[PATCH] membench: Add memory benchmark programs
Thu Jul 20 13:42:25 UTC 2023
These memory benchmark programs are not supposed to run.  Instead, they
can be analysed on the host system to measure the memory usage of
features.  See the membench module of rtems-central.
Update #3716.
 cpukit/doxygen/top-level-groups.h             |   8 +
 spec/build/testsuites/grp.yml                 |   2 +
 spec/build/testsuites/membench/grp.yml        | 121 +++++++++++++++
 .../membench/mem-barrier-wait-rel-del.yml     |  19 +++
 .../membench/mem-barrier-wait-rel.yml         |  19 +++
 .../testsuites/membench/mem-bsp-clock.yml     |  19 +++
 .../membench/mem-clock-get-uptime.yml         |  19 +++
 .../membench/mem-clock-set-get-tod.yml        |  19 +++
 .../testsuites/membench/mem-clock-set.yml     |  19 +++
 .../testsuites/membench/mem-event-snd-rcv.yml |  19 +++
 .../testsuites/membench/mem-fatal-fatal.yml   |  19 +++
 .../membench/mem-message-bcst-rcv.yml         |  19 +++
 .../membench/mem-message-snd-rcv-del.yml      |  19 +++
 .../membench/mem-message-snd-rcv.yml          |  19 +++
 .../membench/mem-message-ugt-rcv.yml          |  19 +++
 .../membench/mem-part-get-ret-del.yml         |  19 +++
 .../testsuites/membench/mem-part-get-ret.yml  |  19 +++
 .../membench/mem-ratemon-period-del.yml       |  19 +++
 .../membench/mem-ratemon-period.yml           |  19 +++
 .../testsuites/membench/mem-rtems-basic.yml   |  19 +++
 .../testsuites/membench/mem-rtems-smp-1.yml   |  19 +++
 .../membench/mem-rtems-smp-global-2.yml       |  19 +++
 .../membench/mem-rtems-smp-global-4.yml       |  19 +++
 .../membench/mem-rtems-smp-part-2.yml         |  19 +++
 .../membench/mem-rtems-smp-part-4.yml         |  19 +++
 .../membench/mem-scheduler-add-cpu.yml        |  19 +++
 .../membench/mem-scheduler-rm-cpu.yml         |  19 +++
 .../membench/mem-sem-obt-rel-del.yml          |  19 +++
 .../testsuites/membench/mem-sem-obt-rel.yml   |  19 +++
 .../membench/mem-signal-catch-snd.yml         |  19 +++
 .../testsuites/membench/mem-task-delete.yml   |  19 +++
 .../testsuites/membench/mem-task-exit.yml     |  19 +++
 .../membench/mem-task-get-affinity.yml        |  19 +++
 .../membench/mem-task-get-priority.yml        |  19 +++
 .../membench/mem-task-get-scheduler.yml       |  19 +++
 .../testsuites/membench/mem-task-mode.yml     |  19 +++
 .../testsuites/membench/mem-task-restart.yml  |  19 +++
 .../membench/mem-task-set-affinity.yml        |  19 +++
 .../membench/mem-task-set-priority.yml        |  19 +++
 .../membench/mem-task-set-scheduler.yml       |  19 +++
 .../testsuites/membench/mem-task-sus-res.yml  |  19 +++
 .../membench/mem-task-wake-after.yml          |  19 +++
 .../membench/mem-task-wake-when.yml           |  19 +++
 .../testsuites/membench/mem-timer-after.yml   |  19 +++
 .../testsuites/membench/mem-timer-cancel.yml  |  19 +++
 .../testsuites/membench/mem-timer-delete.yml  |  19 +++
 .../testsuites/membench/mem-timer-reset.yml   |  19 +++
 .../membench/mem-timer-srv-after.yml          |  19 +++
 .../membench/mem-timer-srv-init.yml           |  19 +++
 .../membench/mem-timer-srv-when.yml           |  19 +++
 .../testsuites/membench/mem-timer-when.yml    |  19 +++
 .../membench/mem-userext-create.yml           |  19 +++
 .../membench/mem-userext-delete.yml           |  19 +++
 spec/build/testsuites/optmembench.yml         |  16 ++
 .../membench/mem-barrier-wait-rel-del.c       | 116 +++++++++++++++
 testsuites/membench/mem-barrier-wait-rel.c    | 114 ++++++++++++++
 testsuites/membench/mem-bsp-clock.c           | 109 ++++++++++++++
 testsuites/membench/mem-clock-get-uptime.c    | 108 ++++++++++++++
 testsuites/membench/mem-clock-set-get-tod.c   | 110 ++++++++++++++
 testsuites/membench/mem-clock-set.c           | 108 ++++++++++++++
 testsuites/membench/mem-event-snd-rcv.c       | 110 ++++++++++++++
 testsuites/membench/mem-fatal-fatal.c         | 108 ++++++++++++++
 testsuites/membench/mem-message-bcst-rcv.c    | 111 ++++++++++++++
 testsuites/membench/mem-message-snd-rcv-del.c | 114 ++++++++++++++
 testsuites/membench/mem-message-snd-rcv.c     | 111 ++++++++++++++
 testsuites/membench/mem-message-ugt-rcv.c     | 111 ++++++++++++++
 testsuites/membench/mem-part-get-ret-del.c    | 115 ++++++++++++++
 testsuites/membench/mem-part-get-ret.c        | 114 ++++++++++++++
 testsuites/membench/mem-ratemon-period-del.c  | 114 ++++++++++++++
 testsuites/membench/mem-ratemon-period.c      | 113 ++++++++++++++
 testsuites/membench/mem-rtems-basic.c         | 111 ++++++++++++++
 testsuites/membench/mem-rtems-smp-1.c         | 115 ++++++++++++++
 testsuites/membench/mem-rtems-smp-global-2.c  | 115 ++++++++++++++
 testsuites/membench/mem-rtems-smp-global-4.c  | 115 ++++++++++++++
 testsuites/membench/mem-rtems-smp-part-2.c    | 132 +++++++++++++++++
 testsuites/membench/mem-rtems-smp-part-4.c    | 140 ++++++++++++++++++
 testsuites/membench/mem-scheduler-add-cpu.c   | 114 ++++++++++++++
 testsuites/membench/mem-scheduler-rm-cpu.c    | 115 ++++++++++++++
 testsuites/membench/mem-sem-obt-rel-del.c     | 115 ++++++++++++++
 testsuites/membench/mem-sem-obt-rel.c         | 114 ++++++++++++++
 testsuites/membench/mem-signal-catch-snd.c    | 110 ++++++++++++++
 testsuites/membench/mem-task-delete.c         | 108 ++++++++++++++
 testsuites/membench/mem-task-exit.c           | 108 ++++++++++++++
 testsuites/membench/mem-task-get-affinity.c   | 108 ++++++++++++++
 testsuites/membench/mem-task-get-priority.c   | 108 ++++++++++++++
 testsuites/membench/mem-task-get-scheduler.c  | 108 ++++++++++++++
 testsuites/membench/mem-task-mode.c           | 108 ++++++++++++++
 testsuites/membench/mem-task-restart.c        | 108 ++++++++++++++
 testsuites/membench/mem-task-set-affinity.c   | 108 ++++++++++++++
 testsuites/membench/mem-task-set-priority.c   | 108 ++++++++++++++
 testsuites/membench/mem-task-set-scheduler.c  | 108 ++++++++++++++
 testsuites/membench/mem-task-sus-res.c        | 110 ++++++++++++++
 testsuites/membench/mem-task-wake-after.c     | 108 ++++++++++++++
 testsuites/membench/mem-task-wake-when.c      | 108 ++++++++++++++
 testsuites/membench/mem-timer-after.c         | 110 ++++++++++++++
 testsuites/membench/mem-timer-cancel.c        | 110 ++++++++++++++
 testsuites/membench/mem-timer-delete.c        | 110 ++++++++++++++
 testsuites/membench/mem-timer-reset.c         | 110 ++++++++++++++
 testsuites/membench/mem-timer-srv-after.c     | 110 ++++++++++++++
 testsuites/membench/mem-timer-srv-init.c      | 123 +++++++++++++++
 testsuites/membench/mem-timer-srv-when.c      | 110 ++++++++++++++
 testsuites/membench/mem-timer-when.c          | 110 ++++++++++++++
 testsuites/membench/mem-userext-create.c      | 111 ++++++++++++++
 testsuites/membench/mem-userext-delete.c      | 112 ++++++++++++++
 104 files changed, 6701 insertions(+)
 create mode 100644 spec/build/testsuites/membench/grp.yml
 create mode 100644 spec/build/testsuites/membench/mem-barrier-wait-rel-del.yml
 create mode 100644 spec/build/testsuites/membench/mem-barrier-wait-rel.yml
 create mode 100644 spec/build/testsuites/membench/mem-bsp-clock.yml
 create mode 100644 spec/build/testsuites/membench/mem-clock-get-uptime.yml
 create mode 100644 spec/build/testsuites/membench/mem-clock-set-get-tod.yml
 create mode 100644 spec/build/testsuites/membench/mem-clock-set.yml
 create mode 100644 spec/build/testsuites/membench/mem-event-snd-rcv.yml
 create mode 100644 spec/build/testsuites/membench/mem-fatal-fatal.yml
 create mode 100644 spec/build/testsuites/membench/mem-message-bcst-rcv.yml
 create mode 100644 spec/build/testsuites/membench/mem-message-snd-rcv-del.yml
 create mode 100644 spec/build/testsuites/membench/mem-message-snd-rcv.yml
 create mode 100644 spec/build/testsuites/membench/mem-message-ugt-rcv.yml
 create mode 100644 spec/build/testsuites/membench/mem-part-get-ret-del.yml
 create mode 100644 spec/build/testsuites/membench/mem-part-get-ret.yml
 create mode 100644 spec/build/testsuites/membench/mem-ratemon-period-del.yml
 create mode 100644 spec/build/testsuites/membench/mem-ratemon-period.yml
 create mode 100644 spec/build/testsuites/membench/mem-rtems-basic.yml
 create mode 100644 spec/build/testsuites/membench/mem-rtems-smp-1.yml
 create mode 100644 spec/build/testsuites/membench/mem-rtems-smp-global-2.yml
 create mode 100644 spec/build/testsuites/membench/mem-rtems-smp-global-4.yml
 create mode 100644 spec/build/testsuites/membench/mem-rtems-smp-part-2.yml
 create mode 100644 spec/build/testsuites/membench/mem-rtems-smp-part-4.yml
 create mode 100644 spec/build/testsuites/membench/mem-scheduler-add-cpu.yml
 create mode 100644 spec/build/testsuites/membench/mem-scheduler-rm-cpu.yml
 create mode 100644 spec/build/testsuites/membench/mem-sem-obt-rel-del.yml
 create mode 100644 spec/build/testsuites/membench/mem-sem-obt-rel.yml
 create mode 100644 spec/build/testsuites/membench/mem-signal-catch-snd.yml
 create mode 100644 spec/build/testsuites/membench/mem-task-delete.yml
 create mode 100644 spec/build/testsuites/membench/mem-task-exit.yml
 create mode 100644 spec/build/testsuites/membench/mem-task-get-affinity.yml
 create mode 100644 spec/build/testsuites/membench/mem-task-get-priority.yml
 create mode 100644 spec/build/testsuites/membench/mem-task-get-scheduler.yml
 create mode 100644 spec/build/testsuites/membench/mem-task-mode.yml
 create mode 100644 spec/build/testsuites/membench/mem-task-restart.yml
 create mode 100644 spec/build/testsuites/membench/mem-task-set-affinity.yml
 create mode 100644 spec/build/testsuites/membench/mem-task-set-priority.yml
 create mode 100644 spec/build/testsuites/membench/mem-task-set-scheduler.yml
 create mode 100644 spec/build/testsuites/membench/mem-task-sus-res.yml
 create mode 100644 spec/build/testsuites/membench/mem-task-wake-after.yml
 create mode 100644 spec/build/testsuites/membench/mem-task-wake-when.yml
 create mode 100644 spec/build/testsuites/membench/mem-timer-after.yml
 create mode 100644 spec/build/testsuites/membench/mem-timer-cancel.yml
 create mode 100644 spec/build/testsuites/membench/mem-timer-delete.yml
 create mode 100644 spec/build/testsuites/membench/mem-timer-reset.yml
 create mode 100644 spec/build/testsuites/membench/mem-timer-srv-after.yml
 create mode 100644 spec/build/testsuites/membench/mem-timer-srv-init.yml
 create mode 100644 spec/build/testsuites/membench/mem-timer-srv-when.yml
 create mode 100644 spec/build/testsuites/membench/mem-timer-when.yml
 create mode 100644 spec/build/testsuites/membench/mem-userext-create.yml
 create mode 100644 spec/build/testsuites/membench/mem-userext-delete.yml
 create mode 100644 spec/build/testsuites/optmembench.yml
 create mode 100644 testsuites/membench/mem-barrier-wait-rel-del.c
 create mode 100644 testsuites/membench/mem-barrier-wait-rel.c
 create mode 100644 testsuites/membench/mem-bsp-clock.c
 create mode 100644 testsuites/membench/mem-clock-get-uptime.c
 create mode 100644 testsuites/membench/mem-clock-set-get-tod.c
 create mode 100644 testsuites/membench/mem-clock-set.c
 create mode 100644 testsuites/membench/mem-event-snd-rcv.c
 create mode 100644 testsuites/membench/mem-fatal-fatal.c
 create mode 100644 testsuites/membench/mem-message-bcst-rcv.c
 create mode 100644 testsuites/membench/mem-message-snd-rcv-del.c
 create mode 100644 testsuites/membench/mem-message-snd-rcv.c
 create mode 100644 testsuites/membench/mem-message-ugt-rcv.c
 create mode 100644 testsuites/membench/mem-part-get-ret-del.c
 create mode 100644 testsuites/membench/mem-part-get-ret.c
 create mode 100644 testsuites/membench/mem-ratemon-period-del.c
 create mode 100644 testsuites/membench/mem-ratemon-period.c
 create mode 100644 testsuites/membench/mem-rtems-basic.c
 create mode 100644 testsuites/membench/mem-rtems-smp-1.c
 create mode 100644 testsuites/membench/mem-rtems-smp-global-2.c
 create mode 100644 testsuites/membench/mem-rtems-smp-global-4.c
 create mode 100644 testsuites/membench/mem-rtems-smp-part-2.c
 create mode 100644 testsuites/membench/mem-rtems-smp-part-4.c
 create mode 100644 testsuites/membench/mem-scheduler-add-cpu.c
 create mode 100644 testsuites/membench/mem-scheduler-rm-cpu.c
 create mode 100644 testsuites/membench/mem-sem-obt-rel-del.c
 create mode 100644 testsuites/membench/mem-sem-obt-rel.c
 create mode 100644 testsuites/membench/mem-signal-catch-snd.c
 create mode 100644 testsuites/membench/mem-task-delete.c
 create mode 100644 testsuites/membench/mem-task-exit.c
 create mode 100644 testsuites/membench/mem-task-get-affinity.c
 create mode 100644 testsuites/membench/mem-task-get-priority.c
 create mode 100644 testsuites/membench/mem-task-get-scheduler.c
 create mode 100644 testsuites/membench/mem-task-mode.c
 create mode 100644 testsuites/membench/mem-task-restart.c
 create mode 100644 testsuites/membench/mem-task-set-affinity.c
 create mode 100644 testsuites/membench/mem-task-set-priority.c
 create mode 100644 testsuites/membench/mem-task-set-scheduler.c
 create mode 100644 testsuites/membench/mem-task-sus-res.c
 create mode 100644 testsuites/membench/mem-task-wake-after.c
 create mode 100644 testsuites/membench/mem-task-wake-when.c
 create mode 100644 testsuites/membench/mem-timer-after.c
 create mode 100644 testsuites/membench/mem-timer-cancel.c
 create mode 100644 testsuites/membench/mem-timer-delete.c
 create mode 100644 testsuites/membench/mem-timer-reset.c
 create mode 100644 testsuites/membench/mem-timer-srv-after.c
 create mode 100644 testsuites/membench/mem-timer-srv-init.c
 create mode 100644 testsuites/membench/mem-timer-srv-when.c
 create mode 100644 testsuites/membench/mem-timer-when.c
 create mode 100644 testsuites/membench/mem-userext-create.c
 create mode 100644 testsuites/membench/mem-userext-delete.c
diff --git a/cpukit/doxygen/top-level-groups.h b/cpukit/doxygen/top-level-groups.h
index fd32db347a..8a50d32a4d 100644
--- a/cpukit/doxygen/top-level-groups.h
+++ b/cpukit/doxygen/top-level-groups.h
@@ -81,6 +81,14 @@
  * @brief This group contains the test suites related to filesystem tests.
+ * @defgroup RTEMSTestSuitesMembench Memory Benchmark Test Suites
+ * @ingroup RTEMSTestSuites
+ * @brief This group contains the test suites related to memory benchmarks.
  * @defgroup RTEMSTestSuitesUnit Unit Test Suites
diff --git a/spec/build/testsuites/grp.yml b/spec/build/testsuites/grp.yml
index c50693420c..bda6140ef1 100644
--- a/spec/build/testsuites/grp.yml
+++ b/spec/build/testsuites/grp.yml
@@ -24,6 +24,8 @@ links:
   uid: optfs
 - role: build-dependency
   uid: optlib
+- role: build-dependency
+  uid: optmembench
   uid: optmp
diff --git a/spec/build/testsuites/membench/grp.yml b/spec/build/testsuites/membench/grp.yml
new file mode 100644
index 0000000000..d145d6c861
--- /dev/null
+++ b/spec/build/testsuites/membench/grp.yml
@@ -0,0 +1,121 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: group
+copyrights:
+- Copyright (C) 2021 embedded brains GmbH & Co. KG
+enabled-by:
+- BUILD_TESTS
+- BUILD_MEMBENCH
+cflags: []
+cppflags: []
+cxxflags: []
+includes:
+- ${BSP_INCLUDES}
+install: []
+ldflags: []
+links:
+  uid: mem-barrier-wait-rel-del
+  uid: mem-bsp-clock
+  uid: mem-clock-get-uptime
+  uid: mem-clock-set-get-tod
+  uid: mem-event-snd-rcv
+  uid: mem-fatal-fatal
+  uid: mem-message-bcst-rcv
+  uid: mem-message-snd-rcv-del
+  uid: mem-message-ugt-rcv
+  uid: mem-part-get-ret-del
+  uid: mem-ratemon-period-del
+  uid: mem-rtems-basic
+  uid: mem-rtems-smp-1
+  uid: mem-rtems-smp-global-2
+  uid: mem-rtems-smp-global-4
+  uid: mem-rtems-smp-part-2
+  uid: mem-rtems-smp-part-4
+  uid: mem-scheduler-add-cpu
+  uid: mem-scheduler-rm-cpu
+  uid: mem-sem-obt-rel-del
+  uid: mem-signal-catch-snd
+  uid: mem-task-delete
+  uid: mem-task-exit
+  uid: mem-task-get-affinity
+  uid: mem-task-get-priority
+  uid: mem-task-get-scheduler
+  uid: mem-task-mode
+  uid: mem-task-restart
+  uid: mem-task-set-affinity
+  uid: mem-task-set-priority
+  uid: mem-task-set-scheduler
+  uid: mem-task-sus-res
+  uid: mem-task-wake-after
+  uid: mem-task-wake-when
+  uid: mem-timer-after
+  uid: mem-timer-cancel
+  uid: mem-timer-delete
+  uid: mem-timer-reset
+  uid: mem-timer-srv-after
+  uid: mem-timer-srv-init
+  uid: mem-timer-srv-when
+  uid: mem-timer-when
+  uid: mem-userext-create
+  uid: mem-userext-delete
+type: build
+use-after:
+- rtemstest
+- rtemscpu
+- rtemsbsp
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-barrier-wait-rel-del.yml b/spec/build/testsuites/membench/mem-barrier-wait-rel-del.yml
index 0000000000..005f87981a
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-barrier-wait-rel-del.yml
@@ -0,0 +1,19 @@
+build-type: test-program
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+features: c cprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-barrier-wait-rel-del.c
+stlib: []
+target: testsuites/membench/mem-barrier-wait-rel-del.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-barrier-wait-rel.yml b/spec/build/testsuites/membench/mem-barrier-wait-rel.yml
index 0000000000..934245e528
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-barrier-wait-rel.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-barrier-wait-rel.c
+stlib: []
+target: testsuites/membench/mem-barrier-wait-rel.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-bsp-clock.yml b/spec/build/testsuites/membench/mem-bsp-clock.yml
index 0000000000..a598ee6eb4
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-bsp-clock.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-bsp-clock.c
+stlib: []
+target: testsuites/membench/mem-bsp-clock.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-clock-get-uptime.yml b/spec/build/testsuites/membench/mem-clock-get-uptime.yml
index 0000000000..fc07ba7df4
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-clock-get-uptime.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-clock-get-uptime.c
+stlib: []
+target: testsuites/membench/mem-clock-get-uptime.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-clock-set-get-tod.yml b/spec/build/testsuites/membench/mem-clock-set-get-tod.yml
index 0000000000..1ab43d634b
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-clock-set-get-tod.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-clock-set-get-tod.c
+stlib: []
+target: testsuites/membench/mem-clock-set-get-tod.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-clock-set.yml b/spec/build/testsuites/membench/mem-clock-set.yml
index 0000000000..acaaef4b92
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-clock-set.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-clock-set.c
+stlib: []
+target: testsuites/membench/mem-clock-set.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-event-snd-rcv.yml b/spec/build/testsuites/membench/mem-event-snd-rcv.yml
index 0000000000..6c1478cd40
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-event-snd-rcv.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-event-snd-rcv.c
+stlib: []
+target: testsuites/membench/mem-event-snd-rcv.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-fatal-fatal.yml b/spec/build/testsuites/membench/mem-fatal-fatal.yml
index 0000000000..4cfffb8f16
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-fatal-fatal.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-fatal-fatal.c
+stlib: []
+target: testsuites/membench/mem-fatal-fatal.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-message-bcst-rcv.yml b/spec/build/testsuites/membench/mem-message-bcst-rcv.yml
index 0000000000..3b619ef3c2
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-message-bcst-rcv.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-message-bcst-rcv.c
+stlib: []
+target: testsuites/membench/mem-message-bcst-rcv.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-message-snd-rcv-del.yml b/spec/build/testsuites/membench/mem-message-snd-rcv-del.yml
index 0000000000..33f0f6261f
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-message-snd-rcv-del.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-message-snd-rcv-del.c
+stlib: []
+target: testsuites/membench/mem-message-snd-rcv-del.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-message-snd-rcv.yml b/spec/build/testsuites/membench/mem-message-snd-rcv.yml
index 0000000000..7a18c16c87
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-message-snd-rcv.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-message-snd-rcv.c
+stlib: []
+target: testsuites/membench/mem-message-snd-rcv.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-message-ugt-rcv.yml b/spec/build/testsuites/membench/mem-message-ugt-rcv.yml
index 0000000000..f21bed9e5b
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-message-ugt-rcv.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-message-ugt-rcv.c
+stlib: []
+target: testsuites/membench/mem-message-ugt-rcv.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-part-get-ret-del.yml b/spec/build/testsuites/membench/mem-part-get-ret-del.yml
index 0000000000..9294221995
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-part-get-ret-del.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-part-get-ret-del.c
+stlib: []
+target: testsuites/membench/mem-part-get-ret-del.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-part-get-ret.yml b/spec/build/testsuites/membench/mem-part-get-ret.yml
index 0000000000..718a6dc07f
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-part-get-ret.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-part-get-ret.c
+stlib: []
+target: testsuites/membench/mem-part-get-ret.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-ratemon-period-del.yml b/spec/build/testsuites/membench/mem-ratemon-period-del.yml
index 0000000000..b23c5d7e2b
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-ratemon-period-del.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-ratemon-period-del.c
+stlib: []
+target: testsuites/membench/mem-ratemon-period-del.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-ratemon-period.yml b/spec/build/testsuites/membench/mem-ratemon-period.yml
index 0000000000..d5c273c15e
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-ratemon-period.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-ratemon-period.c
+stlib: []
+target: testsuites/membench/mem-ratemon-period.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-rtems-basic.yml b/spec/build/testsuites/membench/mem-rtems-basic.yml
index 0000000000..9b659dd3d4
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-rtems-basic.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-rtems-basic.c
+stlib: []
+target: testsuites/membench/mem-rtems-basic.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-rtems-smp-1.yml b/spec/build/testsuites/membench/mem-rtems-smp-1.yml
index 0000000000..7ef6df634f
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-rtems-smp-1.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-rtems-smp-1.c
+stlib: []
+target: testsuites/membench/mem-rtems-smp-1.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-rtems-smp-global-2.yml b/spec/build/testsuites/membench/mem-rtems-smp-global-2.yml
index 0000000000..512cfd55d1
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-rtems-smp-global-2.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-rtems-smp-global-2.c
+stlib: []
+target: testsuites/membench/mem-rtems-smp-global-2.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-rtems-smp-global-4.yml b/spec/build/testsuites/membench/mem-rtems-smp-global-4.yml
index 0000000000..da0678c58c
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-rtems-smp-global-4.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-rtems-smp-global-4.c
+stlib: []
+target: testsuites/membench/mem-rtems-smp-global-4.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-rtems-smp-part-2.yml b/spec/build/testsuites/membench/mem-rtems-smp-part-2.yml
index 0000000000..ffa8353815
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-rtems-smp-part-2.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-rtems-smp-part-2.c
+stlib: []
+target: testsuites/membench/mem-rtems-smp-part-2.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-rtems-smp-part-4.yml b/spec/build/testsuites/membench/mem-rtems-smp-part-4.yml
index 0000000000..d36a741323
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-rtems-smp-part-4.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-rtems-smp-part-4.c
+stlib: []
+target: testsuites/membench/mem-rtems-smp-part-4.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-scheduler-add-cpu.yml b/spec/build/testsuites/membench/mem-scheduler-add-cpu.yml
index 0000000000..7d7ec6a50b
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-scheduler-add-cpu.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-scheduler-add-cpu.c
+stlib: []
+target: testsuites/membench/mem-scheduler-add-cpu.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-scheduler-rm-cpu.yml b/spec/build/testsuites/membench/mem-scheduler-rm-cpu.yml
index 0000000000..d623835950
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-scheduler-rm-cpu.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-scheduler-rm-cpu.c
+stlib: []
+target: testsuites/membench/mem-scheduler-rm-cpu.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-sem-obt-rel-del.yml b/spec/build/testsuites/membench/mem-sem-obt-rel-del.yml
index 0000000000..9a6a6234d1
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-sem-obt-rel-del.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-sem-obt-rel-del.c
+stlib: []
+target: testsuites/membench/mem-sem-obt-rel-del.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-sem-obt-rel.yml b/spec/build/testsuites/membench/mem-sem-obt-rel.yml
index 0000000000..0144ef10ae
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-sem-obt-rel.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-sem-obt-rel.c
+stlib: []
+target: testsuites/membench/mem-sem-obt-rel.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-signal-catch-snd.yml b/spec/build/testsuites/membench/mem-signal-catch-snd.yml
index 0000000000..b752cd2749
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-signal-catch-snd.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-signal-catch-snd.c
+stlib: []
+target: testsuites/membench/mem-signal-catch-snd.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-task-delete.yml b/spec/build/testsuites/membench/mem-task-delete.yml
index 0000000000..05abcbd97f
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-task-delete.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-task-delete.c
+stlib: []
+target: testsuites/membench/mem-task-delete.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-task-exit.yml b/spec/build/testsuites/membench/mem-task-exit.yml
index 0000000000..cac0a0999f
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-task-exit.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-task-exit.c
+stlib: []
+target: testsuites/membench/mem-task-exit.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-task-get-affinity.yml b/spec/build/testsuites/membench/mem-task-get-affinity.yml
index 0000000000..fdd588ed17
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-task-get-affinity.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-task-get-affinity.c
+stlib: []
+target: testsuites/membench/mem-task-get-affinity.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-task-get-priority.yml b/spec/build/testsuites/membench/mem-task-get-priority.yml
index 0000000000..be4074208e
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-task-get-priority.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-task-get-priority.c
+stlib: []
+target: testsuites/membench/mem-task-get-priority.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-task-get-scheduler.yml b/spec/build/testsuites/membench/mem-task-get-scheduler.yml
index 0000000000..0bf68fb8fb
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-task-get-scheduler.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-task-get-scheduler.c
+stlib: []
+target: testsuites/membench/mem-task-get-scheduler.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-task-mode.yml b/spec/build/testsuites/membench/mem-task-mode.yml
index 0000000000..27f90e51d8
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-task-mode.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-task-mode.c
+stlib: []
+target: testsuites/membench/mem-task-mode.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-task-restart.yml b/spec/build/testsuites/membench/mem-task-restart.yml
index 0000000000..8db94dbc92
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-task-restart.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-task-restart.c
+stlib: []
+target: testsuites/membench/mem-task-restart.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-task-set-affinity.yml b/spec/build/testsuites/membench/mem-task-set-affinity.yml
index 0000000000..671acf997e
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-task-set-affinity.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-task-set-affinity.c
+stlib: []
+target: testsuites/membench/mem-task-set-affinity.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-task-set-priority.yml b/spec/build/testsuites/membench/mem-task-set-priority.yml
index 0000000000..e1cbb4aa7f
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-task-set-priority.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-task-set-priority.c
+stlib: []
+target: testsuites/membench/mem-task-set-priority.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-task-set-scheduler.yml b/spec/build/testsuites/membench/mem-task-set-scheduler.yml
index 0000000000..3278a56ce3
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-task-set-scheduler.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-task-set-scheduler.c
+stlib: []
+target: testsuites/membench/mem-task-set-scheduler.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-task-sus-res.yml b/spec/build/testsuites/membench/mem-task-sus-res.yml
index 0000000000..4553713bd0
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-task-sus-res.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-task-sus-res.c
+stlib: []
+target: testsuites/membench/mem-task-sus-res.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-task-wake-after.yml b/spec/build/testsuites/membench/mem-task-wake-after.yml
index 0000000000..971dda343c
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-task-wake-after.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-task-wake-after.c
+stlib: []
+target: testsuites/membench/mem-task-wake-after.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-task-wake-when.yml b/spec/build/testsuites/membench/mem-task-wake-when.yml
index 0000000000..5e7e95dd28
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-task-wake-when.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-task-wake-when.c
+stlib: []
+target: testsuites/membench/mem-task-wake-when.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-timer-after.yml b/spec/build/testsuites/membench/mem-timer-after.yml
index 0000000000..a0aee83b57
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-timer-after.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-timer-after.c
+stlib: []
+target: testsuites/membench/mem-timer-after.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-timer-cancel.yml b/spec/build/testsuites/membench/mem-timer-cancel.yml
index 0000000000..10938da3d1
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-timer-cancel.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-timer-cancel.c
+stlib: []
+target: testsuites/membench/mem-timer-cancel.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-timer-delete.yml b/spec/build/testsuites/membench/mem-timer-delete.yml
index 0000000000..a1ae8a1ac0
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-timer-delete.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-timer-delete.c
+stlib: []
+target: testsuites/membench/mem-timer-delete.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-timer-reset.yml b/spec/build/testsuites/membench/mem-timer-reset.yml
index 0000000000..1c7206d8f7
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-timer-reset.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-timer-reset.c
+stlib: []
+target: testsuites/membench/mem-timer-reset.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-timer-srv-after.yml b/spec/build/testsuites/membench/mem-timer-srv-after.yml
index 0000000000..c92ef9db54
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-timer-srv-after.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-timer-srv-after.c
+stlib: []
+target: testsuites/membench/mem-timer-srv-after.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-timer-srv-init.yml b/spec/build/testsuites/membench/mem-timer-srv-init.yml
index 0000000000..e0738de37f
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-timer-srv-init.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-timer-srv-init.c
+stlib: []
+target: testsuites/membench/mem-timer-srv-init.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-timer-srv-when.yml b/spec/build/testsuites/membench/mem-timer-srv-when.yml
index 0000000000..8ce76fe0b0
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-timer-srv-when.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-timer-srv-when.c
+stlib: []
+target: testsuites/membench/mem-timer-srv-when.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-timer-when.yml b/spec/build/testsuites/membench/mem-timer-when.yml
index 0000000000..f134f2c212
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-timer-when.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-timer-when.c
+stlib: []
+target: testsuites/membench/mem-timer-when.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-userext-create.yml b/spec/build/testsuites/membench/mem-userext-create.yml
index 0000000000..6da881c393
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-userext-create.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-userext-create.c
+stlib: []
+target: testsuites/membench/mem-userext-create.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/membench/mem-userext-delete.yml b/spec/build/testsuites/membench/mem-userext-delete.yml
index 0000000000..948818ceb5
--- /dev/null
+++ b/spec/build/testsuites/membench/mem-userext-delete.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/membench/mem-userext-delete.c
+stlib: []
+target: testsuites/membench/mem-userext-delete.norun.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/optmembench.yml b/spec/build/testsuites/optmembench.yml
index 0000000000..26c81ab56c
--- /dev/null
+++ b/spec/build/testsuites/optmembench.yml
@@ -0,0 +1,16 @@
+actions:
+- get-boolean: null
+- env-enable: null
+build-type: option
+copyrights:
+default:
+- enabled-by: true
+  value: false
+description: |
+  Build the memory benchmark programs (may be also enabled by BUILD_TESTS)
+enabled-by: true
+links: []
+name: BUILD_MEMBENCH
+type: build
diff --git a/testsuites/membench/mem-barrier-wait-rel-del.c b/testsuites/membench/mem-barrier-wait-rel-del.c
index 0000000000..2b55962bfd
--- /dev/null
+++ b/testsuites/membench/mem-barrier-wait-rel-del.c
@@ -0,0 +1,116 @@
+ * @file
+ * @ingroup RtemsBarrierValMemWaitRelDel
+ * Copyright (C) 2021 embedded brains GmbH & Co. KG
+ * are met:
+ * This file is part of the RTEMS quality process and was automatically
+ * generated.  If you find something that needs to be fixed or
+ * worded better please post a report or patch to an RTEMS mailing list
+ * or raise a bug report:
+ * https://www.rtems.org/bugs.html
+ * For information on updating and regenerating please refer to the How-To
+ * section in the Software Requirements Engineering chapter of the
+ * RTEMS Software Engineering manual.  The manual is provided as a part of
+ * a release.  For development sources please refer to the online
+ * documentation at:
+ * https://docs.rtems.org
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems.h>
+#include <rtems/test.h>
+ * @defgroup RtemsBarrierValMemWaitRelDel \
+ *   spec:/rtems/barrier/val/mem-wait-rel-del
+ * @ingroup RTEMSTestSuitesMembench
+ * @brief This static memory usage benchmark program facilitates a basic
+ *   application configuration with CONFIGURE_MAXIMUM_BARRIERS defined to one
+ *   and calls to rtems_barrier_create(), rtems_barrier_wait(),
+ *   rtems_barrier_release(), and rtems_barrier_delete().
+static void Init( rtems_task_argument arg )
+  (void) arg;
+  (void) rtems_barrier_create( 0, 0, 0, NULL );
+  (void) rtems_barrier_wait( 0, 0 );
+  (void) rtems_barrier_release( 0, NULL );
+  (void) rtems_barrier_delete( 0 );
+#define CONFIGURE_MAXIMUM_BARRIERS 1
+#define TASK_ATTRIBUTES RTEMS_DEFAULT_ATTRIBUTES
+#define TASK_STORAGE_SIZE \
+  RTEMS_TASK_STORAGE_SIZE( \
+    RTEMS_MINIMUM_STACK_SIZE, \
+    TASK_ATTRIBUTES   )
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 0
+#define CONFIGURE_DISABLE_NEWLIB_REENTRANCY
+#define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
+#define CONFIGURE_IDLE_TASK_STORAGE_SIZE RTEMS_MINIMUM_STACK_SIZE
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INIT_TASK_ATTRIBUTES TASK_ATTRIBUTES
+#define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_DEFAULT_MODES
+#define CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE TASK_STORAGE_SIZE
+#include <rtems/confdefs.h>
diff --git a/testsuites/membench/mem-barrier-wait-rel.c b/testsuites/membench/mem-barrier-wait-rel.c
index 0000000000..0d9ce0eab1
--- /dev/null
+++ b/testsuites/membench/mem-barrier-wait-rel.c
@@ -0,0 +1,114 @@
+ * @file
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsBarrierValMemWaitRel spec:/rtems/barrier/val/mem-wait-rel
+ *   and calls to rtems_barrier_create(), rtems_barrier_wait(), and
+ *   rtems_barrier_release().
+  (void) arg;
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-bsp-clock.c b/testsuites/membench/mem-bsp-clock.c
index 0000000000..d3974fda5c
--- /dev/null
+++ b/testsuites/membench/mem-bsp-clock.c
@@ -0,0 +1,109 @@
+ * @file
+ * @ingroup BspValMemClock
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup BspValMemClock spec:/bsp/val/mem-clock
+ *   application configuration with the clock driver enabled
+ *   (CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER).
+  (void) arg;
+  /* Nothing to do */
+    TASK_ATTRIBUTES   )
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
diff --git a/testsuites/membench/mem-clock-get-uptime.c b/testsuites/membench/mem-clock-get-uptime.c
index 0000000000..ec02ad212c
--- /dev/null
+++ b/testsuites/membench/mem-clock-get-uptime.c
@@ -0,0 +1,108 @@
+ * @file
+ * @ingroup RtemsClockValMemGetUptime
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsClockValMemGetUptime spec:/rtems/clock/val/mem-get-uptime
+ *   application configuration with a call to rtems_clock_get_uptime().
+  (void) arg;
+  (void) rtems_clock_get_uptime( NULL );
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-clock-set-get-tod.c b/testsuites/membench/mem-clock-set-get-tod.c
index 0000000000..09ed52f283
--- /dev/null
+++ b/testsuites/membench/mem-clock-set-get-tod.c
@@ -0,0 +1,110 @@
+ * @file
+ * @ingroup RtemsClockValMemSetGetTod
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsClockValMemSetGetTod spec:/rtems/clock/val/mem-set-get-tod
+ *   application configuration with calls to rtems_clock_set() and
+ *   rtems_clock_get_tod().
+  (void) arg;
+  (void) rtems_clock_set( NULL );
+  (void) rtems_clock_get_tod( NULL );
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-clock-set.c b/testsuites/membench/mem-clock-set.c
index 0000000000..b7a8922cf4
--- /dev/null
+++ b/testsuites/membench/mem-clock-set.c
@@ -0,0 +1,108 @@
+ * @file
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsClockValMemSet spec:/rtems/clock/val/mem-set
+ *   application configuration with a call to rtems_clock_set().
+  (void) arg;
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-event-snd-rcv.c b/testsuites/membench/mem-event-snd-rcv.c
index 0000000000..5972fc17c2
--- /dev/null
+++ b/testsuites/membench/mem-event-snd-rcv.c
@@ -0,0 +1,110 @@
+ * @file
+ * @ingroup RtemsEventValMemSndRcv
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsEventValMemSndRcv spec:/rtems/event/val/mem-snd-rcv
+ *   application configuration with calls to rtems_event_send() and
+ *   rtems_event_receive().
+  (void) arg;
+  (void) rtems_event_send( 0, 0 );
+  (void) rtems_event_receive( 0, 0, 0, NULL );
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-fatal-fatal.c b/testsuites/membench/mem-fatal-fatal.c
index 0000000000..fb72b5f339
--- /dev/null
+++ b/testsuites/membench/mem-fatal-fatal.c
@@ -0,0 +1,108 @@
+ * @file
+ * @ingroup RtemsFatalValMemFatal
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsFatalValMemFatal spec:/rtems/fatal/val/mem-fatal
+ *   application configuration with a call to rtems_fatal().
+  (void) arg;
+  rtems_fatal( 0, 0 );
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-message-bcst-rcv.c b/testsuites/membench/mem-message-bcst-rcv.c
index 0000000000..80c71866d1
--- /dev/null
+++ b/testsuites/membench/mem-message-bcst-rcv.c
@@ -0,0 +1,111 @@
+ * @file
+ * @ingroup RtemsMessageValMemBcstRcv
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsMessageValMemBcstRcv spec:/rtems/message/val/mem-bcst-rcv
+ *   application configuration with calls to rtems_message_queue_construct(),
+ *   rtems_message_queue_broadcast(), and rtems_message_queue_receive().
+  (void) arg;
+  (void) rtems_message_queue_construct( NULL, NULL );
+  (void) rtems_message_queue_broadcast( 0, NULL, 0, NULL );
+  (void) rtems_message_queue_receive( 0, NULL, NULL, 0, 0 );
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-message-snd-rcv-del.c b/testsuites/membench/mem-message-snd-rcv-del.c
index 0000000000..6ea5a0a8ab
--- /dev/null
+++ b/testsuites/membench/mem-message-snd-rcv-del.c
@@ -0,0 +1,114 @@
+ * @file
+ * @ingroup RtemsMessageValMemSndRcvDel
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsMessageValMemSndRcvDel \
+ *   spec:/rtems/message/val/mem-snd-rcv-del
+ *   rtems_message_queue_send(), rtems_message_queue_receive(), and
+ *   rtems_message_queue_delete().
+  (void) arg;
+  (void) rtems_message_queue_send( 0, NULL, 0 );
+  (void) rtems_message_queue_delete( 0 );
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-message-snd-rcv.c b/testsuites/membench/mem-message-snd-rcv.c
index 0000000000..026d00deab
--- /dev/null
+++ b/testsuites/membench/mem-message-snd-rcv.c
@@ -0,0 +1,111 @@
+ * @file
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsMessageValMemSndRcv spec:/rtems/message/val/mem-snd-rcv
+ *   rtems_message_queue_send(), and rtems_message_queue_receive().
+  (void) arg;
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-message-ugt-rcv.c b/testsuites/membench/mem-message-ugt-rcv.c
index 0000000000..7fab259550
--- /dev/null
+++ b/testsuites/membench/mem-message-ugt-rcv.c
@@ -0,0 +1,111 @@
+ * @file
+ * @ingroup RtemsMessageValMemUgtRcv
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsMessageValMemUgtRcv spec:/rtems/message/val/mem-ugt-rcv
+ *   rtems_message_queue_urgent(), and rtems_message_queue_receive().
+  (void) arg;
+  (void) rtems_message_queue_urgent( 0, NULL, 0 );
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-part-get-ret-del.c b/testsuites/membench/mem-part-get-ret-del.c
index 0000000000..a7d5f496be
--- /dev/null
+++ b/testsuites/membench/mem-part-get-ret-del.c
@@ -0,0 +1,115 @@
+ * @file
+ * @ingroup RtemsPartValMemGetRetDel
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsPartValMemGetRetDel spec:/rtems/part/val/mem-get-ret-del
+ *   application configuration with CONFIGURE_MAXIMUM_PARTITIONS defined to one
+ *   and calls to rtems_partition_create(), rtems_partition_get_buffer(),
+ *   rtems_partition_return_buffer(), and rtems_partition_delete().
+  (void) arg;
+  (void) rtems_partition_create( 0, NULL, 0, 0, 0, NULL );
+  (void) rtems_partition_get_buffer( 0, NULL );
+  (void) rtems_partition_return_buffer( 0, NULL );
+  (void) rtems_partition_delete( 0 );
+#define CONFIGURE_MAXIMUM_PARTITIONS 1
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-part-get-ret.c b/testsuites/membench/mem-part-get-ret.c
index 0000000000..1c6178d371
--- /dev/null
+++ b/testsuites/membench/mem-part-get-ret.c
@@ -0,0 +1,114 @@
+ * @file
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsPartValMemGetRet spec:/rtems/part/val/mem-get-ret
+ *   and calls to rtems_partition_create(), rtems_partition_get_buffer(), and
+ *   rtems_partition_return_buffer().
+  (void) arg;
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-ratemon-period-del.c b/testsuites/membench/mem-ratemon-period-del.c
index 0000000000..85e4133d02
--- /dev/null
+++ b/testsuites/membench/mem-ratemon-period-del.c
@@ -0,0 +1,114 @@
+ * @file
+ * @ingroup RtemsRatemonValMemPeriodDel
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsRatemonValMemPeriodDel spec:/rtems/ratemon/val/mem-period-del
+ *   application configuration with CONFIGURE_MAXIMUM_PERIODS defined to one
+ *   and calls to rtems_rate_monotonic_create(), rtems_rate_monotonic_period(),
+ *   and rtems_rate_monotonic_delete().
+  (void) arg;
+  (void) rtems_rate_monotonic_create( 0, NULL );
+  (void) rtems_rate_monotonic_period( 0, 0 );
+  (void) rtems_rate_monotonic_delete( 0 );
+#define CONFIGURE_MAXIMUM_PERIODS 1
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-ratemon-period.c b/testsuites/membench/mem-ratemon-period.c
index 0000000000..076be2994d
--- /dev/null
+++ b/testsuites/membench/mem-ratemon-period.c
@@ -0,0 +1,113 @@
+ * @file
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsRatemonValMemPeriod spec:/rtems/ratemon/val/mem-period
+ *   and calls to rtems_rate_monotonic_create() and
+ *   rtems_rate_monotonic_period().
+  (void) arg;
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-rtems-basic.c b/testsuites/membench/mem-rtems-basic.c
index 0000000000..4ab19cd2bf
--- /dev/null
+++ b/testsuites/membench/mem-rtems-basic.c
@@ -0,0 +1,111 @@
+ * @file
+ * @ingroup RtemsValMemBasic
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsValMemBasic spec:/rtems/val/mem-basic
+ *   application configuration.
+ * This resource benchmark is configured for exactly one processor, no clock
+ * driver, no Newlib reentrancy support, and no file system.
+  (void) arg;
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-rtems-smp-1.c b/testsuites/membench/mem-rtems-smp-1.c
index 0000000000..879e6914e3
--- /dev/null
+++ b/testsuites/membench/mem-rtems-smp-1.c
@@ -0,0 +1,115 @@
+ * @file
+ * @ingroup RtemsValMemSmp1
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsValMemSmp1 spec:/rtems/val/mem-smp-1
+ *   application configuration with CONFIGURE_MAXIMUM_PROCESSORS defined to one
+ *   using the SMP EDF scheduler (CONFIGURE_SCHEDULER_EDF_SMP).
+  (void) arg;
+#define CONFIGURE_MAXIMUM_PROCESSORS 1
+#if defined(RTEMS_SMP)
+#define CONFIGURE_SCHEDULER_EDF_SMP
+#endif
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-rtems-smp-global-2.c b/testsuites/membench/mem-rtems-smp-global-2.c
index 0000000000..67de99ce27
--- /dev/null
+++ b/testsuites/membench/mem-rtems-smp-global-2.c
@@ -0,0 +1,115 @@
+ * @file
+ * @ingroup RtemsValMemSmpGlobal2
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsValMemSmpGlobal2 spec:/rtems/val/mem-smp-global-2
+ *   application configuration with CONFIGURE_MAXIMUM_PROCESSORS defined to two
+ *   using the global SMP EDF scheduler (CONFIGURE_SCHEDULER_EDF_SMP).
+  (void) arg;
+#define CONFIGURE_MAXIMUM_PROCESSORS 2
+#endif
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-rtems-smp-global-4.c b/testsuites/membench/mem-rtems-smp-global-4.c
index 0000000000..42acd643f1
--- /dev/null
+++ b/testsuites/membench/mem-rtems-smp-global-4.c
@@ -0,0 +1,115 @@
+ * @file
+ * @ingroup RtemsValMemSmpGlobal4
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsValMemSmpGlobal4 spec:/rtems/val/mem-smp-global-4
+ *   four using the global SMP EDF scheduler (CONFIGURE_SCHEDULER_EDF_SMP).
+  (void) arg;
+#define CONFIGURE_MAXIMUM_PROCESSORS 4
+#endif
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-rtems-smp-part-2.c b/testsuites/membench/mem-rtems-smp-part-2.c
index 0000000000..2648352d83
--- /dev/null
+++ b/testsuites/membench/mem-rtems-smp-part-2.c
@@ -0,0 +1,132 @@
+ * @file
+ * @ingroup RtemsValMemSmpPart2
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsValMemSmpPart2 spec:/rtems/val/mem-smp-part-2
+ *   using one SMP EDF scheduler for each configured processor
+ *   (CONFIGURE_SCHEDULER_EDF_SMP).
+  (void) arg;
+#include <rtems/scheduler.h>
+RTEMS_SCHEDULER_EDF_SMP( a );
+RTEMS_SCHEDULER_EDF_SMP( b );
+#define NAME( x ) rtems_build_name( x, ' ', ' ', ' ' )
+#define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
+  RTEMS_SCHEDULER_TABLE_EDF_SMP( a, NAME( 'A' ) ), \
+  RTEMS_SCHEDULER_TABLE_EDF_SMP( b, NAME( 'B' ) )
+#define CONFIGURE_SCHEDULER_ASSIGNMENTS \
+  RTEMS_SCHEDULER_ASSIGN( 0, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY ), \
+  RTEMS_SCHEDULER_ASSIGN( 1, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY )
+#endif
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-rtems-smp-part-4.c b/testsuites/membench/mem-rtems-smp-part-4.c
index 0000000000..b237ae2432
--- /dev/null
+++ b/testsuites/membench/mem-rtems-smp-part-4.c
@@ -0,0 +1,140 @@
+ * @file
+ * @ingroup RtemsValMemSmpPart4
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsValMemSmpPart4 spec:/rtems/val/mem-smp-part-4
+ *   four using one SMP EDF scheduler for each configured processor
+  (void) arg;
+RTEMS_SCHEDULER_EDF_SMP( c );
+RTEMS_SCHEDULER_EDF_SMP( d );
+  RTEMS_SCHEDULER_TABLE_EDF_SMP( b, NAME( 'B' ) ), \
+  RTEMS_SCHEDULER_TABLE_EDF_SMP( c, NAME( 'C' ) ), \
+  RTEMS_SCHEDULER_TABLE_EDF_SMP( d, NAME( 'D' ) )
+  RTEMS_SCHEDULER_ASSIGN( 1, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY ), \
+  RTEMS_SCHEDULER_ASSIGN( 2, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY ), \
+  RTEMS_SCHEDULER_ASSIGN( 3, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY )
+#endif
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-scheduler-add-cpu.c b/testsuites/membench/mem-scheduler-add-cpu.c
index 0000000000..29f3e43d57
--- /dev/null
+++ b/testsuites/membench/mem-scheduler-add-cpu.c
@@ -0,0 +1,114 @@
+ * @file
+ * @ingroup RtemsSchedulerValMemAddCpu
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsSchedulerValMemAddCpu spec:/rtems/scheduler/val/mem-add-cpu
+ *   application configuration with a call to rtems_scheduler_add_processor().
+  (void) arg;
+  (void) rtems_scheduler_add_processor( 0, 0 );
+#endif
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-scheduler-rm-cpu.c b/testsuites/membench/mem-scheduler-rm-cpu.c
index 0000000000..b1c39d0393
--- /dev/null
+++ b/testsuites/membench/mem-scheduler-rm-cpu.c
@@ -0,0 +1,115 @@
+ * @file
+ * @ingroup RtemsSchedulerValMemRmCpu
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsSchedulerValMemRmCpu spec:/rtems/scheduler/val/mem-rm-cpu
+ *   rtems_scheduler_remove_processor().
+  (void) arg;
+  (void) rtems_scheduler_remove_processor( 0, 0 );
+#endif
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-sem-obt-rel-del.c b/testsuites/membench/mem-sem-obt-rel-del.c
index 0000000000..80473e7051
--- /dev/null
+++ b/testsuites/membench/mem-sem-obt-rel-del.c
@@ -0,0 +1,115 @@
+ * @file
+ * @ingroup RtemsSemValMemObtRelDel
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsSemValMemObtRelDel spec:/rtems/sem/val/mem-obt-rel-del
+ *   application configuration with CONFIGURE_MAXIMUM_SEMAPHORES defined to one
+ *   and calls to rtems_semaphore_create(), rtems_semaphore_obtain(),
+ *   rtems_semaphore_release(), and rtems_semaphore_delete().
+  (void) arg;
+  (void) rtems_semaphore_create( 0, 0, 0, 0, NULL );
+  (void) rtems_semaphore_obtain( 0, 0, 0 );
+  (void) rtems_semaphore_release( 0 );
+  (void) rtems_semaphore_delete( 0 );
+#define CONFIGURE_MAXIMUM_SEMAPHORES 1
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-sem-obt-rel.c b/testsuites/membench/mem-sem-obt-rel.c
index 0000000000..c97236c4e2
--- /dev/null
+++ b/testsuites/membench/mem-sem-obt-rel.c
@@ -0,0 +1,114 @@
+ * @file
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsSemValMemObtRel spec:/rtems/sem/val/mem-obt-rel
+ *   and calls to rtems_semaphore_create(), rtems_semaphore_obtain(), and
+ *   rtems_semaphore_release().
+  (void) arg;
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-signal-catch-snd.c b/testsuites/membench/mem-signal-catch-snd.c
index 0000000000..0794eb509c
--- /dev/null
+++ b/testsuites/membench/mem-signal-catch-snd.c
@@ -0,0 +1,110 @@
+ * @file
+ * @ingroup RtemsSignalValMemCatchSnd
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsSignalValMemCatchSnd spec:/rtems/signal/val/mem-catch-snd
+ *   application configuration with calls to rtems_signal_catch() and
+ *   rtems_signal_send().
+  (void) arg;
+  (void) rtems_signal_catch( NULL, 0 );
+  (void) rtems_signal_send( 0, 0 );
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-task-delete.c b/testsuites/membench/mem-task-delete.c
index 0000000000..9da6ef57a6
--- /dev/null
+++ b/testsuites/membench/mem-task-delete.c
@@ -0,0 +1,108 @@
+ * @file
+ * @ingroup RtemsTaskValMemDelete
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsTaskValMemDelete spec:/rtems/task/val/mem-delete
+ *   application configuration with a call to rtems_task_delete().
+  (void) arg;
+  (void) rtems_task_delete( 0 );
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-task-exit.c b/testsuites/membench/mem-task-exit.c
index 0000000000..c2feb9b406
--- /dev/null
+++ b/testsuites/membench/mem-task-exit.c
@@ -0,0 +1,108 @@
+ * @file
+ * @ingroup RtemsTaskValMemExit
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsTaskValMemExit spec:/rtems/task/val/mem-exit
+ *   application configuration with a call to rtems_task_exit().
+  (void) arg;
+  rtems_task_exit();
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-task-get-affinity.c b/testsuites/membench/mem-task-get-affinity.c
index 0000000000..6bba7888c0
--- /dev/null
+++ b/testsuites/membench/mem-task-get-affinity.c
@@ -0,0 +1,108 @@
+ * @file
+ * @ingroup RtemsTaskValMemGetAffinity
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsTaskValMemGetAffinity spec:/rtems/task/val/mem-get-affinity
+ *   application configuration with a call to rtems_task_get_affinity().
+  (void) arg;
+  (void) rtems_task_get_affinity( 0, 0, NULL );
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-task-get-priority.c b/testsuites/membench/mem-task-get-priority.c
index 0000000000..9a45a77e9f
--- /dev/null
+++ b/testsuites/membench/mem-task-get-priority.c
@@ -0,0 +1,108 @@
+ * @file
+ * @ingroup RtemsTaskValMemGetPriority
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsTaskValMemGetPriority spec:/rtems/task/val/mem-get-priority
+ *   application configuration with a call to rtems_task_get_priority().
+  (void) arg;
+  (void) rtems_task_get_priority( 0, 0, NULL );
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-task-get-scheduler.c b/testsuites/membench/mem-task-get-scheduler.c
index 0000000000..4a40af505e
--- /dev/null
+++ b/testsuites/membench/mem-task-get-scheduler.c
@@ -0,0 +1,108 @@
+ * @file
+ * @ingroup RtemsTaskValMemGetScheduler
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsTaskValMemGetScheduler spec:/rtems/task/val/mem-get-scheduler
+ *   application configuration with a call to rtems_task_get_scheduler().
+  (void) arg;
+  (void) rtems_task_get_scheduler( 0, NULL );
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-task-mode.c b/testsuites/membench/mem-task-mode.c
index 0000000000..cdf1007289
--- /dev/null
+++ b/testsuites/membench/mem-task-mode.c
@@ -0,0 +1,108 @@
+ * @file
+ * @ingroup RtemsTaskValMemMode
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsTaskValMemMode spec:/rtems/task/val/mem-mode
+ *   application configuration with a call to rtems_task_mode().
+  (void) arg;
+  (void) rtems_task_mode( 0, 0, 0 );
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-task-restart.c b/testsuites/membench/mem-task-restart.c
index 0000000000..7e613cab5c
--- /dev/null
+++ b/testsuites/membench/mem-task-restart.c
@@ -0,0 +1,108 @@
+ * @file
+ * @ingroup RtemsTaskValMemRestart
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsTaskValMemRestart spec:/rtems/task/val/mem-restart
+ *   application configuration with a call to rtems_task_restart().
+  (void) arg;
+  (void) rtems_task_restart( 0, 0 );
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-task-set-affinity.c b/testsuites/membench/mem-task-set-affinity.c
index 0000000000..390f669a62
--- /dev/null
+++ b/testsuites/membench/mem-task-set-affinity.c
@@ -0,0 +1,108 @@
+ * @file
+ * @ingroup RtemsTaskValMemSetAffinity
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsTaskValMemSetAffinity spec:/rtems/task/val/mem-set-affinity
+ *   application configuration with a call to rtems_task_set_affinity().
+  (void) arg;
+  (void) rtems_task_set_affinity( 0, 0, NULL );
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-task-set-priority.c b/testsuites/membench/mem-task-set-priority.c
index 0000000000..5ac42e0735
--- /dev/null
+++ b/testsuites/membench/mem-task-set-priority.c
@@ -0,0 +1,108 @@
+ * @file
+ * @ingroup RtemsTaskValMemSetPriority
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsTaskValMemSetPriority spec:/rtems/task/val/mem-set-priority
+ *   application configuration with a call to rtems_task_set_priority().
+  (void) arg;
+  (void) rtems_task_set_priority( 0, 0, NULL );
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-task-set-scheduler.c b/testsuites/membench/mem-task-set-scheduler.c
index 0000000000..f758f5a78d
--- /dev/null
+++ b/testsuites/membench/mem-task-set-scheduler.c
@@ -0,0 +1,108 @@
+ * @file
+ * @ingroup RtemsTaskValMemSetScheduler
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsTaskValMemSetScheduler spec:/rtems/task/val/mem-set-scheduler
+ *   application configuration with a call to rtems_task_set_scheduler().
+  (void) arg;
+  (void) rtems_task_set_scheduler( 0, 0, 0 );
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-task-sus-res.c b/testsuites/membench/mem-task-sus-res.c
index 0000000000..0869206132
--- /dev/null
+++ b/testsuites/membench/mem-task-sus-res.c
@@ -0,0 +1,110 @@
+ * @file
+ * @ingroup RtemsTaskValMemSusRes
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsTaskValMemSusRes spec:/rtems/task/val/mem-sus-res
+ *   application configuration with calls to rtems_task_suspend() and
+ *   rtems_task_resume().
+  (void) arg;
+  (void) rtems_task_suspend( 0 );
+  (void) rtems_task_resume( 0 );
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-task-wake-after.c b/testsuites/membench/mem-task-wake-after.c
index 0000000000..677956ed81
--- /dev/null
+++ b/testsuites/membench/mem-task-wake-after.c
@@ -0,0 +1,108 @@
+ * @file
+ * @ingroup RtemsTaskValMemWakeAfter
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsTaskValMemWakeAfter spec:/rtems/task/val/mem-wake-after
+ *   application configuration with a call to rtems_task_wake_after().
+  (void) arg;
+  (void) rtems_task_wake_after( 0 );
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-task-wake-when.c b/testsuites/membench/mem-task-wake-when.c
index 0000000000..0ca37cd98a
--- /dev/null
+++ b/testsuites/membench/mem-task-wake-when.c
@@ -0,0 +1,108 @@
+ * @file
+ * @ingroup RtemsTaskValMemWakeWhen
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsTaskValMemWakeWhen spec:/rtems/task/val/mem-wake-when
+ *   application configuration with a call to rtems_task_wake_when().
+  (void) arg;
+  (void) rtems_task_wake_when( NULL );
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-timer-after.c b/testsuites/membench/mem-timer-after.c
index 0000000000..94fc222de3
--- /dev/null
+++ b/testsuites/membench/mem-timer-after.c
@@ -0,0 +1,110 @@
+ * @file
+ * @ingroup RtemsTimerValMemAfter
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsTimerValMemAfter spec:/rtems/timer/val/mem-after
+ *   application configuration with calls to rtems_timer_create() and
+ *   rtems_timer_fire_after().
+  (void) arg;
+  (void) rtems_timer_create( 0, NULL );
+  (void) rtems_timer_fire_after( 0, 0, NULL, NULL );
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-timer-cancel.c b/testsuites/membench/mem-timer-cancel.c
index 0000000000..acadefc8ac
--- /dev/null
+++ b/testsuites/membench/mem-timer-cancel.c
@@ -0,0 +1,110 @@
+ * @file
+ * @ingroup RtemsTimerValMemCancel
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsTimerValMemCancel spec:/rtems/timer/val/mem-cancel
+ *   rtems_timer_cancel().
+  (void) arg;
+  (void) rtems_timer_cancel( 0 );
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-timer-delete.c b/testsuites/membench/mem-timer-delete.c
index 0000000000..ab8649dffc
--- /dev/null
+++ b/testsuites/membench/mem-timer-delete.c
@@ -0,0 +1,110 @@
+ * @file
+ * @ingroup RtemsTimerValMemDelete
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsTimerValMemDelete spec:/rtems/timer/val/mem-delete
+ *   rtems_timer_delete().
+  (void) arg;
+  (void) rtems_timer_delete( 0 );
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-timer-reset.c b/testsuites/membench/mem-timer-reset.c
index 0000000000..719030108d
--- /dev/null
+++ b/testsuites/membench/mem-timer-reset.c
@@ -0,0 +1,110 @@
+ * @file
+ * @ingroup RtemsTimerValMemReset
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsTimerValMemReset spec:/rtems/timer/val/mem-reset
+ *   rtems_timer_reset().
+  (void) arg;
+  (void) rtems_timer_reset( 0 );
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-timer-srv-after.c b/testsuites/membench/mem-timer-srv-after.c
index 0000000000..dbb7d2a1c4
--- /dev/null
+++ b/testsuites/membench/mem-timer-srv-after.c
@@ -0,0 +1,110 @@
+ * @file
+ * @ingroup RtemsTimerValMemSrvAfter
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsTimerValMemSrvAfter spec:/rtems/timer/val/mem-srv-after
+ *   rtems_timer_server_fire_after().
+  (void) arg;
+  (void) rtems_timer_server_fire_after( 0, 0, NULL, NULL );
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-timer-srv-init.c b/testsuites/membench/mem-timer-srv-init.c
index 0000000000..a4a87121ac
--- /dev/null
+++ b/testsuites/membench/mem-timer-srv-init.c
@@ -0,0 +1,123 @@
+ * @file
+ * @ingroup RtemsTimerValMemSrvInit
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsTimerValMemSrvInit spec:/rtems/timer/val/mem-srv-init
+ *   application configuration with a call to rtems_timer_initiate_server().
+  (void) arg;
+  (void) rtems_timer_initiate_server( 0, 0, 0 );
+static void *task_stack_allocate( size_t size )
+  (void) size;
+  return NULL;
+static void task_stack_deallocate( void *stack )
+  (void) stack;
+#define CONFIGURE_TASK_STACK_ALLOCATOR task_stack_allocate
+#define CONFIGURE_TASK_STACK_DEALLOCATOR task_stack_deallocate
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-timer-srv-when.c b/testsuites/membench/mem-timer-srv-when.c
index 0000000000..ab6595e986
--- /dev/null
+++ b/testsuites/membench/mem-timer-srv-when.c
@@ -0,0 +1,110 @@
+ * @file
+ * @ingroup RtemsTimerValMemSrvWhen
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsTimerValMemSrvWhen spec:/rtems/timer/val/mem-srv-when
+ *   rtems_timer_server_fire_when().
+  (void) arg;
+  (void) rtems_timer_server_fire_when( 0, NULL, NULL, NULL );
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-timer-when.c b/testsuites/membench/mem-timer-when.c
index 0000000000..551c84fc4f
--- /dev/null
+++ b/testsuites/membench/mem-timer-when.c
@@ -0,0 +1,110 @@
+ * @file
+ * @ingroup RtemsTimerValMemWhen
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsTimerValMemWhen spec:/rtems/timer/val/mem-when
+ *   rtems_timer_fire_when().
+  (void) arg;
+  (void) rtems_timer_fire_when( 0, NULL, NULL, NULL );
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-userext-create.c b/testsuites/membench/mem-userext-create.c
index 0000000000..74a4284cf9
--- /dev/null
+++ b/testsuites/membench/mem-userext-create.c
@@ -0,0 +1,111 @@
+ * @file
+ * @ingroup RtemsUserextValMemCreate
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsUserextValMemCreate spec:/rtems/userext/val/mem-create
+ *   application configuration with CONFIGURE_MAXIMUM_USER_EXTENSIONS defined
+ *   to one and a call to rtems_extension_create().
+  (void) arg;
+  (void) rtems_extension_create( 0, NULL, NULL );
+#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 1
+    TASK_ATTRIBUTES   )
diff --git a/testsuites/membench/mem-userext-delete.c b/testsuites/membench/mem-userext-delete.c
index 0000000000..81983e5a7a
--- /dev/null
+++ b/testsuites/membench/mem-userext-delete.c
@@ -0,0 +1,112 @@
+ * @file
+ * @ingroup RtemsUserextValMemDelete
+ * are met:
+#endif
+#include <rtems.h>
+ * @defgroup RtemsUserextValMemDelete spec:/rtems/userext/val/mem-delete
+ *   to one and calls to rtems_extension_create() and rtems_extension_delete().
+  (void) arg;
+  (void) rtems_extension_delete( 0 );
+    TASK_ATTRIBUTES   )
2.35.3
