[PATCH rtems-docs] user: Update @rtems-ver-major@ to use sphinx substitution extention
Muhammad Sulthan Mazaya msulthanmazaya at gmail.com
Tue Jul 18 08:16:07 UTC 2023
 Using sphinx-substitution-extensions to manage the variable @rtems-ver-major at .
 Originally Utkarsh's idea:
 https://discord.com/channels/820452222382112799/820452222848335924/1118416996606943302
 I have tested and built the docs to see if it works and it does
 subtitute the variable. The changes are: the variable @rtems-ver-major@
 is now |rtems-ver-major|. For inline code block we use
 :substitution-code:`{content}` and for multiline code block we use:
 .. code-block:: {language}
   :substitutions:
   {content}
 user/bsps/aarch64/raspberrypi4.rst  |  3 +-
 user/bsps/aarch64/xilinx-zynqmp.rst |  3 +-
 user/bsps/arm/altera-cyclone-v.rst  |  3 +-
 user/bsps/arm/beagle.rst            |  3 +-
 user/bsps/arm/imx.rst               |  3 +-
 user/bsps/arm/imxrt.rst             |  9 ++--
 user/bsps/arm/raspberrypi.rst       |  6 ++-
 user/bsps/arm/xen.rst               |  6 ++-
 user/bsps/bsps-microblaze.rst       |  6 ++-
 user/bsps/bsps-powerpc.rst          | 10 ++--
 user/bsps/bsps-riscv.rst            | 12 +++--
 user/conf.py                        |  6 +++
 user/deployment/index.rst           | 71 ++++++++++++++------------
 user/exe/initialization.rst         | 13 ++---
 user/exe/loader.rst                 | 15 +++---
 user/installation/developer.rst     |  9 ++--
 user/installation/releases.rst      |  6 ++-
 user/start/app.rst                  | 60 ++++++++++++----------
 user/start/bsp-build.rst            | 79 ++++++++++++++++-------------
 19 files changed, 185 insertions(+), 138 deletions(-)
diff --git a/user/bsps/aarch64/raspberrypi4.rst b/user/bsps/aarch64/raspberrypi4.rst
index efb09b6..616cc3f 100644
--- a/user/bsps/aarch64/raspberrypi4.rst
+++ b/user/bsps/aarch64/raspberrypi4.rst
@@ -79,8 +79,9 @@ can be processed in a similar way.
 To create the kernel image:
 .. code-block:: shell
+   :substitutions:
-  $ aarch64-rtems at rtems-ver-major@-objcopy -Obinary hello.exe kernel8.img
+  $ aarch64-rtems|rtems-ver-major|-objcopy -Obinary hello.exe kernel8.img
 Copy the kernel image to the SD card.
diff --git a/user/bsps/aarch64/xilinx-zynqmp.rst b/user/bsps/aarch64/xilinx-zynqmp.rst
index 4de0115..255628a 100644
--- a/user/bsps/aarch64/xilinx-zynqmp.rst
+++ b/user/bsps/aarch64/xilinx-zynqmp.rst
@@ -143,8 +143,9 @@ Prepare the RTEMS image
 Prepare your RTEMS image to boot from u-boot with the following commands:
+   :substitutions:
-  $ aarch64-rtems at rtems-ver-major@-objcopy -Obinary ticker.exe ticker.bin
+  $ aarch64-rtems|rtems-ver-major|-objcopy -Obinary ticker.exe ticker.bin
   $ gzip -9 ticker.bin
   $ mkimage -A arm64 -O rtems -T kernel -a 0x10000000 -e 0x10000000 -n RTEMS -d ticker.bin.gz rtems.img
diff --git a/user/bsps/arm/altera-cyclone-v.rst b/user/bsps/arm/altera-cyclone-v.rst
index 12e563e..5aaa841 100644
--- a/user/bsps/arm/altera-cyclone-v.rst
+++ b/user/bsps/arm/altera-cyclone-v.rst
@@ -26,8 +26,9 @@ The application executable file (ELF file) must be converted to an U-Boot
 image.  Use the following commands:
 .. code-block:: none
+   :substitutions:
-    arm-rtems at rtems-ver-major@-objcopy -O binary app.exe app.bin
+    arm-rtems|rtems-ver-major|-objcopy -O binary app.exe app.bin
     gzip -9 -f -c app.bin > app.bin.gz
     mkimage -A arm -O linux -T kernel -a 0x00300000 -e 0x00300000 -n RTEMS -d app.bin.gz app.img
diff --git a/user/bsps/arm/beagle.rst b/user/bsps/arm/beagle.rst
index 55f75c0..9da18e8 100644
--- a/user/bsps/arm/beagle.rst
+++ b/user/bsps/arm/beagle.rst
@@ -31,8 +31,9 @@ Boot via U-Boot
 To boot via uboot, the ELF must be converted to a U-Boot image like below:
+   :substitutions:
-    arm-rtems at rtems-ver-major@-objcopy hello.exe -O binary app.bin
+    arm-rtems|rtems-ver-major|-objcopy hello.exe -O binary app.bin
     gzip -9 app.bin
     mkimage -A arm -O linux -T kernel -a 0x80000000 -e 0x80000000 -n RTEMS -d app.bin.gz rtems-app.img
diff --git a/user/bsps/arm/imx.rst b/user/bsps/arm/imx.rst
index 47ad503..6c8cf49 100644
--- a/user/bsps/arm/imx.rst
+++ b/user/bsps/arm/imx.rst
@@ -74,8 +74,9 @@ The application executable file (ELF file) must be converted to an U-Boot
+   :substitutions:
     mkimage -A arm -O linux -T kernel -a 0x80200000 -e 0x80200000 -n RTEMS -d app.bin.gz app.img
diff --git a/user/bsps/arm/imxrt.rst b/user/bsps/arm/imxrt.rst
index 3df233f..4af603b 100644
--- a/user/bsps/arm/imxrt.rst
+++ b/user/bsps/arm/imxrt.rst
@@ -39,7 +39,7 @@ For programming the HyperFlash in case 1, you can use the on board debugger
 integrated into the IMXRT1050-EVKB. You can generate a flash image out of a
 compiled RTEMS application with for example::
-  arm-rtems at rtems-ver-major@-objcopy -O binary build/arm/imxrt1052/testsuites/samples/hello.exe hello.bin
+  arm-rtems|rtems-ver-major|-objcopy -O binary build/arm/imxrt1052/testsuites/samples/hello.exe hello.bin
 Then just copy the generated binary to the mass storage provided by the
 debugger. Wait a bit till the mass storage vanishes and re-appears. After that,
@@ -91,7 +91,7 @@ The BSP uses a FDT based initialization. The FDT is linked into the application.
 You can find the default FDT used in the BSP in
 `bsps/arm/imxrt/dts/imxrt1050-evkb.dts`. The FDT is split up into two parts. The
 core part is put into an `dtsi` file and is installed together with normal
-headers into `${PREFIX}/arm-rtems at rtems-ver-major@/imxrt1052/lib/include`. You
+headers into `${PREFIX}/arm-rtems|rtems-ver-major|/imxrt1052/lib/include`. You
 can use that to create your own device tree based on that. Basically use
 something like::
@@ -126,9 +126,10 @@ You can then convert your FDT into a C file with (replace `YOUR.dts` and similar
 with your FDT source names):
+   :substitutions:
-  sh> arm-rtems at rtems-ver-major@-cpp -P -x assembler-with-cpp \
-             -I ${PREFIX}/arm-rtems at rtems-ver-major@/imxrt1052/lib/include \
+  sh> arm-rtems|rtems-ver-major|-cpp -P -x assembler-with-cpp \
+             -I ${PREFIX}/arm-rtems|rtems-ver-major|/imxrt1052/lib/include \
              -include "YOUR.dts" /dev/null | \
          dtc -O dtb -o "YOUR.dtb" -b 0 -p 64
   sh> rtems-bin2c -A 8 -C -N imxrt_dtb "YOUR.dtb" "YOUR.c"
diff --git a/user/bsps/arm/raspberrypi.rst b/user/bsps/arm/raspberrypi.rst
index 8f40e92..40da041 100644
--- a/user/bsps/arm/raspberrypi.rst
+++ b/user/bsps/arm/raspberrypi.rst
@@ -40,8 +40,9 @@ Other executables can be processed in a similar way.
+   :substitutions:
-     $ xsarm-rtems at rtems-ver-major@-objcopy -Obinary hello.exe kernel.img
+     $ xsarm-rtems|rtems-ver-major|-objcopy -Obinary hello.exe kernel.img
@@ -131,8 +132,9 @@ We need to pass in the DTB file to GDB before running the example.
 In a new terminal, run GDB using
+   :substitutions:
-     $ arm-rtems at rtems-ver-major@-gdb hello.exe
+     $ arm-rtems|rtems-ver-major|-gdb hello.exe
 This will open GDB and will load the symbol table from hello.exe. Issue the
 following commands in the GDB prompt.
diff --git a/user/bsps/arm/xen.rst b/user/bsps/arm/xen.rst
index d7538f0..07c503a 100644
--- a/user/bsps/arm/xen.rst
+++ b/user/bsps/arm/xen.rst
@@ -41,14 +41,16 @@ already be built with the BSP.
 The ``ticker.exe`` file can be found in the BSP build tree at:
+   :substitutions:
-    arm-rtems at rtems-ver-major@/c/xen_virtual/testsuites/samples/ticker.exe
+    arm-rtems|rtems-ver-major|/c/xen_virtual/testsuites/samples/ticker.exe
 The ``ticker.exe`` elf file must be translated to a binary format.
+   :substitutions:
-    arm-rtems at rtems-ver-major@-objcopy -O binary ticker.exe ticker.bin
+    arm-rtems|rtems-ver-major|-objcopy -O binary ticker.exe ticker.bin
 Then place the ``ticker.bin`` file on the dom0 filesystem.
diff --git a/user/bsps/bsps-microblaze.rst b/user/bsps/bsps-microblaze.rst
index 6fe4891..f53c9cc 100644
--- a/user/bsps/bsps-microblaze.rst
+++ b/user/bsps/bsps-microblaze.rst
@@ -113,8 +113,9 @@ For example, to debug the hello sample and break at ``Init``, first start QEMU.
 Then start GDB and connect to QEMU.
+   :substitutions:
-  $ microblaze-rtems at rtems-ver-major@-gdb build/microblaze/kcu105_qemu/testsuites/samples/hello.exe
+  $ microblaze-rtems|rtems-ver-major|-gdb build/microblaze/kcu105_qemu/testsuites/samples/hello.exe
   (gdb) target remote localhost:1234
   (gdb) break Init
   (gdb) continue
@@ -174,8 +175,9 @@ With the debug server running, connect to the debug server with GDB, load the
 application, and debug as usual. By default the GDB server listens on port 3002.
+   :substitutions:
-  $ microblaze-rtems at rtems-ver-major@-gdb example.exe
+  $ microblaze-rtems|rtems-ver-major|-gdb example.exe
   (gdb) target extended-remote localhost:3002
   (gdb) load
   (gdb) break Init
diff --git a/user/bsps/bsps-powerpc.rst b/user/bsps/bsps-powerpc.rst
index 6b63936..217aa63 100644
--- a/user/bsps/bsps-powerpc.rst
+++ b/user/bsps/bsps-powerpc.rst
@@ -35,11 +35,12 @@ The application executable file (ELF file) must be converted to a boot
+   :substitutions:
-    powerpc-rtems at rtems-ver-major@-objcopy -O binary -R .comment -S ticker.exe rtems
+    powerpc-rtems|rtems-ver-major|-objcopy -O binary -R .comment -S ticker.exe rtems
     gzip -9 -f rtems
-    powerpc-rtems at rtems-ver-major@-ld -o ticker.boot bootloader.o --just-symbols=ticker.exe -b binary rtems.gz -T ppcboot.lds -no-warn-mismatch
-    powerpc-rtems at rtems-ver-major@-objcopy -O binary ticker.boot ticker.bin
+    powerpc-rtems|rtems-ver-major|-ld -o ticker.boot bootloader.o --just-symbols=ticker.exe -b binary rtems.gz -T ppcboot.lds -no-warn-mismatch
+    powerpc-rtems|rtems-ver-major|-objcopy -O binary ticker.boot ticker.bin
 mpc55xxevb
@@ -106,8 +107,9 @@ The application executable file (ELF file) must be converted to an U-Boot
+   :substitutions:
-    powerpc-rtems at rtems-ver-major@-objcopy -O binary app.exe app.bin
+    powerpc-rtems|rtems-ver-major|-objcopy -O binary app.exe app.bin
     mkimage -A ppc -O linux -T kernel -a 0x4000 -e 0x4000 -n RTEMS -d app.bin.gz app.img
diff --git a/user/bsps/bsps-riscv.rst b/user/bsps/bsps-riscv.rst
index 263796e..678d5c4 100644
--- a/user/bsps/bsps-riscv.rst
+++ b/user/bsps/bsps-riscv.rst
@@ -220,15 +220,17 @@ The "config.ini" file.
 Build RTEMS.
+   :substitutions:
-    $ ./waf configure --prefix=$HOME/rtems-start/rtems/@rtems-ver-major@
+    $ ./waf configure --prefix=$HOME/rtems-start/rtems/|rtems-ver-major|
     $ ./waf
 Convert .exe to .elf file.
+   :substitutions:
-    $ riscv-rtems at rtems-ver-major@-objcopy build/riscv/mpfs64imafdc/testsuites/smptests/smp01.exe build/riscv/mpfs64imafdc/testsuites/smptests/smp01.elf
+    $ riscv-rtems|rtems-ver-major|-objcopy build/riscv/mpfs64imafdc/testsuites/smptests/smp01.exe build/riscv/mpfs64imafdc/testsuites/smptests/smp01.elf
 Generate a payload for the `smp01.elf` using the `hss-payload-generator <https://github.com/polarfire-soc/hart-software-services/blob/master/tools/hss-payload-generator>`_.
@@ -326,8 +328,9 @@ Configuration file ``config.ini``:
 Build RTEMS:
+   :substitutions:
     $ ./waf
 **Flash an executable to a supported K210 board**
@@ -336,8 +339,9 @@ Binary images can be flashed to the Sipeed boards through the USB port using
 the ``kflash.py`` utility available from the python pip utility.
+   :substitutions:
-    $ riscv-rtems at rtems-ver-major@-objcopy -Obinary ticker.exe ticker.bin
+    $ riscv-rtems|rtems-ver-major|-objcopy -Obinary ticker.exe ticker.bin
     $ kflash.py --uart /dev/ttyUSB0 ticker.bin
 After the image is flashed, the RTEMS image will automatically boot. It will
diff --git a/user/conf.py b/user/conf.py
index 134ec61..3b88520 100644
--- a/user/conf.py
+++ b/user/conf.py
@@ -12,3 +12,9 @@ latex_documents = [
      u'RTEMS Documentation Project',
      'manual'),
+extensions += ['sphinx_substitution_extensions']
+rst_prolog = """
+.. |rtems-ver-major| replace:: 6
diff --git a/user/deployment/index.rst b/user/deployment/index.rst
index d1315af..9fccc57 100644
--- a/user/deployment/index.rst
+++ b/user/deployment/index.rst
@@ -94,11 +94,12 @@ Create a configuration file for the ``project``:
 Add the following to the buildset configuration file:
+   :substitutions:
     # Project Tools
-    @rtems-ver-major@/rtems-aarch64
+    |rtems-ver-major|/rtems-aarch64
 Commit the changes to the repository:
@@ -128,22 +129,23 @@ Inspect the tarfile to check the path matches the prefix used to build
 the tools (sizes may vary):
+   :substitutions:
    $ tar Jtvf tar/project-tools.tar.bz2 | less
    drwxr-xr-x  0 chris  eng        0 Sep  6 14:27 opt/project/bin/
-   -rwxr-xr-x  0 chris  eng  1320888 Sep  6 14:20 opt/project/bin/aarch64-rtems at rtems-ver-major@-addr2line
-   -rwxr-xr-x  0 chris  eng  1358688 Sep  6 14:20 opt/project/bin/aarch64-rtems at rtems-ver-major@-ar
-   -rwxr-xr-x  0 chris  eng  2381976 Sep  6 14:20 opt/project/bin/aarch64-rtems at rtems-ver-major@-as
-   -rwxr-xr-x  0 chris  eng  1328440 Sep  6 14:27 opt/project/bin/aarch64-rtems at rtems-ver-major@-c++
-   -rwxr-xr-x  0 chris  eng  1316240 Sep  6 14:20 opt/project/bin/aarch64-rtems at rtems-ver-major@-c++filt
-   -rwxr-xr-x  0 chris  eng  1328440 Sep  6 14:27 opt/project/bin/aarch64-rtems at rtems-ver-major@-cpp
-   -rwxr-xr-x  0 chris  eng    60792 Sep  6 14:20 opt/project/bin/aarch64-rtems at rtems-ver-major@-elfedit
-   -rwxr-xr-x  0 chris  eng  1328440 Sep  6 14:27 opt/project/bin/aarch64-rtems at rtems-ver-major@-g++
-   -rwxr-xr-x  0 chris  eng  1328440 Sep  6 14:27 opt/project/bin/aarch64-rtems at rtems-ver-major@-gcc
-   -rwxr-xr-x  0 chris  eng  1328440 Sep  6 14:27 opt/project/bin/aarch64-rtems at rtems-ver-major@-gcc-12.1.1
-   -rwxr-xr-x  0 chris  eng    48568 Sep  6 14:27 opt/project/bin/aarch64-rtems at rtems-ver-major@-gcc-ar
-   -rwxr-xr-x  0 chris  eng    48568 Sep  6 14:27 opt/project/bin/aarch64-rtems at rtems-ver-major@-gcc-nm
-   -rwxr-xr-x  0 chris  eng    48576 Sep  6 14:27 opt/project/bin/aarch64-rtems at rtems-ver-major@-gcc-ranlib
+   -rwxr-xr-x  0 chris  eng  1320888 Sep  6 14:20 opt/project/bin/aarch64-rtems|rtems-ver-major|-addr2line
+   -rwxr-xr-x  0 chris  eng  1358688 Sep  6 14:20 opt/project/bin/aarch64-rtems|rtems-ver-major|-ar
+   -rwxr-xr-x  0 chris  eng  2381976 Sep  6 14:20 opt/project/bin/aarch64-rtems|rtems-ver-major|-as
+   -rwxr-xr-x  0 chris  eng  1328440 Sep  6 14:27 opt/project/bin/aarch64-rtems|rtems-ver-major|-c++
+   -rwxr-xr-x  0 chris  eng  1316240 Sep  6 14:20 opt/project/bin/aarch64-rtems|rtems-ver-major|-c++filt
+   -rwxr-xr-x  0 chris  eng  1328440 Sep  6 14:27 opt/project/bin/aarch64-rtems|rtems-ver-major|-cpp
+   -rwxr-xr-x  0 chris  eng    60792 Sep  6 14:20 opt/project/bin/aarch64-rtems|rtems-ver-major|-elfedit
+   -rwxr-xr-x  0 chris  eng  1328440 Sep  6 14:27 opt/project/bin/aarch64-rtems|rtems-ver-major|-g++
+   -rwxr-xr-x  0 chris  eng  1328440 Sep  6 14:27 opt/project/bin/aarch64-rtems|rtems-ver-major|-gcc
+   -rwxr-xr-x  0 chris  eng  1328440 Sep  6 14:27 opt/project/bin/aarch64-rtems|rtems-ver-major|-gcc-12.1.1
+   -rwxr-xr-x  0 chris  eng    48568 Sep  6 14:27 opt/project/bin/aarch64-rtems|rtems-ver-major|-gcc-ar
+   -rwxr-xr-x  0 chris  eng    48568 Sep  6 14:27 opt/project/bin/aarch64-rtems|rtems-ver-major|-gcc-nm
+   -rwxr-xr-x  0 chris  eng    48576 Sep  6 14:27 opt/project/bin/aarch64-rtems|rtems-ver-major|-gcc-ranlib
 Tools and Kernel
@@ -163,6 +165,7 @@ and a BSP:
 Add the following to the buildset configuration file and save:
+   :substitutions:
    # Project Tools and BSP
@@ -170,8 +173,8 @@ Add the following to the buildset configuration file and save:
    %define with_rtems_bsp     aarch64/xilinx_versal_aiedge
    %define with_rtems_bspopts BSP_XILINX_VERSAL_NOCACHE_LENGTH=0x4000000 \
                               BSP_XILINX_VERSAL_RAM_LENGTH=0x200000000
-   @rtems-ver-major@/rtems-kernel
+   |rtems-ver-major|/rtems-kernel
 The configuration provides BSP options. Commit the changes to the
 repository:
@@ -231,14 +234,15 @@ tools and BSPs:
+   :substitutions:
    # Project Tools and BSPs
    %define with_rtems_bsp_config config/project-bsps.ini
-   @rtems-ver-major@/rtems-arm
+   |rtems-ver-major|/rtems-arm
 Add a kernel configuration INI file:
@@ -336,23 +340,24 @@ submodule:
 The tarfile can be reviewed to see the BSP libraries built (sizes may vary):
+   :substitutions:
    $ tar jtvf tar/project-aarch64-tools-bsp-libbsd.tar.bz2 | \
               grep -e '\.a$' | grep -e 'xilinx_versal_aiedge'
-   -rw-r--r--  0 chris  eng 138936312 Sep  7 14:58 opt/project/aarch64-rtems at rtems-ver-major@/xilinx_versal_aiedge/lib/libbsd.a
-   -rw-r--r--  0 chris  eng    686190 Sep  7 14:56 opt/project/aarch64-rtems at rtems-ver-major@/xilinx_versal_aiedge/lib/libdebugger.a
-   -rw-r--r--  0 chris  eng    164086 Sep  7 14:56 opt/project/aarch64-rtems at rtems-ver-major@/xilinx_versal_aiedge/lib/libftpd.a
-   -rw-r--r--  0 chris  eng    107560 Sep  7 14:56 opt/project/aarch64-rtems at rtems-ver-major@/xilinx_versal_aiedge/lib/libftpfs.a
-   -rw-r--r--  0 chris  eng    978812 Sep  7 14:56 opt/project/aarch64-rtems at rtems-ver-major@/xilinx_versal_aiedge/lib/libjffs2.a
-   -rw-r--r--  0 chris  eng    412354 Sep  7 14:56 opt/project/aarch64-rtems at rtems-ver-major@/xilinx_versal_aiedge/lib/libmghttpd.a
-   -rw-r--r--  0 chris  eng   2099962 Sep  7 14:56 opt/project/aarch64-rtems at rtems-ver-major@/xilinx_versal_aiedge/lib/librtemsbsp.a
-   -rw-r--r--  0 chris  eng  29693496 Sep  7 14:56 opt/project/aarch64-rtems at rtems-ver-major@/xilinx_versal_aiedge/lib/librtemscpu.a
-   -rw-r--r--  0 chris  eng    435236 Sep  7 14:56 opt/project/aarch64-rtems at rtems-ver-major@/xilinx_versal_aiedge/lib/librtemscxx.a
-   -rw-r--r--  0 chris  eng    141234 Sep  7 14:56 opt/project/aarch64-rtems at rtems-ver-major@/xilinx_versal_aiedge/lib/librtemsdefaultconfig.a
-   -rw-r--r--  0 chris  eng    856514 Sep  7 14:56 opt/project/aarch64-rtems at rtems-ver-major@/xilinx_versal_aiedge/lib/librtemstest.a
-   -rw-r--r--  0 chris  eng    159004 Sep  7 14:56 opt/project/aarch64-rtems at rtems-ver-major@/xilinx_versal_aiedge/lib/libtelnetd.a
-   -rw-r--r--  0 chris  eng    137386 Sep  7 14:56 opt/project/aarch64-rtems at rtems-ver-major@/xilinx_versal_aiedge/lib/libtftpfs.a
-   -rw-r--r--  0 chris  eng    476692 Sep  7 14:56 opt/project/aarch64-rtems at rtems-ver-major@/xilinx_versal_aiedge/lib/libz.a
+   -rw-r--r--  0 chris  eng 138936312 Sep  7 14:58 opt/project/aarch64-rtems|rtems-ver-major|/xilinx_versal_aiedge/lib/libbsd.a
+   -rw-r--r--  0 chris  eng    686190 Sep  7 14:56 opt/project/aarch64-rtems|rtems-ver-major|/xilinx_versal_aiedge/lib/libdebugger.a
+   -rw-r--r--  0 chris  eng    164086 Sep  7 14:56 opt/project/aarch64-rtems|rtems-ver-major|/xilinx_versal_aiedge/lib/libftpd.a
+   -rw-r--r--  0 chris  eng    107560 Sep  7 14:56 opt/project/aarch64-rtems|rtems-ver-major|/xilinx_versal_aiedge/lib/libftpfs.a
+   -rw-r--r--  0 chris  eng    978812 Sep  7 14:56 opt/project/aarch64-rtems|rtems-ver-major|/xilinx_versal_aiedge/lib/libjffs2.a
+   -rw-r--r--  0 chris  eng    412354 Sep  7 14:56 opt/project/aarch64-rtems|rtems-ver-major|/xilinx_versal_aiedge/lib/libmghttpd.a
+   -rw-r--r--  0 chris  eng   2099962 Sep  7 14:56 opt/project/aarch64-rtems|rtems-ver-major|/xilinx_versal_aiedge/lib/librtemsbsp.a
+   -rw-r--r--  0 chris  eng  29693496 Sep  7 14:56 opt/project/aarch64-rtems|rtems-ver-major|/xilinx_versal_aiedge/lib/librtemscpu.a
+   -rw-r--r--  0 chris  eng    435236 Sep  7 14:56 opt/project/aarch64-rtems|rtems-ver-major|/xilinx_versal_aiedge/lib/librtemscxx.a
+   -rw-r--r--  0 chris  eng    141234 Sep  7 14:56 opt/project/aarch64-rtems|rtems-ver-major|/xilinx_versal_aiedge/lib/librtemsdefaultconfig.a
+   -rw-r--r--  0 chris  eng    856514 Sep  7 14:56 opt/project/aarch64-rtems|rtems-ver-major|/xilinx_versal_aiedge/lib/librtemstest.a
+   -rw-r--r--  0 chris  eng    159004 Sep  7 14:56 opt/project/aarch64-rtems|rtems-ver-major|/xilinx_versal_aiedge/lib/libtelnetd.a
+   -rw-r--r--  0 chris  eng    137386 Sep  7 14:56 opt/project/aarch64-rtems|rtems-ver-major|/xilinx_versal_aiedge/lib/libtftpfs.a
+   -rw-r--r--  0 chris  eng    476692 Sep  7 14:56 opt/project/aarch64-rtems|rtems-ver-major|/xilinx_versal_aiedge/lib/libz.a
 Tools, Kernel with Config and Packages
diff --git a/user/exe/initialization.rst b/user/exe/initialization.rst
index f4b5d7e..fd192af 100644
--- a/user/exe/initialization.rst
+++ b/user/exe/initialization.rst
@@ -83,19 +83,20 @@ initialization is performed before multitasking is started.
 The RTEMS Tool ``rtems-exeinfo`` can provide some detail about the registered
 handlers. The following shows the initialization handlers for the Hello World
-sample application in the RTEMS kernel's testsuite::
+sample application in the RTEMS kernel's testsuite:
+   :substitutions:
- $ rtems-exeinfo --init arm-rtems at rtems-ver-major@/c/xilinx_zynq_zedboard/testsuites/samples/hello.exe
- RTEMS Executable Info @rtems-ver-major at .5416cfa39dd6
- exe: arm-rtems at rtems-ver-major@/c/xilinx_zynq_zedboard/testsuites/samples/hello.exe
+ $ rtems-exeinfo --init arm-rtems|rtems-ver-major|/c/xilinx_zynq_zedboard/testsuites/samples/hello.exe
+ RTEMS Executable Info |rtems-ver-major|.5416cfa39dd6
+ exe: arm-rtems|rtems-ver-major|/c/xilinx_zynq_zedboard/testsuites/samples/hello.exe
  Compilation:
   Producers: 2
    |  GNU AS 2.31.1: 14 objects
-   |  GNU C11 7.3.0 20180125 (RTEMS @rtems-ver-major@, RSB e55769c64cf1a201588565a5662deafe3f1ccdcc, Newlib 103b055035fea328f8bc7826801760fb1c055683): 284 objects
+   |  GNU C11 7.3.0 20180125 (RTEMS |rtems-ver-major|, RSB e55769c64cf1a201588565a5662deafe3f1ccdcc, Newlib 103b055035fea328f8bc7826801760fb1c055683): 284 objects
   Common flags: 4
    | -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard
diff --git a/user/exe/loader.rst b/user/exe/loader.rst
index be2e78e..cb174e7 100644
--- a/user/exe/loader.rst
+++ b/user/exe/loader.rst
@@ -457,10 +457,11 @@ This example shows creating an embedded symbol table object file and linking it
 into the base image.
+   :substitutions:
- $ sparc-rtems at rtems-ver-major@-gcc -mcpu=cypress foo.o -lrtemsbsp -lrtemscpu -o foo.pre
- $ rtems-syms -e -C sparc-rtems at rtems-ver-major@-gcc -c "-mcpu=cypress" -o foo-sym.o foo.pre
- $ sparc-rtems at rtems-ver-major@-gcc -mcpu=cypress foo.o foo-sym.o -lrtemsbsp -lrtemscpu -o foo.exe
+ $ sparc-rtems|rtems-ver-major|-gcc -mcpu=cypress foo.o -lrtemsbsp -lrtemscpu -o foo.pre
+ $ rtems-syms -e -C sparc-rtems|rtems-ver-major|-gcc -c "-mcpu=cypress" -o foo-sym.o foo.pre
+ $ sparc-rtems|rtems-ver-major|-gcc -mcpu=cypress foo.o foo-sym.o -lrtemsbsp -lrtemscpu -o foo.exe
 The link command line steps in this example are not complete.
@@ -485,9 +486,10 @@ The example shows creating and loading a symbol table executable object
 file. First create the symbol table's executable object file:
+   :substitutions:
- $ sparc-rtems at rtems-ver-major@-gcc -mcpu=cypress foo.o -lrtemsbsp -lrtemscpu -o foo.exe
- $ rtems-syms -C sparc-rtems at rtems-ver-major@-gcc -c "-mcpu=cypress" -o foo-sym.o foo.exe
+ $ sparc-rtems|rtems-ver-major|-gcc -mcpu=cypress foo.o -lrtemsbsp -lrtemscpu -o foo.exe
+ $ rtems-syms -C sparc-rtems|rtems-ver-major|-gcc -c "-mcpu=cypress" -o foo-sym.o foo.exe
@@ -631,8 +633,9 @@ target. The tool suite's command :program:`strip` can strip all the object files
 in a library with a single command.
+   :substitutions:
-  $ sparc-rtems at rtems-ver-major@-strip libc.a
+  $ sparc-rtems|rtems-ver-major|-strip libc.a
 Large Memory
diff --git a/user/installation/developer.rst b/user/installation/developer.rst
index 8acd68c..b2b414f 100644
--- a/user/installation/developer.rst
+++ b/user/installation/developer.rst
@@ -81,10 +81,11 @@ checked and this includes checking for the python development libraries GDB
 requires:
+   :substitutions:
   $ cd rsb
   $ ./source-builder/sb-check
-  RTEMS Source Builder - Check, @rtems-ver-major@ (089327b5dcf9)
+  RTEMS Source Builder - Check, |rtems-ver-major| (089327b5dcf9)
   Environment is ok
 If you are unsure how to specify the build set for the architecture you wish to
@@ -196,14 +197,14 @@ build, just ask the tool:
   2. The paths inspected. See :ref:`Configuration`.
-  3. A build set to build all RTEMS @rtems-ver-major@ supported architectures.
+  3. A build set to build all RTEMS |rtems-ver-major| supported architectures.
-  4. The build set for the ARM architecture on RTEMS @rtems-ver-major at .
+  4. The build set for the ARM architecture on RTEMS |rtems-ver-major|.
 Build a tool chain for the SPARC architecture. We are using the SPARC
 architecture because GDB has a good simulator that lets us run and
 test the samples RTEMS builds by default. The development version is
-one more than ``@rtems-ver-major@` and is on the ``master`` branch:
+one more than :substitution-code:``|rtems-ver-major|` and is on the ``master`` branch:
 .. _windows-tool-chain:
diff --git a/user/installation/releases.rst b/user/installation/releases.rst
index 6694806..1aef73d 100644
--- a/user/installation/releases.rst
+++ b/user/installation/releases.rst
@@ -84,8 +84,9 @@ If building on Windows:
 Download the RTEMS Source Builder (RSB) from the RTEMS FTP server:
+   :substitutions:
- $ wget https://ftp.rtems.org/pub/rtems/releases/@rtems-ver-major@/@rtems-ver-majminrev@/rtems-source-builder-@rtems-ver-majminrev@.tar.xz
+ $ wget https://ftp.rtems.org/pub/rtems/releases/|rtems-ver-major|/@rtems-ver-majminrev@/rtems-source-builder-@rtems-ver-majminrev@.tar.xz
  --2016-03-21 10:50:04-- https://ftp.rtems.org/pub/rtems/releases/@rtems-ver-major/@rtems-ver-majminrev@/rtems-source-builder-@rtems-ver-majminrev@.tar.xz
  Resolving ftp.rtems.org (ftp.rtems.org)... 140.211.10.151
  Connecting to ftp.rtems.org (ftp.rtems.org)|140.211.10.151|:443... connected.
@@ -121,8 +122,9 @@ If building on Windows add ``--jobs=none`` to avoid GNU make issues on Windows
 discussed in :ref:`msys2_parallel_builds`.
+   :substitutions:
  $ ../source-builder/sb-set-builder \
-     --prefix=/opt/rtems/@rtems-ver-major@ @rtems-ver-major@/rtems-sparc
+     --prefix=/opt/rtems/|rtems-ver-major| |rtems-ver-major|/rtems-sparc
 You can now build a third-party library or an application as defaulted in TBD.
diff --git a/user/start/app.rst b/user/start/app.rst
index 0599305..91659f8 100644
--- a/user/start/app.rst
+++ b/user/start/app.rst
@@ -8,7 +8,7 @@ Build Your Application
 You tested a BSP in the previous section.  We built the ``erc32`` BSP
-and it is installed under :file:`$HOME/quick-start/rtems/@rtems-ver-major@`.
+and it is installed under :substitution-code:`$HOME/quick-start/rtems/|rtems-ver-major|`.
 We will now create a simple Hello World application with a Git
 repository and using the `Waf <https://waf.io>`_ build system.
@@ -147,29 +147,30 @@ Configure the application using Waf's ``configure`` command:
 The output will be something close to:
+   :substitutions:
      Setting top to                           : $BASE/app/hello
      Setting out to                           : $BASE/app/hello/build
-     RTEMS Version                            : @rtems-ver-major@
-     Architectures                            : sparc-rtems at rtems-ver-major@
-     Board Support Package (BSP)              : sparc-rtems at rtems-ver-major@-erc32
+     RTEMS Version                            : |rtems-ver-major|
+     Architectures                            : sparc-rtems|rtems-ver-major|
+     Board Support Package (BSP)              : sparc-rtems|rtems-ver-major|-erc32
      Show commands                            : no
      Long commands                            : no
-     Checking for program 'sparc-rtems at rtems-ver-major@-gcc'  : $BASE/rtems/@rtems-ver-major@/bin/sparc-rtems at rtems-ver-major@-gcc
-     Checking for program 'sparc-rtems at rtems-ver-major@-g++'  : $BASE/rtems/@rtems-ver-major@/bin/sparc-rtems at rtems-ver-major@-g++
-     Checking for program 'sparc-rtems at rtems-ver-major@-ld'   : $BASE/rtems/@rtems-ver-major@/bin/sparc-rtems at rtems-ver-major@-ld
-     Checking for program 'sparc-rtems at rtems-ver-major@-ar'   : $BASE/rtems/@rtems-ver-major@/bin/sparc-rtems at rtems-ver-major@-ar
-     Checking for program 'sparc-rtems at rtems-ver-major@-nm'   : $BASE/rtems/@rtems-ver-major@/bin/sparc-rtems at rtems-ver-major@-nm
-     Checking for program 'sparc-rtems at rtems-ver-major@-objdump' : $BASE/rtems/@rtems-ver-major@/bin/sparc-rtems at rtems-ver-major@-objdump
-     Checking for program 'sparc-rtems at rtems-ver-major@-objcopy' : $BASE/rtems/@rtems-ver-major@/bin/sparc-rtems at rtems-ver-major@-objcopy
-     Checking for program 'sparc-rtems at rtems-ver-major@-readelf' : $BASE/rtems/@rtems-ver-major@/bin/sparc-rtems at rtems-ver-major@-readelf
-     Checking for program 'sparc-rtems6-strip'   : $BASE/rtems/@rtems-ver-major@/bin/sparc-rtems at rtems-ver-major@-strip
-     Checking for program 'sparc-rtems6-ranlib'  : $BASE/rtems/@rtems-ver-major@/bin/sparc-rtems at rtems-ver-major@-ranlib
-     Checking for program 'rtems-ld'             : $BASE/rtems/@rtems-ver-major@/bin/rtems-ld
-     Checking for program 'rtems-tld'            : $BASE/rtems/@rtems-ver-major@/bin/rtems-tld
-     Checking for program 'rtems-syms'           : $BASE/rtems/@rtems-ver-major@/bin/rtems-syms
-     Checking for program 'rtems-bin2c'          : $BASE/rtems/@rtems-ver-major@/bin/rtems-bin2c
+     Checking for program 'sparc-rtems|rtems-ver-major|-gcc'  : $BASE/rtems/|rtems-ver-major|/bin/sparc-rtems|rtems-ver-major|-gcc
+     Checking for program 'sparc-rtems|rtems-ver-major|-g++'  : $BASE/rtems/|rtems-ver-major|/bin/sparc-rtems|rtems-ver-major|-g++
+     Checking for program 'sparc-rtems|rtems-ver-major|-ld'   : $BASE/rtems/|rtems-ver-major|/bin/sparc-rtems|rtems-ver-major|-ld
+     Checking for program 'sparc-rtems|rtems-ver-major|-ar'   : $BASE/rtems/|rtems-ver-major|/bin/sparc-rtems|rtems-ver-major|-ar
+     Checking for program 'sparc-rtems|rtems-ver-major|-nm'   : $BASE/rtems/|rtems-ver-major|/bin/sparc-rtems|rtems-ver-major|-nm
+     Checking for program 'sparc-rtems|rtems-ver-major|-objdump' : $BASE/rtems/|rtems-ver-major|/bin/sparc-rtems|rtems-ver-major|-objdump
+     Checking for program 'sparc-rtems|rtems-ver-major|-objcopy' : $BASE/rtems/|rtems-ver-major|/bin/sparc-rtems|rtems-ver-major|-objcopy
+     Checking for program 'sparc-rtems|rtems-ver-major|-readelf' : $BASE/rtems/|rtems-ver-major|/bin/sparc-rtems|rtems-ver-major|-readelf
+     Checking for program 'sparc-rtems6-strip'   : $BASE/rtems/|rtems-ver-major|/bin/sparc-rtems|rtems-ver-major|-strip
+     Checking for program 'sparc-rtems6-ranlib'  : $BASE/rtems/|rtems-ver-major|/bin/sparc-rtems|rtems-ver-major|-ranlib
+     Checking for program 'rtems-ld'             : $BASE/rtems/|rtems-ver-major|/bin/rtems-ld
+     Checking for program 'rtems-tld'            : $BASE/rtems/|rtems-ver-major|/bin/rtems-tld
+     Checking for program 'rtems-syms'           : $BASE/rtems/|rtems-ver-major|/bin/rtems-syms
+     Checking for program 'rtems-bin2c'          : $BASE/rtems/|rtems-ver-major|/bin/rtems-bin2c
      Checking for program 'tar'                  : /usr/bin/tar
      Checking for program 'gcc, cc'              : $BASE/rtems/6/bin/sparc-rtems6-gcc
      Checking for program 'ar'                   : $BASE/rtems/6/bin/sparc-rtems6-ar
@@ -179,7 +180,7 @@ The output will be something close to:
      Checking for c flags '-MMD'                 : yes
      Checking for cxx flags '-MMD'               : yes
-     Compiler version (sparc-rtems at rtems-ver-major@-gcc)         : 10.2.1 20210309 (RTEMS @rtems-ver-major@, RSB 5e449fb5c2cb6812a238f9f9764fd339cbbf05c2, Newlib d10d0d9)
+     Compiler version (sparc-rtems|rtems-ver-major|-gcc)         : 10.2.1 20210309 (RTEMS |rtems-ver-major|, RSB 5e449fb5c2cb6812a238f9f9764fd339cbbf05c2, Newlib d10d0d9)
      Checking for a valid RTEMS BSP installation : yes
      Checking for RTEMS_DEBUG                    : no
      Checking for RTEMS_MULTIPROCESSING          : no
@@ -197,26 +198,29 @@ Build the application:
+   :substitutions:
-    Waf: Entering directory `$BASE/app/hello/build/sparc-rtems at rtems-ver-major@-erc32'
+    Waf: Entering directory `$BASE/app/hello/build/sparc-rtems|rtems-ver-major|-erc32'
     [1/3] Compiling init.c
     [2/3] Compiling hello.c
-    [3/3] Linking build/sparc-rtems at rtems-ver-major@-erc32/hello.exe
-    Waf: Leaving directory `$BASE/app/hello/build/sparc-rtems at rtems-ver-major@-erc32'
-    'build-sparc-rtems at rtems-ver-major@-erc32' finished successfully (0.183s)
+    [3/3] Linking build/sparc-rtems|rtems-ver-major|-erc32/hello.exe
+    Waf: Leaving directory `$BASE/app/hello/build/sparc-rtems|rtems-ver-major|-erc32'
+    'build-sparc-rtems|rtems-ver-major|-erc32' finished successfully (0.183s)
 Run the executable:
+   :substitutions:
-    rtems-run --rtems-bsps=erc32-sis build/sparc-rtems at rtems-ver-major@-erc32/hello.exe
+    rtems-run --rtems-bsps=erc32-sis build/sparc-rtems|rtems-ver-major|-erc32/hello.exe
+   :substitutions:
     RTEMS Testing - Run, @rtems-ver-mjminrev@
-    Command Line: $BASE/quick-start/rtems/@rtems-ver-major@/bin/rtems-run --rtems-bsps=erc32-sis build/sparc-rtems at rtems-ver-major@-erc32/hello.exe
+    Command Line: $BASE/quick-start/rtems/|rtems-ver-major|/bin/rtems-run --rtems-bsps=erc32-sis build/sparc-rtems|rtems-ver-major|-erc32/hello.exe
     Host: Linux  5.8.0-44-generic #50~20.04.1-Ubuntu SMP Wed Feb 10 21:07:30 UTC 2021 x86_64
     Python: 3.8.5 (default, Jan 27 2021, 15:41:15) [GCC 9.3.0]
     Host: Linux-5.8.0-44-generic-x86_64-with-glibc2.29 (Linux 5.8.0-44-generic #50~20.04.1-Ubuntu SMP Wed Feb 10 21:07:30 UTC 2021 x86_64 x86_64)
@@ -226,7 +230,7 @@ The output will be something close to:
     ERC32 emulation enabled
-    Loaded build/sparc-rtems at rtems-ver-major@-erc32/hello.exe, entry 0x02000000
+    Loaded build/sparc-rtems|rtems-ver-major|-erc32/hello.exe, entry 0x02000000
     Hello World
@@ -234,7 +238,7 @@ The output will be something close to:
     fatal source: 5 (RTEMS_FATAL_SOURCE_EXIT)
     fatal code: 0 (0x00000000)
     RTEMS version: 6.0.0.586e06ec6222f1cd1f005aa8f4a34a8b33f5d862
-    RTEMS tools: 10.2.1 20210309 (RTEMS @rtems-ver-major@, RSB 5e449fb5c2cb6812a238f9f9764fd339cbbf05c2, Newlib d10d0d9)
+    RTEMS tools: 10.2.1 20210309 (RTEMS |rtems-ver-major|, RSB 5e449fb5c2cb6812a238f9f9764fd339cbbf05c2, Newlib d10d0d9)
     executing thread ID: 0x08a010001
     executing thread name: UI1
     cpu 0 in error mode (tt = 0x101)
diff --git a/user/start/bsp-build.rst b/user/start/bsp-build.rst
index c62b6ba..e53225e 100644
--- a/user/start/bsp-build.rst
+++ b/user/start/bsp-build.rst
@@ -42,26 +42,28 @@ Git clone of the RSB the BSP will be version referenced in the RSB clone.
 To build the BSP with all the tests run this command:
+   :substitutions:
     cd $HOME/quick-start/src/rsb/rtems
     ../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/5 \
-        --target=sparc-rtems at rtems-ver-major@ --with-rtems-bsp=erc32 --with-rtems-tests=yes @rtems-ver-major@/rtems-kernel
+        --target=sparc-rtems|rtems-ver-major| --with-rtems-bsp=erc32 --with-rtems-tests=yes |rtems-ver-major|/rtems-kernel
 This command should output something like:
+   :substitutions:
     RTEMS Source Builder - Set Builder, @rtems-ver-majminver@
-    Build Set: @rtems-ver-major@/rtems-kernel
-    config: tools/rtems-kernel- at rtems-ver-major@.cfg
-    package: sparc-rtems at rtems-ver-major@-kernel-erc32-1
-    building: sparc-rtems at rtems-ver-major@-kernel-erc32-1
-    sizes: sparc-rtems at rtems-ver-major@-kernel-erc32-1: 2.279GB (installed: 44.612MB)
-    cleaning: sparc-rtems at rtems-ver-major@-kernel-erc32-1
-    reporting: tools/rtems-kernel- at rtems-ver-major@.cfg -> sparc-rtems at rtems-ver-major@-kernel-erc32-1.txt
-    reporting: tools/rtems-kernel- at rtems-ver-major@.cfg -> sparc-rtems at rtems-ver-major@-kernel-erc32-1.xml
-    installing: sparc-rtems at rtems-ver-major@-kernel-erc32-1 -> $BASE/
+    Build Set: |rtems-ver-major|/rtems-kernel
+    config: tools/rtems-kernel-|rtems-ver-major|.cfg
+    package: sparc-rtems|rtems-ver-major|-kernel-erc32-1
+    building: sparc-rtems|rtems-ver-major|-kernel-erc32-1
+    sizes: sparc-rtems|rtems-ver-major|-kernel-erc32-1: 2.279GB (installed: 44.612MB)
+    cleaning: sparc-rtems|rtems-ver-major|-kernel-erc32-1
+    reporting: tools/rtems-kernel-|rtems-ver-major|.cfg -> sparc-rtems|rtems-ver-major|-kernel-erc32-1.txt
+    reporting: tools/rtems-kernel-|rtems-ver-major|.cfg -> sparc-rtems|rtems-ver-major|-kernel-erc32-1.xml
+    installing: sparc-rtems|rtems-ver-major|-kernel-erc32-1 -> $BASE/
     Build Set: Time 0:03:09.896961
 The RSB BSP build can be customised with following RSB command line options:
@@ -104,14 +106,16 @@ Prepend the RTEMS tool suite binary directory to your ``$PATH`` throughout the
 remaining steps. Run the command:
+   :substitutions:
-    export PATH=$HOME/quick-start/rtems/@rtems-ver-major@/bin:"$PATH"
+    export PATH=$HOME/quick-start/rtems/|rtems-ver-major|/bin:"$PATH"
 Check your installed tools can be found by running:
+   :substitutions:
-    command -v sparc-rtems at rtems-ver-major@-gcc && echo "found" || echo "not found"
+    command -v sparc-rtems|rtems-ver-major|-gcc && echo "found" || echo "not found"
 The output should be:
@@ -121,8 +125,8 @@ The output should be:
 If ``not found`` is printed the tools are not correctly installed or the path
 has not been correctly set. Check the contents of the path
-:file:`$HOME/quick-start/rtems/@rtems-ver-major@/bin` manually and if
-:file:`sparc-rtems at rtems-ver-major@-gcc` is present the path is wrong. If the
+:substitution-code:`$HOME/quick-start/rtems/|rtems-ver-major|/bin` manually and if
+:substitution-code:`sparc-rtems|rtems-ver-major|-gcc` is present the path is wrong. If the
 file cannot be found return to :ref:`QuickStartTools` and install the tools
 again.
@@ -135,11 +139,12 @@ everything else.  For detailed information about the BSP build system, see
 :ref:`BSPBuildSystem`.
+   :substitutions:
     cd $HOME/quick-start/src/rtems
     echo "[sparc/erc32]" > config.ini
     echo "BUILD_TESTS = True" >> config.ini
-    ./waf configure --prefix=$HOME/quick-start/rtems/@rtems-ver-major@
+    ./waf configure --prefix=$HOME/quick-start/rtems/|rtems-ver-major|
 The first invocation of ``./waf`` needs a bit of time (e.g. 10 seconds) since an
 internal cache file is populated.  This command should output something like
@@ -147,28 +152,29 @@ this.  In this output the base directory :file:`$HOME/quick-start` was replaced
 by ``$BASE``.
+   :substitutions:
     Setting top to                           : $BASE/quick-start/src/rtems
     Setting out to                           : $BASE/quick-start/src/rtems/build
     Configure board support package (BSP)    : sparc/erc32
-    Checking for program 'sparc-rtems at rtems-ver-major@-gcc'  : $BASE/quick-start/rtems/@rtems-ver-major@/bin/sparc-rtems at rtems-ver-major@-gcc
-    Checking for program 'sparc-rtems at rtems-ver-major@-g++'  : $BASE/quick-start/rtems/@rtems-ver-major@/bin/sparc-rtems at rtems-ver-major@-g++
-    Checking for program 'sparc-rtems at rtems-ver-major@-ar'   : $BASE/quick-start/rtems/@rtems-ver-major@/bin/sparc-rtems at rtems-ver-major@-ar
-    Checking for program 'sparc-rtems at rtems-ver-major@-ld'   : $BASE/quick-start/rtems/@rtems-ver-major@/bin/sparc-rtems at rtems-ver-major@-ld
-    Checking for program 'ar'                : $BASE/quick-start/rtems/@rtems-ver-major@/bin/sparc-rtems at rtems-ver-major@-ar
-    Checking for program 'g++, c++'          : $BASE/quick-start/rtems/@rtems-ver-major@/bin/sparc-rtems at rtems-ver-major@-g++
-    Checking for program 'gas, gcc'          : $BASE/quick-start/rtems/@rtems-ver-major@/bin/sparc-rtems at rtems-ver-major@-gcc
-    Checking for program 'gcc, cc'           : $BASE/quick-start/rtems/@rtems-ver-major@/bin/sparc-rtems at rtems-ver-major@-gcc
+    Checking for program 'sparc-rtems|rtems-ver-major|-gcc'  : $BASE/quick-start/rtems/|rtems-ver-major|/bin/sparc-rtems|rtems-ver-major|-gcc
+    Checking for program 'sparc-rtems|rtems-ver-major|-g++'  : $BASE/quick-start/rtems/|rtems-ver-major|/bin/sparc-rtems|rtems-ver-major|-g++
+    Checking for program 'sparc-rtems|rtems-ver-major|-ar'   : $BASE/quick-start/rtems/|rtems-ver-major|/bin/sparc-rtems|rtems-ver-major|-ar
+    Checking for program 'sparc-rtems|rtems-ver-major|-ld'   : $BASE/quick-start/rtems/|rtems-ver-major|/bin/sparc-rtems|rtems-ver-major|-ld
+    Checking for program 'ar'                : $BASE/quick-start/rtems/|rtems-ver-major|/bin/sparc-rtems|rtems-ver-major|-ar
+    Checking for program 'g++, c++'          : $BASE/quick-start/rtems/|rtems-ver-major|/bin/sparc-rtems|rtems-ver-major|-g++
+    Checking for program 'gas, gcc'          : $BASE/quick-start/rtems/|rtems-ver-major|/bin/sparc-rtems|rtems-ver-major|-gcc
+    Checking for program 'gcc, cc'           : $BASE/quick-start/rtems/|rtems-ver-major|/bin/sparc-rtems|rtems-ver-major|-gcc
     Checking for asm flags '-MMD'            : yes
-    Checking for program 'rtems-bin2c'       : $BASE/quick-start/rtems/@rtems-ver-major@/bin/rtems-bin2c
+    Checking for program 'rtems-bin2c'       : $BASE/quick-start/rtems/|rtems-ver-major|/bin/rtems-bin2c
     Checking for program 'gzip'              : /usr/bin/gzip
-    Checking for program 'rtems-ld'          : $BASE/quick-start/rtems/@rtems-ver-major@/bin/rtems-ld
-    Checking for program 'rtems-syms'        : $BASE/quick-start/rtems/@rtems-ver-major@/bin/rtems-syms
+    Checking for program 'rtems-ld'          : $BASE/quick-start/rtems/|rtems-ver-major|/bin/rtems-ld
+    Checking for program 'rtems-syms'        : $BASE/quick-start/rtems/|rtems-ver-major|/bin/rtems-syms
     Checking for program 'xz'                : $BASE/anaconda3/bin/xz
     'configure' finished successfully (0.414s)
@@ -208,17 +214,18 @@ This command should output something like this (omitted lines are denoted by
 by ``$BASE``.
+   :substitutions:
     Waf: Entering directory `$BASE/quick-start/src/rtems/build'
     Waf: Leaving directory `$BASE/quick-start/src/rtems/build'
     'install' finished successfully (0.081s)
     Waf: Entering directory `$BASE/quick-start/src/rtems/build/sparc/erc32'
-    + install $BASE/quick-start/rtems/@rtems-ver-major@/sparc-rtems at rtems-ver-major@/erc32/lib/include/libchip/am29lv16.h (from bsps/include/libchip/am29lv1.h)
-    + install $BASE/quick-start/rtems/@rtems-ver-major@/sparc-rtems at rtems-ver-major@/erc32/lib/include/libchip/mc146818a.h (from bsps/include/libchip/mc146818a.h)
-    + install $BASE/quick-start/rtems/@rtems-ver-major@/sparc-rtems at rtems-ver-major@/erc32/lib/include/libchip/mc68681.h (from bsps/include/libchip/mc68681.h))
+    + install $BASE/quick-start/rtems/|rtems-ver-major|/sparc-rtems|rtems-ver-major|/erc32/lib/include/libchip/am29lv16.h (from bsps/include/libchip/am29lv1.h)
+    + install $BASE/quick-start/rtems/|rtems-ver-major|/sparc-rtems|rtems-ver-major|/erc32/lib/include/libchip/mc146818a.h (from bsps/include/libchip/mc146818a.h)
+    + install $BASE/quick-start/rtems/|rtems-ver-major|/sparc-rtems|rtems-ver-major|/erc32/lib/include/libchip/mc68681.h (from bsps/include/libchip/mc68681.h))
-    + install $BASE/quick-start/rtems/@rtems-ver-major@/sparc-rtems at rtems-ver-major@/erc32/lib/include/rtems/score/watchdogticks.h (from cpukit/include/rtems/score/watchdogticks.h)
-    + install $BASE/quick-start/rtems/@rtems-ver-major@/sparc-rtems at rtems-ver-major@/erc32/lib/include/rtems/score/wkspace.h (from cpukit/include/rtems/score/wkspace.h)
-    + install $BASE/quick-start/rtems/@rtems-ver-major@/sparc-rtems at rtems-ver-major@/erc32/lib/include/rtems/score/wkspacedata.h (from cpukit/include/rtems/score/wkspacedata.h)
+    + install $BASE/quick-start/rtems/|rtems-ver-major|/sparc-rtems|rtems-ver-major|/erc32/lib/include/rtems/score/watchdogticks.h (from cpukit/include/rtems/score/watchdogticks.h)
+    + install $BASE/quick-start/rtems/|rtems-ver-major|/sparc-rtems|rtems-ver-major|/erc32/lib/include/rtems/score/wkspace.h (from cpukit/include/rtems/score/wkspace.h)
+    + install $BASE/quick-start/rtems/|rtems-ver-major|/sparc-rtems|rtems-ver-major|/erc32/lib/include/rtems/score/wkspacedata.h (from cpukit/include/rtems/score/wkspacedata.h)
     Waf: Leaving directory `$BASE/quick-start/src/rtems/build/sparc/erc32'
     'install_sparc/erc32' finished successfully (1.834s))
2.34.1
