[PATCH rtems v2] Add the Regulator Interface and test
Wed Jul 19 15:33:09 UTC 2023
Comments are interspersed but I am starting another thread for discussion
of delete.
Your comments made me realize something we both missed and it will take a
bit to address it.
On Tue, Jul 18, 2023 at 9:32 PM Chris Johns <chrisj at rtems.org> wrote:
> On 15/7/2023 9:48 am, Joel Sherrill wrote:
> > Updates #4924.
> > The Regulator is an application support class which is used to
> > deal with the scenario where there is a bursty input source
> > which needs to be metered out to a destination sink. The maximum
> > size of bursts needs to be known and the delivery method must
> > be configured to deliver messages at a rate that allows the
> > traffic to not overflow.
> >  cpukit/include/rtems/regulator.h              |  439 ++++++
> >  cpukit/include/rtems/regulatorimpl.h          |  103 ++
> >  cpukit/libmisc/regulator/regulator.c          |  522 ++++++++
> >  spec/build/cpukit/librtemscpu.yml             |    2 +
> >  spec/build/cpukit/objregulator.yml            |   18 +
> >  spec/build/testsuites/libtests/grp.yml        |    2 +
> >  .../build/testsuites/libtests/regulator01.yml |   21 +
> >  testsuites/libtests/regulator01/regulator01.c | 1192 +++++++++++++++++
> >  .../libtests/regulator01/regulator01.doc      |   68 +
> >  .../libtests/regulator01/rtems_config.c       |   59 +
> >  10 files changed, 2426 insertions(+)
> >  create mode 100644 cpukit/include/rtems/regulator.h
> >  create mode 100644 cpukit/include/rtems/regulatorimpl.h
> >  create mode 100644 cpukit/libmisc/regulator/regulator.c
> >  create mode 100644 spec/build/cpukit/objregulator.yml
> >  create mode 100644 spec/build/testsuites/libtests/regulator01.yml
> >  create mode 100644 testsuites/libtests/regulator01/regulator01.c
> >  create mode 100644 testsuites/libtests/regulator01/regulator01.doc
> >  create mode 100644 testsuites/libtests/regulator01/rtems_config.c
> > diff --git a/cpukit/include/rtems/regulator.h
> b/cpukit/include/rtems/regulator.h
> > new file mode 100644
> > index 0000000000..74f0d00f2e
> > --- /dev/null
> > +++ b/cpukit/include/rtems/regulator.h
> > @@ -0,0 +1,439 @@
> > +/* SPDX-License-Identifier: BSD-2-Clause */
> > + * @defgroup RegulatorAPI Regulator API
> > + * @brief Regulator APIs
> > + * The Regulator provides a set of APIs to manage input sources which
> > + * produces bursts of message traffic.
> > + * @mainpage
> > + * The regulator is designed to sit logically between two entities -- a
> > + * source and a sink/destination, where it limits the traffic sent to
> the
> > + * destination to prevent it from being flooded with messages from the
> > + * source. This can be used to accommodate bursts of input from a source
> > + * and meter it out to a destination.  The maximum number of messages
> > + * which can be buffered in the regulator is specified by the
> > + * @a maximum_messages field in the @a rtems_regulator_attributes
> > + * structure passed as an argument to @a rtems_regulator_create().
> > + * The regulator library accepts an input stream of messages from a
> > + * source and delivers them to a destination. The regulator assumes
> that the
> > + * input stream from the source contains sporadic bursts of data which
> can
> > + * exceed the acceptable rate of the destination. By limiting the
> message rate,
> > + * the regulator prevents an overflow of messages.
> > + * The regulator can be configured for the input buffering required to
> manage
> > + * the maximum burst and for the metering rate for the output. The
> output rate
> > + * is in messages per second. If the sender produces data too fast, the
> > + * regulator will buffer the configured number of messages.
> > + * A configuration capability is provided to allow for adaptation to
> different
> > + * message streams. The regulator can also support running multiple
> instances,
> > + * which could be used on independent message streams.
> > + * The regulator provides a simple interface to the application for
> avoiding
> > + * bursts of input from a fast source overflowing a slower output sink.
> > + * It is assumed that the application has a design limit on the number
> of
> > + * messages which may be buffered. All messages accepted by the
> regulator,
> > + * assuming no overflow on input, will eventually be output by the
> delivery
> > + * thread.
> > + * A regulator instance is used as follows:
> > + * @code
> > + *   while (1)
> > + *     use rtems_regulator_obtain_buffer to obtain a buffer
> > + *     input operation to fetch data into the buffer
> > + *     rtems_regulator_send(buffer, size of message)
> > + *       // rtems_regulator_send() will release the buffer
> automatically when done
> OK however ...
Comment is out of date with the addition of the delivery function returning
a bool.
I noticed a few other places like this while starting the chapter for the
manual.
Fixed.
> > + * @endcode
> > + * The sequence diagram below shows the interaction between a message
> Source,
> > + * a Regulator instance, and RTEMS, given the usage described in the
> above
> > + * paragraphs.
> > + * \startuml "Regulator Application Input Source Usage"
> > + *   Source -> Regulator : rtems_regulator_obtain_buffer(regulator,
> buffer)
> > + *   Regulator -> RTEMS : rtems_partition_get_buffer(id, buffer)
> > + *   RTEMS --> Regulator : rtems_status_code
> > + *   Regulator --> Source : rtems_status_code
> > + *   Source -> Regulator : rtems_regulator_send(regulator, message,
> length)
> > + *   Regulator -> RTEMS : rtems_message_queue_send(id, message, size)
> > + * \enduml
> > + * As illustrated in the sequence diagram, the Source usually
> corresponds
> > + * to application software reading a system input. The Source obtains a
> > + * buffer from the Regulator instance and fills it with incoming data.
> > + * The application explicitly obtaining a buffer and filling it in
> allows
> > + * for zero copy operations on the Source side.
> > + * The Source then sends the buffer to the Regulator instance. The
> Regulator
> > + * the sends the buffer via a message queue which to the Delivery
> thread.
> > + * The Delivery thread executes periodically at a rate specified at
> > + * Regulation creation. At each period, the Delivery thread attempts to
> > + * receive up to a configured number of buffers and invoke the Delivery
> > + * function to deliver them to the Sink.
> > + * The Delivery function is provided by the application for this
> specific
> > + * Regulator instance. Depending on the Sink, it may use a method which
> > + * copies the buffer contents (e.g., write()) or which operates directly
> > + * on the buffer contents (e.g. DMA from buffer). In the case of a
> > + * Sink which copies the buffer contents, the buffer can be released
> > + * via @a rtems_regulator_release_buffer() as soon as the method or
> copying
> > + * completes. In the case where the delivery uses the buffer and
> returns,
> > + * the call to @a rtems_regulator_release_buffer() will occur when the
> > + * use of the buffer is complete (e.g. completion of DMA transfer).
> > + * This explicit and deliverate exposure of buffering provides the
> > + * application with the ability to avoid copying the contents.
> > + * After the Source has sent the message to the Regulator instance,
> > + * the Source is free to process another input and the Regulator
> > + * instance will ensure that the buffer is delivered to the Delivery
> > + * function and Sink.
> > + * The Regulator implementation uses the RTEMS Classic API Partition
> Manager
> > + * to manage the buffer pool and the RTEMS Classic API Message Queue
> > + * Manager to send the buffer to the Delivery thread.
> > + * Destination by the internal Delivery thread.
> > + * @addtogroup RegulatorAPI
> > + * @file
> > + * @brief This header file defines the Regulator API.
> > + * Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
> > + * Redistribution and use in source and binary forms, with or without
> > + * modification, are permitted provided that the following conditions
> > + * are met:
> > + * 1. Redistributions of source code must retain the above copyright
> > + *    notice, this list of conditions and the following disclaimer.
> > + * 2. Redistributions in binary form must reproduce the above copyright
> > + *    notice, this list of conditions and the following disclaimer in
> the
> > + *    documentation and/or other materials provided with the
> distribution.
> > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
> TO, THE
> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
> CONTRIBUTORS BE
> > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
> IN
> > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> OTHERWISE)
> > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
> OF THE
> > + * POSSIBILITY OF SUCH DAMAGE.
> > +#ifndef REGULATOR_H
> > +#define REGULATOR_H
> > +#include <stdlib.h>
> > +#include <rtems.h>
> > + * @ingroup RegulatorAPI
> > + * @brief Regulator Delivery Function Type
> > + * The user provides a function which is invoked to deliver a message
> > + * to the output. It is invoked by the output thread created as part
> > + * of @a rtems_regulator_create(). The priority and stack size of the
> > + * output thread are specified in the regulator attribute set.
> > + * It takes three parameters:
> > + * @param[in] context is an untyped pointer to a user context
> > + * @param[in] message points to the message
> > + * @param[in] length is the message size
> > + * The following is an example deliverer function. It assumes that the
> > + * application has defined the my_context_t structure and it has at
> least
> > + * the socket field. The @a message passed in originated with an
> > + * application source which obtained the @a message buffer using
> > + * @a rtems_regulator_obtain_buffer(), filled it in with source data,
> > + * and used @a rtems_regulator_send() to hand to the regulator instance
> > + * for later delivery.
> > + * @code
> > + *   bool my_deliverer(
> > + *     void     *context,
> > + *     void     *message,
> > + *     size_t    length
> > + *       my_context_t *my_context;
> > + *       my_context = (my_context_t *)context;
> > + *       write(my_context->socket, message, length);
> > + *       rtems_regulator_release_buffer(message);
> ... you have this?
 Note that just below this, it says return false to indicate that it
released the buffer. Returning true tells the delivery thread to
do it.
> Chris
> > + *       // return false to indicate we released the buffer
> > + *       return false;
> > + * @endcode
> > + * The delivery function returns true to indicate that the delivery
> thread
> > + * should release the buffer or false to indicate that it released the
> buffer.
> > + * If the delivery function invokes a method like @a write() to deliver
> the
> > + * message to the sink, then the buffer can be released immediately
> after the
> > + * call. If the delivery method does something like setting up a DMA
> transfer
> > + * of the buffer, it cannot be released until after the DMA is complete.
> > + * The following sequence diagram shows the behavior of the Delivery
> thread
> > + * body and its interaction with the user-supplied deliverer() function.
> > + * \startuml "Regulator Delivery Thread Body"
> > + *   loop while (1)
> > + *     "Delivery Thread" -> RTEMS : rtems_rate_monotonic_period(id,
> output_thread_period)
> > + *     loop for 0 : maximum_to_dequeue_per_period
> > + *       "Delivery Thread" -> RTEMS : rtems_message_queue_receive(id,
> message, size, wait, 0)
> > + *       RTEMS --> "Delivery Thread" : rtems_status_code
> > + *       group if [rtems_status_code != RTEMS_SUCCESSFUL]
> > + *         RTEMS -> "Delivery Thread" : break
> > + *       end
> > + *       "Delivery Thread" -> Application : deliverer(context, buffer,
> length)
> > + *       "Delivery Thread" -> RTEMS : rtems_partition_return_buffer(id,
> buffer)
> > + *     end
> > + *   end
> > + * \enduml
> > + * In the above sequence diagram, the key points are:
> > + *   -# The Delivery Thread Body is periodically executed.
> > + *   -# During each period, up to the instance configuration parameter
> > + *      @a maximum_to_dequeue_per_period may be dequeued and
> > + *      passed the application's delivery function for processing.
> > + * Note that the application explicitly obtains buffers from the
> > + * regulator instance but that the release may be done by Delivery
> > + * Thread, the Delivery function, or later when the buffer contents
> > + * are transferred.
> > +typedef bool (*rtems_regulator_deliverer)(
> > +  void     *context,
> > +  void     *message,
> > +  size_t    length
> > + * @brief Attributes for Regulator Instance
> > + * An instance of this structure must be populated by the application
> > + * before creating an instance of the regulator. These settings tailor
> > + * the behavior of the regulator instance.
> > +typedef struct {
> > +  /** Application method to invoke to output a message to the
> destination*/
> > +  rtems_regulator_deliverer deliverer;
> > +  /** Context pointer to pass to deliver method */
> > +  void  *deliverer_context;
> > +  /** Maximum size message to process */
> > +  size_t  maximum_message_size;
> > +  /** Maximum number of messages to be able to buffer */
> > +  size_t  maximum_messages;
> > +  /** Priority of output thread */
> > +  rtems_task_priority output_thread_priority;
> > +  /** Stack size of output thread */
> > +  size_t output_thread_stack_size;
> > +  /** Period (in ticks) of output thread */
> > +  rtems_interval output_thread_period;
> > +  /** Maximum messages to dequeue per period */
> > +  size_t  maximum_to_dequeue_per_period;
> > +} rtems_regulator_attributes;
> > + * @brief Regulator Instance
> > +typedef void *rtems_regulator_instance;
> > + * @brief Create a regulator
> > + * This function creates an instance of a regulator. It uses the
> provided
> > + * @a attributes to create the instance return in @a regulator. This
> instance
> > + * will allocate the buffers associated with the regulator instance as
> well
> > + * as the Output Thread.
> > + * The @a attributes structure defines the priority and stack size of
> > + * the output thread dedicated to this regulator instance. It also
> > + * defines the period of the output thread and the maximum number of
> > + * messages that may be delivered per period via invocation of the
> > + * delivery function.
> > + * Each regulator instance will allocate the following resources:
> > + * - A memory area for the regulator control block using @a malloc()
> > + * - A RTEMS Classic API Message Queue is constructed with message
> > + *   buffer memory allocated using @a malloc().  Each message consists
> > + *   of a pointer and a size_t value.
> > + * - A RTEMS Classic API Partition.
> > + * - A RTEMS Classic API Rate Monotonic Period.
> > + * @param[in] attributes specify the regulator instance attributes
> > + * @param[inout] regulator will point to the regulator instance
> > + * @return an RTEMS status code indicating success or failure.
> > + * @note This method allocates memory for the buffers holding messages,
> > + *       an output thread and an RTEMS partition. When it executes, the
> > + *       output thread will create an RTEMS rate monotonic period.
> > +rtems_status_code rtems_regulator_create(
> > +  rtems_regulator_attributes  *attributes,
> > +  rtems_regulator_instance   **regulator
> > + * @brief Delete a regulator
> > + * This method is used to delete an instance of a @a regulator.
> > + * It is the responsibility of the user to ensure that any resources
> > + * such as sockets or open file descriptors used by the delivery
> > + * function are also deleted. It is likely safer to delete those
> > + * delivery resources before deleting the regulator instance.
> > + * @param[in] regulator is the instance to delete
> > + * @note This method deallocates the resources allocated during
> > + *       rtems_regulator_create().
> > +rtems_status_code rtems_regulator_delete(
> > +  rtems_regulator_instance    *regulator
> > + * @brief Obtain Buffer from Regulator
> > + * This method is used to obtain a buffer from the regulator's pool. The
> > + * @a buffer returned is assumed to be filled in with contents and used
> > + * in a subsequent call to @a rtems_regulator_send(). When the @a
> buffer is
> > + * delivered, it will be automatically released. If the @a buffer is
> not sent,
> > + * then it should be returned using @a rtems_regulator_release_buffer().
> > + * The buffer is of the maximum_message_size specified in the attributes
> > + * passed in to @a rtems_regulator_create().
> > + * @param[in] regulator is the regulator instance to operate upon
> > + * @param[out] buffer will point to the allocated buffer
> > + * @note This method does not perform dynamic allocation. It obtains a
> > + *       buffer from the pool allocated during @a
> > + * @note Any attempt to write outside the buffer area is undefined.
> > +rtems_status_code rtems_regulator_obtain_buffer(
> > +  rtems_regulator_instance   *regulator,
> > +  void                      **buffer
> > + * @brief Release Previously Obtained Regulator Buffer
> > + * This method is used to release a buffer from the regulator's pool.
> It is
> > + * assumed that the @a buffer returned will not be used by the
> application
> > + * anymore. The @a buffer must have previously been allocated by
> > + * @a rtems_regulator_obtain_buffer() and NOT passed to
> > + * @a rtems_regulator_send().
> > + * If the @a rtems_regulator_send() is successful, the buffer will
> eventually
> > + * be processed by the delivery thread and automatically released.
> > + * The status @a RTEMS_TOO_MANY is returned if the regulator's
> > + * internal queue is full. This indicates that the configured
> > + * maximum number of messages was insufficient. It is the
> > + * responsibility of the caller to decide whether to hold messages,
> > + * drop them, or print a message that the maximum number of messages
> > + * should be increased
> > + * @param[out] buffer will point to the buffer to release
> > + * @note This method does not perform dynamic deallocation. It releases
> a
> > + *       buffer to the pool allocated during @a
> > +rtems_status_code rtems_regulator_release_buffer(
> > +  void                       *buffer
> > + * @brief Send to regulator instance
> > + * This method is used by the producer to send a @a message to the
> > + * @a regulator for later delivery by the output thread. The message is
> > + * contained in the memory pointed to by @a message and is @a length
> > + * bytes in length.
> > + * It is required that the @a message buffer was obtained via
> > + * @a rtems_regulator_obtain_buffer().
> > + * It is assumed that the @a message buffer has been filled in with
> > + * application content to deliver
> > + * If the @a rtems_regulator_send() is successful, the buffer is
> enqueued
> > + * inside the regulator instance for subsequent delivery. After the
> > + * @a message is delivered, the buffer is automatically freed.
> > + * If @a rtems_regulator_send() is unsuccessful, it is the application's
> > + * responsibility to * release the buffer.
> > + * @param[out] message points to the message to deliver
> > + * @param[out] length is the size of the message in bytes
> > +rtems_status_code rtems_regulator_send(
> > +  void                      *message,
> > +  size_t                     length
> > +#endif /* REGULATOR_H */
> > diff --git a/cpukit/include/rtems/regulatorimpl.h
> b/cpukit/include/rtems/regulatorimpl.h
> > index 0000000000..f46f942d69
> > --- /dev/null
> > +++ b/cpukit/include/rtems/regulatorimpl.h
> > @@ -0,0 +1,103 @@
> > + * @defgroup RegulatorInternalAPI Regulator API Internals
> > + * @brief Regulator Internal Information
> > + * This concerns implementation information about the Regulator.
> > + * @ingroup RegulatorInternalAPI
> > + * @file
> > + * @brief Regulator Library Implementation Support
> > + * are met:
> the
> distribution.
> "AS IS"
> TO, THE
> PURPOSE
> CONTRIBUTORS BE
> BUSINESS
> IN
> OTHERWISE)
> OF THE
> > +#ifndef RTEMS_REGULATORIMPL_H
> > +#define RTEMS_REGULATORIMPL_H
> > +#include <rtems/chain.h>
> > + * This constant is used to indicate the regulator instance is
> initialized.
> > +#define REGULATOR_INITIALIZED 0xDeadF00d
> > + * @brief Regulator Message Instance Management Structure
> > +typedef struct {
> > +  /** This points to the message contents. */
> > +  void   *buffer;
> > +  /** This is the length of the message. */
> > +  size_t  length;
> > +} _Regulator_Message_t;
> > + * @brief Regulator Instance Private Structure
> > + * An instance of this structure is allocated per regulator instance.
> > +typedef struct {
> > +  /** Has magic value when instance is usable */
> > +  uint32_t   initialized;
> > +  /** Attributes for this instance -- copied from user */
> > +  rtems_regulator_attributes  Attributes;
> > +  /** Pointer to allocated message memory */
> > +  void *message_memory;
> > +  /** Pointer to allocated memory for RTEMS Message Queue for pending
> buffers*/
> > +  void *message_queue_storage;
> > +  /** RTEMS Message Queue of pending outgoing messages */
> > +  rtems_id  queue_id;
> > +  /** RTEMS Partition for pool of unused messages */
> > +  rtems_id  messages_partition_id;
> > +  /** RTEMS Task for performing output */
> > +  rtems_id  output_thread_id;
> > +  /** Id of period used by output thread */
> > +  rtems_id  output_thread_period_id;
> > +} _Regulator_Control;
> > +#endif /* RTEMS_REGULATORIMPL_H */
> > diff --git a/cpukit/libmisc/regulator/regulator.c
> b/cpukit/libmisc/regulator/regulator.c
> > index 0000000000..5460590007
> > --- /dev/null
> > +++ b/cpukit/libmisc/regulator/regulator.c
> > @@ -0,0 +1,522 @@
> > + * @file
> > + * are met:
> the
> distribution.
> "AS IS"
> TO, THE
> PURPOSE
> CONTRIBUTORS BE
> BUSINESS
> IN
> OTHERWISE)
> OF THE
> > +#include <rtems.h>
> > +#include <rtems/regulator.h>
> > +#include <rtems/regulatorimpl.h>
> > + * This method is the body for the task which delivers the output for
> > + * this regulator instance at the configured rate.
> > + * @param[in] arg points to the regulator instance this thread
> > + *                is associated with
> > +static rtems_task _Regulator_Output_task_body(
> > +  rtems_task_argument arg
> > +  _Regulator_Control   *the_regulator;
> > +  rtems_status_code     sc;
> > +  size_t                to_dequeue;
> > +  _Regulator_Message_t  regulator_message;
> > +  size_t                regulator_message_size;
> > +  bool                  release_it;
> > +   * The argument passed in cannot be NULL if the regulator_create
> worked.
> > +  the_regulator = (_Regulator_Control *) arg;
> > +   * This thread uses a rate monotonic period object instance. A rate
> > +   * monotonic period object must be created by the thread using it.
> > +   * It can be deleted by any thread which simplifies clean up.
> > +   * The rate_monotonic_create() call can fail if the application
> > +   * is incorrectly configured. This thread has no way to report the
> > +   * failure. If it continues with an invalid id, then the thread will
> > +   * not block on the period and spin continuously consuming CPU. The
> only
> > +   * alternatives are to invoke rtems_fatal_error_occurred() or silently
> > +   * exit the thread.
> > +  sc = rtems_rate_monotonic_create(
> > +    rtems_build_name('P', 'E', 'R', 'D'),
> > +    &the_regulator->output_thread_period_id
> > +  if (sc != RTEMS_SUCCESSFUL) {
> > +    rtems_task_exit();
> > +   * Loop on the rate_monotonic_period() based on the specified period.
> > +  while (1) {
> > +    sc = rtems_rate_monotonic_period(
> > +      the_regulator->output_thread_period_id,
> > +      the_regulator->Attributes.output_thread_period
> > +     _Assert_Unused_variable_equals(sc, RTEMS_SUCCESSFUL);
> > +     * Loop for the configured number of messages to deliver per period.
> > +     * If we reach the point, there are no more messages, block for the
> > +     * rest of this period. If there are messages, deliver them.
> > +    for (to_dequeue = 0;
> > +         to_dequeue <
> the_regulator->Attributes.maximum_to_dequeue_per_period;
> > +         to_dequeue++) {
> > +      regulator_message_size = sizeof(_Regulator_Message_t);
> > +      sc = rtems_message_queue_receive(
> > +        the_regulator->queue_id,
> > +        &regulator_message,
> > +        &regulator_message_size,
> > +        RTEMS_NO_WAIT,
> > +        0
> > +        break;
> > +      release_it = the_regulator->Attributes.deliverer(
> Does this mean the releasing is optional?
Not as much optional as allows it to be deferred. If the delivery function
is setitng up a DMA transfer, it can set that up and return immediately.
When the transfer is complete, it can release the buffer.
This scenario is actually discussed in a comment a few lines below. :)
> > +        the_regulator->Attributes.deliverer_context,
> > +        regulator_message.buffer,
> > +        regulator_message.length
> > +       * The message was successfully delivered. If the delivery
> function
> > +       * wants the buffer returned, do it now. The delivery to the sink
> > +       * may involve handing the buffer off to something like DMA
> > +       * and need to wait for it to complete before releasing the
> buffer.
> > +       * Note that this is the underlying RTEMS service
> > +       * used by @a rtems_regulator_obtain_buffer() and @a
> > +       * rtems_regulator_release_buffer().
> > +      if (release_it == true) {
> > +        sc = rtems_partition_return_buffer(
> > +       the_regulator->messages_partition_id,
> > + * This method frees the resources associated with a regulator instance.
> > + * The resources are freed in the opposite of the order in which they
> are
> > + * allocated. This is used on error cases in @a
> rtems_regulator_create() and in
> > + * @a rtems_regulator_delete().
> > + * @param[in] the_regulator is the instance to operate upon
> > +static void _Regulator_Free_helper(
> > +  (void)
> rtems_rate_monotonic_delete(the_regulator->output_thread_period_id);
> > +  (void) rtems_task_delete(the_regulator->output_thread_id);
> > +   * The regulator's message_queue_storage is implicitly freed by this
> call.
> > +  (void) rtems_message_queue_delete(the_regulator->queue_id);
> I am not comfortable with these deletes. What happens if the delivery
> handler
> has been called and has not returned and it holds the allocator mutex, a
> networking mutex or some other resource?
> I think you need to ask the delivery thread to exit and you need to wait
> for it
> to finish.
Another thread for this one. One issue neither of us caught is that you
can't
delete a partition with buffers outstanding. In order to delete the
regulator,
you will have to coordinate it having all buffers released.  I have a
couple of
ideas on this and will start another thread.
> Chris
> > +  (void) rtems_partition_delete(the_regulator->messages_partition_id);
> > +  if (the_regulator->message_memory) {
> > +    free(the_regulator->message_memory);
> > +  the_regulator->initialized = 0;
> > +  free(the_regulator);
> > +  size_t             alloc_size;
> > +   * Perform basic validation of parameters
> > +  if (!attributes) {
> > +    return RTEMS_INVALID_ADDRESS;
> > +  if (!regulator) {
> > +   * Verify attributes are OK. Some are checked by calls to object
> create
> > +   * methods. Specifically the following are not checked:
> > +   * - output_thread_priority by rtems_task_create()
> > +   * - output_thread_stack_size can be any value
> > +  if (attributes->deliverer == NULL) {
> > +  if (attributes->maximum_messages == 0) {
> > +    return RTEMS_INVALID_NUMBER;
> > +  if (attributes->maximum_message_size == 0) {
> > +    return RTEMS_INVALID_SIZE;
> > +  if (attributes->maximum_to_dequeue_per_period == 0) {
> > +  if (attributes->output_thread_period == 0) {
> > +   * Allocate memory for regulator instance
> calloc(sizeof(_Regulator_Control), 1);
> > +  if (!the_regulator) {
> > +    return RTEMS_NO_MEMORY;
> > +   * We do NOT want the output_thread_id field to be initialized to 0.
> If the
> > +   * @a rtems_task_create() fails, then the field will not be
> overwritten.
> > +   * This results in an attempt to rtems_task_delete(0) during clean
> > +   * up. The thread ID of 0 is self which results in the calling thread
> > +   * accidentally deleting itself.
> > +  the_regulator->output_thread_id = (rtems_id) -1;
> > +   * Copy the attributes to an internal area for later use
> > +  the_regulator->Attributes = *attributes;
> > +   * Allocate memory for the messages. There is no need to zero out the
> > +   * message memory because the user should fill that in.
> > +  alloc_size = attributes->maximum_message_size *
> attributes->maximum_messages;
> > +  the_regulator->message_memory = calloc(alloc_size, 1);
> > +  if (!the_regulator->message_memory) {
> > +    _Regulator_Free_helper(the_regulator);
> > +   * Associate message memory with a partition so allocations are atomic
> > +  sc = rtems_partition_create(
> > +    rtems_build_name('P', 'O', 'O', 'L'),
> > +    the_regulator->message_memory,
> > +    alloc_size,
> > +    attributes->maximum_message_size,
> > +    RTEMS_DEFAULT_ATTRIBUTES,
> > +    &the_regulator->messages_partition_id
> > +    return sc;
> > +   * Create the message queue between the sender and output thread
> > +  RTEMS_MESSAGE_QUEUE_BUFFER(sizeof(_Regulator_Message_t))
> regulator_message_t;
> > +  size_t storage_size = sizeof(regulator_message_t) *
> > +  the_regulator->message_queue_storage = malloc(storage_size);
> > +  if (the_regulator->message_queue_storage == NULL) {
> > +  rtems_message_queue_config mq_config = {
> > +    .name = rtems_build_name('S', 'N', 'D', 'Q'),
> > +    .maximum_pending_messages =  attributes->maximum_messages,
> > +    .maximum_message_size = sizeof(_Regulator_Message_t),
> > +    .storage_area = the_regulator->message_queue_storage,
> > +    .storage_size = storage_size,
> > +    .storage_free = free,
> > +    .attributes = RTEMS_DEFAULT_ATTRIBUTES
> > +  sc = rtems_message_queue_construct(
> > +    &mq_config,
> > +    &the_regulator->queue_id
> > +    return sc;
> > +   * @note A rate monotonic period object must be created by the thread
> > +   *       using it. Thus that specific create operation is not included
> > +   *       in this method. All other resources are allocated here.
> > +   * Create the output thread Using the priority and stack size
> attributes
> > +   * specified by the user.
> > +  sc = rtems_task_create(
> > +    rtems_build_name('R', 'E', 'G', 'U'),
> > +    attributes->output_thread_priority,
> > +    attributes->output_thread_stack_size,
> > +    RTEMS_DEFAULT_MODES,
> > +    &the_regulator->output_thread_id
> > +    return sc;
> > +   * Start the output thread.
> > +   * @note There should be no way this call can fail. The task id is
> valid,
> > +   *       the regulator output thread entry point is valid, and the
> argument
> > +   *       is valid.
> > +  sc = rtems_task_start(
> > +    the_regulator->output_thread_id,
> > +    _Regulator_Output_task_body,
> > +    (rtems_task_argument) the_regulator
> > +   * The regulator is successfully initialized. Set the initialized
> field
> > +   * to reflect this and return the instance pointer.
> > +  the_regulator->initialized = REGULATOR_INITIALIZED;
> > +  *regulator = (void *)the_regulator;
> > +  return RTEMS_SUCCESSFUL;
> > +  the_regulator = (_Regulator_Control *) regulator;
> > +   * Validate the arguments and ensure the regulator was successfully
> > +   * initialized.
> > +  if (the_regulator->initialized != REGULATOR_INITIALIZED) {
> > +    return RTEMS_INCORRECT_STATE;
> > +   * Free the resources associated with this regulator instance.
> > + * Allocate a buffer for the caller using the internal partition.
> > +  void                       **buffer
> > +   * initialized.
> > +   * Allocate a buffer for the user application from the buffer pool
> managed
> > +   * by an Classic API partition.
> > +  sc = rtems_partition_get_buffer(
> > +    buffer
> > +  return sc;
> > +  void                      *buffer
> > +   * initialized.
> > +   * Deallocate the buffer to the buffer pool managed by a Classic
> > +   * API partition.
> > +    buffer
> > +  return sc;
> > +  void                     *message,
> > +  size_t                    length
> > +   * initialized.
> > +  if (!message) {
> > +  if (length == 0) {
> > +   * Place the message pointer and length into a temporary structure.
> This
> > +   * lets the implementation internally send the message by reference
> and
> > +   * have a zero-copy implementation.
> > +  regulator_message.buffer = message;
> > +  regulator_message.length = length;
> > +   * Send the application message to the output thread for delivery
> using
> > +   * a Classic API message queue.
> > +  sc = rtems_message_queue_send(
> > +    sizeof(_Regulator_Message_t)
> > +    return sc;
> > +  return sc;
> > diff --git a/spec/build/cpukit/librtemscpu.yml
> b/spec/build/cpukit/librtemscpu.yml
> > index 3654e7f94a..4074ca1fcb 100644
> > --- a/spec/build/cpukit/librtemscpu.yml
> > +++ b/spec/build/cpukit/librtemscpu.yml
> > @@ -514,6 +514,8 @@ links:
> >    uid: objmpci
> >  - role: build-dependency
> >    uid: objpci
> > +- role: build-dependency
> > +  uid: objregulator
> >    uid: objpsxsgnl
> > diff --git a/spec/build/cpukit/objregulator.yml
> b/spec/build/cpukit/objregulator.yml
> > index 0000000000..56d6154de9
> > --- /dev/null
> > +++ b/spec/build/cpukit/objregulator.yml
> > @@ -0,0 +1,18 @@
> > +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> > +build-type: objects
> > +cflags: []
> > +copyrights:
> > +- Copyright (C) 2023 OAR Corporatoin
> > +cppflags: []
> > +cxxflags: []
> > +enabled-by: true
> > +includes: []
> > +install:
> > +- destination: ${BSP_INCLUDEDIR}/rtems
> > +  source:
> > +  - cpukit/include/rtems/regulator.h
> > +  - cpukit/include/rtems/regulatorimpl.h
> > +links: []
> > +source:
> > +- cpukit/libmisc/regulator/regulator.c
> > +type: build
> > diff --git a/spec/build/testsuites/libtests/grp.yml
> b/spec/build/testsuites/libtests/grp.yml
> > index be340c8ab6..7ca0f7dfa1 100644
> > --- a/spec/build/testsuites/libtests/grp.yml
> > +++ b/spec/build/testsuites/libtests/grp.yml
> > @@ -230,6 +230,8 @@ links:
> >    uid: record01
> >    uid: record02
> > +  uid: regulator01
> >    uid: rtmonuse
> > diff --git a/spec/build/testsuites/libtests/regulator01.yml
> b/spec/build/testsuites/libtests/regulator01.yml
> > index 0000000000..776d0ae34b
> > --- /dev/null
> > +++ b/spec/build/testsuites/libtests/regulator01.yml
> > @@ -0,0 +1,21 @@
> > +build-type: test-program
> > +cflags: []
> > +copyrights:
> > +- Copyright (C) 2023 OAR Corporation
> > +cppflags: []
> > +cxxflags: []
> > +enabled-by: true
> > +features: c cprogram
> > +includes: []
> > +ldflags:
> > +- -Wl,--wrap=malloc
> > +links: []
> > +source:
> > +- testsuites/libtests/regulator01/regulator01.c
> > +- testsuites/libtests/regulator01/rtems_config.c
> > +stlib: []
> > +target: testsuites/libtests/regulator01.exe
> > +type: build
> > +use-after: []
> > +use-before: []
> > diff --git a/testsuites/libtests/regulator01/regulator01.c
> b/testsuites/libtests/regulator01/regulator01.c
> > index 0000000000..739af05fd6
> > --- /dev/null
> > +++ b/testsuites/libtests/regulator01/regulator01.c
> > @@ -0,0 +1,1192 @@
> > + * @defgroup RegulatorTests Regulator Test Cases
> > + * @brief Unit test cases for the Regulator
> > + * This is a set of unit test cases for the regulator.
> > + * @ingroup RegulatorTests
> > + * @file
> > + * @brief Test 01 for Regulator Library
> > + * are met:
> the
> distribution.
> "AS IS"
> TO, THE
> PURPOSE
> CONTRIBUTORS BE
> BUSINESS
> IN
> OTHERWISE)
> OF THE
> > +#include <stdio.h>
> > +#include <string.h>
> > +#include <unistd.h>
> > +#include <rtems.h>
> > +#include <rtems/test-info.h>
> > +#include <tmacros.h>
> > + * @brief Regulator Test Name
> > +const char rtems_test_name[] = "Regulator 1";
> > + * Prototypes for wrapped functions
> > +void *__wrap_malloc(size_t size);
> > +void *__real_malloc(size_t size);
> > + * @brief Calloc Wrapper Trigger Count
> > +static int malloc_trigger_count;
> > + * @brief Calloc Wrapper Call Count
> > +static int malloc_call_count;
> > + * @brief Calloc Wrapper Trigger enable
> > +static bool malloc_trigger_enabled;
> > + * @brief Enable Calloc Wrapper Trigger
> > +static void malloc_trigger_enable(
> > +  int trigger_count
> > +  malloc_trigger_enabled = true;
> > +  malloc_trigger_count = trigger_count;
> > +  malloc_call_count = 0;
> > + * @brief Reset Calloc Wrapper Trigger and Count
> > +static void malloc_trigger_reset(void)
> > +  malloc_trigger_enabled = 0;
> > +  malloc_trigger_count = 0;
> > + * @brief Calloc Wrapper to Trigger Allocation Errors
> > +  if (malloc_trigger_enabled) {
> > +    malloc_call_count++;
> > +    if (malloc_call_count == malloc_trigger_count) {
> > +      return NULL;
> > +  return __real_malloc(size);
> > + * @brief Empty Deliver Method for Testing
> > +static bool test_regulator_deliverer(
> > +  void     *context,
> > +  void     *message,
> > +  size_t    length
> > +  (void) context;
> > +  (void) message;
> > +  (void) length;
> > +  return true;
> > + * @brief Maximum length of a test message that is delivered
> > +#define MAXIMUM_MESSAGE_LENGTH 32
> > + * @brief Maximum number of test messages to buffer
> > +#define MAXIMUM_MESSAGES_TO_BUFFER 10
> > + * @brief Structure for capturing messages as delivered
> > +typedef struct {
> > +  rtems_interval processed;
> > +  char           message[MAXIMUM_MESSAGE_LENGTH];
> > +} message_log_t;
> > + * @brief Set of Delivered messages
> > +message_log_t delivered_messages[MAXIMUM_MESSAGES_TO_BUFFER];
> > + * @brief Count of Delivered messages
> > +int delivered_message_count;
> > + * @brief Reset Delivered Message Set
> > + * This is used at the beginning of a test case which is going to
> > + * check that message contents and delivery times were as expected.
> > +static void delivered_messages_reset(void)
> > +  delivered_message_count = 0;
> > +  memset(delivered_messages, 0xc5, sizeof(delivered_messages));
> > + * @brief Context for Logger Delivery Function
> > +typedef struct {
> > +  /** Regulator instance being operated on */
> > +  rtems_regulator_instance   *regulator;
> > +} deliverer_logger_context_t;
> > + * @brief Context Instance for Logger Delivery Function
> > +static deliverer_logger_context_t deliverer_logger_context;
> > + * This deliverer method implementation logs the messages along with
> > + * their time of arrival. This is used by the test cases to verify
> > + * proper delivery.
> > +static bool test_regulator_deliverer_logger(
> > +  void     *context,
> > +  void     *message,
> > +  size_t    length
> > +  (void) context;
> > +  static bool caller_releases_buffer = true;
> > +  size_t         len;
> > +  rtems_interval ticks;
> > +  len = strnlen(message, MAXIMUM_MESSAGE_LENGTH) + 1;
> > +  rtems_test_assert(len = length);
> > +  ticks = rtems_clock_get_ticks_since_boot();
> > +  delivered_messages[delivered_message_count].processed = ticks;
> > +  strcpy(delivered_messages[delivered_message_count].message, message);
> > +  delivered_message_count++;
> > +   * Alternate releasing the buffer here and allowing the calling
> Delivery
> > +   * Thread to do it. This increases coverage of that logic.
> > +  if (caller_releases_buffer == true) {
> > +    caller_releases_buffer = false;
> > +    return true;
> > +  return false;
> > + * @brief Helper to create a Regulator instance
> > + * This helper creates a regulator instance with some arbitrary
> attributes.
> > + * This is used in multiple test cases to have a valie regulator
> instance to
> > + * trigger error cases.
> > +static rtems_regulator_instance
> *test_regulator_create_regulator_OK(void)
> > +  rtems_regulator_attributes  attributes = {
> > +    .deliverer = test_regulator_deliverer,
> > +    .deliverer_context = NULL,
> > +    .maximum_message_size = 16,
> > +    .maximum_messages = 10,
> > +    .output_thread_priority = 16,
> > +    .output_thread_stack_size = 0,
> > +    .output_thread_period = RTEMS_MILLISECONDS_TO_TICKS(1000),
> > +    .maximum_to_dequeue_per_period = 3
> > +  regulator = NULL;
> > +  sc = rtems_regulator_create(&attributes, &regulator);
> > +  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
> > +  rtems_test_assert(regulator != NULL);
> > +  return regulator;
> > + * @brief Verify rtems_regulator_create() maximum_to_dequeue_per_period
> > + * attributes error
> > + * This unit test verifies that rtems_regulator_create() returns an
> error when
> > + * the maximum_to_dequeue_per_period attribute is zero.
> > +static void test_regulator_create_max_dequeue_zero(void)
> > +    .maximum_to_dequeue_per_period = 0
> > +  regulator = NULL;
> > +  rtems_test_assert(sc == RTEMS_INVALID_NUMBER);
> > + * @brief Verify rtems_regulator_create() NULL attributes error
> error when
> > + * the attributes argument is NULL.
> > +static void test_regulator_create_null_attributes(void)
> > +  sc = rtems_regulator_create(NULL, &regulator);
> > +  rtems_test_assert(sc == RTEMS_INVALID_ADDRESS);
> > + * @brief Verify rtems_regulator_create NULL regulator error
> error when
> > + * the regulator argument is NULL.
> > +static void test_regulator_create_null_regulator(void)
> > +  rtems_regulator_attributes  attributes;
> > +  sc = rtems_regulator_create(&attributes, NULL);
> > + * @brief Verify rtems_regulator_create deliverer is NULL
> error when
> > + * the the attributes deliverer field is NULL.
> > +static void test_regulator_create_deliverer_is_null(void)
> > +  (void) memset(&attributes, 0, sizeof(rtems_regulator_attributes));
> > +  attributes.deliverer                     = NULL;
> > +  attributes.maximum_messages              = 0;
> > +  attributes.maximum_message_size          = 16;
> > +  attributes.maximum_to_dequeue_per_period = 1;
> > + * @brief Verify rtems_regulator_create maximum_messages is 0 error
> error when
> > + * the the attributes maximum_messages field is 0.
> > +static void test_regulator_create_maximum_messages_is_zero(void)
> > +  attributes.deliverer                     = test_regulator_deliverer;
> > + * @brief Verify rtems_regulator_create maximum_message_size is 0 error
> error when
> > + * the the attributes maximum_message_size field is 0.
> > +static void test_regulator_create_maximum_message_size_is_zero(void)
> > +  attributes.maximum_messages              = 10;
> > +  attributes.maximum_message_size          = 0;
> > +  rtems_test_assert(sc == RTEMS_INVALID_SIZE);
> > + * @brief Verify rtems_regulator_create maximum_to_dequeue_per_period
> is 0 error
> error when
> > + * the the attributes maximum_to_dequeue_per_period field is 0.
> > +static void
> test_regulator_create_maximum_to_dequeue_per_period_is_zero(void)
> > + * @brief Verify rtems_regulator_create returns error on failure to
> allocate regulator
> error when
> > + * it is unable to allocate the mmemory for the regulator instance.
> > +static void test_regulator_create_malloc_regulator_fails(void)
> > +  attributes.output_thread_priority        = 32;
> > +  attributes.output_thread_period          =
> RTEMS_MILLISECONDS_TO_TICKS(1000);
> > +  malloc_trigger_enable(1);
> > +  rtems_test_assert(sc == RTEMS_NO_MEMORY);
> > +  malloc_trigger_reset();
> allocate buffers
> error when
> > + * it is unable to allocate the mmemory for the regulator buffers.
> > +static void test_regulator_create_malloc_buffers_fails(void)
> > +  malloc_trigger_enable(2);
> > + * @brief Verify rtems_regulator_create and delete work
> > + * This unit test verifies that rtems_regulator_create() can
> successfully create
> > + * the the attributes output_thread_priority field is 0.
> > +static void test_regulator_create_output_thread_priority_is_zero(void)
> > +  attributes.output_thread_priority        = 0;
> > +  rtems_test_assert(sc == RTEMS_INVALID_PRIORITY);
> > + * @brief Verify rtems_regulator_create rtems_partition_create error
> > + * This unit test verifies that rtems_regulator_create() correctly
> returns an
> > + * error when the call to rtems_partition_create() fails.
> > +static void test_regulator_create_partition_create_fails(void)
> > +  rtems_id                    partition_id;
> > +  unsigned long               partition_area[16];
> > +    rtems_build_name('T', 'P', 'T', 'P'),
> > +    partition_area,
> > +    16 * sizeof(unsigned long),
> > +    2 * sizeof(unsigned long),
> > +    &partition_id
> > +  attributes.output_thread_priority        = 8;
> > +  rtems_test_assert(sc == RTEMS_TOO_MANY);
> > +  sc = rtems_partition_delete(partition_id);
> > + * @brief Verify rtems_regulator_create rtems_message_queue_create error
> returns an
> > + * error when the call to rtems_message_queue_create() fails.
> > +static void test_regulator_create_message_queue_create_fails(void)
> > +  sc = rtems_message_queue_create(
> > +    rtems_build_name('T', 'Q', 'T', 'Q'),
> > +    4,
> > +    sizeof(unsigned long),
> > +    &queue_id
> > +  sc = rtems_message_queue_delete(queue_id);
> > + * @brief Verify rtems_regulator_create rtems_task_create error
> returns an
> > + * error when the call to rtems_task_create() fails.
> > +static void test_regulator_create_task_create_fails(void)
> > +  rtems_id                    task_id;
> > +    rtems_build_name('T', 'T', 'T', 'T'),
> > +    80,
> > +    0,
> > +    &task_id
> > +  sc = rtems_task_delete(task_id);
> > + * @brief Verify Regulator Output Thread Handles Error on Period Create
> > + * This unit test verifies that regulator output thread correctly exits
> > + * when the call to rtems_rate_monotonic_create() fails.
> > + * This error condition/path cannot be directly detected via a return
> code,
> > + * It is verified via a debugger or code coverage reports.
> > +static void test_regulator_create_rate_monotonic_create_fails(void)
> > +  rtems_id                    period_id;
> > +    rtems_build_name('T', 'S', 'T', 'P'),
> > +    &period_id
> > +   * Let the output thread execute and encounter the create error.
> > +  sleep(1);
> > +   * Now deallocate the resources allocated earlier
> > +  sc = rtems_regulator_delete(regulator);
> > +  sc = rtems_rate_monotonic_delete(period_id);
> > + * @brief Verify rtems_regulator_delete NULL regulator error
> > + * This unit test verifies that rtems_regulator_delete() returns an
> error when
> > +static void test_regulator_delete_null_regulator(void)
> > +  sc = rtems_regulator_delete(NULL);
> > + * @brief Verify rtems_regulator_delete uninitialized regulator error
> error when
> > + * the regulator argument is uninitialized.
> > +static void test_regulator_delete_uninitialized_regulator(void)
> > +  rtems_regulator_instance  regulator;
> > +  (void) memset(&regulator, 0, sizeof(regulator));
> > +  sc = rtems_regulator_delete(&regulator);
> > +  rtems_test_assert(sc == RTEMS_INCORRECT_STATE);
> > + * @brief Verify rtems_regulator_delete successful case
> > + * This unit test verifies that rtems_regulator_delete() can be
> successfully
> > + * deleted.
> > +static void test_regulator_delete_OK(void)
> > +  regulator = test_regulator_create_regulator_OK();
> > + * @brief Verify rtems_regulator_obtain_buffer NULL regulator error
> > + * This unit test verifies that rtems_regulator_obtain_buffer() returns
> an error when
> > +static void test_regulator_obtain_buffer_null_regulator(void)
> > +  void               *buffer;
> > +  sc = rtems_regulator_obtain_buffer(NULL, &buffer);
> > + * @brief Verify rtems_regulator_obtain_buffer uninitialized regulator
> error
> an error when
> > +static void test_regulator_obtain_buffer_uninitialized_regulator(void)
> > +  void                     *buffer;
> > +  sc = rtems_regulator_obtain_buffer(&regulator, &buffer);
> > + * @brief Verify rtems_regulator_obtain_buffer successful case
> > + * This unit test verifies that rtems_regulator_obtain_buffer() can be
> successfully
> > + * obtained from an initialized regulator.
> > +static void test_regulator_obtain_buffer_OK(void)
> > +  void                     *buffer;
> > +  sc = rtems_regulator_obtain_buffer(regulator, &buffer);
> > +  rtems_test_assert(buffer != NULL);
> > +   * Not really testing this here but cannot delete underlying partition
> > +   * if there are buffers outstanding.
> > +  sc = rtems_regulator_release_buffer(regulator, buffer);
> > + * @brief Verify rtems_regulator_release_buffer NULL regulator error
> > + * This unit test verifies that rtems_regulator_release_buffer()
> returns an error when
> > +static void test_regulator_release_buffer_null_regulator(void)
> > +  void               *buffer;
> > +  sc = rtems_regulator_release_buffer(NULL, &buffer);
> > + * @brief Verify rtems_regulator_release_buffer uninitialized regulator
> error
> returns an
> > + * error when the regulator argument is uninitialized.
> > +static void test_regulator_release_buffer_uninitialized_regulator(void)
> > +  void                     *buffer;
> > +  sc = rtems_regulator_release_buffer(&regulator, &buffer);
> > + * @brief Verify rtems_regulator_release_buffer successful case
> > + * This unit test verifies that rtems_regulator_release_buffer() can be
> successfully
> > + * invoked with a buffer previously allocated by
> > +static void test_regulator_release_buffer_OK(void)
> > +  void                     *buffer;
> > + * @brief Verify rtems_regulator_send NULL regulator error
> > + * This unit test verifies that rtems_regulator_send() returns an error
> when
> > +static void test_regulator_send_null_regulator(void)
> > +  void               *buffer;
> > +  size_t              length;
> > +  buffer = &length;
> > +  length = sizeof(size_t);
> > +  sc = rtems_regulator_send(NULL, buffer, length);
> > + * @brief Verify rtems_regulator_send NULL message error
> when
> > + * the message argument is NULL.
> > +static void test_regulator_send_null_message(void)
> > +  size_t                    length;
> > +  sc = rtems_regulator_send(&regulator, NULL, length);
> > + * @brief Verify rtems_regulator_send zero length message error
> > + * error when the message length is 0.
> > +static void test_regulator_send_length_is_zero(void)
> > +  void                     *buffer;
> > +  size_t                    length;
> > +  buffer = &length;
> > +  length = 0;
> > +  sc = rtems_regulator_send(&regulator, buffer, length);
> > + * @brief Verify rtems_regulator_send uninitialized regulator error
> > +static void test_regulator_send_uninitialized_regulator(void)
> > +  void                     *buffer;
> > +  size_t                    length;
> > +  buffer = &length;
> > + * @brief Verify rtems_regulator_send and output thread delivers message
> > + * This unit test verifies that when the regulator is successfully
> initialized
> > + * and used as expected, a message sent via rtems_regulator_send() is
> delivered as
> > + * expected.
> > +static void test_regulator_send_one_message_OK(void)
> > +  void                     *buffer;
> > +  size_t                    length;
> > +  int                       match;
> > +    .deliverer = test_regulator_deliverer_logger,
> > +    .deliverer_context = &deliverer_logger_context,
> > +    .output_thread_period = RTEMS_MILLISECONDS_TO_TICKS(250),
> > +  deliverer_logger_context.regulator = regulator;
> > +  delivered_messages_reset();
> > +  length = snprintf(message, MAXIMUM_MESSAGE_LENGTH, "message %d",
> 1024) + 1;
> > +  strcpy(buffer, message);
> > +  sc = rtems_regulator_send(regulator, buffer, length);
> > +  sleep(1);
> > +  rtems_test_assert(delivered_message_count == 1);
> > +  match = strncmp(
> > +    delivered_messages[0].message,
> > +    message,
> > +    MAXIMUM_MESSAGE_LENGTH
> > +  rtems_test_assert(match == 0);
> > +  deliverer_logger_context.regulator = NULL;
> messages
> initialized
> > + * and used as expected, and multiple messages are sent via
> > + * that they are delivered as expected.
> > +#include <stdio.h>
> > +static void test_regulator_send_multiple_messages_OK(void)
> > +  void                     *buffer;
> > +  size_t                    length;
> > +  int                       match;
> > +  int                       i;
> > +  time_t                    base_time;
> > +  time_t                    tmp_time;
> > +  rtems_interval            base_ticks;
> > +  rtems_interval            ticks_per_second;
> > +    .maximum_message_size = MAXIMUM_MESSAGE_LENGTH,
> > +    .maximum_to_dequeue_per_period = 2
> > +   * Ensure the messages are sent on a second boundary to ensure the
> > +   * output thread will process them as expected.
> > +  tmp_time = time(NULL);
> > +  do {
> > +    base_time = time(NULL);
> > +  } while (tmp_time == base_time);
> > +   * Send five messages as a burst which will need to be smoothly sent
> at
> > +   * the configured rate.
> > +  for (i=1 ; i <= 5 ; i++) {
> > +    length = snprintf(message, MAXIMUM_MESSAGE_LENGTH, "message %d", i);
> > +   * Let the output thread executed and deliver the messages.
> > +  sleep(5);
> > +   * Ensure the five messages were delivered as follows:
> > +   *   - deliver all 5
> > +   *   - contents are "message N" where N is 1 to 5
> > +   *   - message 1 and 2 delivered during the first second
> > +   *   - message 3 and 4 delivered during the second second
> > +   *   - message 5 delivered during the third second
> > +   *   - no further messages delivered
> > +  rtems_test_assert(delivered_message_count == 5);
> > +  for (i=0 ; i < 5 ; i++) {
> > +    (void) snprintf(message, MAXIMUM_MESSAGE_LENGTH, "message %d", i+1);
> > +// printf("%d %s\n", i, delivered_messages[i].message);
> > +    match = strncmp(
> > +      delivered_messages[i].message,
> > +      message,
> > +   * Verify that messages were delivered in the proper groups. Check
> that
> > +   * the delivery time matches expectations.
> > +  rtems_test_assert(delivered_messages[0].processed ==
> delivered_messages[1].processed);
> > +  rtems_test_assert(delivered_messages[1].processed !=
> delivered_messages[2].processed);
> > +  rtems_test_assert(delivered_messages[2].processed ==
> delivered_messages[3].processed);
> > +  rtems_test_assert(delivered_messages[3].processed !=
> delivered_messages[4].processed);
> > +   * Verify that the message groups were properly spaced temporally.
> They
> > +   * should be one second apart.
> > +  ticks_per_second = rtems_clock_get_ticks_per_second();
> > +  base_ticks = delivered_messages[1].processed;
> > +  ticks      = delivered_messages[2].processed;
> > +  rtems_test_assert(ticks_per_second == ticks - base_ticks);
> > +  base_ticks = delivered_messages[3].processed;
> > +  ticks      = delivered_messages[4].processed;
> > +/* Necessary prototype */
> > +rtems_task test_regulator(rtems_task_argument);
> > + * @ingroup RegulatorTestshttps://devel.rtems.org/milestone/6.1
> > + * @brief Test entry task which invokes test cases
> > +rtems_task test_regulator(rtems_task_argument arg)
> > +  (void) arg;
> > +  TEST_BEGIN();
> > +  test_regulator_create_max_dequeue_zero();
> > +  test_regulator_create_null_attributes();
> > +  test_regulator_create_null_regulator();
> > +  test_regulator_create_deliverer_is_null();
> > +  test_regulator_create_maximum_messages_is_zero();
> > +  test_regulator_create_maximum_message_size_is_zero();
> > +  test_regulator_create_maximum_to_dequeue_per_period_is_zero();
> > +  test_regulator_create_malloc_regulator_fails();
> > +  test_regulator_create_malloc_buffers_fails();
> > +  test_regulator_create_output_thread_priority_is_zero();
> > +  test_regulator_create_partition_create_fails();
> > +  test_regulator_create_message_queue_create_fails();
> > +  test_regulator_create_task_create_fails();
> > +  test_regulator_create_rate_monotonic_create_fails();
> > +  test_regulator_delete_null_regulator();
> > +  test_regulator_delete_uninitialized_regulator();
> > +  test_regulator_delete_OK();
> > +  test_regulator_obtain_buffer_null_regulator();
> > +  test_regulator_obtain_buffer_uninitialized_regulator();
> > +  test_regulator_obtain_buffer_OK();
> > +  test_regulator_release_buffer_null_regulator();
> > +  test_regulator_release_buffer_uninitialized_regulator();
> > +  test_regulator_release_buffer_OK();
> > +  test_regulator_send_null_regulator();
> > +  test_regulator_send_null_message();
> > +  test_regulator_send_length_is_zero();
> > +  test_regulator_send_uninitialized_regulator();
> > +  test_regulator_send_one_message_OK();
> > +  test_regulator_send_multiple_messages_OK();
> > +  TEST_END();
> > +  rtems_test_exit(0);
> > diff --git a/testsuites/libtests/regulator01/regulator01.doc
> b/testsuites/libtests/regulator01/regulator01.doc
> > index 0000000000..5685e4b857
> > --- /dev/null
> > +++ b/testsuites/libtests/regulator01/regulator01.doc
> > @@ -0,0 +1,68 @@
> > +# SPDX-License-Identifier: BSD-2-Clause
> > +# Copyright (c) 2023 OAR Corporation
> > +# Redistribution and use in source and binary forms, with or without
> > +# modification, are permitted provided that the following conditions
> > +# are met:
> > +# 1. Redistributions of source code must retain the above copyright
> > +#    notice, this list of conditions and the following disclaimer.
> > +# 2. Redistributions in binary form must reproduce the above copyright
> > +#    notice, this list of conditions and the following disclaimer in the
> > +#    documentation and/or other materials provided with the
> distribution.
> > +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> > +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> > +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> > +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS
> BE
> > +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> > +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> > +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> > +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
> IN
> > +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> OTHERWISE)
> > +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
> OF THE
> > +# POSSIBILITY OF SUCH DAMAGE.
> > +This file describes the directives and concepts tested by this test set.
> > +test set name: regulator01
> > +directives:
> > +  + rtems_regulator_create
> > +  + rtems_regulator_delete
> > +  + rtems_regulator_obtain_buffer
> > +  + rtems_regulator_release_buffer
> > +  + rtems_regulator_send
> > +concepts
> > +  + Verify rtems_regulator_create() maximum_to_dequeue_per_period
> > +  + Verify rtems_regulator_create() NULL attributes error
> > +  + Verify rtems_regulator_create NULL regulator error
> > +  + Verify rtems_regulator_create deliverer is NULL
> > +  + Verify rtems_regulator_create maximum_messages is 0 error
> > +  + Verify rtems_regulator_create maximum_message_size is 0 error
> > +  + Verify rtems_regulator_create maximum_to_dequeue_per_period is 0
> error
> > +  + Verify rtems_regulator_create returns error on failure to allocate
> regulator
> buffers
> > +  + Verify rtems_regulator_create and delete work
> > +  + Verify rtems_regulator_create rtems_partition_create error
> > +  + Verify rtems_regulator_create rtems_message_queue_create error
> > +  + Verify rtems_regulator_create rtems_task_create error
> > +  + Verify Regulator Output Thread Handles Error on Period Create
> > +  + Verify rtems_regulator_delete NULL regulator error
> > +  + Verify rtems_regulator_delete uninitialized regulator error
> > +  + Verify rtems_regulator_delete successful case
> > +  + Verify rtems_regulator_obtain_buffer NULL regulator error
> > +  + Verify rtems_regulator_obtain_buffer uninitialized regulator error
> > +  + Verify rtems_regulator_obtain_buffer successful case
> > +  + Verify rtems_regulator_release_buffer NULL regulator error
> > +  + Verify rtems_regulator_release_buffer uninitialized regulator error
> > +  + Verify rtems_regulator_release_buffer successful case
> > +  + Verify rtems_regulator_send NULL regulator error
> > +  + Verify rtems_regulator_send NULL message error
> > +  + Verify rtems_regulator_send zero length message error
> > +  + Verify rtems_regulator_send uninitialized regulator error
> > +  + Verify rtems_regulator_send and output thread delivers message
> > +  + Verify rtems_regulator_send and output thread delivers messages
> > diff --git a/testsuites/libtests/regulator01/rtems_config.c
> b/testsuites/libtests/regulator01/rtems_config.c
> > index 0000000000..ca96e1b1dd
> > --- /dev/null
> > +++ b/testsuites/libtests/regulator01/rtems_config.c
> > @@ -0,0 +1,59 @@
> > + * @file
> > + * @brief RTEMS Configuration for regulator tests
> > + *  COPYRIGHT (c) 2022.  *  On-Line Applications Research Corporation
> (OAR).
> > + * are met:
> the
> distribution.
> "AS IS"
> TO, THE
> PURPOSE
> CONTRIBUTORS BE
> BUSINESS
> IN
> OTHERWISE)
> OF THE
> > +#include <rtems.h>
> > +#include <bsp.h> /* for device driver prototypes */
> > +/* NOTICE: the clock driver is explicitly disabled */
> > +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> > +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> > +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> > +#define CONFIGURE_INIT_TASK_ENTRY_POINT test_regulator
> > +#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
> > +/* Use hard limits to make it easier to trip object creation errors */
> > +#define CONFIGURE_MAXIMUM_TASKS 2
> > +#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 1
> > +#define CONFIGURE_MAXIMUM_PARTITIONS 1
> > +#define CONFIGURE_MAXIMUM_PERIODS 1
> > +#define CONFIGURE_UNIFIED_WORK_AREAS
> > +#define CONFIGURE_MINIMUM_TASK_STACK_SIZE (8 * 1024)
> > +#include <rtems/confdefs.h>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230719/e8b94eed/attachment-0001.htm>
