[PATCH rtems-tools] tester/rtems: add renode implementation
Mon Jul 17 21:31:03 UTC 2023
The patch has 3 whitespace errors. I have fixed them, and I will push this soon.
On Tue, Jun 27, 2023 at 8:42 PM Muhammad Sulthan Mazaya
<msulthanmazaya at gmail.com> wrote:
> Hi Joel and Chris,
> Yes, and I will be working on the rsb patch for renode installation next.
> Regards,
> Mazaya
> On Wed, Jun 28, 2023 at 12:34 PM Chris Johns <chrisj at rtems.org> wrote:
>> I am as well
>> Chris
>> On 28/6/2023 12:25 am, Joel Sherrill wrote:
>> > I'm OK with this patch.
>> > Is it assuming that you installed renode on your own -- not using the RSB?
>> > --joel
>> > On Mon, Jun 26, 2023 at 5:37 PM Muhammad Sulthan Mazaya
>> > <msulthanmazaya at gmail.com <mailto:msulthanmazaya at gmail.com>> wrote:
>> >     Hi Chris,
>> >     Yes they are the same. I thought there was an email error, so I re-send it
>> >     twice.
>> >     On Tue, 27 Jun 2023, 07:46 Chris Johns, <chrisj at rtems.org
>> >     <mailto:chrisj at rtems.org>> wrote:
>> >         Hi Muhammad,
>> >         The patch looks good, thanks.
>> >         Are the 3 posted patches the same version?
>> >         Chris
>> >         On 26/6/2023 2:17 pm, Muhammad Sulthan Mazaya wrote:
>> >         > Patch for the implementation of renode on rtems-test. Currently, renode
>> >         > installation has not been implemented in rsb. Thus, for testing, you can
>> >         > install renode by referring to the documentation link below.
>> >         > Downloads for debian, fedora, arch, macOS, and windows:
>> >         > https://renode.io/#downloads <https://renode.io/#downloads>
>> >         > Alternatively, you can access Renode's GitHub releases:
>> >         > https://github.com/renode/renode/releases/tag/v1.13.3
>> >         <https://github.com/renode/renode/releases/tag/v1.13.3>
>> >         > You can also build it from source:
>> >         https://renode.readthedocs.io/en/latest/advanced/building_from_sources.html#building-from-source <https://renode.readthedocs.io/en/latest/advanced/building_from_sources.html#building-from-source>
>> >         > This patch consists of changes to test kendrytek210 using renode. To
>> >         > test it, you can build the kendrytek210 test suite as instructed in the
>> >         > rtems-docs (Alan's patch here:
>> >         https://lists.rtems.org/pipermail/devel/2023-April/074838.html
>> >         <https://lists.rtems.org/pipermail/devel/2023-April/074838.html>).
>> >         > Then, use the following command to run the test suite.
>> >         > rtems-test --rtems-bsp=kendrytek210-renode [test-suite-path]
>> >         >  .../testing/bsps/kendrytek210-renode.ini      | 38 +++++++++++
>> >         >  tester/rtems/testing/renode.cfg               | 64 +++++++++++++++++++
>> >         >  .../testing/renode_scripts/kendrytek210.resc  | 53 +++++++++++++++
>> >         >  3 files changed, 155 insertions(+)
>> >         >  create mode 100644 tester/rtems/testing/bsps/kendrytek210-renode.ini
>> >         >  create mode 100644 tester/rtems/testing/renode.cfg
>> >         >  create mode 100644 tester/rtems/testing/renode_scripts/kendrytek210.resc
>> >         > diff --git a/tester/rtems/testing/bsps/kendrytek210-renode.ini
>> >         b/tester/rtems/testing/bsps/kendrytek210-renode.ini
>> >         > new file mode 100644
>> >         > index 0000000..95850c5
>> >         > --- /dev/null
>> >         > +++ b/tester/rtems/testing/bsps/kendrytek210-renode.ini
>> >         > @@ -0,0 +1,38 @@
>> >         > +# RTEMS Tools Project (http://www.rtems.org/ <http://www.rtems.org/>)
>> >         > +# Copyright 2010-2014 Chris Johns (chrisj at rtems.org
>> >         <mailto:chrisj at rtems.org>)
>> >         > +# All rights reserved.
>> >         > +# This file is part of the RTEMS Tools package in 'rtems-tools'.
>> >         > +# Redistribution and use in source and binary forms, with or without
>> >         > +# modification, are permitted provided that the following conditions
>> >         are met:
>> >         > +# 1. Redistributions of source code must retain the above copyright
>> >         notice,
>> >         > +# this list of conditions and the following disclaimer.
>> >         > +# 2. Redistributions in binary form must reproduce the above
>> >         copyright notice,
>> >         > +# this list of conditions and the following disclaimer in the
>> >         documentation
>> >         > +# and/or other materials provided with the distribution.
>> >         > +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
>> >         "AS IS"
>> >         > +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
>> >         TO, THE
>> >         > +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>> >         PURPOSE
>> >         > +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
>> >         CONTRIBUTORS BE
>> >         > +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> >         > +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>> >         > +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>> >         BUSINESS
>> >         > +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
>> >         > +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
>> >         > +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
>> >         OF THE
>> >         > +# POSSIBILITY OF SUCH DAMAGE.
>> >         > +# The Kendrytek210 Renode BSP
>> >         > +[kendrytek210-renode]
>> >         > +bsp             = kendrytek210-renode
>> >         > +arch            = riscv
>> >         > +tester          = %{_rtscripts}/renode.cfg
>> >         > +bsp_resc_script = %{_rtscripts}/renode_scripts/kendrytek210.resc
>> >         > diff --git a/tester/rtems/testing/renode.cfg
>> >         b/tester/rtems/testing/renode.cfg
>> >         > index 0000000..49e84a5
>> >         > --- /dev/null
>> >         > +++ b/tester/rtems/testing/renode.cfg
>> >         > @@ -0,0 +1,64 @@
>> >         are met:
>> >         notice,
>> >         copyright notice,
>> >         documentation
>> >         "AS IS"
>> >         TO, THE
>> >         PURPOSE
>> >         CONTRIBUTORS BE
>> >         BUSINESS
>> >         OF THE
>> >         > +# Renode
>> >         > +# Use a renode command to run the executable in the renode simulator.
>> >         > +%include %{_configdir}/base.cfg
>> >         > +%include %{_configdir}/checks.cfg
>> >         > +# Console.
>> >         > +%define console_telnet
>> >         > +%include %{_configdir}/console.cfg
>> >         > +# RTEMS version
>> >         > +%include %{_rtdir}/rtems/version.cfg
>> >         > +# Renode executable
>> >         > +%define renode_cmd renode --hide-monitor
>> >         > +%define binary_opts -e $bin?=@%{test_executable}
>> >         > +%define start_opts -e "s @%{bsp_resc_script}"
>> >         > +%define trim_command sed 's/.*\[output\] //'
>> >         > +# Executable
>> >         > +%execute %{renode_cmd} %{binary_opts} %{start_opts} | %{trim_command}
>> >         > diff --git a/tester/rtems/testing/renode_scripts/kendrytek210.resc
>> >         b/tester/rtems/testing/renode_scripts/kendrytek210.resc
>> >         > index 0000000..fe13aa8
>> >         > --- /dev/null
>> >         > +++ b/tester/rtems/testing/renode_scripts/kendrytek210.resc
>> >         > @@ -0,0 +1,53 @@
>> >         > +using sysbus
>> >         > +using monitor
>> >         > +mach create "K210"
>> >         > +machine LoadPlatformDescription @platforms/cpus/kendryte_k210.repl
>> >         > +path add @/
>> >         > +showAnalyzer "uartAnalyzer" uart
>> >         Antmicro.Renode.Analyzers.LoggingUartAnalyzer
>> >         > +uartAnalyzer TimestampFormat None
>> >         > +set report_repeating_line """
>> >         > +from Antmicro.Renode.Logging import ConsoleBackend
>> >         > +ConsoleBackend.Instance.ReportRepeatingLines = True
>> >         > +set add_hook """
>> >         > +def match(line):
>> >         > +    ok_to_kill_lines = [
>> >         > +        '*** TEST STATE: USER_INPUT',
>> >         > +        '*** TEST STATE: BENCHMARK',
>> >         > +        '*** END OF TEST ',
>> >         > +        '*** FATAL ***'
>> >         > +    return any(l in line for l in ok_to_kill_lines)
>> >         > +def hook(line):
>> >         > +    monitor.Parse("q")
>> >         +Antmicro.Renode.Hooks.UartHooksExtensions.AddLineHook(monitor.Machine["sysbus.uart"], match, hook)
>> >         > +python $add_hook
>> >         > +python $report_repeating_line
>> >         > +sysbus Tag <0x50440000 0x10000> "SYSCTL"
>> >         > +sysbus Tag <0x50440018 0x4> "pll_lock" 0xFFFFFFFF
>> >         > +sysbus Tag <0x5044000C 0x4> "pll1"
>> >         > +sysbus Tag <0x50440008 0x4> "pll0"
>> >         > +sysbus Tag <0x50440020 0x4> "clk_sel0"
>> >         > +sysbus Tag <0x50440028 0x4> "clk_en_cent"
>> >         > +sysbus Tag <0x5044002c 0x4> "clk_en_peri"
>> >         > +# enable uart tx
>> >         > +uart WriteDoubleWord 0x8 0x1
>> >         > +macro reset
>> >         > +    sysbus LoadELF $bin
>> >         > +runMacro $reset
>> >         _______________________________________________
>> >         devel mailing list
>> >         devel at rtems.org <mailto:devel at rtems.org>
>> >         http://lists.rtems.org/mailman/listinfo/devel
>> >         <http://lists.rtems.org/mailman/listinfo/devel>
>> >     devel mailing list
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
