[PATCH rtems 6/6] bsps/imxrt: Add imxrt1166_cm7_saltshaker BSP
oss at c-mauderer.de oss at c-mauderer.de
Mon Jul 17 19:17:48 UTC 2023
Hello Jacob,
Am 14.07.23 um 09:08 schrieb Christian MAUDERER:
> Hello Jacob,
> On 2023-07-14 08:36, Christian MAUDERER wrote:
>> Hello Jacob,
>> On 2023-07-13 18:59, Jacob Killelea wrote:
>>> Hi Christian,
>>> This looks awesome! Do you have any interest in adding support for
>>> the i.MXRT1062 based Teensy 4.0 and Teensy 4.1?
>>> - Jacob
>> the Teensy look like interesting boards. Maybe a bit low on memory.
>> That would make it difficult to run libbsd on them. The boards don't
>> have network, so it's not a problem for the network part. But on the
>> i.MXRT, I also use the MMC/SD stack from libbsd so the SD card would
>> be a problem.
> Just noted: The Teensy 4.1 has an optional Ethernet. So some network
> library would be good. But like I said: The target has too few memory
> for libbsd. lwIP would be a candidate. But I haven't tried that on the
> i.MXRT yet.
> Best regards
> Christian
It was mean from you to point me to that board. It seems like an
interesting challenge ;)
I've thrown together a quick prototype for a BSP. It's not yet tested.
It doesn't even link the tests yet, because the linker command file
isn't adapted yet. But the BSP sources at least compile without problems:
   https://gitlab.com/c-mauderer/rtems/-/tree/cm/20230717_teensy41
If I find some more time and maybe some hardware, I maybe continue to
try to write the linker command file. But I don't promise anything ;-)
Best regards
Christian
>> On the Teensy 4.1, the two memories (optional Flash and optional
>> PSRAM) on the FlexSPI maybe can be a bit tricky.
>> These boards would be pure hobby time. I don't think that I will find
>> enough time to fully support the boards at the moment. But I would
>> expect that the basics should work with the i.MXRT1052 BSP already.
>> The 1050 and 1060 family is quite similar. If you want, I can give you
>> some guidance what would be necessary to support the boards.
>> Best regards
>> Christian
