[PATCH] score/arm: style fixes
Tue Jul 25 23:02:56 UTC 2023
On Tue, Jul 25, 2023 at 5:53 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Tue, Jul 25, 2023 at 4:48 PM Joel Sherrill <joel at rtems.org> wrote:
> > I may have missed something. Commented in one place.
> > It looks like mostly spaces inside () and variable/parameter declaration
> changes.
> Yes, for the most part those are the least consistent so far.
> > On Tue, Jul 25, 2023 at 4:38 PM Gedare Bloom <gedare at rtems.org> wrote:
> >> diff --git a/cpukit/score/cpu/arm/armv7m-isr-dispatch.c
> b/cpukit/score/cpu/arm/armv7m-isr-dispatch.c
> >> index ea168969ba..dfc125d545 100644
> >> --- a/cpukit/score/cpu/arm/armv7m-isr-dispatch.c
> >> +++ b/cpukit/score/cpu/arm/armv7m-isr-dispatch.c
> >> @@ -43,7 +43,7 @@
> >>  #ifdef ARM_MULTILIB_ARCH_V7M
> >> -static void __attribute__((naked)) _ARMV7M_Thread_dispatch( void )
> >> +static void __attribute__((naked)) _ARMV7M_Thread_dispatch(void)
> >>    __asm__ volatile (
> >>      "bl _Thread_Dispatch\n"
> >> @@ -53,7 +53,7 @@ static void __attribute__((naked))
> >> -static void _ARMV7M_Trigger_lazy_floating_point_context_save( void )
> >> +static void _ARMV7M_Trigger_lazy_floating_point_context_save(void)
> >>  #ifdef ARM_MULTILIB_VFP
> >>    __asm__ volatile (
> >> @@ -62,7 +62,7 @@ static void
> >>  #endif
> >> -void _ARMV7M_Pendable_service_call( void )
> >> +void _ARMV7M_Pendable_service_call(void)
> >>    Per_CPU_Control *cpu_self = _Per_CPU_Get();
> >> @@ -73,7 +73,7 @@ void _ARMV7M_Pendable_service_call( void )
> >>     * this interrupt service may be delayed until interrupts are enable
> again.
> >>    if (
> >> -    ( cpu_self->isr_nest_level |
> cpu_self->thread_dispatch_disable_level ) == 0
> >> +    (cpu_self->isr_nest_level |
> cpu_self->thread_dispatch_disable_level) == 0
> > Does this fit on a single line?
> No. it's like two characters short. In fact, i had to do this one
> manually. otherwise, it breaks as
> if ( (...
>     ) == 0 ) {
! instead of == 0? :)
> > Ignoring the fact it is using bitwise operations on two integer
> counters. Perhaps
> > it should be a +?
> separate problem I suppose. That is a little bit of a suspicious bit of
> logic.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230725/a72dc2c2/attachment.htm>
