[PATCH] build: Export BSP base and family via pkg-config
Tue Jul 25 17:15:42 UTC 2023
On Tue, Jul 25, 2023 at 11:11 AM Sebastian Huber
> On 25.07.23 18:01, Gedare Bloom wrote:
> > On Tue, Jul 25, 2023 at 5:13 AM Sebastian Huber
> >> This allows application and library build systems to derive option
> >> values from the BSP base and family names.
> >>   spec/build/bsps/pkgconfig.yml | 2 ++
> >>   1 file changed, 2 insertions(+)
> >> diff --git a/spec/build/bsps/pkgconfig.yml b/spec/build/bsps/pkgconfig.yml
> >> index e08c83fe27..afaffbbf0f 100644
> >> --- a/spec/build/bsps/pkgconfig.yml
> >> +++ b/spec/build/bsps/pkgconfig.yml
> >> @@ -15,6 +15,8 @@ content: |
> >>     ABI_FLAGS=${ABI_FLAGS}
> >>     RTEMS_ARCH=${ARCH}
> >>     RTEMS_BSP=${BSP_NAME}
> >> +  RTEMS_BSP_BASE=${BSP_BASE}
> >> +  RTEMS_BSP_FAMILY=${BSP_FAMILY}
> > These expose a little bit of the internal working of the build system.
> > I think it's fine, since these two fields should not change over time.
> > But, it commits us to maintain this mapping and these variables.
> We had the RTEMS_BSP also in the old build system, but it was actually
> what is now the RTEMS_BSP_BASE in this patch. With the user-defined BSP
> names we have for:
> [arch/user_bsp_name]
> INHERIT = system_bsp_name
> This results in:
> RTEMS_BSP = user_bsp_name
> RTEMS_BSP_BASE = system_bsp_name
> Maybe we should change this to:
> RTEMS_BSP = system_bsp_name
> RTEMS_BSP_NAME = user_bsp_name
This would make more sense. I don't know what it might break to make
this change now though, as external build tools may rely on the
current definition of RTEMS_BSP?
> The RTEMS_BSP_FAMILY is quite handy if you want to for example enable a
> network interface driver for a couple of BSPs. You don't have to
> enumerate all variants that exist now and in the future.
Yes, I see that. I'm fine with the addition, it makes sense.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
