Msk                 (0xFFUL /*<< TPI_FIFO0_ETM0_Pos*/)          /*!< TPI FIFO0: ETM0 Mask */
+/* TPI ITATBCTR2 Register Definitions */
+#define TPI_ITATBCTR2_ATREADY2_Pos          0U                                         /*!< TPI ITATBCTR2: ATREADY2 Position */
+#define TPI_ITATBCTR2_ATREADY2_Msk         (0x1UL /*<< TPI_ITATBCTR2_ATREADY2_Pos*/)   /*!< TPI ITATBCTR2: ATREADY2 Mask */
+#define TPI_ITATBCTR2_ATREADY1_Pos          0U                                         /*!< TPI ITATBCTR2: ATREADY1 Position */
+#define TPI_ITATBCTR2_ATREADY1_Msk         (0x1UL /*<< TPI_ITATBCTR2_ATREADY1_Pos*/)   /*!< TPI ITATBCTR2: ATREADY1 Mask */
+/* TPI Integration ITM Data Register Definitions (FIFO1) */
+#define TPI_FIFO1_ITM_ATVALID_Pos          29U                                         /*!< TPI FIFO1: ITM_ATVALID Position */
+#define TPI_FIFO1_ITM_ATVALID_Msk          (0x1UL << TPI_FIFO1_ITM_ATVALID_Pos)        /*!< TPI FIFO1: ITM_ATVALID Mask */
+#define TPI_FIFO1_ITM_bytecount_Pos        27U                                         /*!< TPI FIFO1: ITM_bytecount Position */
+#define TPI_FIFO1_ITM_bytecount_Msk        (0x3UL << TPI_FIFO1_ITM_bytecount_Pos)      /*!< TPI FIFO1: ITM_bytecount Mask */
+#define TPI_FIFO1_ETM_ATVALID_Pos          26U                                         /*!< TPI FIFO1: ETM_ATVALID Position */
+#define TPI_FIFO1_ETM_ATVALID_Msk          (0x1UL << TPI_FIFO1_ETM_ATVALID_Pos)        /*!< TPI FIFO1: ETM_ATVALID Mask */
+#define TPI_FIFO1_ETM_bytecount_Pos        24U                                         /*!< TPI FIFO1: ETM_bytecount Position */
+#define TPI_FIFO1_ETM_bytecount_Msk        (0x3UL << TPI_FIFO1_ETM_bytecount_Pos)      /*!< TPI FIFO1: ETM_bytecount Mask */
+#define TPI_FIFO1_ITM2_Pos                 16U                                         /*!< TPI FIFO1: ITM2 Position */
+#define TPI_FIFO1_ITM2_Msk                 (0xFFUL << TPI_FIFO1_ITM2_Pos)              /*!< TPI FIFO1: ITM2 Mask */
+#define TPI_FIFO1_ITM1_Pos                  8U                                         /*!< TPI FIFO1: ITM1 Position */
+#define TPI_FIFO1_ITM1_Msk                 (0xFFUL << TPI_FIFO1_ITM1_Pos)              /*!< TPI FIFO1: ITM1 Mask */
+#define TPI_FIFO1_ITM0_Pos                  0U                                         /*!< TPI FIFO1: ITM0 Position */
+#define TPI_FIFO1_ITM0_Msk                 (0xFFUL /*<< TPI_FIFO1_ITM0_Pos*/)          /*!< TPI FIFO1: ITM0 Mask */
+/* TPI ITATBCTR0 Register Definitions */
+#define TPI_ITATBCTR0_ATREADY2_Pos          0U                                         /*!< TPI ITATBCTR0: ATREADY2 Position */
+#define TPI_ITATBCTR0_ATREADY2_Msk         (0x1UL /*<< TPI_ITATBCTR0_ATREADY2_Pos*/)   /*!< TPI ITATBCTR0: ATREADY2 Mask */
+#define TPI_ITATBCTR0_ATREADY1_Pos          0U                                         /*!< TPI ITATBCTR0: ATREADY1 Position */
+#define TPI_ITATBCTR0_ATREADY1_Msk         (0x1UL /*<< TPI_ITATBCTR0_ATREADY1_Pos*/)   /*!< TPI ITATBCTR0: ATREADY1 Mask */
+/* TPI Integration Mode Control Register Definitions */
+#define TPI_ITCTRL_Mode_Pos                 0U                                         /*!< TPI ITCTRL: Mode Position */
+#define TPI_ITCTRL_Mode_Msk                (0x3UL /*<< TPI_ITCTRL_Mode_Pos*/)          /*!< TPI ITCTRL: Mode Mask */
+/* TPI DEVID Register Definitions */
+#define TPI_DEVID_NRZVALID_Pos             11U                                         /*!< TPI DEVID: NRZVALID Position */
+#define TPI_DEVID_NRZVALID_Msk             (0x1UL << TPI_DEVID_NRZVALID_Pos)           /*!< TPI DEVID: NRZVALID Mask */
+#define TPI_DEVID_MANCVALID_Pos            10U                                         /*!< TPI DEVID: MANCVALID Position */
+#define TPI_DEVID_MANCVALID_Msk            (0x1UL << TPI_DEVID_MANCVALID_Pos)          /*!< TPI DEVID: MANCVALID Mask */
+#define TPI_DEVID_PTINVALID_Pos             9U                                         /*!< TPI DEVID: PTINVALID Position */
+#define TPI_DEVID_PTINVALID_Msk            (0x1UL << TPI_DEVID_PTINVALID_Pos)          /*!< TPI DEVID: PTINVALID Mask */
+#define TPI_DEVID_MinBufSz_Pos              6U                                         /*!< TPI DEVID: MinBufSz Position */
+#define TPI_DEVID_MinBufSz_Msk             (0x7UL << TPI_DEVID_MinBufSz_Pos)           /*!< TPI DEVID: MinBufSz Mask */
+#define TPI_DEVID_AsynClkIn_Pos             5U                                         /*!< TPI DEVID: AsynClkIn Position */
+#define TPI_DEVID_AsynClkIn_Msk            (0x1UL << TPI_DEVID_AsynClkIn_Pos)          /*!< TPI DEVID: AsynClkIn Mask */
+#define TPI_DEVID_NrTraceInput_Pos          0U                                         /*!< TPI DEVID: NrTraceInput Position */
+#define TPI_DEVID_NrTraceInput_Msk         (0x1FUL /*<< TPI_DEVID_NrTraceInput_Pos*/)  /*!< TPI DEVID: NrTraceInput Mask */
+/* TPI DEVTYPE Register Definitions */
+#define TPI_DEVTYPE_SubType_Pos             4U                                         /*!< TPI DEVTYPE: SubType Position */
+#define TPI_DEVTYPE_SubType_Msk            (0xFUL /*<< TPI_DEVTYPE_SubType_Pos*/)      /*!< TPI DEVTYPE: SubType Mask */
+#define TPI_DEVTYPE_MajorType_Pos           0U                                         /*!< TPI DEVTYPE: MajorType Position */
+#define TPI_DEVTYPE_MajorType_Msk          (0xFUL << TPI_DEVTYPE_MajorType_Pos)        /*!< TPI DEVTYPE: MajorType Mask */
+/*@}*/ /* end of group CMSIS_TPI */
+#if defined (__MPU_PRESENT) && (__MPU_PRESENT == 1U)
+  \defgroup CMSIS_MPU     Memory Protection Unit (MPU)
+  \brief    Type definitions for the Memory Protection Unit (MPU)
+  \brief  Structure type to access the Memory Protection Unit (MPU).
+typedef struct
+  __IM  uint32_t TYPE;                   /*!< Offset: 0x000 (R/ )  MPU Type Register */
+  __IOM uint32_t CTRL;                   /*!< Offset: 0x004 (R/W)  MPU Control Register */
+  __IOM uint32_t RNR;                    /*!< Offset: 0x008 (R/W)  MPU Region RNRber Register */
+  __IOM uint32_t RBAR;                   /*!< Offset: 0x00C (R/W)  MPU Region Base Address Register */
+  __IOM uint32_t RASR;                   /*!< Offset: 0x010 (R/W)  MPU Region Attribute and Size Register */
+  __IOM uint32_t RBAR_A1;                /*!< Offset: 0x014 (R/W)  MPU Alias 1 Region Base Address Register */
+  __IOM uint32_t RASR_A1;                /*!< Offset: 0x018 (R/W)  MPU Alias 1 Region Attribute and Size Register */
+  __IOM uint32_t RBAR_A2;                /*!< Offset: 0x01C (R/W)  MPU Alias 2 Region Base Address Register */
+  __IOM uint32_t RASR_A2;                /*!< Offset: 0x020 (R/W)  MPU Alias 2 Region Attribute and Size Register */
+  __IOM uint32_t RBAR_A3;                /*!< Offset: 0x024 (R/W)  MPU Alias 3 Region Base Address Register */
+  __IOM uint32_t RASR_A3;                /*!< Offset: 0x028 (R/W)  MPU Alias 3 Region Attribute and Size Register */
+} MPU_Type;
+#define MPU_TYPE_RALIASES                  4U
+/* MPU Type Register Definitions */
+#define MPU_TYPE_IREGION_Pos               16U                                            /*!< MPU TYPE: IREGION Position */
+#define MPU_TYPE_IREGION_Msk               (0xFFUL << MPU_TYPE_IREGION_Pos)               /*!< MPU TYPE: IREGION Mask */
+#define MPU_TYPE_DREGION_Pos                8U                                            /*!< MPU TYPE: DREGION Position */
+#define MPU_TYPE_DREGION_Msk               (0xFFUL << MPU_TYPE_DREGION_Pos)               /*!< MPU TYPE: DREGION Mask */
+#define MPU_TYPE_SEPARATE_Pos               0U                                            /*!< MPU TYPE: SEPARATE Position */
+#define MPU_TYPE_SEPARATE_Msk              (1UL /*<< MPU_TYPE_SEPARATE_Pos*/)             /*!< MPU TYPE: SEPARATE Mask */
+/* MPU Control Register Definitions */
+#define MPU_CTRL_PRIVDEFENA_Pos             2U                                            /*!< MPU CTRL: PRIVDEFENA Position */
+#define MPU_CTRL_PRIVDEFENA_Msk            (1UL << MPU_CTRL_PRIVDEFENA_Pos)               /*!< MPU CTRL: PRIVDEFENA Mask */
+#define MPU_CTRL_HFNMIENA_Pos               1U                                            /*!< MPU CTRL: HFNMIENA Position */
+#define MPU_CTRL_HFNMIENA_Msk              (1UL << MPU_CTRL_HFNMIENA_Pos)                 /*!< MPU CTRL: HFNMIENA Mask */
+#define MPU_CTRL_ENABLE_Pos                 0U                                            /*!< MPU CTRL: ENABLE Position */
+#define MPU_CTRL_ENABLE_Msk                (1UL /*<< MPU_CTRL_ENABLE_Pos*/)               /*!< MPU CTRL: ENABLE Mask */
+/* MPU Region Number Register Definitions */
+#define MPU_RNR_REGION_Pos                  0U                                            /*!< MPU RNR: REGION Position */
+#define MPU_RNR_REGION_Msk                 (0xFFUL /*<< MPU_RNR_REGION_Pos*/)             /*!< MPU RNR: REGION Mask */
+/* MPU Region Base Address Register Definitions */
+#define MPU_RBAR_ADDR_Pos                   5U                                            /*!< MPU RBAR: ADDR Position */
+#define MPU_RBAR_ADDR_Msk                  (0x7FFFFFFUL << MPU_RBAR_ADDR_Pos)             /*!< MPU RBAR: ADDR Mask */
+#define MPU_RBAR_VALID_Pos                  4U                                            /*!< MPU RBAR: VALID Position */
+#define MPU_RBAR_VALID_Msk                 (1UL << MPU_RBAR_VALID_Pos)                    /*!< MPU RBAR: VALID Mask */
+#define MPU_RBAR_REGION_Pos                 0U                                            /*!< MPU RBAR: REGION Position */
+#define MPU_RBAR_REGION_Msk                (0xFUL /*<< MPU_RBAR_REGION_Pos*/)             /*!< MPU RBAR: REGION Mask */
+/* MPU Region Attribute and Size Register Definitions */
+#define MPU_RASR_ATTRS_Pos                 16U                                            /*!< MPU RASR: MPU Region Attribute field Position */
+#define MPU_RASR_ATTRS_Msk                 (0xFFFFUL << MPU_RASR_ATTRS_Pos)               /*!< MPU RASR: MPU Region Attribute field Mask */
+#define MPU_RASR_XN_Pos                    28U                                            /*!< MPU RASR: ATTRS.XN Position */
+#define MPU_RASR_XN_Msk                    (1UL << MPU_RASR_XN_Pos)                       /*!< MPU RASR: ATTRS.XN Mask */
+#define MPU_RASR_AP_Pos                    24U                                            /*!< MPU RASR: ATTRS.AP Position */
+#define MPU_RASR_AP_Msk                    (0x7UL << MPU_RASR_AP_Pos)                     /*!< MPU RASR: ATTRS.AP Mask */
+#define MPU_RASR_TEX_Pos                   19U                                            /*!< MPU RASR: ATTRS.TEX Position */
+#define MPU_RASR_TEX_Msk                   (0x7UL << MPU_RASR_TEX_Pos)                    /*!< MPU RASR: ATTRS.TEX Mask */
+#define MPU_RASR_S_Pos                     18U                                            /*!< MPU RASR: ATTRS.S Position */
+#define MPU_RASR_S_Msk                     (1UL << MPU_RASR_S_Pos)                        /*!< MPU RASR: ATTRS.S Mask */
+#define MPU_RASR_C_Pos                     17U                                            /*!< MPU RASR: ATTRS.C Position */
+#define MPU_RASR_C_Msk                     (1UL << MPU_RASR_C_Pos)                        /*!< MPU RASR: ATTRS.C Mask */
+#define MPU_RASR_B_Pos                     16U                                            /*!< MPU RASR: ATTRS.B Position */
+#define MPU_RASR_B_Msk                     (1UL << MPU_RASR_B_Pos)                        /*!< MPU RASR: ATTRS.B Mask */
+#define MPU_RASR_SRD_Pos                    8U                                            /*!< MPU RASR: Sub-Region Disable Position */
+#define MPU_RASR_SRD_Msk                   (0xFFUL << MPU_RASR_SRD_Pos)                   /*!< MPU RASR: Sub-Region Disable Mask */
+#define MPU_RASR_SIZE_Pos                   1U                                            /*!< MPU RASR: Region Size Field Position */
+#define MPU_RASR_SIZE_Msk                  (0x1FUL << MPU_RASR_SIZE_Pos)                  /*!< MPU RASR: Region Size Field Mask */
+#define MPU_RASR_ENABLE_Pos                 0U                                            /*!< MPU RASR: Region enable bit Position */
+#define MPU_RASR_ENABLE_Msk                (1UL /*<< MPU_RASR_ENABLE_Pos*/)               /*!< MPU RASR: Region enable bit Disable Mask */
+/*@} end of group CMSIS_MPU */
+#endif /* defined (__MPU_PRESENT) && (__MPU_PRESENT == 1U) */
+  \ingroup  CMSIS_core_register
+  \defgroup CMSIS_FPU     Floating Point Unit (FPU)
+  \brief    Type definitions for the Floating Point Unit (FPU)
+  \brief  Structure type to access the Floating Point Unit (FPU).
+typedef struct
+  __IOM uint32_t FPCCR;                  /*!< Offset: 0x004 (R/W)  Floating-Point Context Control Register */
+  __IOM uint32_t FPCAR;                  /*!< Offset: 0x008 (R/W)  Floating-Point Context Address Register */
+  __IOM uint32_t FPDSCR;                 /*!< Offset: 0x00C (R/W)  Floating-Point Default Status Control Register */
+  __IM  uint32_t MVFR0;                  /*!< Offset: 0x010 (R/ )  Media and FP Feature Register 0 */
+  __IM  uint32_t MVFR1;                  /*!< Offset: 0x014 (R/ )  Media and FP Feature Register 1 */
+  __IM  uint32_t MVFR2;                  /*!< Offset: 0x018 (R/ )  Media and FP Feature Register 2 */
+} FPU_Type;
+/* Floating-Point Context Control Register Definitions */
+#define FPU_FPCCR_ASPEN_Pos                31U                                            /*!< FPCCR: ASPEN bit Position */
+#define FPU_FPCCR_ASPEN_Msk                (1UL << FPU_FPCCR_ASPEN_Pos)                   /*!< FPCCR: ASPEN bit Mask */
+#define FPU_FPCCR_LSPEN_Pos                30U                                            /*!< FPCCR: LSPEN Position */
+#define FPU_FPCCR_LSPEN_Msk                (1UL << FPU_FPCCR_LSPEN_Pos)                   /*!< FPCCR: LSPEN bit Mask */
+#define FPU_FPCCR_MONRDY_Pos                8U                                            /*!< FPCCR: MONRDY Position */
+#define FPU_FPCCR_MONRDY_Msk               (1UL << FPU_FPCCR_MONRDY_Pos)                  /*!< FPCCR: MONRDY bit Mask */
+#define FPU_FPCCR_BFRDY_Pos                 6U                                            /*!< FPCCR: BFRDY Position */
+#define FPU_FPCCR_BFRDY_Msk                (1UL << FPU_FPCCR_BFRDY_Pos)                   /*!< FPCCR: BFRDY bit Mask */
+#define FPU_FPCCR_MMRDY_Pos                 5U                                            /*!< FPCCR: MMRDY Position */
+#define FPU_FPCCR_MMRDY_Msk                (1UL << FPU_FPCCR_MMRDY_Pos)                   /*!< FPCCR: MMRDY bit Mask */
+#define FPU_FPCCR_HFRDY_Pos                 4U                                            /*!< FPCCR: HFRDY Position */
+#define FPU_FPCCR_HFRDY_Msk                (1UL << FPU_FPCCR_HFRDY_Pos)                   /*!< FPCCR: HFRDY bit Mask */
+#define FPU_FPCCR_THREAD_Pos                3U                                            /*!< FPCCR: processor mode bit Position */
+#define FPU_FPCCR_THREAD_Msk               (1UL << FPU_FPCCR_THREAD_Pos)                  /*!< FPCCR: processor mode active bit Mask */
+#define FPU_FPCCR_USER_Pos                  1U                                            /*!< FPCCR: privilege level bit Position */
+#define FPU_FPCCR_USER_Msk                 (1UL << FPU_FPCCR_USER_Pos)                    /*!< FPCCR: privilege level bit Mask */
+#define FPU_FPCCR_LSPACT_Pos                0U                                            /*!< FPCCR: Lazy state preservation active bit Position */
+#define FPU_FPCCR_LSPACT_Msk               (1UL /*<< FPU_FPCCR_LSPACT_Pos*/)              /*!< FPCCR: Lazy state preservation active bit Mask */
+/* Floating-Point Context Address Register Definitions */
+#define FPU_FPCAR_ADDRESS_Pos               3U                                            /*!< FPCAR: ADDRESS bit Position */
+#define FPU_FPCAR_ADDRESS_Msk              (0x1FFFFFFFUL << FPU_FPCAR_ADDRESS_Pos)        /*!< FPCAR: ADDRESS bit Mask */
+/* Floating-Point Default Status Control Register Definitions */
+#define FPU_FPDSCR_AHP_Pos                 26U                                            /*!< FPDSCR: AHP bit Position */
+#define FPU_FPDSCR_AHP_Msk                 (1UL << FPU_FPDSCR_AHP_Pos)                    /*!< FPDSCR: AHP bit Mask */
+#define FPU_FPDSCR_DN_Pos                  25U                                            /*!< FPDSCR: DN bit Position */
+#define FPU_FPDSCR_DN_Msk                  (1UL << FPU_FPDSCR_DN_Pos)                     /*!< FPDSCR: DN bit Mask */
+#define FPU_FPDSCR_FZ_Pos                  24U                                            /*!< FPDSCR: FZ bit Position */
+#define FPU_FPDSCR_FZ_Msk                  (1UL << FPU_FPDSCR_FZ_Pos)                     /*!< FPDSCR: FZ bit Mask */
+#define FPU_FPDSCR_RMode_Pos               22U                                            /*!< FPDSCR: RMode bit Position */
+#define FPU_FPDSCR_RMode_Msk               (3UL << FPU_FPDSCR_RMode_Pos)                  /*!< FPDSCR: RMode bit Mask */
+/* Media and FP Feature Register 0 Definitions */
+#define FPU_MVFR0_FP_rounding_modes_Pos    28U                                            /*!< MVFR0: FP rounding modes bits Position */
+#define FPU_MVFR0_FP_rounding_modes_Msk    (0xFUL << FPU_MVFR0_FP_rounding_modes_Pos)     /*!< MVFR0: FP rounding modes bits Mask */
+#define FPU_MVFR0_Short_vectors_Pos        24U                                            /*!< MVFR0: Short vectors bits Position */
+#define FPU_MVFR0_Short_vectors_Msk        (0xFUL << FPU_MVFR0_Short_vectors_Pos)         /*!< MVFR0: Short vectors bits Mask */
+#define FPU_MVFR0_Square_root_Pos          20U                                            /*!< MVFR0: Square root bits Position */
+#define FPU_MVFR0_Square_root_Msk          (0xFUL << FPU_MVFR0_Square_root_Pos)           /*!< MVFR0: Square root bits Mask */
+#define FPU_MVFR0_Divide_Pos               16U                                            /*!< MVFR0: Divide bits Position */
+#define FPU_MVFR0_Divide_Msk               (0xFUL << FPU_MVFR0_Divide_Pos)                /*!< MVFR0: Divide bits Mask */
+#define FPU_MVFR0_FP_excep_trapping_Pos    12U                                            /*!< MVFR0: FP exception trapping bits Position */
+#define FPU_MVFR0_FP_excep_trapping_Msk    (0xFUL << FPU_MVFR0_FP_excep_trapping_Pos)     /*!< MVFR0: FP exception trapping bits Mask */
+#define FPU_MVFR0_Double_precision_Pos      8U                                            /*!< MVFR0: Double-precision bits Position */
+#define FPU_MVFR0_Double_precision_Msk     (0xFUL << FPU_MVFR0_Double_precision_Pos)      /*!< MVFR0: Double-precision bits Mask */
+#define FPU_MVFR0_Single_precision_Pos      4U                                            /*!< MVFR0: Single-precision bits Position */
+#define FPU_MVFR0_Single_precision_Msk     (0xFUL << FPU_MVFR0_Single_precision_Pos)      /*!< MVFR0: Single-precision bits Mask */
+#define FPU_MVFR0_A_SIMD_registers_Pos      0U                                            /*!< MVFR0: A_SIMD registers bits Position */
+#define FPU_MVFR0_A_SIMD_registers_Msk     (0xFUL /*<< FPU_MVFR0_A_SIMD_registers_Pos*/)  /*!< MVFR0: A_SIMD registers bits Mask */
+/* Media and FP Feature Register 1 Definitions */
+#define FPU_MVFR1_FP_fused_MAC_Pos         28U                                            /*!< MVFR1: FP fused MAC bits Position */
+#define FPU_MVFR1_FP_fused_MAC_Msk         (0xFUL << FPU_MVFR1_FP_fused_MAC_Pos)          /*!< MVFR1: FP fused MAC bits Mask */
+#define FPU_MVFR1_FP_HPFP_Pos              24U                                            /*!< MVFR1: FP HPFP bits Position */
+#define FPU_MVFR1_FP_HPFP_Msk              (0xFUL << FPU_MVFR1_FP_HPFP_Pos)               /*!< MVFR1: FP HPFP bits Mask */
+#define FPU_MVFR1_D_NaN_mode_Pos            4U                                            /*!< MVFR1: D_NaN mode bits Position */
+#define FPU_MVFR1_D_NaN_mode_Msk           (0xFUL << FPU_MVFR1_D_NaN_mode_Pos)            /*!< MVFR1: D_NaN mode bits Mask */
+#define FPU_MVFR1_FtZ_mode_Pos              0U                                            /*!< MVFR1: FtZ mode bits Position */
+#define FPU_MVFR1_FtZ_mode_Msk             (0xFUL /*<< FPU_MVFR1_FtZ_mode_Pos*/)          /*!< MVFR1: FtZ mode bits Mask */
+/* Media and FP Feature Register 2 Definitions */
+#define FPU_MVFR2_VFP_Misc_Pos              4U                                            /*!< MVFR2: VFP Misc bits Position */
+#define FPU_MVFR2_VFP_Misc_Msk             (0xFUL << FPU_MVFR2_VFP_Misc_Pos)              /*!< MVFR2: VFP Misc bits Mask */
+/*@} end of group CMSIS_FPU */
+  \defgroup CMSIS_CoreDebug       Core Debug Registers (CoreDebug)
+  \brief    Type definitions for the Core Debug Registers
+  \brief  Structure type to access the Core Debug Register (CoreDebug).
+typedef struct
+  __IOM uint32_t DHCSR;                  /*!< Offset: 0x000 (R/W)  Debug Halting Control and Status Register */
+  __OM  uint32_t DCRSR;                  /*!< Offset: 0x004 ( /W)  Debug Core Register Selector Register */
+  __IOM uint32_t DCRDR;                  /*!< Offset: 0x008 (R/W)  Debug Core Register Data Register */
+  __IOM uint32_t DEMCR;                  /*!< Offset: 0x00C (R/W)  Debug Exception and Monitor Control Register */
+} CoreDebug_Type;
+/* Debug Halting Control and Status Register Definitions */
+#define CoreDebug_DHCSR_DBGKEY_Pos         16U                                            /*!< CoreDebug DHCSR: DBGKEY Position */
+#define CoreDebug_DHCSR_DBGKEY_Msk         (0xFFFFUL << CoreDebug_DHCSR_DBGKEY_Pos)       /*!< CoreDebug DHCSR: DBGKEY Mask */
+#define CoreDebug_DHCSR_S_RESET_ST_Pos     25U                                            /*!< CoreDebug DHCSR: S_RESET_ST Position */
+#define CoreDebug_DHCSR_S_RESET_ST_Msk     (1UL << CoreDebug_DHCSR_S_RESET_ST_Pos)        /*!< CoreDebug DHCSR: S_RESET_ST Mask */
+#define CoreDebug_DHCSR_S_RETIRE_ST_Pos    24U                                            /*!< CoreDebug DHCSR: S_RETIRE_ST Position */
+#define CoreDebug_DHCSR_S_RETIRE_ST_Msk    (1UL << CoreDebug_DHCSR_S_RETIRE_ST_Pos)       /*!< CoreDebug DHCSR: S_RETIRE_ST Mask */
+#define CoreDebug_DHCSR_S_LOCKUP_Pos       19U                                            /*!< CoreDebug DHCSR: S_LOCKUP Position */
+#define CoreDebug_DHCSR_S_LOCKUP_Msk       (1UL << CoreDebug_DHCSR_S_LOCKUP_Pos)          /*!< CoreDebug DHCSR: S_LOCKUP Mask */
+#define CoreDebug_DHCSR_S_SLEEP_Pos        18U                                            /*!< CoreDebug DHCSR: S_SLEEP Position */
+#define CoreDebug_DHCSR_S_SLEEP_Msk        (1UL << CoreDebug_DHCSR_S_SLEEP_Pos)           /*!< CoreDebug DHCSR: S_SLEEP Mask */
+#define CoreDebug_DHCSR_S_HALT_Pos         17U                                            /*!< CoreDebug DHCSR: S_HALT Position */
+#define CoreDebug_DHCSR_S_HALT_Msk         (1UL << CoreDebug_DHCSR_S_HALT_Pos)            /*!< CoreDebug DHCSR: S_HALT Mask */
+#define CoreDebug_DHCSR_S_REGRDY_Pos       16U                                            /*!< CoreDebug DHCSR: S_REGRDY Position */
+#define CoreDebug_DHCSR_S_REGRDY_Msk       (1UL << CoreDebug_DHCSR_S_REGRDY_Pos)          /*!< CoreDebug DHCSR: S_REGRDY Mask */
+#define CoreDebug_DHCSR_C_SNAPSTALL_Pos     5U                                            /*!< CoreDebug DHCSR: C_SNAPSTALL Position */
+#define CoreDebug_DHCSR_C_SNAPSTALL_Msk    (1UL << CoreDebug_DHCSR_C_SNAPSTALL_Pos)       /*!< CoreDebug DHCSR: C_SNAPSTALL Mask */
+#define CoreDebug_DHCSR_C_MASKINTS_Pos      3U                                            /*!< CoreDebug DHCSR: C_MASKINTS Position */
+#define CoreDebug_DHCSR_C_MASKINTS_Msk     (1UL << CoreDebug_DHCSR_C_MASKINTS_Pos)        /*!< CoreDebug DHCSR: C_MASKINTS Mask */
+#define CoreDebug_DHCSR_C_STEP_Pos          2U                                            /*!< CoreDebug DHCSR: C_STEP Position */
+#define CoreDebug_DHCSR_C_STEP_Msk         (1UL << CoreDebug_DHCSR_C_STEP_Pos)            /*!< CoreDebug DHCSR: C_STEP Mask */
+#define CoreDebug_DHCSR_C_HALT_Pos          1U                                            /*!< CoreDebug DHCSR: C_HALT Position */
+#define CoreDebug_DHCSR_C_HALT_Msk         (1UL << CoreDebug_DHCSR_C_HALT_Pos)            /*!< CoreDebug DHCSR: C_HALT Mask */
+#define CoreDebug_DHCSR_C_DEBUGEN_Pos       0U                                            /*!< CoreDebug DHCSR: C_DEBUGEN Position */
+#define CoreDebug_DHCSR_C_DEBUGEN_Msk      (1UL /*<< CoreDebug_DHCSR_C_DEBUGEN_Pos*/)     /*!< CoreDebug DHCSR: C_DEBUGEN Mask */
+/* Debug Core Register Selector Register Definitions */
+#define CoreDebug_DCRSR_REGWnR_Pos         16U                                            /*!< CoreDebug DCRSR: REGWnR Position */
+#define CoreDebug_DCRSR_REGWnR_Msk         (1UL << CoreDebug_DCRSR_REGWnR_Pos)            /*!< CoreDebug DCRSR: REGWnR Mask */
+#define CoreDebug_DCRSR_REGSEL_Pos          0U                                            /*!< CoreDebug DCRSR: REGSEL Position */
+#define CoreDebug_DCRSR_REGSEL_Msk         (0x1FUL /*<< CoreDebug_DCRSR_REGSEL_Pos*/)     /*!< CoreDebug DCRSR: REGSEL Mask */
+/* Debug Exception and Monitor Control Register Definitions */
+#define CoreDebug_DEMCR_TRCENA_Pos         24U                                            /*!< CoreDebug DEMCR: TRCENA Position */
+#define CoreDebug_DEMCR_TRCENA_Msk         (1UL << CoreDebug_DEMCR_TRCENA_Pos)            /*!< CoreDebug DEMCR: TRCENA Mask */
+#define CoreDebug_DEMCR_MON_REQ_Pos        19U                                            /*!< CoreDebug DEMCR: MON_REQ Position */
+#define CoreDebug_DEMCR_MON_REQ_Msk        (1UL << CoreDebug_DEMCR_MON_REQ_Pos)           /*!< CoreDebug DEMCR: MON_REQ Mask */
+#define CoreDebug_DEMCR_MON_STEP_Pos       18U                                            /*!< CoreDebug DEMCR: MON_STEP Position */
+#define CoreDebug_DEMCR_MON_STEP_Msk       (1UL << CoreDebug_DEMCR_MON_STEP_Pos)          /*!< CoreDebug DEMCR: MON_STEP Mask */
+#define CoreDebug_DEMCR_MON_PEND_Pos       17U                                            /*!< CoreDebug DEMCR: MON_PEND Position */
+#define CoreDebug_DEMCR_MON_PEND_Msk       (1UL << CoreDebug_DEMCR_MON_PEND_Pos)          /*!< CoreDebug DEMCR: MON_PEND Mask */
+#define CoreDebug_DEMCR_MON_EN_Pos         16U                                            /*!< CoreDebug DEMCR: MON_EN Position */
+#define CoreDebug_DEMCR_MON_EN_Msk         (1UL << CoreDebug_DEMCR_MON_EN_Pos)            /*!< CoreDebug DEMCR: MON_EN Mask */
+#define CoreDebug_DEMCR_VC_HARDERR_Pos     10U                                            /*!< CoreDebug DEMCR: VC_HARDERR Position */
+#define CoreDebug_DEMCR_VC_HARDERR_Msk     (1UL << CoreDebug_DEMCR_VC_HARDERR_Pos)        /*!< CoreDebug DEMCR: VC_HARDERR Mask */
+#define CoreDebug_DEMCR_VC_INTERR_Pos       9U                                            /*!< CoreDebug DEMCR: VC_INTERR Position */
+#define CoreDebug_DEMCR_VC_INTERR_Msk      (1UL << CoreDebug_DEMCR_VC_INTERR_Pos)         /*!< CoreDebug DEMCR: VC_INTERR Mask */
+#define CoreDebug_DEMCR_VC_BUSERR_Pos       8U                                            /*!< CoreDebug DEMCR: VC_BUSERR Position */
+#define CoreDebug_DEMCR_VC_BUSERR_Msk      (1UL << CoreDebug_DEMCR_VC_BUSERR_Pos)         /*!< CoreDebug DEMCR: VC_BUSERR Mask */
+#define CoreDebug_DEMCR_VC_STATERR_Pos      7U                                            /*!< CoreDebug DEMCR: VC_STATERR Position */
+#define CoreDebug_DEMCR_VC_STATERR_Msk     (1UL << CoreDebug_DEMCR_VC_STATERR_Pos)        /*!< CoreDebug DEMCR: VC_STATERR Mask */
+#define CoreDebug_DEMCR_VC_CHKERR_Pos       6U                                            /*!< CoreDebug DEMCR: VC_CHKERR Position */
+#define CoreDebug_DEMCR_VC_CHKERR_Msk      (1UL << CoreDebug_DEMCR_VC_CHKERR_Pos)         /*!< CoreDebug DEMCR: VC_CHKERR Mask */
+#define CoreDebug_DEMCR_VC_NOCPERR_Pos      5U                                            /*!< CoreDebug DEMCR: VC_NOCPERR Position */
+#define CoreDebug_DEMCR_VC_NOCPERR_Msk     (1UL << CoreDebug_DEMCR_VC_NOCPERR_Pos)        /*!< CoreDebug DEMCR: VC_NOCPERR Mask */
+#define CoreDebug_DEMCR_VC_MMERR_Pos        4U                                            /*!< CoreDebug DEMCR: VC_MMERR Position */
+#define CoreDebug_DEMCR_VC_MMERR_Msk       (1UL << CoreDebug_DEMCR_VC_MMERR_Pos)          /*!< CoreDebug DEMCR: VC_MMERR Mask */
+#define CoreDebug_DEMCR_VC_CORERESET_Pos    0U                                            /*!< CoreDebug DEMCR: VC_CORERESET Position */
+#define CoreDebug_DEMCR_VC_CORERESET_Msk   (1UL /*<< CoreDebug_DEMCR_VC_CORERESET_Pos*/)  /*!< CoreDebug DEMCR: VC_CORERESET Mask */
+/*@} end of group CMSIS_CoreDebug */
+  \defgroup   CMSIS_core_bitfield     Core register bit field macros
+  \brief      Macros for use with bit field definitions (xxx_Pos, xxx_Msk).
+  \brief   Mask and shift a bit field value for use in a register bit range.
+  \param[in] field  Name of the register bit field.
+  \param[in] value  Value of the bit field. This parameter is interpreted as an uint32_t type.
+  \return           Masked and shifted value.
+#define _VAL2FLD(field, value)    (((uint32_t)(value) << field ## _Pos) & field ## _Msk)
+  \brief     Mask and shift a register value to extract a bit filed value.
+  \param[in] value  Value of register. This parameter is interpreted as an uint32_t type.
+  \return           Masked and shifted bit field value.
+#define _FLD2VAL(field, value)    (((uint32_t)(value) & field ## _Msk) >> field ## _Pos)
+/*@} end of group CMSIS_core_bitfield */
+  \defgroup   CMSIS_core_base     Core Definitions
+  \brief      Definitions for base addresses, unions, and structures.
+/* Memory mapping of Core Hardware */
+#define SCS_BASE            (0xE000E000UL)                            /*!< System Control Space Base Address */
+#define ITM_BASE            (0xE0000000UL)                            /*!< ITM Base Address */
+#define DWT_BASE            (0xE0001000UL)                            /*!< DWT Base Address */
+#define TPI_BASE            (0xE0040000UL)                            /*!< TPI Base Address */
+#define CoreDebug_BASE      (0xE000EDF0UL)                            /*!< Core Debug Base Address */
+#define SysTick_BASE        (SCS_BASE +  0x0010UL)                    /*!< SysTick Base Address */
+#define NVIC_BASE           (SCS_BASE +  0x0100UL)                    /*!< NVIC Base Address */
+#define SCB_BASE            (SCS_BASE +  0x0D00UL)                    /*!< System Control Block Base Address */
+#define SCnSCB              ((SCnSCB_Type    *)     SCS_BASE      )   /*!< System control Register not in SCB */
+#define SCB                 ((SCB_Type       *)     SCB_BASE      )   /*!< SCB configuration struct */
+#define SysTick             ((SysTick_Type   *)     SysTick_BASE  )   /*!< SysTick configuration struct */
+#define NVIC                ((NVIC_Type      *)     NVIC_BASE     )   /*!< NVIC configuration struct */
+#define ITM                 ((ITM_Type       *)     ITM_BASE      )   /*!< ITM configuration struct */
+#define DWT                 ((DWT_Type       *)     DWT_BASE      )   /*!< DWT configuration struct */
+#define TPI                 ((TPI_Type       *)     TPI_BASE      )   /*!< TPI configuration struct */
+#define CoreDebug           ((CoreDebug_Type *)     CoreDebug_BASE)   /*!< Core Debug configuration struct */
+  #define MPU_BASE          (SCS_BASE +  0x0D90UL)                    /*!< Memory Protection Unit */
+  #define MPU               ((MPU_Type       *)     MPU_BASE      )   /*!< Memory Protection Unit */
+#endif
+#define FPU_BASE            (SCS_BASE +  0x0F30UL)                    /*!< Floating Point Unit */
+#define FPU                 ((FPU_Type       *)     FPU_BASE      )   /*!< Floating Point Unit */
+  \defgroup   CMSIS_register_aliases     Backwards Compatibility Aliases
+  \brief      Register alias definitions for backwards compatibility.
+/* Capitalize ITM_TCR Register Definitions */
+#define ITM_TCR_TraceBusID_Pos           (ITM_TCR_TRACEBUSID_Pos)     /*!< \deprecated ITM_TCR_TraceBusID_Pos */
+#define ITM_TCR_TraceBusID_Msk           (ITM_TCR_TRACEBUSID_Msk)     /*!< \deprecated ITM_TCR_TraceBusID_Msk */
+#define ITM_TCR_TSPrescale_Pos           (ITM_TCR_TSPRESCALE_Pos)     /*!< \deprecated ITM_TCR_TSPrescale_Pos */
+#define ITM_TCR_TSPrescale_Msk           (ITM_TCR_TSPRESCALE_Msk)     /*!< \deprecated ITM_TCR_TSPrescale_Msk */
+#define ITM_LSR_ByteAcc_Pos              (ITM_LSR_BYTEACC_Pos)        /*!< \deprecated ITM_LSR_ByteAcc_Pos */
+#define ITM_LSR_ByteAcc_Msk              (ITM_LSR_BYTEACC_Msk)        /*!< \deprecated ITM_LSR_ByteAcc_Msk */
+#define ITM_LSR_Access_Pos               (ITM_LSR_ACCESS_Pos)         /*!< \deprecated ITM_LSR_Access_Pos */
+#define ITM_LSR_Access_Msk               (ITM_LSR_ACCESS_Msk)         /*!< \deprecated ITM_LSR_Access_Msk */
+#define ITM_LSR_Present_Pos              (ITM_LSR_PRESENT_Pos)        /*!< \deprecated ITM_LSR_Present_Pos */
+#define ITM_LSR_Present_Msk              (ITM_LSR_PRESENT_Msk)        /*!< \deprecated ITM_LSR_Present_Msk */
+ *                Hardware Abstraction Layer
+  Core Function Interface contains:
+  - Core NVIC Functions
+  - Core SysTick Functions
+  - Core Debug Functions
+  - Core Register Access Functions
+  \defgroup CMSIS_Core_FunctionInterface Functions and Instructions Reference
+/* ##########################   NVIC functions  #################################### */
+  \ingroup  CMSIS_Core_FunctionInterface
+  \defgroup CMSIS_Core_NVICFunctions NVIC Functions
+  \brief    Functions that manage interrupts and exceptions via the NVIC.
+#ifdef CMSIS_NVIC_VIRTUAL
+  #ifndef CMSIS_NVIC_VIRTUAL_HEADER_FILE
+    #define CMSIS_NVIC_VIRTUAL_HEADER_FILE "cmsis_nvic_virtual.h"
+  #endif
+  #include CMSIS_NVIC_VIRTUAL_HEADER_FILE
+#else
+  #define NVIC_SetPriorityGrouping    __NVIC_SetPriorityGrouping
+  #define NVIC_GetPriorityGrouping    __NVIC_GetPriorityGrouping
+  #define NVIC_EnableIRQ              __NVIC_EnableIRQ
+  #define NVIC_GetEnableIRQ           __NVIC_GetEnableIRQ
+  #define NVIC_DisableIRQ             __NVIC_DisableIRQ
+  #define NVIC_GetPendingIRQ          __NVIC_GetPendingIRQ
+  #define NVIC_SetPendingIRQ          __NVIC_SetPendingIRQ
+  #define NVIC_ClearPendingIRQ        __NVIC_ClearPendingIRQ
+  #define NVIC_GetActive              __NVIC_GetActive
+  #define NVIC_SetPriority            __NVIC_SetPriority
+  #define NVIC_GetPriority            __NVIC_GetPriority
+  #define NVIC_SystemReset            __NVIC_SystemReset
+#endif /* CMSIS_NVIC_VIRTUAL */
+#ifdef CMSIS_VECTAB_VIRTUAL
+  #ifndef CMSIS_VECTAB_VIRTUAL_HEADER_FILE
+    #define CMSIS_VECTAB_VIRTUAL_HEADER_FILE "cmsis_vectab_virtual.h"
+  #endif
+  #include CMSIS_VECTAB_VIRTUAL_HEADER_FILE
+#else
+  #define NVIC_SetVector              __NVIC_SetVector
+  #define NVIC_GetVector              __NVIC_GetVector
+#endif  /* (CMSIS_VECTAB_VIRTUAL) */
+#define NVIC_USER_IRQ_OFFSET          16
+/* The following EXC_RETURN values are saved the LR on exception entry */
+#define EXC_RETURN_HANDLER         (0xFFFFFFF1UL)     /* return to Handler mode, uses MSP after return                               */
+#define EXC_RETURN_THREAD_MSP      (0xFFFFFFF9UL)     /* return to Thread mode, uses MSP after return                                */
+#define EXC_RETURN_THREAD_PSP      (0xFFFFFFFDUL)     /* return to Thread mode, uses PSP after return                                */
+#define EXC_RETURN_HANDLER_FPU     (0xFFFFFFE1UL)     /* return to Handler mode, uses MSP after return, restore floating-point state */
+#define EXC_RETURN_THREAD_MSP_FPU  (0xFFFFFFE9UL)     /* return to Thread mode, uses MSP after return, restore floating-point state  */
+#define EXC_RETURN_THREAD_PSP_FPU  (0xFFFFFFEDUL)     /* return to Thread mode, uses PSP after return, restore floating-point state  */
+  \brief   Set Priority Grouping
+  \details Sets the priority grouping field using the required unlock sequence.
+           The parameter PriorityGroup is assigned to the field SCB->AIRCR [10:8] PRIGROUP field.
+           Only values from 0..7 are used.
+           In case of a conflict between priority grouping and available
+           priority bits (__NVIC_PRIO_BITS), the smallest possible priority group is set.
+  \param [in]      PriorityGroup  Priority grouping field.
+__STATIC_INLINE void __NVIC_SetPriorityGrouping(uint32_t PriorityGroup)
+  uint32_t reg_value;
+  uint32_t PriorityGroupTmp = (PriorityGroup & (uint32_t)0x07UL);             /* only values 0..7 are used          */
+  reg_value  =  SCB->AIRCR;                                                   /* read old register configuration    */
+  reg_value &= ~((uint32_t)(SCB_AIRCR_VECTKEY_Msk | SCB_AIRCR_PRIGROUP_Msk)); /* clear bits to change               */
+  reg_value  =  (reg_value                                   |
+                ((uint32_t)0x5FAUL << SCB_AIRCR_VECTKEY_Pos) |
+                (PriorityGroupTmp << SCB_AIRCR_PRIGROUP_Pos)  );              /* Insert write key and priority group */
+  SCB->AIRCR =  reg_value;
+  \brief   Get Priority Grouping
+  \details Reads the priority grouping field from the NVIC Interrupt Controller.
+  \return                Priority grouping field (SCB->AIRCR [10:8] PRIGROUP field).
+__STATIC_INLINE uint32_t __NVIC_GetPriorityGrouping(void)
+  return ((uint32_t)((SCB->AIRCR & SCB_AIRCR_PRIGROUP_Msk) >> SCB_AIRCR_PRIGROUP_Pos));
+  \brief   Enable Interrupt
+  \details Enables a device specific interrupt in the NVIC interrupt controller.
+  \param [in]      IRQn  Device specific interrupt number.
+  \note    IRQn must not be negative.
+__STATIC_INLINE void __NVIC_EnableIRQ(IRQn_Type IRQn)
+  if ((int32_t)(IRQn) >= 0)
+    __COMPILER_BARRIER();
+    NVIC->ISER[(((uint32_t)IRQn) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)IRQn) & 0x1FUL));
+  \brief   Get Interrupt Enable status
+  \details Returns a device specific interrupt enable status from the NVIC interrupt controller.
+  \return             0  Interrupt is not enabled.
+  \return             1  Interrupt is enabled.
+__STATIC_INLINE uint32_t __NVIC_GetEnableIRQ(IRQn_Type IRQn)
+    return((uint32_t)(((NVIC->ISER[(((uint32_t)IRQn) >> 5UL)] & (1UL << (((uint32_t)IRQn) & 0x1FUL))) != 0UL) ? 1UL : 0UL));
+  else
+    return(0U);
+  \brief   Disable Interrupt
+  \details Disables a device specific interrupt in the NVIC interrupt controller.
+__STATIC_INLINE void __NVIC_DisableIRQ(IRQn_Type IRQn)
+    NVIC->ICER[(((uint32_t)IRQn) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)IRQn) & 0x1FUL));
+    __DSB();
+    __ISB();
+  \brief   Get Pending Interrupt
+  \details Reads the NVIC pending register and returns the pending bit for the specified device specific interrupt.
+  \return             0  Interrupt status is not pending.
+  \return             1  Interrupt status is pending.
+__STATIC_INLINE uint32_t __NVIC_GetPendingIRQ(IRQn_Type IRQn)
+    return((uint32_t)(((NVIC->ISPR[(((uint32_t)IRQn) >> 5UL)] & (1UL << (((uint32_t)IRQn) & 0x1FUL))) != 0UL) ? 1UL : 0UL));
+  else
+    return(0U);
+  \brief   Set Pending Interrupt
+  \details Sets the pending bit of a device specific interrupt in the NVIC pending register.
+__STATIC_INLINE void __NVIC_SetPendingIRQ(IRQn_Type IRQn)
+    NVIC->ISPR[(((uint32_t)IRQn) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)IRQn) & 0x1FUL));
+  \brief   Clear Pending Interrupt
+  \details Clears the pending bit of a device specific interrupt in the NVIC pending register.
+__STATIC_INLINE void __NVIC_ClearPendingIRQ(IRQn_Type IRQn)
+    NVIC->ICPR[(((uint32_t)IRQn) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)IRQn) & 0x1FUL));
+  \brief   Get Active Interrupt
+  \details Reads the active register in the NVIC and returns the active bit for the device specific interrupt.
+  \return             0  Interrupt status is not active.
+  \return             1  Interrupt status is active.
+__STATIC_INLINE uint32_t __NVIC_GetActive(IRQn_Type IRQn)
+    return((uint32_t)(((NVIC->IABR[(((uint32_t)IRQn) >> 5UL)] & (1UL << (((uint32_t)IRQn) & 0x1FUL))) != 0UL) ? 1UL : 0UL));
+  else
+    return(0U);
+  \brief   Set Interrupt Priority
+  \details Sets the priority of a device specific interrupt or a processor exception.
+           The interrupt number can be positive to specify a device specific interrupt,
+           or negative to specify a processor exception.
+  \param [in]      IRQn  Interrupt number.
+  \param [in]  priority  Priority to set.
+  \note    The priority cannot be set for every processor exception.
+__STATIC_INLINE void __NVIC_SetPriority(IRQn_Type IRQn, uint32_t priority)
+    NVIC->IP[((uint32_t)IRQn)]                = (uint8_t)((priority << (8U - __NVIC_PRIO_BITS)) & (uint32_t)0xFFUL);
+  else
+    SCB->SHPR[(((uint32_t)IRQn) & 0xFUL)-4UL] = (uint8_t)((priority << (8U - __NVIC_PRIO_BITS)) & (uint32_t)0xFFUL);
+  \brief   Get Interrupt Priority
+  \details Reads the priority of a device specific interrupt or a processor exception.
+  \return             Interrupt Priority.
+                      Value is aligned automatically to the implemented priority bits of the microcontroller.
+__STATIC_INLINE uint32_t __NVIC_GetPriority(IRQn_Type IRQn)
+    return(((uint32_t)NVIC->IP[((uint32_t)IRQn)]                >> (8U - __NVIC_PRIO_BITS)));
+  else
+    return(((uint32_t)SCB->SHPR[(((uint32_t)IRQn) & 0xFUL)-4UL] >> (8U - __NVIC_PRIO_BITS)));
+  \brief   Encode Priority
+  \details Encodes the priority for an interrupt with the given priority group,
+           preemptive priority value, and subpriority value.
+  \param [in]     PriorityGroup  Used priority group.
+  \param [in]   PreemptPriority  Preemptive priority value (starting from 0).
+  \param [in]       SubPriority  Subpriority value (starting from 0).
+  \return                        Encoded priority. Value can be used in the function \ref NVIC_SetPriority().
+__STATIC_INLINE uint32_t NVIC_EncodePriority (uint32_t PriorityGroup, uint32_t PreemptPriority, uint32_t SubPriority)
+  uint32_t PreemptPriorityBits;
+  uint32_t SubPriorityBits;
+  PreemptPriorityBits = ((7UL - PriorityGroupTmp) > (uint32_t)(__NVIC_PRIO_BITS)) ? (uint32_t)(__NVIC_PRIO_BITS) : (uint32_t)(7UL - PriorityGroupTmp);
+  SubPriorityBits     = ((PriorityGroupTmp + (uint32_t)(__NVIC_PRIO_BITS)) < (uint32_t)7UL) ? (uint32_t)0UL : (uint32_t)((PriorityGroupTmp - 7UL) + (uint32_t)(__NVIC_PRIO_BITS));
+  return (
+           ((PreemptPriority & (uint32_t)((1UL << (PreemptPriorityBits)) - 1UL)) << SubPriorityBits) |
+           ((SubPriority     & (uint32_t)((1UL << (SubPriorityBits    )) - 1UL)))
+  \brief   Decode Priority
+  \details Decodes an interrupt priority value with a given priority group to
+           preemptive priority value and subpriority value.
+           priority bits (__NVIC_PRIO_BITS) the smallest possible priority group is set.
+  \param [in]         Priority   Priority value, which can be retrieved with the function \ref NVIC_GetPriority().
+  \param [out] pPreemptPriority  Preemptive priority value (starting from 0).
+  \param [out]     pSubPriority  Subpriority value (starting from 0).
+__STATIC_INLINE void NVIC_DecodePriority (uint32_t Priority, uint32_t PriorityGroup, uint32_t* const pPreemptPriority, uint32_t* const pSubPriority)
+  *pPreemptPriority = (Priority >> SubPriorityBits) & (uint32_t)((1UL << (PreemptPriorityBits)) - 1UL);
+  *pSubPriority     = (Priority                   ) & (uint32_t)((1UL << (SubPriorityBits    )) - 1UL);
+  \brief   Set Interrupt Vector
+  \details Sets an interrupt vector in SRAM based interrupt vector table.
+           VTOR must been relocated to SRAM before.
+  \param [in]   vector    Address of interrupt handler function
+__STATIC_INLINE void __NVIC_SetVector(IRQn_Type IRQn, uint32_t vector)
+  uint32_t *vectors = (uint32_t *)SCB->VTOR;
+  vectors[(int32_t)IRQn + NVIC_USER_IRQ_OFFSET] = vector;
+  __DSB();
+  \brief   Get Interrupt Vector
+  \details Reads an interrupt vector from interrupt vector table.
+  \return                 Address of interrupt handler function
+__STATIC_INLINE uint32_t __NVIC_GetVector(IRQn_Type IRQn)
+  return vectors[(int32_t)IRQn + NVIC_USER_IRQ_OFFSET];
+  \brief   System Reset
+  \details Initiates a system reset request to reset the MCU.
+__NO_RETURN __STATIC_INLINE void __NVIC_SystemReset(void)
+  __DSB();                                                          /* Ensure all outstanding memory accesses included
+        buffered write are completed before reset */
+  SCB->AIRCR  = (uint32_t)((0x5FAUL << SCB_AIRCR_VECTKEY_Pos)    |
+                           (SCB->AIRCR & SCB_AIRCR_PRIGROUP_Msk) |
+                            SCB_AIRCR_SYSRESETREQ_Msk    );         /* Keep priority group unchanged */
+  __DSB();                                                          /* Ensure completion of memory access */
+  for(;;)                                                           /* wait until reset */
+    __NOP();
+/*@} end of CMSIS_Core_NVICFunctions */
+/* ##########################  MPU functions  #################################### */
+#include "mpu_armv7.h"
+#endif
+/* ##########################  FPU functions  #################################### */
+  \defgroup CMSIS_Core_FpuFunctions FPU Functions
+  \brief    Function that provides FPU type.
+  \brief   get FPU type
+  \details returns the FPU type
+  \returns
+   - \b  0: No FPU
+   - \b  1: Single precision FPU
+   - \b  2: Double + Single precision FPU
+__STATIC_INLINE uint32_t SCB_GetFPUType(void)
+  uint32_t mvfr0;
+  mvfr0 = SCB->MVFR0;
+  if      ((mvfr0 & (FPU_MVFR0_Single_precision_Msk | FPU_MVFR0_Double_precision_Msk)) == 0x220U)
+    return 2U;           /* Double + Single precision FPU */
+  else if ((mvfr0 & (FPU_MVFR0_Single_precision_Msk | FPU_MVFR0_Double_precision_Msk)) == 0x020U)
+    return 1U;           /* Single precision FPU */
+  else
+    return 0U;           /* No FPU */
+/*@} end of CMSIS_Core_FpuFunctions */
+/* ##########################  Cache functions  #################################### */
+#if ((defined (__ICACHE_PRESENT) && (__ICACHE_PRESENT == 1U)) || \
+     (defined (__DCACHE_PRESENT) && (__DCACHE_PRESENT == 1U)))
+#include "cachel1_armv7.h"
+#endif
+/* ##################################    SysTick function  ############################################ */
+  \defgroup CMSIS_Core_SysTickFunctions SysTick Functions
+  \brief    Functions that configure the System.
+#if defined (__Vendor_SysTickConfig) && (__Vendor_SysTickConfig == 0U)
+  \brief   System Tick Configuration
+  \details Initializes the System Timer and its interrupt, and starts the System Tick Timer.
+           Counter is in free running mode to generate periodic interrupts.
+  \param [in]  ticks  Number of ticks between two interrupts.
+  \return          0  Function succeeded.
+  \return          1  Function failed.
+  \note    When the variable <b>__Vendor_SysTickConfig</b> is set to 1, then the
+           function <b>SysTick_Config</b> is not included. In this case, the file <b><i>device</i>.h</b>
+           must contain a vendor-specific implementation of this function.
+__STATIC_INLINE uint32_t SysTick_Config(uint32_t ticks)
+  if ((ticks - 1UL) > SysTick_LOAD_RELOAD_Msk)
+    return (1UL);                                                   /* Reload value impossible */
+  SysTick->LOAD  = (uint32_t)(ticks - 1UL);                         /* set reload register */
+  NVIC_SetPriority (SysTick_IRQn, (1UL << __NVIC_PRIO_BITS) - 1UL); /* set Priority for Systick Interrupt */
+  SysTick->VAL   = 0UL;                                             /* Load the SysTick Counter Value */
+  SysTick->CTRL  = SysTick_CTRL_CLKSOURCE_Msk |
+                   SysTick_CTRL_TICKINT_Msk   |
+                   SysTick_CTRL_ENABLE_Msk;                         /* Enable SysTick IRQ and SysTick Timer */
+  return (0UL);                                                     /* Function successful */
+#endif
+/*@} end of CMSIS_Core_SysTickFunctions */
+/* ##################################### Debug In/Output function ########################################### */
+  \defgroup CMSIS_core_DebugFunctions ITM Functions
+  \brief    Functions that access the ITM debug interface.
+extern volatile int32_t ITM_RxBuffer;                              /*!< External variable to receive characters. */
+#define                 ITM_RXBUFFER_EMPTY  ((int32_t)0x5AA55AA5U) /*!< Value identifying \ref ITM_RxBuffer is ready for next character. */
+  \brief   ITM Send Character
+  \details Transmits a character via the ITM channel 0, and
+           \li Just returns when no debugger is connected that has booked the output.
+           \li Is blocking when a debugger is connected, but the previous character sent has not been transmitted.
+  \param [in]     ch  Character to transmit.
+  \returns            Character to transmit.
+__STATIC_INLINE uint32_t ITM_SendChar (uint32_t ch)
+  if (((ITM->TCR & ITM_TCR_ITMENA_Msk) != 0UL) &&      /* ITM enabled */
+      ((ITM->TER & 1UL               ) != 0UL)   )     /* ITM Port #0 enabled */
+    while (ITM->PORT[0U].u32 == 0UL)
+      __NOP();
+    ITM->PORT[0U].u8 = (uint8_t)ch;
+  return (ch);
+  \brief   ITM Receive Character
+  \details Inputs a character via the external variable \ref ITM_RxBuffer.
+  \return             Received character.
+  \return         -1  No character pending.
+__STATIC_INLINE int32_t ITM_ReceiveChar (void)
+  int32_t ch = -1;                           /* no character available */
+  if (ITM_RxBuffer != ITM_RXBUFFER_EMPTY)
+    ch = ITM_RxBuffer;
+    ITM_RxBuffer = ITM_RXBUFFER_EMPTY;       /* ready for next character */
+  return (ch);
+  \brief   ITM Check Character
+  \details Checks whether a character is pending for reading in the variable \ref ITM_RxBuffer.
+  \return          0  No character available.
+  \return          1  Character available.
+__STATIC_INLINE int32_t ITM_CheckChar (void)
+  if (ITM_RxBuffer == ITM_RXBUFFER_EMPTY)
+    return (0);                              /* no character available */
+  else
+    return (1);                              /*    character available */
+/*@} end of CMSIS_core_DebugFunctions */
+#ifdef __cplusplus
+#endif
+#endif /* __CORE_CM7_H_DEPENDANT */
+#endif /* __CMSIS_GENERIC */
diff --git a/bsps/arm/include/core_cmFunc.h b/bsps/arm/include/core_cmFunc.h
deleted file mode 100644
index d4c46661db..0000000000
--- a/bsps/arm/include/core_cmFunc.h
+++ /dev/null
@@ -1,87 +0,0 @@
- * @file
- * @brief    CMSIS Cortex-M Core Function Access Header File
- * @version  V4.30
- * @date     20. October 2015
-/* Copyright (c) 2009 - 2015 ARM LIMITED
-   All rights reserved.
-   Redistribution and use in source and binary forms, with or without
-   modification, are permitted provided that the following conditions are met:
-   - Redistributions of source code must retain the above copyright
-     notice, this list of conditions and the following disclaimer.
-   - Redistributions in binary form must reproduce the above copyright
-     notice, this list of conditions and the following disclaimer in the
-     documentation and/or other materials provided with the distribution.
-   - Neither the name of ARM nor the names of its contributors may be used
-     to endorse or promote products derived from this software without
-     specific prior written permission.
-   THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
-   AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
-   IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
-   ARE DISCLAIMED. IN NO EVENT SHALL COPYRIGHT HOLDERS AND CONTRIBUTORS BE
-   LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
-   CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
-   SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
-   INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
-   CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
-   ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
-   POSSIBILITY OF SUCH DAMAGE.
-#if   defined ( __ICCARM__ )
- #pragma system_include         /* treat file as system include file for MISRA check */
-#elif defined(__ARMCC_VERSION) && (__ARMCC_VERSION >= 6010050)
-  #pragma clang system_header   /* treat file as system include file */
-#endif
-#ifndef __CORE_CMFUNC_H
-#define __CORE_CMFUNC_H
-/* ###########################  Core Function Access  ########################### */
-/** \ingroup  CMSIS_Core_FunctionInterface
-    \defgroup CMSIS_Core_RegAccFunctions CMSIS Core Register Access Functions
-/*------------------ RealView Compiler -----------------*/
-#if   defined ( __CC_ARM )
-  #include "cmsis_armcc.h"
-/*------------------ ARM Compiler V6 -------------------*/
-  #include "cmsis_armcc_V6.h"
-/*------------------ GNU Compiler ----------------------*/
-#elif defined ( __GNUC__ )
-  #include "cmsis_gcc.h"
-/*------------------ ICC Compiler ----------------------*/
-#elif defined ( __ICCARM__ )
-  #include <cmsis_iar.h>
-/*------------------ TI CCS Compiler -------------------*/
-#elif defined ( __TMS470__ )
-  #include <cmsis_ccs.h>
-/*------------------ TASKING Compiler ------------------*/
-#elif defined ( __TASKING__ )
-   * The CMSIS functions have been implemented as intrinsics in the compiler.
-   * Please use "carm -?i" to get an up to date list of all intrinsics,
-   * Including the CMSIS ones.
-/*------------------ COSMIC Compiler -------------------*/
-#elif defined ( __CSMC__ )
-  #include <cmsis_csm.h>
-#endif
-/*@} end of CMSIS_Core_RegAccFunctions */
-#endif /* __CORE_CMFUNC_H */
diff --git a/bsps/arm/include/core_cmInstr.h b/bsps/arm/include/core_cmInstr.h
index 0bf0e501f0..0000000000
--- a/bsps/arm/include/core_cmInstr.h
+++ /dev/null
@@ -1,88 +0,0 @@
- * @file
- * @brief    CMSIS Cortex-M Core Instruction Access Header File
- * @version  V4.30
-#endif
-#ifndef __CORE_CMINSTR_H
-#define __CORE_CMINSTR_H
-/* ##########################  Core Instruction Access  ######################### */
-/** \defgroup CMSIS_Core_InstructionInterface CMSIS Core Instruction Interface
-  \ingroup CMSIS
-  Access to dedicated instructions
-#endif
-/*@}*/ /* end of group CMSIS_Core_InstructionInterface */
-#endif /* __CORE_CMINSTR_H */
diff --git a/bsps/arm/include/core_cmSimd.h b/bsps/arm/include/core_cmSimd.h
index 08f9e9ad70..0000000000
--- a/bsps/arm/include/core_cmSimd.h
+++ /dev/null
@@ -1,97 +0,0 @@
- * @file
- * @brief    CMSIS Cortex-M SIMD Header File
- * @version  V4.30
-#endif
-#ifndef __CORE_CMSIMD_H
-#define __CORE_CMSIMD_H
-#ifdef __cplusplus
- extern "C" {
-#endif
-/* ###################  Compiler specific Intrinsics  ########################### */
-/** \defgroup CMSIS_SIMD_intrinsics CMSIS SIMD Intrinsics
-  \ingroup CMSIS
-  Access to dedicated SIMD instructions
-#endif
-/*@} end of group CMSIS_SIMD_intrinsics */
-#ifdef __cplusplus
-#endif
-#endif /* __CORE_CMSIMD_H */
diff --git a/bsps/arm/include/mpu_armv7.h b/bsps/arm/include/mpu_armv7.h
new file mode 100644
index 0000000000..d9eedf81a6
--- /dev/null
+++ b/bsps/arm/include/mpu_armv7.h
@@ -0,0 +1,275 @@
+ * @file     mpu_armv7.h
+ * @brief    CMSIS MPU API for Armv7-M MPU
+ * @version  V5.1.2
+ * @date     25. May 2020
+ * Copyright (c) 2017-2020 Arm Limited. All rights reserved.
+ * SPDX-License-Identifier: Apache-2.0
+ * Licensed under the Apache License, Version 2.0 (the License); you may
+ * not use this file except in compliance with the License.
+ * You may obtain a copy of the License at
+ * www.apache.org/licenses/LICENSE-2.0
+ * Unless required by applicable law or agreed to in writing, software
+ * distributed under the License is distributed on an AS IS BASIS, WITHOUT
+ * WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+ * See the License for the specific language governing permissions and
+ * limitations under the License.
+#if   defined ( __ICCARM__ )
+  #pragma system_include         /* treat file as system include file for MISRA check */
+#elif defined (__clang__)
+  #pragma clang system_header    /* treat file as system include file */
+#endif
+#ifndef ARM_MPU_ARMV7_H
+#define ARM_MPU_ARMV7_H
+#define ARM_MPU_REGION_SIZE_32B      ((uint8_t)0x04U) ///!< MPU Region Size 32 Bytes
+#define ARM_MPU_REGION_SIZE_64B      ((uint8_t)0x05U) ///!< MPU Region Size 64 Bytes
+#define ARM_MPU_REGION_SIZE_128B     ((uint8_t)0x06U) ///!< MPU Region Size 128 Bytes
+#define ARM_MPU_REGION_SIZE_256B     ((uint8_t)0x07U) ///!< MPU Region Size 256 Bytes
+#define ARM_MPU_REGION_SIZE_512B     ((uint8_t)0x08U) ///!< MPU Region Size 512 Bytes
+#define ARM_MPU_REGION_SIZE_1KB      ((uint8_t)0x09U) ///!< MPU Region Size 1 KByte
+#define ARM_MPU_REGION_SIZE_2KB      ((uint8_t)0x0AU) ///!< MPU Region Size 2 KBytes
+#define ARM_MPU_REGION_SIZE_4KB      ((uint8_t)0x0BU) ///!< MPU Region Size 4 KBytes
+#define ARM_MPU_REGION_SIZE_8KB      ((uint8_t)0x0CU) ///!< MPU Region Size 8 KBytes
+#define ARM_MPU_REGION_SIZE_16KB     ((uint8_t)0x0DU) ///!< MPU Region Size 16 KBytes
+#define ARM_MPU_REGION_SIZE_32KB     ((uint8_t)0x0EU) ///!< MPU Region Size 32 KBytes
+#define ARM_MPU_REGION_SIZE_64KB     ((uint8_t)0x0FU) ///!< MPU Region Size 64 KBytes
+#define ARM_MPU_REGION_SIZE_128KB    ((uint8_t)0x10U) ///!< MPU Region Size 128 KBytes
+#define ARM_MPU_REGION_SIZE_256KB    ((uint8_t)0x11U) ///!< MPU Region Size 256 KBytes
+#define ARM_MPU_REGION_SIZE_512KB    ((uint8_t)0x12U) ///!< MPU Region Size 512 KBytes
+#define ARM_MPU_REGION_SIZE_1MB      ((uint8_t)0x13U) ///!< MPU Region Size 1 MByte
+#define ARM_MPU_REGION_SIZE_2MB      ((uint8_t)0x14U) ///!< MPU Region Size 2 MBytes
+#define ARM_MPU_REGION_SIZE_4MB      ((uint8_t)0x15U) ///!< MPU Region Size 4 MBytes
+#define ARM_MPU_REGION_SIZE_8MB      ((uint8_t)0x16U) ///!< MPU Region Size 8 MBytes
+#define ARM_MPU_REGION_SIZE_16MB     ((uint8_t)0x17U) ///!< MPU Region Size 16 MBytes
+#define ARM_MPU_REGION_SIZE_32MB     ((uint8_t)0x18U) ///!< MPU Region Size 32 MBytes
+#define ARM_MPU_REGION_SIZE_64MB     ((uint8_t)0x19U) ///!< MPU Region Size 64 MBytes
+#define ARM_MPU_REGION_SIZE_128MB    ((uint8_t)0x1AU) ///!< MPU Region Size 128 MBytes
+#define ARM_MPU_REGION_SIZE_256MB    ((uint8_t)0x1BU) ///!< MPU Region Size 256 MBytes
+#define ARM_MPU_REGION_SIZE_512MB    ((uint8_t)0x1CU) ///!< MPU Region Size 512 MBytes
+#define ARM_MPU_REGION_SIZE_1GB      ((uint8_t)0x1DU) ///!< MPU Region Size 1 GByte
+#define ARM_MPU_REGION_SIZE_2GB      ((uint8_t)0x1EU) ///!< MPU Region Size 2 GBytes
+#define ARM_MPU_REGION_SIZE_4GB      ((uint8_t)0x1FU) ///!< MPU Region Size 4 GBytes
+#define ARM_MPU_AP_NONE 0U ///!< MPU Access Permission no access
+#define ARM_MPU_AP_PRIV 1U ///!< MPU Access Permission privileged access only
+#define ARM_MPU_AP_URO  2U ///!< MPU Access Permission unprivileged access read-only
+#define ARM_MPU_AP_FULL 3U ///!< MPU Access Permission full access
+#define ARM_MPU_AP_PRO  5U ///!< MPU Access Permission privileged access read-only
+#define ARM_MPU_AP_RO   6U ///!< MPU Access Permission read-only access
+/** MPU Region Base Address Register Value
+* \param Region The region to be configured, number 0 to 15.
+* \param BaseAddress The base address for the region.
+#define ARM_MPU_RBAR(Region, BaseAddress) \
+  (((BaseAddress) & MPU_RBAR_ADDR_Msk) |  \
+   ((Region) & MPU_RBAR_REGION_Msk)    |  \
+   (MPU_RBAR_VALID_Msk))
+* MPU Memory Access Attributes
+* \param TypeExtField      Type extension field, allows you to configure memory access type, for example strongly ordered, peripheral.
+* \param IsShareable       Region is shareable between multiple bus masters.
+* \param IsCacheable       Region is cacheable, i.e. its value may be kept in cache.
+* \param IsBufferable      Region is bufferable, i.e. using write-back caching. Cacheable but non-bufferable regions use write-through policy.
+#define ARM_MPU_ACCESS_(TypeExtField, IsShareable, IsCacheable, IsBufferable)   \
+  ((((TypeExtField) << MPU_RASR_TEX_Pos) & MPU_RASR_TEX_Msk)                  | \
+   (((IsShareable)  << MPU_RASR_S_Pos)   & MPU_RASR_S_Msk)                    | \
+   (((IsCacheable)  << MPU_RASR_C_Pos)   & MPU_RASR_C_Msk)                    | \
+   (((IsBufferable) << MPU_RASR_B_Pos)   & MPU_RASR_B_Msk))
+* MPU Region Attribute and Size Register Value
+* \param DisableExec       Instruction access disable bit, 1= disable instruction fetches.
+* \param AccessPermission  Data access permissions, allows you to configure read/write access for User and Privileged mode.
+* \param AccessAttributes  Memory access attribution, see \ref ARM_MPU_ACCESS_.
+* \param SubRegionDisable  Sub-region disable field.
+* \param Size              Region size of the region to be configured, for example 4K, 8K.
+#define ARM_MPU_RASR_EX(DisableExec, AccessPermission, AccessAttributes, SubRegionDisable, Size)    \
+  ((((DisableExec)      << MPU_RASR_XN_Pos)   & MPU_RASR_XN_Msk)                                  | \
+   (((AccessPermission) << MPU_RASR_AP_Pos)   & MPU_RASR_AP_Msk)                                  | \
+   (((AccessAttributes) & (MPU_RASR_TEX_Msk | MPU_RASR_S_Msk | MPU_RASR_C_Msk | MPU_RASR_B_Msk))) | \
+   (((SubRegionDisable) << MPU_RASR_SRD_Pos)  & MPU_RASR_SRD_Msk)                                 | \
+   (((Size)             << MPU_RASR_SIZE_Pos) & MPU_RASR_SIZE_Msk)                                | \
+   (((MPU_RASR_ENABLE_Msk))))
+#define ARM_MPU_RASR(DisableExec, AccessPermission, TypeExtField, IsShareable, IsCacheable, IsBufferable, SubRegionDisable, Size) \
+  ARM_MPU_RASR_EX(DisableExec, AccessPermission, ARM_MPU_ACCESS_(TypeExtField, IsShareable, IsCacheable, IsBufferable), SubRegionDisable, Size)
+* MPU Memory Access Attribute for strongly ordered memory.
+*  - TEX: 000b
+*  - Shareable
+*  - Non-cacheable
+*  - Non-bufferable
+#define ARM_MPU_ACCESS_ORDERED ARM_MPU_ACCESS_(0U, 1U, 0U, 0U)
+* MPU Memory Access Attribute for device memory.
+*  - TEX: 000b (if shareable) or 010b (if non-shareable)
+*  - Shareable or non-shareable
+*  - Non-cacheable
+*  - Bufferable (if shareable) or non-bufferable (if non-shareable)
+* \param IsShareable Configures the device memory as shareable or non-shareable.
+#define ARM_MPU_ACCESS_DEVICE(IsShareable) ((IsShareable) ? ARM_MPU_ACCESS_(0U, 1U, 0U, 1U) : ARM_MPU_ACCESS_(2U, 0U, 0U, 0U))
+* MPU Memory Access Attribute for normal memory.
+*  - TEX: 1BBb (reflecting outer cacheability rules)
+*  - Cacheable or non-cacheable (reflecting inner cacheability rules)
+*  - Bufferable or non-bufferable (reflecting inner cacheability rules)
+* \param OuterCp Configures the outer cache policy.
+* \param InnerCp Configures the inner cache policy.
+* \param IsShareable Configures the memory as shareable or non-shareable.
+#define ARM_MPU_ACCESS_NORMAL(OuterCp, InnerCp, IsShareable) ARM_MPU_ACCESS_((4U | (OuterCp)), IsShareable, ((InnerCp) >> 1U), ((InnerCp) & 1U))
+* MPU Memory Access Attribute non-cacheable policy.
+#define ARM_MPU_CACHEP_NOCACHE 0U
+* MPU Memory Access Attribute write-back, write and read allocate policy.
+#define ARM_MPU_CACHEP_WB_WRA 1U
+* MPU Memory Access Attribute write-through, no write allocate policy.
+#define ARM_MPU_CACHEP_WT_NWA 2U
+* MPU Memory Access Attribute write-back, no write allocate policy.
+#define ARM_MPU_CACHEP_WB_NWA 3U
+* Struct for a single MPU Region
+typedef struct {
+  uint32_t RBAR; //!< The region base address register value (RBAR)
+  uint32_t RASR; //!< The region attribute and size register value (RASR) \ref MPU_RASR
+} ARM_MPU_Region_t;
+/** Enable the MPU.
+* \param MPU_Control Default access permissions for unconfigured regions.
+__STATIC_INLINE void ARM_MPU_Enable(uint32_t MPU_Control)
+  __DMB();
+  MPU->CTRL = MPU_Control | MPU_CTRL_ENABLE_Msk;
+#ifdef SCB_SHCSR_MEMFAULTENA_Msk
+  SCB->SHCSR |= SCB_SHCSR_MEMFAULTENA_Msk;
+#endif
+  __DSB();
+  __ISB();
+/** Disable the MPU.
+__STATIC_INLINE void ARM_MPU_Disable(void)
+  __DMB();
+  SCB->SHCSR &= ~SCB_SHCSR_MEMFAULTENA_Msk;
+#endif
+  MPU->CTRL  &= ~MPU_CTRL_ENABLE_Msk;
+  __DSB();
+  __ISB();
+/** Clear and disable the given MPU region.
+* \param rnr Region number to be cleared.
+__STATIC_INLINE void ARM_MPU_ClrRegion(uint32_t rnr)
+  MPU->RNR = rnr;
+  MPU->RASR = 0U;
+/** Configure an MPU region.
+* \param rbar Value for RBAR register.
+* \param rasr Value for RASR register.
+__STATIC_INLINE void ARM_MPU_SetRegion(uint32_t rbar, uint32_t rasr)
+  MPU->RBAR = rbar;
+  MPU->RASR = rasr;
+/** Configure the given MPU region.
+* \param rnr Region number to be configured.
+__STATIC_INLINE void ARM_MPU_SetRegionEx(uint32_t rnr, uint32_t rbar, uint32_t rasr)
+  MPU->RNR = rnr;
+  MPU->RBAR = rbar;
+  MPU->RASR = rasr;
+/** Memcpy with strictly ordered memory access, e.g. used by code in ARM_MPU_Load().
+* \param dst Destination data is copied to.
+* \param src Source data is copied from.
+* \param len Amount of data words to be copied.
+__STATIC_INLINE void ARM_MPU_OrderedMemcpy(volatile uint32_t* dst, const uint32_t* __RESTRICT src, uint32_t len)
+  uint32_t i;
+  for (i = 0U; i < len; ++i)
+    dst[i] = src[i];
+/** Load the given number of MPU regions from a table.
+* \param table Pointer to the MPU configuration table.
+* \param cnt Amount of regions to be configured.
+__STATIC_INLINE void ARM_MPU_Load(ARM_MPU_Region_t const* table, uint32_t cnt)
+  const uint32_t rowWordSize = sizeof(ARM_MPU_Region_t)/4U;
+  while (cnt > MPU_TYPE_RALIASES) {
+    ARM_MPU_OrderedMemcpy(&(MPU->RBAR), &(table->RBAR), MPU_TYPE_RALIASES*rowWordSize);
+    table += MPU_TYPE_RALIASES;
+    cnt -= MPU_TYPE_RALIASES;
+  ARM_MPU_OrderedMemcpy(&(MPU->RBAR), &(table->RBAR), cnt*rowWordSize);
+#endif
2.25.1
