[PATCH 1/2] unit: Test POSIX-specific message queue impl
Thu Jul 20 13:40:01 UTC 2023
From: Frank Kühndel <frank.kuehndel at embedded-brains.de>
This unit test covers code paths of the Message Handler which are only
reached by through POSIX message queue API.
Update #3716.
 .../build/testsuites/unit/unit-no-clock-0.yml |   1 +
 testsuites/unit/tc-score-msgq.c               | 452 ++++++++++++++++++
 2 files changed, 453 insertions(+)
 create mode 100644 testsuites/unit/tc-score-msgq.c
diff --git a/spec/build/testsuites/unit/unit-no-clock-0.yml b/spec/build/testsuites/unit/unit-no-clock-0.yml
index 57cd279a7a..517b84284d 100644
--- a/spec/build/testsuites/unit/unit-no-clock-0.yml
+++ b/spec/build/testsuites/unit/unit-no-clock-0.yml
@@ -12,6 +12,7 @@ ldflags: []
 links: []
 source:
 - testsuites/unit/tc-misaligned-builtin-memcpy.c
+- testsuites/unit/tc-score-msgq.c
 - testsuites/unit/tc-score-rbtree.c
 - testsuites/unit/ts-unit-no-clock-0.c
 stlib: []
diff --git a/testsuites/unit/tc-score-msgq.c b/testsuites/unit/tc-score-msgq.c
new file mode 100644
index 0000000000..c4baa6d53e
--- /dev/null
+++ b/testsuites/unit/tc-score-msgq.c
@@ -0,0 +1,452 @@
+ * @file
+ * @ingroup ScoreMsgqUnitMsgq
+ * Copyright (C) 2021 embedded brains GmbH & Co. KG
+ * are met:
+ * This file is part of the RTEMS quality process and was automatically
+ * generated.  If you find something that needs to be fixed or
+ * worded better please post a report or patch to an RTEMS mailing list
+ * or raise a bug report:
+ * https://www.rtems.org/bugs.html
+ * For information on updating and regenerating please refer to the How-To
+ * section in the Software Requirements Engineering chapter of the
+ * RTEMS Software Engineering manual.  The manual is provided as a part of
+ * a release.  For development sources please refer to the online
+ * documentation at:
+ * https://docs.rtems.org
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems.h>
+#include <rtems/rtems/messageimpl.h>
+#include <rtems/rtems/statusimpl.h>
+#include <rtems/score/coremsgimpl.h>
+#include "../validation/tx-support.h"
+#include <rtems/test.h>
+ * @defgroup ScoreMsgqUnitMsgq spec:/score/msgq/unit/msgq
+ * @ingroup TestsuitesUnitNoClock0
+ * @brief Unit tests for the Message Queue Handler.
+ * Parts of the files ``cpukit/score/src/coremsginsert.c``,
+ * ``cpukit/score/src/coremsgseize.c``, and
+ * ``cpukit/score/src/coremsgsubmit.c`` are only executed by the POSIX API.
+ * Currently, the pre-qualified subset of RTEMS does not contain the POSIX API.
+ * This test exercises the code parts otherwise only reached by the POSIX API
+ * to achieve full code coverage.
+ * This test case performs the following actions:
+ * - Use _CORE_message_queue_Insert_message() to insert two messages into a
+ *   message queue and use the POSIX message priority to define their order in
+ *   the queue.
+ *   - Check that _CORE_message_queue_Submit() was executed successfully.
+ *   - Check that the messages are in right order in the message queue.
+ * - Submit three messages into a message queue which can only store two and
+ *   have the third submit() blocked till a seize() occurs.
+ *   - Check that the third _CORE_message_queue_Submit() did actually block
+ *     till there was room for the message in the message queue.
+ * - Submit messages in the queue from within an ISR.
+ *   - Check that the first two messages were successfully send.
+ *   - Check that trying to send the third message from ISR when the message
+ *     queue was full was rejected.
+#define MAXIMUM_PENDING_MESSAGES 2
+#define MAXIMUM_MESSAGE_SIZE 3
+static void WorkerTask( rtems_task_argument argument );
+ * @brief Test context for spec:/score/msgq/unit/msgq test case.
+typedef struct {
+   * @brief This member contains a valid ID of a message queue.
+  rtems_id message_queue_id;
+   * @brief This member is used as storage area for the message queue.
+  RTEMS_MESSAGE_QUEUE_BUFFER( MAXIMUM_MESSAGE_SIZE )
+    storage_area[ MAXIMUM_PENDING_MESSAGES];
+   * @brief This member contains the task identifier of the worker task.
+  rtems_id worker_id;
+   * @brief This member indicated whether the worker task is currently sending
+   *   a message (``true``) or whether it is waiting to receive an event
+   *   (``false``)..
+  bool is_worker_working;
+   * @brief This member contains the returned status code of the SendMessage()
+   *   function.
+  rtems_status_code send_status;
+} ScoreMsgqUnitMsgq_Context;
+static ScoreMsgqUnitMsgq_Context
+  ScoreMsgqUnitMsgq_Instance;
+#define EVENT_SEND RTEMS_EVENT_17
+#define MESSAGE_CONTENT_LOW { 1, 2, 3 }
+#define MESSAGE_CONTENT_HIGH { 4, 5 }
+#define MESSAGE_PRIORITY_LOW 5
+#define MESSAGE_PRIORITY_HIGH 7
+#define DO_WAIT true
+typedef ScoreMsgqUnitMsgq_Context Context;
+ * This is a code fragment from rtems_message_queue_send() with the
+ * specialty that it uses a POSIX priority and the sender
+ * task will wait in case the queue is full.
+static rtems_status_code SubmitMessage(
+  rtems_id id,
+  uint8_t *message,
+  size_t message_size,
+  unsigned int posix_piority
+  rtems_status_code status;
+  Thread_queue_Context queue_context;
+  Message_queue_Control *the_message_queue;
+  T_assert_lt_uint( posix_piority, MQ_PRIO_MAX );
+  the_message_queue = _Message_queue_Get(
+    id,
+    &queue_context
+  T_assert_not_null( the_message_queue );
+  /* The next two calls are from _POSIX_Message_queue_Send_support() */
+  _Thread_queue_Context_set_enqueue_callout(
+    &queue_context,
+    _Thread_queue_Enqueue_do_nothing_extra
+  _Thread_queue_Context_set_timeout_argument( &queue_context, NULL, true );
+  _CORE_message_queue_Acquire_critical(
+    &the_message_queue->message_queue,
+    &queue_context
+  status = _CORE_message_queue_Submit(
+    _Thread_Executing,
+    message,
+    message_size,
+    (CORE_message_queue_Submit_types) ( posix_piority * -1 ),
+    DO_WAIT,
+    &queue_context
+  return _Status_Get( status );
+static rtems_status_code ReceiveMessage(
+  rtems_id id,
+  void *buffer,
+  size_t *size
+  return rtems_message_queue_receive(
+    id,
+    buffer,
+    size,
+    RTEMS_LOCAL | RTEMS_NO_WAIT,
+    RTEMS_NO_TIMEOUT
+static rtems_status_code ReceiveOneMessages( Context *ctx )
+  uint8_t message_buffer[ MAXIMUM_MESSAGE_SIZE ];
+  size_t message_size;
+  return ReceiveMessage(
+    ctx->message_queue_id,
+    &message_buffer,
+    &message_size
+static void SendMessage( Context *ctx )
+  uint8_t message[] = { 100, 101, 102 };
+  ctx->send_status = SubmitMessage(
+    message,
+    sizeof( message ),
+    MESSAGE_PRIORITY_LOW
+  Context *ctx = (Context *) argument;
+  while ( true ) {
+    ctx->is_worker_working = false;
+    ReceiveAnyEvents();
+    ctx->is_worker_working = true;
+    SendMessage( ctx );
+    T_assert_rsc_success( ctx->send_status );
+static void WorkerSendMessage( Context *ctx )
+  SendEvents( ctx->worker_id, EVENT_SEND );
+static void ScoreMsgqUnitMsgq_Setup( ScoreMsgqUnitMsgq_Context *ctx )
+  rtems_message_queue_config config = {
+    .name                     = rtems_build_name( 'M', 'S', 'G', 'Q' ),
+    .maximum_pending_messages = MAXIMUM_PENDING_MESSAGES,
+    .maximum_message_size     = MAXIMUM_MESSAGE_SIZE,
+    .storage_area             = ctx->storage_area,
+    .storage_size             = sizeof( ctx->storage_area ),
+    .storage_free             = NULL,
+    .attributes               = RTEMS_DEFAULT_ATTRIBUTES
+  status = rtems_message_queue_construct(
+    &config,
+    &ctx->message_queue_id
+  T_rsc_success( status );
+  SetSelfPriority( PRIO_NORMAL );
+  ctx->worker_id = CreateTask( "WORK", PRIO_HIGH );
+  StartTask( ctx->worker_id, WorkerTask, ctx );
+static void ScoreMsgqUnitMsgq_Setup_Wrap( void *arg )
+  ScoreMsgqUnitMsgq_Context *ctx;
+  ctx = arg;
+  ScoreMsgqUnitMsgq_Setup( ctx );
+static void ScoreMsgqUnitMsgq_Teardown( ScoreMsgqUnitMsgq_Context *ctx )
+  DeleteTask( ctx->worker_id );
+  RestoreRunnerPriority();
+  T_rsc_success( rtems_message_queue_delete( ctx->message_queue_id ) );
+static void ScoreMsgqUnitMsgq_Teardown_Wrap( void *arg )
+  ctx = arg;
+  ScoreMsgqUnitMsgq_Teardown( ctx );
+static T_fixture ScoreMsgqUnitMsgq_Fixture = {
+  .setup = ScoreMsgqUnitMsgq_Setup_Wrap,
+  .stop = NULL,
+  .teardown = ScoreMsgqUnitMsgq_Teardown_Wrap,
+  .scope = NULL,
+  .initial_context = &ScoreMsgqUnitMsgq_Instance
+ * @brief Use _CORE_message_queue_Insert_message() to insert two messages into
+ *   a message queue and use the POSIX message priority to define their order
+ *   in the queue.
+static void ScoreMsgqUnitMsgq_Action_0( ScoreMsgqUnitMsgq_Context *ctx )
+  rtems_status_code status_submit_low;
+  rtems_status_code status_submit_high;
+  rtems_status_code status_receive_low;
+  rtems_status_code status_receive_high;
+  uint8_t message_low[] = MESSAGE_CONTENT_LOW;
+  uint8_t message_high[] = MESSAGE_CONTENT_HIGH;
+  uint8_t message_buffer_low[ MAXIMUM_MESSAGE_SIZE ];
+  uint8_t message_buffer_high[ MAXIMUM_MESSAGE_SIZE ];
+  size_t message_size_low;
+  size_t message_size_high;
+  status_submit_low = SubmitMessage(
+    message_low,
+    sizeof( message_low ),
+  status_submit_high = SubmitMessage(
+    message_high,
+    sizeof( message_high ),
+    MESSAGE_PRIORITY_HIGH
+  status_receive_high = ReceiveMessage(
+    &message_buffer_high,
+    &message_size_high
+  status_receive_low = ReceiveMessage(
+    &message_buffer_low,
+    &message_size_low
+   * Check that _CORE_message_queue_Submit() was executed successfully.
+  T_rsc_success( status_submit_low );
+  T_rsc_success( status_submit_high );
+   * Check that the messages are in right order in the message queue.
+  T_rsc_success( status_receive_high );
+  T_eq_sz( message_size_high, sizeof( message_high ) );
+  T_eq_mem( message_buffer_high, message_high, message_size_high );
+  T_rsc_success( status_receive_low );
+  T_eq_sz( message_size_low, sizeof( message_low ) );
+  T_eq_mem( message_buffer_low, message_low, message_size_low );
+ * @brief Submit three messages into a message queue which can only store two
+ *   and have the third submit() blocked till a seize() occurs.
+static void ScoreMsgqUnitMsgq_Action_1( ScoreMsgqUnitMsgq_Context *ctx )
+  bool is_worker_blocked_after_third_send;
+  bool is_worker_blocked_after_first_receive;
+  WorkerSendMessage( ctx );
+  is_worker_blocked_after_third_send = ctx->is_worker_working;
+  T_rsc_success( ReceiveOneMessages( ctx ) );
+  is_worker_blocked_after_first_receive = ctx->is_worker_working;
+   * Check that the third _CORE_message_queue_Submit() did actually block till
+   * there was room for the message in the message queue.
+  T_true( is_worker_blocked_after_third_send );
+  T_true( !is_worker_blocked_after_first_receive );
+ * @brief Submit messages in the queue from within an ISR.
+static void ScoreMsgqUnitMsgq_Action_2( ScoreMsgqUnitMsgq_Context *ctx )
+  rtems_status_code status_send_first_message;
+  rtems_status_code status_send_second_message;
+  rtems_status_code status_send_third_message;
+  CallWithinISR( ( void (*)(void*) ) SendMessage, ctx );
+  status_send_first_message = ctx->send_status;
+  status_send_second_message = ctx->send_status;
+  status_send_third_message = ctx->send_status;
+   * Check that the first two messages were successfully send.
+  T_assert_rsc_success( status_send_first_message );
+  T_assert_rsc_success( status_send_second_message );
+   * Check that trying to send the third message from ISR when the message
+  T_rsc( status_send_third_message, STATUS_CLASSIC_INTERNAL_ERROR );
+ * @fn void T_case_body_ScoreMsgqUnitMsgq( void )
+T_TEST_CASE_FIXTURE( ScoreMsgqUnitMsgq, &ScoreMsgqUnitMsgq_Fixture )
+  ctx = T_fixture_context();
+  ScoreMsgqUnitMsgq_Action_0( ctx );
+  ScoreMsgqUnitMsgq_Action_1( ctx );
+  ScoreMsgqUnitMsgq_Action_2( ctx );
2.35.3
