[PATCH v1 1/2] bsps/stm32h7: Make UART7 pins configurable
Kinsey Moore kinsey.moore at oarcorp.com
Mon Jul 24 18:28:32 UTC 2023
This change allows for the pins assigned to UART7 to be reconfigured via
config.ini.
 bsps/arm/stm32h7/console/console-uart7-cfg.c    |  4 ++--
 spec/build/bsps/arm/stm32h7/grp.yml             |  4 ++++
 .../build/bsps/arm/stm32h7/optuart7gpiopins.yml | 17 +++++++++++++++++
 .../build/bsps/arm/stm32h7/optuart7gpioregs.yml | 17 +++++++++++++++++
 4 files changed, 40 insertions(+), 2 deletions(-)
 create mode 100644 spec/build/bsps/arm/stm32h7/optuart7gpiopins.yml
 create mode 100644 spec/build/bsps/arm/stm32h7/optuart7gpioregs.yml
diff --git a/bsps/arm/stm32h7/console/console-uart7-cfg.c b/bsps/arm/stm32h7/console/console-uart7-cfg.c
index dca19e652d..2ced4cf9c2 100644
--- a/bsps/arm/stm32h7/console/console-uart7-cfg.c
+++ b/bsps/arm/stm32h7/console/console-uart7-cfg.c
@@ -33,9 +33,9 @@
 const stm32h7_uart_config stm32h7_uart7_config = {
   .gpio = {
-    .regs = GPIOB,
+    .regs = STM32H7_UART7_GPIO_REGS,
     .config = {
-      .Pin = GPIO_PIN_3 | GPIO_PIN_4,
+      .Pin = STM32H7_UART7_GPIO_PINS,
       .Mode = GPIO_MODE_AF_PP,
       .Pull = GPIO_NOPULL,
       .Speed = GPIO_SPEED_FREQ_LOW,
diff --git a/spec/build/bsps/arm/stm32h7/grp.yml b/spec/build/bsps/arm/stm32h7/grp.yml
index 595762c665..239df9b898 100644
--- a/spec/build/bsps/arm/stm32h7/grp.yml
+++ b/spec/build/bsps/arm/stm32h7/grp.yml
@@ -106,6 +106,10 @@ links:
   uid: optusart3gpiopins
 - role: build-dependency
   uid: optusart3gpioregs
+- role: build-dependency
+  uid: optuart7gpiopins
+  uid: optuart7gpioregs
   uid: optvariant
diff --git a/spec/build/bsps/arm/stm32h7/optuart7gpiopins.yml b/spec/build/bsps/arm/stm32h7/optuart7gpiopins.yml
new file mode 100644
index 0000000000..0252bdab7c
--- /dev/null
+++ b/spec/build/bsps/arm/stm32h7/optuart7gpiopins.yml
@@ -0,0 +1,17 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+actions:
+- get-string: null
+- define-unquoted: null
+build-type: option
+copyrights:
+- Copyright (C) 2023 On-Line Applications Research (OAR)
+default:
+- enabled-by: true
+  value: ( GPIO_PIN_3 | GPIO_PIN_4 )
+description: |
+  GPIO pins used for the UART7 pin configuration.
+enabled-by: true
+format: '{}'
+links: []
+name: STM32H7_UART7_GPIO_PINS
+type: build
diff --git a/spec/build/bsps/arm/stm32h7/optuart7gpioregs.yml b/spec/build/bsps/arm/stm32h7/optuart7gpioregs.yml
index 0000000000..16ce3bf526
--- /dev/null
+++ b/spec/build/bsps/arm/stm32h7/optuart7gpioregs.yml
@@ -0,0 +1,17 @@
+actions:
+- get-string: null
+build-type: option
+copyrights:
+default:
+- enabled-by: true
+  value: GPIOB
+description: |
+  GPIO registers used for the UART7 pin configuration.
+enabled-by: true
+format: '{}'
+links: []
+name: STM32H7_UART7_GPIO_REGS
+type: build
2.39.2
