[PATCH] score/arm: style fixes
Wed Jul 26 05:11:24 UTC 2023
On 25.07.23 23:38, Gedare Bloom wrote:
> diff --git a/cpukit/score/cpu/arm/aarch32-psma-init.c b/cpukit/score/cpu/arm/aarch32-psma-init.c
> index 93a3673a98..b30cb5e308 100644
> --- a/cpukit/score/cpu/arm/aarch32-psma-init.c
> +++ b/cpukit/score/cpu/arm/aarch32-psma-init.c
> @@ -46,7 +46,7 @@
>   #include <rtems/score/cpu.h>
>   #define AARCH32_PMSA_REGION_MAX \
> -  ( ( AARCH32_MPUIR_REGION_MASK >> AARCH32_MPUIR_REGION_SHIFT ) + 1 )
> +  ((AARCH32_MPUIR_REGION_MASK >> AARCH32_MPUIR_REGION_SHIFT) + 1)
>   static void _AArch32_PMSA_Configure(
>     const AArch32_PMSA_Region *regions,
> @@ -57,36 +57,36 @@ static void _AArch32_PMSA_Configure(
>     size_t   ri;
>     uint32_t sctlr;
> -  for ( ri = 0 ; ri < region_used; ++ri ) {
> +  for ( ri = 0; ri < region_used; ++ri ) {
>       uint32_t prbar;
>       uint32_t prlar;
>       uint32_t attr;
> -    prbar = regions[ ri ].base;
> -    prlar = regions[ ri ].limit;
> -    attr = regions[ ri ].attributes;
> +    prbar = regions[ri].base;
> +    prlar = regions[ri].limit;
> +    attr  = regions[ri].attributes;
> -    prbar |= ( attr >> 6 ) & 0x3fU;
> +    prbar |= (attr >> 6) & 0x3fU;
>       prlar |= attr & 0x3fU;
> -    _AArch32_Write_prselr( ri );
> +    _AArch32_Write_prselr(ri);
>       _ARM_Instruction_synchronization_barrier();
> -    _AArch32_Write_prbar( prbar );
> -    _AArch32_Write_prlar( prlar );
> +    _AArch32_Write_prbar(prbar);
> +    _AArch32_Write_prlar(prlar);
The existing style had the spaces which are removed here. I think this
would lead to a lot of changes in score.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
