[PATCH rtems-libbsd/6-freebsd-12 1/3] freenbsd/vfs: VFS attributes need to have the same size mode_t variable
chrisj at rtems.org chrisj at rtems.org
Thu Jul 20 05:45:33 UTC 2023
If the size in the attributes struct does not match the mode_t the
VNOVAL checks fail because sie of the values are not the same.
Updates #4723
 freebsd/sys/sys/vnode.h | 4 ++++
 1 file changed, 4 insertions(+)
diff --git a/freebsd/sys/sys/vnode.h b/freebsd/sys/sys/vnode.h
index d297c931..ddb9ac30 100644
--- a/freebsd/sys/sys/vnode.h
+++ b/freebsd/sys/sys/vnode.h
@@ -266,8 +266,12 @@ struct xvnode {
 struct vattr {
 	enum vtype	va_type;	/* vnode type (for create) */
+#ifndef __rtems__
 	u_short		va_mode;	/* files access mode and type */
 	u_short		va_padding0;
+#else /* __rtems__ */
+	mode_t		va_mode;	/* files access mode and type */
+#endif /* __rtems__ */
 	uid_t		va_uid;		/* owner user id */
 	gid_t		va_gid;		/* owner group id */
 	nlink_t		va_nlink;	/* number of references to file */
2.37.1
