[PATCH rtems-net-legacy] powerpc/beatnik: Add mv643xx_eth.c driver from RTEMS 5
Thu Jul 20 00:50:22 UTC 2023
On 20/7/2023 10:18 am, Vijay Kumar Banerjee wrote:
> On Wed, Jul 19, 2023 at 6:39 PM Chris Johns <chrisj at rtems.org> wrote:
>> Excellent.
>> Could you please update the hash in the RSB for the net legacy package?
> Thanks for mentioning it! While trying to build from RSB, I realized
> two important changes I need from rtems build:
> 1. Removing networking check, put a patch for it just now:
> https://lists.rtems.org/pipermail/devel/2023-July/075830.html
I saw that.
> 2. Building the ping and telnetd02 requires posix. For this, should be
> conditionally build these two tests only when RTEMS_POSIX_API is true?
Which part of POSIX is needed? I ask because I think the POSIX option is only
controlling signals and maybe something else, I cannot remember what the list
is. What happens if you remove the check?
