[PATCH 1/8] libtest: Place files into a Doxygen group
Tue Jul 25 08:49:19 UTC 2023
Canonicalize the file headers.
Update #3707.
 cpukit/include/rtems/test-info.h         |  9 +++++++++
 cpukit/include/rtems/test.h              | 13 +++++++++++--
 cpukit/libtest/t-test-busy-tick.c        |  3 ++-
 cpukit/libtest/t-test-busy.c             |  3 ++-
 cpukit/libtest/t-test-checks-eno.c       | 13 +++++++++++--
 cpukit/libtest/t-test-checks-psx.c       |  5 ++++-
 cpukit/libtest/t-test-checks.c           | 13 +++++++++++--
 cpukit/libtest/t-test-hash-sha256.c      | 13 +++++++++++--
 cpukit/libtest/t-test-interrupt.c        |  3 ++-
 cpukit/libtest/t-test-rtems-context.c    | 13 +++++++++++--
 cpukit/libtest/t-test-rtems-fds.c        | 13 +++++++++++--
 cpukit/libtest/t-test-rtems-heap.c       | 13 +++++++++++--
 cpukit/libtest/t-test-rtems-measure.c    | 13 +++++++++++--
 cpukit/libtest/t-test-rtems-memory.c     |  9 +++++++++
 cpukit/libtest/t-test-rtems-objs.c       |  5 +++--
 cpukit/libtest/t-test-rtems-posix-keys.c |  5 +++--
 cpukit/libtest/t-test-rtems.c            | 13 +++++++++++--
 cpukit/libtest/t-test-rtems.h            |  5 +++--
 cpukit/libtest/t-test-thread-switch.c    |  3 ++-
 cpukit/libtest/t-test-time.c             | 13 +++++++++++--
 cpukit/libtest/t-test.c                  | 13 +++++++++++--
 cpukit/libtest/testbeginend.c            |  9 +++++++++
 22 files changed, 169 insertions(+), 33 deletions(-)
diff --git a/cpukit/include/rtems/test-info.h b/cpukit/include/rtems/test-info.h
index 055ed4f25b..c1b41ccc6e 100644
--- a/cpukit/include/rtems/test-info.h
+++ b/cpukit/include/rtems/test-info.h
@@ -1,5 +1,14 @@
 /* SPDX-License-Identifier: BSD-2-Clause */
+ * @file
+ * @ingroup RTEMSTestFramework
+ * @brief This header file provides interfaces of the
+ *   RTEMS Test Framework.
  * Copyright (C) 2014, 2018 embedded brains GmbH & Co. KG
diff --git a/cpukit/include/rtems/test.h b/cpukit/include/rtems/test.h
index 79313343a0..04eebd6e75 100644
--- a/cpukit/include/rtems/test.h
+++ b/cpukit/include/rtems/test.h
@@ -1,6 +1,15 @@
- * SPDX-License-Identifier: BSD-2-Clause
+ * @file
  * Copyright (C) 2017, 2021 embedded brains GmbH & Co. KG
diff --git a/cpukit/libtest/t-test-busy-tick.c b/cpukit/libtest/t-test-busy-tick.c
index b7fed247fa..5e45757f24 100644
--- a/cpukit/libtest/t-test-busy-tick.c
+++ b/cpukit/libtest/t-test-busy-tick.c
@@ -5,7 +5,8 @@
  * @ingroup RTEMSTestFrameworkImpl
- * @brief Implementation of T_get_one_clock_tick_busy().
+ * @brief This source file contains the implementation of
+ *   T_get_one_clock_tick_busy().
diff --git a/cpukit/libtest/t-test-busy.c b/cpukit/libtest/t-test-busy.c
index 8583284087..e28fa3e5e4 100644
--- a/cpukit/libtest/t-test-busy.c
+++ b/cpukit/libtest/t-test-busy.c
@@ -5,7 +5,8 @@
- * @brief Implementation of T_busy().
+ *   T_busy().
diff --git a/cpukit/libtest/t-test-checks-eno.c b/cpukit/libtest/t-test-checks-eno.c
index 5b450ccf99..48736915b4 100644
--- a/cpukit/libtest/t-test-checks-eno.c
+++ b/cpukit/libtest/t-test-checks-eno.c
@@ -1,6 +1,15 @@
+ * @file
+ * @ingroup RTEMSTestFrameworkImpl
+ *   T_strerror(), T_check_eno(), and T_check_eno_success().
  * Copyright (C) 2018 embedded brains GmbH & Co. KG
diff --git a/cpukit/libtest/t-test-checks-psx.c b/cpukit/libtest/t-test-checks-psx.c
index 5394ea537a..5d6ec25bda 100644
--- a/cpukit/libtest/t-test-checks-psx.c
+++ b/cpukit/libtest/t-test-checks-psx.c
@@ -3,7 +3,10 @@
  * @file
- * @brief
+ *   T_check_psx_error() and T_check_psx_success().
diff --git a/cpukit/libtest/t-test-checks.c b/cpukit/libtest/t-test-checks.c
index 40479a8277..b83e83f1f3 100644
--- a/cpukit/libtest/t-test-checks.c
+++ b/cpukit/libtest/t-test-checks.c
@@ -1,6 +1,15 @@
+ * @file
+ * @brief This source file contains the implementation of various RTEMS Test
+ *   Framework check functions.
diff --git a/cpukit/libtest/t-test-hash-sha256.c b/cpukit/libtest/t-test-hash-sha256.c
index a9aa4df023..e937f81ddf 100644
--- a/cpukit/libtest/t-test-hash-sha256.c
+++ b/cpukit/libtest/t-test-hash-sha256.c
@@ -1,6 +1,15 @@
+ * @file
+ *   T_report_hash_sha256_update() and T_report_hash_sha256().
  * Copyright (C) 2019, 2021 embedded brains GmbH & Co. KG
diff --git a/cpukit/libtest/t-test-interrupt.c b/cpukit/libtest/t-test-interrupt.c
index 800724dd93..8796dc0b5a 100644
--- a/cpukit/libtest/t-test-interrupt.c
+++ b/cpukit/libtest/t-test-interrupt.c
@@ -5,7 +5,8 @@
- * @brief Implementation of T_interrupt_test().
+ *   T_interrupt_test().
diff --git a/cpukit/libtest/t-test-rtems-context.c b/cpukit/libtest/t-test-rtems-context.c
index 351a29a1ca..1405db0c7d 100644
--- a/cpukit/libtest/t-test-rtems-context.c
+++ b/cpukit/libtest/t-test-rtems-context.c
@@ -1,6 +1,15 @@
+ * @file
+ *   T_check_task_context().
  * Copyright (C) 2019 embedded brains GmbH & Co. KG
diff --git a/cpukit/libtest/t-test-rtems-fds.c b/cpukit/libtest/t-test-rtems-fds.c
index df5279f585..2b520972d2 100644
--- a/cpukit/libtest/t-test-rtems-fds.c
+++ b/cpukit/libtest/t-test-rtems-fds.c
@@ -1,6 +1,15 @@
+ * @file
+ *   T_check_file_descriptors().
diff --git a/cpukit/libtest/t-test-rtems-heap.c b/cpukit/libtest/t-test-rtems-heap.c
index ac54e96fc7..2fb069a50e 100644
--- a/cpukit/libtest/t-test-rtems-heap.c
+++ b/cpukit/libtest/t-test-rtems-heap.c
@@ -1,6 +1,15 @@
+ * @file
+ *   T_check_heap().
diff --git a/cpukit/libtest/t-test-rtems-measure.c b/cpukit/libtest/t-test-rtems-measure.c
index c165fc8f2a..2a2376cd27 100644
--- a/cpukit/libtest/t-test-rtems-measure.c
+++ b/cpukit/libtest/t-test-rtems-measure.c
@@ -1,6 +1,15 @@
+ * @file
+ *   T_measure_runtime().
  * Copyright (C) 2018, 2021 embedded brains GmbH & Co. KG
diff --git a/cpukit/libtest/t-test-rtems-memory.c b/cpukit/libtest/t-test-rtems-memory.c
index 1d41192f56..ed0908ae10 100644
--- a/cpukit/libtest/t-test-rtems-memory.c
+++ b/cpukit/libtest/t-test-rtems-memory.c
@@ -1,5 +1,14 @@
+ * @file
+ *   T_memory_allocate(), T_memory_deallocate(), and T_memory_action().
  * Copyright (C) 2020 embedded brains GmbH & Co. KG
diff --git a/cpukit/libtest/t-test-rtems-objs.c b/cpukit/libtest/t-test-rtems-objs.c
index 2eb3db6f7f..ce752424b5 100644
--- a/cpukit/libtest/t-test-rtems-objs.c
+++ b/cpukit/libtest/t-test-rtems-objs.c
@@ -3,9 +3,10 @@
  * @file
- * @ingroup RTEMSTestFramework
- * @brief RTEMS Objects Support for Test Framework
+ * @brief This source file contains the implementation of the RTEMS objects
+ *   test support.
diff --git a/cpukit/libtest/t-test-rtems-posix-keys.c b/cpukit/libtest/t-test-rtems-posix-keys.c
index a26988e27a..65153d3d33 100644
--- a/cpukit/libtest/t-test-rtems-posix-keys.c
+++ b/cpukit/libtest/t-test-rtems-posix-keys.c
@@ -3,9 +3,10 @@
  * @file
- * @brief RTEMS POSIX Keys Support for Test Framework
+ *   T_check_posix_keys().
diff --git a/cpukit/libtest/t-test-rtems.c b/cpukit/libtest/t-test-rtems.c
index 97864c1c76..d4fc6827af 100644
--- a/cpukit/libtest/t-test-rtems.c
+++ b/cpukit/libtest/t-test-rtems.c
@@ -1,6 +1,15 @@
+ * @file
+ *   T_putchar_default(), T_check_rsc(), and T_check_rsc_success().
diff --git a/cpukit/libtest/t-test-rtems.h b/cpukit/libtest/t-test-rtems.h
index 9d40f1aa9b..d429c4f5bd 100644
--- a/cpukit/libtest/t-test-rtems.h
+++ b/cpukit/libtest/t-test-rtems.h
@@ -3,9 +3,10 @@
  * @file
- * @ingroup RTEMSTestFrameworkImpl
- * @brief RTEMS Support for Test Framework
+ * @brief This header file provides the RTEMS-specific API of the RTEMS Test
+ *   Framework.
diff --git a/cpukit/libtest/t-test-thread-switch.c b/cpukit/libtest/t-test-thread-switch.c
index 44cd819dd1..99d2d7ee29 100644
--- a/cpukit/libtest/t-test-thread-switch.c
+++ b/cpukit/libtest/t-test-thread-switch.c
@@ -5,7 +5,8 @@
- * @brief Implementation of T_thread_switch_record().
+ * @brief This source file contains the implementation of the thread switch
+ *   recorder.
diff --git a/cpukit/libtest/t-test-time.c b/cpukit/libtest/t-test-time.c
index 3f953626a5..2acb75f799 100644
--- a/cpukit/libtest/t-test-time.c
+++ b/cpukit/libtest/t-test-time.c
@@ -1,6 +1,15 @@
+ * @file
+ * @brief This source file contains the implementation of the time and ticks
+ *   test support.
diff --git a/cpukit/libtest/t-test.c b/cpukit/libtest/t-test.c
index 4f3bf56142..427b3b426a 100644
--- a/cpukit/libtest/t-test.c
+++ b/cpukit/libtest/t-test.c
@@ -1,6 +1,15 @@
+ * @file
+ * @brief This source file contains the core implementation of RTEMS Test
+ *    Framework.
  * Copyright (C) 2018, 2020 embedded brains GmbH & Co. KG
diff --git a/cpukit/libtest/testbeginend.c b/cpukit/libtest/testbeginend.c
index 067155fef3..546fdf65ff 100644
--- a/cpukit/libtest/testbeginend.c
+++ b/cpukit/libtest/testbeginend.c
@@ -1,5 +1,14 @@
+ * @file
+ *   rtems_test_begin() and rtems_test_end().
2.35.3
