[PATCH rtems 1/2] bsps/shared: Add MCP7940M RTC driver
Christian Mauderer christian.mauderer at embedded-brains.de
Mon Jul 24 14:03:09 UTC 2023
The MCP7940M is a I2C RTC chip. The new driver uses the dev/i2c API to
support the RTC. It is written with the intention, that the driver can
be adapted to other RTCs with a similar register layout by just
replacing the initialization function.
 bsps/include/libchip/mcp7940m-rtc.h | 103 ++++++++
 bsps/shared/dev/rtc/mcp7940m.c      | 362 ++++++++++++++++++++++++++++
 spec/build/bsps/obj.yml             |   2 +
 3 files changed, 467 insertions(+)
 create mode 100644 bsps/include/libchip/mcp7940m-rtc.h
 create mode 100644 bsps/shared/dev/rtc/mcp7940m.c
diff --git a/bsps/include/libchip/mcp7940m-rtc.h b/bsps/include/libchip/mcp7940m-rtc.h
new file mode 100644
index 0000000000..266400dfba
--- /dev/null
+++ b/bsps/include/libchip/mcp7940m-rtc.h
@@ -0,0 +1,103 @@
+ * Copyright (C) 2023 embedded brains GmbH & Co. KG
+ * are met:
+#ifndef LIBCHIP_MCP7940M_RTC_H
+#define LIBCHIP_MCP7940M_RTC_H
+#include <rtems.h>
+#include <rtems/thread.h>
+#include <libchip/rtc.h>
+#include <stdint.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+extern const rtc_fns rtc_mcp7940m_fns;
+bool rtc_mcp7940m_probe(int minor);
+ * It is expected, that the RTC can be accessed as a raw file. A pointer to a
+ * constant string with the name of that device has to be passed to the table
+ * initializer.
+ * The MCP7940M uses an EEPROM-like interface. So you could for example use the
+ * following initialization:
+ * Define a context for the RTC somewhere:
+ *   static struct mcp7940m_rtc rtc_ctx =
+ *     MCP7940M_RTC_INITIALIZER("/dev/i2c-1", 0x6F, true);
+ * Then you can use the following for the RTC_Table:
+ *   MCP7940M_RTC_TBL_ENTRY("/dev/rtc", &rtc_ctx)
+struct mcp7940m_rtc {
+  /** Just initialize with RTEMS_MUTEX_INITIALIZER('mcp7940'). */
+  rtems_mutex mutex;
+  /** The path of the I2C bus device. */
+  const char *i2c_bus_path;
+  /** I2C address. */
+  uint8_t i2c_addr;
+  /** True if a crystal should be used. False if an oscillator is connected. */
+  bool crystal;
+  /** Whether the RTC has already been initialized. Used internally. */
+  bool initialized;
+#define MCP7940M_RTC_INITIALIZER(i2c_path, i2c_address, has_crystal) { \
+    .mutex = RTEMS_MUTEX_INITIALIZER("mcp7940m"), \
+    .i2c_bus_path = i2c_path, \
+    .i2c_addr = i2c_address, \
+    .crystal = has_crystal, \
+    .initialized = false, \
+#define MCP7940M_RTC_TBL_ENTRY(dev_name, mcp7940m_rtc_ctx) \
+    .sDeviceName = dev_name, \
+    .deviceType = RTC_CUSTOM, \
+    .pDeviceFns = &rtc_mcp7940m_fns, \
+    .deviceProbe = rtc_mcp7940m_probe, \
+    .pDeviceParams = (void *)mcp7940m_rtc_ctx, \
+    .ulCtrlPort1 = 0, \
+    .ulDataPort = 0, \
+    .getRegister = NULL, \
+    .setRegister = NULL, \
+#ifdef __cplusplus
+#endif /* LIBCHIP_MCP7940M_RTC_H */
diff --git a/bsps/shared/dev/rtc/mcp7940m.c b/bsps/shared/dev/rtc/mcp7940m.c
index 0000000000..78a4f21b58
--- /dev/null
+++ b/bsps/shared/dev/rtc/mcp7940m.c
@@ -0,0 +1,362 @@
+ * are met:
+ * Note: This driver implements only the basic RTC functionality of the
+ * MCP7940M. It tries not to touch any register fields except for the basic
+ * date/time fields in the get/set time functions. That way it should be
+ * possible to re-use the driver for similar RTCs by just replacing the
+ * initialization function. Suggested method for that: Add a field to the struct
+ * mcp7940m_rtc with a function pointer that points to the initialization
+ * function.
+ * All flags that are considered MCP7940M specific have a MCP7940M in the name.
+ * Only 24 hour format is supported. If this driver is the only ones who write
+ * the RTC, that shouldn't be a problem.
+ * The weekday register is not used. It has a user-defined representation anyway
+ * and therefore doesn't really matter.
+#include <dev/i2c/i2c.h>
+#include <libchip/mcp7940m-rtc.h>
+#include <rtems/score/sysstate.h>
+#include <rtems/score/todimpl.h>
+#include <fcntl.h>
+#include <string.h>
+#include <sys/stat.h>
+#include <unistd.h>
+#define REG_RTCSEC 0x00u
+#define RTCSEC_SECBCD_SHIFT  0u
+#define RTCSEC_SECBCD_MASK   (0x7fu << RTCSEC_SECBCD_SHIFT)
+#define RTCSEC_SECBCD(x)     (((x) << RTCSEC_SECBCD_SHIFT) & RTCSEC_SECBCD_MASK)
+#define RTCSEC_SECBCD_GET(x) (((x) & RTCSEC_SECBCD_MASK) >> RTCSEC_SECBCD_SHIFT)
+#define MCP7940M_RTCSEC_ST   (0x01u << 7)
+#define REG_RTCMIN 0x01
+#define RTCMIN_MINBCD_SHIFT  0u
+#define RTCMIN_MINBCD_MASK   (0x7fu << RTCMIN_MINBCD_SHIFT)
+#define RTCMIN_MINBCD(x)     (((x) << RTCMIN_MINBCD_SHIFT) & RTCMIN_MINBCD_MASK)
+#define RTCMIN_MINBCD_GET(x) (((x) & RTCMIN_MINBCD_MASK) >> RTCMIN_MINBCD_SHIFT)
+#define REG_RTCHOUR 0x02
+#define RTCHOUR_HRBCD12_SHIFT  0u
+#define RTCHOUR_HRBCD12_MASK   (0x1fu << RTCHOUR_HRBCD12_SHIFT)
+#define RTCHOUR_HRBCD12(x)     (((x) << RTCHOUR_HRBCD12_SHIFT) & RTCHOUR_HRBCD12_MASK)
+#define RTCHOUR_HRBCD12_GET(x) (((x) & RTCHOUR_HRBCD12_MASK) >> RTCHOUR_HRBCD12_SHIFT)
+#define RTCHOUR_HRBCD24_SHIFT  0u
+#define RTCHOUR_HRBCD24_MASK   (0x3fu << RTCHOUR_HRBCD24_SHIFT)
+#define RTCHOUR_HRBCD24(x)     (((x) << RTCHOUR_HRBCD24_SHIFT) & RTCHOUR_HRBCD24_MASK)
+#define RTCHOUR_HRBCD24_GET(x) (((x) & RTCHOUR_HRBCD24_MASK) >> RTCHOUR_HRBCD24_SHIFT)
+#define RTCHOUR_AMPM           (0x01u << 5)
+#define RTCHOUR_1224           (0x01u << 6)
+#define REG_RTCWKDAY 0x03
+#define RTCWKDAY_WKDAY_SHIFT   0u
+#define RTCWKDAY_WKDAY_MASK    (0x7u << RTCWKDAY_WKDAY_SHIFT)
+#define RTCWKDAY_WKDAY(x)      (((x) << RTCWKDAY_WKDAY_SHIFT) & RTCWKDAY_WKDAY_MASK)
+#define RTCWKDAY_WKDAY_GET(x)  (((x) & RTCWKDAY_WKDAY_MASK) >> RTCWKDAY_WKDAY_SHIFT)
+#define REG_RTCDATE 0x04
+#define RTCDATE_DATEBCD_SHIFT  0u
+#define RTCDATE_DATEBCD_MASK   (0x3fu << RTCDATE_DATEBCD_SHIFT)
+#define RTCDATE_DATEBCD(x)     (((x) << RTCDATE_DATEBCD_SHIFT) & RTCDATE_DATEBCD_MASK)
+#define RTCDATE_DATEBCD_GET(x) (((x) & RTCDATE_DATEBCD_MASK) >> RTCDATE_DATEBCD_SHIFT)
+#define REG_RTCMTH 0x05
+#define RTCMTH_MTHBCD_SHIFT    0u
+#define RTCMTH_MTHBCD_MASK     (0x1fu << RTCMTH_MTHBCD_SHIFT)
+#define RTCMTH_MTHBCD(x)       (((x) << RTCMTH_MTHBCD_SHIFT) & RTCMTH_MTHBCD_MASK)
+#define RTCMTH_MTHBCD_GET(x)   (((x) & RTCMTH_MTHBCD_MASK) >> RTCMTH_MTHBCD_SHIFT)
+#define MCP7940M_RTCMTH_LPYR   (0x01u << 5)
+#define REG_RTCYEAR 0x06
+#define RTCYEAR_YRBCD_SHIFT    0u
+#define RTCYEAR_YRBCD_MASK     (0xffu << RTCYEAR_YRBCD_SHIFT)
+#define RTCYEAR_YRBCD(x)       (((x) << RTCYEAR_YRBCD_SHIFT) & RTCYEAR_YRBCD_MASK)
+#define RTCYEAR_YRBCD_GET(x)   (((x) & RTCYEAR_YRBCD_MASK) >> RTCYEAR_YRBCD_SHIFT)
+#define REG_MCP7940M_CONTROL 0x07
+#define MCP7940M_CONTROL_OUT     (0x1u << 7)
+#define MCP7940M_CONTROL_SQWEN   (0x1u << 6)
+#define MCP7940M_CONTROL_ALM1EN  (0x1u << 5)
+#define MCP7940M_CONTROL_ALM0EN  (0x1u << 4)
+#define MCP7940M_CONTROL_EXTOSC  (0x1u << 3)
+#define MCP7940M_CONTROL_CRSTRIM (0x1u << 2)
+#define MCP7940M_CONTROL_SQWFS1  (0x1u << 1)
+#define MCP7940M_CONTROL_SQWFS0  (0x1u << 0)
+static inline uint8_t bcd_to_bin(uint8_t bcd)
+  uint8_t bin;
+  bin = bcd & 0x0f;
+  bin += ((bcd >> 4) & 0x0f) * 10;
+  return bin;
+static inline uint8_t bin_to_bcd(uint8_t bin)
+  uint8_t bcd;
+  bcd = bin % 10;
+  bcd |= (bin / 10) << 4;
+  return bcd;
+static struct mcp7940m_rtc *mcp7940m_get_context(int minor)
+  return (struct mcp7940m_rtc *) RTC_Table[minor].pDeviceParams;
+static int mcp7940m_i2c_read(
+    struct mcp7940m_rtc *ctx,
+    uint8_t addr,
+    uint8_t *buf,
+    size_t len
+  int fd;
+  int rv;
+  struct i2c_msg msgs[] = {{
+    .addr = ctx->i2c_addr,
+    .flags = 0,
+    .buf = &addr,
+    .len = 1,
+    .flags = I2C_M_RD,
+    .buf = buf,
+    .len = len,
+  struct i2c_rdwr_ioctl_data payload = {
+    .msgs = msgs,
+    .nmsgs = sizeof(msgs)/sizeof(msgs[0]),
+  fd = open(ctx->i2c_bus_path, O_RDWR);
+  if (fd < 0) {
+    return fd;
+  rv = ioctl(fd, I2C_RDWR, &payload);
+  close(fd);
+  return rv;
+static int mcp7940m_i2c_write(
+    uint8_t addr,
+    const uint8_t *buf,
+    size_t len
+  int fd;
+  int rv;
+  uint8_t writebuf[len + 1];
+    .flags = 0,
+    .buf = writebuf,
+    .len = len + 1,
+    .msgs = msgs,
+  writebuf[0] = addr;
+  memcpy(&writebuf[1], buf, len);
+  if (fd < 0) {
+    return fd;
+  close(fd);
+  return rv;
+static int mcp7940m_initialize_once(struct mcp7940m_rtc *ctx)
+  uint8_t reg;
+  ssize_t rv;
+  if (ctx->initialized) {
+    return 0;
+   * Make sure that all alarms and outputs are disabled. Enable or disable
+   * oscillator.
+   * This makes sure that we can start with an uninitialized device that has a
+   * random value in the control register.
+  reg = 0;
+  if (!ctx->crystal) {
+    reg |= MCP7940M_CONTROL_EXTOSC;
+  rv = mcp7940m_i2c_write(ctx, REG_MCP7940M_CONTROL, &reg, 1);
+  if (rv == 0 && ctx->crystal) {
+    rv = mcp7940m_i2c_read(ctx, REG_RTCSEC, &reg, 1);
+    if (rv == 0 && (reg & MCP7940M_RTCSEC_ST) == 0) {
+      reg |= MCP7940M_RTCSEC_ST;
+      rv = mcp7940m_i2c_write(ctx, REG_RTCSEC, &reg, 1);
+  ctx->initialized = true;
+  return rv;
+static int mcp7940m_get_time(int minor, rtems_time_of_day *time)
+  int rv = 0;
+  uint8_t buf[REG_RTCYEAR + 1];
+  struct mcp7940m_rtc *ctx = mcp7940m_get_context(minor);
+  if (!_System_state_Is_up(_System_state_Get())) {
+      return -1;
+  rtems_mutex_lock(&ctx->mutex);
+  rv = mcp7940m_initialize_once(ctx);
+  if (rv == 0) {
+    rv = mcp7940m_i2c_read(ctx, REG_RTCSEC, buf, sizeof(buf));
+  if (rv == 0) {
+    unsigned year = bcd_to_bin(RTCYEAR_YRBCD_GET(buf[REG_RTCYEAR])) +
+                    (TOD_BASE_YEAR / 100 * 100);
+    if (year < TOD_BASE_YEAR) {
+      year += 100;
+    time->year = year;
+    time->month = bcd_to_bin(RTCMTH_MTHBCD_GET(buf[REG_RTCMTH]));
+    time->day = bcd_to_bin(RTCDATE_DATEBCD_GET(buf[REG_RTCDATE]));
+    time->hour = bcd_to_bin(RTCHOUR_HRBCD24_GET(buf[REG_RTCHOUR]));
+    time->minute = bcd_to_bin(RTCMIN_MINBCD_GET(buf[REG_RTCMIN]));
+    time->second = bcd_to_bin(RTCSEC_SECBCD_GET(buf[REG_RTCSEC]));
+    time->ticks  = 0;
+  rtems_mutex_unlock(&ctx->mutex);
+  return rv;
+static int mcp7940m_set_time(int minor, const rtems_time_of_day *time)
+  int rv = 0;
+      return -1;
+  if (rv == 0) {
+  if (rv == 0) {
+    /* Make sure weekday is in range. Otherwise it's not relevant. */
+    if (RTCWKDAY_WKDAY_GET(buf[REG_RTCWKDAY]) < 1 ||
+        RTCWKDAY_WKDAY_GET(buf[REG_RTCWKDAY]) > 7) {
+      buf[REG_RTCWKDAY] &= ~RTCWKDAY_WKDAY_MASK;
+      buf[REG_RTCWKDAY] |= RTCWKDAY_WKDAY(1);
+    buf[REG_RTCYEAR] &= ~RTCYEAR_YRBCD_MASK;
+    buf[REG_RTCYEAR] |= RTCYEAR_YRBCD(bin_to_bcd(time->year % 100));
+    buf[REG_RTCMTH] &= ~RTCMTH_MTHBCD_MASK;
+    buf[REG_RTCMTH] |= RTCMTH_MTHBCD(bin_to_bcd(time->month));
+    buf[REG_RTCDATE] &= ~RTCDATE_DATEBCD_MASK;
+    buf[REG_RTCDATE] |= RTCDATE_DATEBCD(bin_to_bcd(time->day));
+    buf[REG_RTCHOUR] &= ~(RTCHOUR_HRBCD24_MASK | RTCHOUR_1224);
+    buf[REG_RTCHOUR] |= RTCHOUR_HRBCD24(bin_to_bcd(time->hour));
+    buf[REG_RTCMIN] &= ~RTCMIN_MINBCD_MASK;
+    buf[REG_RTCMIN] |= RTCMIN_MINBCD(bin_to_bcd(time->minute));
+    buf[REG_RTCSEC] &= ~RTCSEC_SECBCD_MASK;
+    buf[REG_RTCSEC] |= RTCSEC_SECBCD(bin_to_bcd(time->second));
+    rv = mcp7940m_i2c_write(ctx, REG_RTCSEC, buf, sizeof(buf));
+  return rv;
+static void mcp7940m_init(int minor)
+  (void) minor;
+  return true;
+const rtc_fns rtc_mcp7940m_fns = {
+  .deviceInitialize = mcp7940m_init,
+  .deviceGetTime =    mcp7940m_get_time,
+  .deviceSetTime =    mcp7940m_set_time,
diff --git a/spec/build/bsps/obj.yml b/spec/build/bsps/obj.yml
index 8da4869583..6f76e9bb7c 100644
--- a/spec/build/bsps/obj.yml
+++ b/spec/build/bsps/obj.yml
@@ -42,6 +42,7 @@ install:
   - bsps/include/libchip/ide_ctrl_cfg.h
   - bsps/include/libchip/ide_ctrl_io.h
   - bsps/include/libchip/m48t08.h
+  - bsps/include/libchip/mcp7940m-rtc.h
   - bsps/include/libchip/ns16550.h
   - bsps/include/libchip/ns16550_p.h
   - bsps/include/libchip/rtc.h
@@ -93,6 +94,7 @@ source:
 - bsps/shared/dev/rtc/m48t08_reg2.c
 - bsps/shared/dev/rtc/m48t08_reg4.c
 - bsps/shared/dev/rtc/m48t08_reg8.c
+- bsps/shared/dev/rtc/mcp7940m.c
 - bsps/shared/dev/rtc/rtcprobe.c
 - bsps/shared/dev/serial/arm-pl011.c
 - bsps/shared/dev/serial/ns16550-context.c
2.35.3
