[PATCH] bsps/arm: fix installation broken by recent CMSIS files update
Christian MAUDERER christian.mauderer at embedded-brains.de
Tue Jul 25 10:07:21 UTC 2023
Hello Karel,
I tested with the patch from Chris (which is identical to yours) and I
have no problems building and installing the imx7, imxrt1052 and
imxrt1166-cm7-saltshaker BSP and libbsd from master for these BSPs.
The only point that I have noted are a lot of new warnings when building
the BSP. Example:
../../../../../rtems-sources/rtems/bsps/arm/include/cmsis_gcc.h:139:15:
warning: nested extern declaration of '_start' [-Wnested-externs]
   139 |   extern void _start(void) __NO_RETURN;
Best regards
Christian
On 2023-07-25 08:55, Karel Gardas wrote:
> Sure! Not a problem, I was just waiting for Christian to confirm its
> also working on his side.
> Thanks,
> Karel
> On 7/25/23 03:34, Chris Johns wrote:
>> Hi Karel,
>> I did not see this and made and pushed a similar patch. Thanks for
>> this and
>> sorry for not checking closely as I missed it on the first pass.
>> Thanks
>> Chris
>> On 25/7/2023 1:53 am, Karel Gardas wrote:
>>>   spec/build/bsps/arm/grp.yml | 7 ++++---
>>>   1 file changed, 4 insertions(+), 3 deletions(-)
>>> diff --git a/spec/build/bsps/arm/grp.yml b/spec/build/bsps/arm/grp.yml
>>> index 1058f58d92..a48cd80d74 100644
>>> --- a/spec/build/bsps/arm/grp.yml
>>> +++ b/spec/build/bsps/arm/grp.yml
>>> @@ -10,12 +10,13 @@ includes: []
>>>   install:
>>>   - destination: ${BSP_INCLUDEDIR}
>>>     source:
>>> +  - bsps/arm/include/cachel1_armv7.h
>>> +  - bsps/arm/include/cmsis_compiler.h
>>>     - bsps/arm/include/cmsis_gcc.h
>>> +  - bsps/arm/include/cmsis_version.h
>>>     - bsps/arm/include/core_cm7.h
>>>     - bsps/arm/include/core_cm4.h
>>> -  - bsps/arm/include/core_cmFunc.h
>>> -  - bsps/arm/include/core_cmInstr.h
>>> -  - bsps/arm/include/core_cmSimd.h
>>> +  - bsps/arm/include/mpu_armv7.h
>>>     - bsps/arm/include/uart.h
>>>   - destination: ${BSP_INCLUDEDIR}/bsp
>>>     source:
> devel mailing list
> devel at rtems.org
embedded brains GmbH & Co. KG
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
email:  christian.mauderer at embedded-brains.de
phone:  +49-89-18 94 741 - 18
mobile: +49-176-152 206 08
Registernummer: HRA 117265
