[PATCH] doxygen: Replace main page
Thu Jul 27 13:57:38 UTC 2023
On Thu, Jul 27, 2023 at 12:52 AM Sebastian Huber <
> On 27.07.23 02:13, Joel Sherrill wrote:
> > On Wed, Jul 26, 2023 at 12:50 AM Sebastian Huber
> > <sebastian.huber at embedded-brains.de
> > <mailto:sebastian.huber at embedded-brains.de>> wrote:
> >     Replace the main page with a high level description of the RTEMS
> feature
> >     set similar to:
> https://docs.rtems.org/branches/master/user/overview/index.html#features <
> https://docs.rtems.org/branches/master/user/overview/index.html#features>
> >     The replaced content can be found in the RTEMS Classic API Guide:
> >     https://docs.rtems.org/branches/master/c-user/overview.html
> >     <https://docs.rtems.org/branches/master/c-user/overview.html>
> >     https://docs.rtems.org/branches/master/c-user/key_concepts.html
> >     <https://docs.rtems.org/branches/master/c-user/key_concepts.html>
> >     Update #3705.
> >       cpukit/include/rtems/rtems/mainpage.h | 1078
> >       1 file changed, 166 insertions(+), 912 deletions(-)
> >     diff --git a/cpukit/include/rtems/rtems/mainpage.h
> >     b/cpukit/include/rtems/rtems/mainpage.h
> >     index f168cc3395..d284429d20 100644
> >     --- a/cpukit/include/rtems/rtems/mainpage.h
> >     +++ b/cpukit/include/rtems/rtems/mainpage.h
> >     @@ -10,8 +10,7 @@
> >     - *  COPYRIGHT (c) 1989-2014.
> >     - *  On-Line Applications Research Corporation (OAR).
> >     + * Copyright (C) 2021 embedded brains GmbH & Co. KG
> > No. You are reformatting this. This text dates back to the beginnings of
> > RTEMS. You should NOT remove the OAR copyright.
> I am quite careful with copyright, but everyone can make mistakes. This
> patch replaces the original content with the new features section from:
> https://git.rtems.org/rtems-docs/commit/user/overview/index.rst?id=52f4890281a50d7d2e27386257cc9799d9152707
> Which updated OAR Copyright line do you want to see in this patch? I
> will add it to v2 of the patch.
This is based on content that was in the introduction to the Classic API
Guide
which dates back to at least 1992 since I can download one from then. Yes,
I think it should stay.
> >     + * The Real-Time Executive for Multiprocessor Systems (RTEMS) is a
> >     + * multi-threaded, single address-space, real-time operating system
> >     with no
> >     + * kernel-space/user-space separation.  It is capable to operate in
> >     an SMP
> >     + * configuration providing a state of the art feature set.
> >     + * RTEMS is licensed under a [modified GPL 2.0 or later license
> with an
> >     + * exception for static
> >     linking](https://git.rtems.org/rtems/tree/LICENSE
> >     <https://git.rtems.org/rtems/tree/LICENSE>>).
> >     + * It exposes no license requirements on application code.  The
> >     third-party
> >     + * software used and distributed by RTEMS which may be linked to the
> >     + * application is licensed under permissive open source licenses.
> >     Everything
> >     + * necessary to build RTEMS applications is available as open
> >     source software.
> >     + * This makes you completely vendor independent.
> >     + * The goal is to use the [BSD 2-Clause
> >     + * license](https://git.rtems.org/rtems/tree/LICENSE.BSD-2-Clause
> >     <https://git.rtems.org/rtems/tree/LICENSE.BSD-2-Clause>) for new
> code
> >     + * or code those copyright holder agreed to a license change, see
> >     + * [#3053](https://devel.rtems.org/ticket/3053
> >     <https://devel.rtems.org/ticket/3053>) for the details.
> > This is true but out of date. The bulk of the target and BSP independent
> > code
> > is BSD-2 and we state that first. There are older submissions --
> > primarily around
> > BSPs and a couple of architectures where GPL code is present.
> > We state now that we are BSD-2 with remnants of GPLv2 + exception and
> will
> > NOT accept code under the old license.
> Yes, the patch is actually from 2021, but I was busy with other things
> in the meantime. I will reformulate this section for v2. The user manual
> probably needs also an update:
That may have been written while I was tracking people down and changing
the license on files as allowed.
For 7, we have already decided to remove some ports which are GPL+exception
based on technical factors. But if you find GPL code and know how to
contact that
person, help is appreciated. I worked my way through everyone I could. It
was
quite time consuming.
--joel
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230727/9db9b7d4/attachment-0001.htm>
