Building leon3 prom image for testing on renode
Muhammad Sulthan Mazaya msulthanmazaya at gmail.com
Wed Jul 19 00:34:53 UTC 2023
Hi Alan,
> Also, as you mentioned, the renode Zephyr example runs directly from RAM
without a prom image. Is it that the RTEMS LEON3 BSP relies on
initialization done by the boot prom (GRMON or MKPROM2 based boot code)?
Do you or anyone on the devel mailing list know where/how can I check which
kind of initialization rtems leon3 bsp rely on? Sorry, I am fairly new to
this
Thank you,
Mazaya
On Tue, Jul 18, 2023 at 11:27 PM Alan Cudmore <alan.cudmore at gmail.com>
wrote:
> Hi Mazaya,
> I wonder if it is possible to initialize the processor to the state where
> it can run the RTEMS image in RAM without using the prom image? The
> processor initialization would have to go in the resc script before the
> image is loaded and started.
> https://github.com/renode/renode/blob/master/scripts/single-node/leon3_zephyr.resc
> I guess it ends up being a trade off of tooling vs. trying to program the
> necessary initialization in the resc script.
> Regards,
> Alan
> On Tue, Jul 18, 2023 at 2:46 AM Muhammad Sulthan Mazaya <
> msulthanmazaya at gmail.com> wrote:
>> Hi,
>> I was trying to implement renode for testing leon3 using rtems-test. I
>> noticed that from the example they provide
>> https://github.com/antmicro/renode-rtems-leon3/blob/main/leon3_rtems.resc,
>> it seems like the renode simulator needs the prom image of leon3 to do so.
>> I don't think an additional build step before testing a particular bsp is
>> something supported by the build config of rtems-tools + my mentors also
>> said it shouldn't be on the rtems-tools. Is it okay to have RSB build that
>> for us as part of the BSP?
>> Thank you,
>> Mazaya
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230719/5e19d2a2/attachment.htm>
