Repository edit
Wed Jul 19 02:30:39 UTC 2023
I had a local copy of the two commits that were dropped during the
rewinding. I have pushed them back. We are back to the state prior to
the accidental push. Hashes all look good. Thanks for handling this.
Gedare
On Tue, Jul 18, 2023 at 7:55 PM Amar Takhar <amar at rtems.org> wrote:
> There was a mistaken push to the RTEMS main repository earlier.  These things
> happen so we have rewound the repository back to the latest safe commit.
> This is 1425735.
> If anyone did checkout the repository afterwards they will get an error when
> trying to update as the repository has been rewound.  You can solve this by
> doing a fresh clone -- something I always recommend
> Alternatively you can reset your own repository by doing
>   git reset --hard 1425735
> While on the master branch -- please keep in mind this will blow away any
> changes you have in your source tree.
> Sebastian, I noticed you had two commits pushed after these will need to be
> re-applied as rewinding back is the safest and best way to handle this.
> Amar.
> devel mailing list
> devel at rtems.org
