[PATCH rtems-net-legacy] powerpc/beatnik: Add mv643xx_eth.c driver from RTEMS 5
Vijay Kumar Banerjee vijay at rtems.org
Tue Jul 18 15:36:48 UTC 2023
 bsp_drivers.py                                |    2 +
 bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c | 3318 +++++++++++++++++
 2 files changed, 3320 insertions(+)
 create mode 100644 bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c
diff --git a/bsp_drivers.py b/bsp_drivers.py
index e2250aa..5628ff3 100644
--- a/bsp_drivers.py
+++ b/bsp_drivers.py
@@ -79,6 +79,7 @@ include = {
         'bsps/powerpc/beatnik/net',
         'bsps/powerpc/beatnik/net/if_em',
         'bsps/powerpc/beatnik/net/if_gfe',
+        'bsps/powerpc/beatnik/net/if_mve',
         'bsps/powerpc/beatnik/net/porting',
     'powerpc/mpc8260ads': [
@@ -174,6 +175,7 @@ source = {
         'bsps/powerpc/beatnik/net/if_em/if_em_rtems.c',
         'bsps/powerpc/beatnik/net/if_gfe/if_gfe.c',
         'bsps/powerpc/beatnik/net/if_gfe/if_gfe_rtems.c',
+        'bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c',
         'bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c',
         'bsps/powerpc/beatnik/net/support/bsp_attach.c',
         'bsps/powerpc/beatnik/net/support/early_link_status.c',
diff --git a/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c b/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c
new file mode 100644
index 0000000..85ab038
--- /dev/null
+++ b/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c
@@ -0,0 +1,3318 @@
+/* RTEMS driver for the mv643xx gigabit ethernet chip */
+/* Acknowledgement:
+ * Valuable information for developing this driver was obtained
+ * from the linux open-source driver mv643xx_eth.c which was written
+ * by the following people and organizations:
+ * Matthew Dharm <mdharm at momenco.com>
+ * rabeeh at galileo.co.il
+ * PMC-Sierra, Inc., Manish Lachwani
+ * Ralf Baechle <ralf at linux-mips.org>
+ * MontaVista Software, Inc., Dale Farnsworth <dale at farnsworth.org>
+ * Steven J. Hill <sjhill1 at rockwellcollins.com>/<sjhill at realitydiluted.com>
+ * Note however, that in spite of the identical name of this file
+ * (and some of the symbols used herein) this file provides a
+ * new implementation and is the original work by the author.
+ * Authorship
+ * This software (mv643xx ethernet driver for RTEMS) was
+ *     created by Till Straumann <strauman at slac.stanford.edu>, 2005-2007,
+ * 	   Stanford Linear Accelerator Center, Stanford University.
+ * Acknowledgement of sponsorship
+ * The 'mv643xx ethernet driver for RTEMS' was produced by
+ *     the Stanford Linear Accelerator Center, Stanford University,
+ * 	   under Contract DE-AC03-76SFO0515 with the Department of Energy.
+ * Government disclaimer of liability
+ * Neither the United States nor the United States Department of Energy,
+ * nor any of their employees, makes any warranty, express or implied, or
+ * assumes any legal liability or responsibility for the accuracy,
+ * completeness, or usefulness of any data, apparatus, product, or process
+ * disclosed, or represents that its use would not infringe privately owned
+ * rights.
+ * Stanford disclaimer of liability
+ * Stanford University makes no representations or warranties, express or
+ * implied, nor assumes any liability for the use of this software.
+ * Stanford disclaimer of copyright
+ * Stanford University, owner of the copyright, hereby disclaims its
+ * copyright and all other rights in this software.  Hence, anyone may
+ * freely use it for any purpose without restriction.
+ * Maintenance of notices
+ * In the interest of clarity regarding the origin and status of this
+ * SLAC software, this and all the preceding Stanford University notices
+ * are to remain affixed to any copy or derivative of this software made
+ * or distributed by the recipient and are to be affixed to any copy of
+ * software made or distributed by the recipient that contains a copy or
+ * derivative of this software.
+ * ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
+ * NOTE: Some register (e.g., the SMI register) are SHARED among the
+ *       three devices. Concurrent access protection is provided by
+ *       the global networking semaphore.
+ *       If other drivers are running on a subset of IFs then proper
+ *       locking of all shared registers must be implemented!
+ *       Some things I learned about this hardware can be found
+ *       further down...
+#ifndef KERNEL
+#define KERNEL
+#endif
+#ifndef _KERNEL
+#define _KERNEL
+#endif
+#include <rtems.h>
+#include <rtems/bspIo.h>
+#include <rtems/error.h>
+#include <bsp.h>
+#include <bsp/irq.h>
+#include <bsp/gtreg.h>
+#include <libcpu/byteorder.h>
+#include <sys/param.h>
+#include <sys/proc.h>
+#include <sys/socket.h>
+#include <sys/sockio.h>
+#include <dev/mii/mii.h>
+#include <net/if_var.h>
+#include <net/if_media.h>
+/* Not so nice; would be more elegant not to depend on C library but the
+ * RTEMS-specific ioctl for dumping statistics needs stdio anyways.
+/*#define NDEBUG effectively removes all assertions
+ * If defining NDEBUG, MAKE SURE assert() EXPRESSION HAVE NO SIDE_EFFECTS!!
+ * This driver DOES have side-effects, so DONT DEFINE NDEBUG
+ * Performance-critical assertions are removed by undefining MVETH_TESTING.
+#undef NDEBUG
+#include <assert.h>
+#include <stdio.h>
+#include <errno.h>
+#include <inttypes.h>
+#include <rtems/rtems_bsdnet.h>
+#include <sys/mbuf.h>
+#include <net/ethernet.h>
+#include <net/if.h>
+#include <netinet/in.h>
+#include <netinet/if_ether.h>
+#include <rtems/rtems_mii_ioctl.h>
+#include <bsp/early_enet_link_status.h>
+#include <bsp/if_mve_pub.h>
+/* CONFIGURABLE PARAMETERS */
+/* Enable Hardware Snooping; if this is disabled (undefined),
+ * cache coherency is maintained by software.
+#undef  ENABLE_HW_SNOOPING
+/* Compile-time debugging features */
+/* Enable paranoia assertions and checks; reduce # of descriptors to minimum for stressing   */
+#undef  MVETH_TESTING
+/* Enable debugging messages and some support routines  (dump rings etc.)                    */
+#undef  MVETH_DEBUG
+/* Hack for driver development; rtems bsdnet doesn't implement detaching an interface :-(
+ * but this hack allows us to unload/reload the driver module which makes development
+ * a lot less painful.
+#undef MVETH_DETACH_HACK
+/* Ring sizes */
+#ifdef MVETH_TESTING
+/* hard and small defaults */
+#undef  MV643XX_RX_RING_SIZE
+#define MV643XX_RX_RING_SIZE	2
+#undef  MV643XX_TX_RING_SIZE
+#define MV643XX_TX_RING_SIZE	4
+#else /* MVETH_TESTING */
+/* Define default ring sizes, allow override from bsp.h, Makefile,... and from ifcfg->rbuf_count/xbuf_count */
+#ifndef MV643XX_RX_RING_SIZE
+#define MV643XX_RX_RING_SIZE	40	/* attached buffers are always 2k clusters, i.e., this
+									 * driver - with a configured ring size of 40 - constantly
+									 * locks 80k of cluster memory - your app config better
+									 * provides enough space!
+#endif
+#ifndef MV643XX_TX_RING_SIZE
+/* NOTE: tx ring size MUST be > max. # of fragments / mbufs in a chain;
+ *       in 'TESTING' mode, special code is compiled in to repackage
+ *		 chains that are longer than the ring size. Normally, this is
+ *		 disabled for sake of speed.
+ *		 I observed chains of >17 entries regularly!
+ *       Also, TX_NUM_TAG_SLOTS (1) must be left empty as a marker, hence
+ *       the ring size must be > max. #frags + 1.
+#define MV643XX_TX_RING_SIZE	200	/* these are smaller fragments and not occupied when
+									 * the driver is idle.
+#endif
+#endif /* MVETH_TESTING */
+/* How many instances to we support (bsp.h could override) */
+#ifndef MV643XXETH_NUM_DRIVER_SLOTS
+#define MV643XXETH_NUM_DRIVER_SLOTS	2
+#endif
+#define TX_NUM_TAG_SLOTS			1 /* leave room for tag; must not be 0 */
+/* This is REAL; chip reads from 64-bit down-aligned buffer
+ * if the buffer size is < 8 !!! for buffer sizes 8 and upwards
+ * alignment is not an issue. This was verified using the
+ * 'mve_smallbuf_test.c'
+#define ENABLE_TX_WORKAROUND_8_BYTE_PROBLEM
+/* Chip register configuration values */
+#define	MVETH_PORT_CONFIG_VAL			(0				\
+			| MV643XX_ETH_DFLT_RX_Q(0)					\
+			| MV643XX_ETH_DFLT_RX_ARP_Q(0)				\
+			| MV643XX_ETH_DFLT_RX_TCP_Q(0)				\
+			| MV643XX_ETH_DFLT_RX_UDP_Q(0)				\
+			| MV643XX_ETH_DFLT_RX_BPDU_Q(0)				\
+#define	MVETH_PORT_XTEND_CONFIG_VAL		0
+#ifdef OLDCONFIGVAL
+#define	MVETH_SERIAL_CTRL_CONFIG_VAL	(0				\
+			 | MV643XX_ETH_FORCE_LINK_PASS 				\
+			 | MV643XX_ETH_DISABLE_AUTO_NEG_FOR_FLOWCTL	\
+			 | MV643XX_ETH_ADVERTISE_SYMMETRIC_FLOWCTL	\
+			 | MV643XX_ETH_BIT9_UNKNOWN					\
+			 | MV643XX_ETH_FORCE_LINK_FAIL_DISABLE		\
+			 | MV643XX_ETH_SC_MAX_RX_1552				\
+			 | MV643XX_ETH_SET_FULL_DUPLEX				\
+			 | MV643XX_ETH_ENBL_FLOWCTL_TX_RX_IN_FD		\
+#endif
+/* If we enable autoneg (duplex, speed, ...) then it seems
+ * that the chip automatically updates link settings
+ * (correct link settings are reflected in PORT_STATUS_R).
+ * However, when we disable aneg in the PHY then things
+ * can get messed up and the port doesn't work anymore.
+ * => we follow the linux driver in disabling all aneg
+ * in the serial config reg. and manually updating the
+ * speed & duplex bits when the phy link status changes.
+ * FIXME: don't know what to do about pause/flow-ctrl.
+ * It is best to just use ANEG anyways!!!
+			 | MV643XX_ETH_DISABLE_AUTO_NEG_FOR_DUPLEX	\
+			 | MV643XX_ETH_DISABLE_AUTO_NEG_SPEED_GMII	\
+#define	MVETH_SERIAL_CTRL_CONFIG_MSK	(0				\
+			 | MV643XX_ETH_SERIAL_PORT_ENBL				\
+			 | MV643XX_ETH_SC_MAX_RX_MASK				\
+#ifdef __PPC__
+#define MVETH_SDMA_CONFIG_VAL			(0				\
+			| MV643XX_ETH_RX_BURST_SZ_4_64BIT			\
+			| MV643XX_ETH_TX_BURST_SZ_4_64BIT			\
+#else
+			| MV643XX_ETH_RX_BURST_SZ_16_64BIT			\
+			| MV643XX_ETH_TX_BURST_SZ_16_64BIT			\
+#endif
+/* minimal frame size we accept */
+#define MVETH_MIN_FRAMSZ_CONFIG_VAL	40
+/* END OF CONFIGURABLE SECTION */
+ * Here's stuff I learned about this chip:
+ * RX interrupt flags:
+ * broadcast packet RX: 0x00000005
+ *           last buf:  0x00000c05
+ *           overrun:   0x00000c00
+ * unicast   packet RX: 0x00000005
+ * bad CRC received:    0x00000005
+ * clearing 0x00000004 -> clears 0x00000001
+ * clearing 0x00000400 -> clears 0x00000800
+ * --> 0x0801 are probably some sort of summary bits.
+ * TX interrupt flags:
+ * broadcast packet in 1 buf: xcause: 0x00000001 (cause 0x00080000)
+ *        into disconn. link:             "                 "
+ * in some cases, I observed  xcause: 0x00000101 (reason for 0x100 unknown
+ * but the linux driver accepts it also).
+ * Here a few more ugly things about this piece of hardware I learned
+ * (painfully, painfully; spending many many hours & nights :-()
+ * a) Especially in the case of 'chained' descriptors, the DMA keeps
+ *    clobbering 'cmd_sts' long after it cleared the OWNership flag!!!
+ *    Only after the whole chain is processed (OWN cleared on the
+ *    last descriptor) it is safe to change cmd_sts.
+ *    However, in the case of hardware snooping I found that the
+ *    last descriptor in chain has its cmd_sts still clobbered *after*
+ *    checking ownership!, I.e.,
+ *        if ( ! OWN & cmd_sts ) {
+ *            cmd_sts = 0;
+ *    --> sometimes, cmd_sts is STILL != 0 here
+ * b) Sometimes, the OWNership flag is *not cleared*.
+ * c) Weird things happen if the chip finds a descriptor with 'OWN'
+ *    still set (i.e., not properly loaded), i.e., corrupted packets
+ *    are sent [with OK checksum since the chip calculates it].
+ * Combine a+b+c and we end up with a real mess.
+ * The fact that the chip doesn't reliably reset OWN and that OTOH,
+ * it can't be reliably reset by the driver and still, the chip needs
+ * it for proper communication doesn't make things easy...
+ * Here the basic workarounds:
+ *     - In addition to check OWN, the scavenger compares the "currently
+ *       served desc" register to the descriptor it tries to recover and
+ *       ignores OWN if they do not match. Hope this is OK.
+ *       Otherwise, we could scan the list of used descriptors and proceed
+ *       recycling descriptors if we find a !OWNed one behind the target...
+ *     - Always keep an empty slot around to mark the end of the list of
+ *       jobs. The driver clears the descriptor ahead when enqueueing a new
+ *       packet.
+#define DRVNAME			"mve"
+#define MAX_NUM_SLOTS	3
+#if MV643XXETH_NUM_DRIVER_SLOTS > MAX_NUM_SLOTS
+#error "mv643xxeth: only MAX_NUM_SLOTS supported"
+#endif
+#ifdef NDEBUG
+#error "Driver uses assert() statements with side-effects; MUST NOT define NDEBUG"
+#endif
+#ifdef MVETH_DEBUG
+#define STATIC
+#else
+#define STATIC static
+#endif
+#define TX_AVAILABLE_RING_SIZE(mp)		((mp)->xbuf_count - (TX_NUM_TAG_SLOTS))
+/* macros for ring alignment; proper alignment is a hardware req; . */
+#ifdef ENABLE_HW_SNOOPING
+#define RING_ALIGNMENT				16
+/* rx buffers must be 64-bit aligned (chip requirement) */
+#define RX_BUF_ALIGNMENT			8
+#else /* ENABLE_HW_SNOOPING */
+/* Software cache management */
+#ifndef __PPC__
+#error	"Dont' know how to deal with cache on this CPU architecture"
+#endif
+/* Ring entries are 32 bytes; coherency-critical chunks are 16 -> software coherency
+ * management works for cache line sizes of 16 and 32 bytes only. If the line size
+ * is bigger, the descriptors could be padded...
+#if	PPC_CACHE_ALIGMENT != 16 && PPC_CACHE_ALIGNMENT != 32
+#error "Cache line size must be 16 or 32"
+#else
+#define RING_ALIGNMENT				PPC_CACHE_ALIGNMENT
+#define RX_BUF_ALIGNMENT			PPC_CACHE_ALIGNMENT
+#endif
+#endif /* ENABLE_HW_SNOOPING */
+/* HELPER MACROS */
+/* Align base to alignment 'a' */
+#define MV643XX_ALIGN(b, a)	((((uint32_t)(b)) + (a)-1) & (~((a)-1)))
+#define NOOP()			do {} while(0)
+/* Function like macros */
+#define MV_READ(off) \
+		ld_le32((volatile uint32_t *)(BSP_MV64x60_BASE + (off)))
+#define MV_WRITE(off, data)		\
+		st_le32((volatile uint32_t *)(BSP_MV64x60_BASE + (off)), ((unsigned)data))
+/* ENET window mapped 1:1 to CPU addresses by our BSP/MotLoad
+ * -- if this is changed, we should think about caching the 'next' and 'buf' pointers.
+#define CPUADDR2ENET(a) ((Dma_addr_t)(a))
+#define ENET2CPUADDR(a) (a)
+#if 1	/* Whether to automatically try to reclaim descriptors when enqueueing new packets */
+#define MVETH_CLEAN_ON_SEND(mp) (BSP_mve_swipe_tx(mp))
+#else
+#define MVETH_CLEAN_ON_SEND(mp) (-1)
+#endif
+#define NEXT_TXD(d)	(d)->next
+#define NEXT_RXD(d)	(d)->next
+/* REGISTER AND DESCRIPTOR OFFSET AND BIT DEFINITIONS */
+/* Descriptor Definitions */
+/* Rx descriptor */
+#define RDESC_ERROR									(1<< 0)	/* Error summary    */
+/* Error code (bit 1&2) is only valid if summary bit is set */
+#define RDESC_CRC_ERROR								(    1)
+#define RDESC_OVERRUN_ERROR							(    3)
+#define RDESC_MAX_FRAMELENGTH_ERROR					(    5)
+#define RDESC_RESOURCE_ERROR						(    7)
+#define RDESC_LAST									(1<<26)	/* Last Descriptor   */
+#define RDESC_FRST									(1<<27)	/* First Descriptor  */
+#define RDESC_INT_ENA								(1<<29) /* Enable Interrupts */
+#define RDESC_DMA_OWNED								(1<<31)
+/* Tx descriptor */
+#define TDESC_ERROR									(1<< 0) /* Error summary     */
+#define TDESC_ZERO_PAD								(1<<19)
+#define TDESC_LAST									(1<<20)	/* Last Descriptor   */
+#define TDESC_FRST									(1<<21)	/* First Descriptor  */
+#define TDESC_GEN_CRC								(1<<22)
+#define TDESC_INT_ENA								(1<<23) /* Enable Interrupts */
+#define TDESC_DMA_OWNED								(1<<31)
+/* Register Definitions */
+#define MV643XX_ETH_PHY_ADDR_R						(0x2000)
+#define MV643XX_ETH_SMI_R							(0x2004)
+#define MV643XX_ETH_SMI_BUSY						(1<<28)
+#define MV643XX_ETH_SMI_VALID						(1<<27)
+#define MV643XX_ETH_SMI_OP_WR						(0<<26)
+#define MV643XX_ETH_SMI_OP_RD						(1<<26)
+#define MV643XX_ETH_TRANSMIT_QUEUE_COMMAND_R(port)	(0x2448 + ((port)<<10))
+#define MV643XX_ETH_TX_START(queue)					(0x0001<<(queue))
+#define MV643XX_ETH_TX_STOP(queue)					(0x0100<<(queue))
+#define MV643XX_ETH_TX_START_M(queues)				((queues)&0xff)
+#define MV643XX_ETH_TX_STOP_M(queues)				(((queues)&0xff)<<8)
+#define MV643XX_ETH_TX_STOP_ALL						(0xff00)
+#define MV643XX_ETH_TX_ANY_RUNNING					(0x00ff)
+#define MV643XX_ETH_RECEIVE_QUEUE_COMMAND_R(port)	(0x2680 + ((port)<<10))
+#define MV643XX_ETH_RX_START(queue)					(0x0001<<(queue))
+#define MV643XX_ETH_RX_STOP(queue)					(0x0100<<(queue))
+#define MV643XX_ETH_RX_STOP_ALL						(0xff00)
+#define MV643XX_ETH_RX_ANY_RUNNING					(0x00ff)
+#define MV643XX_ETH_CURRENT_SERVED_TX_DESC(port)	(0x2684 + ((port)<<10))
+/* The chip puts the ethernet header at offset 2 into the buffer so
+ * that the payload is aligned
+#define ETH_RX_OFFSET								2
+#define ETH_CRC_LEN									4	/* strip FCS at end of packet */
+#define MV643XX_ETH_INTERRUPT_CAUSE_R(port)			(0x2460 + ((port)<<10))
+/* not fully understood; RX seems to raise 0x0005 or 0x0c05 if last buffer is filled and 0x0c00
+ * if there are no buffers
+#define MV643XX_ETH_ALL_IRQS						(0x0007ffff)
+#define MV643XX_ETH_KNOWN_IRQS						(0x00000c05)
+#define MV643XX_ETH_IRQ_EXT_ENA						(1<<1)
+#define MV643XX_ETH_IRQ_RX_DONE						(1<<2)
+#define MV643XX_ETH_IRQ_RX_NO_DESC					(1<<10)
+#define MV643XX_ETH_INTERRUPT_EXTEND_CAUSE_R(port)	(0x2464 + ((port)<<10))
+/* not fully understood; TX seems to raise 0x0001 and link change is 0x00010000
+#define MV643XX_ETH_ALL_EXT_IRQS					(0x0011ffff)
+#define MV643XX_ETH_KNOWN_EXT_IRQS					(0x00010101)
+#define MV643XX_ETH_EXT_IRQ_TX_DONE					(1<<0)
+#define MV643XX_ETH_EXT_IRQ_LINK_CHG				(1<<16)
+#define MV643XX_ETH_INTERRUPT_ENBL_R(port)			(0x2468 + ((port)<<10))
+#define MV643XX_ETH_INTERRUPT_EXTEND_ENBL_R(port)	(0x246c + ((port)<<10))
+/* port configuration */
+#define MV643XX_ETH_PORT_CONFIG_R(port)				(0x2400 + ((port)<<10))
+#define	MV643XX_ETH_UNICAST_PROMISC_MODE			(1<<0)
+#define	MV643XX_ETH_DFLT_RX_Q(q)					((q)<<1)
+#define	MV643XX_ETH_DFLT_RX_ARP_Q(q)				((q)<<4)
+#define MV643XX_ETH_REJ_BCAST_IF_NOT_IP_OR_ARP		(1<<7)
+#define MV643XX_ETH_REJ_BCAST_IF_IP					(1<<8)
+#define MV643XX_ETH_REJ_BCAST_IF_ARP				(1<<9)
+#define MV643XX_ETH_TX_AM_NO_UPDATE_ERR_SUMMARY		(1<<12)
+#define MV643XX_ETH_CAPTURE_TCP_FRAMES_ENBL			(1<<14)
+#define MV643XX_ETH_CAPTURE_UDP_FRAMES_ENBL			(1<<15)
+#define	MV643XX_ETH_DFLT_RX_TCP_Q(q)				((q)<<16)
+#define	MV643XX_ETH_DFLT_RX_UDP_Q(q)				((q)<<19)
+#define	MV643XX_ETH_DFLT_RX_BPDU_Q(q)				((q)<<22)
+#define MV643XX_ETH_PORT_CONFIG_XTEND_R(port)		(0x2404 + ((port)<<10))
+#define MV643XX_ETH_CLASSIFY_ENBL					(1<<0)
+#define MV643XX_ETH_SPAN_BPDU_PACKETS_AS_NORMAL		(0<<1)
+#define MV643XX_ETH_SPAN_BPDU_PACKETS_2_Q7			(1<<1)
+#define MV643XX_ETH_PARTITION_DISBL					(0<<2)
+#define MV643XX_ETH_PARTITION_ENBL					(1<<2)
+#define MV643XX_ETH_SDMA_CONFIG_R(port)				(0x241c + ((port)<<10))
+#define MV643XX_ETH_SDMA_RIFB						(1<<0)
+#define MV643XX_ETH_RX_BURST_SZ_1_64BIT				(0<<1)
+#define MV643XX_ETH_RX_BURST_SZ_2_64BIT				(1<<1)
+#define MV643XX_ETH_RX_BURST_SZ_4_64BIT				(2<<1)
+#define MV643XX_ETH_RX_BURST_SZ_8_64BIT				(3<<1)
+#define MV643XX_ETH_RX_BURST_SZ_16_64BIT			(4<<1)
+#define MV643XX_ETH_SMDA_BLM_RX_NO_SWAP				(1<<4)
+#define MV643XX_ETH_SMDA_BLM_TX_NO_SWAP				(1<<5)
+#define MV643XX_ETH_SMDA_DESC_BYTE_SWAP				(1<<6)
+#define MV643XX_ETH_TX_BURST_SZ_1_64BIT				(0<<22)
+#define MV643XX_ETH_TX_BURST_SZ_2_64BIT				(1<<22)
+#define MV643XX_ETH_TX_BURST_SZ_4_64BIT				(2<<22)
+#define MV643XX_ETH_TX_BURST_SZ_8_64BIT				(3<<22)
+#define MV643XX_ETH_TX_BURST_SZ_16_64BIT			(4<<22)
+#define	MV643XX_ETH_RX_MIN_FRAME_SIZE_R(port)		(0x247c + ((port)<<10))
+#define MV643XX_ETH_SERIAL_CONTROL_R(port)			(0x243c + ((port)<<10))
+#define MV643XX_ETH_SERIAL_PORT_ENBL				(1<<0)	/* Enable serial port */
+#define MV643XX_ETH_FORCE_LINK_PASS					(1<<1)
+#define MV643XX_ETH_DISABLE_AUTO_NEG_FOR_DUPLEX		(1<<2)
+#define MV643XX_ETH_DISABLE_AUTO_NEG_FOR_FLOWCTL	(1<<3)
+#define MV643XX_ETH_ADVERTISE_SYMMETRIC_FLOWCTL		(1<<4)
+#define MV643XX_ETH_FORCE_FC_MODE_TX_PAUSE_DIS		(1<<5)
+#define MV643XX_ETH_FORCE_BP_MODE_JAM_TX			(1<<7)
+#define MV643XX_ETH_FORCE_BP_MODE_JAM_TX_ON_RX_ERR	(1<<8)
+#define MV643XX_ETH_BIT9_UNKNOWN					(1<<9)	/* unknown purpose; linux sets this */
+#define MV643XX_ETH_FORCE_LINK_FAIL_DISABLE			(1<<10)
+#define MV643XX_ETH_RETRANSMIT_FOREVER				(1<<11) /* limit to 16 attempts if clear    */
+#define MV643XX_ETH_DISABLE_AUTO_NEG_SPEED_GMII		(1<<13)
+#define MV643XX_ETH_DTE_ADV_1						(1<<14)
+#define MV643XX_ETH_AUTO_NEG_BYPASS_ENBL			(1<<15)
+#define MV643XX_ETH_RESTART_AUTO_NEG				(1<<16)
+#define MV643XX_ETH_SC_MAX_RX_1518					(0<<17)	/* Limit RX packet size */
+#define MV643XX_ETH_SC_MAX_RX_1522					(1<<17)	/* Limit RX packet size */
+#define MV643XX_ETH_SC_MAX_RX_1552					(2<<17)	/* Limit RX packet size */
+#define MV643XX_ETH_SC_MAX_RX_9022					(3<<17)	/* Limit RX packet size */
+#define MV643XX_ETH_SC_MAX_RX_9192					(4<<17)	/* Limit RX packet size */
+#define MV643XX_ETH_SC_MAX_RX_9700					(5<<17)	/* Limit RX packet size */
+#define MV643XX_ETH_SC_MAX_RX_MASK					(7<<17)	/* bitmask */
+#define MV643XX_ETH_SET_EXT_LOOPBACK				(1<<20)
+#define MV643XX_ETH_SET_FULL_DUPLEX					(1<<21)
+#define MV643XX_ETH_ENBL_FLOWCTL_TX_RX_IN_FD		(1<<22)	/* enable flow ctrl on rx and tx in full-duplex */
+#define MV643XX_ETH_SET_GMII_SPEED_1000				(1<<23)	/* 10/100 if clear */
+#define MV643XX_ETH_SET_MII_SPEED_100				(1<<24)	/* 10 if clear     */
+#define MV643XX_ETH_PORT_STATUS_R(port)				(0x2444 + ((port)<<10))
+#define MV643XX_ETH_PORT_STATUS_MODE_10_BIT			(1<<0)
+#define MV643XX_ETH_PORT_STATUS_LINK_UP				(1<<1)
+#define MV643XX_ETH_PORT_STATUS_FDX					(1<<2)
+#define MV643XX_ETH_PORT_STATUS_FC					(1<<3)
+#define MV643XX_ETH_PORT_STATUS_1000				(1<<4)
+#define MV643XX_ETH_PORT_STATUS_100					(1<<5)
+/* PSR bit 6 unknown */
+#define MV643XX_ETH_PORT_STATUS_TX_IN_PROGRESS		(1<<7)
+#define MV643XX_ETH_PORT_STATUS_ANEG_BYPASSED		(1<<8)
+#define MV643XX_ETH_PORT_STATUS_PARTITION			(1<<9)
+#define MV643XX_ETH_PORT_STATUS_TX_FIFO_EMPTY		(1<<10)
+#define MV643XX_ETH_MIB_COUNTERS(port)				(0x3000 + ((port)<<7))
+#define MV643XX_ETH_NUM_MIB_COUNTERS				32
+#define MV643XX_ETH_MIB_GOOD_OCTS_RCVD_LO			(0)
+#define MV643XX_ETH_MIB_GOOD_OCTS_RCVD_HI			(1<<2)
+#define MV643XX_ETH_MIB_BAD_OCTS_RCVD				(2<<2)
+#define MV643XX_ETH_MIB_INTERNAL_MAC_TX_ERR			(3<<2)
+#define MV643XX_ETH_MIB_GOOD_FRAMES_RCVD			(4<<2)
+#define MV643XX_ETH_MIB_BAD_FRAMES_RCVD				(5<<2)
+#define MV643XX_ETH_MIB_BCAST_FRAMES_RCVD			(6<<2)
+#define MV643XX_ETH_MIB_MCAST_FRAMES_RCVD			(7<<2)
+#define MV643XX_ETH_MIB_FRAMES_64_OCTS				(8<<2)
+#define MV643XX_ETH_MIB_FRAMES_65_127_OCTS			(9<<2)
+#define MV643XX_ETH_MIB_FRAMES_128_255_OCTS			(10<<2)
+#define MV643XX_ETH_MIB_FRAMES_256_511_OCTS			(11<<2)
+#define MV643XX_ETH_MIB_FRAMES_512_1023_OCTS		(12<<2)
+#define MV643XX_ETH_MIB_FRAMES_1024_MAX_OCTS		(13<<2)
+#define MV643XX_ETH_MIB_GOOD_OCTS_SENT_LO			(14<<2)
+#define MV643XX_ETH_MIB_GOOD_OCTS_SENT_HI			(15<<2)
+#define MV643XX_ETH_MIB_GOOD_FRAMES_SENT			(16<<2)
+#define MV643XX_ETH_MIB_EXCESSIVE_COLL				(17<<2)
+#define MV643XX_ETH_MIB_MCAST_FRAMES_SENT			(18<<2)
+#define MV643XX_ETH_MIB_BCAST_FRAMES_SENT			(19<<2)
+#define MV643XX_ETH_MIB_UNREC_MAC_CTRL_RCVD			(20<<2)
+#define MV643XX_ETH_MIB_FC_SENT						(21<<2)
+#define MV643XX_ETH_MIB_GOOD_FC_RCVD				(22<<2)
+#define MV643XX_ETH_MIB_BAD_FC_RCVD					(23<<2)
+#define MV643XX_ETH_MIB_UNDERSIZE_RCVD				(24<<2)
+#define MV643XX_ETH_MIB_FRAGMENTS_RCVD				(25<<2)
+#define MV643XX_ETH_MIB_OVERSIZE_RCVD				(26<<2)
+#define MV643XX_ETH_MIB_JABBER_RCVD					(27<<2)
+#define MV643XX_ETH_MIB_MAC_RX_ERR					(28<<2)
+#define MV643XX_ETH_MIB_BAD_CRC_EVENT				(29<<2)
+#define MV643XX_ETH_MIB_COLL						(30<<2)
+#define MV643XX_ETH_MIB_LATE_COLL					(31<<2)
+#define MV643XX_ETH_DA_FILTER_SPECL_MCAST_TBL(port) (0x3400+((port)<<10))
+#define MV643XX_ETH_DA_FILTER_OTHER_MCAST_TBL(port) (0x3500+((port)<<10))
+#define MV643XX_ETH_DA_FILTER_UNICAST_TBL(port)		(0x3600+((port)<<10))
+#define MV643XX_ETH_NUM_MCAST_ENTRIES				64
+#define MV643XX_ETH_NUM_UNICAST_ENTRIES				4
+#define MV643XX_ETH_BAR_0							(0x2200)
+#define MV643XX_ETH_SIZE_R_0						(0x2204)
+#define MV643XX_ETH_BAR_1							(0x2208)
+#define MV643XX_ETH_SIZE_R_1						(0x220c)
+#define MV643XX_ETH_BAR_2							(0x2210)
+#define MV643XX_ETH_SIZE_R_2						(0x2214)
+#define MV643XX_ETH_BAR_3							(0x2218)
+#define MV643XX_ETH_SIZE_R_3						(0x221c)
+#define MV643XX_ETH_BAR_4							(0x2220)
+#define MV643XX_ETH_SIZE_R_4						(0x2224)
+#define MV643XX_ETH_BAR_5							(0x2228)
+#define MV643XX_ETH_SIZE_R_5						(0x222c)
+#define MV643XX_ETH_NUM_BARS						6
+/* Bits in the BAR reg to program cache snooping */
+#define MV64360_ENET2MEM_SNOOP_NONE 0x0000
+#define MV64360_ENET2MEM_SNOOP_WT	0x1000
+#define MV64360_ENET2MEM_SNOOP_WB	0x2000
+#define MV64360_ENET2MEM_SNOOP_MSK	0x3000
+#define MV643XX_ETH_BAR_ENBL_R						(0x2290)
+#define MV643XX_ETH_BAR_DISABLE(bar)				(1<<(bar))
+#define MV643XX_ETH_BAR_DISBL_ALL					0x3f
+#define MV643XX_ETH_RX_Q0_CURRENT_DESC_PTR(port)	(0x260c+((port)<<10))
+#define MV643XX_ETH_RX_Q1_CURRENT_DESC_PTR(port)	(0x261c+((port)<<10))
+#define MV643XX_ETH_RX_Q2_CURRENT_DESC_PTR(port)	(0x262c+((port)<<10))
+#define MV643XX_ETH_RX_Q3_CURRENT_DESC_PTR(port)	(0x263c+((port)<<10))
+#define MV643XX_ETH_RX_Q4_CURRENT_DESC_PTR(port)	(0x264c+((port)<<10))
+#define MV643XX_ETH_RX_Q5_CURRENT_DESC_PTR(port)	(0x265c+((port)<<10))
+#define MV643XX_ETH_RX_Q6_CURRENT_DESC_PTR(port)	(0x266c+((port)<<10))
+#define MV643XX_ETH_RX_Q7_CURRENT_DESC_PTR(port)	(0x267c+((port)<<10))
+#define MV643XX_ETH_TX_Q0_CURRENT_DESC_PTR(port)	(0x26c0+((port)<<10))
+#define MV643XX_ETH_TX_Q1_CURRENT_DESC_PTR(port)	(0x26c4+((port)<<10))
+#define MV643XX_ETH_TX_Q2_CURRENT_DESC_PTR(port)	(0x26c8+((port)<<10))
+#define MV643XX_ETH_TX_Q3_CURRENT_DESC_PTR(port)	(0x26cc+((port)<<10))
+#define MV643XX_ETH_TX_Q4_CURRENT_DESC_PTR(port)	(0x26d0+((port)<<10))
+#define MV643XX_ETH_TX_Q5_CURRENT_DESC_PTR(port)	(0x26d4+((port)<<10))
+#define MV643XX_ETH_TX_Q6_CURRENT_DESC_PTR(port)	(0x26d8+((port)<<10))
+#define MV643XX_ETH_TX_Q7_CURRENT_DESC_PTR(port)	(0x26dc+((port)<<10))
+#define MV643XX_ETH_MAC_ADDR_LO(port)				(0x2414+((port)<<10))
+#define MV643XX_ETH_MAC_ADDR_HI(port)				(0x2418+((port)<<10))
+/* TYPE DEFINITIONS */
+/* just to make the purpose explicit; vars of this
+ * type may need CPU-dependent address translation,
+ * endian conversion etc.
+typedef uint32_t Dma_addr_t;
+typedef volatile struct mveth_rx_desc {
+#ifndef __BIG_ENDIAN__
+#error	"descriptor declaration not implemented for little endian machines"
+#endif
+	uint16_t	byte_cnt;
+	uint16_t	buf_size;
+	uint32_t	cmd_sts;					/* control and status */
+	Dma_addr_t	next_desc_ptr;				/* next descriptor (as seen from DMA) */
+	Dma_addr_t	buf_ptr;
+	/* fields below here are not used by the chip */
+	void		*u_buf;						/* user buffer */
+	volatile struct mveth_rx_desc *next;	/* next descriptor (CPU address; next_desc_ptr is a DMA address) */
+	uint32_t	pad[2];
+} __attribute__(( aligned(RING_ALIGNMENT) )) MvEthRxDescRec, *MvEthRxDesc;
+typedef volatile struct mveth_tx_desc {
+#endif
+	uint16_t	l4i_chk;
+	uint32_t	workaround[2];				/* use this space to work around the 8byte problem (is this real?) */
+	volatile struct mveth_tx_desc *next;	/* next descriptor (CPU address; next_desc_ptr is a DMA address)   */
+} __attribute__(( aligned(RING_ALIGNMENT) )) MvEthTxDescRec, *MvEthTxDesc;
+/* Assume there are never more then 64k aliasing entries */
+typedef uint16_t Mc_Refcnt[MV643XX_ETH_NUM_MCAST_ENTRIES*4];
+/* driver private data and bsdnet interface structure */
+struct mveth_private {
+	MvEthRxDesc		rx_ring;					/* pointers to aligned ring area             */
+	MvEthTxDesc		tx_ring;					/* pointers to aligned ring area             */
+	MvEthRxDesc		ring_area;					/* allocated ring area                       */
+	int				rbuf_count, xbuf_count;		/* saved ring sizes from ifconfig            */
+	int				port_num;
+	int				phy;
+	MvEthRxDesc		d_rx_t;						/* tail of the RX ring; next received packet */
+	MvEthTxDesc		d_tx_t, d_tx_h;
+	uint32_t		rx_desc_dma, tx_desc_dma; 	/* ring address as seen by DMA;	(1:1 on this BSP) */
+	int				avail;
+	void            (*isr)(void*);
+	void            *isr_arg;
+	/* Callbacks to handle buffers */
+	void			(*cleanup_txbuf)(void*, void*, int);	/* callback to cleanup TX buffer */
+	void			*cleanup_txbuf_arg;
+	void			*(*alloc_rxbuf)(int *psize, uintptr_t *paddr);	/* allocate RX buffer  */
+	void			(*consume_rxbuf)(void*, void*,  int);	/* callback to consume RX buffer */
+	void			*consume_rxbuf_arg;
+	rtems_id        tid;
+	uint32_t		irq_mask;					/* IRQs we use                              */
+	uint32_t		xirq_mask;
+    int             promisc;
+	struct		{
+		unsigned		irqs;
+		unsigned		maxchain;
+		unsigned		repack;
+		unsigned		packet;
+		unsigned		odrops;					/* no counter in core code                   */
+		struct {
+			uint64_t	good_octs_rcvd;         /* 64-bit */
+			uint32_t	bad_octs_rcvd;
+			uint32_t	internal_mac_tx_err;
+			uint32_t	good_frames_rcvd;
+			uint32_t	bad_frames_rcvd;
+			uint32_t	bcast_frames_rcvd;
+			uint32_t	mcast_frames_rcvd;
+			uint32_t	frames_64_octs;
+			uint32_t	frames_65_127_octs;
+			uint32_t	frames_128_255_octs;
+			uint32_t	frames_256_511_octs;
+			uint32_t	frames_512_1023_octs;
+			uint32_t	frames_1024_max_octs;
+			uint64_t	good_octs_sent;         /* 64-bit */
+			uint32_t	good_frames_sent;
+			uint32_t	excessive_coll;
+			uint32_t	mcast_frames_sent;
+			uint32_t	bcast_frames_sent;
+			uint32_t	unrec_mac_ctrl_rcvd;
+			uint32_t	fc_sent;
+			uint32_t	good_fc_rcvd;
+			uint32_t	bad_fc_rcvd;
+			uint32_t	undersize_rcvd;
+			uint32_t	fragments_rcvd;
+			uint32_t	oversize_rcvd;
+			uint32_t	jabber_rcvd;
+			uint32_t	mac_rx_err;
+			uint32_t	bad_crc_event;
+			uint32_t	coll;
+			uint32_t	late_coll;
+		} mib;
+	}			stats;
+	struct {
+		Mc_Refcnt	specl, other;
+	}           mc_refcnt;
+/* stuff needed for bsdnet support */
+struct mveth_bsdsupp {
+	int				oif_flags;					/* old / cached if_flags */
+struct mveth_softc {
+	struct arpcom			arpcom;
+	struct mveth_bsdsupp	bsd;
+	struct mveth_private	pvt;
+/* GLOBAL VARIABLES */
+#ifdef MVETH_DEBUG_TX_DUMP
+int mveth_tx_dump = 0;
+#endif
+/* THE array of driver/bsdnet structs */
+/* If detaching/module unloading is enabled, the main driver data
+ * structure must remain in memory; hence it must reside in its own
+ * 'dummy' module...
+#ifdef  MVETH_DETACH_HACK
+extern
+#else
+STATIC
+#endif
+struct mveth_softc theMvEths[MV643XXETH_NUM_DRIVER_SLOTS]
+#ifndef MVETH_DETACH_HACK
+= {{{{0}},}}
+#endif
+/* daemon task id */
+STATIC rtems_id	mveth_tid = 0;
+/* register access protection mutex */
+STATIC rtems_id mveth_mtx = 0;
+#define REGLOCK()	do { \
+		if ( RTEMS_SUCCESSFUL != rtems_semaphore_obtain(mveth_mtx, RTEMS_WAIT, RTEMS_NO_TIMEOUT) ) \
+			rtems_panic(DRVNAME": unable to lock register protection mutex"); \
+		} while (0)
+#define REGUNLOCK()	rtems_semaphore_release(mveth_mtx)
+/* Format strings for statistics messages */
+static const char *mibfmt[] = {
+	"  GOOD_OCTS_RCVD:      %"PRIu64"\n",
+	0,
+	"  BAD_OCTS_RCVD:       %"PRIu32"\n",
+	"  INTERNAL_MAC_TX_ERR: %"PRIu32"\n",
+	"  GOOD_FRAMES_RCVD:    %"PRIu32"\n",
+	"  BAD_FRAMES_RCVD:     %"PRIu32"\n",
+	"  BCAST_FRAMES_RCVD:   %"PRIu32"\n",
+	"  MCAST_FRAMES_RCVD:   %"PRIu32"\n",
+	"  FRAMES_64_OCTS:      %"PRIu32"\n",
+	"  FRAMES_65_127_OCTS:  %"PRIu32"\n",
+	"  FRAMES_128_255_OCTS: %"PRIu32"\n",
+	"  FRAMES_256_511_OCTS: %"PRIu32"\n",
+	"  FRAMES_512_1023_OCTS:%"PRIu32"\n",
+	"  FRAMES_1024_MAX_OCTS:%"PRIu32"\n",
+	"  GOOD_OCTS_SENT:      %"PRIu64"\n",
+	0,
+	"  GOOD_FRAMES_SENT:    %"PRIu32"\n",
+	"  EXCESSIVE_COLL:      %"PRIu32"\n",
+	"  MCAST_FRAMES_SENT:   %"PRIu32"\n",
+	"  BCAST_FRAMES_SENT:   %"PRIu32"\n",
+	"  UNREC_MAC_CTRL_RCVD: %"PRIu32"\n",
+	"  FC_SENT:             %"PRIu32"\n",
+	"  GOOD_FC_RCVD:        %"PRIu32"\n",
+	"  BAD_FC_RCVD:         %"PRIu32"\n",
+	"  UNDERSIZE_RCVD:      %"PRIu32"\n",
+	"  FRAGMENTS_RCVD:      %"PRIu32"\n",
+	"  OVERSIZE_RCVD:       %"PRIu32"\n",
+	"  JABBER_RCVD:         %"PRIu32"\n",
+	"  MAC_RX_ERR:          %"PRIu32"\n",
+	"  BAD_CRC_EVENT:       %"PRIu32"\n",
+	"  COLL:                %"PRIu32"\n",
+	"  LATE_COLL:           %"PRIu32"\n",
+/* Interrupt Handler Connection */
+/* forward decls + implementation for IRQ API funcs */
+static void mveth_isr(rtems_irq_hdl_param unit);
+static void mveth_isr_1(rtems_irq_hdl_param unit);
+static void noop(const rtems_irq_connect_data *unused)  {}
+static int  noop1(const rtems_irq_connect_data *unused) { return 0; }
+static rtems_irq_connect_data irq_data[MAX_NUM_SLOTS] = {
+		BSP_IRQ_ETH0,
+		0,
+		(rtems_irq_hdl_param)0,
+		noop,
+		noop,
+		noop1
+		BSP_IRQ_ETH1,
+		0,
+		(rtems_irq_hdl_param)1,
+		noop,
+		noop,
+		noop1
+		BSP_IRQ_ETH2,
+		0,
+		(rtems_irq_hdl_param)2,
+		noop,
+		noop,
+		noop1
+/* MII Ioctl Interface */
+STATIC unsigned
+mveth_mii_read(struct mveth_private *mp, unsigned addr);
+STATIC unsigned
+mveth_mii_write(struct mveth_private *mp, unsigned addr, unsigned v);
+/* mdio / mii interface wrappers for rtems_mii_ioctl API */
+static int mveth_mdio_r(int phy, void *uarg, unsigned reg, uint32_t *pval)
+	if ( phy > 1 )
+		return -1;
+	*pval = mveth_mii_read(uarg, reg);
+	return 0;
+static int mveth_mdio_w(int phy, void *uarg, unsigned reg, uint32_t val)
+	if ( phy > 1 )
+		return -1;
+	mveth_mii_write(uarg, reg, val);
+	return 0;
+static struct rtems_mdio_info mveth_mdio = {
+	mdio_r:	  mveth_mdio_r,
+	mdio_w:	  mveth_mdio_w,
+	has_gmii: 1,
+/* LOW LEVEL SUPPORT ROUTINES */
+/* Software Cache Coherency */
+#ifndef ENABLE_HW_SNOOPING
+#ifndef __PPC__
+#error "Software cache coherency maintenance is not implemented for your CPU architecture"
+#endif
+static inline unsigned INVAL_DESC(volatile void *d)
+typedef const char cache_line[PPC_CACHE_ALIGNMENT];
+	asm volatile("dcbi 0, %1":"=m"(*(cache_line*)d):"r"(d));
+	return (unsigned)d;	/* so this can be used in comma expression */
+static inline void FLUSH_DESC(volatile void *d)
+	asm volatile("dcbf 0, %0"::"r"(d),"m"(*(cache_line*)d));
+static inline void FLUSH_BARRIER(void)
+	asm volatile("eieio");
+/* RX buffers are always cache-line aligned
+ * ASSUMPTIONS:
+ *   - 'addr' is cache aligned
+ *   -  len   is a multiple >0 of cache lines
+static inline void INVAL_BUF(register uintptr_t addr, register int len)
+typedef char maxbuf[2048]; /* more than an ethernet packet */
+	do {
+		len -= RX_BUF_ALIGNMENT;
+		asm volatile("dcbi %0, %1"::"b"(addr),"r"(len));
+	} while (len > 0);
+	asm volatile("":"=m"(*(maxbuf*)addr));
+/* Flushing TX buffers is a little bit trickier; we don't really know their
+ * alignment but *assume* adjacent addresses are covering 'ordinary' memory
+ * so that flushing them does no harm!
+static inline void FLUSH_BUF(register uintptr_t addr, register int len)
+	asm volatile("":::"memory");
+	len = MV643XX_ALIGN(len, RX_BUF_ALIGNMENT);
+	do {
+		asm volatile("dcbf %0, %1"::"b"(addr),"r"(len));
+	} while ( len >= 0 );
+#else /* hardware snooping enabled */
+/* inline this to silence compiler warnings */
+static inline int INVAL_DESC(volatile void *d)
+{ return 0; }
+#define FLUSH_DESC(d)	NOOP()
+#define INVAL_BUF(b,l)	NOOP()
+#define FLUSH_BUF(b,l)	NOOP()
+#define FLUSH_BARRIER()	NOOP()
+#endif	/* cache coherency support */
+/* Synchronize memory access */
+#ifdef __PPC__
+static inline void membarrier(void)
+	asm volatile("sync":::"memory");
+#else
+#error "memory barrier instruction not defined (yet) for this CPU"
+#endif
+/* Enable and disable interrupts at the device */
+static inline void
+mveth_enable_irqs(struct mveth_private *mp, uint32_t mask)
+rtems_interrupt_level l;
+uint32_t val;
+	rtems_interrupt_disable(l);
+	val  = MV_READ(MV643XX_ETH_INTERRUPT_ENBL_R(mp->port_num));
+	val  = (val | mask | MV643XX_ETH_IRQ_EXT_ENA) & mp->irq_mask;
+	MV_WRITE(MV643XX_ETH_INTERRUPT_ENBL_R(mp->port_num),        val);
+	val  = MV_READ(MV643XX_ETH_INTERRUPT_EXTEND_ENBL_R(mp->port_num));
+	val  = (val | mask) & mp->xirq_mask;
+	MV_WRITE(MV643XX_ETH_INTERRUPT_EXTEND_ENBL_R(mp->port_num), val);
+	rtems_interrupt_enable(l);
+static inline uint32_t
+mveth_disable_irqs(struct mveth_private *mp, uint32_t mask)
+uint32_t val,xval,tmp;
+	tmp  = ( (val & ~mask) | MV643XX_ETH_IRQ_EXT_ENA ) & mp->irq_mask;
+	MV_WRITE(MV643XX_ETH_INTERRUPT_ENBL_R(mp->port_num),        tmp);
+	xval = MV_READ(MV643XX_ETH_INTERRUPT_EXTEND_ENBL_R(mp->port_num));
+	tmp  = (xval & ~mask) & mp->xirq_mask;
+	MV_WRITE(MV643XX_ETH_INTERRUPT_EXTEND_ENBL_R(mp->port_num), tmp);
+	return (val | xval);
+/* This should be safe even w/o turning off interrupts if multiple
+ * threads ack different bits in the cause register (and ignore
+ * other ones) since writing 'ones' into the cause register doesn't
+ * 'stick'.
+mveth_ack_irqs(struct mveth_private *mp, uint32_t mask)
+register uint32_t x,xe,p;
+		p  = mp->port_num;
+		/* Get cause */
+		x  = MV_READ(MV643XX_ETH_INTERRUPT_CAUSE_R(p));
+		/* Ack interrupts filtering the ones we're interested in */
+		/* Note: EXT_IRQ bit clears by itself if EXT interrupts are cleared */
+		MV_WRITE(MV643XX_ETH_INTERRUPT_CAUSE_R(p), ~ (x & mp->irq_mask & mask));
+				/* linux driver tests 1<<1 as a summary bit for extended interrupts;
+				 * the mv64360 seems to use 1<<19 for that purpose; for the moment,
+				 * I just check both.
+				 * Update: link status irq (1<<16 in xe) doesn't set (1<<19) in x!
+		if ( 1 /* x & 2 */ )
+			xe = MV_READ(MV643XX_ETH_INTERRUPT_EXTEND_CAUSE_R(p));
+			MV_WRITE(MV643XX_ETH_INTERRUPT_EXTEND_CAUSE_R(p), ~ (xe & mp->xirq_mask & mask));
+		} else {
+			xe = 0;
+		if (    ((x & MV643XX_ETH_ALL_IRQS) & ~MV643XX_ETH_KNOWN_IRQS)
+			 || ((xe & MV643XX_ETH_ALL_EXT_IRQS) & ~MV643XX_ETH_KNOWN_EXT_IRQS) ) {
+			fprintf(stderr, "Unknown IRQs detected; leaving all disabled for debugging:\n");
+			fprintf(stderr, "Cause reg was 0x%08x, ext cause 0x%08x\n", x, xe);
+			mp->irq_mask  = 0;
+			mp->xirq_mask = 0;
+#endif
+		/* luckily, the extended and 'normal' interrupts we use don't overlap so
+		 * we can just OR them into a single word
+		return  (xe & mp->xirq_mask) | (x & mp->irq_mask);
+static void mveth_isr(rtems_irq_hdl_param arg)
+unsigned unit = (unsigned)arg;
+	mveth_disable_irqs(&theMvEths[unit].pvt, -1);
+	theMvEths[unit].pvt.stats.irqs++;
+	rtems_bsdnet_event_send( theMvEths[unit].pvt.tid, 1<<unit );
+static void mveth_isr_1(rtems_irq_hdl_param arg)
+struct mveth_private *mp   = &theMvEths[unit].pvt;
+	mp->stats.irqs++;
+	mp->isr(mp->isr_arg);
+static void
+mveth_clear_mib_counters(struct mveth_private *mp)
+register int		i;
+register uint32_t	b;
+	/* reading the counters resets them */
+	b = MV643XX_ETH_MIB_COUNTERS(mp->port_num);
+	for (i=0; i< MV643XX_ETH_NUM_MIB_COUNTERS; i++, b+=4)
+		(void)MV_READ(b);
+/* Reading a MIB register also clears it. Hence we read the lo
+ * register first, then the hi one. Correct reading is guaranteed since
+ * the 'lo' register cannot overflow after it is read since it had
+ * been reset to 0.
+static unsigned long long
+read_long_mib_counter(int port_num, int idx)
+unsigned long lo;
+unsigned long long hi;
+	lo = MV_READ(MV643XX_ETH_MIB_COUNTERS(port_num)+(idx<<2));
+	idx++;
+	hi = MV_READ(MV643XX_ETH_MIB_COUNTERS(port_num)+(idx<<2));
+	return (hi<<32) | lo;
+static inline unsigned long
+read_mib_counter(int port_num, int idx)
+	return MV_READ(MV643XX_ETH_MIB_COUNTERS(port_num)+(idx<<2));
+/* write ethernet address from buffer to hardware (need to change unicast filter after this) */
+static void
+mveth_write_eaddr(struct mveth_private *mp, unsigned char *eaddr)
+int			i;
+uint32_t	x;
+	/* build hi word */
+ 	for (i=4,x=0; i; i--, eaddr++) {
+		x = (x<<8) | *eaddr;
+	MV_WRITE(MV643XX_ETH_MAC_ADDR_HI(mp->port_num), x);
+	/* build lo word */
+ 	for (i=2,x=0; i; i--, eaddr++) {
+	MV_WRITE(MV643XX_ETH_MAC_ADDR_LO(mp->port_num), x);
+/* PHY/MII Interface
+ * Read/write a PHY register;
+ * NOTE: The SMI register is shared among the three devices.
+ *       Protection is provided by the global networking semaphore.
+ *       If non-bsd drivers are running on a subset of IFs proper
+STATIC unsigned
+unsigned v;
+unsigned wc = 0;
+	addr  &= 0x1f;
+	/* wait until not busy */
+	do {
+		v = MV_READ(MV643XX_ETH_SMI_R);
+		wc++;
+	} while ( MV643XX_ETH_SMI_BUSY & v );
+	MV_WRITE(MV643XX_ETH_SMI_R, (addr <<21 ) | (mp->phy<<16) | MV643XX_ETH_SMI_OP_RD );
+	do {
+		wc++;
+	if (wc>0xffff)
+		wc = 0xffff;
+	return (wc<<16) | (v & 0xffff);
+STATIC unsigned
+unsigned wc = 0;
+	addr  &= 0x1f;
+	v     &= 0xffff;
+	/* busywait is ugly but not preventing ISRs or high priority tasks from
+	 * preempting us
+	while ( MV643XX_ETH_SMI_BUSY & MV_READ(MV643XX_ETH_SMI_R) )
+		wc++ /* wait */;
+	MV_WRITE(MV643XX_ETH_SMI_R, (addr <<21 ) | (mp->phy<<16) | MV643XX_ETH_SMI_OP_WR | v );
+	return wc;
+/* MID-LAYER SUPPORT ROUTINES */
+/* Start TX if descriptors are exhausted */
+static __inline__ void
+mveth_start_tx(struct mveth_private *mp)
+uint32_t running;
+	if ( mp->avail <= 0 ) {
+		running = MV_READ(MV643XX_ETH_TRANSMIT_QUEUE_COMMAND_R(mp->port_num));
+		if ( ! (running & MV643XX_ETH_TX_START(0)) ) {
+			MV_WRITE(MV643XX_ETH_TRANSMIT_QUEUE_COMMAND_R(mp->port_num), MV643XX_ETH_TX_START(0));
+/* Stop TX and wait for the command queues to stop and the fifo to drain */
+static uint32_t
+mveth_stop_tx(int port)
+uint32_t active_q;
+	active_q = (MV_READ(MV643XX_ETH_TRANSMIT_QUEUE_COMMAND_R(port)) & MV643XX_ETH_TX_ANY_RUNNING);
+	if ( active_q ) {
+		/* Halt TX and wait for activity to stop */
+		MV_WRITE(MV643XX_ETH_TRANSMIT_QUEUE_COMMAND_R(port), MV643XX_ETH_TX_STOP_ALL);
+		while ( MV643XX_ETH_TX_ANY_RUNNING & MV_READ(MV643XX_ETH_TRANSMIT_QUEUE_COMMAND_R(port)) )
+			/* poll-wait */;
+		/* Wait for Tx FIFO to drain */
+		while ( ! (MV643XX_ETH_PORT_STATUS_R(port) & MV643XX_ETH_PORT_STATUS_TX_FIFO_EMPTY) )
+			/* poll-wait */;
+	return active_q;
+/* update serial port settings from current link status */
+static void
+mveth_update_serial_port(struct mveth_private *mp, int media)
+int port = mp->port_num;
+uint32_t old, new;
+	new = old = MV_READ(MV643XX_ETH_SERIAL_CONTROL_R(port));
+	/* mask speed and duplex settings */
+	new &= ~(  MV643XX_ETH_SET_GMII_SPEED_1000
+			 | MV643XX_ETH_SET_MII_SPEED_100
+			 | MV643XX_ETH_SET_FULL_DUPLEX );
+	if ( IFM_FDX & media )
+		new |= MV643XX_ETH_SET_FULL_DUPLEX;
+	switch ( IFM_SUBTYPE(media) ) {
+		default: /* treat as 10 */
+			break;
+		case IFM_100_TX:
+			new |= MV643XX_ETH_SET_MII_SPEED_100;
+			break;
+		case IFM_1000_T:
+			new |= MV643XX_ETH_SET_GMII_SPEED_1000;
+			break;
+	if ( new != old ) {
+		if ( ! (MV643XX_ETH_SERIAL_PORT_ENBL & new) ) {
+			/* just write */
+			MV_WRITE(MV643XX_ETH_SERIAL_CONTROL_R(port), new);
+		} else {
+			uint32_t were_running;
+			were_running = mveth_stop_tx(port);
+			old &= ~MV643XX_ETH_SERIAL_PORT_ENBL;
+			MV_WRITE(MV643XX_ETH_SERIAL_CONTROL_R(port), old);
+			/* linux driver writes twice... */
+			if ( were_running ) {
+/* Clear multicast filters                        */
+void
+BSP_mve_mcast_filter_clear(struct mveth_private *mp)
+int                 i;
+register uint32_t 	s,o;
+uint32_t            v = mp->promisc ? 0x01010101 : 0x00000000;
+	s = MV643XX_ETH_DA_FILTER_SPECL_MCAST_TBL(mp->port_num);
+	o = MV643XX_ETH_DA_FILTER_OTHER_MCAST_TBL(mp->port_num);
+	for (i=0; i<MV643XX_ETH_NUM_MCAST_ENTRIES; i++) {
+		MV_WRITE(s,v);
+		MV_WRITE(o,v);
+		s+=4;
+		o+=4;
+	for (i=0; i<sizeof(mp->mc_refcnt.specl)/sizeof(mp->mc_refcnt.specl[0]); i++) {
+		mp->mc_refcnt.specl[i] = 0;
+		mp->mc_refcnt.other[i] = 0;
+void
+BSP_mve_mcast_filter_accept_all(struct mveth_private *mp)
+int                 i;
+		MV_WRITE(s,0x01010101);
+		MV_WRITE(o,0x01010101);
+		s+=4;
+		o+=4;
+		/* Not clear what we should do with the reference count.
+		 * For now just increment it.
+			mp->mc_refcnt.specl[i]++;
+			mp->mc_refcnt.other[i]++;
+static void add_entry(uint32_t off, uint8_t hash, Mc_Refcnt *refcnt)
+uint32_t val;
+uint32_t slot = hash & 0xfc;
+	if ( 0 == (*refcnt)[hash]++ ) {
+		val = MV_READ(off+slot) | ( 1 << ((hash&3)<<3) );
+		MV_WRITE(off+slot, val);
+static void del_entry(uint32_t off, uint8_t hash, Mc_Refcnt *refcnt)
+uint32_t val;
+	if ( (*refcnt)[hash] > 0 && 0 == --(*refcnt)[hash] ) {
+		val = MV_READ(off+slot) & ~( 1 << ((hash&3)<<3) );
+void
+BSP_mve_mcast_filter_accept_add(struct mveth_private *mp, unsigned char *enaddr)
+uint32_t   hash;
+static const char spec[]={0x01,0x00,0x5e,0x00,0x00};
+static const char bcst[]={0xff,0xff,0xff,0xff,0xff,0xff};
+uint32_t   tabl;
+Mc_Refcnt  *refcnt;
+	if ( ! (0x01 & enaddr[0]) ) {
+		/* not a multicast address; ignore */
+		return;
+	if ( 0 == memcmp(enaddr, bcst, sizeof(bcst)) ) {
+		/* broadcast address; ignore */
+		return;
+	if ( 0 == memcmp(enaddr, spec, sizeof(spec)) ) {
+		hash   = enaddr[5];
+		tabl   = MV643XX_ETH_DA_FILTER_SPECL_MCAST_TBL(mp->port_num);
+		refcnt = &mp->mc_refcnt.specl;
+	} else {
+		uint32_t test, mask;
+		int      i;
+		/* algorithm used by linux driver */
+		for ( hash=0, i=0; i<6; i++ ) {
+			hash = (hash ^ enaddr[i]) << 8;
+			for ( test=0x8000, mask=0x8380; test>0x0080; test>>=1, mask>>=1 ) {
+				if ( hash & test )
+					hash ^= mask;
+		tabl   = MV643XX_ETH_DA_FILTER_OTHER_MCAST_TBL(mp->port_num);
+		refcnt = &mp->mc_refcnt.other;
+	add_entry(tabl, hash, refcnt);
+void
+BSP_mve_mcast_filter_accept_del(struct mveth_private *mp, unsigned char *enaddr)
+uint32_t   hash;
+uint32_t   tabl;
+Mc_Refcnt  *refcnt;
+		return;
+		return;
+		hash   = enaddr[5];
+	} else {
+		int      i;
+					hash ^= mask;
+	del_entry(tabl, hash, refcnt);
+/* Clear all address filters (multi- and unicast) */
+static void
+mveth_clear_addr_filters(struct mveth_private *mp)
+register int      i;
+register uint32_t u;
+	u = MV643XX_ETH_DA_FILTER_UNICAST_TBL(mp->port_num);
+	for (i=0; i<MV643XX_ETH_NUM_UNICAST_ENTRIES; i++) {
+		MV_WRITE(u,0);
+		u+=4;
+	BSP_mve_mcast_filter_clear(mp);
+/* Setup unicast filter for a given MAC address (least significant nibble) */
+static void
+mveth_ucfilter(struct mveth_private *mp, unsigned char mac_lsbyte, int accept)
+unsigned nib, slot, bit;
+uint32_t	val;
+	/* compute slot in table */
+	nib  = mac_lsbyte & 0xf;	/* strip nibble     */
+	slot = nib & ~3;			/* (nibble/4)*4     */
+	bit  = (nib &  3)<<3;		/*  8*(nibble % 4)  */
+	val = MV_READ(MV643XX_ETH_DA_FILTER_UNICAST_TBL(mp->port_num) + slot);
+	if ( accept ) {
+		val |= 0x01 << bit;
+	} else {
+		val &= 0x0e << bit;
+	MV_WRITE(MV643XX_ETH_DA_FILTER_UNICAST_TBL(mp->port_num) + slot, val);
+#if defined( ENABLE_TX_WORKAROUND_8_BYTE_PROBLEM ) && 0
+/* Currently unused; small unaligned buffers seem to be rare
+ * so we just use memcpy()...
+/* memcpy for 0..7 bytes; arranged so that gcc
+ * optimizes for powerpc...
+static inline void memcpy8(void *to, void *fr, unsigned x)
+register uint8_t *d = to, *s = fro;
+	d+=l; s+=l;
+	if ( l & 1 ) {
+		*--d=*--s;
+	if ( l & 2 ) {
+		/* pre-decrementing causes gcc to use auto-decrementing
+		 * PPC instructions (lhzu rx, -2(ry))
+		d-=2; s-=2;
+		/* use memcpy; don't cast to short -- accessing
+		 * misaligned data as short is not portable
+		 * (but it works on PPC).
+		__builtin_memcpy(d,s,2);
+	if ( l & 4 ) {
+		d-=4; s-=4;
+		/* see above */
+		__builtin_memcpy(d,s,4);
+#endif
+/* Assign values (buffer + user data) to a tx descriptor slot */
+static int
+mveth_assign_desc(MvEthTxDesc d, struct mbuf *m, unsigned long extra)
+int rval = (d->byte_cnt = m->m_len);
+	assert( !d->mb      );
+	assert(  m->m_len   );
+#endif
+	/* set CRC on all descriptors; seems to be necessary */
+	d->cmd_sts  = extra | (TDESC_GEN_CRC | TDESC_ZERO_PAD);
+#ifdef ENABLE_TX_WORKAROUND_8_BYTE_PROBLEM
+	/* The buffer must be 64bit aligned if the payload is <8 (??) */
+	if ( rval < 8 && ((mtod(m, uintptr_t)) & 7) ) {
+		d->buf_ptr = CPUADDR2ENET( d->workaround );
+		memcpy((void*)d->workaround, mtod(m, void*), rval);
+	} else
+#endif
+		d->buf_ptr  = CPUADDR2ENET( mtod(m, unsigned long) );
+	d->l4i_chk  = 0;
+	return rval;
+static int
+mveth_assign_desc_raw(MvEthTxDesc d, void *buf, int len, unsigned long extra)
+int rval = (d->byte_cnt = len);
+	assert( !d->u_buf );
+	assert(  len   );
+#endif
+	if ( rval < 8 && ( ((uintptr_t)buf) & 7) ) {
+		memcpy((void*)d->workaround, buf, rval);
+	} else
+#endif
+		d->buf_ptr  = CPUADDR2ENET( (unsigned long)buf );
+	d->l4i_chk  = 0;
+	return rval;
+ * Ring Initialization
+ * ENDIAN ASSUMPTION: DMA engine matches CPU endianness (???)
+ * Linux driver discriminates __LITTLE and __BIG endian for re-arranging
+ * the u16 fields in the descriptor structs. However, no endian conversion
+ * is done on the individual fields (SDMA byte swapping is disabled on LE).
+STATIC int
+mveth_init_rx_desc_ring(struct mveth_private *mp)
+int i,sz;
+MvEthRxDesc	d;
+uintptr_t baddr;
+	memset((void*)mp->rx_ring, 0, sizeof(*mp->rx_ring)*mp->rbuf_count);
+	mp->rx_desc_dma = CPUADDR2ENET(mp->rx_ring);
+	for ( i=0, d = mp->rx_ring; i<mp->rbuf_count; i++, d++ ) {
+		d->u_buf = mp->alloc_rxbuf(&sz, &baddr);
+		assert( d->u_buf );
+		/* could reduce the area to max. ethernet packet size */
+		INVAL_BUF(baddr, sz);
+#endif
+		d->buf_size = sz;
+		d->byte_cnt = 0;
+		d->cmd_sts  = RDESC_DMA_OWNED | RDESC_INT_ENA;
+		d->next		= mp->rx_ring + (i+1) % mp->rbuf_count;
+		d->buf_ptr  = CPUADDR2ENET( baddr );
+		d->next_desc_ptr = CPUADDR2ENET(d->next);
+		FLUSH_DESC(d);
+	FLUSH_BARRIER();
+	mp->d_rx_t = mp->rx_ring;
+	/* point the chip to the start of the ring */
+	MV_WRITE(MV643XX_ETH_RX_Q0_CURRENT_DESC_PTR(mp->port_num),mp->rx_desc_dma);
+	return i;
+STATIC int
+mveth_init_tx_desc_ring(struct mveth_private *mp)
+int i;
+MvEthTxDesc d;
+	memset((void*)mp->tx_ring, 0, sizeof(*mp->tx_ring)*mp->xbuf_count);
+	/* DMA and CPU live in the same address space (rtems) */
+	mp->tx_desc_dma = CPUADDR2ENET(mp->tx_ring);
+	mp->avail       = TX_AVAILABLE_RING_SIZE(mp);
+	for ( i=0, d=mp->tx_ring; i<mp->xbuf_count; i++,d++ ) {
+		d->l4i_chk  = 0;
+		d->byte_cnt = 0;
+		d->cmd_sts  = 0;
+		d->buf_ptr  = 0;
+		d->next     = mp->tx_ring + (i+1) % mp->xbuf_count;
+		FLUSH_DESC(d);
+	FLUSH_BARRIER();
+	mp->d_tx_h = mp->d_tx_t = mp->tx_ring;
+	MV_WRITE(MV643XX_ETH_TX_Q0_CURRENT_DESC_PTR(mp->port_num),mp->tx_desc_dma);
+	return i;
+/* PUBLIC LOW-LEVEL DRIVER ACCESS */
+static struct mveth_private *
+mve_setup_internal(
+	int		 unit,
+	rtems_id tid,
+	void     (*isr)(void*isr_arg),
+	void     *isr_arg,
+	void (*cleanup_txbuf)(void *user_buf, void *closure, int error_on_tx_occurred),
+	void *cleanup_txbuf_arg,
+	void *(*alloc_rxbuf)(int *p_size, uintptr_t *p_data_addr),
+	void (*consume_rxbuf)(void *user_buf, void *closure, int len),
+	void *consume_rxbuf_arg,
+	int		rx_ring_size,
+	int		tx_ring_size,
+	int		irq_mask
+struct mveth_private *mp;
+struct ifnet         *ifp;
+int                  InstallISRSuccessful;
+	if ( unit <= 0 || unit > MV643XXETH_NUM_DRIVER_SLOTS ) {
+		printk(DRVNAME": Bad unit number %i; must be 1..%i\n", unit, MV643XXETH_NUM_DRIVER_SLOTS);
+		return 0;
+	ifp = &theMvEths[unit-1].arpcom.ac_if;
+	if ( ifp->if_init ) {
+			printk(DRVNAME": instance %i already attached.\n", unit);
+			return 0;
+	if ( rx_ring_size < 0 && tx_ring_size < 0 )
+		return 0;
+	if ( MV_64360 != BSP_getDiscoveryVersion(0) ) {
+		printk(DRVNAME": not mv64360 chip\n");
+		return 0;
+	/* lazy init of mutex (non thread-safe! - we assume 1st initialization is single-threaded) */
+	if ( ! mveth_mtx ) {
+		rtems_status_code sc;
+		sc = rtems_semaphore_create(
+				rtems_build_name('m','v','e','X'),
+				1,
+				RTEMS_BINARY_SEMAPHORE | RTEMS_PRIORITY | RTEMS_INHERIT_PRIORITY | RTEMS_DEFAULT_ATTRIBUTES,
+				0,
+				&mveth_mtx);
+		if ( RTEMS_SUCCESSFUL != sc ) {
+			rtems_error(sc,DRVNAME": creating mutex\n");
+			rtems_panic("unable to proceed\n");
+	mp = &theMvEths[unit-1].pvt;
+	memset(mp, 0, sizeof(*mp));
+	mp->port_num          = unit-1;
+	mp->phy               = (MV_READ(MV643XX_ETH_PHY_ADDR_R) >> (5*mp->port_num)) & 0x1f;
+	mp->tid               = tid;
+	mp->isr               = isr;
+	mp->isr_arg           = isr_arg;
+	mp->cleanup_txbuf     = cleanup_txbuf;
+	mp->cleanup_txbuf_arg = cleanup_txbuf_arg;
+	mp->alloc_rxbuf       = alloc_rxbuf;
+	mp->consume_rxbuf     = consume_rxbuf;
+	mp->consume_rxbuf_arg = consume_rxbuf_arg;
+	mp->rbuf_count = rx_ring_size ? rx_ring_size : MV643XX_RX_RING_SIZE;
+	mp->xbuf_count = tx_ring_size ? tx_ring_size : MV643XX_TX_RING_SIZE;
+	if ( mp->xbuf_count > 0 )
+		mp->xbuf_count += TX_NUM_TAG_SLOTS;
+	if ( mp->rbuf_count < 0 )
+		mp->rbuf_count = 0;
+	if ( mp->xbuf_count < 0 )
+		mp->xbuf_count = 0;
+	/* allocate ring area; add 1 entry -- room for alignment */
+	assert( !mp->ring_area );
+	mp->ring_area = malloc(
+							sizeof(*mp->ring_area) *
+								(mp->rbuf_count + mp->xbuf_count + 1),
+							M_DEVBUF,
+							M_WAIT );
+	assert( mp->ring_area );
+	BSP_mve_stop_hw(mp);
+	if ( irq_mask ) {
+		irq_data[mp->port_num].hdl = tid ? mveth_isr : mveth_isr_1;
+		InstallISRSuccessful = BSP_install_rtems_irq_handler( &irq_data[mp->port_num] );
+		assert( InstallISRSuccessful );
+	/* mark as used */
+	ifp->if_init = (void*)(-1);
+	if ( rx_ring_size < 0 )
+		irq_mask &= ~ MV643XX_ETH_IRQ_RX_DONE;
+	if ( tx_ring_size < 0 )
+		irq_mask &= ~ MV643XX_ETH_EXT_IRQ_TX_DONE;
+	mp->irq_mask = (irq_mask & MV643XX_ETH_IRQ_RX_DONE);
+	if ( (irq_mask &= (MV643XX_ETH_EXT_IRQ_TX_DONE | MV643XX_ETH_EXT_IRQ_LINK_CHG)) ) {
+		mp->irq_mask |= MV643XX_ETH_IRQ_EXT_ENA;
+		mp->xirq_mask = irq_mask;
+	} else {
+	return mp;
+BSP_mve_setup(
+	int		 unit,
+	rtems_id tid,
+	int		rx_ring_size,
+	int		tx_ring_size,
+	int		irq_mask
+	if ( irq_mask && 0 == tid ) {
+		printk(DRVNAME": must supply a TID if irq_msk not zero\n");
+		return 0;
+	return mve_setup_internal(
+				unit,
+				tid,
+				0, 0,
+				cleanup_txbuf, cleanup_txbuf_arg,
+				alloc_rxbuf,
+				consume_rxbuf, consume_rxbuf_arg,
+				rx_ring_size, tx_ring_size,
+				irq_mask);
+BSP_mve_setup_1(
+	int		 unit,
+	void     (*isr)(void *isr_arg),
+	void     *isr_arg,
+	int		rx_ring_size,
+	int		tx_ring_size,
+	int		irq_mask
+	if ( irq_mask && 0 == isr ) {
+		printk(DRVNAME": must supply an ISR if irq_msk not zero\n");
+		return 0;
+				unit,
+				0,
+				isr, isr_arg,
+				alloc_rxbuf,
+				irq_mask);
+rtems_id
+BSP_mve_get_tid(struct mveth_private *mp)
+    return mp->tid;
+int
+BSP_mve_detach(struct mveth_private *mp)
+int unit = mp->port_num;
+	if ( mp->irq_mask || mp->xirq_mask ) {
+		if ( !BSP_remove_rtems_irq_handler( &irq_data[mp->port_num] ) )
+			return -1;
+	free( (void*)mp->ring_area, M_DEVBUF );
+	__asm__ __volatile__("":::"memory");
+	/* mark as unused */
+	theMvEths[unit].arpcom.ac_if.if_init = 0;
+	return 0;
+/* MAIN RX-TX ROUTINES
+ * BSP_mve_swipe_tx():  descriptor scavenger; releases mbufs
+ * BSP_mve_send_buf():  xfer mbufs from IF to chip
+ * BSP_mve_swipe_rx():  enqueue received mbufs to interface
+ *                    allocate new ones and yield them to the
+ *                    chip.
+/* clean up the TX ring freeing up buffers */
+int
+BSP_mve_swipe_tx(struct mveth_private *mp)
+int						rval = 0;
+register MvEthTxDesc	d;
+	for ( d = mp->d_tx_t; d->buf_ptr; d = NEXT_TXD(d) ) {
+		INVAL_DESC(d);
+		if (	(TDESC_DMA_OWNED & d->cmd_sts)
+			 &&	(uint32_t)d == MV_READ(MV643XX_ETH_CURRENT_SERVED_TX_DESC(mp->port_num)) )
+			break;
+		/* d->u_buf is only set on the last descriptor in a chain;
+		 * we only count errors in the last descriptor;
+		if ( d->u_buf ) {
+			mp->cleanup_txbuf(d->u_buf, mp->cleanup_txbuf_arg, (d->cmd_sts & TDESC_ERROR) ? 1 : 0);
+			d->u_buf = 0;
+		d->buf_ptr = 0;
+		rval++;
+	mp->d_tx_t = d;
+	mp->avail += rval;
+	return rval;
+/* allocate a new cluster and copy an existing chain there;
+ * old chain is released...
+static struct mbuf *
+repackage_chain(struct mbuf *m_head)
+struct mbuf *m;
+	MGETHDR(m, M_DONTWAIT, MT_DATA);
+	if ( !m ) {
+		goto bail;
+	MCLGET(m, M_DONTWAIT);
+	if ( !(M_EXT & m->m_flags) ) {
+		m_freem(m);
+		m = 0;
+		goto bail;
+	m_copydata(m_head, 0, MCLBYTES, mtod(m, caddr_t));
+	m->m_pkthdr.len = m->m_len = m_head->m_pkthdr.len;
+bail:
+	m_freem(m_head);
+	return m;
+/* Enqueue a mbuf chain or a raw data buffer for transmission;
+ * RETURN: #bytes sent or -1 if there are not enough descriptors
+ * If 'len' is <=0 then 'm_head' is assumed to point to a mbuf chain.
+ * OTOH, a raw data packet may be send (non-BSD driver) by pointing
+ * m_head to the start of the data and passing 'len' > 0.
+ * Comments: software cache-flushing incurs a penalty if the
+ *           packet cannot be queued since it is flushed anyways.
+ *           The algorithm is slightly more efficient in the normal
+ *			 case, though.
+int
+BSP_mve_send_buf(struct mveth_private *mp, void *m_head, void *data_p, int len)
+int						rval;
+register MvEthTxDesc	l,d,h;
+register struct mbuf	*m1;
+int						nmbs;
+int						ismbuf = (len <= 0);
+/* Only way to get here is when we discover that the mbuf chain
+ * is too long for the tx ring
+startover:
+	rval = 0;
+	assert(m_head);
+#endif
+	/* if no descriptor is available; try to wipe the queue */
+	if ( (mp->avail < 1) && MVETH_CLEAN_ON_SEND(mp)<=0 ) {
+		/* Maybe TX is stalled and needs to be restarted */
+		mveth_start_tx(mp);
+		return -1;
+	h = mp->d_tx_h;
+	assert( !h->buf_ptr );
+	assert( !h->mb      );
+#endif
+	if ( ! (m1 = m_head) )
+		return 0;
+	if ( ismbuf ) {
+		/* find first mbuf with actual data */
+		while ( 0 == m1->m_len ) {
+			if ( ! (m1 = m1->m_next) ) {
+				/* end reached and still no data to send ?? */
+				m_freem(m_head);
+				return 0;
+	/* Don't use the first descriptor yet because BSP_mve_swipe_tx()
+	 * needs mp->d_tx_h->buf_ptr == NULL as a marker. Hence, we
+	 * start with the second mbuf and fill the first descriptor
+	 * last.
+	l = h;
+	d = NEXT_TXD(h);
+	mp->avail--;
+	nmbs = 1;
+	if ( ismbuf ) {
+			register struct mbuf *m;
+			for ( m=m1->m_next; m; m=m->m_next ) {
+					if ( 0 == m->m_len )
+							continue;	/* skip empty mbufs */
+					nmbs++;
+					if ( mp->avail < 1 && MVETH_CLEAN_ON_SEND(mp)<=0 ) {
+							/* Maybe TX was stalled - try to restart */
+							/* not enough descriptors; cleanup...
+							 * the first slot was never used, so we start
+							 * at mp->d_tx_h->next;
+							for ( l = NEXT_TXD(h); l!=d; l=NEXT_TXD(l) ) {
+									assert( l->mb == 0 );
+#endif
+									l->buf_ptr  = 0;
+									l->cmd_sts  = 0;
+									mp->avail++;
+							mp->avail++;
+							if ( nmbs > TX_AVAILABLE_RING_SIZE(mp) ) {
+									/* this chain will never fit into the ring */
+									if ( nmbs > mp->stats.maxchain )
+											mp->stats.maxchain = nmbs;
+									mp->stats.repack++;
+									if ( ! (m_head = repackage_chain(m_head)) ) {
+											/* no cluster available */
+											mp->stats.odrops++;
+											return 0;
+									goto startover;
+							return -1;
+					mp->avail--;
+					assert( d != h      );
+					assert( !d->buf_ptr );
+#endif
+					/* fill this slot */
+					rval += mveth_assign_desc(d, m, TDESC_DMA_OWNED);
+					FLUSH_BUF(mtod(m, uint32_t), m->m_len);
+					l = d;
+					d = NEXT_TXD(d);
+					FLUSH_DESC(l);
+		/* fill first slot - don't release to DMA yet */
+		rval += mveth_assign_desc(h, m1, TDESC_FRST);
+		FLUSH_BUF(mtod(m1, uint32_t), m1->m_len);
+	} else {
+		/* fill first slot with raw buffer - don't release to DMA yet */
+		rval += mveth_assign_desc_raw(h, data_p, len, TDESC_FRST);
+		FLUSH_BUF( (uint32_t)data_p, len);
+	/* tag last slot; this covers the case where 1st==last */
+	l->cmd_sts      |= TDESC_LAST | TDESC_INT_ENA;
+	/* mbuf goes into last desc */
+	l->u_buf         = m_head;
+	FLUSH_DESC(l);
+	/* Tag end; make sure chip doesn't try to read ahead of here! */
+	l->next->cmd_sts = 0;
+	FLUSH_DESC(l->next);
+	if ( (mveth_tx_dump & (1<<mp->port_num)) ) {
+		int ll,kk;
+		if ( ismbuf ) {
+			struct mbuf *m;
+			for ( kk=0, m=m_head; m; m=m->m_next) {
+				for ( ll=0; ll<m->m_len; ll++ ) {
+					printf("%02X ",*(mtod(m,char*) + ll));
+					if ( ((++kk)&0xf) == 0 )
+						printf("\n");
+		} else {
+			for ( ll=0; ll<len; ) {
+				printf("%02X ",*((char*)data_p + ll));
+				if ( ((++ll)&0xf) == 0 )
+					printf("\n");
+		printf("\n");
+#endif
+	membarrier();
+	/* turn over the whole chain by flipping ownership of the first desc */
+	h->cmd_sts |= TDESC_DMA_OWNED;
+	FLUSH_DESC(h);
+	membarrier();
+	/* notify the device */
+	/* Update softc */
+	mp->stats.packet++;
+	/* remember new head */
+	mp->d_tx_h = d;
+	return rval; /* #bytes sent */
+int
+BSP_mve_send_buf_raw(
+	struct mveth_private *mp,
+	void                 *head_p,
+	int                   h_len,
+	void                 *data_p,
+    int                   d_len)
+int						rval;
+int						needed;
+void                    *frst_buf;
+int                     frst_len;
+	rval = 0;
+	assert(header || data);
+#endif
+	needed = head_p && data_p ? 2 : 1;
+	if (   ( mp->avail < needed )
+        && ( MVETH_CLEAN_ON_SEND(mp) <= 0 || mp->avail < needed ) ) {
+		/* Maybe TX was stalled and needs a restart */
+		return -1;
+	h = mp->d_tx_h;
+	assert( !h->mb      );
+#endif
+	/* find the 'first' user buffer */
+	if ( (frst_buf = head_p) ) {
+		frst_len = h_len;
+	} else {
+		frst_buf = data_p;
+		frst_len = d_len;
+	 * start with the second (optional) slot and fill the first
+     * descriptor last.
+	l = h;
+	d = NEXT_TXD(h);
+	mp->avail--;
+	if ( needed > 1 ) {
+		mp->avail--;
+		assert( d != h      );
+#endif
+		rval += mveth_assign_desc_raw(d, data_p, d_len, TDESC_DMA_OWNED);
+		FLUSH_BUF( (uint32_t)data_p, d_len );
+		d->u_buf = data_p;
+		l = d;
+		d = NEXT_TXD(d);
+		FLUSH_DESC(l);
+	rval       += mveth_assign_desc_raw(h, frst_buf, frst_len, TDESC_FRST);
+	FLUSH_BUF( (uint32_t)frst_buf, frst_len);
+	/* first buffer of 'chain' goes into last desc */
+	l->u_buf    = frst_buf;
+	FLUSH_DESC(l);
+	membarrier();
+	FLUSH_DESC(h);
+	membarrier();
+	if ( needed > mp->stats.maxchain )
+		mp->stats.maxchain = needed;
+	mp->d_tx_h = d;
+/* send received buffers upwards and replace them
+ * with freshly allocated ones;
+ * ASSUMPTION:	buffer length NEVER changes and is set
+ *				when the ring is initialized.
+ * TS 20060727: not sure if this assumption is still necessary - I believe it isn't.
+int
+BSP_mve_swipe_rx(struct mveth_private *mp)
+int						rval = 0, err;
+register MvEthRxDesc	d;
+void					*newbuf;
+int						sz;
+uintptr_t 				baddr;
+	for ( d = mp->d_rx_t; ! (INVAL_DESC(d), (RDESC_DMA_OWNED & d->cmd_sts)); d=NEXT_RXD(d) ) {
+		assert(d->u_buf);
+#endif
+		err = (RDESC_ERROR & d->cmd_sts);
+		if ( err || !(newbuf = mp->alloc_rxbuf(&sz, &baddr)) ) {
+			/* drop packet and recycle buffer */
+			newbuf = d->u_buf;
+			mp->consume_rxbuf(0, mp->consume_rxbuf_arg, err ? -1 : 0);
+		} else {
+			assert( d->byte_cnt > 0 );
+#endif
+			mp->consume_rxbuf(d->u_buf, mp->consume_rxbuf_arg, d->byte_cnt);
+#endif
+			d->u_buf    = newbuf;
+			d->buf_ptr  = CPUADDR2ENET(baddr);
+			d->buf_size = sz;
+			FLUSH_DESC(d);
+		membarrier();
+		FLUSH_DESC(d);
+		rval++;
+	MV_WRITE(MV643XX_ETH_RECEIVE_QUEUE_COMMAND_R(mp->port_num), MV643XX_ETH_RX_START(0));
+	mp->d_rx_t = d;
+	return rval;
+/* Stop hardware and clean out the rings */
+void
+BSP_mve_stop_hw(struct mveth_private *mp)
+MvEthTxDesc	d;
+MvEthRxDesc	r;
+int			i;
+	mveth_disable_irqs(mp, -1);
+	mveth_stop_tx(mp->port_num);
+	/* cleanup TX rings */
+	if (mp->d_tx_t) { /* maybe ring isn't initialized yet */
+		for ( i=0, d=mp->tx_ring; i<mp->xbuf_count; i++, d++ ) {
+			/* should be safe to clear ownership */
+			d->cmd_sts &= ~TDESC_DMA_OWNED;
+			FLUSH_DESC(d);
+		FLUSH_BARRIER();
+		BSP_mve_swipe_tx(mp);
+		assert( mp->d_tx_h == mp->d_tx_t );
+#endif
+	MV_WRITE(MV643XX_ETH_RECEIVE_QUEUE_COMMAND_R(mp->port_num), MV643XX_ETH_RX_STOP_ALL);
+	while ( MV643XX_ETH_RX_ANY_RUNNING & MV_READ(MV643XX_ETH_RECEIVE_QUEUE_COMMAND_R(mp->port_num)) )
+		/* poll-wait */;
+	/* stop serial port */
+	MV_WRITE(MV643XX_ETH_SERIAL_CONTROL_R(mp->port_num),
+		MV_READ(MV643XX_ETH_SERIAL_CONTROL_R(mp->port_num))
+		& ~( MV643XX_ETH_SERIAL_PORT_ENBL | MV643XX_ETH_FORCE_LINK_FAIL_DISABLE | MV643XX_ETH_FORCE_LINK_PASS)
+	/* clear pending interrupts */
+	MV_WRITE(MV643XX_ETH_INTERRUPT_CAUSE_R(mp->port_num), 0);
+	MV_WRITE(MV643XX_ETH_INTERRUPT_EXTEND_CAUSE_R(mp->port_num), 0);
+	/* cleanup RX rings */
+	if ( mp->rx_ring ) {
+		for ( i=0, r=mp->rx_ring; i<mp->rbuf_count; i++, r++ ) {
+			/* should be OK to clear ownership flag */
+			r->cmd_sts = 0;
+			FLUSH_DESC(r);
+			mp->consume_rxbuf(r->u_buf, mp->consume_rxbuf_arg, 0);
+			r->u_buf = 0;
+		FLUSH_BARRIER();
+uint32_t mveth_serial_ctrl_config_val = MVETH_SERIAL_CTRL_CONFIG_VAL;
+/* Fire up the low-level driver
+ * - make sure hardware is halted
+ * - enable cache snooping
+ * - clear address filters
+ * - clear mib counters
+ * - reset phy
+ * - initialize (or reinitialize) descriptor rings
+ * - check that the firmware has set up a reasonable mac address.
+ * - generate unicast filter entry for our mac address
+ * - write register config values to the chip
+ * - start hardware (serial port and SDMA)
+void
+BSP_mve_init_hw(struct mveth_private *mp, int promisc, unsigned char *enaddr)
+int					i;
+uint32_t			v;
+static int			inited = 0;
+#ifdef MVETH_DEBUG
+	printk(DRVNAME"%i: Entering BSP_mve_init_hw()\n", mp->port_num+1);
+#endif
+	/* since enable/disable IRQ routine only operate on select bitsets
+	 * we must make sure everything is masked initially.
+	MV_WRITE(MV643XX_ETH_INTERRUPT_ENBL_R(mp->port_num),        0);
+	MV_WRITE(MV643XX_ETH_INTERRUPT_EXTEND_ENBL_R(mp->port_num), 0);
+	memset(&mp->stats, 0, sizeof(mp->stats));
+	mp->promisc = promisc;
+	/* MotLoad has cache snooping disabled on the ENET2MEM windows.
+	 * Some comments in (linux) indicate that there are errata
+	 * which cause problems which would be a real bummer.
+	 * We try it anyways...
+	if ( !inited ) {
+	unsigned long disbl, bar;
+		inited = 1;	/* FIXME: non-thread safe lazy init */
+		disbl = MV_READ(MV643XX_ETH_BAR_ENBL_R);
+			/* disable all 6 windows */
+			MV_WRITE(MV643XX_ETH_BAR_ENBL_R, MV643XX_ETH_BAR_DISBL_ALL);
+			/* set WB snooping on enabled bars */
+			for ( i=0; i<MV643XX_ETH_NUM_BARS*8; i+=8 ) {
+				if ( (bar = MV_READ(MV643XX_ETH_BAR_0 + i)) && MV_READ(MV643XX_ETH_SIZE_R_0 + i) ) {
+					MV_WRITE(MV643XX_ETH_BAR_0 + i, bar | MV64360_ENET2MEM_SNOOP_WB);
+#else
+					MV_WRITE(MV643XX_ETH_BAR_0 + i, bar & ~MV64360_ENET2MEM_SNOOP_MSK);
+#endif
+					/* read back to flush fifo [linux comment] */
+					(void)MV_READ(MV643XX_ETH_BAR_0 + i);
+			/* restore/re-enable */
+		MV_WRITE(MV643XX_ETH_BAR_ENBL_R, disbl);
+	mveth_clear_mib_counters(mp);
+	mveth_clear_addr_filters(mp);
+/*	Just leave it alone...
+	reset_phy();
+	if ( mp->rbuf_count > 0 ) {
+		mp->rx_ring = (MvEthRxDesc)MV643XX_ALIGN(mp->ring_area, RING_ALIGNMENT);
+		mveth_init_rx_desc_ring(mp);
+	if ( mp->xbuf_count > 0 ) {
+		mp->tx_ring = (MvEthTxDesc)mp->rx_ring + mp->rbuf_count;
+		mveth_init_tx_desc_ring(mp);
+	if ( enaddr ) {
+		/* set ethernet address from arpcom struct */
+#ifdef MVETH_DEBUG
+		printk(DRVNAME"%i: Writing MAC addr ", mp->port_num+1);
+		for (i=5; i>=0; i--) {
+			printk("%02X%c", enaddr[i], i?':':'\n');
+#endif
+		mveth_write_eaddr(mp, enaddr);
+	/* set mac address and unicast filter */
+	uint32_t machi, maclo;
+		maclo = MV_READ(MV643XX_ETH_MAC_ADDR_LO(mp->port_num));
+		machi = MV_READ(MV643XX_ETH_MAC_ADDR_HI(mp->port_num));
+		/* ASSUME: firmware has set the mac address for us
+		 *         - if assertion fails, we have to do more work...
+		assert( maclo && machi && maclo != 0xffffffff && machi != 0xffffffff );
+		mveth_ucfilter(mp, maclo&0xff, 1/* accept */);
+	/* port, serial and sdma configuration */
+	v = MVETH_PORT_CONFIG_VAL;
+	if ( promisc ) {
+		/* multicast filters were already set up to
+		 * accept everything (mveth_clear_addr_filters())
+		v |= MV643XX_ETH_UNICAST_PROMISC_MODE;
+	} else {
+		v &= ~MV643XX_ETH_UNICAST_PROMISC_MODE;
+	MV_WRITE(MV643XX_ETH_PORT_CONFIG_R(mp->port_num),
+				v);
+	MV_WRITE(MV643XX_ETH_PORT_CONFIG_XTEND_R(mp->port_num),
+				MVETH_PORT_XTEND_CONFIG_VAL);
+	v  = MV_READ(MV643XX_ETH_SERIAL_CONTROL_R(mp->port_num));
+	v &= ~(MVETH_SERIAL_CTRL_CONFIG_MSK);
+	v |= mveth_serial_ctrl_config_val;
+	MV_WRITE(MV643XX_ETH_SERIAL_CONTROL_R(mp->port_num), v);
+	i = IFM_MAKEWORD(0, 0, 0, 0);
+	if ( 0 == BSP_mve_media_ioctl(mp, SIOCGIFMEDIA, &i) ) {
+	    if ( (IFM_LINK_OK & i) ) {
+			mveth_update_serial_port(mp, i);
+	/* enable serial port */
+				v | MV643XX_ETH_SERIAL_PORT_ENBL);
+#error	"byte swapping needs to be disabled for little endian machines"
+#endif
+	MV_WRITE(MV643XX_ETH_SDMA_CONFIG_R(mp->port_num), MVETH_SDMA_CONFIG_VAL);
+	/* allow short frames */
+	MV_WRITE(MV643XX_ETH_RX_MIN_FRAME_SIZE_R(mp->port_num), MVETH_MIN_FRAMSZ_CONFIG_VAL);
+	/* TODO: set irq coalescing */
+	/* enable Rx */
+	mveth_enable_irqs(mp, -1);
+#ifdef MVETH_DEBUG
+	printk(DRVNAME"%i: Leaving BSP_mve_init_hw()\n", mp->port_num+1);
+#endif
+/* read ethernet address from hw to buffer */
+void
+BSP_mve_read_eaddr(struct mveth_private *mp, unsigned char *oeaddr)
+int				i;
+uint32_t		x;
+unsigned char	buf[6], *eaddr;
+	eaddr = oeaddr ? oeaddr : buf;
+	eaddr += 5;
+	x = MV_READ(MV643XX_ETH_MAC_ADDR_LO(mp->port_num));
+	/* lo word */
+ 	for (i=2; i; i--, eaddr--) {
+		*eaddr = (unsigned char)(x & 0xff);
+		x>>=8;
+	x = MV_READ(MV643XX_ETH_MAC_ADDR_HI(mp->port_num));
+	/* hi word */
+ 	for (i=4; i; i--, eaddr--) {
+		x>>=8;
+	if ( !oeaddr ) {
+		printf("%02X",buf[0]);
+		for (i=1; i<sizeof(buf); i++)
+			printf(":%02X",buf[i]);
+		printf("\n");
+int
+BSP_mve_media_ioctl(struct mveth_private *mp, int cmd, int *parg)
+int rval;
+	/* alias cmd == 0,1 */
+	switch ( cmd ) {
+		case 0: cmd = SIOCGIFMEDIA;
+			break;
+		case 1: cmd = SIOCSIFMEDIA;
+		case SIOCGIFMEDIA:
+		case SIOCSIFMEDIA:
+			break;
+		default: return -1;
+	REGLOCK();
+	rval = rtems_mii_ioctl(&mveth_mdio, mp, cmd, parg);
+	REGUNLOCK();
+	return rval;
+void
+BSP_mve_enable_irqs(struct mveth_private *mp)
+void
+BSP_mve_disable_irqs(struct mveth_private *mp)
+uint32_t
+BSP_mve_ack_irqs(struct mveth_private *mp)
+	return mveth_ack_irqs(mp, -1);
+void
+BSP_mve_enable_irq_mask(struct mveth_private *mp, uint32_t mask)
+	mveth_enable_irqs(mp, mask);
+uint32_t
+BSP_mve_disable_irq_mask(struct mveth_private *mp, uint32_t mask)
+	return mveth_disable_irqs(mp, mask);
+uint32_t
+BSP_mve_ack_irq_mask(struct mveth_private *mp, uint32_t mask)
+	return mveth_ack_irqs(mp, mask);
+int
+BSP_mve_ack_link_chg(struct mveth_private *mp, int *pmedia)
+int media = IFM_MAKEWORD(0,0,0,0);
+	if ( 0 == BSP_mve_media_ioctl(mp, SIOCGIFMEDIA, &media)) {
+		if ( IFM_LINK_OK & media ) {
+			mveth_update_serial_port(mp, media);
+			/* If TX stalled because there was no buffer then whack it */
+		if ( pmedia )
+			*pmedia = media;
+		return 0;
+	return -1;
+/* BSDNET SUPPORT/GLUE ROUTINES */
+static void
+mveth_set_filters(struct ifnet *ifp);
+STATIC void
+mveth_stop(struct mveth_softc *sc)
+	BSP_mve_stop_hw(&sc->pvt);
+	sc->arpcom.ac_if.if_timer = 0;
+/* allocate a mbuf for RX with a properly aligned data buffer
+ * RETURNS 0 if allocation fails
+static void *
+alloc_mbuf_rx(int *psz, uintptr_t *paddr)
+struct mbuf		*m;
+unsigned long	l,o;
+	if ( !m )
+		return 0;
+	if ( ! (m->m_flags & M_EXT) ) {
+		m_freem(m);
+		return 0;
+	o = mtod(m, unsigned long);
+	l = MV643XX_ALIGN(o, RX_BUF_ALIGNMENT) - o;
+	/* align start of buffer */
+	m->m_data += l;
+	/* reduced length */
+	l = MCLBYTES - l;
+	m->m_len   = m->m_pkthdr.len = l;
+	*psz       = m->m_len;
+	*paddr     = mtod(m, uintptr_t);
+	return (void*) m;
+static void consume_rx_mbuf(void *buf, void *arg, int len)
+struct ifnet *ifp = arg;
+struct mbuf    *m = buf;
+	if ( len <= 0 ) {
+		ifp->if_iqdrops++;
+		if ( len < 0 ) {
+			ifp->if_ierrors++;
+		if ( m )
+			m_freem(m);
+	} else {
+		struct ether_header *eh;
+			eh			= (struct ether_header *)(mtod(m, unsigned long) + ETH_RX_OFFSET);
+			m->m_len	= m->m_pkthdr.len = len - sizeof(struct ether_header) - ETH_RX_OFFSET - ETH_CRC_LEN;
+			m->m_data  += sizeof(struct ether_header) + ETH_RX_OFFSET;
+			m->m_pkthdr.rcvif = ifp;
+			ifp->if_ipackets++;
+			ifp->if_ibytes  += m->m_pkthdr.len;
+			if (0) {
+				/* Low-level debugging */
+				int i;
+				for (i=0; i<13; i++) {
+					printf("%02X:",((char*)eh)[i]);
+				printf("%02X\n",((char*)eh)[i]);
+				for (i=0; i<m->m_len; i++) {
+					if ( !(i&15) )
+						printf("\n");
+					printf("0x%02x ",mtod(m,char*)[i]);
+				printf("\n");
+			if (0) {
+				/* Low-level debugging/testing without bsd stack */
+				m_freem(m);
+			} else {
+				/* send buffer upwards */
+				ether_input(ifp, eh, m);
+static void release_tx_mbuf(void *buf, void *arg, int err)
+struct mbuf  *mb  = buf;
+	if ( err ) {
+		ifp->if_oerrors++;
+	} else {
+		ifp->if_opackets++;
+	ifp->if_obytes += mb->m_pkthdr.len;
+	m_freem(mb);
+static void
+dump_update_stats(struct mveth_private *mp, FILE *f)
+int      p = mp->port_num;
+int      idx;
+uint32_t v;
+	if ( !f )
+		f = stdout;
+	fprintf(f, DRVNAME"%i Statistics:\n",        mp->port_num + 1);
+	fprintf(f, "  # IRQS:                 %i\n", mp->stats.irqs);
+	fprintf(f, "  Max. mbuf chain length: %i\n", mp->stats.maxchain);
+	fprintf(f, "  # repacketed:           %i\n", mp->stats.repack);
+	fprintf(f, "  # packets:              %i\n", mp->stats.packet);
+	fprintf(f, "MIB Counters:\n");
+	for ( idx = MV643XX_ETH_MIB_GOOD_OCTS_RCVD_LO>>2;
+			idx < MV643XX_ETH_NUM_MIB_COUNTERS;
+			idx++ ) {
+		switch ( idx ) {
+			case MV643XX_ETH_MIB_GOOD_OCTS_RCVD_LO>>2:
+				mp->stats.mib.good_octs_rcvd += read_long_mib_counter(p, idx);
+				fprintf(f, mibfmt[idx], mp->stats.mib.good_octs_rcvd);
+				idx++;
+				break;
+			case MV643XX_ETH_MIB_GOOD_OCTS_SENT_LO>>2:
+				mp->stats.mib.good_octs_sent += read_long_mib_counter(p, idx);
+				fprintf(f, mibfmt[idx], mp->stats.mib.good_octs_sent);
+				idx++;
+				break;
+			default:
+				v = ((uint32_t*)&mp->stats.mib)[idx] += read_mib_counter(p, idx);
+				fprintf(f, mibfmt[idx], v);
+				break;
+	fprintf(f, "\n");
+void
+BSP_mve_dump_stats(struct mveth_private *mp, FILE *f)
+	dump_update_stats(mp, f);
+/* BSDNET DRIVER CALLBACKS */
+static void
+mveth_init(void *arg)
+struct mveth_softc	*sc  = arg;
+struct ifnet		*ifp = &sc->arpcom.ac_if;
+int                 media;
+	BSP_mve_init_hw(&sc->pvt, ifp->if_flags & IFF_PROMISC, sc->arpcom.ac_enaddr);
+	media = IFM_MAKEWORD(0, 0, 0, 0);
+	if ( 0 == BSP_mve_media_ioctl(&sc->pvt, SIOCGIFMEDIA, &media) ) {
+	    if ( (IFM_LINK_OK & media) ) {
+			ifp->if_flags &= ~IFF_OACTIVE;
+		} else {
+			ifp->if_flags |= IFF_OACTIVE;
+	/* if promiscuous then there is no need to change */
+	if ( ! (ifp->if_flags & IFF_PROMISC) )
+		mveth_set_filters(ifp);
+	ifp->if_flags |= IFF_RUNNING;
+/* bsdnet driver entry to start transmission */
+static void
+mveth_start(struct ifnet *ifp)
+struct mveth_softc	*sc = ifp->if_softc;
+struct mbuf			*m  = 0;
+	while ( ifp->if_snd.ifq_head ) {
+		IF_DEQUEUE( &ifp->if_snd, m );
+		if ( BSP_mve_send_buf(&sc->pvt, m, 0, 0) < 0 ) {
+			IF_PREPEND( &ifp->if_snd, m);
+			break;
+		/* need to do this really only once
+		 * but it's cheaper this way.
+		ifp->if_timer = 2*IFNET_SLOWHZ;
+/* bsdnet driver entry; */
+static void
+mveth_watchdog(struct ifnet *ifp)
+	printk(DRVNAME"%i: watchdog timeout; resetting\n", ifp->if_unit);
+	mveth_init(sc);
+	mveth_start(ifp);
+static void
+uint32_t              v;
+	v = MV_READ(MV643XX_ETH_PORT_CONFIG_R(sc->pvt.port_num));
+	if ( ifp->if_flags & IFF_PROMISC )
+	else
+	MV_WRITE(MV643XX_ETH_PORT_CONFIG_R(sc->pvt.port_num), v);
+	if ( ifp->if_flags & (IFF_PROMISC | IFF_ALLMULTI) ) {
+		BSP_mve_mcast_filter_accept_all(&sc->pvt);
+	} else {
+		struct ether_multi     *enm;
+		struct ether_multistep step;
+		BSP_mve_mcast_filter_clear( &sc->pvt );
+		ETHER_FIRST_MULTI(step, (struct arpcom *)ifp, enm);
+		while ( enm ) {
+			if ( memcmp(enm->enm_addrlo, enm->enm_addrhi, ETHER_ADDR_LEN) )
+				assert( !"Should never get here; IFF_ALLMULTI should be set!" );
+			BSP_mve_mcast_filter_accept_add(&sc->pvt, enm->enm_addrlo);
+			ETHER_NEXT_MULTI(step, enm);
+/* bsdnet driver ioctl entry */
+static int
+mveth_ioctl(struct ifnet *ifp, ioctl_command_t cmd, caddr_t data)
+struct ifreq		*ifr  = (struct ifreq *)data;
+int					error = 0;
+int					f;
+	switch ( cmd ) {
+  		case SIOCSIFFLAGS:
+			f = ifp->if_flags;
+			if ( f & IFF_UP ) {
+				if ( ! ( f & IFF_RUNNING ) ) {
+					mveth_init(sc);
+				} else {
+					if ( (f & IFF_PROMISC) != (sc->bsd.oif_flags & IFF_PROMISC) ) {
+						/* Note: in all other scenarios the 'promisc' flag
+						 * in the low-level driver [which affects the way
+						 * the multicast filter is setup: accept none vs.
+						 * accept all in promisc mode] is eventually
+						 * set when the IF is brought up...
+						sc->pvt.promisc = (f & IFF_PROMISC);
+					/* FIXME: other flag changes are ignored/unimplemented */
+			} else {
+				if ( f & IFF_RUNNING ) {
+					mveth_stop(sc);
+					ifp->if_flags  &= ~(IFF_RUNNING | IFF_OACTIVE);
+			sc->bsd.oif_flags = ifp->if_flags;
+		break;
+			error = BSP_mve_media_ioctl(&sc->pvt, cmd, &ifr->ifr_media);
+		break;
+		case SIOCADDMULTI:
+		case SIOCDELMULTI:
+			error = (cmd == SIOCADDMULTI)
+		    		? ether_addmulti(ifr, &sc->arpcom)
+				    : ether_delmulti(ifr, &sc->arpcom);
+			if (error == ENETRESET) {
+				if (ifp->if_flags & IFF_RUNNING) {
+				error = 0;
+		break;
+		break;
+ 		case SIO_RTEMS_SHOW_STATS:
+			dump_update_stats(&sc->pvt, stdout);
+		break;
+		default:
+			error = ether_ioctl(ifp, cmd, data);
+		break;
+	return error;
+/* DRIVER TASK */
+/* Daemon task does all the 'interrupt' work */
+static void mveth_daemon(void *arg)
+struct mveth_softc	*sc;
+struct ifnet		*ifp;
+rtems_event_set		evs;
+	for (;;) {
+		rtems_bsdnet_event_receive( 7, RTEMS_WAIT | RTEMS_EVENT_ANY, RTEMS_NO_TIMEOUT, &evs );
+		evs &= 7;
+		for ( sc = theMvEths; evs; evs>>=1, sc++ ) {
+			if ( (evs & 1) ) {
+				register uint32_t x;
+				ifp = &sc->arpcom.ac_if;
+				if ( !(ifp->if_flags & IFF_UP) ) {
+					mveth_stop(sc);
+					ifp->if_flags &= ~(IFF_UP|IFF_RUNNING);
+					continue;
+				if ( !(ifp->if_flags & IFF_RUNNING) ) {
+					/* event could have been pending at the time hw was stopped;
+					 * just ignore...
+					continue;
+				x = mveth_ack_irqs(&sc->pvt, -1);
+				if ( MV643XX_ETH_EXT_IRQ_LINK_CHG & x ) {
+					/* phy status changed */
+					int media;
+					if ( 0 == BSP_mve_ack_link_chg(&sc->pvt, &media) ) {
+							mveth_start(ifp);
+						} else {
+							/* stop sending */
+				/* free tx chain */
+				if ( (MV643XX_ETH_EXT_IRQ_TX_DONE & x) && BSP_mve_swipe_tx(&sc->pvt) ) {
+					if ( TX_AVAILABLE_RING_SIZE(&sc->pvt) == sc->pvt.avail )
+						ifp->if_timer = 0;
+					mveth_start(ifp);
+				if ( (MV643XX_ETH_IRQ_RX_DONE & x) )
+					BSP_mve_swipe_rx(&sc->pvt);
+				mveth_enable_irqs(&sc->pvt, -1);
+static int mveth_detach(struct mveth_softc *sc);
+#endif
+/* PUBLIC RTEMS BSDNET ATTACH FUNCTION */
+int
+rtems_mve_attach(struct rtems_bsdnet_ifconfig *ifcfg, int attaching)
+char				*unitName;
+int					unit,i,cfgUnits;
+struct	ifnet		*ifp;
+	unit = rtems_bsdnet_parse_driver_name(ifcfg, &unitName);
+		return 1;
+	sc  = &theMvEths[unit-1];
+	sc->pvt.port_num = unit-1;
+	sc->pvt.phy      = (MV_READ(MV643XX_ETH_PHY_ADDR_R) >> (5*sc->pvt.port_num)) & 0x1f;
+	if ( attaching ) {
+			return -1;
+		for ( i=cfgUnits = 0; i<MV643XXETH_NUM_DRIVER_SLOTS; i++ ) {
+			if ( theMvEths[i].arpcom.ac_if.if_init )
+				cfgUnits++;
+		cfgUnits++; /* this new one */
+		/* lazy init of TID should still be thread-safe because we are protected
+		 * by the global networking semaphore..
+		if ( !mveth_tid ) {
+			/* newproc uses the 1st 4 chars of name string to build an rtems name */
+			mveth_tid = rtems_bsdnet_newproc("MVEd", 4096, mveth_daemon, 0);
+		if ( !BSP_mve_setup( unit,
+						     mveth_tid,
+						     release_tx_mbuf, ifp,
+						     alloc_mbuf_rx,
+						     consume_rx_mbuf, ifp,
+						     ifcfg->rbuf_count,
+						     ifcfg->xbuf_count,
+			                 BSP_MVE_IRQ_TX | BSP_MVE_IRQ_RX | BSP_MVE_IRQ_LINK) ) {
+			return -1;
+		if ( nmbclusters < sc->pvt.rbuf_count * cfgUnits + 60 /* arbitrary */ )  {
+			printk(DRVNAME"%i: (mv643xx ethernet) Your application has not enough mbuf clusters\n", unit);
+			printk(     "                         configured for this driver.\n");
+			return -1;
+		if ( ifcfg->hardware_address ) {
+			memcpy(sc->arpcom.ac_enaddr, ifcfg->hardware_address, ETHER_ADDR_LEN);
+		} else {
+			/* read back from hardware assuming that MotLoad already had set it up */
+			BSP_mve_read_eaddr(&sc->pvt, sc->arpcom.ac_enaddr);
+		ifp->if_softc			= sc;
+		ifp->if_unit			= unit;
+		ifp->if_name			= unitName;
+		ifp->if_mtu				= ifcfg->mtu ? ifcfg->mtu : ETHERMTU;
+		ifp->if_init			= mveth_init;
+		ifp->if_ioctl			= mveth_ioctl;
+		ifp->if_start			= mveth_start;
+		ifp->if_output			= ether_output;
+		 * While nonzero, the 'if->if_timer' is decremented
+		 * (by the networking code) at a rate of IFNET_SLOWHZ (1hz) and 'if_watchdog'
+		 * is called when it expires.
+		 * If either of those fields is 0 the feature is disabled.
+		ifp->if_watchdog		= mveth_watchdog;
+		sc->bsd.oif_flags		= /* ... */
+		ifp->if_flags			= IFF_BROADCAST | IFF_MULTICAST | IFF_SIMPLEX;
+		 * if unset, this set to 10Mbps by ether_ifattach; seems to be unused by bsdnet stack;
+		 * could be updated along with phy speed, though...
+		ifp->if_baudrate		= 10000000;
+		/* NOTE: ether_output drops packets if ifq_len >= ifq_maxlen
+		 *       but this is the packet count, not the fragment count!
+		ifp->if_snd.ifq_maxlen	= sc->pvt.xbuf_count;
+		ifp->if_snd.ifq_maxlen	= ifqmaxlen;
+		if ( !ifp->if_addrlist ) /* do only the first time [reattach hack] */
+#endif
+			if_attach(ifp);
+			ether_ifattach(ifp);
+	} else {
+		if ( !ifp->if_init ) {
+			printk(DRVNAME": instance %i not attached.\n", unit);
+			return -1;
+		return mveth_detach(sc);
+#else
+		printk(DRVNAME": interface detaching not implemented\n");
+		return -1;
+#endif
+	return 0;
+/* EARLY PHY ACCESS */
+static int
+mveth_early_init(int idx)
+	if ( idx < 0 || idx >= MV643XXETH_NUM_DRIVER_SLOTS )
+		return -1;
+	/* determine the phy */
+	theMvEths[idx].pvt.phy = (MV_READ(MV643XX_ETH_PHY_ADDR_R) >> (5*idx)) & 0x1f;
+	return 0;
+static int
+mveth_early_read_phy(int idx, unsigned reg)
+int rval;
+		return -1;
+	rval = mveth_mii_read(&theMvEths[idx].pvt, reg);
+	return rval < 0 ? rval : rval & 0xffff;
+static int
+mveth_early_write_phy(int idx, unsigned reg, unsigned val)
+		return -1;
+	mveth_mii_write(&theMvEths[idx].pvt, reg, val);
+	return 0;
+rtems_bsdnet_early_link_check_ops
+rtems_mve_early_link_check_ops = {
+	init:		mveth_early_init,
+	read_phy:	mveth_early_read_phy,
+	write_phy:	mveth_early_write_phy,
+	name:		DRVNAME,
+	num_slots:	MAX_NUM_SLOTS
+/* DEBUGGING */
+#ifdef MVETH_DEBUG
+/* Display/dump descriptor rings */
+int
+mveth_dring(struct mveth_softc *sc)
+int i;
+if (1) {
+MvEthRxDesc pr;
+printf("RX:\n");
+	for (i=0, pr=sc->pvt.rx_ring; i<sc->pvt.rbuf_count; i++, pr++) {
+		/* can't just invalidate the descriptor - if it contains
+		 * data that hasn't been flushed yet, we create an inconsistency...
+		rtems_bsdnet_semaphore_obtain();
+		INVAL_DESC(pr);
+#endif
+		printf("cnt: 0x%04x, size: 0x%04x, stat: 0x%08x, next: 0x%08x, buf: 0x%08x\n",
+			pr->byte_cnt, pr->buf_size, pr->cmd_sts, (uint32_t)pr->next_desc_ptr, pr->buf_ptr);
+		rtems_bsdnet_semaphore_release();
+#endif
+if (1) {
+MvEthTxDesc pt;
+printf("TX:\n");
+	for (i=0, pt=sc->pvt.tx_ring; i<sc->pvt.xbuf_count; i++, pt++) {
+		INVAL_DESC(pt);
+#endif
+		printf("cnt: 0x%04x, stat: 0x%08x, next: 0x%08x, buf: 0x%08x, mb: 0x%08x\n",
+			pt->byte_cnt, pt->cmd_sts, (uint32_t)pt->next_desc_ptr, pt->buf_ptr,
+			(uint32_t)pt->mb);
+#endif
+	return 0;
+#endif
+/* DETACH HACK DETAILS */
+int
+_cexpModuleFinalize(void *mh)
+int i;
+	for ( i=0; i<MV643XXETH_NUM_DRIVER_SLOTS; i++ ) {
+		if ( theMvEths[i].arpcom.ac_if.if_init ) {
+			printf("Interface %i still attached; refuse to unload\n", i+1);
+			return -1;
+	/* delete task; since there are no attached interfaces, it should block
+	 * for events and hence not hold the semaphore or other resources...
+	rtems_task_delete(mveth_tid);
+	return 0;
+/* ugly hack to allow unloading/reloading the driver core.
+ * needed because rtems' bsdnet release doesn't implement
+ * if_detach(). Therefore, we bring the interface down but
+ * keep the device record alive...
+static void
+ether_ifdetach_pvt(struct ifnet *ifp)
+        ifp->if_flags = 0;
+        ifp->if_ioctl = 0;
+        ifp->if_start = 0;
+        ifp->if_watchdog = 0;
+        ifp->if_init  = 0;
+static int
+mveth_detach(struct mveth_softc *sc)
+		if ( ifp->if_flags & (IFF_UP | IFF_RUNNING) ) {
+			printf(DRVNAME"%i: refuse to detach; interface still up\n",sc->pvt.port_num+1);
+			return -1;
+		mveth_stop(sc);
+/* not implemented in BSDnet/RTEMS (yet) but declared in header */
+#define ether_ifdetach ether_ifdetach_pvt
+		ether_ifdetach(ifp);
+	free( (void*)sc->pvt.ring_area, M_DEVBUF );
+	sc->pvt.ring_area = 0;
+	sc->pvt.tx_ring   = 0;
+	sc->pvt.rx_ring   = 0;
+	sc->pvt.d_tx_t    = sc->pvt.d_tx_h   = 0;
+	sc->pvt.d_rx_t    = 0;
+	sc->pvt.avail     = 0;
+	/* may fail if ISR was not installed yet */
+	BSP_remove_rtems_irq_handler( &irq_data[sc->pvt.port_num] );
+	return 0;
+#ifdef MVETH_DEBUG
+struct rtems_bsdnet_ifconfig mveth_dbg_config = {
+	name:				DRVNAME"1",
+	attach:				rtems_mve_attach,
+	ip_address:			"192.168.2.10",		/* not used by rtems_bsdnet_attach */
+	ip_netmask:			"255.255.255.0",	/* not used by rtems_bsdnet_attach */
+	hardware_address:	0, /* (void *) */
+	ignore_broadcast:	0,					/* TODO driver should honour this  */
+	mtu:				0,
+	rbuf_count:			0,					/* TODO driver should honour this  */
+	xbuf_count:			0,					/* TODO driver should honour this  */
+#endif
+#endif
2.39.3
