Discussion: How to handle HALs, SDKs and libraries
oss at c-mauderer.de oss at c-mauderer.de
Sun Jul 16 19:17:26 UTC 2023
Hello Karel,
Am 16.07.23 um 12:37 schrieb Karel Gardas:
> On 7/16/23 10:03, oss at c-mauderer.de wrote:
>>>> Of course the revision from two months back has to be available in
>>>> the repo. It doesn't really matter whether it's on master because
>>>> the code just worked or whether it's a RTEMS specific branch because
>>>> adaptions have been necessary.
>>> You "it doesn't really matter" worries me a little bit. I'm not sure
>>> this functionality is even supported hence my question above if you
>>> have tested it yourself.
>> Yes, I use that regularly. For an (old) example, take a look at a
>> branch in the repo that I use to test GSoC work:
>>    https://gitlab.com/c-mauderer/rtems-bbb/-/tree/6
>> I have a libs/rtems-libbsd submodule there that uses the revision
>> c9474c0b which is on a cm/20200726_fix branch in my clone of
>> rtems-libbsd. In the .gitmodules the branch is still set to "master".
>> Despite that, git can find thre right commit ID.
> Cool! So it didn't work for me due to (i) my git bug or (ii) my git
> doesn't supporting whatever or simply due to (iii) me making silly
> mistake somewhere.
> Will need to recheck this. Thanks for the info!
> Karel
Seems that we are not the only ones with a waf based build system that
want to manipulate submodules:
https://github.com/ArduPilot/ardupilot/pull/3592
The final solution seems to be a bit different. Their wscript in the
latest version has a "--no-submodule-update" parameter. So they decided
to just update the submodules every time. Can be interesting for users
because they don't have to care for outdated submodules if they pull a
new version.
But I think the problem with adding it as a fixed step is, that we have
a problem with the releases. A release tar ball is not a git repo
anymore. So a "git submodule init --update" or similar will not work. We
would need some mechanism to detect whether it's a git repo or not.
Best regards
Christian
