[PATCH] fix type and logic issue when libbsd checking is enforced by the user code
Karel Gardas karel at functional.vision
Sat Jul 22 15:04:40 UTC 2023
Fixes #4930.
 rtems_bsd.py | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/rtems_bsd.py b/rtems_bsd.py
index 7fbe66f..8faae10 100644
--- a/rtems_bsd.py
+++ b/rtems_bsd.py
@@ -71,8 +71,8 @@ def bsp_configure(conf, arch_bsp, mandatory=True):
                        'configure RTEMS with --disable-networking')
         rtems_libbsd_path = conf.options.rtems_libbsd
         if rtems_libbsd_path is None:
-            if conf.options.rtems is None:
-                rtems_libbsd_path = conf.options.rtems
+            if conf.options.rtems_path is not None:
+                rtems_libbsd_path = conf.options.rtems_path
             else:
                 rtems_libbsd_path = conf.env.PREFIX
2.25.1
