[PATCH v2] build: Add optional RTEMS_VERSION_CONTROL_KEY
Wed Jul 26 05:44:04 UTC 2023
Allow the user to set the version control key.
 spec/build/cpukit/grp.yml                  |  2 ++
 spec/build/cpukit/optversioncontrolkey.yml | 21 ++++++++++++
 wscript                                    | 38 +++++++++++++---------
 3 files changed, 45 insertions(+), 16 deletions(-)
 create mode 100644 spec/build/cpukit/optversioncontrolkey.yml
diff --git a/spec/build/cpukit/grp.yml b/spec/build/cpukit/grp.yml
index e07e975d7d..eeaefcba91 100644
--- a/spec/build/cpukit/grp.yml
+++ b/spec/build/cpukit/grp.yml
@@ -18,6 +18,8 @@ links:
   uid: cpuopts
 - role: build-dependency
   uid: cfghdr
+- role: build-dependency
+  uid: optversioncontrolkey
   uid: libdebugger
diff --git a/spec/build/cpukit/optversioncontrolkey.yml b/spec/build/cpukit/optversioncontrolkey.yml
new file mode 100644
index 0000000000..36dfeeb82a
--- /dev/null
+++ b/spec/build/cpukit/optversioncontrolkey.yml
@@ -0,0 +1,21 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+actions:
+- get-string: null
+- env-assign: null
+build-type: option
+copyrights:
+- Copyright (C) 2022, 2023 embedded brains GmbH & Co. KG
+default:
+- enabled-by: true
+  value: git
+description: |
+  This option defines what is returned by the directives rtems_version() and
+  rtems_version_control_key().  If the value is "git", then the version key is
+  determined by the Git repository containing the waf top directory for each
+  build process.  If the value is the empty string "", then no version key is
+  used.  Otherwise, the value is used as the version key.
+enabled-by: true
+format: '{}'
+links: []
+name: RTEMS_VERSION_CONTROL_KEY
+type: build
diff --git a/wscript b/wscript
index 862000513d..e80c3800b6 100755
--- a/wscript
+++ b/wscript
@@ -58,38 +58,44 @@ def no_unicode(value):
 class VersionControlKeyHeader:
-    _content = None
+    _git_commit = None
     @staticmethod
     def write(bld, filename):
-        if VersionControlKeyHeader._content is None:
-            from waflib.Build import Context
-            from waflib.Errors import WafError
-            content = """/*
+        content = """/*
  * Automatically generated. Do not edit.
 #if !defined(_RTEMS_VERSION_VC_KEY_H_)
 #define _RTEMS_VERSION_VC_KEY_H_
-            try:
-                rev = bld.cmd_and_log("git rev-parse HEAD",
-                                      quiet=Context.STDOUT).strip()
-                content += """#define RTEMS_VERSION_VC_KEY "{}"
+        rev = bld.env.RTEMS_VERSION_CONTROL_KEY
+        if rev == "git":
+            rev = VersionControlKeyHeader._git_commit
+            if rev is None:
+                from waflib.Build import Context
+                from waflib.Errors import WafError
+                try:
+                    rev = bld.cmd_and_log("git rev-parse HEAD",
+                                          quiet=Context.STDOUT).strip()
+                except WafError:
+                    rev = ""
+                VersionControlKeyHeader._git_commit = rev
+        if rev:
+            content += """#define RTEMS_VERSION_VC_KEY "{}"
 """.format(rev)
-            except WafError:
-                content += """/* No version control key found; release? */
+        else:
+            content += """/* No version control key found; release? */
-            content += """#endif
+        content += """#endif
-            VersionControlKeyHeader._content = content
         f = bld.bldnode.make_node(filename)
         f.parent.mkdir()
         try:
             if content != f.read():
-                f.write(VersionControlKeyHeader._content)
+                f.write(content)
         except:
+            f.write(content)
 class EnvWrapper(object):
2.35.3
