[PATCH rtems-libbsd/6-freebsd-12 2/3] syscall/open: Reference the path info directory vnode
Cedric Berger cedric at precidata.com
Thu Jul 20 18:11:01 UTC 2023
On 20.07.23 09:52, Chris Johns wrote:
> On 20/7/2023 5:24 pm, Cedric Berger wrote:
>> On 20.07.23 07:45, chrisj at rtems.org wrote:
>>> From: Chris Johns <chrisj at rtems.org>
>>> The kernel open call requires a path so to open a file we need to
>>> set the current directory to the parent vnode. If the open mode is
>>> create the path info vnode is the directory to perform the open
>>> create in. Using the parent node creates the file in wrong path.
>>> Updates #4723
>>>    rtemsbsd/rtems/rtems-bsd-syscall-api.c | 24 ++++++---
>>>    testsuite/nfs01/test_main.c            | 75 ++++++++++++++++----------
>>>    2 files changed, 64 insertions(+), 35 deletions(-)
>>> diff --git a/rtemsbsd/rtems/rtems-bsd-syscall-api.c
>>> b/rtemsbsd/rtems/rtems-bsd-syscall-api.c
>>> index 76fc8ad7..cfceb768 100644
>>> --- a/rtemsbsd/rtems/rtems-bsd-syscall-api.c
>>> +++ b/rtemsbsd/rtems/rtems-bsd-syscall-api.c
>>> @@ -931,9 +931,18 @@ rtems_bsd_sysgen_open_node(
>>>        } else {
>>>            rtems_filesystem_location_info_t *rootloc =
>>>                &iop->pathinfo.mt_entry->mt_fs_root->location;
>>> +         * We need the parent directory so open can find the
>>> +         * the entry. If we are creating the file the pathinfo
>> the the
> Yeah and thanks for the review. I think this should be:
>   * entry. If we are creating the file the pathinfo
>   * vnode entry is the directory to open uses to create
>   * the file in.
Yes,
Cedric
