[PATCH rtems-source-builder v2] bare/config: add renode rsb installation config
Mon Jul 17 21:27:49 UTC 2023
This patch applies cleanly and builds renode for me. Thanks for making
the changes, this recipe should be much easier to maintain for version
updates of renode. i will push it if no one complains soon.
We will definitely need some documentation for building this. At the
least you should start with a blog post, but in general we should find
a good place for documenting RSB build dependencies. Maybe a new
section in https://docs.rtems.org/branches/master/user/rsb/index.html
On Ubuntu, in addition to whatever "typical" development tools I
already have installed, I had to add mono-devel and gtk-sharp2
On Wed, Jul 12, 2023 at 2:43 AM Muhammad Sulthan Mazaya
<msulthanmazaya at gmail.com> wrote:
> Use the design of how qemu handle config files + add version number to
> the config file name.
>  bare/config/devel/renode-1.13.3-1.cfg     | 11 ++++++
>  bare/config/devel/renode.bset             |  7 ++++
>  source-builder/config/renode-1.13.3.cfg   |  7 ++++
>  source-builder/config/renode-common-1.cfg | 45 +++++++++++++++++++++++
>  4 files changed, 70 insertions(+)
>  create mode 100644 bare/config/devel/renode-1.13.3-1.cfg
>  create mode 100644 bare/config/devel/renode.bset
>  create mode 100644 source-builder/config/renode-1.13.3.cfg
>  create mode 100644 source-builder/config/renode-common-1.cfg
> diff --git a/bare/config/devel/renode-1.13.3-1.cfg b/bare/config/devel/renode-1.13.3-1.cfg
> new file mode 100644
> index 0000000..ad9b0ad
> --- /dev/null
> +++ b/bare/config/devel/renode-1.13.3-1.cfg
> @@ -0,0 +1,11 @@
> +# Renode from git
> +%if %{release} == %{nil}
> + %define release 1
> +%endif
> +%define renode_version 1.13.3
> +%include %{_configdir}/renode-1.13.3.cfg
> diff --git a/bare/config/devel/renode.bset b/bare/config/devel/renode.bset
> index 0000000..f89168d
> --- /dev/null
> +++ b/bare/config/devel/renode.bset
> @@ -0,0 +1,7 @@
> +# Build set for Renode
> +%define release 1
> +devel/renode-1.13.3-1
> diff --git a/source-builder/config/renode-1.13.3.cfg b/source-builder/config/renode-1.13.3.cfg
> index 0000000..5aff341
> --- /dev/null
> +++ b/source-builder/config/renode-1.13.3.cfg
> @@ -0,0 +1,7 @@
> +# Renode 1.13.3 Version 1.
> +# This configuration file configure's, make's and install's Renode.
> +%include %{_configdir}/renode-common-1.cfg
> diff --git a/source-builder/config/renode-common-1.cfg b/source-builder/config/renode-common-1.cfg
> index 0000000..65be946
> --- /dev/null
> +++ b/source-builder/config/renode-common-1.cfg
> @@ -0,0 +1,45 @@
> +# Renode from git
> + %define release 1
> +%endif
> +Name:      renode-%{renode_version}-%{_host}-%{release}
> +Summary:   Renode v%{renode_version}
> +Version:   %{renode_version}
> +Release:   %{release}
> +URL:      http://www.renode.io
> +# Renode source
> +%source set renode https://github.com/renode/renode/releases/download/v%{renode_version}/renode_%{renode_version}_source.tar.xz
> +# Prepare the source code.
> +%prep
> +  build_top=$(pwd)
> +  source_dir_renode="renode_%{renode_version}_source"
> +  %source setup renode -q -n renode_%{renode_version}_source
> +  cd ${build_top}
> +%build
> +  build_top=$(pwd)
> +  cd ${source_dir_renode}
> +  ./build.sh
> +  cd ${build_top}
> +%install
> +  build_top=$(pwd)
> +  mkdir -p %{_bindir}
> +  cp -r ./${source_dir_renode}/* %{_bindir}
> +  cd ${build_top}
> 2.34.1
> devel mailing list
> devel at rtems.org
