[PATCH] eng: add Apache License 2.0 restriction
Wed Jul 26 14:52:49 UTC 2023
On Wed, Jul 26, 2023 at 4:28 AM Karel Gardas <karel at functional.vision> wrote:
>  eng/license-requirements.rst | 18 +++++++++++++++++-
>  1 file changed, 17 insertions(+), 1 deletion(-)
> diff --git a/eng/license-requirements.rst b/eng/license-requirements.rst
> index b2720f2..b9eea9a 100644
> --- a/eng/license-requirements.rst
> +++ b/eng/license-requirements.rst
> @@ -98,9 +98,25 @@ these guidelines:
>  * Advertising obligations are not acceptable.
>  * Some license restrictions may be permissible. These will be considered
> -  on a case-by-case basis.
> +  on a case-by-case basis. See below for a list of such restrictions.
>  In practice, these guidelines are not hard to follow. Critically,
>  they protect the freedom of the RTEMS source code and that of end users
>  to select the license and distribution terms they prefer for their
>  RTEMS-based application.
> +License restrictions
> +* Apache License 2.0 in section 4 (b) requires modified files to carry
> +  prominent notice about performed modification. In case you modify such
> +  file and the notice is not there yet you are required to put notice
> +  below at the top of the modified file. If the notice is already
> +  there you don't need to add it second time.
> +  The notice should look:
> +  .. code-block:: c
> +      * The file was modified by RTEMS contributors.
Add a note about NOTICES (and that we currently don't have one.)
> 2.25.1
> devel mailing list
> devel at rtems.org
