[PATCH] bsps/stm32h7: Allow use of max temp range
Kinsey Moore kinsey.moore at oarcorp.com
Wed Jul 26 20:48:13 UTC 2023
This adds an option to allow operation of the CPU at its maximum
temperature range of 125F by reducing the CPU clock to 400MHz instead of
the 105F limit imposed by the default 480MHz CPU clock. This tradeoff is
detailed in table 122 in section 7.3.1 of the STM32H743VI datasheet. The
default remains at 480MHz/105F.
 .../stm/stm32h743i-eval/stm32h7-config-osc.c   |  8 ++++++++
 spec/build/bsps/arm/stm32h7/bspstm32h7.yml     |  2 ++
 spec/build/bsps/arm/stm32h7/optenthermal.yml   | 18 ++++++++++++++++++
 3 files changed, 28 insertions(+)
 create mode 100644 spec/build/bsps/arm/stm32h7/optenthermal.yml
diff --git a/bsps/arm/stm32h7/boards/stm/stm32h743i-eval/stm32h7-config-osc.c b/bsps/arm/stm32h7/boards/stm/stm32h743i-eval/stm32h7-config-osc.c
index df55a49b3c..016f772309 100644
--- a/bsps/arm/stm32h7/boards/stm/stm32h743i-eval/stm32h7-config-osc.c
+++ b/bsps/arm/stm32h7/boards/stm/stm32h743i-eval/stm32h7-config-osc.c
@@ -42,9 +42,17 @@ const RCC_OscInitTypeDef stm32h7_config_oscillator = {
   .PLL.PLLState = RCC_PLL_ON,
   .PLL.PLLSource = RCC_PLLSOURCE_HSE,
   .PLL.PLLM = 5,
+#ifdef STM32H7_OSC_ENABLE_MAX_THERMAL_RANGE
+  .PLL.PLLN = 160,
+#else
   .PLL.PLLN = 192,
+#endif
   .PLL.PLLP = 2,
+  .PLL.PLLQ = 2,
+#else
   .PLL.PLLQ = 12,
+#endif
   .PLL.PLLR = 2,
   .PLL.PLLRGE = RCC_PLL1VCIRANGE_2,
   .PLL.PLLVCOSEL = RCC_PLL1VCOWIDE,
diff --git a/spec/build/bsps/arm/stm32h7/bspstm32h7.yml b/spec/build/bsps/arm/stm32h7/bspstm32h7.yml
index 0aaf1f0cc6..2614457bcc 100644
--- a/spec/build/bsps/arm/stm32h7/bspstm32h7.yml
+++ b/spec/build/bsps/arm/stm32h7/bspstm32h7.yml
@@ -13,6 +13,8 @@ install: []
 links:
 - role: build-dependency
   uid: grp
+- role: build-dependency
+  uid: optenthermal
 source:
 - bsps/arm/stm32h7/boards/stm/stm32h743i-eval/stm32h7-bspstarthooks.c
 - bsps/arm/stm32h7/boards/stm/stm32h743i-eval/stm32h7-config-clk.c
diff --git a/spec/build/bsps/arm/stm32h7/optenthermal.yml b/spec/build/bsps/arm/stm32h7/optenthermal.yml
new file mode 100644
index 0000000000..ff79db213d
--- /dev/null
+++ b/spec/build/bsps/arm/stm32h7/optenthermal.yml
@@ -0,0 +1,18 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+actions:
+- get-boolean: null
+- define-condition: null
+build-type: option
+copyrights:
+- Copyright (C) 2023 On-Line Applications Research (OAR)
+default:
+- enabled-by: true
+  value: false
+description: |
+  Allow use of the maximum thermal range the CPU is capable of by reducing the
+  CPU clock to 400MHz
+enabled-by: true
+format: '{}'
+links: []
+name: STM32H7_OSC_ENABLE_MAX_THERMAL_RANGE
+type: build
2.39.2
