[PATCH rtems-libbsd/6-freebsd-12 v2 4/4] nfs: Support multiple mounts with the same path basename
chrisj at rtems.org chrisj at rtems.org
Fri Jul 21 05:02:37 UTC 2023
NFSv4 mounts NFS file systems to the flat root of a pseudo file
system. This change allow the same basename to be used.
 rtemsbsd/fs/nfsclient/nfs.c            | 31 +++++++++++++++++++------
 rtemsbsd/rtems/rtems-bsd-syscall-api.c | 32 +++++++++++---------------
 2 files changed, 37 insertions(+), 26 deletions(-)
diff --git a/rtemsbsd/fs/nfsclient/nfs.c b/rtemsbsd/fs/nfsclient/nfs.c
index ffbf7f4d..a3a29b62 100644
--- a/rtemsbsd/fs/nfsclient/nfs.c
+++ b/rtemsbsd/fs/nfsclient/nfs.c
@@ -830,8 +830,10 @@ rtems_nfs_initialize(
     rtems_filesystem_mount_table_entry_t *mt_entry, const void *data)
 	struct nfs_args args;
-	const char *fspath = NULL;
+	static int mount_counter;
+	char fspath[NAME_MAX + 1];
 	char *at;
+	int len;
 	int error;
 	if (RTEMS_DEBUG) {
@@ -923,15 +925,30 @@ rtems_nfs_initialize(
 	rtems_bsd_vfs_mount_init(mt_entry);
-	fspath = mt_entry->target;
-	if (*fspath == '/') {
-		++fspath;
+	at = mt_entry->target + strlen(mt_entry->target);
+	len = 0;
+	while (at != mt_entry->target && !rtems_filesystem_is_delimiter(at[-1])) {
+		at--;
+		len++;
-	if (strchr(fspath, '/') != 0) {
+	 * Account for the mount number and leading `/`
+	if (len >= sizeof(fspath) - (6 + 2)) {
 		error = EINVAL;
 		goto out;
+	 * Append a unique number to the end of the path created in
+	 * the FreeBSD root file system. All mounts are in the root
+	 * directory of the root file system and so flat. A user could
+	 * use different mount paths with the same end name. Without
+	 * the counter appended they would clash.
+	snprintf(fspath, sizeof(fspath), "/%s-%d", at, mount_counter++);
 	if (getnfsargs(mt_entry->dev, &args) < 0) {
 		if (RTEMS_DEBUG)
 			printf(
@@ -949,7 +966,7 @@ rtems_nfs_initialize(
 	 * export then find the vnode and hold it. Make sure we find the root
 	 * node of the NFS share and the not the root file system's mount node.
-	error = rtems_bsd_rootfs_mkdir(fspath);
+	error = rtems_bsd_rootfs_mkdir(fspath + 1);
 	if (error == 0) {
 		struct addrinfo *ai;
 		enum tryret tryret;
@@ -964,7 +981,7 @@ rtems_nfs_initialize(
 			if (tryret == TRYRET_SUCCESS) {
 				error = nfs_trymount(mt_entry, ai, &args, fspath, data);
 				if (RTEMS_DEBUG)
-						printf("nfs: mount: (%d) %s\n", error, strerror(error));
+					printf("nfs: mount: (%d) %s\n", error, strerror(error));
 				break;
 			} else {
 				error = EIO;
diff --git a/rtemsbsd/rtems/rtems-bsd-syscall-api.c b/rtemsbsd/rtems/rtems-bsd-syscall-api.c
index 142e4faf..81361e94 100644
--- a/rtemsbsd/rtems/rtems-bsd-syscall-api.c
+++ b/rtemsbsd/rtems/rtems-bsd-syscall-api.c
@@ -889,6 +889,7 @@ rtems_bsd_sysgen_open_node(
 	struct vnode *cdir;
 	struct vnode *rdir;
 	const char *opath;
+	rtems_filesystem_location_info_t *rootloc;
 	int opathlen;
 	int fd;
 	int error;
@@ -902,6 +903,8 @@ rtems_bsd_sysgen_open_node(
 	fdp = td->td_proc->p_fd;
+	rootloc = &iop->pathinfo.mt_entry->mt_fs_root->location;
 	 * There is no easy or clean means to open a vnode and follow the
 	 * POSIX open semantics. See `kern_openat`. You can open a vnode but
@@ -912,11 +915,16 @@ rtems_bsd_sysgen_open_node(
 	 * parent directory vnode to position ourselves in the parent
 	 * directory. The pathloc vnode points to the '.' or '..'  directory.
-	opath = path + strlen(path);
-	opathlen = 0;
-	while (opath != path && !rtems_filesystem_is_delimiter(opath[-1])) {
-		opath--;
-		opathlen++;
+	if (rtems_bsd_libio_loc_to_vnode(&iop->pathinfo) ==
+	    rtems_bsd_libio_loc_to_vnode(rootloc)) {
+		opath = ".";
+	} else {
+		opath = path + strlen(path);
+		opathlen = 0;
+		while (opath != path && !rtems_filesystem_is_delimiter(opath[-1])) {
+			opath--;
+			opathlen++;
 	if (rtems_filesystem_is_current_directory(opath, opathlen) ||
 	    rtems_filesystem_is_parent_directory(opath, opathlen)) {
@@ -929,8 +937,6 @@ rtems_bsd_sysgen_open_node(
 		opath = ".";
 		cdir = rtems_bsd_libio_loc_to_vnode(&iop->pathinfo);
 	} else {
-		rtems_filesystem_location_info_t *rootloc =
-		    &iop->pathinfo.mt_entry->mt_fs_root->location;
 		 * We need the parent directory so open can find the
 		 * entry. If we are creating the file the pathinfo
@@ -943,18 +949,6 @@ rtems_bsd_sysgen_open_node(
 		if (fdp->fd_cdir == NULL) {
 			cdir = rtems_bsd_libio_loc_to_vnode_dir(rootloc);
-		} else if (rtems_bsd_libio_loc_to_vnode(&iop->pathinfo) ==
-				rtems_bsd_libio_loc_to_vnode(rootloc)) {
-			 * If this is a directory and this is the root node of
-			 * the mounted file system we need to move up the
-			 * hidden pseudo file system node.
-			if (isdir) {
-				cdir = rootvnode;
-			} else {
-				cdir = rtems_bsd_libio_loc_to_vnode(rootloc);
2.37.1
